[fusion-commits] r1709 - trunk/layers
svn_fusion at osgeo.org
Wed Dec 10 15:47:03 EST 2008
Author: chrisclaydon
Date: 2008-12-10 15:47:03 -0500 (Wed, 10 Dec 2008)
New Revision: 1709
trunk/layers/Layers.js
Fix #190 - Increase max scale from 100,000,000 to 1,000,000,000,000
Modified: trunk/layers/Layers.js
--- trunk/layers/Layers.js 2008-12-10 20:43:02 UTC (rev 1708)
+++ trunk/layers/Layers.js 2008-12-10 20:47:03 UTC (rev 1709)
@@ -26,14 +26,14 @@
* Class: Fusion.Layers
-* Implements Layers for Fusion.
+* Implements Layers for Fusion.
Fusion.Event.MAP_LAYER_TOGGLED = Fusion.Event.lastEventId++;
Fusion.Event.MAP_LAYER_ORDER_CHANGED = Fusion.Event.lastEventId++;
Fusion.Event.LAYER_LOADED = Fusion.Event.lastEventId++;
Fusion.Event.LAYER_LOADING = Fusion.Event.lastEventId++;
Fusion.Layers = OpenLayers.Class(Fusion.Lib.EventMgr, {
bSingleTile: null,
bIsBaseLayer: false, //TODO: set this in AppDef?
@@ -48,10 +48,10 @@
noCache: false,
_sMapTitle: null,
_sMapname: null,
initialize: function(map, mapTag, isMapWidgetLayer) {
// console.log('Fusion.Layers.initialize');
this.registerEventID(Fusion.Event.MAP_SELECTION_ON);
this.registerEventID(Fusion.Event.MAP_SELECTION_OFF);
this.registerEventID(Fusion.Event.MAP_LOADED);
@@ -64,8 +64,8 @@
if (isMapWidgetLayer != null) {
this.bIsMapWidgetLayer = isMapWidgetLayer;
- this.mapTag = mapTag;
+ this.mapTag = mapTag;
if (!this.mapTag.layerOptions) {
this.mapTag.layerOptions = {};
@@ -75,39 +75,39 @@
this.sMapResourceId = mapTag.resourceId ? mapTag.resourceId : '';
this.mapInfo = mapTag.mapInfo;
this.layerType = mapTag.type;
* Function: loadScaleRanges
* This function should be called after the map has loaded. It
* loads the scsle ranges for each layer. I tis for now only
* used by the legend widget.
loadScaleRanges: function(userFunc) {
userFunc();
getMapName: function() {
return this._sMapname;
getMapTitle: function() {
return this._sMapTitle;
* Function: isMapLoaded
* Returns true if the Map has been laoded succesfully form the server
isMapLoaded: function() {
return this.bMapLoaded;
getMaxExtent: function() {
var maxExtent = null;
if (this.oLayerOL) {
@@ -116,10 +116,10 @@
return maxExtent;
- hasSelection: function() {
- return this.bSelectionOn;
+ hasSelection: function() {
+ return this.bSelectionOn;
* Returns the number of features selected for this map layer
@@ -159,14 +159,14 @@
* @param layers {string} Optional parameter. A comma separated
* list of layer names (Roads,Parcels). If it is not
- * given, all the layers that have a selection will be used
+ * given, all the layers that have a selection will be used
* @param startcount {string} Optional parameter. A comma separated
* list of a statinh index and the number of features to be retured for
* each layer given in the layers parameter. Index starts at 0
* (eg: 0:4,2:6 : return 4 elements for the first layers starting at index 0 and
* six elements for layer 2 starting at index 6). If it is not
- * given, all the elemsnts will be returned.
+ * given, all the elemsnts will be returned.
getSelection: function(userFunc, layers, startcount) {
@@ -182,7 +182,7 @@
query: function(options) {
processLayerEvents: function(layer, isEnabling) {
if (this.mapInfo && this.mapInfo.mapEvents.layerEvents[layer.layerName]) {
var layerEvent = this.mapInfo.mapEvents.layerEvents[layer.layerName];
@@ -198,7 +198,7 @@
l.hide(true);
} else if (o.type == 'group') {
var g = this.layerRoot.findGroupByAttribute('groupName', o.name);
if (g) {
@@ -212,7 +212,7 @@
processGroupEvents: function(group, isEnabling) {
if (this.mapInfo && this.mapInfo.mapEvents.groupEvents[group.groupName]) {
var groupEvent = this.mapInfo.mapEvents.groupEvents[group.groupName];
@@ -228,7 +228,7 @@
l.hide(true);
if (g) {
@@ -242,11 +242,11 @@
refreshLayer: function( layer ) {
this.drawMap();
setParameter: function(param, value) {
if (param == 'SelectionType') {
this.selectionType = value;
@@ -264,7 +264,7 @@
this.mapWidget._removeWorker();
getGroupInfoUrl: function(groupName) {
if (this.mapInfo) {
var groups = this.mapInfo.links.groups;
@@ -288,7 +288,7 @@
return null;
* Class: Fusion.Layers.Group
@@ -317,7 +317,7 @@
this.actuallyVisible = o.actuallyVisible;
this.registerEventID(Fusion.Event.GROUP_PROPERTY_CHANGED);
show: function(noDraw) {
if (this.visible) {
return;
@@ -328,7 +328,7 @@
this.legend.checkBox.checked = true;
hide: function(noDraw) {
if (!this.visible) {
return;
@@ -339,11 +339,11 @@
this.legend.checkBox.checked = false;
isVisible: function() {
return this.visible;
clear: function() {
for (var i=0; i<this.groups.length; i++) {
this.groups[i].clear();
@@ -354,12 +354,12 @@
this.groups = [];
this.layers = [];
set: function(property, value) {
this[property] = value;
this.triggerEvent(Fusion.Event.GROUP_PROPERTY_CHANGED, this);
addGroup: function(group,reverse) {
group.parentGroup = this;
if (reverse) {
@@ -368,7 +368,7 @@
this.groups.push(group);
addLayer: function(layer,reverse) {
layer.parentGroup = this;
if (reverse) {
@@ -377,11 +377,11 @@
this.layers.push(layer);
findGroup: function(name) {
return this.findGroupByAttribute('name', name);
findGroupByAttribute: function(attribute, value) {
if (this[attribute] == value) {
return this;
@@ -394,11 +394,11 @@
return null;
findLayer: function(name) {
return this.findLayerByAttribute('name', name);
findLayerByAttribute: function(attribute, value) {
for (var i=0; i<this.layers.length; i++) {
if (this.layers[i][attribute] == value) {
@@ -413,7 +413,7 @@
return null;
@@ -424,11 +424,11 @@
Fusion.Event.LAYER_PROPERTY_CHANGED = Fusion.Event.lastEventId++;
Fusion.Layers.Layer = OpenLayers.Class(Fusion.Lib.EventMgr, {
scaleRanges: null,
oMap: null,
initialize: function(o, oMap) {
this.oMap = oMap;
this.layerName = o.layerName;
@@ -444,8 +444,8 @@
this.editable = o.editable;
this.visible = o.visible;
this.selectable = o.selectable;
//determine the layer type so that the correct icon can be displayed in the legend
this.layerType = null;
if (this.supportsType(Fusion.Constant.LAYER_RASTER_TYPE)) { //raster layers
@@ -453,26 +453,26 @@
} else if (this.supportsType(Fusion.Constant.LAYER_DWF_TYPE)) { //DWF layers
this.layerType = Fusion.Constant.LAYER_DWF_TYPE;
this.parentGroup = o.parentGroup;
this.minScale = o.minScale;
this.maxScale = o.maxScale;
if (this.maxScale == 'infinity') {
- this.maxScale = 100000000;
+ this.maxScale = 1000000000000;
this.scaleRanges = [];
if (o.scaleRanges)
for (var i=0; i<o.scaleRanges.length; i++) {
- var scaleRange = new Fusion.Layers.ScaleRange(o.scaleRanges[i],
+ var scaleRange = new Fusion.Layers.ScaleRange(o.scaleRanges[i],
this.layerType);
this.scaleRanges.push(scaleRange);
this.registerEventID(Fusion.Event.LAYER_PROPERTY_CHANGED);
supportsType: function(type) {
for (var i=0; i<this.layerTypes.length; i++) {
if (this.layerTypes[i] == type) {
@@ -481,7 +481,7 @@
return false;
getScaleRange: function(fScale) {
for (var i=0; i<this.scaleRanges.length; i++) {
if (this.scaleRanges[i].contains(fScale)) {
@@ -516,14 +516,14 @@
clear: function() {},
this.triggerEvent(Fusion.Event.LAYER_PROPERTY_CHANGED, this);
More information about the fusion-commits
