[fusion-commits] r1358 - trunk/MapGuide/php
svn_fusion at osgeo.org
Thu Apr 3 10:51:10 EDT 2008
Author: madair
Date: 2008-04-03 10:51:10 -0400 (Thu, 03 Apr 2008)
New Revision: 1358
trunk/MapGuide/php/Buffer.php
closes #45: remove $excludedLayers variable and modify MgCoordinateSystemMeasure for MGOS 2.0
Modified: trunk/MapGuide/php/Buffer.php
--- trunk/MapGuide/php/Buffer.php 2008-04-01 19:16:04 UTC (rev 1357)
+++ trunk/MapGuide/php/Buffer.php 2008-04-03 14:51:10 UTC (rev 1358)
@@ -158,12 +158,10 @@
$layerSrsWkt = $spatialContext->GetCoordinateSystemWkt();
/* skip this layer if the srs is empty */
if($layerSrsWkt == "") {
- $excludedLayers ++;
continue;
} else {
/* skip this layer if there is no spatial context at all */
continue;
@@ -182,7 +180,6 @@
if(($arbitraryDsSrs != $arbitraryMapSrs) || ($arbitraryDsSrs && ($dsSrsUnits != $mapSrsUnits)))
continue;
@@ -191,15 +188,19 @@
$dist = $layerCs->ConvertMetersToCoordinateSystemUnits($distance);
// calculate great circle unless data source srs is arbitrary
+ $verMajor = subStr(GetSiteVersion(), 0,1);
if(!$arbitraryDsSrs) {
- $measure = new MgCoordinateSystemMeasure($layerCs);
+ if ($verMajor == '1') {
+ $measure = new MgCoordinateSystemMeasure($layerCs);
+ } else {
+ $measure = $layerCs->GetMeasure();
} else {
$measure = null;
// create a SRS transformer if necessary.
if($layerSrsWkt != $srsDefMap) {
- $verMajor = subStr(GetSiteVersion(), 0,1);
$srsXform = new MgCoordinateSystemTransform($layerCs, $srsMap);
} else {
More information about the fusion-commits
