[fusion-commits] r1418 - in sandbox/aboudreault: MapServer/php
widgets
svn_fusion at osgeo.org
Tue Jun 10 14:13:13 EDT 2008
Author: aboudreault
Date: 2008-06-10 14:13:13 -0400 (Tue, 10 Jun 2008)
New Revision: 1418
sandbox/aboudreault/MapServer/php/Search.php
sandbox/aboudreault/widgets/SelectionPanel.js
SelectionPanel with some changes...
Modified: sandbox/aboudreault/MapServer/php/Search.php
--- sandbox/aboudreault/MapServer/php/Search.php 2008-06-04 14:02:38 UTC (rev 1417)
+++ sandbox/aboudreault/MapServer/php/Search.php 2008-06-10 18:13:13 UTC (rev 1418)
@@ -112,57 +112,49 @@
$oResultSet = $oLayer->getResult(0);
$oShape = $oLayer->getShape($oResultSet->tileindex,$oResultSet->shapeindex);
$selFields = array();
- if (isset($_SESSION[$mapName][$layerName]['query_items']))
- $aQueryItems = $_SESSION[$mapName][$layerName]['query_items'];
- else
- //token separator (for parsing displayed attributes on a query)
- $tokenSeparator = ",";
- // checking if metadata "query_include_items" is set
- $metadataItems = $oLayer->getMetaData('query_include_items');
- if ( ($metadataItems == "") || ($metadataItems == "all") )
- while ( list($key,$val) = each($oShape->values) )
- $aQueryItems[$key] = NULL;
+ if (isset($_SESSION[$mapName][$layerName]['query_items'])) {
+ $aQueryItems = $_SESSION[$mapName][$layerName]['query_items'];
+ } else {
+ //token separator (for parsing displayed attributes on a query)
+ $tokenSeparator = ",";
+ // checking if metadata "query_include_items" is set
+ $metadataItems = $oLayer->getMetaData('query_include_items');
+ if ( ($metadataItems == "") || ($metadataItems == "all") ) {
+ while ( list($key,$val) = each($oShape->values) ) {
+ $aQueryItems[$key] = NULL;
+ } else {
+ $token = strtok($metadataItems, $tokenSeparator);
+ while ($token !== false) {
+ $aQueryItems[trim($token)] = NULL;
+ $token = strtok($tokenSeparator);
- else
- $token = strtok($metadataItems, $tokenSeparator);
- while ($token !== false)
- $aQueryItems[$token] = NULL;
- $token = strtok($tokenSeparator);
+ // checking if metadata "query_exclude_items" is set
+ $metadataItems = $oLayer->getMetaData('query_exclude_items');
+ if ($metadataItems != "") {
+ if (array_key_exists($token, $aQueryItems)) {
+ unset($aQueryItems[$token]);
- // checking if metadata "query_exclude_items" is set
- $metadataItems = $oLayer->getMetaData('query_exclude_items');
- if ($metadataItems != "")
- if (array_key_exists($token, $aQueryItems))
- unset($aQueryItems[$token]);
+ // get all alias
+ while ( list($key,$val) = each($aQueryItems) ) {
+ $keyAlias = $oLayer->getMetaData("query_".$key."_alias");
+ trim($keyAlias);
+ if ($keyAlias != "") {
+ $aQueryItems[$key] = $keyAlias;
- // get all alias
- while ( list($key,$val) = each($aQueryItems) )
- $keyAlias = $oLayer->getMetaData("query_".$key."_alias");
- trim($keyAlias);
- if ($keyAlias != "")
- $aQueryItems[$key] = $keyAlias;
- $_SESSION[$mapName][$layerName]['query_items'] = $aQueryItems;
+ $_SESSION[$mapName][$layerName]['query_items'] = $aQueryItems;
Modified: sandbox/aboudreault/widgets/SelectionPanel.js
--- sandbox/aboudreault/widgets/SelectionPanel.js 2008-06-04 14:02:38 UTC (rev 1417)
+++ sandbox/aboudreault/widgets/SelectionPanel.js 2008-06-10 18:13:13 UTC (rev 1418)
@@ -33,47 +33,57 @@
Fusion.Widget.SelectionPanel = OpenLayers.Class(Fusion.Widget,
+ * Property: previousIcon
+ * {String} The default image for Previous page button.
+ previousIcon: 'images/icon_back.gif',
+ * Property: nextIcon
+ nextIcon: 'images/icon_forward.gif',
initialize : function(widgetTag) {
//console.log('SelectionPanel.initialize');
Fusion.Widget.prototype.initialize.apply(this, [widgetTag, false]);
- this.defPrevTaskIcon = 'images/icon_back.gif';
- this.defNextTaskIcon = 'images/icon_forward.gif';
var json = widgetTag.extension;
+ if (json.PreviousImageUrl) this.previousIcon = json.PreviousImageUrl;
+ if (json.NextImageUrl) this.nextIcon = json.NextImageUrl;
this.iResultsPerPage = json.ResultsPerPage ? json.ResultsPerPage[0] : 0;
this.iResultsPerPage = parseInt(this.iResultsPerPage);
- if (isNaN(this.iResultsPerPage))
+ if (isNaN(this.iResultsPerPage) || (this.iResultsPerPage < 0))
this.iResultsPerPage = 0;
if (json.SelectionRenderer)
- { // todo: use OpenLayers.Util.Try ?
- try {
- var renderer = eval(json.SelectionRenderer[0]);
- if (renderer.prototype.CLASS_NAME && renderer.prototype.CLASS_NAME == "Fusion.Widget.SelectionPanel.SelectionRenderer") {
- this.renderer = new renderer(this);
- } else if (typeof renderer == "function") {
- var renderFunction = renderer;
- this.renderer = new Fusion.Widget.SelectionPanel.SelectionRenderer(this);
- this.renderer.updateSelection = function() {
- this.getMap().getSelection(
- OpenLayers.Function.bind(renderFunction));
- this.renderer.clearSelection = false;
+ var renderer = eval(json.SelectionRenderer[0]);
+ if (renderer && renderer.prototype.CLASS_NAME && renderer.prototype.CLASS_NAME == "Fusion.Widget.SelectionPanel.SelectionRenderer") {
+ this.renderer = new renderer(this);
+ } else if (typeof renderer == "function") {
+ var renderFunction = renderer;
+ this.renderer = new Fusion.Widget.SelectionPanel.SelectionRenderer(this);
+ this.renderer.updateSelection = function() {
+ this.getMap().getSelection(
+ OpenLayers.Function.bind(renderFunction));
+ this.renderer.clearSelection = false;
+ } else {
+ this.renderer = new Fusion.Widget.SelectionPanel.SelectionRendererDefault(this);
- catch (e) {}// this will occur if the renderer name provided is undefined.
} else {
this.iResultsPerPage = null; // handled by the renderer
if (this.renderer.updateSelection) {
this.getMap().registerForEvent(Fusion.Event.MAP_SELECTION_ON,
OpenLayers.Function.bind(this.renderer.updateSelection, this.renderer));
if (this.renderer.clearSelection) {
this.getMap().registerForEvent(Fusion.Event.MAP_SELECTION_OFF,
OpenLayers.Function.bind(this.renderer.clearSelection, this.renderer));
@@ -83,7 +93,7 @@
/* Class: Fusion.Widget.SelectionPanel.SelectionRenderer
* This is a class designed to help users to create their own renderer
- * for customize display results.
+ * for customize display results.
Fusion.Widget.SelectionPanel.SelectionRenderer = OpenLayers.Class(
@@ -95,11 +105,11 @@
oSelection: null,
- * Property: iCurrentIndex
- * {int} The index of the current position for pagination
+ * Property: aiCurrentIndex
+ * {Array(int)} The index of the current position for pagination.
- iCurrentIndex: 0,
+ aiCurrentIndex: null,
* Property: iResultsPerPage
@@ -117,11 +127,25 @@
initialize: function(selectionPanel) {
this.oSelectionPanel = selectionPanel;
this.iResultsPerPage = selectionPanel.iResultsPerPage;
+ this.aiCurrentIndex = new Array();
+ * Method: updateSelectionObject
+ * Helper method to update the aiCurrentIndex array for pagination.
+ updatePageIndexes: function() {
+ var nLayers = this.oSelection.getNumLayers();
+ for (var i=0; i<nLayers; i++) {
+ this.aiCurrentIndex[this.oSelection.getLayer(i).getName()] = 0;
* Method: getNextPage
* Get the next batches of features. Wrapper of the getPage() method.
+ * This method calcul the startIndex/endIndex of the next batch.
* Parameters:
* selectionLayer - {<Fusion.SelectionObject.Layer>} The layer that contains
@@ -131,27 +155,38 @@
* {Array(Array)} An array of all features with their properties.
getNextPage: function(selectionLayer) {
- if (selectionLayer && this.iCurrentIndex != selectionLayer.getNumElements()) {
- var startIndex = 0;
- var endIndex = selectionLayer.getNumElements();
- if (this.iResultsPerPage != 0) {
- var iTotalElement = endIndex;
- startIndex = this.iCurrentIndex;
- endIndex = startIndex + this.iResultsPerPage;
- if (endIndex >= iTotalElement) {
- endIndex = iTotalElement;
- this.iCurrentIndex = endIndex;
+ if (selectionLayer && (this.iResultsPerPage != 0)) {
+ var layerName = selectionLayer.getName();
+ if (this.aiCurrentIndex[layerName] >= selectionLayer.getNumElements()) {
+ this.aiCurrentIndex[layerName] = this.aiCurrentIndex[layerName] - this.iResultsPerPage;
+ var iTotalElement = selectionLayer.getNumElements();
+ var startIndex = this.aiCurrentIndex[layerName];
+ var endIndex = startIndex + this.iResultsPerPage;
+ if (endIndex >= iTotalElement) {
+ endIndex = iTotalElement;
+ if (startIndex < 0) {
+ startIndex = 0;
+ this.aiCurrentIndex[layerName] = endIndex;
+ // if the last page doesn't contains "iResultsPerPage" elements. Fix the current index for the next getPreviousPage() call.
+ var diff = (endIndex - startIndex);
+ if ( diff != this.iResultsPerPage) {
+ this.aiCurrentIndex[layerName] = this.aiCurrentIndex[layerName] + (this.iResultsPerPage - diff);
return this.getPage(selectionLayer, startIndex, endIndex);
- return false;
+ return this.getPage(selectionLayer, false, false);
* Method: getPreviousPage
* Get the previous batches of features. Wrapper of the getPage() method.
+ * This method calcul the startIndex/endIndex of the previous batch.
* Parameters:
@@ -161,24 +196,21 @@
getPreviousPage: function(selectionLayer) {
- var page = false;
- if (selectionLayer && this.iCurrentIndex != 0) {
- var page = new Array();
- startIndex = this.iCurrentIndex - (this.iResultsPerPage * 2);
- endIndex = this.iCurrentIndex - this.iResultsPerPage;
- if (startIndex < 0) {
- startIndex = 0;
+ if (selectionLayer && (this.aiCurrentIndex[layerName] != 0) && (this.iResultsPerPage != 0)) {
+ var startIndex = this.aiCurrentIndex[layerName] - (this.iResultsPerPage * 2);
+ var endIndex = this.aiCurrentIndex[layerName] - this.iResultsPerPage;
+ startIndex = 0;
+ endIndex = (iTotalElement < this.iResultsPerPage) ? iTotalElement : this.iResultsPerPage;
- return page;
@@ -208,12 +240,14 @@
getPage: function(selectionLayer, startIndex, endIndex) {
var page = false;
if (selectionLayer) {
+ page = new Array();
+ startIndex = startIndex ? startIndex : 0;
+ endIndex = endIndex ? endIndex : selectionLayer.getNumElements();
var propNames = selectionLayer.getPropertyNames();
- var index = 0;
+ var index =0;
for (var i=startIndex; i<endIndex; i++, index++) {
+ page[index] = new Array();
for (var j=0; j<propNames.length; j++) {
- page[index] = new Array();
page[index][j] = selectionLayer.getElementValue(i, j);
@@ -270,7 +304,7 @@
d.appendChild(this.toolbar);
d.appendChild(this.featureDiv);
Fusion.addWidgetStyleSheet(this.oSelectionPanel.getLocation() + 'SelectionPanel/SelectionPanel.css');
this.oSelectionPanel.domObj.appendChild(d);
@@ -295,10 +329,11 @@
this.oSelection = oSelection[mapName];
break;
if (!this.oSelection) {
return;
//clear the layer list select box of any previous selections
Element.removeClassName(this.featureDiv, 'noSelection');
while (this.layerList.length>0) {
@@ -325,11 +360,13 @@
renderSelectionFeatures: function() {
var layerIdx = this.layerList.selectedIndex;
+ var layerObj = this.oSelection.getLayer(layerIdx);
//clear the feature list select box of any previous selections
while (this.featureList.length>0) {
this.featureList.remove(this.featureList.options[0]);
- var layerObj = this.oSelection.getLayer(layerIdx);
var nElements = layerObj.getNumElements();
for (var i=0; i<nElements; i++) {
var opt = new Option(i+1, i);
@@ -377,4 +414,139 @@
this.featureDiv.innerHTML = '';
this.featureDiv.appendChild(table);
\ No newline at end of file
+/* Class: Fusion.Widget.SelectionPanel.SelectionRendererHorizontal
+ * This class provide a alternate behavior for the selection panel.
+ * Generate a table which have one feature per row.
+Fusion.Widget.SelectionPanel.SelectionRendererHorizontal = OpenLayers.Class(Fusion.Widget.SelectionPanel.SelectionRenderer,
+ initialize : function(selectionPanel) {
+ Fusion.Widget.SelectionPanel.SelectionRenderer.prototype.initialize.apply(this, [selectionPanel]);
+ var d = document.createElement('div');
+ this.featureDiv = document.createElement('div');
+ this.featureDiv.innerHTML = 'No Selection';
+ Element.addClassName(this.featureDiv, 'noSelection');
+ d.appendChild(this.featureDiv);
+ if (this.iResultsPerPage != 0) {
+ this.previousButton = document.createElement('img');
+ this.previousButton.src = this.oSelectionPanel.previousIcon;
+ this.previousButton.style.position = "absolute";
+ this.previousButton.style.left = "0px";
+ this.previousButton.style.padding = "3px";
+ Event.observe(this.previousButton, 'click',
+ OpenLayers.Function.bind(this.renderLayers, this, 'prev'));
+ this.nextButton = document.createElement('img');
+ this.nextButton.src = this.oSelectionPanel.nextIcon;
+ this.nextButton.style.position = "absolute";
+ this.nextButton.style.right = "0px";
+ this.nextButton.style.padding = "3px";
+ Event.observe(this.nextButton, 'click',
+ OpenLayers.Function.bind(this.renderLayers, this, 'next'));
+ d.appendChild(this.previousButton);
+ d.appendChild(this.nextButton);
+ Element.addClassName(this.featureDiv, 'selectionPanelContent');
+ Fusion.addWidgetStyleSheet(this.oSelectionPanel.getLocation() + 'SelectionPanel/SelectionPanel.css');
+ this.oSelectionPanel.domObj.appendChild(d);
+ updateSelection: function() {
+ OpenLayers.Function.bind(this.renderSelection, this));
+ clearSelection: function() {
+ this.oSelection = null;
+ this.featureDiv.innerHTML = OpenLayers.i18n('noSelection');
+ renderSelection: function(oSelection) {
+ //TODO: this just gets the first map, we need them all
+ for (var mapName in oSelection) {
+ this.oSelection = oSelection[mapName];
+ break;
+ this.updatePageIndexes();
+ this.renderLayers("next");
+ renderLayers: function(renderingPage) {
+ if (!this.oSelection) {
+ return;
+ Element.removeClassName(this.featureDiv, 'noSelection');
+ this.featureDiv.innerHTML = '';
+ var table = document.createElement('table');
+ table.style.borderLeft = "1px solid #CCCCCC";
+ table.style.marginBottom = "10px";
+ var layerObj = this.oSelection.getLayer(i);
+ var aNames = layerObj.getPropertyNames();
+ //find the legend label from the Map layer objects
+ var mapLayers = this.getMap().aMaps[0].aLayers; //TODO: allow multiple maps
+ var labelName = layerObj.getName();
+ for (var j=0; j<mapLayers.length; ++j) {
+ if (mapLayers[j].layerName == labelName) {
+ labelName = mapLayers[j].legendLabel;
+ break;
+ var thead = document.createElement('thead');
+ var tr = document.createElement('tr');
+ var th = document.createElement('th');
+ th.innerHTML = labelName;
+ th.colSpan=aNames.length;
+ th.style.textAlign = "center";
+ tr.appendChild(th);
+ thead.appendChild(tr);
+ tr = document.createElement('tr');
+ for (var j=0; j<aNames.length; j++) {
+ th = document.createElement('th');
+ th.innerHTML = aNames[j];
+ table.appendChild(thead);
+ var tbody = document.createElement('tbody');
+ var page = (renderingPage == 'next') ? this.getNextPage(layerObj): this.getPreviousPage(layerObj);
+ this.renderFeatures(page,tbody);
+ table.appendChild(tbody);
+ this.featureDiv.appendChild(table);
+ renderFeatures: function(page, dom) {
+ if (!page)
+ return;
+ for (var i=0; i<page.length; i++) {
+ if (i%2) {
+ Element.addClassName(tr, 'oddRow');
+ for (var j=0; j<page[i].length; j++) {
+ var td = document.createElement('td');
+ td.innerHTML = page[i][j];
+ tr.appendChild(td);
+ dom.appendChild(tr);
More information about the fusion-commits
