[FOSS4G-UK] Local Venue Welcome
Dan Ormsby
dormsby at sparkgeo.com
Mon Sep 4 00:54:20 PDT 2023
Hi Nick,
We've a 15 minute "local welcome" on the agenda, between 9:30 and 9:45
presumably to cover whatever needs to be said at the venue (housekeeping,
local sponsor acknowledgements etc) plus your national welcome. How do we
want that to work? Should we cover local welcomes first then switch over
to you so that it is a smoother transition into Helen's talk (who
presumably you would introduce)? Is 15 mins going to be sufficient for
both - how long do you need for your bits?
Dan
On Sun, 3 Sept 2023 at 14:03, Nick Bearman <
nick at geospatialtrainingsolutions.co.uk> wrote:
> Hi All,
> I have put together some slides as a template for the Local Venue Welcome.
> These are for my welcome and wrap up at the end:
> https://docs.google.com/presentation/d/1eaDAKWST4Bf5RJzl06BjjQ-JMIGfOLZoi1EZ_D3IECA/
> Feel free to make a copy and edit as you see fit.
> Things I think should mention in your Local Welcome:
> Who you are (local venue chair) + other volunteers
> Schedule for the day
> Logistics - toilets, fire alarms, catering, etc.
> Code of Conduct slide
> Thank your sponsors - show their logos - give them an opportunity to say
> hello (1 min) if they want.
> I have also created some "Holding slides" to show at the start, in
> breaks etc.
> https://docs.google.com/presentation/d/1S1xDNxce4QJFA_FuzaN4kPI2KMvoCrun6y91W039ywU/edit
> You can run these to scroll through automatically:
> Open a presentation in Google Slides.
> In the top-right corner, click Slideshow .
> At the bottom, click Options. Auto-advance options.
> Choose how quickly to advance your slides.
> Of course you can add to these as well.
> Any questions, etc. do let me know here or at our meeting on Tue.
> Best wishes,
> Nick.
> Nick Bearman
> +44 (0) 7717745715
> Due to my own life/work balance, you may get emails from me outside of
> normal working hours. Please do not feel any pressure to respond outside of
> your own working pattern.
> FOSS4G-UK mailing list
> FOSS4G-UK at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/foss4g-uk
I’m Dan Ormsby, UK Lead at *Sparkgeo*.
We provide geospatial expertise to tech companies.
Reach me at dormsby at sparkgeo.com or on LinkedIn
<https://www.linkedin.com/in/danielormsby/>
+44 7880794939
URL: <http://lists.osgeo.org/pipermail/foss4g-uk/attachments/20230904/56550306/attachment.htm>
More information about the FOSS4G-UK
