[FOSS-GPS] RTKlib help pls
Bud Asterisk
budasterisk at gmail.com
Tue Nov 19 14:13:56 PST 2019
OK gang.....good news!
I used the latest source for rtkrcv from rtklibexplorer's repo and compiled
it on my google cloud instance. Also used my conf file I had working in
rtknavi since it had been tweaked for me. Here is my setup. 2 CSG M8T
boards, each connected to a Raspberry Pi Zero W. They have str2str compiled
and streaming the data to the google VM of rtkrcv. Attached is a
screencapture of 3 terminals, 2 of the PI and one of the rtksrv output
stream of the rover location. Sorry I blacked out the IP and location info
for security reasons. Right now the antennas are in my window facing south
so it is only a float solution that comes and and goes. Not sure it
attachments will make it through the list....
Bud
Oh here is a cut and paste of the output stream. IP and location info has
been fudged
2019/11/19 22:12:40.000 21.134425586 -42.963204887 452.7045 2 4
0.2230 0.1686 0.5208 -0.1212 -0.1373 -0.1447 1.00 0.0
Right after the elevation of 452 you can see the "2" as solution type which
is enumated as float.
On Tue, Nov 19, 2019 at 9:13 AM drwho <drwho at infidigm.net> wrote:
> On 2019-11-19 8:35 a.m., Bud Asterisk wrote:
> > I will try the CUI code from here:
> > https://github.com/rtklibexplorer/RTKLIB
> > Is this what you are using as well? His binaries on windows work for
> > me to get FIX.
> The rtkrcv I have been using is from
> https://github.com/tomojitakasu/RTKLIB.git
> branch = 2.4.3b33
> http://www.rtklib.com/ points to this git repo.
> I'll try the rtkrcv from rtklibexplorer tonight
> Jon
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit https://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20191119/842b3fae/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20191119/842b3fae/attachment-0001.jpg>
More information about the FOSS-GPS
