[fusion-commits] r1710 - trunk/widgets/widgetinfo
svn_fusion at osgeo.org
Wed Dec 10 16:14:23 EST 2008
Author: chrisclaydon
Date: 2008-12-10 16:14:23 -0500 (Wed, 10 Dec 2008)
New Revision: 1710
trunk/widgets/widgetinfo/legend.xml
Fix #187 - Adjust the default setting in the legend widget info for HideInvisibleLayers from 'false' to 'true'
Modified: trunk/widgets/widgetinfo/legend.xml
--- trunk/widgets/widgetinfo/legend.xml 2008-12-10 20:47:03 UTC (rev 1709)
+++ trunk/widgets/widgetinfo/legend.xml 2008-12-10 21:14:23 UTC (rev 1710)
@@ -15,7 +15,7 @@
<Description>Suppress invisible layers from the legend</Description>
<Type>boolean</Type>
<Label>Hide Invisible Layers</Label>
- <DefaultValue>false</DefaultValue>
+ <DefaultValue>true</DefaultValue>
<IsMandatory>false</IsMandatory>
</Parameter>
<Parameter>
More information about the fusion-commits
