[fusion-commits] r1711 - in trunk: lib widgets
svn_fusion at osgeo.org
Thu Dec 11 16:30:25 EST 2008
Author: pagameba
Date: 2008-12-11 16:30:24 -0500 (Thu, 11 Dec 2008)
New Revision: 1711
trunk/lib/jxlib.uncompressed.js
trunk/widgets/Legend.js
fixes #189. create two different context menus based on whether the item is a folder or not.
Modified: trunk/lib/jxlib.uncompressed.js
--- trunk/lib/jxlib.uncompressed.js 2008-12-10 21:14:23 UTC (rev 1710)
+++ trunk/lib/jxlib.uncompressed.js 2008-12-11 21:30:24 UTC (rev 1711)
@@ -10118,6 +10118,7 @@
this.contentContainer.setStyle('visibility','hidden');
+ this.contentContainer.setStyle('display','block');
$(document.body).adopt(this.contentContainer);
/* we have to size the container for IE to render the chrome correctly
* but just in the menu/sub menu case - there is some horrible peekaboo
Modified: trunk/widgets/Legend.js
--- trunk/widgets/Legend.js 2008-12-10 21:14:23 UTC (rev 1710)
+++ trunk/widgets/Legend.js 2008-12-11 21:30:24 UTC (rev 1711)
@@ -264,28 +264,45 @@
getContextMenu: function(folder) {
- return new Jx.Menu.Context(this.name).add(
- new Jx.Menu.Item({
- label: OpenLayers.i18n('collapse'),
- onClick: OpenLayers.Function.bind(this.collapseBranch, this, folder)
- label: OpenLayers.i18n('expand'),
- onClick: OpenLayers.Function.bind(this.expandBranch, this, folder)
- label: OpenLayers.i18n('refresh'),
- onClick: OpenLayers.Function.bind(this.update, this, folder)
- label: OpenLayers.i18n('collapseAll'),
- onClick: OpenLayers.Function.bind(this.collapseAll, this, folder)
- label: OpenLayers.i18n('expandAll'),
- onClick: OpenLayers.Function.bind(this.expandAll, this, folder)
+ if (folder instanceof Jx.TreeFolder) {
+ return new Jx.Menu.Context(this.name).add(
+ new Jx.Menu.Item({
+ label: OpenLayers.i18n('collapse'),
+ onClick: OpenLayers.Function.bind(this.collapseBranch, this, folder)
+ label: OpenLayers.i18n('expand'),
+ onClick: OpenLayers.Function.bind(this.expandBranch, this, folder)
+ label: OpenLayers.i18n('refresh'),
+ onClick: OpenLayers.Function.bind(this.update, this, folder)
+ label: OpenLayers.i18n('collapseAll'),
+ onClick: OpenLayers.Function.bind(this.collapseAll, this, folder)
+ label: OpenLayers.i18n('expandAll'),
+ onClick: OpenLayers.Function.bind(this.expandAll, this, folder)
+ } else {
expandAll: function(folder) {
this.recurseTree('expand', this.oRoot);
@@ -626,7 +643,7 @@
var item = new Jx.TreeItem(opt);
- item.contextMenu = this.getContextMenu(layer.parentGroup.legend.treeItem);
+ item.contextMenu = this.getContextMenu(item); //layer.parentGroup.legend.treeItem);
if (bCheckBox) {
//item.domObj.insertBefore(layer.legend.checkBox, item.domObj.childNodes[1]);
/* only need to add layer info if it has a check box too */
More information about the fusion-commits
