[FOSS-GPS] RTKlib help pls
Bud Asterisk
budasterisk at gmail.com
Tue Nov 19 07:03:13 PST 2019
Even with the
https://github.com/tomojitakasu/RTKLIB.git
I used from a couple years back I could never get a FIX solution until I
switched to the rtkexplorer clone with additional fixes incorporated. Will
capture some screenshots this eve and share them with the antennas outside
and not inside next to a window. I can typically get a FIX under a minute.
For fun took a measuring tape as well and measured between antennas on
kitchen pot ground planes and got 1 cm accuracy.
On Tue, Nov 19, 2019 at 9:13 AM drwho <drwho at infidigm.net> wrote:
> On 2019-11-19 8:35 a.m., Bud Asterisk wrote:
> > I will try the CUI code from here:
> > https://github.com/rtklibexplorer/RTKLIB
> > Is this what you are using as well? His binaries on windows work for
> > me to get FIX.
> The rtkrcv I have been using is from
> branch = 2.4.3b33
> http://www.rtklib.com/ points to this git repo.
> I'll try the rtkrcv from rtklibexplorer tonight
> Jon
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit https://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20191119/4f9a3845/attachment.html>
More information about the FOSS-GPS
