[fusion-commits] r1419 - in trunk: lib widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon Jun 23 12:07:35 EDT 2008
Author: madair
Date: 2008-06-23 12:07:34 -0400 (Mon, 23 Jun 2008)
New Revision: 1419
   trunk/lib/Map.js
   trunk/widgets/ViewOptions.js
re #73: view options patch applied to trunk
Modified: trunk/lib/Map.js
--- trunk/lib/Map.js	2008-06-10 18:13:13 UTC (rev 1418)
+++ trunk/lib/Map.js	2008-06-23 16:07:34 UTC (rev 1419)
@@ -152,6 +152,8 @@
         this.registerEventID(Fusion.Event.MAP_SELECTION_ON);
         this.registerEventID(Fusion.Event.MAP_SELECTION_OFF);
+        this.registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.mapLoaded,this));
         //register for OL map extent change events
         this.oMapOL.events.register('moveend', this, this.mapExtentsChanged);
@@ -163,6 +165,10 @@
         this.bFetchingSelection = false;
+    mapLoaded: function() {
+      this.setViewOptions(this.getUnits());
     setMenu: function() {
         if (this.widgetTag.extension.MenuContainer) {
             var contextMenu = new Jx.ContextMenu();
@@ -684,6 +690,25 @@
         return this._fMetersperunit;
+     * initializes all widgets with the map units after the map has loaded
+    setViewOptions: function(data) {
+      for (var i=0; i<Fusion.applicationDefinition.widgetSets.length; ++i) {
+        var widgetSet = Fusion.applicationDefinition.widgetSets[i];
+        for (var j=0; j<widgetSet.widgetInstances.length; ++j) {
+          var widget = widgetSet.widgetInstances[j];
+          for (var k=0; k<widget.paramRegister.length; ++k) {
+            if (widget.paramRegister[k] == 'Units') {
+              widget.setParameter('Units', data);
      * convert geographic into pixels.
Modified: trunk/widgets/ViewOptions.js
--- trunk/widgets/ViewOptions.js	2008-06-10 18:13:13 UTC (rev 1418)
+++ trunk/widgets/ViewOptions.js	2008-06-23 16:07:34 UTC (rev 1419)
@@ -67,20 +67,6 @@
     setMapUnits: function() {
       var units = this.displayUnits ? this.displayUnits : this.getMap().getUnits();
-      this.setViewOptions(units);
-    setViewOptions: function(data) {
-      for (var i=0; i<Fusion.applicationDefinition.widgetSets.length; ++i) {
-        var widgetSet = Fusion.applicationDefinition.widgetSets[i];
-        for (var j=0; j<widgetSet.widgetInstances.length; ++j) {
-          var widget = widgetSet.widgetInstances[j];
-          for (var k=0; k<widget.paramRegister.length; ++k) {
-            if (widget.paramRegister[k] == 'Units') {
-              widget.setParameter('Units', data);
+      this.getMap().setViewOptions(units);
More information about the fusion-commits mailing list
