[fusion-commits] r1359 - trunk/widgets
svn_fusion at osgeo.org
Thu Apr 3 11:19:26 EDT 2008
Author: madair
Date: 2008-04-03 11:19:26 -0400 (Thu, 03 Apr 2008)
New Revision: 1359
trunk/widgets/CenterSelection.js
closes #46: dereference selection object by map name
Modified: trunk/widgets/CenterSelection.js
--- trunk/widgets/CenterSelection.js 2008-04-03 14:51:10 UTC (rev 1358)
+++ trunk/widgets/CenterSelection.js 2008-04-03 15:19:26 UTC (rev 1359)
@@ -61,12 +61,13 @@
* @param selection the active selection, or null if there is none
centerSelection : function(selection) {
- var extents = this.getMap().getCurrentExtents();
+ var map = this.getMap();
+ var extents = map.getCurrentExtents();
var curWidth = extents[2] - extents[0];
var curHeight = extents[3] - extents[1];
- var ll = selection.getLowerLeftCoord();
- var ur = selection.getUpperRightCoord();
+ var ll = selection[map.getMapName()].getLowerLeftCoord();
+ var ur = selection[map.getMapName()].getUpperRightCoord();
var newWidth = ur.x - ll.x;
var newHeight = ur.y - ll.y;
@@ -74,14 +75,14 @@
if (newWidth < curWidth && newHeight < curHeight) {
var cx = (ur.x + ll.x) / 2;
var cy = (ur.y + ll.y) / 2;
- this.getMap().zoom(cx,cy,1);
+ map.zoom(cx,cy,1);
} else {
var buffer = 0.1;
var minx = ll.x-newWidth*buffer;
var miny = ll.y-newHeight*buffer;
var maxx = ur.x+newWidth*buffer;
var maxy = ur.y+newHeight*buffer;
- this.getMap().setExtents(new OpenLayers.Bounds(minx,miny,maxx,maxy));
+ map.setExtents(new OpenLayers.Bounds(minx,miny,maxx,maxy));
More information about the fusion-commits
