[fusion-commits] r1224 - in trunk: . jx jx/images jx/lib
svn_fusion at osgeo.org
Mon Mar 10 09:29:18 EDT 2008
Author: pagameba
Date: 2008-03-10 09:29:17 -0400 (Mon, 10 Mar 2008)
New Revision: 1224
Added:
trunk/jx/
trunk/jx/JX_VERSION.txt
trunk/jx/images/
trunk/jx/images/a_pixel.png
trunk/jx/images/button_bg.png
trunk/jx/images/button_bg_arrow_d2.png
trunk/jx/images/button_bg_arrow_r2.png
trunk/jx/images/close.png
trunk/jx/images/container_bg.png
trunk/jx/images/dialog_bg.png
trunk/jx/images/dialog_glow_b.png
trunk/jx/images/dialog_glow_bl.png
trunk/jx/images/dialog_glow_br.png
trunk/jx/images/dialog_glow_l.png
trunk/jx/images/dialog_glow_r.png
trunk/jx/images/dialog_glow_t.png
trunk/jx/images/dialog_glow_tl.png
trunk/jx/images/dialog_glow_tr.png
trunk/jx/images/dialog_resize.png
trunk/jx/images/disclose.png
trunk/jx/images/disclose2.png
trunk/jx/images/disclose3.png
trunk/jx/images/grid.png
trunk/jx/images/help.png
trunk/jx/images/help_close.png
trunk/jx/images/icon_close.png
trunk/jx/images/icon_quickhelp.png
trunk/jx/images/maximize.png
trunk/jx/images/menu_item_arrow_d.png
trunk/jx/images/menu_item_arrow_d2.png
trunk/jx/images/menu_item_arrow_r.png
trunk/jx/images/menu_item_arrow_r2.png
trunk/jx/images/menu_item_check.png
trunk/jx/images/menu_item_radio.png
trunk/jx/images/minimize.png
trunk/jx/images/page_grid.png
trunk/jx/images/panel_grey_bg.png
trunk/jx/images/panel_white_bg.png
trunk/jx/images/separator.png
trunk/jx/images/snap_bg.png
trunk/jx/images/tab_bottom_bg.png
trunk/jx/images/tab_left_bg.png
trunk/jx/images/tab_right_bg.png
trunk/jx/images/tab_top_bg.png
trunk/jx/images/test-text.png
trunk/jx/images/toolbar_separator_h.png
trunk/jx/images/toolbar_separator_v.png
trunk/jx/images/tree_folder.png
trunk/jx/images/tree_folder_open.png
trunk/jx/images/tree_last_node.png
trunk/jx/images/tree_minus.png
trunk/jx/images/tree_node.png
trunk/jx/images/tree_none.png
trunk/jx/images/tree_page.png
trunk/jx/images/tree_plus.png
trunk/jx/images/tree_vert_line.png
trunk/jx/lib/
trunk/jx/lib/jx_combined.css
trunk/jx/lib/jx_combined.js
trunk/jx/lib/jx_compressed.js
add static jx to trunk
Added: trunk/jx/JX_VERSION.txt
--- trunk/jx/JX_VERSION.txt (rev 0)
+++ trunk/jx/JX_VERSION.txt 2008-03-10 13:29:17 UTC (rev 1224)
@@ -0,0 +1,5 @@
+Jx is an open source library available from http://jxlib.org/. A copy of a specific version of Jx is included with Fusion. The current version is:
+Jx 1.0.3
+You may replace jx with any version including an svn version. However, Fusion may not work with newer versions. Also, Fusion requires the combined or compressed version of Jx. See Jx documentation for information on building the combined and compressed versions.
\ No newline at end of file
Added: trunk/jx/images/a_pixel.png
(Binary files differ)
Property changes on: trunk/jx/images/a_pixel.png
___________________________________________________________________
+ application/octet-stream
Added: trunk/jx/images/button_bg.png
Property changes on: trunk/jx/images/button_bg.png
Added: trunk/jx/images/button_bg_arrow_d2.png
Property changes on: trunk/jx/images/button_bg_arrow_d2.png
Added: trunk/jx/images/button_bg_arrow_r2.png
Property changes on: trunk/jx/images/button_bg_arrow_r2.png
Added: trunk/jx/images/close.png
Property changes on: trunk/jx/images/close.png
Added: trunk/jx/images/container_bg.png
Property changes on: trunk/jx/images/container_bg.png
Added: trunk/jx/images/dialog_bg.png
Property changes on: trunk/jx/images/dialog_bg.png
Added: trunk/jx/images/dialog_glow_b.png
Property changes on: trunk/jx/images/dialog_glow_b.png
Added: trunk/jx/images/dialog_glow_bl.png
Property changes on: trunk/jx/images/dialog_glow_bl.png
Added: trunk/jx/images/dialog_glow_br.png
Property changes on: trunk/jx/images/dialog_glow_br.png
Added: trunk/jx/images/dialog_glow_l.png
Property changes on: trunk/jx/images/dialog_glow_l.png
Added: trunk/jx/images/dialog_glow_r.png
Property changes on: trunk/jx/images/dialog_glow_r.png
Added: trunk/jx/images/dialog_glow_t.png
Property changes on: trunk/jx/images/dialog_glow_t.png
Added: trunk/jx/images/dialog_glow_tl.png
Property changes on: trunk/jx/images/dialog_glow_tl.png
Added: trunk/jx/images/dialog_glow_tr.png
Property changes on: trunk/jx/images/dialog_glow_tr.png
Added: trunk/jx/images/dialog_resize.png
Property changes on: trunk/jx/images/dialog_resize.png
Added: trunk/jx/images/disclose.png
Property changes on: trunk/jx/images/disclose.png
Added: trunk/jx/images/disclose2.png
Property changes on: trunk/jx/images/disclose2.png
Added: trunk/jx/images/disclose3.png
Property changes on: trunk/jx/images/disclose3.png
Added: trunk/jx/images/grid.png
Property changes on: trunk/jx/images/grid.png
Added: trunk/jx/images/help.png
Property changes on: trunk/jx/images/help.png
Added: trunk/jx/images/help_close.png
Property changes on: trunk/jx/images/help_close.png
Added: trunk/jx/images/icon_close.png
Property changes on: trunk/jx/images/icon_close.png
Added: trunk/jx/images/icon_quickhelp.png
Property changes on: trunk/jx/images/icon_quickhelp.png
Added: trunk/jx/images/maximize.png
Property changes on: trunk/jx/images/maximize.png
Added: trunk/jx/images/menu_item_arrow_d.png
Property changes on: trunk/jx/images/menu_item_arrow_d.png
Added: trunk/jx/images/menu_item_arrow_d2.png
Property changes on: trunk/jx/images/menu_item_arrow_d2.png
Added: trunk/jx/images/menu_item_arrow_r.png
Property changes on: trunk/jx/images/menu_item_arrow_r.png
Added: trunk/jx/images/menu_item_arrow_r2.png
Property changes on: trunk/jx/images/menu_item_arrow_r2.png
Added: trunk/jx/images/menu_item_check.png
Property changes on: trunk/jx/images/menu_item_check.png
Added: trunk/jx/images/menu_item_radio.png
Property changes on: trunk/jx/images/menu_item_radio.png
Added: trunk/jx/images/minimize.png
Property changes on: trunk/jx/images/minimize.png
Added: trunk/jx/images/page_grid.png
Property changes on: trunk/jx/images/page_grid.png
Added: trunk/jx/images/panel_grey_bg.png
Property changes on: trunk/jx/images/panel_grey_bg.png
Added: trunk/jx/images/panel_white_bg.png
Property changes on: trunk/jx/images/panel_white_bg.png
Added: trunk/jx/images/separator.png
Property changes on: trunk/jx/images/separator.png
Added: trunk/jx/images/snap_bg.png
Property changes on: trunk/jx/images/snap_bg.png
Added: trunk/jx/images/tab_bottom_bg.png
Property changes on: trunk/jx/images/tab_bottom_bg.png
Added: trunk/jx/images/tab_left_bg.png
Property changes on: trunk/jx/images/tab_left_bg.png
Added: trunk/jx/images/tab_right_bg.png
Property changes on: trunk/jx/images/tab_right_bg.png
Added: trunk/jx/images/tab_top_bg.png
Property changes on: trunk/jx/images/tab_top_bg.png
Added: trunk/jx/images/test-text.png
Property changes on: trunk/jx/images/test-text.png
Added: trunk/jx/images/toolbar_separator_h.png
Property changes on: trunk/jx/images/toolbar_separator_h.png
Added: trunk/jx/images/toolbar_separator_v.png
Property changes on: trunk/jx/images/toolbar_separator_v.png
Added: trunk/jx/images/tree_folder.png
Property changes on: trunk/jx/images/tree_folder.png
Added: trunk/jx/images/tree_folder_open.png
Property changes on: trunk/jx/images/tree_folder_open.png
Added: trunk/jx/images/tree_last_node.png
Property changes on: trunk/jx/images/tree_last_node.png
Added: trunk/jx/images/tree_minus.png
Property changes on: trunk/jx/images/tree_minus.png
Added: trunk/jx/images/tree_node.png
Property changes on: trunk/jx/images/tree_node.png
Added: trunk/jx/images/tree_none.png
Property changes on: trunk/jx/images/tree_none.png
Added: trunk/jx/images/tree_page.png
Property changes on: trunk/jx/images/tree_page.png
Added: trunk/jx/images/tree_plus.png
Property changes on: trunk/jx/images/tree_plus.png
Added: trunk/jx/images/tree_vert_line.png
Property changes on: trunk/jx/images/tree_vert_line.png
Added: trunk/jx/lib/jx_combined.css
--- trunk/jx/lib/jx_combined.css (rev 0)
+++ trunk/jx/lib/jx_combined.css 2008-03-10 13:29:17 UTC (rev 1224)
@@ -0,0 +1,1101 @@
+Copyright (c) 2006, Yahoo! Inc. All rights reserved.
+Code licensed under the BSD License:
+http://developer.yahoo.net/yui/license.txt
+version: 0.11.0
+body,div,dl,dt,dd,ul,ol,li,h1,h2,h3,h4,h5,h6,pre,form,fieldset,input,p,blockquote,th,td{margin:0;padding:0;}
+table{border-collapse:collapse;border-spacing:0;}
+fieldset,img{border:0;}
+address,caption,cite,code,dfn,em,strong,th,var{font-style:normal;font-weight:normal;}
+ol,ul {list-style:none;}
+caption,th {text-align:left;}
+h1,h2,h3,h4,h5,h6{font-size:100%;}
+q:before,q:after{content:'';}
+DMSG additions for Jx
+a{outline:none;}
+.png24{filter:expression(Jx.applyPNGFilter(this))}
+.jxClearer{display:block;position:relative;float:none;clear:both;font-size:0;line-height:0;width:0;height:0;margin:0;padding:0;}
+.jxDisabled{opacity:0.4;-moz-opacity:0.4;filter:Alpha(opacity=40);}
+ * @project Jx
+ * @revision $Id: button.css 396 2007-09-05 01:24:59Z pspencer $
+ * @author Fred Warnock (fwarnock at dmsolutions.ca)
+ * @copyright © 2006 DM Solutions Group Inc.
+/* BUTTON STYLES */
+div.jxButtonContainer {
+ display: block;
+ position: relative;
+ float: left;
+/* jxButtons consist of an A, containing a SPAN, which contains an image.
+ Buttons can use the sliding door technique with background images to horizontally
+ accomodate icons with labels. */
+a.jxButton {
+ display: block;
+ float: left;
+span.jxButtonSpan {
+ /* If using background images, the SPAN contains the right side of the background */
+ /* use padding to make space between the icon and button edge */
+ /* padding-left: 0px;*/ /* butts up to the left of the button bg image */
+ display: block;
+ float: left;
+ font-size: 0px;
+ line-height: 0px;
+img.jxButtonIcon {
+ float: left;
+span.jxButtonLabel {
+ display: block;
+ float: left;
+ cursor: pointer;
+span.jxButtonLabel.jxButtonEmptyLabel {
+ /* collapse empty labels */
+ padding: 0px;
+ width: 0px;
+ overflow: hidden;
+.jxButtonMenu a span.jxButtonLabel.jxButtonEmptyLabel,
+a.jxButtonFlyout span.jxButtonLabel.jxButtonEmptyLabel {
+ /* expand empty labels that have a menu */
+ overflow: visible;
+span.jxButtonEmptyLabel {
+ /* collapse empty labels for FF */
+.jxFlyout {
+ position: absolute;
+ display: block;
+ clear: both;
+ float: none;
+ top: 100%;
+ left: 0px;
+ z-index: 100;
+.jxButtonContentTop .jxFlyout {
+ top: auto;
+ bottom: 100%;
+.jxButtonContentLeft .jxFlyout {
+ left: auto;
+ right: 0px;
+ * @project Jx
+ * @revision $Id: color.css 404 2007-09-10 20:03:57Z fwarnock $
+/* COLOR PICKER STYLES */
+/*.jxColorPicker {
+ display: none;
+ top: 100%;
+ width: 212px;
+ left: 0px;
+ border: 1px solid #000;
+ padding: 2px;
+ background-color: #eee;
+.jxColorBar {
+table.jxColorGrid {
+ border-collapse: collapse;
+ empty-cells: show;
+ clear:both;
+.jxColorGrid td {
+.jxColorGrid td.emptyCell {
+ border: 0px solid #000;
+.jxColorGrid td.emptyCell span {
+ display: block;
+ width: 7px;
+ height: 7px;
+ line-height: 0px;
+ font-size: 0px;
+ padding: 1px;
+ margin: 0px;
+.jxColorGrid a.colorSwatch {
+ display: block;
+ width: 7px;
+ height: 7px;
+ line-height: 0px;
+ font-size: 0px;
+ margin: 0px;
+ padding: 1px;
+.jxColorGrid a.borderWhite:hover {
+ border: 1px solid #fff;
+ padding: 0px;
+.jxColorGrid a.borderBlack:hover {
+ padding: 0px;
+input.jxHexInput {
+ width: 55px;
+ vertical-align: middle;
+input.jxAlphaInput {
+ width: 30px;
+div.jxColorPreview {
+ float: left;
+ width: 20px;
+ height: 20px;
+ margin: 2px;
+ background-image: url('../images/grid.png');
+div.jxColorButtonPreview {
+ float: left;
+ width: 14px;
+ height: 14px;
+div.jxColorButtonPreview div {
+ width: 14px;
+ height: 14px;
+div.jxColorPreview img {
+ z-index: 0;
+div.jxColorPreview div {
+ width: 20px;
+ height: 20px;
+ z-index: 1;
+label.jxColorLabel,
+label.jxAlphaLabel {
+ width: auto;
+ font-family: Arial, sans-serif;
+ font-size: 12px;
+ line-height: 24px;
+ padding: 2px;
+a.jxColorClose {
+ top: 0px;
+ right: 0px;
+ width: 20px;
+ height: 20px;
+a.jxColorClose img {
+ width: 20px;
+ height: 20px;
+ * @project Jx
+ * @revision $Id: dialog.css 512 2008-03-07 21:15:45Z pspencer $
+/* DIALOG STYLES */
+.jxDialogContainer {
+ position:absolute;
+ display: block;
+ font-size: 0px;
+ line-height: 0px;
+.jxDialog {
+ display: block;
+ z-index: 1;
+.jxDialogModal {
+ display: block;
+ top: 0px;
+ left: 0px;
+ width: 100%;
+ height: 100%;
+.jxDialogBgTL,
+.jxDialogBgT,
+.jxDialogBgTR,
+.jxDialogBgR,
+.jxDialogBgBR,
+.jxDialogBgB,
+.jxDialogBgBL,
+.jxDialogBgL {
+.jxDialogBgTL img,
+.jxDialogBgT img,
+.jxDialogBgTR img,
+.jxDialogBgR img,
+.jxDialogBgBR img,
+.jxDialogBgB img,
+.jxDialogBgBL img,
+.jxDialogBgL img {
+.jxDialogTitle {
+ display: block;
+/* the Dialog Help Area is likely to be depricated */
+.jxDialogHelp {
+ left: 100%;
+ top: 21px;
+ width: 200px;
+ height: 100px;
+ border: 1px solid #999;
+ background-color: #fff;
+ overflow: auto;
+ padding: 0px;
+.jxDialogHelpCloseButton {
+ top: 2px;
+ right: 2px;
+.jxDialogContent {
+ position:relative;
+ overflow: auto;
+ display: block;
+.jxDialogAction {
+ overflow: hidden;
+ display: block;
+.jxDialogCloseButton,
+.jxDialogHelpButton {
+ display: block;
+.jxDialogResize {
+iframe.jxDialogShim {
+ top: 0px;
+ left: 0px;
+ width: 100%;
+ height: 100%;
+ filter: Alpha(opacity:0);
+ opacity: 0;
+ -moz-opacity: 0;
+ z-index: -1;
+}.jxGridContainer {
+ top: 0;
+ left: 0;
+ border-left: 0px solid #96a7b4;
+ border-top: 0px solid #96a7b4;
+ border-right: 1px solid #96a7b4;
+ border-bottom: 1px solid #96a7b4;
+ overflow: hidden;
+ font-family: Arial, Verdana, sans-serif;
+ font-size: 12px;
+ font-weight: normal;
+.jxGridTable {
+ table-layout: fixed;
+ border-style: none;
+ width: 0px;
+.jxGridColHeadHide {
+ height: 0px;
+ line-height: 0px;
+ font-size: 0px;
+ white-space: normal;
+.jxGridColHeadHide p, .jxGridRowHeadHide p {
+ font-size: 0px;
+ line-height: 0px;
+ height: 0px;
+ margin: 0px;
+ padding: 0px;
+.jxGridRowHeadHide {
+ width: 0px;
+.jxGridCell {
+ border-right: 1px solid #cecece;
+ border-bottom: 1px solid #cecece;
+ overflow: hidden;
+ padding-left: 3px;
+ padding-right: 3px;
+ overflow: hidden;
+ /* can change this to normal */
+ white-space: nowrap;
+ /* only applies in IE and Safari right now */
+ text-overflow: ellipsis;
+.jxGridColHead {
+ background-color: #ebebeb;
+ text-align: center;
+ font-weight: bold;
+ color: #45525f;
+.jxGridRowHead {
+ color: #45525f;
+.jxGridRowAll {
+.jxGridRowOdd {
+ /*background-color: pink;*/
+.jxGridRowEven {
+ /*background-color: lime;*/
+.jxGridRowOdd td {
+ border-right: 1px solid #999;
+ border-bottom: 1px solid #999;
+.jxGridRowEven td {
+.jxGridRowSelected {
+ background-color: #dae6f2;
+.jxGridColumnSelected {
+.jxGridCellSelected {
+.jxGridRowPrelight {
+ background-color: #f2f2f2;
+.jxGridCellPrelight {
+ /*background-color: green;*/
+.jxGridRowHeaderPrelight {
+ background-color: #dfdfdf;
+.jxGridColumnHeaderPrelight {
+.jxGridRowHeaderSelected {
+ background-color: #6d7f8e;
+ color: #fff;
+.jxGridColumnHeaderSelected {
+ color: #fff;
+ * @project Jx
+ * @revision $Id: menu.css 406 2007-09-13 14:42:18Z pspencer $
+/* JX MENU STYLES */
+/* Jx Menus and Sub-menus are all built out of nested ULs
+ For this to work visually, the margins and padding need to be flattened
+ out, and the list marker needs to be hidden
+ul.jxMenu, ul.jxSubMenu {
+ /* this allows menus and submenus to be re-positioned */
+ display: block;
+ clear: both;
+ float: none;
+ /* this allows menus and sub menus to appear above everything */
+ z-index: 100;
+ list-style-type: none;
+ul.jxMenu {
+ top: 100%;
+ left: 0px;
+.jxButtonContentTop ul.jxMenu {
+ top: auto;
+ bottom: 100%;
+.jxButtonContentLeft ul.jxMenu {
+ left: auto;
+ right: 0px;
+li.jxMenuItem, li.jxSubMenuItem {
+ /* This is needed for IE to make sure submenus don't open space in the parent menu */
+ display: inline;
+ clear: both;
+ float: none;
+li.jxMenuItem div.jxButtonContainer {
+ float: none;
+ul.jxMenu a, ul.jxSubMenu a {
+ display: block;
+ text-decoration: none;
+ clear: both;
+ float: none;
+ul.jxMenu img, ul.jxSubMenu img {
+ padding-right: 5px;
+ul.jxMenu span, ul.jxSubMenu span {
+ display: block;
+/* clear: both; */ /*this caused a problem where menu's with images wrapped*/
+ float: none;
+ul.jxMenu span.jxMenuSeparator {
+ display: block;
+iframe.jxMenuShim {
+ top: 0px;
+ left: 0px;
+ width: 100%;
+ height: 100%;
+ opacity: 0;
+ -moz-opacity: 0;
+ z-index: -1;
+ * @project Jx
+ * @revision $Id: panel.css 375 2007-08-21 14:36:10Z fwarnock $
+/* JX PANEL STYLES */
+.jxPanel {
+/* the content panel inside a panel */
+.jxPanelContent {
+ /* position relative is required for panels to work correctly in safari */
+ display: block;
+ /* set the width to 100% to make the content resize properly when the container resizes */
+ width: 100%;
+ /* height gets set by javascript */
+ height: auto;
+ /* content gains scroll bars as needed */
+ overflow: auto;
+ border-top: 1px solid #fff;
+ margin: 0px;
+ padding: 0px;
+ border-top: none;
+ /*white-space: nowrap;*/ /* need wrapping off for trees */
+/* JX PANEL MANAGER STYLES */
+.jxPanelTitle {
+ /* position relative is required for panel dragging to work correctly in safari */
+ width: 100%;
+ background-image: url(../images/snap_bg.png);
+ background-repeat: repeat-x;
+ background-position: left top;
+ border-bottom: 1px solid #666;
+ /* note this is hard coded into jx.js JxPanel initialize function - change there as well as here */
+ height: 22px;
+ margin: 0;
+ padding: 0;
+ /* this prevents lines from wrapping when content is resized */
+/* -moz-box-sizing: border-box;*/
+.jxPanelLabel {
+ /* make room for the loading spinner */
+ padding-left: 25px;
+ font-family: Arial, Helvetica, sans-serif;
+ font-size: 12px;
+ /* line-height vertically aligns the label in the containing div. In the border
+ box model, this should be the containers height less padding and borders. In
+ the content box model, it should be the height of the container. */
+ line-height:21px;
+ /* make the text align properly with an neighbouring inline image */
+ /*vertical-align: top;*/
+ color: #000;
+a.jxPanelMaximize,
+a.jxPanelHelp {
+ top: 1px;
+ padding: 0px;
+ margin: 0px;
+ border: 0px;
+ width: 20px;
+ height: 20px;
+.jxPanelTitle a.jxPanelHelp {
+ right: 20px;
+.jxPanelTitle a.jxPanelMaximize {
+ right: 2px;
+/* removed - this is a WebStudio specific style and needs to be moved there when
+ we update WebStudio */
+.jxPanelTitle a.jxPanelClose {
+ right: 2px;
+ z-index: 10;
+a.jxPanelMaximize img,
+a.jxPanelHelp img,
+a.jxPanelLoading img {
+ border: 0px;
+ /* the margin needs to make up the difference between it's width/height
+ and the width/height of the parent a */
+ margin: 0px;
+ /* width/height has to be the actual image width/height */
+ width: 20px;
+ height: 20px;
+ visibility:hidden;
+ top: 1px;
+ left: 2px;
+ * @project Jx
+ * @revision $Id: picker.css 316 2007-06-19 20:28:53Z pspencer $
+/* PICKER STYLES */
+/* the jx Picker is intended to replace lists and combo boxes that require
+ a richer set of features such as text input, images and styles in the
+ selection list and better control over the list size. */
+div.jxPicker {
+ display: block;
+ padding: 0px;
+ padding-right: 22px;
+ margin: 0px;
+ border: 0px;
+ font-size:11px;
+ z-index: 1;
+.jxPickerDiscloser {
+ right: 3px;
+ top: 3px;
+.jxPickerDiscloser img {
+ width: 16px;
+ height: 16px;
+ border: 0px;
+.jxPickerInput {
+ display: block;
+ float: left;
+ /*padding-right: 16px;*/
+ height: 24px;
+div.jxPickerOptions {
+ top: 100%;
+ left: 0px;
+ width: 100%;
+ height: auto;
+ overflow: auto;
+ border: 1px solid #333;
+ color: #000;
+ z-index: 1;
+ display: none;
+ text-align: right;
+div.jxPickerOptions ul {
+ display: block;
+ margin: 0px;
+ padding: 0px;
+ border: none;
+div.jxPickerOptions li {
+ display: block;
+ margin: 0px;
+ padding: 0px;
+ border: none;
+ height:20px;
+div.jxPickerOptions a {
+ display: block;
+ /* this value needs to be the height of it's parent
+ minus it's own margin, padding and border values */
+ line-height:20px;
+ /* height needs to be set for IE. Same value as line height. */
+ height: 20px;
+ color: #000;
+ background-position: right top;
+ background-repeat: no-repeat;
+div.jxPickerOptions a:hover {
+ background-color: #E1EDFA;
+ /*background-color: #ffffcc; */
+div.jxPickerOptions a.selected {
+ background-color: #ffffb3;
+ * @project Jx
+ * @revision $Id: tabs.css 512 2008-03-07 21:15:45Z pspencer $
+/* TAB STYLES */
+/* Note: There are some specific styles for IE in tabs_ie.css
+ The tabBox consists of a box containing a tabbar and the tab content areas.
+ It can be used within the body or nested within another object.
+.jxTabSetContainer {
+ /* This is an example of a container that can be used to hold a tabBox
+ the position need to be explicitly set, as well as the width and height. */
+ display: block;
+.jxTabSetContainer .jxToolbarContainer {
+ z-index: auto;
+.tabContent {
+ /* the width and height need to be set to 100% to:
+ 1. fill the tab box area
+ 2. allow a scrolling content area in IE */
+ display: none;
+ width:100%;
+ height: 100%;
+ overflow: auto;
+.tabContentActive {
+ display: block;
+/* TAB BOX MODE */
+.jxTabBoxTop,
+.jxTabBoxBottom,
+.jxTabBoxLeft,
+.jxTabBoxRight {
+/* TAB BOX MODE */
+.jxTabBoxTop .jxBarTop,
+.jxTabBoxBottom .jxBarBottom,
+.jxTabBoxLeft .jxBarLeft,
+.jxTabBoxRight .jxBarRight {
+/* The tabbar is built out of a UL
+ The tab background uses the sliding door technique so tabs can expand to
+ accomodate content up to 200 px wide (top/bottom tabs) or 200px high
+ (left/right tabs). All parts and states of the tab BG graphics are in the
+ same image so they can be treated like sprites.
+ Horizontal tabs can contain text or an image label. Vertical tabs need an
+ image label.
+ * @project Jx
+ * @revision $Id: toolbar.css 369 2007-07-26 17:24:23Z fwarnock $
+/* TOOLBAR STYLES */
+/* Multiple toolbars can be housed in the toolbar container the container will expand
+ vertically to accomodate wrapped toolbars */
+.jxToolbarContainer {
+ display: block;
+ z-index: 1;
+/* Horizontally oriented toolbars */
+.jxBarTop,
+.jxBarBottom {
+ width: 100%; /* fills the width, may be needed for JS style sniffing */
+ height: auto; /* since the last element clears the float, a height may not be needed */
+/* Vertically oriented toolbars */
+.jxBarLeft,
+.jxBarRight {
+ width: auto;
+ height: 100%;
+/* a label can optionally be used preceeding a toolbar.
+ the line height is used to center the label relative to the toolbar. */
+.toolbarLabel {
+ display: block;
+ float: left;
+/* The jx toolbar is built out of a UL
+ out, and the list markers need to be hidden
+ UL's are floated left so multiple toolbars can be in the samae row.
+ In IE, the UL needs to have a specified width to prevent button wrapping. */
+ul.jxToolbar {
+ display: block;
+ float: left;
+/* LI's are floated to the left, to make a horizontal row of buttons*/
+li.jxToolItem {
+ display: block;
+ float: left;
+ font-size: 0px;
+ line-height: 0px;
+/* Seperator height should match that of button images
+ and the margins+padding+border should add up to the same total too. */
+li.jxToolItem .separator {
+ display: block;
+ float: left;
+ font-size: 0px;
+ line-height: 0px;
+/* Vertically oriented toolbars need floats cleared */
+.jxBarLeft label.toolbarLabel,
+.jxBarLeft ul.jxToolbar,
+.jxBarLeft li.jxToolItem,
+.jxBarRight label.toolbarLabel,
+.jxBarRight ul.jxToolbar,
+.jxBarRight li.jxToolItem
+ clear: both;
+/* DEPRICATED STYLES */
+/* Vertically oriented toolbars do not need to fill their containers horizontally */
+.verticalToolbar {
+ width: auto;
+.verticalToolbar label.toolbarLabel,
+.verticalToolbar ul.jxToolbar,
+.verticalToolbar li.jxToolItem
+ clear: both;
+ * @project Jx
+ * @revision $Id: tree.css 324 2007-06-20 19:04:54Z pspencer $
+/* TREE STYLES */
+/* The jx tree built out of nested ULs
+.jxTree, .jxTreeRoot {
+ /* relative positioning is required for IE to fix the peek-a-boo bug */
+ list-style: none;
+ margin: 0px;
+ padding: 0px;
+.jxTreeNest {
+ list-style: none;
+ margin: 0px;
+ padding: 0px;
+ background-repeat: repeat-y;
+/* Node Classes */
+.jxTree li, .jxTreeRoot li {
+ margin: 0px;
+ padding: 0px;
+ /* background branches may need to shift up/down according to height of the node */
+ width: 100%;
+.jxTree li {
+ margin-left: 16px;
+.jxTree li.jxDisabled, .jxTreeRoot li.jxDisabled {
+ opacity: 0.4; /* css 3 */
+ -moz-opacity: 0.4; /* moz-specific */
+ filter: Alpha(opacity=40); /* IE only */
+.jxTree a, .jxTreeRoot a {
+ margin: 0px;
+ padding: 0px;
+ padding-left: 2px;
+ font-size: 11px;
+ color: #000;
+ /* Line Height needs to be an even number so branches line up properly */
+ line-height: 20px;
+.jxTree a:hover, .jxTreeRoot a:hover {
+.jxTree img, .jxTreeRoot img {
+ border: 0px;
+ width: 16px;
+ height: 16px;
+.jxTreeNest {background-image: url(../images/tree_vert_line.png);}
+.jxTreeNode {background-image: url(../images/tree_node.png);}
+.jxTreeNodeLast {background-image: url(../images/tree_last_node.png);}
+.jxTreeDropzone {
+ text-decoration:underline;
+ font-weight:bold;
+.jxTreeSelectedNode {
+ background-color: #AFD4FA;
+ /*background-color: #ddffaa; */
+ font-weight:bold;
+.jxTreeCutNode {
+.jxTreeCutNode a:hover {
+.jxTreeNode, .jxTreeNodeLast {
+/* width: 100%;*/
+.jxTreeNode a, .jxTreeNode img, .jxTreeNode input {
+.jxTreeNodeLast a, .jxTreeNodeLast img, .jxTreeNodeLast input {
+.jxTreeNodeImage {
+.jxTreeNodeIcon {
+ margin: 0px;
Added: trunk/jx/lib/jx_combined.js
--- trunk/jx/lib/jx_combined.js (rev 0)
+++ trunk/jx/lib/jx_combined.js 2008-03-10 13:29:17 UTC (rev 1224)
@@ -0,0 +1,14054 @@
+ * Prototype JavaScript framework, version 1.5.0
+ * (c) 2005-2007 Sam Stephenson
+ * Prototype is freely distributable under the terms of an MIT-style license.
+ * For details, see the Prototype web site: http://prototype.conio.net/
+ * Jx UI Library, version 1.0
+ * Copyright © 2008, DM Solutions Group Inc.
+ * Jx is freely distributable under the terms of an MIT-style license.
+/* Prototype JavaScript framework, version 1.5.0
+var Prototype = {
+ Version: '1.5.0',
+ BrowserFeatures: {
+ XPath: !!document.evaluate
+ ScriptFragment: '(?:<script.*?>)((\n|\r|.)*?)(?:<\/script>)',
+ emptyFunction: function() {},
+ K: function(x) { return x }
+var Class = {
+ create: function() {
+ return function() {
+ this.initialize.apply(this, arguments);
+var Abstract = new Object();
+Object.extend = function(destination, source) {
+ for (var property in source) {
+ destination[property] = source[property];
+ return destination;
+Object.extend(Object, {
+ inspect: function(object) {
+ try {
+ if (object === undefined) return 'undefined';
+ if (object === null) return 'null';
+ return object.inspect ? object.inspect() : object.toString();
+ } catch (e) {
+ if (e instanceof RangeError) return '...';
+ throw e;
+ keys: function(object) {
+ var keys = [];
+ for (var property in object)
+ keys.push(property);
+ return keys;
+ values: function(object) {
+ var values = [];
+ values.push(object[property]);
+ return values;
+ clone: function(object) {
+ return Object.extend({}, object);
+Function.prototype.bind = function() {
+ var __method = this, args = $A(arguments), object = args.shift();
+ return __method.apply(object, args.concat($A(arguments)));
+Function.prototype.bindAsEventListener = function(object) {
+ return function(event) {
+ return __method.apply(object, [( event || window.event)].concat(args).concat($A(arguments)));
+Object.extend(Number.prototype, {
+ toColorPart: function() {
+ var digits = this.toString(16);
+ if (this < 16) return '0' + digits;
+ return digits;
+ succ: function() {
+ return this + 1;
+ times: function(iterator) {
+ $R(0, this, true).each(iterator);
+ return this;
+var Try = {
+ these: function() {
+ var returnValue;
+ for (var i = 0, length = arguments.length; i < length; i++) {
+ var lambda = arguments[i];
+ try {
+ returnValue = lambda();
+ break;
+ } catch (e) {}
+ return returnValue;
+var PeriodicalExecuter = Class.create();
+PeriodicalExecuter.prototype = {
+ initialize: function(callback, frequency) {
+ this.callback = callback;
+ this.frequency = frequency;
+ this.currentlyExecuting = false;
+ this.registerCallback();
+ registerCallback: function() {
+ this.timer = setInterval(this.onTimerEvent.bind(this), this.frequency * 1000);
+ stop: function() {
+ if (!this.timer) return;
+ clearInterval(this.timer);
+ this.timer = null;
+ onTimerEvent: function() {
+ if (!this.currentlyExecuting) {
+ try {
+ this.currentlyExecuting = true;
+ this.callback(this);
+ } finally {
+String.interpret = function(value){
+ return value == null ? '' : String(value);
+Object.extend(String.prototype, {
+ gsub: function(pattern, replacement) {
+ var result = '', source = this, match;
+ replacement = arguments.callee.prepareReplacement(replacement);
+ while (source.length > 0) {
+ if (match = source.match(pattern)) {
+ result += source.slice(0, match.index);
+ result += String.interpret(replacement(match));
+ source = source.slice(match.index + match[0].length);
+ } else {
+ result += source, source = '';
+ return result;
+ sub: function(pattern, replacement, count) {
+ replacement = this.gsub.prepareReplacement(replacement);
+ count = count === undefined ? 1 : count;
+ return this.gsub(pattern, function(match) {
+ if (--count < 0) return match[0];
+ return replacement(match);
+ scan: function(pattern, iterator) {
+ this.gsub(pattern, iterator);
+ return this;
+ truncate: function(length, truncation) {
+ length = length || 30;
+ truncation = truncation === undefined ? '...' : truncation;
+ return this.length > length ?
+ this.slice(0, length - truncation.length) + truncation : this;
+ strip: function() {
+ return this.replace(/^\s+/, '').replace(/\s+$/, '');
+ stripTags: function() {
+ return this.replace(/<\/?[^>]+>/gi, '');
+ stripScripts: function() {
+ return this.replace(new RegExp(Prototype.ScriptFragment, 'img'), '');
+ extractScripts: function() {
+ var matchAll = new RegExp(Prototype.ScriptFragment, 'img');
+ var matchOne = new RegExp(Prototype.ScriptFragment, 'im');
+ return (this.match(matchAll) || []).map(function(scriptTag) {
+ return (scriptTag.match(matchOne) || ['', ''])[1];
+ evalScripts: function() {
+ return this.extractScripts().map(function(script) { return eval(script) });
+ escapeHTML: function() {
+ var div = document.createElement('div');
+ var text = document.createTextNode(this);
+ div.appendChild(text);
+ return div.innerHTML;
+ unescapeHTML: function() {
+ div.innerHTML = this.stripTags();
+ return div.childNodes[0] ? (div.childNodes.length > 1 ?
+ $A(div.childNodes).inject('',function(memo,node){ return memo+node.nodeValue }) :
+ div.childNodes[0].nodeValue) : '';
+ toQueryParams: function(separator) {
+ var match = this.strip().match(/([^?#]*)(#.*)?$/);
+ if (!match) return {};
+ return match[1].split(separator || '&').inject({}, function(hash, pair) {
+ if ((pair = pair.split('='))[0]) {
+ var name = decodeURIComponent(pair[0]);
+ var value = pair[1] ? decodeURIComponent(pair[1]) : undefined;
+ if (hash[name] !== undefined) {
+ if (hash[name].constructor != Array)
+ hash[name] = [hash[name]];
+ if (value) hash[name].push(value);
+ else hash[name] = value;
+ return hash;
+ toArray: function() {
+ return this.split('');
+ return this.slice(0, this.length - 1) +
+ String.fromCharCode(this.charCodeAt(this.length - 1) + 1);
+ camelize: function() {
+ var parts = this.split('-'), len = parts.length;
+ if (len == 1) return parts[0];
+ var camelized = this.charAt(0) == '-'
+ ? parts[0].charAt(0).toUpperCase() + parts[0].substring(1)
+ : parts[0];
+ for (var i = 1; i < len; i++)
+ camelized += parts[i].charAt(0).toUpperCase() + parts[i].substring(1);
+ return camelized;
+ capitalize: function(){
+ return this.charAt(0).toUpperCase() + this.substring(1).toLowerCase();
+ underscore: function() {
+ return this.gsub(/::/, '/').gsub(/([A-Z]+)([A-Z][a-z])/,'#{1}_#{2}').gsub(/([a-z\d])([A-Z])/,'#{1}_#{2}').gsub(/-/,'_').toLowerCase();
+ dasherize: function() {
+ return this.gsub(/_/,'-');
+ inspect: function(useDoubleQuotes) {
+ var escapedString = this.replace(/\\/g, '\\\\');
+ if (useDoubleQuotes)
+ return '"' + escapedString.replace(/"/g, '\\"') + '"';
+ else
+ return "'" + escapedString.replace(/'/g, '\\\'') + "'";
+String.prototype.gsub.prepareReplacement = function(replacement) {
+ if (typeof replacement == 'function') return replacement;
+ var template = new Template(replacement);
+ return function(match) { return template.evaluate(match) };
+String.prototype.parseQuery = String.prototype.toQueryParams;
+var Template = Class.create();
+Template.Pattern = /(^|.|\r|\n)(#\{(.*?)\})/;
+Template.prototype = {
+ initialize: function(template, pattern) {
+ this.template = template.toString();
+ this.pattern = pattern || Template.Pattern;
+ evaluate: function(object) {
+ return this.template.gsub(this.pattern, function(match) {
+ var before = match[1];
+ if (before == '\\') return match[2];
+ return before + String.interpret(object[match[3]]);
+var $break = new Object();
+var $continue = new Object();
+var Enumerable = {
+ each: function(iterator) {
+ var index = 0;
+ try {
+ this._each(function(value) {
+ try {
+ iterator(value, index++);
+ } catch (e) {
+ if (e != $continue) throw e;
+ } catch (e) {
+ if (e != $break) throw e;
+ return this;
+ eachSlice: function(number, iterator) {
+ var index = -number, slices = [], array = this.toArray();
+ while ((index += number) < array.length)
+ slices.push(array.slice(index, index+number));
+ return slices.map(iterator);
+ all: function(iterator) {
+ var result = true;
+ this.each(function(value, index) {
+ result = result && !!(iterator || Prototype.K)(value, index);
+ if (!result) throw $break;
+ return result;
+ any: function(iterator) {
+ var result = false;
+ if (result = !!(iterator || Prototype.K)(value, index))
+ throw $break;
+ return result;
+ collect: function(iterator) {
+ var results = [];
+ results.push((iterator || Prototype.K)(value, index));
+ return results;
+ detect: function(iterator) {
+ var result;
+ if (iterator(value, index)) {
+ result = value;
+ throw $break;
+ return result;
+ findAll: function(iterator) {
+ var results = [];
+ results.push(value);
+ return results;
+ grep: function(pattern, iterator) {
+ var results = [];
+ var stringValue = value.toString();
+ if (stringValue.match(pattern))
+ return results;
+ include: function(object) {
+ var found = false;
+ this.each(function(value) {
+ if (value == object) {
+ found = true;
+ throw $break;
+ return found;
+ inGroupsOf: function(number, fillWith) {
+ fillWith = fillWith === undefined ? null : fillWith;
+ return this.eachSlice(number, function(slice) {
+ while(slice.length < number) slice.push(fillWith);
+ return slice;
+ inject: function(memo, iterator) {
+ memo = iterator(memo, value, index);
+ return memo;
+ invoke: function(method) {
+ var args = $A(arguments).slice(1);
+ return this.map(function(value) {
+ return value[method].apply(value, args);
+ max: function(iterator) {
+ var result;
+ value = (iterator || Prototype.K)(value, index);
+ if (result == undefined || value >= result)
+ result = value;
+ return result;
+ min: function(iterator) {
+ var result;
+ if (result == undefined || value < result)
+ result = value;
+ return result;
+ partition: function(iterator) {
+ var trues = [], falses = [];
+ ((iterator || Prototype.K)(value, index) ?
+ trues : falses).push(value);
+ return [trues, falses];
+ pluck: function(property) {
+ var results = [];
+ results.push(value[property]);
+ return results;
+ reject: function(iterator) {
+ var results = [];
+ if (!iterator(value, index))
+ return results;
+ sortBy: function(iterator) {
+ return this.map(function(value, index) {
+ return {value: value, criteria: iterator(value, index)};
+ }).sort(function(left, right) {
+ var a = left.criteria, b = right.criteria;
+ return a < b ? -1 : a > b ? 1 : 0;
+ }).pluck('value');
+ return this.map();
+ zip: function() {
+ var iterator = Prototype.K, args = $A(arguments);
+ if (typeof args.last() == 'function')
+ iterator = args.pop();
+ var collections = [this].concat(args).map($A);
+ return iterator(collections.pluck(index));
+ size: function() {
+ return this.toArray().length;
+ inspect: function() {
+ return '#<Enumerable:' + this.toArray().inspect() + '>';
+Object.extend(Enumerable, {
+ map: Enumerable.collect,
+ find: Enumerable.detect,
+ select: Enumerable.findAll,
+ member: Enumerable.include,
+ entries: Enumerable.toArray
+var $A = Array.from = function(iterable) {
+ if (!iterable) return [];
+ if (iterable.toArray) {
+ return iterable.toArray();
+ } else {
+ var results = [];
+ for (var i = 0, length = iterable.length; i < length; i++)
+ results.push(iterable[i]);
+ return results;
+Object.extend(Array.prototype, Enumerable);
+if (!Array.prototype._reverse)
+ Array.prototype._reverse = Array.prototype.reverse;
+Object.extend(Array.prototype, {
+ _each: function(iterator) {
+ for (var i = 0, length = this.length; i < length; i++)
+ iterator(this[i]);
+ clear: function() {
+ this.length = 0;
+ return this;
+ first: function() {
+ return this[0];
+ last: function() {
+ return this[this.length - 1];
+ compact: function() {
+ return this.select(function(value) {
+ return value != null;
+ flatten: function() {
+ return this.inject([], function(array, value) {
+ return array.concat(value && value.constructor == Array ?
+ value.flatten() : [value]);
+ without: function() {
+ var values = $A(arguments);
+ return !values.include(value);
+ indexOf: function(object) {
+ if (this[i] == object) return i;
+ return -1;
+ reverse: function(inline) {
+ return (inline !== false ? this : this.toArray())._reverse();
+ reduce: function() {
+ return this.length > 1 ? this : this[0];
+ uniq: function() {
+ return array.include(value) ? array : array.concat([value]);
+ clone: function() {
+ return [].concat(this);
+ return this.length;
+ return '[' + this.map(Object.inspect).join(', ') + ']';
+Array.prototype.toArray = Array.prototype.clone;
+function $w(string){
+ string = string.strip();
+ return string ? string.split(/\s+/) : [];
+if(window.opera){
+ Array.prototype.concat = function(){
+ var array = [];
+ for(var i = 0, length = this.length; i < length; i++) array.push(this[i]);
+ for(var i = 0, length = arguments.length; i < length; i++) {
+ if(arguments[i].constructor == Array) {
+ for(var j = 0, arrayLength = arguments[i].length; j < arrayLength; j++)
+ array.push(arguments[i][j]);
+ } else {
+ array.push(arguments[i]);
+ return array;
+var Hash = function(obj) {
+ Object.extend(this, obj || {});
+Object.extend(Hash, {
+ toQueryString: function(obj) {
+ var parts = [];
+ this.prototype._each.call(obj, function(pair) {
+ if (!pair.key) return;
+ if (pair.value && pair.value.constructor == Array) {
+ var values = pair.value.compact();
+ if (values.length < 2) pair.value = values.reduce();
+ else {
+ key = encodeURIComponent(pair.key);
+ values.each(function(value) {
+ value = value != undefined ? encodeURIComponent(value) : '';
+ parts.push(key + '=' + encodeURIComponent(value));
+ return;
+ if (pair.value == undefined) pair[1] = '';
+ parts.push(pair.map(encodeURIComponent).join('='));
+ return parts.join('&');
+Object.extend(Hash.prototype, Enumerable);
+Object.extend(Hash.prototype, {
+ for (var key in this) {
+ var value = this[key];
+ if (value && value == Hash.prototype[key]) continue;
+ var pair = [key, value];
+ pair.key = key;
+ pair.value = value;
+ iterator(pair);
+ keys: function() {
+ return this.pluck('key');
+ values: function() {
+ return this.pluck('value');
+ merge: function(hash) {
+ return $H(hash).inject(this, function(mergedHash, pair) {
+ mergedHash[pair.key] = pair.value;
+ return mergedHash;
+ remove: function() {
+ var result;
+ var value = this[arguments[i]];
+ if (value !== undefined){
+ if (result === undefined) result = value;
+ else {
+ if (result.constructor != Array) result = [result];
+ result.push(value)
+ delete this[arguments[i]];
+ return result;
+ toQueryString: function() {
+ return Hash.toQueryString(this);
+ return '#<Hash:{' + this.map(function(pair) {
+ return pair.map(Object.inspect).join(': ');
+ }).join(', ') + '}>';
+function $H(object) {
+ if (object && object.constructor == Hash) return object;
+ return new Hash(object);
+ObjectRange = Class.create();
+Object.extend(ObjectRange.prototype, Enumerable);
+Object.extend(ObjectRange.prototype, {
+ initialize: function(start, end, exclusive) {
+ this.start = start;
+ this.end = end;
+ this.exclusive = exclusive;
+ var value = this.start;
+ while (this.include(value)) {
+ iterator(value);
+ value = value.succ();
+ include: function(value) {
+ if (value < this.start)
+ return false;
+ if (this.exclusive)
+ return value < this.end;
+ return value <= this.end;
+var $R = function(start, end, exclusive) {
+ return new ObjectRange(start, end, exclusive);
+var Ajax = {
+ getTransport: function() {
+ return Try.these(
+ function() {return new XMLHttpRequest()},
+ function() {return new ActiveXObject('Msxml2.XMLHTTP')},
+ function() {return new ActiveXObject('Microsoft.XMLHTTP')}
+ ) || false;
+ activeRequestCount: 0
+Ajax.Responders = {
+ responders: [],
+ this.responders._each(iterator);
+ register: function(responder) {
+ if (!this.include(responder))
+ this.responders.push(responder);
+ unregister: function(responder) {
+ this.responders = this.responders.without(responder);
+ dispatch: function(callback, request, transport, json) {
+ this.each(function(responder) {
+ if (typeof responder[callback] == 'function') {
+ try {
+ responder[callback].apply(responder, [request, transport, json]);
+ } catch (e) {}
+Object.extend(Ajax.Responders, Enumerable);
+Ajax.Responders.register({
+ onCreate: function() {
+ Ajax.activeRequestCount++;
+ onComplete: function() {
+ Ajax.activeRequestCount--;
+Ajax.Base = function() {};
+Ajax.Base.prototype = {
+ setOptions: function(options) {
+ this.options = {
+ method: 'post',
+ asynchronous: true,
+ contentType: 'application/x-www-form-urlencoded',
+ encoding: 'UTF-8',
+ parameters: ''
+ Object.extend(this.options, options || {});
+ this.options.method = this.options.method.toLowerCase();
+ if (typeof this.options.parameters == 'string')
+ this.options.parameters = this.options.parameters.toQueryParams();
+Ajax.Request = Class.create();
+Ajax.Request.Events =
+ ['Uninitialized', 'Loading', 'Loaded', 'Interactive', 'Complete'];
+Ajax.Request.prototype = Object.extend(new Ajax.Base(), {
+ _complete: false,
+ initialize: function(url, options) {
+ this.transport = Ajax.getTransport();
+ this.setOptions(options);
+ this.request(url);
+ request: function(url) {
+ this.url = url;
+ this.method = this.options.method;
+ var params = this.options.parameters;
+ if (!['get', 'post'].include(this.method)) {
+ // simulate other verbs over post
+ params['_method'] = this.method;
+ this.method = 'post';
+ params = Hash.toQueryString(params);
+ if (params && /Konqueror|Safari|KHTML/.test(navigator.userAgent)) params += '&_='
+ // when GET, append parameters to URL
+ if (this.method == 'get' && params)
+ this.url += (this.url.indexOf('?') > -1 ? '&' : '?') + params;
+ try {
+ Ajax.Responders.dispatch('onCreate', this, this.transport);
+ this.transport.open(this.method.toUpperCase(), this.url,
+ this.options.asynchronous);
+ if (this.options.asynchronous)
+ setTimeout(function() { this.respondToReadyState(1) }.bind(this), 10);
+ this.transport.onreadystatechange = this.onStateChange.bind(this);
+ this.setRequestHeaders();
+ var body = this.method == 'post' ? (this.options.postBody || params) : null;
+ this.transport.send(body);
+ /* Force Firefox to handle ready state 4 for synchronous requests */
+ if (!this.options.asynchronous && this.transport.overrideMimeType)
+ this.onStateChange();
+ catch (e) {
+ this.dispatchException(e);
+ onStateChange: function() {
+ var readyState = this.transport.readyState;
+ if (readyState > 1 && !((readyState == 4) && this._complete))
+ this.respondToReadyState(this.transport.readyState);
+ setRequestHeaders: function() {
+ var headers = {
+ 'X-Requested-With': 'XMLHttpRequest',
+ 'X-Prototype-Version': Prototype.Version,
+ 'Accept': 'text/javascript, text/html, application/xml, text/xml, */*'
+ if (this.method == 'post') {
+ headers['Content-type'] = this.options.contentType +
+ (this.options.encoding ? '; charset=' + this.options.encoding : '');
+ /* Force "Connection: close" for older Mozilla browsers to work
+ * around a bug where XMLHttpRequest sends an incorrect
+ * Content-length header. See Mozilla Bugzilla #246651.
+ if (this.transport.overrideMimeType &&
+ (navigator.userAgent.match(/Gecko\/(\d{4})/) || [0,2005])[1] < 2005)
+ headers['Connection'] = 'close';
+ // user-defined headers
+ if (typeof this.options.requestHeaders == 'object') {
+ var extras = this.options.requestHeaders;
+ if (typeof extras.push == 'function')
+ for (var i = 0, length = extras.length; i < length; i += 2)
+ headers[extras[i]] = extras[i+1];
+ else
+ $H(extras).each(function(pair) { headers[pair.key] = pair.value });
+ for (var name in headers)
+ this.transport.setRequestHeader(name, headers[name]);
+ success: function() {
+ return !this.transport.status
+ || (this.transport.status >= 200 && this.transport.status < 300);
+ respondToReadyState: function(readyState) {
+ var state = Ajax.Request.Events[readyState];
+ var transport = this.transport, json = this.evalJSON();
+ if (state == 'Complete') {
+ try {
+ this._complete = true;
+ (this.options['on' + this.transport.status]
+ || this.options['on' + (this.success() ? 'Success' : 'Failure')]
+ || Prototype.emptyFunction)(transport, json);
+ } catch (e) {
+ if ((this.getHeader('Content-type') || 'text/javascript').strip().
+ match(/^(text|application)\/(x-)?(java|ecma)script(;.*)?$/i))
+ this.evalResponse();
+ try {
+ (this.options['on' + state] || Prototype.emptyFunction)(transport, json);
+ Ajax.Responders.dispatch('on' + state, this, transport, json);
+ } catch (e) {
+ // avoid memory leak in MSIE: clean up
+ this.transport.onreadystatechange = Prototype.emptyFunction;
+ getHeader: function(name) {
+ try {
+ return this.transport.getResponseHeader(name);
+ } catch (e) { return null }
+ evalJSON: function() {
+ try {
+ var json = this.getHeader('X-JSON');
+ return json ? eval('(' + json + ')') : null;
+ evalResponse: function() {
+ try {
+ return eval(this.transport.responseText);
+ } catch (e) {
+ dispatchException: function(exception) {
+ (this.options.onException || Prototype.emptyFunction)(this, exception);
+ Ajax.Responders.dispatch('onException', this, exception);
+Ajax.Updater = Class.create();
+Object.extend(Object.extend(Ajax.Updater.prototype, Ajax.Request.prototype), {
+ initialize: function(container, url, options) {
+ this.container = {
+ success: (container.success || container),
+ failure: (container.failure || (container.success ? null : container))
+ var onComplete = this.options.onComplete || Prototype.emptyFunction;
+ this.options.onComplete = (function(transport, param) {
+ this.updateContent();
+ onComplete(transport, param);
+ }).bind(this);
+ updateContent: function() {
+ var receiver = this.container[this.success() ? 'success' : 'failure'];
+ var response = this.transport.responseText;
+ if (!this.options.evalScripts) response = response.stripScripts();
+ if (receiver = $(receiver)) {
+ if (this.options.insertion)
+ new this.options.insertion(receiver, response);
+ else
+ receiver.update(response);
+ if (this.success()) {
+ if (this.onComplete)
+ setTimeout(this.onComplete.bind(this), 10);
+Ajax.PeriodicalUpdater = Class.create();
+Ajax.PeriodicalUpdater.prototype = Object.extend(new Ajax.Base(), {
+ this.onComplete = this.options.onComplete;
+ this.frequency = (this.options.frequency || 2);
+ this.decay = (this.options.decay || 1);
+ this.updater = {};
+ this.container = container;
+ this.url = url;
+ this.start();
+ start: function() {
+ this.options.onComplete = this.updateComplete.bind(this);
+ this.onTimerEvent();
+ this.updater.options.onComplete = undefined;
+ clearTimeout(this.timer);
+ (this.onComplete || Prototype.emptyFunction).apply(this, arguments);
+ updateComplete: function(request) {
+ if (this.options.decay) {
+ this.decay = (request.responseText == this.lastText ?
+ this.decay * this.options.decay : 1);
+ this.lastText = request.responseText;
+ this.timer = setTimeout(this.onTimerEvent.bind(this),
+ this.decay * this.frequency * 1000);
+ this.updater = new Ajax.Updater(this.container, this.url, this.options);
+function $(element) {
+ if (arguments.length > 1) {
+ for (var i = 0, elements = [], length = arguments.length; i < length; i++)
+ elements.push($(arguments[i]));
+ return elements;
+ if (typeof element == 'string')
+ element = document.getElementById(element);
+ return Element.extend(element);
+if (Prototype.BrowserFeatures.XPath) {
+ document._getElementsByXPath = function(expression, parentElement) {
+ var results = [];
+ var query = document.evaluate(expression, $(parentElement) || document,
+ null, XPathResult.ORDERED_NODE_SNAPSHOT_TYPE, null);
+ for (var i = 0, length = query.snapshotLength; i < length; i++)
+ results.push(query.snapshotItem(i));
+ return results;
+document.getElementsByClassName = function(className, parentElement) {
+ if (Prototype.BrowserFeatures.XPath) {
+ var q = ".//*[contains(concat(' ', @class, ' '), ' " + className + " ')]";
+ return document._getElementsByXPath(q, parentElement);
+ } else {
+ var children = ($(parentElement) || document.body).getElementsByTagName('*');
+ var elements = [], child;
+ for (var i = 0, length = children.length; i < length; i++) {
+ child = children[i];
+ if (Element.hasClassName(child, className))
+ elements.push(Element.extend(child));
+ return elements;
+if (!window.Element)
+ var Element = new Object();
+Element.extend = function(element) {
+ if (!element || _nativeExtensions || element.nodeType == 3) return element;
+ if (!element._extended && element.tagName && element != window) {
+ var methods = Object.clone(Element.Methods), cache = Element.extend.cache;
+ if (element.tagName == 'FORM')
+ Object.extend(methods, Form.Methods);
+ if (['INPUT', 'TEXTAREA', 'SELECT'].include(element.tagName))
+ Object.extend(methods, Form.Element.Methods);
+ Object.extend(methods, Element.Methods.Simulated);
+ for (var property in methods) {
+ var value = methods[property];
+ if (typeof value == 'function' && !(property in element))
+ element[property] = cache.findOrStore(value);
+ element._extended = true;
+ return element;
+Element.extend.cache = {
+ findOrStore: function(value) {
+ return this[value] = this[value] || function() {
+ return value.apply(null, [this].concat($A(arguments)));
+Element.Methods = {
+ visible: function(element) {
+ return $(element).style.display != 'none';
+ toggle: function(element) {
+ element = $(element);
+ Element[Element.visible(element) ? 'hide' : 'show'](element);
+ return element;
+ hide: function(element) {
+ $(element).style.display = 'none';
+ return element;
+ show: function(element) {
+ $(element).style.display = '';
+ return element;
+ remove: function(element) {
+ element.parentNode.removeChild(element);
+ return element;
+ update: function(element, html) {
+ html = typeof html == 'undefined' ? '' : html.toString();
+ $(element).innerHTML = html.stripScripts();
+ setTimeout(function() {html.evalScripts()}, 10);
+ return element;
+ replace: function(element, html) {
+ if (element.outerHTML) {
+ element.outerHTML = html.stripScripts();
+ } else {
+ var range = element.ownerDocument.createRange();
+ range.selectNodeContents(element);
+ element.parentNode.replaceChild(
+ range.createContextualFragment(html.stripScripts()), element);
+ return element;
+ inspect: function(element) {
+ var result = '<' + element.tagName.toLowerCase();
+ $H({'id': 'id', 'className': 'class'}).each(function(pair) {
+ var property = pair.first(), attribute = pair.last();
+ var value = (element[property] || '').toString();
+ if (value) result += ' ' + attribute + '=' + value.inspect(true);
+ return result + '>';
+ recursivelyCollect: function(element, property) {
+ var elements = [];
+ while (element = element[property])
+ if (element.nodeType == 1)
+ elements.push(Element.extend(element));
+ return elements;
+ ancestors: function(element) {
+ return $(element).recursivelyCollect('parentNode');
+ descendants: function(element) {
+ return $A($(element).getElementsByTagName('*'));
+ immediateDescendants: function(element) {
+ if (!(element = $(element).firstChild)) return [];
+ while (element && element.nodeType != 1) element = element.nextSibling;
+ if (element) return [element].concat($(element).nextSiblings());
+ return [];
+ previousSiblings: function(element) {
+ return $(element).recursivelyCollect('previousSibling');
+ nextSiblings: function(element) {
+ return $(element).recursivelyCollect('nextSibling');
+ siblings: function(element) {
+ return element.previousSiblings().reverse().concat(element.nextSiblings());
+ match: function(element, selector) {
+ if (typeof selector == 'string')
+ selector = new Selector(selector);
+ return selector.match($(element));
+ up: function(element, expression, index) {
+ return Selector.findElement($(element).ancestors(), expression, index);
+ down: function(element, expression, index) {
+ return Selector.findElement($(element).descendants(), expression, index);
+ previous: function(element, expression, index) {
+ return Selector.findElement($(element).previousSiblings(), expression, index);
+ next: function(element, expression, index) {
+ return Selector.findElement($(element).nextSiblings(), expression, index);
+ getElementsBySelector: function() {
+ var args = $A(arguments), element = $(args.shift());
+ return Selector.findChildElements(element, args);
+ getElementsByClassName: function(element, className) {
+ return document.getElementsByClassName(className, element);
+ readAttribute: function(element, name) {
+ if (document.all && !window.opera) {
+ var t = Element._attributeTranslations;
+ if (t.values[name]) return t.values[name](element, name);
+ if (t.names[name]) name = t.names[name];
+ var attribute = element.attributes[name];
+ if(attribute) return attribute.nodeValue;
+ return element.getAttribute(name);
+ getHeight: function(element) {
+ return $(element).getDimensions().height;
+ getWidth: function(element) {
+ return $(element).getDimensions().width;
+ classNames: function(element) {
+ return new Element.ClassNames(element);
+ hasClassName: function(element, className) {
+ if (!(element = $(element))) return;
+ var elementClassName = element.className;
+ if (elementClassName.length == 0) return false;
+ if (elementClassName == className ||
+ elementClassName.match(new RegExp("(^|\\s)" + className + "(\\s|$)")))
+ return true;
+ return false;
+ addClassName: function(element, className) {
+ Element.classNames(element).add(className);
+ return element;
+ removeClassName: function(element, className) {
+ Element.classNames(element).remove(className);
+ return element;
+ toggleClassName: function(element, className) {
+ Element.classNames(element)[element.hasClassName(className) ? 'remove' : 'add'](className);
+ return element;
+ observe: function() {
+ Event.observe.apply(Event, arguments);
+ return $A(arguments).first();
+ stopObserving: function() {
+ Event.stopObserving.apply(Event, arguments);
+ // removes whitespace-only text node children
+ cleanWhitespace: function(element) {
+ var node = element.firstChild;
+ while (node) {
+ var nextNode = node.nextSibling;
+ if (node.nodeType == 3 && !/\S/.test(node.nodeValue))
+ element.removeChild(node);
+ node = nextNode;
+ return element;
+ empty: function(element) {
+ return $(element).innerHTML.match(/^\s*$/);
+ descendantOf: function(element, ancestor) {
+ element = $(element), ancestor = $(ancestor);
+ while (element = element.parentNode)
+ if (element == ancestor) return true;
+ return false;
+ scrollTo: function(element) {
+ var pos = Position.cumulativeOffset(element);
+ window.scrollTo(pos[0], pos[1]);
+ return element;
+ getStyle: function(element, style) {
+ if (['float','cssFloat'].include(style))
+ style = (typeof element.style.styleFloat != 'undefined' ? 'styleFloat' : 'cssFloat');
+ style = style.camelize();
+ var value = element.style[style];
+ if (!value) {
+ if (document.defaultView && document.defaultView.getComputedStyle) {
+ var css = document.defaultView.getComputedStyle(element, null);
+ value = css ? css[style] : null;
+ } else if (element.currentStyle) {
+ value = element.currentStyle[style];
+ if((value == 'auto') && ['width','height'].include(style) && (element.getStyle('display') != 'none'))
+ value = element['offset'+style.capitalize()] + 'px';
+ if (window.opera && ['left', 'top', 'right', 'bottom'].include(style))
+ if (Element.getStyle(element, 'position') == 'static') value = 'auto';
+ if(style == 'opacity') {
+ if(value) return parseFloat(value);
+ if(value = (element.getStyle('filter') || '').match(/alpha\(opacity=(.*)\)/))
+ if(value[1]) return parseFloat(value[1]) / 100;
+ return 1.0;
+ return value == 'auto' ? null : value;
+ setStyle: function(element, style) {
+ for (var name in style) {
+ var value = style[name];
+ if(name == 'opacity') {
+ if (value == 1) {
+ value = (/Gecko/.test(navigator.userAgent) &&
+ !/Konqueror|Safari|KHTML/.test(navigator.userAgent)) ? 0.999999 : 1.0;
+ if(/MSIE/.test(navigator.userAgent) && !window.opera)
+ element.style.filter = element.getStyle('filter').replace(/alpha\([^\)]*\)/gi,'');
+ } else if(value === '') {
+ } else {
+ if(value < 0.00001) value = 0;
+ element.style.filter = element.getStyle('filter').replace(/alpha\([^\)]*\)/gi,'') +
+ 'alpha(opacity='+value*100+')';
+ } else if(['float','cssFloat'].include(name)) name = (typeof element.style.styleFloat != 'undefined') ? 'styleFloat' : 'cssFloat';
+ element.style[name.camelize()] = value;
+ return element;
+ getDimensions: function(element) {
+ var display = $(element).getStyle('display');
+ if (display != 'none' && display != null) // Safari bug
+ return {width: element.offsetWidth, height: element.offsetHeight};
+ // All *Width and *Height properties give 0 on elements with display none,
+ // so enable the element temporarily
+ var els = element.style;
+ var originalVisibility = els.visibility;
+ var originalPosition = els.position;
+ var originalDisplay = els.display;
+ els.visibility = 'hidden';
+ els.position = 'absolute';
+ els.display = 'block';
+ var originalWidth = element.clientWidth;
+ var originalHeight = element.clientHeight;
+ els.display = originalDisplay;
+ els.position = originalPosition;
+ els.visibility = originalVisibility;
+ return {width: originalWidth, height: originalHeight};
+ makePositioned: function(element) {
+ var pos = Element.getStyle(element, 'position');
+ if (pos == 'static' || !pos) {
+ element._madePositioned = true;
+ element.style.position = 'relative';
+ // Opera returns the offset relative to the positioning context, when an
+ // element is position relative but top and left have not been defined
+ if (window.opera) {
+ element.style.top = 0;
+ element.style.left = 0;
+ return element;
+ undoPositioned: function(element) {
+ if (element._madePositioned) {
+ element._madePositioned = undefined;
+ element.style.bottom =
+ element.style.right = '';
+ return element;
+ makeClipping: function(element) {
+ if (element._overflow) return element;
+ element._overflow = element.style.overflow || 'auto';
+ if ((Element.getStyle(element, 'overflow') || 'visible') != 'hidden')
+ element.style.overflow = 'hidden';
+ return element;
+ undoClipping: function(element) {
+ if (!element._overflow) return element;
+ element.style.overflow = element._overflow == 'auto' ? '' : element._overflow;
+ element._overflow = null;
+ return element;
+Object.extend(Element.Methods, {childOf: Element.Methods.descendantOf});
+Element._attributeTranslations = {};
+Element._attributeTranslations.names = {
+ colspan: "colSpan",
+ rowspan: "rowSpan",
+ valign: "vAlign",
+ datetime: "dateTime",
+ accesskey: "accessKey",
+ tabindex: "tabIndex",
+ enctype: "encType",
+ maxlength: "maxLength",
+ readonly: "readOnly",
+ longdesc: "longDesc"
+Element._attributeTranslations.values = {
+ _getAttr: function(element, attribute) {
+ return element.getAttribute(attribute, 2);
+ _flag: function(element, attribute) {
+ return $(element).hasAttribute(attribute) ? attribute : null;
+ style: function(element) {
+ return element.style.cssText.toLowerCase();
+ title: function(element) {
+ var node = element.getAttributeNode('title');
+ return node.specified ? node.nodeValue : null;
+Object.extend(Element._attributeTranslations.values, {
+ href: Element._attributeTranslations.values._getAttr,
+ src: Element._attributeTranslations.values._getAttr,
+ disabled: Element._attributeTranslations.values._flag,
+ checked: Element._attributeTranslations.values._flag,
+ readonly: Element._attributeTranslations.values._flag,
+ multiple: Element._attributeTranslations.values._flag
+Element.Methods.Simulated = {
+ hasAttribute: function(element, attribute) {
+ attribute = t.names[attribute] || attribute;
+ return $(element).getAttributeNode(attribute).specified;
+// IE is missing .innerHTML support for TABLE-related elements
+if (document.all && !window.opera){
+ Element.Methods.update = function(element, html) {
+ var tagName = element.tagName.toUpperCase();
+ if (['THEAD','TBODY','TR','TD'].include(tagName)) {
+ switch (tagName) {
+ case 'THEAD':
+ case 'TBODY':
+ div.innerHTML = '<table><tbody>' + html.stripScripts() + '</tbody></table>';
+ depth = 2;
+ break;
+ case 'TR':
+ div.innerHTML = '<table><tbody><tr>' + html.stripScripts() + '</tr></tbody></table>';
+ depth = 3;
+ break;
+ case 'TD':
+ div.innerHTML = '<table><tbody><tr><td>' + html.stripScripts() + '</td></tr></tbody></table>';
+ depth = 4;
+ $A(element.childNodes).each(function(node){
+ depth.times(function(){ div = div.firstChild });
+ $A(div.childNodes).each(
+ function(node){ element.appendChild(node) });
+ } else {
+ element.innerHTML = html.stripScripts();
+ return element;
+Object.extend(Element, Element.Methods);
+var _nativeExtensions = false;
+if(/Konqueror|Safari|KHTML/.test(navigator.userAgent))
+ ['', 'Form', 'Input', 'TextArea', 'Select'].each(function(tag) {
+ var className = 'HTML' + tag + 'Element';
+ if(window[className]) return;
+ var klass = window[className] = {};
+ klass.prototype = document.createElement(tag ? tag.toLowerCase() : 'div').__proto__;
+Element.addMethods = function(methods) {
+ Object.extend(Element.Methods, methods || {});
+ function copy(methods, destination, onlyIfAbsent) {
+ onlyIfAbsent = onlyIfAbsent || false;
+ var cache = Element.extend.cache;
+ if (!onlyIfAbsent || !(property in destination))
+ destination[property] = cache.findOrStore(value);
+ if (typeof HTMLElement != 'undefined') {
+ copy(Element.Methods, HTMLElement.prototype);
+ copy(Element.Methods.Simulated, HTMLElement.prototype, true);
+ copy(Form.Methods, HTMLFormElement.prototype);
+ [HTMLInputElement, HTMLTextAreaElement, HTMLSelectElement].each(function(klass) {
+ copy(Form.Element.Methods, klass.prototype);
+ _nativeExtensions = true;
+var Toggle = new Object();
+Toggle.display = Element.toggle;
+Abstract.Insertion = function(adjacency) {
+ this.adjacency = adjacency;
+Abstract.Insertion.prototype = {
+ initialize: function(element, content) {
+ this.element = $(element);
+ this.content = content.stripScripts();
+ if (this.adjacency && this.element.insertAdjacentHTML) {
+ try {
+ this.element.insertAdjacentHTML(this.adjacency, this.content);
+ } catch (e) {
+ var tagName = this.element.tagName.toUpperCase();
+ if (['TBODY', 'TR'].include(tagName)) {
+ this.insertContent(this.contentFromAnonymousTable());
+ } else {
+ throw e;
+ } else {
+ this.range = this.element.ownerDocument.createRange();
+ if (this.initializeRange) this.initializeRange();
+ this.insertContent([this.range.createContextualFragment(this.content)]);
+ setTimeout(function() {content.evalScripts()}, 10);
+ contentFromAnonymousTable: function() {
+ div.innerHTML = '<table><tbody>' + this.content + '</tbody></table>';
+ return $A(div.childNodes[0].childNodes[0].childNodes);
+var Insertion = new Object();
+Insertion.Before = Class.create();
+Insertion.Before.prototype = Object.extend(new Abstract.Insertion('beforeBegin'), {
+ initializeRange: function() {
+ this.range.setStartBefore(this.element);
+ insertContent: function(fragments) {
+ fragments.each((function(fragment) {
+ this.element.parentNode.insertBefore(fragment, this.element);
+ }).bind(this));
+Insertion.Top = Class.create();
+Insertion.Top.prototype = Object.extend(new Abstract.Insertion('afterBegin'), {
+ this.range.selectNodeContents(this.element);
+ this.range.collapse(true);
+ fragments.reverse(false).each((function(fragment) {
+ this.element.insertBefore(fragment, this.element.firstChild);
+ }).bind(this));
+Insertion.Bottom = Class.create();
+Insertion.Bottom.prototype = Object.extend(new Abstract.Insertion('beforeEnd'), {
+ this.range.collapse(this.element);
+ this.element.appendChild(fragment);
+ }).bind(this));
+Insertion.After = Class.create();
+Insertion.After.prototype = Object.extend(new Abstract.Insertion('afterEnd'), {
+ this.range.setStartAfter(this.element);
+ this.element.nextSibling);
+ }).bind(this));
+Element.ClassNames = Class.create();
+Element.ClassNames.prototype = {
+ initialize: function(element) {
+ this.element.className.split(/\s+/).select(function(name) {
+ return name.length > 0;
+ })._each(iterator);
+ set: function(className) {
+ this.element.className = className;
+ add: function(classNameToAdd) {
+ if (this.include(classNameToAdd)) return;
+ this.set($A(this).concat(classNameToAdd).join(' '));
+ remove: function(classNameToRemove) {
+ if (!this.include(classNameToRemove)) return;
+ this.set($A(this).without(classNameToRemove).join(' '));
+ toString: function() {
+ return $A(this).join(' ');
+Object.extend(Element.ClassNames.prototype, Enumerable);
+var Selector = Class.create();
+Selector.prototype = {
+ initialize: function(expression) {
+ this.params = {classNames: []};
+ this.expression = expression.toString().strip();
+ this.parseExpression();
+ this.compileMatcher();
+ parseExpression: function() {
+ function abort(message) { throw 'Parse error in selector: ' + message; }
+ if (this.expression == '') abort('empty expression');
+ var params = this.params, expr = this.expression, match, modifier, clause, rest;
+ while (match = expr.match(/^(.*)\[([a-z0-9_:-]+?)(?:([~\|!]?=)(?:"([^"]*)"|([^\]\s]*)))?\]$/i)) {
+ params.attributes = params.attributes || [];
+ params.attributes.push({name: match[2], operator: match[3], value: match[4] || match[5] || ''});
+ expr = match[1];
+ if (expr == '*') return this.params.wildcard = true;
+ while (match = expr.match(/^([^a-z0-9_-])?([a-z0-9_-]+)(.*)/i)) {
+ modifier = match[1], clause = match[2], rest = match[3];
+ switch (modifier) {
+ case '#': params.id = clause; break;
+ case '.': params.classNames.push(clause); break;
+ case '':
+ case undefined: params.tagName = clause.toUpperCase(); break;
+ default: abort(expr.inspect());
+ expr = rest;
+ if (expr.length > 0) abort(expr.inspect());
+ buildMatchExpression: function() {
+ var params = this.params, conditions = [], clause;
+ if (params.wildcard)
+ conditions.push('true');
+ if (clause = params.id)
+ conditions.push('element.readAttribute("id") == ' + clause.inspect());
+ if (clause = params.tagName)
+ conditions.push('element.tagName.toUpperCase() == ' + clause.inspect());
+ if ((clause = params.classNames).length > 0)
+ for (var i = 0, length = clause.length; i < length; i++)
+ conditions.push('element.hasClassName(' + clause[i].inspect() + ')');
+ if (clause = params.attributes) {
+ clause.each(function(attribute) {
+ var value = 'element.readAttribute(' + attribute.name.inspect() + ')';
+ var splitValueBy = function(delimiter) {
+ return value + ' && ' + value + '.split(' + delimiter.inspect() + ')';
+ switch (attribute.operator) {
+ case '=': conditions.push(value + ' == ' + attribute.value.inspect()); break;
+ case '~=': conditions.push(splitValueBy(' ') + '.include(' + attribute.value.inspect() + ')'); break;
+ case '|=': conditions.push(
+ splitValueBy('-') + '.first().toUpperCase() == ' + attribute.value.toUpperCase().inspect()
+ ); break;
+ case '!=': conditions.push(value + ' != ' + attribute.value.inspect()); break;
+ case '':
+ case undefined: conditions.push('element.hasAttribute(' + attribute.name.inspect() + ')'); break;
+ default: throw 'Unknown operator ' + attribute.operator + ' in selector';
+ return conditions.join(' && ');
+ compileMatcher: function() {
+ this.match = new Function('element', 'if (!element.tagName) return false; element = $(element); return ' + this.buildMatchExpression());
+ findElements: function(scope) {
+ var element;
+ if (element = $(this.params.id))
+ if (this.match(element))
+ if (!scope || Element.childOf(element, scope))
+ return [element];
+ scope = (scope || document).getElementsByTagName(this.params.tagName || '*');
+ var results = [];
+ for (var i = 0, length = scope.length; i < length; i++)
+ if (this.match(element = scope[i]))
+ results.push(Element.extend(element));
+ return results;
+ return this.expression;
+Object.extend(Selector, {
+ matchElements: function(elements, expression) {
+ var selector = new Selector(expression);
+ return elements.select(selector.match.bind(selector)).map(Element.extend);
+ findElement: function(elements, expression, index) {
+ if (typeof expression == 'number') index = expression, expression = false;
+ return Selector.matchElements(elements, expression || '*')[index || 0];
+ findChildElements: function(element, expressions) {
+ return expressions.map(function(expression) {
+ return expression.match(/[^\s"]+(?:"[^"]*"[^\s"]+)*/g).inject([null], function(results, expr) {
+ var selector = new Selector(expr);
+ return results.inject([], function(elements, result) {
+ return elements.concat(selector.findElements(result || element));
+ }).flatten();
+function $$() {
+ return Selector.findChildElements(document, $A(arguments));
+var Form = {
+ reset: function(form) {
+ $(form).reset();
+ return form;
+ serializeElements: function(elements, getHash) {
+ var data = elements.inject({}, function(result, element) {
+ if (!element.disabled && element.name) {
+ var key = element.name, value = $(element).getValue();
+ if (value != undefined) {
+ if (result[key]) {
+ if (result[key].constructor != Array) result[key] = [result[key]];
+ result[key].push(value);
+ else result[key] = value;
+ return result;
+ return getHash ? data : Hash.toQueryString(data);
+Form.Methods = {
+ serialize: function(form, getHash) {
+ return Form.serializeElements(Form.getElements(form), getHash);
+ getElements: function(form) {
+ return $A($(form).getElementsByTagName('*')).inject([],
+ function(elements, child) {
+ if (Form.Element.Serializers[child.tagName.toLowerCase()])
+ return elements;
+ getInputs: function(form, typeName, name) {
+ form = $(form);
+ var inputs = form.getElementsByTagName('input');
+ if (!typeName && !name) return $A(inputs).map(Element.extend);
+ for (var i = 0, matchingInputs = [], length = inputs.length; i < length; i++) {
+ var input = inputs[i];
+ if ((typeName && input.type != typeName) || (name && input.name != name))
+ continue;
+ matchingInputs.push(Element.extend(input));
+ return matchingInputs;
+ disable: function(form) {
+ form = $(form);
+ form.getElements().each(function(element) {
+ element.blur();
+ element.disabled = 'true';
+ return form;
+ enable: function(form) {
+ form = $(form);
+ element.disabled = '';
+ return form;
+ findFirstElement: function(form) {
+ return $(form).getElements().find(function(element) {
+ return element.type != 'hidden' && !element.disabled &&
+ ['input', 'select', 'textarea'].include(element.tagName.toLowerCase());
+ focusFirstElement: function(form) {
+ form = $(form);
+ form.findFirstElement().activate();
+ return form;
+Object.extend(Form, Form.Methods);
+Form.Element = {
+ focus: function(element) {
+ $(element).focus();
+ return element;
+ select: function(element) {
+ $(element).select();
+ return element;
+Form.Element.Methods = {
+ serialize: function(element) {
+ var value = element.getValue();
+ var pair = {};
+ pair[element.name] = value;
+ return Hash.toQueryString(pair);
+ return '';
+ getValue: function(element) {
+ var method = element.tagName.toLowerCase();
+ return Form.Element.Serializers[method](element);
+ clear: function(element) {
+ $(element).value = '';
+ return element;
+ present: function(element) {
+ return $(element).value != '';
+ activate: function(element) {
+ element.focus();
+ if (element.select && ( element.tagName.toLowerCase() != 'input' ||
+ !['button', 'reset', 'submit'].include(element.type) ) )
+ element.select();
+ return element;
+ disable: function(element) {
+ element.disabled = true;
+ return element;
+ enable: function(element) {
+ element.blur();
+ element.disabled = false;
+ return element;
+Object.extend(Form.Element, Form.Element.Methods);
+var Field = Form.Element;
+var $F = Form.Element.getValue;
+Form.Element.Serializers = {
+ input: function(element) {
+ switch (element.type.toLowerCase()) {
+ case 'checkbox':
+ case 'radio':
+ return Form.Element.Serializers.inputSelector(element);
+ default:
+ return Form.Element.Serializers.textarea(element);
+ inputSelector: function(element) {
+ return element.checked ? element.value : null;
+ textarea: function(element) {
+ return element.value;
+ return this[element.type == 'select-one' ?
+ 'selectOne' : 'selectMany'](element);
+ selectOne: function(element) {
+ var index = element.selectedIndex;
+ return index >= 0 ? this.optionValue(element.options[index]) : null;
+ selectMany: function(element) {
+ var values, length = element.length;
+ if (!length) return null;
+ for (var i = 0, values = []; i < length; i++) {
+ var opt = element.options[i];
+ if (opt.selected) values.push(this.optionValue(opt));
+ return values;
+ optionValue: function(opt) {
+ // extend element because hasAttribute may not be native
+ return Element.extend(opt).hasAttribute('value') ? opt.value : opt.text;
+Abstract.TimedObserver = function() {}
+Abstract.TimedObserver.prototype = {
+ initialize: function(element, frequency, callback) {
+ this.lastValue = this.getValue();
+ setInterval(this.onTimerEvent.bind(this), this.frequency * 1000);
+ var value = this.getValue();
+ var changed = ('string' == typeof this.lastValue && 'string' == typeof value
+ ? this.lastValue != value : String(this.lastValue) != String(value));
+ if (changed) {
+ this.callback(this.element, value);
+ this.lastValue = value;
+Form.Element.Observer = Class.create();
+Form.Element.Observer.prototype = Object.extend(new Abstract.TimedObserver(), {
+ getValue: function() {
+ return Form.Element.getValue(this.element);
+Form.Observer = Class.create();
+Form.Observer.prototype = Object.extend(new Abstract.TimedObserver(), {
+ return Form.serialize(this.element);
+Abstract.EventObserver = function() {}
+Abstract.EventObserver.prototype = {
+ initialize: function(element, callback) {
+ if (this.element.tagName.toLowerCase() == 'form')
+ this.registerFormCallbacks();
+ else
+ this.registerCallback(this.element);
+ onElementEvent: function() {
+ if (this.lastValue != value) {
+ registerFormCallbacks: function() {
+ Form.getElements(this.element).each(this.registerCallback.bind(this));
+ registerCallback: function(element) {
+ if (element.type) {
+ case 'checkbox':
+ case 'radio':
+ Event.observe(element, 'click', this.onElementEvent.bind(this));
+ break;
+ default:
+ Event.observe(element, 'change', this.onElementEvent.bind(this));
+ break;
+Form.Element.EventObserver = Class.create();
+Form.Element.EventObserver.prototype = Object.extend(new Abstract.EventObserver(), {
+Form.EventObserver = Class.create();
+Form.EventObserver.prototype = Object.extend(new Abstract.EventObserver(), {
+if (!window.Event) {
+ var Event = new Object();
+Object.extend(Event, {
+ KEY_BACKSPACE: 8,
+ KEY_TAB: 9,
+ KEY_RETURN: 13,
+ KEY_ESC: 27,
+ KEY_LEFT: 37,
+ KEY_UP: 38,
+ KEY_RIGHT: 39,
+ KEY_DOWN: 40,
+ KEY_DELETE: 46,
+ KEY_HOME: 36,
+ KEY_END: 35,
+ KEY_PAGEUP: 33,
+ KEY_PAGEDOWN: 34,
+ element: function(event) {
+ return event.target || event.srcElement;
+ isLeftClick: function(event) {
+ return (((event.which) && (event.which == 1)) ||
+ ((event.button) && (event.button == 1)));
+ pointerX: function(event) {
+ return event.pageX || (event.clientX +
+ (document.documentElement.scrollLeft || document.body.scrollLeft));
+ pointerY: function(event) {
+ return event.pageY || (event.clientY +
+ (document.documentElement.scrollTop || document.body.scrollTop));
+ stop: function(event) {
+ if (event.preventDefault) {
+ event.preventDefault();
+ event.stopPropagation();
+ } else {
+ event.returnValue = false;
+ event.cancelBubble = true;
+ // find the first node with the given tagName, starting from the
+ // node the event was triggered on; traverses the DOM upwards
+ findElement: function(event, tagName) {
+ var element = Event.element(event);
+ while (element.parentNode && (!element.tagName ||
+ (element.tagName.toUpperCase() != tagName.toUpperCase())))
+ element = element.parentNode;
+ return element;
+ observers: false,
+ _observeAndCache: function(element, name, observer, useCapture) {
+ if (!this.observers) this.observers = [];
+ if (element.addEventListener) {
+ this.observers.push([element, name, observer, useCapture]);
+ element.addEventListener(name, observer, useCapture);
+ } else if (element.attachEvent) {
+ element.attachEvent('on' + name, observer);
+ unloadCache: function() {
+ if (!Event.observers) return;
+ for (var i = 0, length = Event.observers.length; i < length; i++) {
+ Event.stopObserving.apply(this, Event.observers[i]);
+ Event.observers[i][0] = null;
+ Event.observers = false;
+ observe: function(element, name, observer, useCapture) {
+ useCapture = useCapture || false;
+ if (name == 'keypress' &&
+ (navigator.appVersion.match(/Konqueror|Safari|KHTML/)
+ || element.attachEvent))
+ name = 'keydown';
+ Event._observeAndCache(element, name, observer, useCapture);
+ stopObserving: function(element, name, observer, useCapture) {
+ || element.detachEvent))
+ name = 'keydown';
+ if (element.removeEventListener) {
+ element.removeEventListener(name, observer, useCapture);
+ } else if (element.detachEvent) {
+ try {
+ element.detachEvent('on' + name, observer);
+ } catch (e) {}
+/* prevent memory leaks in IE */
+if (navigator.appVersion.match(/\bMSIE\b/))
+ Event.observe(window, 'unload', Event.unloadCache, false);
+var Position = {
+ // set to true if needed, warning: firefox performance problems
+ // NOT neeeded for page scrolling, only if draggable contained in
+ // scrollable elements
+ includeScrollOffsets: false,
+ // must be called before calling withinIncludingScrolloffset, every time the
+ // page is scrolled
+ prepare: function() {
+ this.deltaX = window.pageXOffset
+ || document.documentElement.scrollLeft
+ || document.body.scrollLeft
+ || 0;
+ this.deltaY = window.pageYOffset
+ || document.documentElement.scrollTop
+ || document.body.scrollTop
+ || 0;
+ realOffset: function(element) {
+ var valueT = 0, valueL = 0;
+ do {
+ valueT += element.scrollTop || 0;
+ valueL += element.scrollLeft || 0;
+ } while (element);
+ return [valueL, valueT];
+ cumulativeOffset: function(element) {
+ do {
+ valueT += element.offsetTop || 0;
+ valueL += element.offsetLeft || 0;
+ element = element.offsetParent;
+ positionedOffset: function(element) {
+ do {
+ if (element) {
+ if(element.tagName=='BODY') break;
+ var p = Element.getStyle(element, 'position');
+ if (p == 'relative' || p == 'absolute') break;
+ offsetParent: function(element) {
+ if (element.offsetParent) return element.offsetParent;
+ if (element == document.body) return element;
+ while ((element = element.parentNode) && element != document.body)
+ if (Element.getStyle(element, 'position') != 'static')
+ return element;
+ return document.body;
+ // caches x/y coordinate pair to use with overlap
+ within: function(element, x, y) {
+ if (this.includeScrollOffsets)
+ return this.withinIncludingScrolloffsets(element, x, y);
+ this.xcomp = x;
+ this.ycomp = y;
+ this.offset = this.cumulativeOffset(element);
+ return (y >= this.offset[1] &&
+ y < this.offset[1] + element.offsetHeight &&
+ x >= this.offset[0] &&
+ x < this.offset[0] + element.offsetWidth);
+ withinIncludingScrolloffsets: function(element, x, y) {
+ var offsetcache = this.realOffset(element);
+ this.xcomp = x + offsetcache[0] - this.deltaX;
+ this.ycomp = y + offsetcache[1] - this.deltaY;
+ return (this.ycomp >= this.offset[1] &&
+ this.ycomp < this.offset[1] + element.offsetHeight &&
+ this.xcomp >= this.offset[0] &&
+ this.xcomp < this.offset[0] + element.offsetWidth);
+ // within must be called directly before
+ overlap: function(mode, element) {
+ if (!mode) return 0;
+ if (mode == 'vertical')
+ return ((this.offset[1] + element.offsetHeight) - this.ycomp) /
+ element.offsetHeight;
+ if (mode == 'horizontal')
+ return ((this.offset[0] + element.offsetWidth) - this.xcomp) /
+ element.offsetWidth;
+ page: function(forElement) {
+ var element = forElement;
+ do {
+ // Safari fix
+ if (element.offsetParent==document.body)
+ if (Element.getStyle(element,'position')=='absolute') break;
+ } while (element = element.offsetParent);
+ element = forElement;
+ do {
+ if (!window.opera || element.tagName=='BODY') {
+ valueT -= element.scrollTop || 0;
+ valueL -= element.scrollLeft || 0;
+ } while (element = element.parentNode);
+ clone: function(source, target) {
+ var options = Object.extend({
+ setLeft: true,
+ setTop: true,
+ setWidth: true,
+ setHeight: true,
+ offsetTop: 0,
+ offsetLeft: 0
+ }, arguments[2] || {})
+ // find page position of source
+ source = $(source);
+ var p = Position.page(source);
+ // find coordinate system to use
+ target = $(target);
+ var delta = [0, 0];
+ var parent = null;
+ // delta [0,0] will do fine with position: fixed elements,
+ // position:absolute needs offsetParent deltas
+ if (Element.getStyle(target,'position') == 'absolute') {
+ parent = Position.offsetParent(target);
+ delta = Position.page(parent);
+ // correct by body offsets (fixes Safari)
+ if (parent == document.body) {
+ delta[0] -= document.body.offsetLeft;
+ delta[1] -= document.body.offsetTop;
+ // set position
+ if(options.setLeft) target.style.left = (p[0] - delta[0] + options.offsetLeft) + 'px';
+ if(options.setTop) target.style.top = (p[1] - delta[1] + options.offsetTop) + 'px';
+ if(options.setWidth) target.style.width = source.offsetWidth + 'px';
+ if(options.setHeight) target.style.height = source.offsetHeight + 'px';
+ absolutize: function(element) {
+ if (element.style.position == 'absolute') return;
+ Position.prepare();
+ var offsets = Position.positionedOffset(element);
+ var top = offsets[1];
+ var left = offsets[0];
+ var width = element.clientWidth;
+ var height = element.clientHeight;
+ element._originalLeft = left - parseFloat(element.style.left || 0);
+ element._originalTop = top - parseFloat(element.style.top || 0);
+ element._originalWidth = element.style.width;
+ element._originalHeight = element.style.height;
+ element.style.position = 'absolute';
+ element.style.top = top + 'px';
+ element.style.left = left + 'px';
+ element.style.width = width + 'px';
+ element.style.height = height + 'px';
+ relativize: function(element) {
+ if (element.style.position == 'relative') return;
+ var top = parseFloat(element.style.top || 0) - (element._originalTop || 0);
+ var left = parseFloat(element.style.left || 0) - (element._originalLeft || 0);
+ element.style.height = element._originalHeight;
+ element.style.width = element._originalWidth;
+// Safari returns margins on body which is incorrect if the child is absolutely
+// positioned. For performance reasons, redefine Position.cumulativeOffset for
+// KHTML/WebKit only.
+if (/Konqueror|Safari|KHTML/.test(navigator.userAgent)) {
+ Position.cumulativeOffset = function(element) {
+ do {
+ if (element.offsetParent == document.body)
+ if (Element.getStyle(element, 'position') == 'absolute') break;
+Element.addMethods();// script.aculo.us builder.js v1.7.0, Fri Jan 19 19:16:36 CET 2007
+// Copyright (c) 2005, 2006 Thomas Fuchs (http://script.aculo.us, http://mir.aculo.us)
+// script.aculo.us is freely distributable under the terms of an MIT-style license.
+// For details, see the script.aculo.us web site: http://script.aculo.us/
+var Builder = {
+ NODEMAP: {
+ AREA: 'map',
+ CAPTION: 'table',
+ COL: 'table',
+ COLGROUP: 'table',
+ LEGEND: 'fieldset',
+ OPTGROUP: 'select',
+ OPTION: 'select',
+ PARAM: 'object',
+ TBODY: 'table',
+ TD: 'table',
+ TFOOT: 'table',
+ TH: 'table',
+ THEAD: 'table',
+ TR: 'table'
+ // note: For Firefox < 1.5, OPTION and OPTGROUP tags are currently broken,
+ // due to a Firefox bug
+ node: function(elementName) {
+ elementName = elementName.toUpperCase();
+ // try innerHTML approach
+ var parentTag = this.NODEMAP[elementName] || 'div';
+ var parentElement = document.createElement(parentTag);
+ try { // prevent IE "feature": http://dev.rubyonrails.org/ticket/2707
+ parentElement.innerHTML = "<" + elementName + "></" + elementName + ">";
+ } catch(e) {}
+ var element = parentElement.firstChild || null;
+ // see if browser added wrapping tags
+ if(element && (element.tagName.toUpperCase() != elementName))
+ element = element.getElementsByTagName(elementName)[0];
+ // fallback to createElement approach
+ if(!element) element = document.createElement(elementName);
+ // abort if nothing could be created
+ if(!element) return;
+ // attributes (or text)
+ if(arguments[1])
+ if(this._isStringOrNumber(arguments[1]) ||
+ (arguments[1] instanceof Array)) {
+ this._children(element, arguments[1]);
+ } else {
+ var attrs = this._attributes(arguments[1]);
+ if(attrs.length) {
+ parentElement.innerHTML = "<" +elementName + " " +
+ attrs + "></" + elementName + ">";
+ } catch(e) {}
+ element = parentElement.firstChild || null;
+ // workaround firefox 1.0.X bug
+ if(!element) {
+ element = document.createElement(elementName);
+ for(attr in arguments[1])
+ element[attr == 'class' ? 'className' : attr] = arguments[1][attr];
+ if(element.tagName.toUpperCase() != elementName)
+ element = parentElement.getElementsByTagName(elementName)[0];
+ // text, or array of children
+ if(arguments[2])
+ this._children(element, arguments[2]);
+ return element;
+ _text: function(text) {
+ return document.createTextNode(text);
+ ATTR_MAP: {
+ 'className': 'class',
+ 'htmlFor': 'for'
+ _attributes: function(attributes) {
+ var attrs = [];
+ for(attribute in attributes)
+ attrs.push((attribute in this.ATTR_MAP ? this.ATTR_MAP[attribute] : attribute) +
+ '="' + attributes[attribute].toString().escapeHTML() + '"');
+ return attrs.join(" ");
+ _children: function(element, children) {
+ if(typeof children=='object') { // array can hold nodes and text
+ children.flatten().each( function(e) {
+ if(typeof e=='object')
+ element.appendChild(e)
+ else
+ if(Builder._isStringOrNumber(e))
+ element.appendChild(Builder._text(e));
+ } else
+ if(Builder._isStringOrNumber(children))
+ element.appendChild(Builder._text(children));
+ _isStringOrNumber: function(param) {
+ return(typeof param=='string' || typeof param=='number');
+ build: function(html) {
+ var element = this.node('div');
+ $(element).update(html.strip());
+ return element.down();
+ dump: function(scope) {
+ if(typeof scope != 'object' && typeof scope != 'function') scope = window; //global scope
+ var tags = ("A ABBR ACRONYM ADDRESS APPLET AREA B BASE BASEFONT BDO BIG BLOCKQUOTE BODY " +
+ "BR BUTTON CAPTION CENTER CITE CODE COL COLGROUP DD DEL DFN DIR DIV DL DT EM FIELDSET " +
+ "FONT FORM FRAME FRAMESET H1 H2 H3 H4 H5 H6 HEAD HR HTML I IFRAME IMG INPUT INS ISINDEX "+
+ "KBD LABEL LEGEND LI LINK MAP MENU META NOFRAMES NOSCRIPT OBJECT OL OPTGROUP OPTION P "+
+ "PARAM PRE Q S SAMP SCRIPT SELECT SMALL SPAN STRIKE STRONG STYLE SUB SUP TABLE TBODY TD "+
+ "TEXTAREA TFOOT TH THEAD TITLE TR TT U UL VAR").split(/\s+/);
+ tags.each( function(tag){
+ scope[tag] = function() {
+ return Builder.node.apply(Builder, [tag].concat($A(arguments)));
+// script.aculo.us effects.js v1.7.0, Fri Jan 19 19:16:36 CET 2007
+// Contributors:
+// Justin Palmer (http://encytemedia.com/)
+// Mark Pilgrim (http://diveintomark.org/)
+// Martin Bialasinki
+// converts rgb() and #xxx to #xxxxxx format,
+// returns self (or first argument) if not convertable
+String.prototype.parseColor = function() {
+ var color = '#';
+ if(this.slice(0,4) == 'rgb(') {
+ var cols = this.slice(4,this.length-1).split(',');
+ var i=0; do { color += parseInt(cols[i]).toColorPart() } while (++i<3);
+ } else {
+ if(this.slice(0,1) == '#') {
+ if(this.length==4) for(var i=1;i<4;i++) color += (this.charAt(i) + this.charAt(i)).toLowerCase();
+ if(this.length==7) color = this.toLowerCase();
+ return(color.length==7 ? color : (arguments[0] || this));
+Element.collectTextNodes = function(element) {
+ return $A($(element).childNodes).collect( function(node) {
+ return (node.nodeType==3 ? node.nodeValue :
+ (node.hasChildNodes() ? Element.collectTextNodes(node) : ''));
+ }).flatten().join('');
+Element.collectTextNodesIgnoreClass = function(element, className) {
+ ((node.hasChildNodes() && !Element.hasClassName(node,className)) ?
+ Element.collectTextNodesIgnoreClass(node, className) : ''));
+Element.setContentZoom = function(element, percent) {
+ element.setStyle({fontSize: (percent/100) + 'em'});
+ if(navigator.appVersion.indexOf('AppleWebKit')>0) window.scrollBy(0,0);
+ return element;
+Element.getOpacity = function(element){
+ return $(element).getStyle('opacity');
+Element.setOpacity = function(element, value){
+ return $(element).setStyle({opacity:value});
+Element.getInlineOpacity = function(element){
+ return $(element).style.opacity || '';
+Element.forceRerendering = function(element) {
+ try {
+ var n = document.createTextNode(' ');
+ element.appendChild(n);
+ element.removeChild(n);
+ } catch(e) { }
+Array.prototype.call = function() {
+ var args = arguments;
+ this.each(function(f){ f.apply(this, args) });
+var Effect = {
+ _elementDoesNotExistError: {
+ name: 'ElementDoesNotExistError',
+ message: 'The specified DOM element does not exist, but is required for this effect to operate'
+ tagifyText: function(element) {
+ if(typeof Builder == 'undefined')
+ throw("Effect.tagifyText requires including script.aculo.us' builder.js library");
+ var tagifyStyle = 'position:relative';
+ if(/MSIE/.test(navigator.userAgent) && !window.opera) tagifyStyle += ';zoom:1';
+ $A(element.childNodes).each( function(child) {
+ if(child.nodeType==3) {
+ child.nodeValue.toArray().each( function(character) {
+ element.insertBefore(
+ Builder.node('span',{style: tagifyStyle},
+ character == ' ' ? String.fromCharCode(160) : character),
+ child);
+ Element.remove(child);
+ multiple: function(element, effect) {
+ var elements;
+ if(((typeof element == 'object') ||
+ (typeof element == 'function')) &&
+ (element.length))
+ elements = element;
+ else
+ elements = $(element).childNodes;
+ speed: 0.1,
+ delay: 0.0
+ }, arguments[2] || {});
+ var masterDelay = options.delay;
+ $A(elements).each( function(element, index) {
+ new effect(element, Object.extend(options, { delay: index * options.speed + masterDelay }));
+ PAIRS: {
+ 'slide': ['SlideDown','SlideUp'],
+ 'blind': ['BlindDown','BlindUp'],
+ 'appear': ['Appear','Fade']
+ toggle: function(element, effect) {
+ effect = (effect || 'appear').toLowerCase();
+ queue: { position:'end', scope:(element.id || 'global'), limit: 1 }
+ Effect[element.visible() ?
+ Effect.PAIRS[effect][1] : Effect.PAIRS[effect][0]](element, options);
+var Effect2 = Effect; // deprecated
+/* ------------- transitions ------------- */
+Effect.Transitions = {
+ linear: Prototype.K,
+ sinoidal: function(pos) {
+ return (-Math.cos(pos*Math.PI)/2) + 0.5;
+ reverse: function(pos) {
+ return 1-pos;
+ flicker: function(pos) {
+ return ((-Math.cos(pos*Math.PI)/4) + 0.75) + Math.random()/4;
+ wobble: function(pos) {
+ return (-Math.cos(pos*Math.PI*(9*pos))/2) + 0.5;
+ pulse: function(pos, pulses) {
+ pulses = pulses || 5;
+ return (
+ Math.round((pos % (1/pulses)) * pulses) == 0 ?
+ ((pos * pulses * 2) - Math.floor(pos * pulses * 2)) :
+ 1 - ((pos * pulses * 2) - Math.floor(pos * pulses * 2))
+ none: function(pos) {
+ return 0;
+ full: function(pos) {
+ return 1;
+/* ------------- core effects ------------- */
+Effect.ScopedQueue = Class.create();
+Object.extend(Object.extend(Effect.ScopedQueue.prototype, Enumerable), {
+ initialize: function() {
+ this.effects = [];
+ this.interval = null;
+ this.effects._each(iterator);
+ add: function(effect) {
+ var timestamp = new Date().getTime();
+ var position = (typeof effect.options.queue == 'string') ?
+ effect.options.queue : effect.options.queue.position;
+ switch(position) {
+ case 'front':
+ // move unstarted effects after this effect
+ this.effects.findAll(function(e){ return e.state=='idle' }).each( function(e) {
+ e.startOn += effect.finishOn;
+ e.finishOn += effect.finishOn;
+ break;
+ case 'with-last':
+ timestamp = this.effects.pluck('startOn').max() || timestamp;
+ break;
+ case 'end':
+ // start effect after last queued effect has finished
+ timestamp = this.effects.pluck('finishOn').max() || timestamp;
+ break;
+ effect.startOn += timestamp;
+ effect.finishOn += timestamp;
+ if(!effect.options.queue.limit || (this.effects.length < effect.options.queue.limit))
+ this.effects.push(effect);
+ if(!this.interval)
+ this.interval = setInterval(this.loop.bind(this), 15);
+ remove: function(effect) {
+ this.effects = this.effects.reject(function(e) { return e==effect });
+ if(this.effects.length == 0) {
+ clearInterval(this.interval);
+ loop: function() {
+ var timePos = new Date().getTime();
+ for(var i=0, len=this.effects.length;i<len;i++)
+ if(this.effects[i]) this.effects[i].loop(timePos);
+Effect.Queues = {
+ instances: $H(),
+ get: function(queueName) {
+ if(typeof queueName != 'string') return queueName;
+ if(!this.instances[queueName])
+ this.instances[queueName] = new Effect.ScopedQueue();
+ return this.instances[queueName];
+Effect.Queue = Effect.Queues.get('global');
+Effect.DefaultOptions = {
+ transition: Effect.Transitions.sinoidal,
+ duration: 1.0, // seconds
+ fps: 60.0, // max. 60fps due to Effect.Queue implementation
+ sync: false, // true for combining
+ from: 0.0,
+ to: 1.0,
+ delay: 0.0,
+ queue: 'parallel'
+Effect.Base = function() {};
+Effect.Base.prototype = {
+ position: null,
+ start: function(options) {
+ this.options = Object.extend(Object.extend({},Effect.DefaultOptions), options || {});
+ this.currentFrame = 0;
+ this.state = 'idle';
+ this.startOn = this.options.delay*1000;
+ this.finishOn = this.startOn + (this.options.duration*1000);
+ this.event('beforeStart');
+ if(!this.options.sync)
+ Effect.Queues.get(typeof this.options.queue == 'string' ?
+ 'global' : this.options.queue.scope).add(this);
+ loop: function(timePos) {
+ if(timePos >= this.startOn) {
+ if(timePos >= this.finishOn) {
+ this.render(1.0);
+ this.cancel();
+ this.event('beforeFinish');
+ if(this.finish) this.finish();
+ this.event('afterFinish');
+ return;
+ var pos = (timePos - this.startOn) / (this.finishOn - this.startOn);
+ var frame = Math.round(pos * this.options.fps * this.options.duration);
+ if(frame > this.currentFrame) {
+ this.render(pos);
+ this.currentFrame = frame;
+ render: function(pos) {
+ if(this.state == 'idle') {
+ this.state = 'running';
+ this.event('beforeSetup');
+ if(this.setup) this.setup();
+ this.event('afterSetup');
+ if(this.state == 'running') {
+ if(this.options.transition) pos = this.options.transition(pos);
+ pos *= (this.options.to-this.options.from);
+ pos += this.options.from;
+ this.position = pos;
+ this.event('beforeUpdate');
+ if(this.update) this.update(pos);
+ this.event('afterUpdate');
+ cancel: function() {
+ 'global' : this.options.queue.scope).remove(this);
+ this.state = 'finished';
+ event: function(eventName) {
+ if(this.options[eventName + 'Internal']) this.options[eventName + 'Internal'](this);
+ if(this.options[eventName]) this.options[eventName](this);
+ inspect: function() {
+ var data = $H();
+ for(property in this)
+ if(typeof this[property] != 'function') data[property] = this[property];
+ return '#<Effect:' + data.inspect() + ',options:' + $H(this.options).inspect() + '>';
+Effect.Parallel = Class.create();
+Object.extend(Object.extend(Effect.Parallel.prototype, Effect.Base.prototype), {
+ initialize: function(effects) {
+ this.effects = effects || [];
+ this.start(arguments[1]);
+ update: function(position) {
+ this.effects.invoke('render', position);
+ finish: function(position) {
+ this.effects.each( function(effect) {
+ effect.render(1.0);
+ effect.cancel();
+ effect.event('beforeFinish');
+ if(effect.finish) effect.finish(position);
+ effect.event('afterFinish');
+Effect.Event = Class.create();
+Object.extend(Object.extend(Effect.Event.prototype, Effect.Base.prototype), {
+ duration: 0
+ }, arguments[0] || {});
+ this.start(options);
+ update: Prototype.emptyFunction
+Effect.Opacity = Class.create();
+Object.extend(Object.extend(Effect.Opacity.prototype, Effect.Base.prototype), {
+ if(!this.element) throw(Effect._elementDoesNotExistError);
+ // make this work on IE on elements without 'layout'
+ if(/MSIE/.test(navigator.userAgent) && !window.opera && (!this.element.currentStyle.hasLayout))
+ this.element.setStyle({zoom: 1});
+ from: this.element.getOpacity() || 0.0,
+ to: 1.0
+ }, arguments[1] || {});
+ this.element.setOpacity(position);
+Effect.Move = Class.create();
+Object.extend(Object.extend(Effect.Move.prototype, Effect.Base.prototype), {
+ x: 0,
+ y: 0,
+ mode: 'relative'
+ setup: function() {
+ // Bug in Opera: Opera returns the "real" position of a static element or
+ // relative element that does not have top/left explicitly set.
+ // ==> Always set top and left for position relative elements in your stylesheets
+ // (to 0 if you do not need them)
+ this.element.makePositioned();
+ this.originalLeft = parseFloat(this.element.getStyle('left') || '0');
+ this.originalTop = parseFloat(this.element.getStyle('top') || '0');
+ if(this.options.mode == 'absolute') {
+ // absolute movement, so we need to calc deltaX and deltaY
+ this.options.x = this.options.x - this.originalLeft;
+ this.options.y = this.options.y - this.originalTop;
+ left: Math.round(this.options.x * position + this.originalLeft) + 'px',
+ top: Math.round(this.options.y * position + this.originalTop) + 'px'
+// for backwards compatibility
+Effect.MoveBy = function(element, toTop, toLeft) {
+ return new Effect.Move(element,
+ Object.extend({ x: toLeft, y: toTop }, arguments[3] || {}));
+Effect.Scale = Class.create();
+Object.extend(Object.extend(Effect.Scale.prototype, Effect.Base.prototype), {
+ initialize: function(element, percent) {
+ scaleX: true,
+ scaleY: true,
+ scaleContent: true,
+ scaleFromCenter: false,
+ scaleMode: 'box', // 'box' or 'contents' or {} with provided values
+ scaleFrom: 100.0,
+ scaleTo: percent
+ this.restoreAfterFinish = this.options.restoreAfterFinish || false;
+ this.elementPositioning = this.element.getStyle('position');
+ this.originalStyle = {};
+ ['top','left','width','height','fontSize'].each( function(k) {
+ this.originalStyle[k] = this.element.style[k];
+ }.bind(this));
+ this.originalTop = this.element.offsetTop;
+ this.originalLeft = this.element.offsetLeft;
+ var fontSize = this.element.getStyle('font-size') || '100%';
+ ['em','px','%','pt'].each( function(fontSizeType) {
+ if(fontSize.indexOf(fontSizeType)>0) {
+ this.fontSize = parseFloat(fontSize);
+ this.fontSizeType = fontSizeType;
+ }.bind(this));
+ this.factor = (this.options.scaleTo - this.options.scaleFrom)/100;
+ this.dims = null;
+ if(this.options.scaleMode=='box')
+ this.dims = [this.element.offsetHeight, this.element.offsetWidth];
+ if(/^content/.test(this.options.scaleMode))
+ this.dims = [this.element.scrollHeight, this.element.scrollWidth];
+ if(!this.dims)
+ this.dims = [this.options.scaleMode.originalHeight,
+ this.options.scaleMode.originalWidth];
+ var currentScale = (this.options.scaleFrom/100.0) + (this.factor * position);
+ if(this.options.scaleContent && this.fontSize)
+ this.element.setStyle({fontSize: this.fontSize * currentScale + this.fontSizeType });
+ this.setDimensions(this.dims[0] * currentScale, this.dims[1] * currentScale);
+ if(this.restoreAfterFinish) this.element.setStyle(this.originalStyle);
+ setDimensions: function(height, width) {
+ var d = {};
+ if(this.options.scaleX) d.width = Math.round(width) + 'px';
+ if(this.options.scaleY) d.height = Math.round(height) + 'px';
+ if(this.options.scaleFromCenter) {
+ var topd = (height - this.dims[0])/2;
+ var leftd = (width - this.dims[1])/2;
+ if(this.elementPositioning == 'absolute') {
+ if(this.options.scaleY) d.top = this.originalTop-topd + 'px';
+ if(this.options.scaleX) d.left = this.originalLeft-leftd + 'px';
+ } else {
+ if(this.options.scaleY) d.top = -topd + 'px';
+ if(this.options.scaleX) d.left = -leftd + 'px';
+ this.element.setStyle(d);
+Effect.Highlight = Class.create();
+Object.extend(Object.extend(Effect.Highlight.prototype, Effect.Base.prototype), {
+ var options = Object.extend({ startcolor: '#ffff99' }, arguments[1] || {});
+ // Prevent executing on elements not in the layout flow
+ if(this.element.getStyle('display')=='none') { this.cancel(); return; }
+ // Disable background image during the effect
+ this.oldStyle = {};
+ if (!this.options.keepBackgroundImage) {
+ this.oldStyle.backgroundImage = this.element.getStyle('background-image');
+ this.element.setStyle({backgroundImage: 'none'});
+ if(!this.options.endcolor)
+ this.options.endcolor = this.element.getStyle('background-color').parseColor('#ffffff');
+ if(!this.options.restorecolor)
+ this.options.restorecolor = this.element.getStyle('background-color');
+ // init color calculations
+ this._base = $R(0,2).map(function(i){ return parseInt(this.options.startcolor.slice(i*2+1,i*2+3),16) }.bind(this));
+ this._delta = $R(0,2).map(function(i){ return parseInt(this.options.endcolor.slice(i*2+1,i*2+3),16)-this._base[i] }.bind(this));
+ this.element.setStyle({backgroundColor: $R(0,2).inject('#',function(m,v,i){
+ return m+(Math.round(this._base[i]+(this._delta[i]*position)).toColorPart()); }.bind(this)) });
+ finish: function() {
+ this.element.setStyle(Object.extend(this.oldStyle, {
+ backgroundColor: this.options.restorecolor
+Effect.ScrollTo = Class.create();
+Object.extend(Object.extend(Effect.ScrollTo.prototype, Effect.Base.prototype), {
+ this.start(arguments[1] || {});
+ var offsets = Position.cumulativeOffset(this.element);
+ if(this.options.offset) offsets[1] += this.options.offset;
+ var max = window.innerHeight ?
+ window.height - window.innerHeight :
+ document.body.scrollHeight -
+ (document.documentElement.clientHeight ?
+ document.documentElement.clientHeight : document.body.clientHeight);
+ this.scrollStart = Position.deltaY;
+ this.delta = (offsets[1] > max ? max : offsets[1]) - this.scrollStart;
+ window.scrollTo(Position.deltaX,
+ this.scrollStart + (position*this.delta));
+/* ------------- combination effects ------------- */
+Effect.Fade = function(element) {
+ var oldOpacity = element.getInlineOpacity();
+ from: element.getOpacity() || 1.0,
+ to: 0.0,
+ afterFinishInternal: function(effect) {
+ if(effect.options.to!=0) return;
+ effect.element.hide().setStyle({opacity: oldOpacity});
+ }}, arguments[1] || {});
+ return new Effect.Opacity(element,options);
+Effect.Appear = function(element) {
+ from: (element.getStyle('display') == 'none' ? 0.0 : element.getOpacity() || 0.0),
+ to: 1.0,
+ // force Safari to render floated elements properly
+ effect.element.forceRerendering();
+ beforeSetup: function(effect) {
+ effect.element.setOpacity(effect.options.from).show();
+Effect.Puff = function(element) {
+ var oldStyle = {
+ opacity: element.getInlineOpacity(),
+ position: element.getStyle('position'),
+ top: element.style.top,
+ left: element.style.left,
+ width: element.style.width,
+ height: element.style.height
+ return new Effect.Parallel(
+ [ new Effect.Scale(element, 200,
+ { sync: true, scaleFromCenter: true, scaleContent: true, restoreAfterFinish: true }),
+ new Effect.Opacity(element, { sync: true, to: 0.0 } ) ],
+ Object.extend({ duration: 1.0,
+ beforeSetupInternal: function(effect) {
+ Position.absolutize(effect.effects[0].element)
+ effect.effects[0].element.hide().setStyle(oldStyle); }
+Effect.BlindUp = function(element) {
+ element.makeClipping();
+ return new Effect.Scale(element, 0,
+ Object.extend({ scaleContent: false,
+ scaleX: false,
+ restoreAfterFinish: true,
+ effect.element.hide().undoClipping();
+Effect.BlindDown = function(element) {
+ var elementDimensions = element.getDimensions();
+ return new Effect.Scale(element, 100, Object.extend({
+ scaleContent: false,
+ scaleX: false,
+ scaleFrom: 0,
+ scaleMode: {originalHeight: elementDimensions.height, originalWidth: elementDimensions.width},
+ afterSetup: function(effect) {
+ effect.element.makeClipping().setStyle({height: '0px'}).show();
+ effect.element.undoClipping();
+ }, arguments[1] || {}));
+Effect.SwitchOff = function(element) {
+ return new Effect.Appear(element, Object.extend({
+ duration: 0.4,
+ from: 0,
+ transition: Effect.Transitions.flicker,
+ new Effect.Scale(effect.element, 1, {
+ duration: 0.3, scaleFromCenter: true,
+ scaleX: false, scaleContent: false, restoreAfterFinish: true,
+ effect.element.makePositioned().makeClipping();
+ effect.element.hide().undoClipping().undoPositioned().setStyle({opacity: oldOpacity});
+Effect.DropOut = function(element) {
+ var oldStyle = {
+ top: element.getStyle('top'),
+ left: element.getStyle('left'),
+ opacity: element.getInlineOpacity() };
+ [ new Effect.Move(element, {x: 0, y: 100, sync: true }),
+ new Effect.Opacity(element, { sync: true, to: 0.0 }) ],
+ Object.extend(
+ { duration: 0.5,
+ effect.effects[0].element.makePositioned();
+ effect.effects[0].element.hide().undoPositioned().setStyle(oldStyle);
+Effect.Shake = function(element) {
+ var oldStyle = {
+ left: element.getStyle('left') };
+ { x: 20, y: 0, duration: 0.05, afterFinishInternal: function(effect) {
+ new Effect.Move(effect.element,
+ { x: -40, y: 0, duration: 0.1, afterFinishInternal: function(effect) {
+ { x: 40, y: 0, duration: 0.1, afterFinishInternal: function(effect) {
+ { x: -20, y: 0, duration: 0.05, afterFinishInternal: function(effect) {
+ effect.element.undoPositioned().setStyle(oldStyle);
+Effect.SlideDown = function(element) {
+ element = $(element).cleanWhitespace();
+ // SlideDown need to have the content of the element wrapped in a container element with fixed height!
+ var oldInnerBottom = element.down().getStyle('bottom');
+ scaleX: false,
+ scaleFrom: window.opera ? 0 : 1,
+ effect.element.makePositioned();
+ effect.element.down().makePositioned();
+ if(window.opera) effect.element.setStyle({top: ''});
+ afterUpdateInternal: function(effect) {
+ effect.element.down().setStyle({bottom:
+ (effect.dims[0] - effect.element.clientHeight) + 'px' });
+ effect.element.undoClipping().undoPositioned();
+ effect.element.down().undoPositioned().setStyle({bottom: oldInnerBottom}); }
+Effect.SlideUp = function(element) {
+ return new Effect.Scale(element, window.opera ? 0 : 1,
+ scaleX: false,
+ scaleMode: 'box',
+ scaleFrom: 100,
+ beforeStartInternal: function(effect) {
+ effect.element.makeClipping().show();
+ effect.element.hide().undoClipping().undoPositioned().setStyle({bottom: oldInnerBottom});
+ effect.element.down().undoPositioned();
+// Bug in opera makes the TD containing this element expand for a instance after finish
+Effect.Squish = function(element) {
+ return new Effect.Scale(element, window.opera ? 1 : 0, {
+ effect.element.makeClipping();
+Effect.Grow = function(element) {
+ direction: 'center',
+ moveTransition: Effect.Transitions.sinoidal,
+ scaleTransition: Effect.Transitions.sinoidal,
+ opacityTransition: Effect.Transitions.full
+ var oldStyle = {
+ height: element.style.height,
+ var dims = element.getDimensions();
+ var initialMoveX, initialMoveY;
+ var moveX, moveY;
+ switch (options.direction) {
+ case 'top-left':
+ initialMoveX = initialMoveY = moveX = moveY = 0;
+ break;
+ case 'top-right':
+ initialMoveX = dims.width;
+ initialMoveY = moveY = 0;
+ moveX = -dims.width;
+ break;
+ case 'bottom-left':
+ initialMoveX = moveX = 0;
+ initialMoveY = dims.height;
+ moveY = -dims.height;
+ break;
+ case 'bottom-right':
+ break;
+ case 'center':
+ initialMoveX = dims.width / 2;
+ initialMoveY = dims.height / 2;
+ moveX = -dims.width / 2;
+ moveY = -dims.height / 2;
+ break;
+ return new Effect.Move(element, {
+ x: initialMoveX,
+ y: initialMoveY,
+ duration: 0.01,
+ effect.element.hide().makeClipping().makePositioned();
+ new Effect.Parallel(
+ [ new Effect.Opacity(effect.element, { sync: true, to: 1.0, from: 0.0, transition: options.opacityTransition }),
+ new Effect.Move(effect.element, { x: moveX, y: moveY, sync: true, transition: options.moveTransition }),
+ new Effect.Scale(effect.element, 100, {
+ scaleMode: { originalHeight: dims.height, originalWidth: dims.width },
+ sync: true, scaleFrom: window.opera ? 1 : 0, transition: options.scaleTransition, restoreAfterFinish: true})
+ ], Object.extend({
+ effect.effects[0].element.setStyle({height: '0px'}).show();
+ effect.effects[0].element.undoClipping().undoPositioned().setStyle(oldStyle);
+ }, options)
+Effect.Shrink = function(element) {
+ opacityTransition: Effect.Transitions.none
+ var oldStyle = {
+ var moveX, moveY;
+ case 'top-left':
+ moveX = moveY = 0;
+ break;
+ case 'top-right':
+ moveX = dims.width;
+ moveY = 0;
+ break;
+ moveX = 0;
+ moveY = dims.height;
+ break;
+ break;
+ case 'center':
+ moveX = dims.width / 2;
+ moveY = dims.height / 2;
+ break;
+ [ new Effect.Opacity(element, { sync: true, to: 0.0, from: 1.0, transition: options.opacityTransition }),
+ new Effect.Scale(element, window.opera ? 1 : 0, { sync: true, transition: options.scaleTransition, restoreAfterFinish: true}),
+ new Effect.Move(element, { x: moveX, y: moveY, sync: true, transition: options.moveTransition })
+ effect.effects[0].element.makePositioned().makeClipping();
+ effect.effects[0].element.hide().undoClipping().undoPositioned().setStyle(oldStyle); }
+ }, options)
+Effect.Pulsate = function(element) {
+ var options = arguments[1] || {};
+ var transition = options.transition || Effect.Transitions.sinoidal;
+ var reverser = function(pos){ return transition(1-Effect.Transitions.pulse(pos, options.pulses)) };
+ reverser.bind(transition);
+ Object.extend(Object.extend({ duration: 2.0, from: 0,
+ afterFinishInternal: function(effect) { effect.element.setStyle({opacity: oldOpacity}); }
+ }, options), {transition: reverser}));
+Effect.Fold = function(element) {
+ element = $(element);
+ var oldStyle = {
+ height: element.style.height };
+ return new Effect.Scale(element, 5, Object.extend({
+ scaleX: false,
+ new Effect.Scale(element, 1, {
+ scaleY: false,
+ effect.element.hide().undoClipping().setStyle(oldStyle);
+ }}, arguments[1] || {}));
+Effect.Morph = Class.create();
+Object.extend(Object.extend(Effect.Morph.prototype, Effect.Base.prototype), {
+ style: {}
+ if (typeof options.style == 'string') {
+ if(options.style.indexOf(':') == -1) {
+ var cssText = '', selector = '.' + options.style;
+ $A(document.styleSheets).reverse().each(function(styleSheet) {
+ if (styleSheet.cssRules) cssRules = styleSheet.cssRules;
+ else if (styleSheet.rules) cssRules = styleSheet.rules;
+ $A(cssRules).reverse().each(function(rule) {
+ if (selector == rule.selectorText) {
+ cssText = rule.style.cssText;
+ throw $break;
+ if (cssText) throw $break;
+ this.style = cssText.parseStyle();
+ options.afterFinishInternal = function(effect){
+ effect.element.addClassName(effect.options.style);
+ effect.transforms.each(function(transform) {
+ if(transform.style != 'opacity')
+ effect.element.style[transform.style.camelize()] = '';
+ } else this.style = options.style.parseStyle();
+ } else this.style = $H(options.style)
+ setup: function(){
+ function parseColor(color){
+ if(!color || ['rgba(0, 0, 0, 0)','transparent'].include(color)) color = '#ffffff';
+ color = color.parseColor();
+ return $R(0,2).map(function(i){
+ return parseInt( color.slice(i*2+1,i*2+3), 16 )
+ this.transforms = this.style.map(function(pair){
+ var property = pair[0].underscore().dasherize(), value = pair[1], unit = null;
+ if(value.parseColor('#zzzzzz') != '#zzzzzz') {
+ value = value.parseColor();
+ unit = 'color';
+ } else if(property == 'opacity') {
+ value = parseFloat(value);
+ } else if(Element.CSS_LENGTH.test(value))
+ var components = value.match(/^([\+\-]?[0-9\.]+)(.*)$/),
+ value = parseFloat(components[1]), unit = (components.length == 3) ? components[2] : null;
+ var originalValue = this.element.getStyle(property);
+ return $H({
+ style: property,
+ originalValue: unit=='color' ? parseColor(originalValue) : parseFloat(originalValue || 0),
+ targetValue: unit=='color' ? parseColor(value) : value,
+ unit: unit
+ }.bind(this)).reject(function(transform){
+ return (
+ (transform.originalValue == transform.targetValue) ||
+ transform.unit != 'color' &&
+ (isNaN(transform.originalValue) || isNaN(transform.targetValue))
+ var style = $H(), value = null;
+ this.transforms.each(function(transform){
+ value = transform.unit=='color' ?
+ $R(0,2).inject('#',function(m,v,i){
+ return m+(Math.round(transform.originalValue[i]+
+ (transform.targetValue[i] - transform.originalValue[i])*position)).toColorPart() }) :
+ transform.originalValue + Math.round(
+ ((transform.targetValue - transform.originalValue) * position) * 1000)/1000 + transform.unit;
+ style[transform.style] = value;
+ this.element.setStyle(style);
+Effect.Transform = Class.create();
+Object.extend(Effect.Transform.prototype, {
+ initialize: function(tracks){
+ this.tracks = [];
+ this.options = arguments[1] || {};
+ this.addTracks(tracks);
+ addTracks: function(tracks){
+ tracks.each(function(track){
+ var data = $H(track).values().first();
+ this.tracks.push($H({
+ ids: $H(track).keys().first(),
+ effect: Effect.Morph,
+ options: { style: data }
+ }.bind(this));
+ return this;
+ play: function(){
+ this.tracks.map(function(track){
+ var elements = [$(track.ids) || $$(track.ids)].flatten();
+ return elements.map(function(e){ return new track.effect(e, Object.extend({ sync:true }, track.options)) });
+ }).flatten(),
+ this.options
+Element.CSS_PROPERTIES = $w(
+ 'backgroundColor backgroundPosition borderBottomColor borderBottomStyle ' +
+ 'borderBottomWidth borderLeftColor borderLeftStyle borderLeftWidth ' +
+ 'borderRightColor borderRightStyle borderRightWidth borderSpacing ' +
+ 'borderTopColor borderTopStyle borderTopWidth bottom clip color ' +
+ 'fontSize fontWeight height left letterSpacing lineHeight ' +
+ 'marginBottom marginLeft marginRight marginTop markerOffset maxHeight '+
+ 'maxWidth minHeight minWidth opacity outlineColor outlineOffset ' +
+ 'outlineWidth paddingBottom paddingLeft paddingRight paddingTop ' +
+ 'right textIndent top width wordSpacing zIndex');
+Element.CSS_LENGTH = /^(([\+\-]?[0-9\.]+)(em|ex|px|in|cm|mm|pt|pc|\%))|0$/;
+String.prototype.parseStyle = function(){
+ var element = Element.extend(document.createElement('div'));
+ element.innerHTML = '<div style="' + this + '"></div>';
+ var style = element.down().style, styleRules = $H();
+ Element.CSS_PROPERTIES.each(function(property){
+ if(style[property]) styleRules[property] = style[property];
+ if(/MSIE/.test(navigator.userAgent) && !window.opera && this.indexOf('opacity') > -1) {
+ styleRules.opacity = this.match(/opacity:\s*((?:0|1)?(?:\.\d*)?)/)[1];
+ return styleRules;
+Element.morph = function(element, style) {
+ new Effect.Morph(element, Object.extend({ style: style }, arguments[2] || {}));
+ return element;
+['setOpacity','getOpacity','getInlineOpacity','forceRerendering','setContentZoom',
+ 'collectTextNodes','collectTextNodesIgnoreClass','morph'].each(
+ function(f) { Element.Methods[f] = Element[f]; }
+Element.Methods.visualEffect = function(element, effect, options) {
+ s = effect.gsub(/_/, '-').camelize();
+ effect_class = s.charAt(0).toUpperCase() + s.substring(1);
+ new Effect[effect_class](element, options);
+ return $(element);
+Element.addMethods();// script.aculo.us dragdrop.js v1.7.0, Fri Jan 19 19:16:36 CET 2007
+// (c) 2005, 2006 Sammi Williams (http://www.oriontransfer.co.nz, sammi at oriontransfer.co.nz)
+if(typeof Effect == 'undefined')
+ throw("dragdrop.js requires including script.aculo.us' effects.js library");
+var Droppables = {
+ drops: [],
+ remove: function(element) {
+ this.drops = this.drops.reject(function(d) { return d.element==$(element) });
+ add: function(element) {
+ greedy: true,
+ hoverclass: null,
+ tree: false
+ // cache containers
+ if(options.containment) {
+ options._containers = [];
+ var containment = options.containment;
+ if((typeof containment == 'object') &&
+ (containment.constructor == Array)) {
+ containment.each( function(c) { options._containers.push($(c)) });
+ } else {
+ options._containers.push($(containment));
+ if(options.accept) options.accept = [options.accept].flatten();
+ Element.makePositioned(element); // fix IE
+ options.element = element;
+ this.drops.push(options);
+ findDeepestChild: function(drops) {
+ deepest = drops[0];
+ for (i = 1; i < drops.length; ++i)
+ if (Element.isParent(drops[i].element, deepest.element))
+ deepest = drops[i];
+ return deepest;
+ isContained: function(element, drop) {
+ var containmentNode;
+ if(drop.tree) {
+ containmentNode = element.treeNode;
+ } else {
+ containmentNode = element.parentNode;
+ return drop._containers.detect(function(c) { return containmentNode == c });
+ isAffected: function(point, element, drop) {
+ return (
+ (drop.element!=element) &&
+ ((!drop._containers) ||
+ this.isContained(element, drop)) &&
+ ((!drop.accept) ||
+ (Element.classNames(element).detect(
+ function(v) { return drop.accept.include(v) } ) )) &&
+ Position.within(drop.element, point[0], point[1]) );
+ deactivate: function(drop) {
+ if(drop.hoverclass)
+ Element.removeClassName(drop.element, drop.hoverclass);
+ this.last_active = null;
+ activate: function(drop) {
+ Element.addClassName(drop.element, drop.hoverclass);
+ this.last_active = drop;
+ show: function(point, element) {
+ if(!this.drops.length) return;
+ var affected = [];
+ if(this.last_active) this.deactivate(this.last_active);
+ this.drops.each( function(drop) {
+ if(Droppables.isAffected(point, element, drop))
+ affected.push(drop);
+ if(affected.length>0) {
+ drop = Droppables.findDeepestChild(affected);
+ Position.within(drop.element, point[0], point[1]);
+ if(drop.onHover)
+ drop.onHover(element, drop.element, Position.overlap(drop.overlap, drop.element));
+ Droppables.activate(drop);
+ fire: function(event, element) {
+ if(!this.last_active) return;
+ if (this.isAffected([Event.pointerX(event), Event.pointerY(event)], element, this.last_active))
+ if (this.last_active.onDrop)
+ this.last_active.onDrop(element, this.last_active.element, event);
+ reset: function() {
+ this.deactivate(this.last_active);
+var Draggables = {
+ drags: [],
+ observers: [],
+ register: function(draggable) {
+ if(this.drags.length == 0) {
+ this.eventMouseUp = this.endDrag.bindAsEventListener(this);
+ this.eventMouseMove = this.updateDrag.bindAsEventListener(this);
+ this.eventKeypress = this.keyPress.bindAsEventListener(this);
+ Event.observe(document, "mouseup", this.eventMouseUp);
+ Event.observe(document, "mousemove", this.eventMouseMove);
+ Event.observe(document, "keypress", this.eventKeypress);
+ this.drags.push(draggable);
+ unregister: function(draggable) {
+ this.drags = this.drags.reject(function(d) { return d==draggable });
+ Event.stopObserving(document, "mouseup", this.eventMouseUp);
+ Event.stopObserving(document, "mousemove", this.eventMouseMove);
+ Event.stopObserving(document, "keypress", this.eventKeypress);
+ activate: function(draggable) {
+ if(draggable.options.delay) {
+ this._timeout = setTimeout(function() {
+ Draggables._timeout = null;
+ window.focus();
+ Draggables.activeDraggable = draggable;
+ }.bind(this), draggable.options.delay);
+ } else {
+ window.focus(); // allows keypress events if window isn't currently focused, fails for Safari
+ this.activeDraggable = draggable;
+ deactivate: function() {
+ this.activeDraggable = null;
+ updateDrag: function(event) {
+ if(!this.activeDraggable) return;
+ var pointer = [Event.pointerX(event), Event.pointerY(event)];
+ // Mozilla-based browsers fire successive mousemove events with
+ // the same coordinates, prevent needless redrawing (moz bug?)
+ if(this._lastPointer && (this._lastPointer.inspect() == pointer.inspect())) return;
+ this._lastPointer = pointer;
+ this.activeDraggable.updateDrag(event, pointer);
+ endDrag: function(event) {
+ if(this._timeout) {
+ clearTimeout(this._timeout);
+ this._timeout = null;
+ this._lastPointer = null;
+ this.activeDraggable.endDrag(event);
+ keyPress: function(event) {
+ if(this.activeDraggable)
+ this.activeDraggable.keyPress(event);
+ addObserver: function(observer) {
+ this.observers.push(observer);
+ this._cacheObserverCallbacks();
+ removeObserver: function(element) { // element instead of observer fixes mem leaks
+ this.observers = this.observers.reject( function(o) { return o.element==element });
+ notify: function(eventName, draggable, event) { // 'onStart', 'onEnd', 'onDrag'
+ if(this[eventName+'Count'] > 0)
+ this.observers.each( function(o) {
+ if(o[eventName]) o[eventName](eventName, draggable, event);
+ if(draggable.options[eventName]) draggable.options[eventName](draggable, event);
+ _cacheObserverCallbacks: function() {
+ ['onStart','onEnd','onDrag'].each( function(eventName) {
+ Draggables[eventName+'Count'] = Draggables.observers.select(
+ function(o) { return o[eventName]; }
+ ).length;
+var Draggable = Class.create();
+Draggable._dragging = {};
+Draggable.prototype = {
+ var defaults = {
+ handle: false,
+ reverteffect: function(element, top_offset, left_offset) {
+ var dur = Math.sqrt(Math.abs(top_offset^2)+Math.abs(left_offset^2))*0.02;
+ new Effect.Move(element, { x: -left_offset, y: -top_offset, duration: dur,
+ queue: {scope:'_draggable', position:'end'}
+ endeffect: function(element) {
+ var toOpacity = typeof element._opacity == 'number' ? element._opacity : 1.0;
+ new Effect.Opacity(element, {duration:0.2, from:0.7, to:toOpacity,
+ queue: {scope:'_draggable', position:'end'},
+ afterFinish: function(){
+ Draggable._dragging[element] = false
+ zindex: 1000,
+ revert: false,
+ scroll: false,
+ scrollSensitivity: 20,
+ scrollSpeed: 15,
+ snap: false, // false, or xy or [x,y] or function(x,y){ return [x,y] }
+ delay: 0
+ if(!arguments[1] || typeof arguments[1].endeffect == 'undefined')
+ Object.extend(defaults, {
+ starteffect: function(element) {
+ element._opacity = Element.getOpacity(element);
+ Draggable._dragging[element] = true;
+ new Effect.Opacity(element, {duration:0.2, from:element._opacity, to:0.7});
+ var options = Object.extend(defaults, arguments[1] || {});
+ if(options.handle && (typeof options.handle == 'string'))
+ this.handle = this.element.down('.'+options.handle, 0);
+ if(!this.handle) this.handle = $(options.handle);
+ if(!this.handle) this.handle = this.element;
+ if(options.scroll && !options.scroll.scrollTo && !options.scroll.outerHTML) {
+ options.scroll = $(options.scroll);
+ this._isScrollChild = Element.childOf(this.element, options.scroll);
+ Element.makePositioned(this.element); // fix IE
+ this.delta = this.currentDelta();
+ this.options = options;
+ this.dragging = false;
+ this.eventMouseDown = this.initDrag.bindAsEventListener(this);
+ Event.observe(this.handle, "mousedown", this.eventMouseDown);
+ Draggables.register(this);
+ destroy: function() {
+ Event.stopObserving(this.handle, "mousedown", this.eventMouseDown);
+ Draggables.unregister(this);
+ currentDelta: function() {
+ return([
+ parseInt(Element.getStyle(this.element,'left') || '0'),
+ parseInt(Element.getStyle(this.element,'top') || '0')]);
+ initDrag: function(event) {
+ if(typeof Draggable._dragging[this.element] != 'undefined' &&
+ Draggable._dragging[this.element]) return;
+ if(Event.isLeftClick(event)) {
+ // abort on form elements, fixes a Firefox issue
+ var src = Event.element(event);
+ if((tag_name = src.tagName.toUpperCase()) && (
+ tag_name=='INPUT' ||
+ tag_name=='SELECT' ||
+ tag_name=='OPTION' ||
+ tag_name=='BUTTON' ||
+ tag_name=='TEXTAREA')) return;
+ var pos = Position.cumulativeOffset(this.element);
+ this.offset = [0,1].map( function(i) { return (pointer[i] - pos[i]) });
+ Draggables.activate(this);
+ Event.stop(event);
+ startDrag: function(event) {
+ this.dragging = true;
+ if(this.options.zindex) {
+ this.originalZ = parseInt(Element.getStyle(this.element,'z-index') || 0);
+ this.element.style.zIndex = this.options.zindex;
+ if(this.options.ghosting) {
+ this._clone = this.element.cloneNode(true);
+ Position.absolutize(this.element);
+ this.element.parentNode.insertBefore(this._clone, this.element);
+ if(this.options.scroll) {
+ if (this.options.scroll == window) {
+ var where = this._getWindowScroll(this.options.scroll);
+ this.originalScrollLeft = where.left;
+ this.originalScrollTop = where.top;
+ } else {
+ this.originalScrollLeft = this.options.scroll.scrollLeft;
+ this.originalScrollTop = this.options.scroll.scrollTop;
+ Draggables.notify('onStart', this, event);
+ if(this.options.starteffect) this.options.starteffect(this.element);
+ updateDrag: function(event, pointer) {
+ if(!this.dragging) this.startDrag(event);
+ Droppables.show(pointer, this.element);
+ Draggables.notify('onDrag', this, event);
+ this.draw(pointer);
+ if(this.options.change) this.options.change(this);
+ this.stopScrolling();
+ var p;
+ with(this._getWindowScroll(this.options.scroll)) { p = [ left, top, left+width, top+height ]; }
+ } else {
+ p = Position.page(this.options.scroll);
+ p[0] += this.options.scroll.scrollLeft + Position.deltaX;
+ p[1] += this.options.scroll.scrollTop + Position.deltaY;
+ p.push(p[0]+this.options.scroll.offsetWidth);
+ p.push(p[1]+this.options.scroll.offsetHeight);
+ var speed = [0,0];
+ if(pointer[0] < (p[0]+this.options.scrollSensitivity)) speed[0] = pointer[0]-(p[0]+this.options.scrollSensitivity);
+ if(pointer[1] < (p[1]+this.options.scrollSensitivity)) speed[1] = pointer[1]-(p[1]+this.options.scrollSensitivity);
+ if(pointer[0] > (p[2]-this.options.scrollSensitivity)) speed[0] = pointer[0]-(p[2]-this.options.scrollSensitivity);
+ if(pointer[1] > (p[3]-this.options.scrollSensitivity)) speed[1] = pointer[1]-(p[3]-this.options.scrollSensitivity);
+ this.startScrolling(speed);
+ // fix AppleWebKit rendering
+ finishDrag: function(event, success) {
+ Position.relativize(this.element);
+ Element.remove(this._clone);
+ this._clone = null;
+ if(success) Droppables.fire(event, this.element);
+ Draggables.notify('onEnd', this, event);
+ var revert = this.options.revert;
+ if(revert && typeof revert == 'function') revert = revert(this.element);
+ var d = this.currentDelta();
+ if(revert && this.options.reverteffect) {
+ this.options.reverteffect(this.element,
+ d[1]-this.delta[1], d[0]-this.delta[0]);
+ } else {
+ this.delta = d;
+ this.element.style.zIndex = this.originalZ;
+ if(this.options.endeffect)
+ this.options.endeffect(this.element);
+ Draggables.deactivate(this);
+ Droppables.reset();
+ if(event.keyCode!=Event.KEY_ESC) return;
+ this.finishDrag(event, false);
+ if(!this.dragging) return;
+ this.finishDrag(event, true);
+ draw: function(point) {
+ var r = Position.realOffset(this.element);
+ pos[0] += r[0] - Position.deltaX; pos[1] += r[1] - Position.deltaY;
+ pos[0] -= d[0]; pos[1] -= d[1];
+ if(this.options.scroll && (this.options.scroll != window && this._isScrollChild)) {
+ pos[0] -= this.options.scroll.scrollLeft-this.originalScrollLeft;
+ pos[1] -= this.options.scroll.scrollTop-this.originalScrollTop;
+ var p = [0,1].map(function(i){
+ return (point[i]-pos[i]-this.offset[i])
+ }.bind(this));
+ if(this.options.snap) {
+ if(typeof this.options.snap == 'function') {
+ p = this.options.snap(p[0],p[1],this);
+ } else {
+ if(this.options.snap instanceof Array) {
+ p = p.map( function(v, i) {
+ return Math.round(v/this.options.snap[i])*this.options.snap[i] }.bind(this))
+ } else {
+ p = p.map( function(v) {
+ return Math.round(v/this.options.snap)*this.options.snap }.bind(this))
+ var style = this.element.style;
+ if((!this.options.constraint) || (this.options.constraint=='horizontal'))
+ style.left = p[0] + "px";
+ if((!this.options.constraint) || (this.options.constraint=='vertical'))
+ style.top = p[1] + "px";
+ if(style.visibility=="hidden") style.visibility = ""; // fix gecko rendering
+ stopScrolling: function() {
+ if(this.scrollInterval) {
+ clearInterval(this.scrollInterval);
+ this.scrollInterval = null;
+ Draggables._lastScrollPointer = null;
+ startScrolling: function(speed) {
+ if(!(speed[0] || speed[1])) return;
+ this.scrollSpeed = [speed[0]*this.options.scrollSpeed,speed[1]*this.options.scrollSpeed];
+ this.lastScrolled = new Date();
+ this.scrollInterval = setInterval(this.scroll.bind(this), 10);
+ scroll: function() {
+ var current = new Date();
+ var delta = current - this.lastScrolled;
+ this.lastScrolled = current;
+ if(this.options.scroll == window) {
+ with (this._getWindowScroll(this.options.scroll)) {
+ if (this.scrollSpeed[0] || this.scrollSpeed[1]) {
+ var d = delta / 1000;
+ this.options.scroll.scrollTo( left + d*this.scrollSpeed[0], top + d*this.scrollSpeed[1] );
+ } else {
+ this.options.scroll.scrollLeft += this.scrollSpeed[0] * delta / 1000;
+ this.options.scroll.scrollTop += this.scrollSpeed[1] * delta / 1000;
+ Droppables.show(Draggables._lastPointer, this.element);
+ Draggables.notify('onDrag', this);
+ if (this._isScrollChild) {
+ Draggables._lastScrollPointer = Draggables._lastScrollPointer || $A(Draggables._lastPointer);
+ Draggables._lastScrollPointer[0] += this.scrollSpeed[0] * delta / 1000;
+ Draggables._lastScrollPointer[1] += this.scrollSpeed[1] * delta / 1000;
+ if (Draggables._lastScrollPointer[0] < 0)
+ Draggables._lastScrollPointer[0] = 0;
+ if (Draggables._lastScrollPointer[1] < 0)
+ Draggables._lastScrollPointer[1] = 0;
+ this.draw(Draggables._lastScrollPointer);
+ _getWindowScroll: function(w) {
+ var T, L, W, H;
+ with (w.document) {
+ if (w.document.documentElement && documentElement.scrollTop) {
+ T = documentElement.scrollTop;
+ L = documentElement.scrollLeft;
+ } else if (w.document.body) {
+ T = body.scrollTop;
+ L = body.scrollLeft;
+ if (w.innerWidth) {
+ W = w.innerWidth;
+ H = w.innerHeight;
+ } else if (w.document.documentElement && documentElement.clientWidth) {
+ W = documentElement.clientWidth;
+ H = documentElement.clientHeight;
+ } else {
+ W = body.offsetWidth;
+ H = body.offsetHeight
+ return { top: T, left: L, width: W, height: H };
+var SortableObserver = Class.create();
+SortableObserver.prototype = {
+ initialize: function(element, observer) {
+ this.element = $(element);
+ this.observer = observer;
+ this.lastValue = Sortable.serialize(this.element);
+ onStart: function() {
+ onEnd: function() {
+ Sortable.unmark();
+ if(this.lastValue != Sortable.serialize(this.element))
+ this.observer(this.element)
+var Sortable = {
+ SERIALIZE_RULE: /^[^_\-](?:[A-Za-z0-9\-\_]*)[_](.*)$/,
+ sortables: {},
+ _findRootElement: function(element) {
+ while (element.tagName.toUpperCase() != "BODY") {
+ if(element.id && Sortable.sortables[element.id]) return element;
+ options: function(element) {
+ element = Sortable._findRootElement($(element));
+ return Sortable.sortables[element.id];
+ destroy: function(element){
+ var s = Sortable.options(element);
+ if(s) {
+ Draggables.removeObserver(s.element);
+ s.droppables.each(function(d){ Droppables.remove(d) });
+ s.draggables.invoke('destroy');
+ delete Sortable.sortables[s.element.id];
+ create: function(element) {
+ element: element,
+ tag: 'li', // assumes li children, override with tag: 'tagname'
+ dropOnEmpty: false,
+ tree: false,
+ treeTag: 'ul',
+ overlap: 'vertical', // one of 'vertical', 'horizontal'
+ constraint: 'vertical', // one of 'vertical', 'horizontal', false
+ containment: element, // also takes array of elements (or id's); or false
+ handle: false, // or a CSS class
+ only: false,
+ delay: 0,
+ hoverclass: null,
+ ghosting: false,
+ scroll: false,
+ scrollSpeed: 15,
+ format: this.SERIALIZE_RULE,
+ onChange: Prototype.emptyFunction,
+ onUpdate: Prototype.emptyFunction
+ // clear any old sortable with same element
+ this.destroy(element);
+ // build options for the draggables
+ var options_for_draggable = {
+ revert: true,
+ scroll: options.scroll,
+ scrollSpeed: options.scrollSpeed,
+ scrollSensitivity: options.scrollSensitivity,
+ delay: options.delay,
+ ghosting: options.ghosting,
+ constraint: options.constraint,
+ handle: options.handle };
+ if(options.starteffect)
+ options_for_draggable.starteffect = options.starteffect;
+ if(options.reverteffect)
+ options_for_draggable.reverteffect = options.reverteffect;
+ else
+ if(options.ghosting) options_for_draggable.reverteffect = function(element) {
+ element.style.top = 0;
+ element.style.left = 0;
+ if(options.endeffect)
+ options_for_draggable.endeffect = options.endeffect;
+ if(options.zindex)
+ options_for_draggable.zindex = options.zindex;
+ // build options for the droppables
+ var options_for_droppable = {
+ overlap: options.overlap,
+ containment: options.containment,
+ tree: options.tree,
+ hoverclass: options.hoverclass,
+ onHover: Sortable.onHover
+ var options_for_tree = {
+ onHover: Sortable.onEmptyHover,
+ // fix for gecko engine
+ Element.cleanWhitespace(element);
+ options.draggables = [];
+ options.droppables = [];
+ // drop on empty handling
+ if(options.dropOnEmpty || options.tree) {
+ Droppables.add(element, options_for_tree);
+ options.droppables.push(element);
+ (this.findElements(element, options) || []).each( function(e) {
+ // handles are per-draggable
+ var handle = options.handle ?
+ $(e).down('.'+options.handle,0) : e;
+ options.draggables.push(
+ new Draggable(e, Object.extend(options_for_draggable, { handle: handle })));
+ Droppables.add(e, options_for_droppable);
+ if(options.tree) e.treeNode = element;
+ options.droppables.push(e);
+ if(options.tree) {
+ (Sortable.findTreeElements(element, options) || []).each( function(e) {
+ Droppables.add(e, options_for_tree);
+ e.treeNode = element;
+ // keep reference
+ this.sortables[element.id] = options;
+ // for onupdate
+ Draggables.addObserver(new SortableObserver(element, options.onUpdate));
+ // return all suitable-for-sortable elements in a guaranteed order
+ findElements: function(element, options) {
+ return Element.findChildren(
+ element, options.only, options.tree ? true : false, options.tag);
+ findTreeElements: function(element, options) {
+ element, options.only, options.tree ? true : false, options.treeTag);
+ onHover: function(element, dropon, overlap) {
+ if(Element.isParent(dropon, element)) return;
+ if(overlap > .33 && overlap < .66 && Sortable.options(dropon).tree) {
+ return;
+ } else if(overlap>0.5) {
+ Sortable.mark(dropon, 'before');
+ if(dropon.previousSibling != element) {
+ var oldParentNode = element.parentNode;
+ element.style.visibility = "hidden"; // fix gecko rendering
+ dropon.parentNode.insertBefore(element, dropon);
+ if(dropon.parentNode!=oldParentNode)
+ Sortable.options(oldParentNode).onChange(element);
+ Sortable.options(dropon.parentNode).onChange(element);
+ } else {
+ Sortable.mark(dropon, 'after');
+ var nextElement = dropon.nextSibling || null;
+ if(nextElement != element) {
+ dropon.parentNode.insertBefore(element, nextElement);
+ onEmptyHover: function(element, dropon, overlap) {
+ var droponOptions = Sortable.options(dropon);
+ if(!Element.isParent(dropon, element)) {
+ var index;
+ var children = Sortable.findElements(dropon, {tag: droponOptions.tag, only: droponOptions.only});
+ var child = null;
+ if(children) {
+ var offset = Element.offsetSize(dropon, droponOptions.overlap) * (1.0 - overlap);
+ for (index = 0; index < children.length; index += 1) {
+ if (offset - Element.offsetSize (children[index], droponOptions.overlap) >= 0) {
+ offset -= Element.offsetSize (children[index], droponOptions.overlap);
+ } else if (offset - (Element.offsetSize (children[index], droponOptions.overlap) / 2) >= 0) {
+ child = index + 1 < children.length ? children[index + 1] : null;
+ break;
+ } else {
+ child = children[index];
+ break;
+ dropon.insertBefore(element, child);
+ droponOptions.onChange(element);
+ unmark: function() {
+ if(Sortable._marker) Sortable._marker.hide();
+ mark: function(dropon, position) {
+ // mark on ghosting only
+ var sortable = Sortable.options(dropon.parentNode);
+ if(sortable && !sortable.ghosting) return;
+ if(!Sortable._marker) {
+ Sortable._marker =
+ ($('dropmarker') || Element.extend(document.createElement('DIV'))).
+ hide().addClassName('dropmarker').setStyle({position:'absolute'});
+ document.getElementsByTagName("body").item(0).appendChild(Sortable._marker);
+ var offsets = Position.cumulativeOffset(dropon);
+ Sortable._marker.setStyle({left: offsets[0]+'px', top: offsets[1] + 'px'});
+ if(position=='after')
+ if(sortable.overlap == 'horizontal')
+ Sortable._marker.setStyle({left: (offsets[0]+dropon.clientWidth) + 'px'});
+ else
+ Sortable._marker.setStyle({top: (offsets[1]+dropon.clientHeight) + 'px'});
+ Sortable._marker.show();
+ _tree: function(element, options, parent) {
+ var children = Sortable.findElements(element, options) || [];
+ for (var i = 0; i < children.length; ++i) {
+ var match = children[i].id.match(options.format);
+ if (!match) continue;
+ var child = {
+ id: encodeURIComponent(match ? match[1] : null),
+ element: element,
+ parent: parent,
+ children: [],
+ position: parent.children.length,
+ container: $(children[i]).down(options.treeTag)
+ /* Get the element containing the children and recurse over it */
+ if (child.container)
+ this._tree(child.container, options, child)
+ parent.children.push (child);
+ return parent;
+ tree: function(element) {
+ var sortableOptions = this.options(element);
+ tag: sortableOptions.tag,
+ treeTag: sortableOptions.treeTag,
+ only: sortableOptions.only,
+ name: element.id,
+ format: sortableOptions.format
+ var root = {
+ id: null,
+ parent: null,
+ children: [],
+ container: element,
+ position: 0
+ return Sortable._tree(element, options, root);
+ /* Construct a [i] index for a particular node */
+ _constructIndex: function(node) {
+ var index = '';
+ do {
+ if (node.id) index = '[' + node.position + ']' + index;
+ } while ((node = node.parent) != null);
+ return index;
+ sequence: function(element) {
+ var options = Object.extend(this.options(element), arguments[1] || {});
+ return $(this.findElements(element, options) || []).map( function(item) {
+ return item.id.match(options.format) ? item.id.match(options.format)[1] : '';
+ setSequence: function(element, new_sequence) {
+ var options = Object.extend(this.options(element), arguments[2] || {});
+ var nodeMap = {};
+ this.findElements(element, options).each( function(n) {
+ if (n.id.match(options.format))
+ nodeMap[n.id.match(options.format)[1]] = [n, n.parentNode];
+ n.parentNode.removeChild(n);
+ new_sequence.each(function(ident) {
+ var n = nodeMap[ident];
+ if (n) {
+ n[1].appendChild(n[0]);
+ delete nodeMap[ident];
+ serialize: function(element) {
+ var options = Object.extend(Sortable.options(element), arguments[1] || {});
+ var name = encodeURIComponent(
+ (arguments[1] && arguments[1].name) ? arguments[1].name : element.id);
+ if (options.tree) {
+ return Sortable.tree(element, arguments[1]).children.map( function (item) {
+ return [name + Sortable._constructIndex(item) + "[id]=" +
+ encodeURIComponent(item.id)].concat(item.children.map(arguments.callee));
+ }).flatten().join('&');
+ } else {
+ return Sortable.sequence(element, arguments[1]).map( function(item) {
+ return name + "[]=" + encodeURIComponent(item);
+ }).join('&');
+// Returns true if child is contained within element
+Element.isParent = function(child, element) {
+ if (!child.parentNode || child == element) return false;
+ if (child.parentNode == element) return true;
+ return Element.isParent(child.parentNode, element);
+Element.findChildren = function(element, only, recursive, tagName) {
+ if(!element.hasChildNodes()) return null;
+ tagName = tagName.toUpperCase();
+ if(only) only = [only].flatten();
+ var elements = [];
+ $A(element.childNodes).each( function(e) {
+ if(e.tagName && e.tagName.toUpperCase()==tagName &&
+ (!only || (Element.classNames(e).detect(function(v) { return only.include(v) }))))
+ elements.push(e);
+ if(recursive) {
+ var grandchildren = Element.findChildren(e, only, recursive, tagName);
+ if(grandchildren) elements.push(grandchildren);
+ return (elements.length>0 ? elements.flatten() : []);
+Element.offsetSize = function (element, type) {
+ return element['offset' + ((type=='vertical' || type=='height') ? 'Height' : 'Width')];
+// script.aculo.us controls.js v1.7.0, Fri Jan 19 19:16:36 CET 2007
+// (c) 2005, 2006 Ivan Krstic (http://blogs.law.harvard.edu/ivan)
+// (c) 2005, 2006 Jon Tirsen (http://www.tirsen.com)
+// Contributors:
+// Richard Livsey
+// Rahul Bhargava
+// Rob Wills
+// Autocompleter.Base handles all the autocompletion functionality
+// that's independent of the data source for autocompletion. This
+// includes drawing the autocompletion menu, observing keyboard
+// and mouse events, and similar.
+// Specific autocompleters need to provide, at the very least,
+// a getUpdatedChoices function that will be invoked every time
+// the text inside the monitored textbox changes. This method
+// should get the text for which to provide autocompletion by
+// invoking this.getToken(), NOT by directly accessing
+// this.element.value. This is to allow incremental tokenized
+// autocompletion. Specific auto-completion logic (AJAX, etc)
+// belongs in getUpdatedChoices.
+// Tokenized incremental autocompletion is enabled automatically
+// when an autocompleter is instantiated with the 'tokens' option
+// in the options parameter, e.g.:
+// new Ajax.Autocompleter('id','upd', '/url/', { tokens: ',' });
+// will incrementally autocomplete with a comma as the token.
+// Additionally, ',' in the above example can be replaced with
+// a token array, e.g. { tokens: [',', '\n'] } which
+// enables autocompletion on multiple tokens. This is most
+// useful when one of the tokens is \n (a newline), as it
+// allows smart autocompletion after linebreaks.
+ throw("controls.js requires including script.aculo.us' effects.js library");
+var Autocompleter = {}
+Autocompleter.Base = function() {};
+Autocompleter.Base.prototype = {
+ baseInitialize: function(element, update, options) {
+ this.update = $(update);
+ this.hasFocus = false;
+ this.changed = false;
+ this.active = false;
+ this.index = 0;
+ this.entryCount = 0;
+ if(this.setOptions)
+ this.setOptions(options);
+ else
+ this.options = options || {};
+ this.options.paramName = this.options.paramName || this.element.name;
+ this.options.tokens = this.options.tokens || [];
+ this.options.frequency = this.options.frequency || 0.4;
+ this.options.minChars = this.options.minChars || 1;
+ this.options.onShow = this.options.onShow ||
+ function(element, update){
+ if(!update.style.position || update.style.position=='absolute') {
+ update.style.position = 'absolute';
+ Position.clone(element, update, {
+ setHeight: false,
+ offsetTop: element.offsetHeight
+ Effect.Appear(update,{duration:0.15});
+ this.options.onHide = this.options.onHide ||
+ function(element, update){ new Effect.Fade(update,{duration:0.15}) };
+ if(typeof(this.options.tokens) == 'string')
+ this.options.tokens = new Array(this.options.tokens);
+ this.observer = null;
+ this.element.setAttribute('autocomplete','off');
+ Element.hide(this.update);
+ Event.observe(this.element, "blur", this.onBlur.bindAsEventListener(this));
+ Event.observe(this.element, "keypress", this.onKeyPress.bindAsEventListener(this));
+ show: function() {
+ if(Element.getStyle(this.update, 'display')=='none') this.options.onShow(this.element, this.update);
+ if(!this.iefix &&
+ (navigator.appVersion.indexOf('MSIE')>0) &&
+ (navigator.userAgent.indexOf('Opera')<0) &&
+ (Element.getStyle(this.update, 'position')=='absolute')) {
+ new Insertion.After(this.update,
+ '<iframe id="' + this.update.id + '_iefix" '+
+ 'style="display:none;position:absolute;filter:progid:DXImageTransform.Microsoft.Alpha(opacity=0);" ' +
+ 'src="javascript:false;" frameborder="0" scrolling="no"></iframe>');
+ this.iefix = $(this.update.id+'_iefix');
+ if(this.iefix) setTimeout(this.fixIEOverlapping.bind(this), 50);
+ fixIEOverlapping: function() {
+ Position.clone(this.update, this.iefix, {setTop:(!this.update.style.height)});
+ this.iefix.style.zIndex = 1;
+ this.update.style.zIndex = 2;
+ Element.show(this.iefix);
+ hide: function() {
+ this.stopIndicator();
+ if(Element.getStyle(this.update, 'display')!='none') this.options.onHide(this.element, this.update);
+ if(this.iefix) Element.hide(this.iefix);
+ startIndicator: function() {
+ if(this.options.indicator) Element.show(this.options.indicator);
+ stopIndicator: function() {
+ if(this.options.indicator) Element.hide(this.options.indicator);
+ onKeyPress: function(event) {
+ if(this.active)
+ switch(event.keyCode) {
+ case Event.KEY_TAB:
+ case Event.KEY_RETURN:
+ this.selectEntry();
+ case Event.KEY_ESC:
+ this.hide();
+ return;
+ case Event.KEY_LEFT:
+ case Event.KEY_RIGHT:
+ return;
+ case Event.KEY_UP:
+ this.markPrevious();
+ this.render();
+ if(navigator.appVersion.indexOf('AppleWebKit')>0) Event.stop(event);
+ return;
+ case Event.KEY_DOWN:
+ this.markNext();
+ this.render();
+ return;
+ else
+ if(event.keyCode==Event.KEY_TAB || event.keyCode==Event.KEY_RETURN ||
+ (navigator.appVersion.indexOf('AppleWebKit') > 0 && event.keyCode == 0)) return;
+ this.changed = true;
+ this.hasFocus = true;
+ if(this.observer) clearTimeout(this.observer);
+ this.observer =
+ setTimeout(this.onObserverEvent.bind(this), this.options.frequency*1000);
+ activate: function() {
+ this.getUpdatedChoices();
+ onHover: function(event) {
+ var element = Event.findElement(event, 'LI');
+ if(this.index != element.autocompleteIndex)
+ this.index = element.autocompleteIndex;
+ this.render();
+ onClick: function(event) {
+ this.hide();
+ onBlur: function(event) {
+ // needed to make click events working
+ setTimeout(this.hide.bind(this), 250);
+ render: function() {
+ if(this.entryCount > 0) {
+ for (var i = 0; i < this.entryCount; i++)
+ this.index==i ?
+ Element.addClassName(this.getEntry(i),"selected") :
+ Element.removeClassName(this.getEntry(i),"selected");
+ if(this.hasFocus) {
+ this.show();
+ this.active = true;
+ } else {
+ this.hide();
+ markPrevious: function() {
+ if(this.index > 0) this.index--
+ else this.index = this.entryCount-1;
+ this.getEntry(this.index).scrollIntoView(true);
+ markNext: function() {
+ if(this.index < this.entryCount-1) this.index++
+ else this.index = 0;
+ this.getEntry(this.index).scrollIntoView(false);
+ getEntry: function(index) {
+ return this.update.firstChild.childNodes[index];
+ getCurrentEntry: function() {
+ return this.getEntry(this.index);
+ selectEntry: function() {
+ this.updateElement(this.getCurrentEntry());
+ updateElement: function(selectedElement) {
+ if (this.options.updateElement) {
+ this.options.updateElement(selectedElement);
+ return;
+ var value = '';
+ if (this.options.select) {
+ var nodes = document.getElementsByClassName(this.options.select, selectedElement) || [];
+ if(nodes.length>0) value = Element.collectTextNodes(nodes[0], this.options.select);
+ } else
+ value = Element.collectTextNodesIgnoreClass(selectedElement, 'informal');
+ var lastTokenPos = this.findLastToken();
+ if (lastTokenPos != -1) {
+ var newValue = this.element.value.substr(0, lastTokenPos + 1);
+ var whitespace = this.element.value.substr(lastTokenPos + 1).match(/^\s+/);
+ if (whitespace)
+ newValue += whitespace[0];
+ this.element.value = newValue + value;
+ } else {
+ this.element.value = value;
+ this.element.focus();
+ if (this.options.afterUpdateElement)
+ this.options.afterUpdateElement(this.element, selectedElement);
+ updateChoices: function(choices) {
+ if(!this.changed && this.hasFocus) {
+ this.update.innerHTML = choices;
+ Element.cleanWhitespace(this.update);
+ Element.cleanWhitespace(this.update.down());
+ if(this.update.firstChild && this.update.down().childNodes) {
+ this.entryCount =
+ this.update.down().childNodes.length;
+ for (var i = 0; i < this.entryCount; i++) {
+ var entry = this.getEntry(i);
+ entry.autocompleteIndex = i;
+ this.addObservers(entry);
+ } else {
+ this.index = 0;
+ if(this.entryCount==1 && this.options.autoSelect) {
+ this.hide();
+ } else {
+ this.render();
+ addObservers: function(element) {
+ Event.observe(element, "mouseover", this.onHover.bindAsEventListener(this));
+ Event.observe(element, "click", this.onClick.bindAsEventListener(this));
+ onObserverEvent: function() {
+ if(this.getToken().length>=this.options.minChars) {
+ this.startIndicator();
+ } else {
+ this.hide();
+ getToken: function() {
+ var tokenPos = this.findLastToken();
+ if (tokenPos != -1)
+ var ret = this.element.value.substr(tokenPos + 1).replace(/^\s+/,'').replace(/\s+$/,'');
+ else
+ var ret = this.element.value;
+ return /\n/.test(ret) ? '' : ret;
+ findLastToken: function() {
+ var lastTokenPos = -1;
+ for (var i=0; i<this.options.tokens.length; i++) {
+ var thisTokenPos = this.element.value.lastIndexOf(this.options.tokens[i]);
+ if (thisTokenPos > lastTokenPos)
+ lastTokenPos = thisTokenPos;
+ return lastTokenPos;
+Ajax.Autocompleter = Class.create();
+Object.extend(Object.extend(Ajax.Autocompleter.prototype, Autocompleter.Base.prototype), {
+ initialize: function(element, update, url, options) {
+ this.baseInitialize(element, update, options);
+ this.options.asynchronous = true;
+ this.options.onComplete = this.onComplete.bind(this);
+ this.options.defaultParams = this.options.parameters || null;
+ this.url = url;
+ getUpdatedChoices: function() {
+ entry = encodeURIComponent(this.options.paramName) + '=' +
+ encodeURIComponent(this.getToken());
+ this.options.parameters = this.options.callback ?
+ this.options.callback(this.element, entry) : entry;
+ if(this.options.defaultParams)
+ this.options.parameters += '&' + this.options.defaultParams;
+ new Ajax.Request(this.url, this.options);
+ onComplete: function(request) {
+ this.updateChoices(request.responseText);
+// The local array autocompleter. Used when you'd prefer to
+// inject an array of autocompletion options into the page, rather
+// than sending out Ajax queries, which can be quite slow sometimes.
+// The constructor takes four parameters. The first two are, as usual,
+// the id of the monitored textbox, and id of the autocompletion menu.
+// The third is the array you want to autocomplete from, and the fourth
+// is the options block.
+// Extra local autocompletion options:
+// - choices - How many autocompletion choices to offer
+// - partialSearch - If false, the autocompleter will match entered
+// text only at the beginning of strings in the
+// autocomplete array. Defaults to true, which will
+// match text at the beginning of any *word* in the
+// strings in the autocomplete array. If you want to
+// search anywhere in the string, additionally set
+// the option fullSearch to true (default: off).
+// - fullSsearch - Search anywhere in autocomplete array strings.
+// - partialChars - How many characters to enter before triggering
+// a partial match (unlike minChars, which defines
+// how many characters are required to do any match
+// at all). Defaults to 2.
+// - ignoreCase - Whether to ignore case when autocompleting.
+// Defaults to true.
+// It's possible to pass in a custom function as the 'selector'
+// option, if you prefer to write your own autocompletion logic.
+// In that case, the other options above will not apply unless
+// you support them.
+Autocompleter.Local = Class.create();
+Autocompleter.Local.prototype = Object.extend(new Autocompleter.Base(), {
+ initialize: function(element, update, array, options) {
+ this.options.array = array;
+ this.updateChoices(this.options.selector(this));
+ setOptions: function(options) {
+ this.options = Object.extend({
+ choices: 10,
+ partialSearch: true,
+ partialChars: 2,
+ ignoreCase: true,
+ fullSearch: false,
+ selector: function(instance) {
+ var ret = []; // Beginning matches
+ var partial = []; // Inside matches
+ var entry = instance.getToken();
+ var count = 0;
+ for (var i = 0; i < instance.options.array.length &&
+ ret.length < instance.options.choices ; i++) {
+ var elem = instance.options.array[i];
+ var foundPos = instance.options.ignoreCase ?
+ elem.toLowerCase().indexOf(entry.toLowerCase()) :
+ elem.indexOf(entry);
+ while (foundPos != -1) {
+ if (foundPos == 0 && elem.length != entry.length) {
+ ret.push("<li><strong>" + elem.substr(0, entry.length) + "</strong>" +
+ elem.substr(entry.length) + "</li>");
+ break;
+ } else if (entry.length >= instance.options.partialChars &&
+ instance.options.partialSearch && foundPos != -1) {
+ if (instance.options.fullSearch || /\s/.test(elem.substr(foundPos-1,1))) {
+ partial.push("<li>" + elem.substr(0, foundPos) + "<strong>" +
+ elem.substr(foundPos, entry.length) + "</strong>" + elem.substr(
+ foundPos + entry.length) + "</li>");
+ break;
+ foundPos = instance.options.ignoreCase ?
+ elem.toLowerCase().indexOf(entry.toLowerCase(), foundPos + 1) :
+ elem.indexOf(entry, foundPos + 1);
+ if (partial.length)
+ ret = ret.concat(partial.slice(0, instance.options.choices - ret.length))
+ return "<ul>" + ret.join('') + "</ul>";
+ }, options || {});
+// AJAX in-place editor
+// see documentation on http://wiki.script.aculo.us/scriptaculous/show/Ajax.InPlaceEditor
+// Use this if you notice weird scrolling problems on some browsers,
+// the DOM might be a bit confused when this gets called so do this
+// waits 1 ms (with setTimeout) until it does the activation
+Field.scrollFreeActivate = function(field) {
+ setTimeout(function() {
+ Field.activate(field);
+ }, 1);
+Ajax.InPlaceEditor = Class.create();
+Ajax.InPlaceEditor.defaultHighlightColor = "#FFFF99";
+Ajax.InPlaceEditor.prototype = {
+ initialize: function(element, url, options) {
+ this.url = url;
+ paramName: "value",
+ okButton: true,
+ okText: "ok",
+ cancelLink: true,
+ cancelText: "cancel",
+ savingText: "Saving...",
+ clickToEditText: "Click to edit",
+ okText: "ok",
+ rows: 1,
+ onComplete: function(transport, element) {
+ new Effect.Highlight(element, {startcolor: this.options.highlightcolor});
+ onFailure: function(transport) {
+ alert("Error communicating with the server: " + transport.responseText.stripTags());
+ callback: function(form) {
+ return Form.serialize(form);
+ handleLineBreaks: true,
+ loadingText: 'Loading...',
+ savingClassName: 'inplaceeditor-saving',
+ loadingClassName: 'inplaceeditor-loading',
+ formClassName: 'inplaceeditor-form',
+ highlightcolor: Ajax.InPlaceEditor.defaultHighlightColor,
+ highlightendcolor: "#FFFFFF",
+ externalControl: null,
+ submitOnBlur: false,
+ ajaxOptions: {},
+ evalScripts: false
+ if(!this.options.formId && this.element.id) {
+ this.options.formId = this.element.id + "-inplaceeditor";
+ if ($(this.options.formId)) {
+ // there's already a form with that name, don't specify an id
+ this.options.formId = null;
+ if (this.options.externalControl) {
+ this.options.externalControl = $(this.options.externalControl);
+ this.originalBackground = Element.getStyle(this.element, 'background-color');
+ if (!this.originalBackground) {
+ this.originalBackground = "transparent";
+ this.element.title = this.options.clickToEditText;
+ this.onclickListener = this.enterEditMode.bindAsEventListener(this);
+ this.mouseoverListener = this.enterHover.bindAsEventListener(this);
+ this.mouseoutListener = this.leaveHover.bindAsEventListener(this);
+ Event.observe(this.element, 'click', this.onclickListener);
+ Event.observe(this.element, 'mouseover', this.mouseoverListener);
+ Event.observe(this.element, 'mouseout', this.mouseoutListener);
+ Event.observe(this.options.externalControl, 'click', this.onclickListener);
+ Event.observe(this.options.externalControl, 'mouseover', this.mouseoverListener);
+ Event.observe(this.options.externalControl, 'mouseout', this.mouseoutListener);
+ enterEditMode: function(evt) {
+ if (this.saving) return;
+ if (this.editing) return;
+ this.editing = true;
+ this.onEnterEditMode();
+ Element.hide(this.options.externalControl);
+ Element.hide(this.element);
+ this.createForm();
+ this.element.parentNode.insertBefore(this.form, this.element);
+ if (!this.options.loadTextURL) Field.scrollFreeActivate(this.editField);
+ // stop the event to avoid a page refresh in Safari
+ if (evt) {
+ Event.stop(evt);
+ return false;
+ createForm: function() {
+ this.form = document.createElement("form");
+ this.form.id = this.options.formId;
+ Element.addClassName(this.form, this.options.formClassName)
+ this.form.onsubmit = this.onSubmit.bind(this);
+ this.createEditField();
+ if (this.options.textarea) {
+ var br = document.createElement("br");
+ this.form.appendChild(br);
+ if (this.options.okButton) {
+ okButton = document.createElement("input");
+ okButton.type = "submit";
+ okButton.value = this.options.okText;
+ okButton.className = 'editor_ok_button';
+ this.form.appendChild(okButton);
+ if (this.options.cancelLink) {
+ cancelLink = document.createElement("a");
+ cancelLink.href = "javascript:void(0)";
+ cancelLink.appendChild(document.createTextNode(this.options.cancelText));
+ cancelLink.onclick = this.onclickCancel.bind(this);
+ cancelLink.className = 'editor_cancel';
+ this.form.appendChild(cancelLink);
+ hasHTMLLineBreaks: function(string) {
+ if (!this.options.handleLineBreaks) return false;
+ return string.match(/<br/i) || string.match(/<p>/i);
+ convertHTMLLineBreaks: function(string) {
+ return string.replace(/<br>/gi, "\n").replace(/<br\/>/gi, "\n").replace(/<\/p>/gi, "\n").replace(/<p>/gi, "");
+ createEditField: function() {
+ var text;
+ if(this.options.loadTextURL) {
+ text = this.options.loadingText;
+ } else {
+ text = this.getText();
+ var obj = this;
+ if (this.options.rows == 1 && !this.hasHTMLLineBreaks(text)) {
+ this.options.textarea = false;
+ var textField = document.createElement("input");
+ textField.obj = this;
+ textField.type = "text";
+ textField.name = this.options.paramName;
+ textField.value = text;
+ textField.style.backgroundColor = this.options.highlightcolor;
+ textField.className = 'editor_field';
+ var size = this.options.size || this.options.cols || 0;
+ if (size != 0) textField.size = size;
+ if (this.options.submitOnBlur)
+ textField.onblur = this.onSubmit.bind(this);
+ this.editField = textField;
+ } else {
+ this.options.textarea = true;
+ var textArea = document.createElement("textarea");
+ textArea.obj = this;
+ textArea.name = this.options.paramName;
+ textArea.value = this.convertHTMLLineBreaks(text);
+ textArea.rows = this.options.rows;
+ textArea.cols = this.options.cols || 40;
+ textArea.className = 'editor_field';
+ textArea.onblur = this.onSubmit.bind(this);
+ this.editField = textArea;
+ this.loadExternalText();
+ this.form.appendChild(this.editField);
+ getText: function() {
+ return this.element.innerHTML;
+ loadExternalText: function() {
+ Element.addClassName(this.form, this.options.loadingClassName);
+ this.editField.disabled = true;
+ new Ajax.Request(
+ this.options.loadTextURL,
+ Object.extend({
+ asynchronous: true,
+ onComplete: this.onLoadedExternalText.bind(this)
+ }, this.options.ajaxOptions)
+ onLoadedExternalText: function(transport) {
+ Element.removeClassName(this.form, this.options.loadingClassName);
+ this.editField.disabled = false;
+ this.editField.value = transport.responseText.stripTags();
+ Field.scrollFreeActivate(this.editField);
+ onclickCancel: function() {
+ this.onComplete();
+ this.leaveEditMode();
+ return false;
+ this.options.onFailure(transport);
+ if (this.oldInnerHTML) {
+ this.element.innerHTML = this.oldInnerHTML;
+ this.oldInnerHTML = null;
+ return false;
+ onSubmit: function() {
+ // onLoading resets these so we need to save them away for the Ajax call
+ var form = this.form;
+ var value = this.editField.value;
+ // do this first, sometimes the ajax call returns before we get a chance to switch on Saving...
+ // which means this will actually switch on Saving... *after* we've left edit mode causing Saving...
+ // to be displayed indefinitely
+ this.onLoading();
+ if (this.options.evalScripts) {
+ new Ajax.Request(
+ this.url, Object.extend({
+ parameters: this.options.callback(form, value),
+ onComplete: this.onComplete.bind(this),
+ onFailure: this.onFailure.bind(this),
+ asynchronous:true,
+ evalScripts:true
+ }, this.options.ajaxOptions));
+ } else {
+ new Ajax.Updater(
+ { success: this.element,
+ // don't update on failure (this could be an option)
+ failure: null },
+ if (arguments.length > 1) {
+ Event.stop(arguments[0]);
+ return false;
+ onLoading: function() {
+ this.saving = true;
+ this.removeForm();
+ this.leaveHover();
+ this.showSaving();
+ showSaving: function() {
+ this.oldInnerHTML = this.element.innerHTML;
+ this.element.innerHTML = this.options.savingText;
+ Element.addClassName(this.element, this.options.savingClassName);
+ this.element.style.backgroundColor = this.originalBackground;
+ Element.show(this.element);
+ removeForm: function() {
+ if(this.form) {
+ if (this.form.parentNode) Element.remove(this.form);
+ this.form = null;
+ enterHover: function() {
+ this.element.style.backgroundColor = this.options.highlightcolor;
+ if (this.effect) {
+ this.effect.cancel();
+ Element.addClassName(this.element, this.options.hoverClassName)
+ leaveHover: function() {
+ if (this.options.backgroundColor) {
+ this.element.style.backgroundColor = this.oldBackground;
+ Element.removeClassName(this.element, this.options.hoverClassName)
+ this.effect = new Effect.Highlight(this.element, {
+ startcolor: this.options.highlightcolor,
+ endcolor: this.options.highlightendcolor,
+ restorecolor: this.originalBackground
+ leaveEditMode: function() {
+ Element.removeClassName(this.element, this.options.savingClassName);
+ Element.show(this.options.externalControl);
+ this.editing = false;
+ this.saving = false;
+ this.onLeaveEditMode();
+ onComplete: function(transport) {
+ this.options.onComplete.bind(this)(transport, this.element);
+ onEnterEditMode: function() {},
+ onLeaveEditMode: function() {},
+ dispose: function() {
+ Event.stopObserving(this.element, 'click', this.onclickListener);
+ Event.stopObserving(this.element, 'mouseover', this.mouseoverListener);
+ Event.stopObserving(this.element, 'mouseout', this.mouseoutListener);
+ Event.stopObserving(this.options.externalControl, 'click', this.onclickListener);
+ Event.stopObserving(this.options.externalControl, 'mouseover', this.mouseoverListener);
+ Event.stopObserving(this.options.externalControl, 'mouseout', this.mouseoutListener);
+Ajax.InPlaceCollectionEditor = Class.create();
+Object.extend(Ajax.InPlaceCollectionEditor.prototype, Ajax.InPlaceEditor.prototype);
+Object.extend(Ajax.InPlaceCollectionEditor.prototype, {
+ if (!this.cached_selectTag) {
+ var selectTag = document.createElement("select");
+ var collection = this.options.collection || [];
+ var optionTag;
+ collection.each(function(e,i) {
+ optionTag = document.createElement("option");
+ optionTag.value = (e instanceof Array) ? e[0] : e;
+ if((typeof this.options.value == 'undefined') &&
+ ((e instanceof Array) ? this.element.innerHTML == e[1] : e == optionTag.value)) optionTag.selected = true;
+ if(this.options.value==optionTag.value) optionTag.selected = true;
+ optionTag.appendChild(document.createTextNode((e instanceof Array) ? e[1] : e));
+ selectTag.appendChild(optionTag);
+ }.bind(this));
+ this.cached_selectTag = selectTag;
+ this.editField = this.cached_selectTag;
+ if(this.options.loadTextURL) this.loadExternalText();
+ this.options.callback = function(form, value) {
+ return "value=" + encodeURIComponent(value);
+// Delayed observer, like Form.Element.Observer,
+// but waits for delay after last key input
+// Ideal for live-search fields
+Form.Element.DelayedObserver = Class.create();
+Form.Element.DelayedObserver.prototype = {
+ initialize: function(element, delay, callback) {
+ this.delay = delay || 0.5;
+ this.callback = callback;
+ this.timer = null;
+ this.lastValue = $F(this.element);
+ Event.observe(this.element,'keyup',this.delayedListener.bindAsEventListener(this));
+ delayedListener: function(event) {
+ if(this.lastValue == $F(this.element)) return;
+ if(this.timer) clearTimeout(this.timer);
+ this.timer = setTimeout(this.onTimerEvent.bind(this), this.delay * 1000);
+ onTimerEvent: function() {
+ this.callback(this.element, $F(this.element));
+// script.aculo.us slider.js v1.7.0, Fri Jan 19 19:16:36 CET 2007
+// Copyright (c) 2005, 2006 Marty Haught, Thomas Fuchs
+// script.aculo.us is freely distributable under the terms of an MIT-style license.
+// For details, see the script.aculo.us web site: http://script.aculo.us/
+if(!Control) var Control = {};
+Control.Slider = Class.create();
+// options:
+// axis: 'vertical', or 'horizontal' (default)
+// callbacks:
+// onChange(value)
+// onSlide(value)
+Control.Slider.prototype = {
+ initialize: function(handle, track, options) {
+ var slider = this;
+ if(handle instanceof Array) {
+ this.handles = handle.collect( function(e) { return $(e) });
+ } else {
+ this.handles = [$(handle)];
+ this.track = $(track);
+ this.axis = this.options.axis || 'horizontal';
+ this.increment = this.options.increment || 1;
+ this.step = parseInt(this.options.step || '1');
+ this.range = this.options.range || $R(0,1);
+ this.value = 0; // assure backwards compat
+ this.values = this.handles.map( function() { return 0 });
+ this.spans = this.options.spans ? this.options.spans.map(function(s){ return $(s) }) : false;
+ this.options.startSpan = $(this.options.startSpan || null);
+ this.options.endSpan = $(this.options.endSpan || null);
+ this.restricted = this.options.restricted || false;
+ this.maximum = this.options.maximum || this.range.end;
+ this.minimum = this.options.minimum || this.range.start;
+ // Will be used to align the handle onto the track, if necessary
+ this.alignX = parseInt(this.options.alignX || '0');
+ this.alignY = parseInt(this.options.alignY || '0');
+ this.trackLength = this.maximumOffset() - this.minimumOffset();
+ this.handleLength = this.isVertical() ?
+ (this.handles[0].offsetHeight != 0 ?
+ this.handles[0].offsetHeight : this.handles[0].style.height.replace(/px$/,"")) :
+ (this.handles[0].offsetWidth != 0 ? this.handles[0].offsetWidth :
+ this.handles[0].style.width.replace(/px$/,""));
+ this.disabled = false;
+ if(this.options.disabled) this.setDisabled();
+ // Allowed values array
+ this.allowedValues = this.options.values ? this.options.values.sortBy(Prototype.K) : false;
+ if(this.allowedValues) {
+ this.minimum = this.allowedValues.min();
+ this.maximum = this.allowedValues.max();
+ this.eventMouseDown = this.startDrag.bindAsEventListener(this);
+ this.eventMouseMove = this.update.bindAsEventListener(this);
+ // Initialize handles in reverse (make sure first handle is active)
+ this.handles.each( function(h,i) {
+ i = slider.handles.length-1-i;
+ slider.setValue(parseFloat(
+ (slider.options.sliderValue instanceof Array ?
+ slider.options.sliderValue[i] : slider.options.sliderValue) ||
+ slider.range.start), i);
+ Element.makePositioned(h); // fix IE
+ Event.observe(h, "mousedown", slider.eventMouseDown);
+ Event.observe(this.track, "mousedown", this.eventMouseDown);
+ this.initialized = true;
+ Event.stopObserving(this.track, "mousedown", this.eventMouseDown);
+ this.handles.each( function(h) {
+ Event.stopObserving(h, "mousedown", slider.eventMouseDown);
+ setDisabled: function(){
+ this.disabled = true;
+ setEnabled: function(){
+ getNearestValue: function(value){
+ if(this.allowedValues){
+ if(value >= this.allowedValues.max()) return(this.allowedValues.max());
+ if(value <= this.allowedValues.min()) return(this.allowedValues.min());
+ var offset = Math.abs(this.allowedValues[0] - value);
+ var newValue = this.allowedValues[0];
+ this.allowedValues.each( function(v) {
+ var currentOffset = Math.abs(v - value);
+ if(currentOffset <= offset){
+ newValue = v;
+ offset = currentOffset;
+ return newValue;
+ if(value > this.range.end) return this.range.end;
+ if(value < this.range.start) return this.range.start;
+ return value;
+ setValue: function(sliderValue, handleIdx){
+ if(!this.active) {
+ this.activeHandleIdx = handleIdx || 0;
+ this.activeHandle = this.handles[this.activeHandleIdx];
+ this.updateStyles();
+ handleIdx = handleIdx || this.activeHandleIdx || 0;
+ if(this.initialized && this.restricted) {
+ if((handleIdx>0) && (sliderValue<this.values[handleIdx-1]))
+ sliderValue = this.values[handleIdx-1];
+ if((handleIdx < (this.handles.length-1)) && (sliderValue>this.values[handleIdx+1]))
+ sliderValue = this.values[handleIdx+1];
+ sliderValue = this.getNearestValue(sliderValue);
+ this.values[handleIdx] = sliderValue;
+ this.value = this.values[0]; // assure backwards compat
+ this.handles[handleIdx].style[this.isVertical() ? 'top' : 'left'] =
+ this.translateToPx(sliderValue);
+ this.drawSpans();
+ if(!this.dragging || !this.event) this.updateFinished();
+ setValueBy: function(delta, handleIdx) {
+ this.setValue(this.values[handleIdx || this.activeHandleIdx || 0] + delta,
+ handleIdx || this.activeHandleIdx || 0);
+ translateToPx: function(value) {
+ ((this.trackLength-this.handleLength)/(this.range.end-this.range.start)) *
+ (value - this.range.start)) + "px";
+ translateToValue: function(offset) {
+ return ((offset/(this.trackLength-this.handleLength) *
+ (this.range.end-this.range.start)) + this.range.start);
+ getRange: function(range) {
+ var v = this.values.sortBy(Prototype.K);
+ range = range || 0;
+ return $R(v[range],v[range+1]);
+ minimumOffset: function(){
+ return(this.isVertical() ? this.alignY : this.alignX);
+ maximumOffset: function(){
+ (this.track.offsetHeight != 0 ? this.track.offsetHeight :
+ this.track.style.height.replace(/px$/,"")) - this.alignY :
+ (this.track.offsetWidth != 0 ? this.track.offsetWidth :
+ this.track.style.width.replace(/px$/,"")) - this.alignY);
+ isVertical: function(){
+ return (this.axis == 'vertical');
+ drawSpans: function() {
+ if(this.spans)
+ $R(0, this.spans.length-1).each(function(r) { slider.setSpan(slider.spans[r], slider.getRange(r)) });
+ if(this.options.startSpan)
+ this.setSpan(this.options.startSpan,
+ $R(0, this.values.length>1 ? this.getRange(0).min() : this.value ));
+ if(this.options.endSpan)
+ this.setSpan(this.options.endSpan,
+ $R(this.values.length>1 ? this.getRange(this.spans.length-1).max() : this.value, this.maximum));
+ setSpan: function(span, range) {
+ if(this.isVertical()) {
+ span.style.top = this.translateToPx(range.start);
+ span.style.height = this.translateToPx(range.end - range.start + this.range.start);
+ } else {
+ span.style.left = this.translateToPx(range.start);
+ span.style.width = this.translateToPx(range.end - range.start + this.range.start);
+ updateStyles: function() {
+ this.handles.each( function(h){ Element.removeClassName(h, 'selected') });
+ Element.addClassName(this.activeHandle, 'selected');
+ if(!this.disabled){
+ var handle = Event.element(event);
+ var track = handle;
+ if(track==this.track) {
+ var offsets = Position.cumulativeOffset(this.track);
+ this.event = event;
+ this.setValue(this.translateToValue(
+ (this.isVertical() ? pointer[1]-offsets[1] : pointer[0]-offsets[0])-(this.handleLength/2)
+ var offsets = Position.cumulativeOffset(this.activeHandle);
+ this.offsetX = (pointer[0] - offsets[0]);
+ this.offsetY = (pointer[1] - offsets[1]);
+ } else {
+ // find the handle (prevents issues with Safari)
+ while((this.handles.indexOf(handle) == -1) && handle.parentNode)
+ handle = handle.parentNode;
+ if(this.handles.indexOf(handle)!=-1) {
+ this.activeHandle = handle;
+ this.activeHandleIdx = this.handles.indexOf(this.activeHandle);
+ update: function(event) {
+ if(this.active) {
+ if(!this.dragging) this.dragging = true;
+ this.draw(event);
+ if(navigator.appVersion.indexOf('AppleWebKit')>0) window.scrollBy(0,0);
+ draw: function(event) {
+ pointer[0] -= this.offsetX + offsets[0];
+ pointer[1] -= this.offsetY + offsets[1];
+ this.setValue(this.translateToValue( this.isVertical() ? pointer[1] : pointer[0] ));
+ if(this.initialized && this.options.onSlide)
+ this.options.onSlide(this.values.length>1 ? this.values : this.value, this);
+ if(this.active && this.dragging) {
+ this.updateFinished();
+ updateFinished: function() {
+ if(this.initialized && this.options.onChange)
+ this.options.onChange(this.values.length>1 ? this.values : this.value, this);
+ this.event = null;
+ * $Id: jxcore.js 512 2008-03-07 21:15:45Z pspencer $
+ * Title: Jx Core
+ * Purpose:
+ * Implementation of core and base classes for Jx components.
+ * Author:
+ * Paul Spencer (pspencer at dmsolutions.ca)
+ * Copyright:
+ * Copyright © 2008, DM Solutions Group Inc.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+ * Class: Jx
+ * Jx is a global singleton object that contains the entire Jx library
+ * within it. All Jx functions, attributes and classes are accessed
+ * through the global Jx object. Jx should not create any other
+ * global variables, if you discover that it does then please report
+ * it as a bug
+/* LEAVE THIS SEMI-COLON, IT PREVENTS PROBLEMS WITH COMPRESSION */
+/* firebug console supressor for IE/Safari/Opera */
+if (!("console" in window) || !("firebug" in console)) {
+ var names = ["log", "debug", "info", "warn", "error", "assert", "dir", "dirxml",
+ "group", "groupEnd", "time", "timeEnd", "count", "trace", "profile", "profileEnd"];
+ window.console = {};
+ for (var i = 0; i < names.length; ++i) {
+ window.console[names[i]] = function() {};
+/* inspired by extjs, removes css image flicker and related problems in IE 6 */
+var ua = navigator.userAgent.toLowerCase();
+var isIE = ua.indexOf("msie") > -1,
+ isIE7 = ua.indexOf("msie 7") > -1;
+if(isIE && !isIE7) {
+ try {
+ document.execCommand("BackgroundImageCache", false, true);
+ } catch(e) {}
+/* Setup global namespace
+ * If jxcore is loaded by jx.js, then the namespace and baseURL are
+ * already established
+if (typeof Jx == 'undefined') {
+ var Jx = {};
+ * Property: {Boolean} COMBINED_CSS
+ * controls whether Jx uses a single, combined CSS file or
+ * individual ones. The combined version is used automatically
+ * if the combined or compressed version of Jx is used,
+ * otherwise separate ones are used.
+ Jx.COMBINED_CSS = true;
+ var aScripts = document.getElementsByTagName('SCRIPT');
+ for (var i=0; i<aScripts.length; i++) {
+ var s = aScripts[i].src;
+ //only check for lib/jx because we were loaded by
+ var n = s.indexOf('lib/jx');
+ if (n != -1) {
+ * Property: {String} baseURL
+ * This is the URL that Jx was loaded from, it is
+ * automatically calculated from the script tag
+ * src property that included Jx.
+ Jx.baseURL = s.substring(0,n);
+ break;
+ * Property: {Object} importRules
+ * an object containing a list of CSS files to be included
+ * to make the loaded Jx components function correctly
+Jx.importRules = {};
+Jx.importRulesIE = {};
+ * Method: addStyleSheet
+ * Individual components of Jx call this function to get their
+ * style sheets imported at run time.
+ * Parameters:
+ * styleSheet {String} the relative path to the CSS file (relative
+ * to <Jx.baseURL>).
+ * ieOnly {Boolean} if true, then the style sheet is only loaded
+ * if the browser is Internet Explorer.
+Jx.addStyleSheet = function(styleSheet, ieOnly) {
+ if (ieOnly) {
+ this.importRulesIE[styleSheet] = styleSheet;
+ } else {
+ this.importRules[styleSheet] = styleSheet;
+/* everything needs reset.css */
+Jx.addStyleSheet('reset.css');
+ * Method: applyPNGFilter
+ * Static method that applies the PNG Filter Hack for IE browsers
+ * when showing 24bit PNG's. Used automatically for img tags with
+ * a class of png24.
+ * The filter is applied using a nifty feature of IE that allows javascript to
+ * be executed as part of a CSS style rule - this ensures that the hack only
+ * gets applied on IE browsers.
+ * Parameters:
+ * object {Object} the object (img) to which the filter needs to be applied.
+Jx.applyPNGFilter = function(o) {
+ var t=Jx.baseURL + "images/a_pixel.png";
+ if( o.src != t ) {
+ var s=o.src;
+ o.src = t;
+ o.runtimeStyle.filter = "progid:DXImageTransform.Microsoft.AlphaImageLoader(src='"+s+"',sizingMethod='scale')";
+Jx.imgQueue = []; //The queue of images to be loaded
+Jx.imgLoaded = {}; //a hash table of images that have been loaded and cached
+Jx.imagesLoading = 0; //counter for number of concurrent image loads
+ * Method: addToImgQueue
+ * request that an image be set to a DOM IMG element src attribute. This puts
+ * the image into a queue and there are private methods to manage that queue
+ * and limit image loading to 2 at a time.
+Jx.addToImgQueue = function(obj) {
+ if (Jx.imgLoaded[obj.src]) {
+ //if this image was already requested (i.e. it's in cache) just set it directly
+ obj.domElement.src = obj.src;
+ } else {
+ //otherwise stick it in te queue
+ Jx.imgQueue.push(obj);
+ Jx.imgLoaded[obj.src] = true;
+ //start the queue management process
+ Jx.checkImgQueue();
+ * Method: checkImgQueue
+ * An internal method that ensures no more than 2 images are loading at a time.
+Jx.checkImgQueue = function() {
+ //console.log(this.imgQueue.length+":"+this.imagesLoading);
+ while (Jx.imagesLoading < 2 && Jx.imgQueue.length > 0) {
+ Jx.loadNextImg();
+ * Method: loadNextImg
+ * An internal method actually populate the DOM element with the image source.
+Jx.loadNextImg = function() {
+ var obj = Jx.imgQueue.shift();
+ if (obj) {
+ ++Jx.imagesLoading;
+ obj.domElement.onload = function(){--Jx.imagesLoading; Jx.checkImgQueue();};
+ obj.domElement.onerror = function(){--Jx.imagesLoading; Jx.checkImgQueue();};
+ * Class: Jx.Listener
+ * Jx.Listener is a mix-in class that performs common listener functions
+ * for objects that support listeners. It is intended to be added to
+ * existing classes using the following syntax:
+ * (code)
+ * Object.extends( MyClass.prototype, Jx.Listener.prototype)
+ * (end)
+ * The Jx.Listener class functions provide support for managing a list of
+ * listeners (add, remove) and dispatching events to listeners (processEvent).
+Jx.Listener = Class.create();
+Jx.Listener.prototype = {
+ * Method: addListener
+ * add a listener to the provided list.
+ * Parameters:
+ * list {Array} the array of listeners to add the listener to.
+ * object {Object} the object to add as a listener.
+ addListener: function (list,obj) {list.push(obj);},
+ * Method: removeListener
+ * remove a listener from the provided list.
+ * Parameters:
+ * list {Array} the array of listeners to remove the listener from.
+ * obj {Object} the object to remove as a listener.
+ removeListener: function(list,obj) {
+ for(var i=0;i<list.length;i++) {if (list[i] == obj) {list.splice(i,1); break;}}},
+ * Method: processEvent
+ * call each listener with a given method and event.
+ * Parameters:
+ * list {Array} the array of listeners to call.
+ * fnName {String} the name of a function to call on each listener.
+ * obj {Object} an object to pass to each listener.
+ processEvent: function(list,fnName,obj){list.each(function(o){if (o[fnName]) {o[fnName](obj);}});}
+ * Class: Jx.UniqueId
+ * Jx.UniqueId is used to assign unique ids to selected elements
+ * This is used to solve a problem where multiple external html
+ * fragments are loaded into the DOM via ajax at runtime. It is
+ * not always possible to ensure that every element has a unique
+ * id. This is not a problem if you are using id for CSS styling
+ * but if you are using it to access elements using $() then
+ * you may get unexpected results.
+ * Jx.UniqueId is a mix-in class. Extend an existing class to
+ * enable it to handle unique ids. Register the ids that you
+ * want to be unique and then get a reference to those objects
+ * through the interface exposed by this class.
+ * The class retrieves the elements by id by walking a dom object
+ * and retains references to each of the actual DOM objects
+ * you have registered.
+Jx.UniqueId = Class.create();
+Jx.UniqueId.prototype = {
+ * Property: {Array} uniqueIdRefs
+ * an array of references obtained from by registering ids
+ uniqueIdRefs: null,
+ * Method: initUniqueId
+ * initialize the UniqueId object. This must be called prior to
+ * calling the <registerIds> function. Typically, it is called
+ * in the constructor of an object that includes Jx.UniqueId.
+ initUniqueId: function() {
+ this.uniqueIdRefs = [];
+ * Method: deregisterIds
+ * removes all registered ids
+ deregisterIds: function() {
+ this.uniqueIdRefs.length = 0;
+ * Method: registerIds
+ * searches the domObj for each of the ids passed in and
+ * obtains a unique reference to them so that subsequent
+ * calls to <getObj> will return the right object.
+ * Parameters:
+ * aIds {Array} an array of strings containing ids of DOM elements
+ * to register.
+ * domObj {Object} an HTML element reference to search for unique
+ * ids within
+ registerIds: function (aIds, domObj) {
+ if (aIds.indexOf(domObj.id) != -1) {
+ this.uniqueIdRefs[domObj.id] = domObj;
+ for (var i=0; i<domObj.childNodes.length; i++) {
+ this.registerIds(aIds, domObj.childNodes[i]);
+ * Method: getObj
+ * return an object by id if it was previously registered
+ * Parameters:
+ * id {String} the original registered id to get the DOM object for
+ * Returns:
+ * {Object} returns an object or null if the requested id did not
+ * exist in the original DOM object or if the id was not registered.
+ getObj: function(id) {
+ return this.uniqueIdRefs[id] || null;
+ * Class: Jx.Action
+ * Jx.Action is a utility class that provides a mechanism to separate
+ * the user interface code from the implementation code for a particular
+ * piece of functionality. A Jx.Action is used primarily as the basis for
+ * clickable UI elements such as Jx.Button and Jx.MenuItem that need to
+ * execute a particular function when the user clicks them. The Jx.Action
+ * includes a mechanism for controlling the state of the action, allowing
+ * an application to enable or disable an action at any time. A single
+ * Jx.Action may be used with multiple buttons and menu items, allowing
+ * the application to easily keep various user interface elements
+ * synchronized without having to explicitly maintain all of them.
+ * A new instance of Jx.Action is created by passing a function object
+ * to the constructor. The function object may be a function name or
+ * the result of using the Prototype bind() function.
+ * For example:
+ * (code)
+ * //Example 1:
+ * //use a function reference directly
+ * function myFunction() { alert('my function'); }
+ * var action = new Jx.Action(myFunction);
+ * //Example 2:
+ * //use a function bound to an object through bind()
+ * var myClass = Class.create();
+ * myClass.prototype = {
+ * initialize: function() {this.x = 1;},
+ * getX: function() {alert(this.x); }
+ * var myInstance = new myClass();
+ * var action = new Jx.Action(myInstance.getX.bind(myInstance));
+ * (end)
+ * To enable or disable a Jx.Action (and consequently update any associated
+ * buttons or menu items), use the setEnabled([true|false]) method.
+ * For example:
+ * (code)
+ * //disable an action
+ * action.setEnabled(false);
+ * (end)
+Jx.Action = Class.create();
+Jx.Action.prototype = {
+ * Property: {Array} pcl
+ * an array of property change listeners attached to this action
+ pcl: null,
+ * Property: {Boolean} enabled
+ * whether the action (and its associated interface object) is
+ * currently enabled or not. This is controlled through the
+ * setEnabled function
+ enabled : null,
+ * Constructor: Jx.Action
+ * construct a new instance of Jx.Action that invokes a function
+ * when activated
+ * Parameters:
+ * f - {Function} the function that this action triggers
+ initialize: function(f) {
+ this.pcl = [];
+ this.enabled = true;
+ this.actionPerformed = f;
+ * Method: addPropertyChangeListener
+ * add a property change listener to this action. When the enabled
+ * state of the action changes, all property change listeners are
+ * notified through their propertyChanged method.
+ * Parameters:
+ * obj - {Object} the object to notify of property changes
+ addPropertyChangeListener: function(obj){this.addListener(this.pcl, obj);},
+ * Method: removePropertyChangeListener
+ * remove a property change listener from this action.
+ * Parameters:
+ * obj - {Object} the property change listener to remove.
+ removePropertyChangeListener: function(obj) {
+ this.removeListener(this.pcl, obj);
+ * Method: isEnabled
+ * return whether the action is currently enabled or not.
+ * Return: {Boolean}
+ isEnabled: function() {return this.enabled;},
+ * Method: setEnabled
+ * set the state of this action.
+ * Parameters:
+ * b - {Boolean} a boolean value to set enabled state of this action to.
+ setEnabled: function(b){
+ /* prevent unnecessary propogation of propertyChanged */
+ if (this.enabled == b) {
+ return;
+ this.enabled = b;
+ this.processEvent(this.pcl,'propertyChanged',this);
+ * Method: bindTo
+ * convenience function to bind an item to this action. This
+ * adds the item as a property change listener to the action
+ * and adds the action as an ActionListener to the item.
+ * Parameters:
+ * item - {Object} the object to bind the action to.
+ bindTo : function( item ) {
+ this.addPropertyChangeListener(item);
+ item.addActionListener(this);
+ * Method: unbindFrom
+ * convenience function to undo a binding between an object and
+ * this action.
+ * Parameters:
+ * item - {Object} the object to unbind from this action.
+ unbindFrom: function(item) {
+ this.removePropertyChangeListener(item);
+ item.removeActionListener(this);
+ * Method: actionPerformed
+ * placeholder function to conform to the ActionListener interface.
+ * Parameters:
+ * obj - {Object} the object that performed the action.
+ actionPerformed : function(obj) { alert('actionPerformed'); }
+Object.extend(Jx.Action.prototype, Jx.Listener.prototype);
+ * Class: Element
+ * Element is a global object provided by the prototype.js library. The
+ * functions documented here are extensions to the Element object provided
+ * by Jx to make cross-browser compatibility easier to achieve.
+Object.extend( Element, {
+ * Method: getBoxSizing
+ * return the box sizing of an element, one of 'content-box' or
+ *'border-box'.
+ * Parameters:
+ * elem - {Object} the element to get the box sizing of.
+ * Return: {String} the box sizing of the element.
+ getBoxSizing : function(elem) {
+ var result = 'content-box';
+ elem = $(elem);
+ if (elem.currentStyle || window.opera) {
+ var cm = document["compatMode"];
+ if (cm == "BackCompat" || cm == "QuirksMode") {
+ result = 'border-box';
+ } else {
+ result = 'content-box';
+ } else {
+ if (arguments.length == 0) {
+ node = document.documentElement;
+ var sizing = Element.getStyle(elem, "-moz-box-sizing");
+ if (!sizing) {
+ sizing = Element.getStyle(elem, "box-sizing");
+ result = (sizing ? sizing : 'content-box');
+ return result;
+ * Method: getContentBoxSize
+ * return the size of the content area of an element. This is the size of
+ * the element less margins, padding, and borders.
+ * Parameters:
+ * elem - {Object} the element to get the content size of.
+ * Return: {Object} an object with two properties, width and height, that
+ * are the size of the content area of the measured element.
+ getContentBoxSize : function(elem) {
+ elem = $(elem);
+ Element.toggleMeasurable(elem);
+ var w = elem.offsetWidth;
+ var h = elem.offsetHeight;
+ var padding = Element.getPaddingSize(elem);
+ var border = Element.getBorderSize(elem);
+ w = w - padding.left - padding.right - border.left - border.right;
+ h = h - padding.bottom - padding.top - border.bottom - border.top;
+ return {width: w, height: h};
+ * Method: getBorderBoxSize
+ * return the size of the border area of an element. This is the size of
+ * the element less margins.
+ * Parameters:
+ * elem - {Object} the element to get the border sizing of.
+ * are the size of the border area of the measured element.
+ getBorderBoxSize: function(elem) {
+ elem = $(elem);
+ * Method: setContentBoxSize
+ * set either or both of the width and height of an element to
+ * the provided size. This function ensures that the content
+ * area of the element is the requested size and the resulting
+ * size of the element may be larger depending on padding and
+ * borders.
+ * Parameters:
+ * elem - {Object} the element to set the content area of.
+ * size - {Object} an object with a width and/or height property that is the size to set
+ * the content area of the element to.
+ setContentBoxSize : function(elem, size) {
+ elem = $(elem);
+ if (Element.getBoxSizing(elem) == 'border-box') {
+ if (typeof size.width != 'undefined') {
+ var width = (size.width + padding.left + padding.right + border.left + border.right);
+ if (width < 0) {
+ width = 0;
+ elem.style.width = width + 'px';
+ if (typeof size.height != 'undefined') {
+ var height = (size.height + padding.top + padding.bottom + border.top + border.bottom);
+ if (height < 0) {
+ height = 0;
+ elem.style.height = height + 'px';
+ } else {
+ elem.style.width = size.width + 'px';
+ elem.style.height = size.height + 'px';
+ * Method: setBorderBoxSize
+ * the provided size. This function ensures that the border
+ * size of the element is the requested size and the resulting
+ * content areaof the element may be larger depending on padding and
+ * borders.
+ * Parameters:
+ * elem - {Object} the element to set the border size of.
+ setBorderBoxSize : function(elem, size) {
+ elem = $(elem);
+ if (Element.getBoxSizing(elem) == 'content-box') {
+ var margin = Element.getMarginSize(elem);
+ var width = (size.width - padding.left - padding.right - border.left - border.right - margin.left - margin.right);
+ if (width < 0) {
+ width = 0;
+ var height = (size.height - padding.top - padding.bottom - border.top - border.bottom - margin.top - margin.bottom);
+ if (height < 0) {
+ height = 0;
+ } else {
+ if (typeof size.width != 'undefined' && size.width >= 0) {
+ if (typeof size.height != 'undefined' && size.height >= 0) {
+ * Method: getPaddingSize
+ * returns the padding for each edge of an element
+ * Parameters:
+ * elem - {Object} The element to get the padding for.
+ * Return: {Object} an object with properties left, top, right and bottom
+ * that contain the associated padding values.
+ getPaddingSize : function (elem) {
+ elem = $(elem);
+ var l = Element.getNumber(Element.getStyle(elem, 'padding-left'));
+ var t = Element.getNumber(Element.getStyle(elem, 'padding-top'));
+ var r = Element.getNumber(Element.getStyle(elem, 'padding-right'));
+ var b = Element.getNumber(Element.getStyle(elem, 'padding-bottom'));
+ return {left:l, top:t, right: r, bottom: b};
+ * Method: getBorderSize
+ * returns the border size for each edge of an element
+ * Parameters:
+ * elem - {Object} The element to get the borders for.
+ * that contain the associated border values.
+ getBorderSize : function(elem) {
+ elem = $(elem);
+ var l = Element.getNumber(Element.getStyle(elem, 'border-left-width'));
+ var t = Element.getNumber(Element.getStyle(elem, 'border-top-width'));
+ var r = Element.getNumber(Element.getStyle(elem, 'border-right-width'));
+ var b = Element.getNumber(Element.getStyle(elem, 'border-bottom-width'));
+ * Method: getMarginSize
+ * returns the margin size for each edge of an element
+ * Parameters:
+ * elem - {Object} The element to get the margins for.
+ * that contain the associated margin values.
+ getMarginSize : function(elem) {
+ elem = $(elem);
+ var l = Element.getNumber(Element.getStyle(elem, 'margin-left'));
+ var t = Element.getNumber(Element.getStyle(elem, 'margin-top'));
+ var r = Element.getNumber(Element.getStyle(elem, 'margin-right'));
+ var b = Element.getNumber(Element.getStyle(elem, 'margin-bottom'));
+ * Method: getNumber
+ * safely parse a number and return its integer value. A NaN value
+ * returns 0. CSS size values are also parsed correctly.
+ * Parameters:
+ * n - {Mixed} the string or object to parse.
+ * Return: {Integer} the integer value that the parameter represents
+ getNumber: function(n) {
+ var result = n==null||isNaN(parseInt(n))?0:parseInt(n);
+ return result;
+ * Method: getPageDimensions
+ * return the dimensions of the browser client area.
+ * Return: {Object} an object containing a width and height property
+ * that represent the width and height of the browser client area.
+ getPageDimensions: function() {
+ return {width: Element.getInsideWindowWidth(), height: Element.getInsideWindowHeight()};
+ * Method: getInsideWindowWidth
+ * returns the width of the browser client area
+ * Return: {Integer} the width of the browser client area
+ getInsideWindowWidth: function() {
+ if (window.innerWidth) {
+ return window.innerWidth;
+ } else if (document.compatMode && document.compatMode.indexOf("CSS1") >= 0) {
+ // measure the html element's clientWidth
+ return document.body.parentElement.clientWidth;
+ } else if (document.body && document.body.clientWidth) {
+ return document.body.clientWidth;
+ return 0;
+ * Method: getInsideWindowHeight
+ * returns the height of the browser client area
+ * Return: {Integer} the height of the browser client area
+ getInsideWindowHeight: function() {
+ if (window.innerHeight) {
+ return window.innerHeight;
+ // measure the html element's clientHeight
+ return document.body.parentElement.clientHeight;
+ } else if (document.body && document.body.clientHeight) {
+ return document.body.clientHeight;
+ return 0;
+ * Method: toggleMeasurable
+ * toggles an element's display style property so it can be
+ * measured. If the element has display: none, it is
+ * changed to display: block and made temporarily visible
+ * so that it can be measured. Calling this function
+ * a second time with the same element will revert the
+ * changes. This allows an element to be measured in
+ * various ways.
+ * Parameters:
+ * elem - {Object} the element to measure.
+ toggleMeasurable: function(elem) {
+ if (Element.getStyle(elem, 'display') == 'none') {
+ elem.old = {};
+ elem.old.display = elem.style.display;
+ elem.old.visibility = elem.style.visibility;
+ elem.old.position = elem.style.position;
+ elem.style.position = 'absolute';
+ elem.style.visibility = 'hidden';
+ elem.style.display = 'block';
+ } else {
+ if (elem.old) {
+ elem.style.display = elem.old.display;
+ elem.style.visibility = elem.old.visibility;
+ elem.style.position = elem.old.position;
+ elem.old = null;
+ * Class: Jx.ContentLoader
+ * ContentLoader is a mix-in class that provides a consistent
+ * mechanism for other Jx controls to load content in one of
+ * four different ways:
+ * o using an existing element, by id
+ * o using an existing element, by object reference
+ * o using an HTML string
+ * o using a URL to get the content remotely
+Jx.ContentLoader = Class.create();
+Jx.ContentLoader.prototype = {
+ * Property: bContentLoaded
+ * tracks the load state of the content, specifically useful
+ * in the case of remote content.
+ bContentLoaded: false,
+ * Method: contentLoaded
+ * callback function that handles remote content
+ * Parameters:
+ * element - {Object} the element to put the content into
+ * options - {Object} the options that were passed to loadContent originally, only
+ * used to get the optional onContentLoaded callback function.
+ * r - {XmlHttpRequest} the XmlHttpRequest object that has the content.
+ contentLoaded: function(element, options, r) {
+ element.innerHTML = r.responseText;
+ this.bContentLoaded = true;
+ if (options.onContentLoaded) {
+ options.onContentLoaded();
+ * Method: contentLoadFailed
+ * callback function that handles failure to load remote content
+ * Parameters:
+ * used to get the optional onContentLoadedFailed callback function.
+ * r - {XmlHttpRequest} the XmlHttpRequest object that has the failure code
+ contentLoadFailed: function(options, r) {
+ this.bContentLoaded = false;
+ if (options.onContentLoadFailed) {
+ options.onContentLoadFailed();
+ * Method: loadContent
+ * triggers loading of content based on parameters passed in the
+ * options parameter. The options parameter can have the following
+ * attributes:
+ * Parameters:
+ * element - {Object} the element to insert the content into
+ * options - {Object} an object containing the attributes indicating what
+ * content to load.
+ * Options:
+ * content - {HTMLElement} an HTML element that becomes the content
+ * contentID - {String} the id of an element to use as the content
+ * contentURL - {String} URL to get the content remotely
+ * contentHTML - {String} some HTML to use as the innerHTML of the content
+ * area.
+ * onContentLoaded - {Function} a function to call when the content is
+ * loaded.
+ * onContentLoadFailed - a function object that is called if the content
+ * fails to load, primarily useful when using the contentURL method of
+ * loading content.
+ loadContent: function(element, options) {
+ options = options || {};
+ element = $(element);
+ if (options.content) {
+ element.appendChild(options.content);
+ } else if (options.contentID) {
+ var c = $(options.contentID);
+ if (c) {
+ element.appendChild(c);
+ } else if (options.contentURL) {
+ var ts = '';//'ts=' + (new Date()).getTime();
+ var a = new Ajax.Request( options.contentURL,
+ Object.extend({method:'get',
+ onSuccess:this.contentLoaded.bind(this, element, options),
+ onFailure: this.contentLoadFailed.bind(this, options),
+ requestHeaders: ['If-Modified-Since', 'Sat, 1 Jan 2000 00:00:00 GMT'],
+ parameters: ts}));
+ } else if (options.contentHTML) {
+ element.innerHTML = options.contentHTML;
+ } else {
+ if (this.bContentLoaded && options.onContentLoaded) {
+ * $Id: jxbutton.js 512 2008-03-07 21:15:45Z pspencer $
+ * Title: Jx.Button
+ * Purpose:
+ * Implementation of a generic button widget and several
+ * useful subclasses.
+ * Author:
+ * Copyright:
+ * Class: Jx.Button
+ * Jx.Button creates a clickable element in the application that is hooked
+ * to an instance of Jx.Action. When the button is clicked, it activates
+ * its associated Jx.Action instance. When the Jx.Action associated with
+ * the button is enabled or disabled, the Jx.Button updates its visual
+ * appearance to reflect the current state of the Jx.Action.
+ * Visually, a Jx.Button consists of an <A> tag that may contain either
+ * an image, a label, or both (the label appears to the right of the button
+ * if both are present). The default styles for Jx.Button expect the
+ * image to be 16 x 16 pixels, with a padding of 4px and a border of 1px
+ * which results in an element that is 26 pixels high. The width of the
+ * button automatically accomodates the image and label as required.
+ * When you construct a new instance of Jx.Button, the button does not
+ * automatically get inserted into the application. Typically a button
+ * is used as part of building another capability such as a Jx.Toolbar.
+ * However, if you want to manually insert the button into your
+ * application, you may use the domObj property of the Jx.Button instance.
+ * In this case, you will use one of the DOM manipulation functions such
+ * as appendChild, and pass button.domObj. For example:
+ * (code)
+ * var button = new Jx.Button(myAction, options);
+ * var li = $('myListItem'); //obtain a reference to a DOM element
+ * li.appendChild(button.domObj);
+ * (end)
+ * To use a Jx.Button in an application, you must first create an instance
+ * of Jx.Action and then pass it as the first parameter to the Jx.Button
+ * constructor. The second argument to a Jx.Button constructor is an options
+ * object allows configuring the button.
+ * (code)
+ * Example:
+ * function myFunc() { alert('you clicked me'); }
+ * var action = new Jx.Action(myFunc);
+ * var options = {
+ * imgPath: 'images/mybutton.png',
+ * tooltip: 'click me!',
+ * label: 'click me'
+ * var button = new Jx.Button(action, options);
+ * (end)
+Jx.addStyleSheet('button/button.css');
+Jx.Button = Class.create();
+Object.extend(Jx.Button.prototype, Jx.Listener.prototype);
+Object.extend(Jx.Button.prototype, {
+ * Property: {Array} al
+ * an array of action listeners that are attached to the button.
+ al: null,
+ * Property: {Object} domObj
+ * the HTML element that is inserted into the DOM for this button
+ domObj: null,
+ * whether the button is enabled or not. This is controlled by
+ * the Action object that the button is associated with.
+ enabled:null,
+ * Constructor: Jx.Button
+ * create a new button.
+ * Parameters:
+ * action - {Object} the action to trigger for this button.
+ * options - {Object} an object containing optional properties for this
+ * button as below.
+ * Options:
+ * image - optional. A string value that is the url to load the image to
+ * display in this button. The default styles size this image to 16 x 16.
+ * If not provided, then the button will have no icon.
+ * tooltip - optional. A string value to use as the alt/title attribute of
+ * the <A> tag that wraps the button, resulting in a tooltip that appears
+ * when the user hovers the mouse over a button in most browsers. If
+ * not provided, the button will have no tooltip.
+ * label - optional. A string value that is used as a label on the button.
+ * disabledClass - optional. A string value that is the name of a CSS class
+ * to put on the <A> tag if the button is in a disabled state. If not
+ * provided, the default class jxDisabled is used. You may provide
+ * your own class or override jxDisabled.
+ * imgClass - optional. A string value that is the name of a CSS class to
+ * put on the <IMG> element. The default value is jxButtonIcon.
+ initialize : function( action, options ) {
+ this.al = [];
+ this.action = action; //TODO move action into options
+ var imgPath = (options.imgPath || options.image) || '';
+ var tooltip = options.tooltip || '';
+ var label = options.label || '';
+ this.disabledClass = options.disabledClass || 'jxDisabled';
+ this.domA = document.createElement('a');
+ this.domA.className = 'jxButton';
+ this.domA.href='javascript:void(0)'; //make hover effects work in IE
+ this.domA.onclick = this.onclick.bindAsEventListener(this);
+ this.domA.title = tooltip;
+ this.domA.alt = tooltip;
+ var span = document.createElement('span');
+ span.className = 'jxButtonSpan';
+ this.domA.appendChild(span);
+ // if (imgPath != '') {
+ // this.domImg = document.createElement('span');
+ // this.domImg.className = 'jxButtonIcon';
+ // if (options.imageClass && options.imageClass != '') {
+ // Element.addClassName(this.domImg, options.imageClass);
+ // this.domImg.style.backgroundImage = "url("+imgPath+")";
+ // this.domImg.innerHTML = ' ';
+ // span.appendChild(this.domImg);
+ this.domLabel = document.createElement('span');
+ this.domLabel.className = 'jxButtonContent';
+ //this.domLabel.className = label != '' ? 'jxButtonLabel' : ''; //jxButtonLabel jxButtonEmptyLabel';
+ this.domLabel.innerHTML = label != '' ? label : ' ';
+ span.appendChild(this.domLabel);
+ if (label != '') {
+ Element.addClassName(this.domLabel, 'jxButtonLabel');
+ if (imgPath != '') {
+ Element.addClassName(this.domLabel, 'jxButtonIcon');
+ this.domLabel.style.backgroundImage = "url("+imgPath+")";
+ /* if this is an action button, then hook to the action */
+ if (this.action) {
+ this.action.bindTo(this);
+ this.propertyChanged(this.action);
+ this.domObj = document.createElement('div');
+ this.domObj.className = 'jxButtonContainer';
+ this.domObj.appendChild(this.domA);
+ if (options.halign && options.halign == 'left') {
+ Element.addClassName(this.domObj, 'jxButtonContentLeft');
+ if (options.valign && options.valign == 'top') {
+ Element.addClassName(this.domObj, 'jxButtonContentTop');
+ * Method: onclick
+ * triggered when the user clicks the button, processes the
+ * actionPerformed event
+ onclick : function() {
+ if (this.enabled) {
+ this.processEvent(this.al, 'actionPerformed', this);
+ return false;
+ * Method: addActionListener
+ * add an action listener to the button
+ * Parameters:
+ * obj - {Object} the object to add as an action listener
+ addActionListener: function(obj) {
+ this.addListener(this.al,obj);
+ * Method: removeActionListener
+ * remove an action listener from the button
+ * Parameters:
+ * obj - {Object} the object to remove.
+ removeActionListener : function(obj) {
+ this.removeListener(this.al, obj);
+ * Method: propertyChanged
+ * implements the PropertyChangeListener interface
+ * for handling the enabled state changing on the action
+ * associated with this button
+ * Parameters:
+ * obj - {Object} the action that is changing state
+ propertyChanged: function(obj) {
+ this.enabled = obj.isEnabled();
+ Element.removeClassName( this.domObj, this.disabledClass );
+ } else {
+ Element.addClassName( this.domObj, this.disabledClass );
+ * Method: setImage
+ * set the image of this button to a new image URL
+ * Parameters:
+ * path - {String} the new url to use as the image for this button
+ setImage: function(path) {
+ if (this.domImg) {
+ this.domImg.src = path;
+ * Method: setLabel
+ * sets the text of the button. Only works if a label was supplied
+ * when the button was constructed
+ * Parametera:
+ * label - {String} the new label for the button
+ setLabel: function(label) {
+ if (this.domLabel) {
+ this.domLabel.innerHTML = label;
+ * Method: setTooltip
+ * sets the tooltip displayed by the button
+ * Parameters:
+ * tooltip - {String} the new tooltip
+ setTooltip: function(tooltip) {
+ this.domImg.title = tooltip;
+ this.domImg.alt = tooltip;
+ * Class: Jx.Button.Flyout
+ * Flyout buttons expose a panel when the user clicks the button. The
+ * panel can have arbitrary content.
+ * The button itself does not trigger an external action. You must provide
+ * any necessary code to hook up elements in the panel to your application.
+Jx.Button.Flyout = Class.create();
+Object.extend(Jx.Button.Flyout.prototype, Jx.Button.prototype);
+Object.extend(Jx.Button.Flyout.prototype, Jx.ContentLoader.prototype);
+Object.extend(Jx.Button.Flyout.prototype, {
+ * Property: content
+ * {HTMLElement} a reference to the DOM node that contains the flyout
+ * content
+ content: null,
+ * Constructor: Jx.Button.Flyout
+ * construct a new instance of a flyout button. The single options
+ * argument takes the same parameters as <Jx.Button.initialize> plus
+ * content loading options as per <Jx.ContentLoader>.
+ * Parameters:
+ * options - {Object} an options object used to initialize the button.
+ * See <Jx.Button::Jx.Button>
+ initialize: function(options) {
+ var a = new Jx.Action(this.show.bind(this));
+ Jx.Button.prototype.initialize.apply(this, [a, options]);
+ Element.addClassName(this.domA, 'jxButtonFlyout');
+ /* iframe shim to prevent scrollbars and
+ inputs from showing through the menu */
+ this.iframe = document.createElement('iframe');
+ this.iframe.className = 'jxMenuShim';
+ this.iframe.scrolling = 'no';
+ this.iframe.frameborder = 0;
+ this.content = document.createElement('div');
+ Element.addClassName(this.content, 'jxFlyout');
+ this.loadContent(this.content, options);
+ this.domObj.appendChild(this.content);
+ this.content.style.display = 'none';
+ this.keypressWatcher = this.keypressHandler.bindAsEventListener(this);
+ this.hideWatcher = this.clickHandler.bindAsEventListener(this);
+ * Method: show
+ * Show the flyout content
+ show: function() {
+ if (!window.opera && !this.iframe.parentNode) {
+ this.content.appendChild(this.iframe);
+ this.content.style.display = 'block';
+ Event.observe(window, 'keypress', this.keypressWatcher);
+ Event.observe(document, 'click', this.hideWatcher);
+ * Method: hide
+ * Hide the flyout content
+ hide: function() {
+ Event.stopObserving(window, 'keypress', this.keypressWatcher);
+ Event.stopObserving(document, 'click', this.hideWatcher);
+ * Method: clickHandler
+ * hide flyout if the user clicks outside of the flyout
+ clickHandler: function(e) {
+ var elm = Event.element(e);
+ if (!Element.descendantOf(elm, this.domObj.parentNode)) {
+ this.hide();
+ * Method: keypressHandler
+ * hide flyout if the user presses the ESC key
+ keypressHandler: function(e) {
+ var charCode=(e.charCode)?e.charCode:e.keyCode;
+ if (charCode == Event.KEY_ESC) {
+ this.hide();
+ * Class: Jx.Button.Multi
+ * Multi buttons are used to contain multiple buttons in a drop down list
+ * where only one button is actually visible and clickable in the interface.
+ * When the user clicks the active button, it performs its normal action.
+ * The user may also click a drop-down arrow to the right of the button and
+ * access the full list of buttons. Clicking a button in the list causes
+ * that button to replace the active button in the toolbar and performs
+ * the button's regular action.
+ * Other buttons can be added to the Multi button using the <add> function.
+Jx.Button.Multi = Class.create();
+Jx.Button.Multi.prototype = {
+ * Property: {<Jx.Button>} activeButton
+ * the currently selected button
+ activeButton: null,
+ * Property: {Array} buttons
+ * an array of all available buttons
+ buttons: null,
+ * Constructor: Jx.Button.Multi
+ * construct a new instance of Jx.Button.Multi.
+ initialize: function() {
+ this.buttons = [];
+ this.tb = new Jx.Toolbar(this.content, 'right');
+ this.flyout = new Jx.Button.Flyout({content: this.content, label: ' '});
+ Element.addClassName(this.flyout.domObj.firstChild, 'jxButtonMulti');
+ //this.domObj.className = 'jxButtonMulti';
+ this.buttonContainer = document.createElement('div');
+ this.buttonContainer.className = 'jxButtonMultiContainer';
+ this.domObj.appendChild(this.buttonContainer);
+ this.domObj.appendChild(this.flyout.domObj);
+ * Method: add
+ * adds one or more buttons to the Multi button. The first button
+ * added becomes the active button initialize. This function
+ * takes a variable number of arguments, each of which is expected
+ * to be an instance of <Jx.Button>.
+ * Parameters:
+ * button - {<Jx.Button>} a <Jx.Button> instance, may be repeated in the parameter list
+ add: function() {
+ for (var i=0; i<arguments.length; i++) {
+ var theButton = arguments[i];
+ var action = new Jx.Action(this.setButton.bind(this, theButton));
+ var button = new Jx.Button(action, {});
+ var click = button.domA.onclick;
+ button.domObj = theButton.domObj.cloneNode(true);
+ button.domObj.onclick = click;
+ this.tb.add(button);
+ if (!this.activeButton) {
+ this.buttonContainer.appendChild(theButton.domObj);
+ this.activeButton = theButton;
+ * Method: setActiveButton
+ * update the menu item to be the requested button.
+ * Parameters:
+ * button - {<Jx.Button>} a <Jx.Button> instance that was added to this multi button.
+ setActiveButton: function(button) {
+ while(this.buttonContainer.childNodes.length > 0) {
+ this.buttonContainer.removeChild(this.buttonContainer.firstChild);
+ this.buttonContainer.appendChild(button.domObj);
+ * Method: setButton
+ * update the active button in the menu item, trigger the button's action
+ * and hide the flyout that contains the buttons.
+ * Parameters:
+ * button - {<Jx.Button>} The button to set as the active button
+ setButton: function(button) {
+ this.setActiveButton(button);
+ button.onclick();
+ this.flyout.hide();
+ * Class: Jx.Button.Picker
+ * A Picker button allows the user to choose an item from a list of items.
+ * The items can be any HTML element. The chosen item is placed into the
+ * menu item.
+Jx.Button.Picker = Class.create();
+Object.extend(Jx.Button.Picker.prototype, Jx.Button.Flyout.prototype);
+Object.extend(Jx.Button.Picker.prototype, {
+ * Property: {HTMLElement} ul
+ * the UL element that contains the items to pick from
+ ul: null,
+ * Property {HTMLElement} selectedItem
+ * the currently selected item
+ selectedItem: null,
+ * Constructor: Jx.Button.Picker
+ * construct a new instance of <Jx.Button.Picker>
+ Jx.Button.Flyout.prototype.initialize.apply(this, arguments);
+ this.ul = document.createElement('ul');
+ this.content.appendChild(this.ul);
+ Element.removeClassName(this.domLabel, 'jxButtonEmptyLabel');
+ * Method: add
+ * adds one or more items to the picker, passed as separate arguments.
+ * Parameters:
+ * item - {Object} can be present one or more times in the argument list. The item
+ * to be added can be a Jx object with a domObj property, a string,
+ * or an HTML element reference.
+ add: function() {
+ var thing = arguments[i];
+ if (thing.domObj) {
+ thing = thing.domObj;
+ var li = document.createElement('li');
+ var a = document.createElement('a');
+ li.appendChild(a);
+ if (typeof(thing) == 'string') {
+ a.innerHTML = thing;
+ } else {
+ a.appendChild(thing);
+ this.ul.appendChild(li);
+ if (!this.selectedItem) {
+ this.updateButton(a);
+ * handle the user selecting an item in the list
+ * Parameters:
+ * e - {Event} the event object associated with the click event
+ this.hide();
+ return;
+ var a = Event.findElement(e, 'A');
+ if (a && Element.descendantOf(a, this.ul)) {
+ this.hide();
+ * Method: updateButton
+ * updates the button to contain the picked item
+ * Parameters:
+ * a - {HTMLElement} the A tag that the user clicked on
+ updateButton: function(a) {
+ while(this.domLabel.childNodes.length > 0) {
+ this.domLabel.removeChild(this.domLabel.firstChild);
+ this.domLabel.appendChild(a.firstChild.cloneNode(true));
+ this.selectedItem = a.firstChild;
+ * $Id: jxcolor.js 512 2008-03-07 21:15:45Z pspencer $
+ * Title: Jx.Color
+ * Purpose:
+ * Implementation of a color selection panel.
+ * Author:
+ * Copyright:
+Jx.addStyleSheet('color/color.css');
+ * Class: Jx.ColorPanel
+ * A Jx.ColorPanel presents a user interface for selecting colors. Currently,
+ * the user can either enter a HEX colour value or select from a palette of
+ * web-safe colours. The user can also enter an opacity value.
+ * A Jx.ColorPanel can be embedded anywhere in a web page by appending its
+ * <Jx.ColorPanel.domObj> property to an HTML element. However, a
+ * a Jx.Button subclass is provided ( <Jx.Button.Color> ) that embeds a
+ * colour panel inside a button for easy use in toolbars.
+ * Colour changes are propogated via a colorChanged listener pattern. To
+ * be notified of changes in a Jx.ColorPanel, register a color change
+ * listener that implements a colorChanged method. For instance:
+ * (code)
+ * var colorChangeListener = {
+ * colorChanged: function(colorPanel) {
+ * alert('the color changed to: ' + colorPanel.color);
+ * var colorPanel = new Jx.ColorPanel();
+ * colorPanel.addColorChangeListener(colorChangeListener);
+ * document.getElementsByTagName('BODY')[0].appendChild(colorPanel.domObj);
+ * (end)
+Jx.ColorPanel = Class.create();
+Jx.ColorPanel.prototype = {
+ * Property: {HTMLElement} domObj
+ * the HTML element representing the color panel
+ domObj: null,
+ * Property {String} color
+ * the currently selected colour, in hex format
+ color: null,
+ * Property: {Float} alpha
+ * the current alpha value, between 0 (transparent) and 1 (opaque)
+ alpha: null,
+ * Property: {Array} ccl
+ * color change property listeners
+ ccl: null,
+ * Property: {Array} hexColors
+ * an array of valid hex values that are used to build a web-safe
+ * palette
+ hexColors: ['00', '33', '66', '99', 'CC', 'FF'],
+ * Constructor: Jx.ColorPanel
+ * initialize a new instance of Jx.ColorPanel
+ * Parameters:
+ * options - {Object} an object containing a variable list of optional initialization
+ * parameters.
+ * Options:
+ * color - a colour to initialize the panel with, defaults to #000000
+ * (black) if not specified.
+ * alpha - an alpha value to initialize the panel with, defaults to 1
+ * (opaque) if not specified.
+ this.keypressWatcher = this.keypressHandler.bind(this);
+ this.ccl = [];
+ this.color = options.color || '#000000';
+ this.alpha = options.alpha || 1;
+ this.domObj.className = 'jxColorPanel';
+ var top = document.createElement('div');
+ top.className = 'jxColorBar';
+ var d = document.createElement('div');
+ d.className = 'jxColorPreview';
+ // var img = document.createElement('img');
+ // img.src = Jx.baseURL + '/color/grid.png';
+ // d.appendChild(img);
+ this.selectedSwatch = document.createElement('div');
+ d.appendChild(this.selectedSwatch);
+ top.appendChild(d);
+ this.colorInputLabel = document.createElement('label');
+ this.colorInputLabel.className = 'jxColorLabel';
+ this.colorInputLabel.innerHTML = '#';
+ top.appendChild(this.colorInputLabel);
+ this.colorInput = document.createElement('input');
+ this.colorInput.className = 'jxHexInput';
+ this.colorInput.type = 'text';
+ this.colorInput.maxLength = 6;
+ Event.observe(this.colorInput, 'keyup', this.colorChanged.bind(this));
+ Event.observe(this.colorInput, 'blur', this.colorChanged.bind(this));
+ Event.observe(this.colorInput, 'change', this.colorChanged.bind(this));
+ top.appendChild(this.colorInput);
+ this.alphaLabel = document.createElement('label');
+ this.alphaLabel.className = 'jxAlphaLabel';
+ this.alphaLabel.innerHTML = 'alpha (%)';
+ top.appendChild(this.alphaLabel);
+ this.alphaInput = document.createElement('input');
+ this.alphaInput.className = 'jxAlphaInput';
+ this.alphaInput.type = 'text';
+ this.alphaInput.maxLength = 3;
+ Event.observe(this.alphaInput, 'keyup', this.alphaChanged.bind(this));
+ top.appendChild(this.alphaInput);
+ this.domObj.appendChild(top);
+ a.href="javascript:void(0)";
+ a.className = 'jxColorClose';
+ a.alt = 'Close';
+ a.title = 'Close';
+ Event.observe(a, 'click', this.hide.bind(this));
+ img = document.createElement('img');
+ img.className = 'png24';
+ img.src = Jx.baseURL + 'images/close.png';
+ a.appendChild(img);
+ this.domObj.appendChild(a);
+ d = document.createElement('div');
+ d.className = 'jxClearer';
+ this.domObj.appendChild(d);
+ var swatchClick = this.swatchClick.bindAsEventListener(this);
+ var swatchOver = this.swatchOver.bindAsEventListener(this);
+ var table = document.createElement('table');
+ table.className = 'jxColorGrid';
+ var tbody = document.createElement('tbody');
+ table.appendChild(tbody);
+ for (var i=0; i<12; i++) {
+ var tr = document.createElement('tr');
+ for (var j=-3; j<18; j++) {
+ var bSkip = false;
+ var r, g, b;
+ /* hacky approach to building first three columns
+ * because I couldn't find a good way to do it
+ * programmatically
+ if (j < 0) {
+ if (j == -3 || j == -1) {
+ r = g = b = 0;
+ bSkip = true;
+ } else {
+ if (i<6) {
+ r = g = b = i;
+ } else {
+ if (i == 6) {
+ r = 5; g = 0; b = 0;
+ } else if (i == 7) {
+ r = 0; g = 5; b = 0;
+ } else if (i == 8) {
+ r = 0; g = 0; b = 5;
+ } else if (i == 9) {
+ r = 5; g = 5; b = 0;
+ } else if (i == 10) {
+ r = 0; g = 5; b = 5;
+ } else if (i == 11) {
+ r = 5; g = 0; b = 5;
+ } else {
+ /* remainder of the columns are built
+ * based on the current row/column
+ r = parseInt(i/6)*3 + parseInt(j/6);
+ g = j%6;
+ b = i%6;
+ var bgColor = '#'+this.hexColors[r]+this.hexColors[g]+this.hexColors[b];
+ var td = document.createElement('td');
+ if (!bSkip) {
+ td.style.backgroundColor = bgColor;
+ if ((r > 2 && g > 2) || (r > 2 && b > 2) || (g > 2 && b > 2)) {
+ a.className = 'colorSwatch borderBlack';
+ } else {
+ a.className = 'colorSwatch borderWhite';
+ a.href = '#';
+ a.title = bgColor;
+ a.alt = bgColor;
+ a.swatchColor = bgColor;
+ a.onmouseover = swatchOver;
+ a.onclick = swatchClick;
+ td.appendChild(a);
+ } else {
+ td.className = 'emptyCell';
+ td.appendChild(span);
+ tr.appendChild(td);
+ tbody.appendChild(tr);
+ this.domObj.appendChild(table);
+ this.previewSwatch = document.createElement('div');
+ d.appendChild(this.previewSwatch);
+ this.previewSwatch.style.backgroundColor = this.color;
+ this.previewLabel = document.createElement('label');
+ this.previewLabel.className = 'jxColorLabel';
+ this.previewLabel.innerHTML = this.color;
+ this.domObj.appendChild(this.previewLabel);
+ this.updateSelected();
+ * Method: swatchOver
+ * handle the mouse moving over a colour swatch by updating the preview
+ * Parameters:
+ * e - {Event} the mousemove event object
+ swatchOver: function(e) {
+ var a = Event.element(e);
+ this.previewSwatch.style.backgroundColor = a.swatchColor;
+ this.previewLabel.innerHTML = a.swatchColor;
+ * Method: swatchClick
+ * handle mouse click on a swatch by updating the color and hiding the
+ * panel.
+ * Parameters:
+ * e - {Event} the mouseclick event object
+ swatchClick: function(e) {
+ this.color = a.swatchColor;
+ this.hide();
+ * Method: colorChanged
+ * handle the user entering a new colour value manually by updating the
+ * selected colour if the entered value is valid HEX.
+ colorChanged: function() {
+ var color = this.colorInput.value;
+ if (color.substring(0,1) == '#') {
+ color = color.substring(1);
+ if (color.toLowerCase().match(/^[0-9a-f]{6}$/)) {
+ this.color = '#' +color.toUpperCase();
+ * Method: alphaChanged
+ * handle the user entering a new alpha value manually by updating the
+ * selected alpha if the entered value is valid alpha (0-100).
+ alphaChanged: function() {
+ var alpha = this.alphaInput.value;
+ if (alpha.match(/^[0-9]{1,3}$/)) {
+ this.alpha = parseFloat(alpha/100);
+ * Method: setColor
+ * set the colour represented by this colour panel
+ * Parameters:
+ * color - {String} the new hex color value
+ setColor: function( color ) {
+ this.colorInput.value = color;
+ this.colorChanged();
+ * Method: setAlpha
+ * set the alpha represented by this colour panel
+ * Parameters:
+ * alpha - {Integer} the new alpha value (between 0 and 100)
+ setAlpha: function( alpha ) {
+ this.alphaInput.value = alpha;
+ this.alphaChanged();
+ * Method: updateSelected
+ * update the colour panel user interface based on the current
+ * colour and alpha values
+ updateSelected: function() {
+ this.selectedSwatch.style.backgroundColor = this.color;
+ this.colorInput.value = this.color.substring(1);
+ this.alphaInput.value = parseInt(this.alpha*100);
+ if (this.alpha < 1) {
+ this.selectedSwatch.style.opacity = this.alpha;
+ this.selectedSwatch.style.filter = 'Alpha(opacity='+(this.alpha*100)+')';
+ } else {
+ this.selectedSwatch.style.opacity = '';
+ this.selectedSwatch.style.filter = '';
+ this.processEvent(this.ccl,'colorChanged',this);
+ * Method: show
+ * show the panel
+ this.domObj.style.display = 'block';
+ * Method: hide
+ * hide the panel
+ this.domObj.style.display = 'none';
+ * handle the user pressing a key. If the key is the ESC key, then
+ * hide the color panel
+ * Parameters:
+ * e - {Event} The keypress event
+ this.hide();
+ * Method: addColorChangeListener
+ * add a colour change listener, an object that has a colorChanged
+ * function.
+ * Parameters:
+ * obj - {Object} The colour change listener to call when the colour changes.
+ addColorChangeListener: function(obj){this.addListener(this.ccl, obj);},
+ * Method: removeColorChangeListener
+ * remove a previously added colour change listener
+ * Parameters:
+ * obj - {Object} The colour change listener to remove
+ removeColorChangeListener: function(obj) {
+ this.removeListener(this.ccl, obj);
+Object.extend(Jx.ColorPanel.prototype, Jx.Listener.prototype);
+ * Class: Jx.Button.Color
+ * A <Jx.ColorPanel> wrapped up in a Jx.Button. The button includes a
+ * preview of the currently selected color. Clicking the button opens
+ * the color panel.
+ * Inherits From:
+ * <Jx.Button.Flyout>
+Jx.Button.Color = Class.create();
+Object.extend(Jx.Button.Color.prototype, Jx.Button.Flyout.prototype);
+Object.extend(Jx.Button.Color.prototype, {
+ * Property: { Array } colorPanel
+ * By declaring this property as an array in the prototype, the
+ * array is used for all instances making it a Class property.
+ * A <Jx.ColorPanel> instance used by all color buttons is made the
+ * first element so that only one color panel is ever created.
+ colorPanel: [],
+ * Property: {HTMLElement} swatch
+ * a div used to represent the current colour in the button.
+ swatch: null,
+ * Property: {String} color
+ * the current colour of this button in hex. We have to maintain
+ * it here because we share a colour panel with all other colour
+ * buttons
+ color: null,
+ * Property: {Integer} alpha
+ * the current alpha of this button. We have to maintain
+ * buttons
+ alpha: null,
+ ccl: null,
+ * Constructor: Jx.Button.Color
+ * initialize a new colour button.
+ * Parameters:
+ * parameters.
+ * Options:
+ options.label = options.label || ' ';
+ this.alpha = options.alpha || 100;
+ this.ccl = [];
+ if (this.colorPanel.length == 0) {
+ this.colorPanel[0] = new Jx.ColorPanel();
+ d.className = 'jxColorButtonPreview';
+ /* create a button with a label so it doesn't get an empty label class
+ and then replace the label text with the swatch */
+ Jx.Button.Flyout.prototype.initialize.apply(this, [options]);
+ Element.addClassName(this.domObj.firstChild, 'jxButtonColor');
+ this.domObj.firstChild.firstChild.insertBefore(d, this.domObj.firstChild.firstChild.firstChild);
+ this.updateSwatch();
+ * Method: show
+ * show the color panel when the user clicks the button
+ if (this.colorPanel[0].currentButton) {
+ this.colorPanel[0].currentButton.hide();
+ this.colorPanel[0].currentButton = this;
+ this.colorPanel[0].addColorChangeListener(this);
+ this.content.appendChild(this.colorPanel[0].domObj);
+ this.colorPanel[0].domObj.style.display = 'block';
+ Jx.Button.Flyout.prototype.show.apply(this, arguments);
+ /* setting these before causes an update problem when clicking on
+ * a second color button when another one is open - the color
+ * wasn't updating properly
+ this.colorPanel[0].setColor(this.color);
+ this.colorPanel[0].setAlpha(this.alpha);
+ * Method: hide
+ * hide the colour panel
+ this.colorPanel[0].removeColorChangeListener(this);
+ Jx.Button.Flyout.prototype.hide.apply(this, arguments);
+ this.colorPanel[0].currentButton = null;
+ * Parameters:
+ setColor: function(color) {
+ this.color = color;
+ * Parameters:
+ setAlpha: function(alpha) {
+ this.alpha = alpha;
+ * colorChangeListener callback function when the user changes
+ * the colour in the panel (just update the preview).
+ colorChanged: function(panel) {
+ this.color = panel.color;
+ this.alpha = panel.alpha * 100;
+ * Method: updateSwatch
+ * Update the swatch color for the current color
+ updateSwatch: function() {
+ if (this.alpha < 100) {
+ this.selectedSwatch.style.opacity = this.alpha/100;
+ this.selectedSwatch.style.filter = 'Alpha(opacity='+(this.alpha)+')';
+ } else {
+ * function.
+ * Parameters:
+ * Parameters:
+ * $Id: jxdialog.js 512 2008-03-07 21:15:45Z pspencer $
+ * Title: Jx.Dialog
+ * Purpose:
+ * Implementation of a javascript Dialog for Jx.
+ * Author:
+ * Copyright:
+Jx.addStyleSheet('dialog/dialog.css');
+ * Class: Jx.Dialog
+ * A Jx.Dialog implements a floating dialog. Dialogs represent a useful way
+ * to present users with certain information or application controls.
+ * Jx.Dialog is designed to provide the same types of features as traditional
+ * operating system dialog boxes, including:
+ * - dialogs may be modal (user must dismiss the dialog to continue) or
+ * non-modal
+ * - dialogs are moveable (user can drag the title bar to move the dialog
+ * around)
+ * - dialogs may be a fixed size or allow user resizing.
+ * - dialogs may have associated help content that is available as a slide-out
+ * help panel on the right-hand side of the dialog.
+ * Jx.Dialog uses <Jx.ContentLoader> to load content into the content area
+ * of the dialog. Refer to the <Jx.ContentLoader> documentation for details
+ * on content options. Jx.Dialog also uses <Jx.ContentLoader> to load
+ * help content, using non-standard options prefixed by 'help' instead of
+ * 'content' (see options in initialize below).
+ * (code)
+ * var dialog = new Jx.Dialog({});
+ * (end)
+ * Inherits From:
+ * <Jx.ContentLoader>, <Jx.UniqueId>
+Jx.Dialog = Class.create();
+Jx.Dialog.prototype = {
+ * Property: {Function} onClose
+ * if specified by the caller, this is a function to invoke
+ * when the dialog closes.
+ onClose : null,
+ * Property: {Function} onOpen
+ * when the dialog opens.
+ onOpen : null,
+ * Property: {Function} onChange
+ * when any input element in the dialog is changed.
+ onChange : null,
+ * Property: {String} title
+ * the text to display in the title bar of the dialog.
+ title : null,
+ * Property: {HTMLElement} content
+ * the content area element of the dialog, used to load user-
+ * specified content into.
+ content : null,
+ * Property: {HTMLElement} action
+ * the action area element of the dialog, used for buttons.
+ action : null,
+ * Property: {Object} values
+ * when dialog content is loaded, the content is inspected for input
+ * elements and a record of them is keep in this object for later
+ * reference.
+ values : null,
+ * Property: {Object} actions
+ * input elements of type 'button' and a record of them is
+ * kept in this object for later reference.
+ actions : null,
+ * Property: {Function} handler
+ * when an input of type button is clicked by the user.
+ handler : null,
+ * TODO: Jx.Dialog.bContentLoaded
+ * remove this property, it is provided by Jx.ContentLoader.
+ bContentLoaded : null,
+ * Property: {Array} zIndex
+ * class variable containing the last assigned z-index so that
+ * dialogs stack correctly.
+ zIndex: [101],
+ * Property: {Array} stack
+ * class variable containing the list of visible dialogs used to
+ * manage the z-index of non-modal dialogs. This allows the user
+ * to click a dialog and have it appear in front of other dialogs.
+ stack: [],
+ * Property: {HTMLElement} blanket
+ * modal dialogs prevent interaction with the rest of the application
+ * while they are open, this element is displayed just under the
+ * dialog to prevent the user from clicking anything.
+ blanket: null,
+ * Property: firstShow
+ * {Boolean} true if the dialog has not been made visible yet. This
+ * facilitates resizing of <Jx.Layout> managed elements in the dialog
+ firstShow: true,
+ * Property: {Boolean} modal
+ * whether or not the dialog is modal.
+ modal: true,
+ * Constructor: Jx.Dialog
+ * Construct a new instance of Jx.Dialog
+ * Parameters:
+ * options - {Object} an object containing options for the dialog.
+ * Options:
+ * onChange - (optional) {Function} a function to call if the user changes
+ * the value of any input in the dialog
+ * onClose - (optional) {Function} a function to call when the user closes
+ * the dialog
+ * onOpen - (optional) {Function} a function to call when the user opens
+ * the dialog
+ * onContentLoaded - (optional) {Function} a function to call when the
+ * content of the dialog has been loaded, used primarily with
+ * asynchronous content
+ * handler - (optional) {Function} a function to call when the user clicks
+ * on any input of type 'button' in the dialog
+ * modal - (optional) {Boolean} controls whether the dialog will be modal
+ * or not. The default is to create modal dialogs.
+ * top - (optional) {Integer} the distance in pixels to initially place
+ * the dialog from the top edge of its container. Default is 0 unless
+ * bottom is specified, in which case the top value is not used.
+ * bottom - (optional) {Integer} the distance in pixels to initially place
+ * the dialog from the bottom edge of its container. Default is null, which
+ * means that the dialog is not positioned relative to the bottom of its
+ * container. If top and bottom are specified, top is used.
+ * left - (optional) {Integer} the distance in pixels to initially place
+ * the dialog from the left edge of its container.
+ * right - (optional) {Integer} the distance in pixels to initially place
+ * the dialog from the right edge of its container. Default is null, which
+ * means that the dialog is not positioned relative to the right of its
+ * container. If left and right are specified, left is used.
+ * width - (optional) {Integer} the initial width in pixels of the dialog.
+ * The default value is 250 if not specified.
+ * height - (optional) {Integer} the initial height in pixels of the
+ * dialog. The default value is 250 if not specified.
+ * title - (optional) {String} the title of the dialog box. "New Dialog"
+ * is the default value.
+ * titleHeight - (optional) {Integer} the height, in pixels, of the
+ * dialog's title bar. The default value is 22, and works with the default
+ * dialog styles. Only change this value is you are overriding the
+ * default style of the dialog's title bar
+ * closeImg - (optional) {String} URL to an image to use for the close
+ * button in the dialog title bar area. The default value is to use
+ * the close image provided by Jx. Only override this value if you are
+ * changing the default style of the dialog's title bar.
+ * helpID - (optional) {String} passed to <Jx.ContentLoader> for loading
+ * help content.
+ * helpURL - (optional) {String} passed to <Jx.ContentLoader> for loading
+ * help content.
+ * helpHTML - (optional) {String} passed to <Jx.ContentLoader> for loading
+ * help content.
+ * help - (optional) {Object} passed to <Jx.ContentLoader> for loading
+ * help content.
+ * contentID - (optional) {String} passed to <Jx.ContentLoader> for loading
+ * dialog content.
+ * contentURL - (optional) {String} passed to <Jx.ContentLoader> for loading
+ * dialog content.
+ * contentHTML - (optional) {String} passed to <Jx.ContentLoader> for loading
+ * dialog content.
+ * content - (optional) {Object} passed to <Jx.ContentLoader> for loading
+ * dialog content.
+ * buttons - (optional) {Array} an array of strings that contain the labels
+ * for buttons to create in the Action area of the dialog.
+ * id - (optional) {String} an HTML ID to assign to the dialog, primarily
+ * used for applying CSS styles to specific dialogs
+ * parentObj - (optional) {HTMLElement} a reference to an HTML element that
+ * the dialog is to be contained by. The default value is for the dialog
+ * to be contained by the body element.
+ * resizeable - (optional) {Boolean} determines whether the dialog is
+ * resizeable by the user or not. Default is false.
+ * imageBaseUrl - (optional) {String} the path to the various dialog edge
+ * images. If not specified, then Jx.baseURL is used.
+ this.initUniqueId();
+ this.values = {};
+ this.actions = {};
+ this.handler = options.handler?options.handler:null;
+ if (options.onChange) {this.onChange = options.onChange;}
+ if (options.onClose) {this.onClose = options.onClose;}
+ if (options.onOpen) {this.onOpen = options.onOpen;}
+ if (options.onContentLoaded) {this.onContentLoaded = options.onContentLoaded;}
+ this.imageBaseUrl = options.imageBaseUrl || Jx.baseURL + "/images/";
+ if (this.imageBaseUrl.slice(-1) != '/') {
+ this.imageBaseUrl += '/';
+ this.modal = typeof options.modal == 'undefined' ? true : options.modal;
+ var w = options.width || 250;
+ var h = options.height || 250;
+ var b = (typeof options.bottom != 'undefined') ? options.bottom : null;
+ var r = (typeof options.right != 'undefined') ? options.right : null;
+ var t = (typeof options.top != 'undefined') ? options.top : (b != null ? null : 0);
+ var l = (typeof options.left != 'undefined') ? options.left : (r != null ? null : 0);
+ this.blanket = document.createElement('div');
+ this.blanket.className = 'jxDialogModal';
+ this.blanket.style.display = 'none';
+ if (!window.opera && this.modal) {
+ var iframe = document.createElement('iframe');
+ iframe.className = 'jxDialogShim';
+ iframe.scrolling = 'no';
+ iframe.frameborder = 0;
+ this.blanket.appendChild(iframe);
+ if (options.parentObj) {
+ $(options.parentObj).appendChild(this.blanket);
+ } else {
+ document.body.appendChild(this.blanket);
+ /* dragHandle is the title bar */
+ this.dragHandle = document.createElement('div');
+ this.dragHandle.innerHTML = options.title || ' ';
+ this.dragHandle.style.width = '100%';
+ var domObj = document.createElement('div');
+ domObj.className = 'jxDialogContainer';
+ this.domObj = domObj;
+ /* set the id if passed in through options */
+ if (options.id) {
+ domObj.id = options.id;
+ var dialogObj = document.createElement('div');
+ dialogObj.className = 'jxDialog';
+ this.innerDialogObj = dialogObj;
+ var titleObj = document.createElement('div');
+ titleObj.className = 'jxDialogTitle';
+ this.title = titleObj;
+ titleObj.appendChild(this.dragHandle);
+ /* element must be in the page to be measured */
+ titleObj.style.visibility = 'hidden';
+ document.getElementsByTagName('BODY')[0].appendChild(titleObj);
+ this.titleHeight = Element.getBorderBoxSize(titleObj).height;
+ document.getElementsByTagName('BODY')[0].removeChild(titleObj);
+ titleObj.style.visibility = '';
+ var contentObj = document.createElement('div');
+ contentObj.className = 'jxDialogContent';
+ this.content = contentObj;
+ domObj.appendChild(dialogObj);
+ dialogObj.appendChild(titleObj);
+ dialogObj.appendChild(contentObj);
+ new Jx.Layout(dialogObj, {width: w, height: h});
+ new Jx.Layout(titleObj, {top: 0, left: 0, right: 0, bottom: null, height: this.titleHeight, width: null});
+ /* optional 'action' area for buttons if necessary */
+ this.actionHeight = 0;
+ if (options.buttons) {
+ var actionObj = document.createElement('div');
+ actionObj.className = 'jxDialogAction';
+ actionObj.style.visibility = 'hidden';
+ document.getElementsByTagName('BODY')[0].appendChild(actionObj);
+ this.actionHeight = parseInt(Element.getStyle(actionObj, 'height'));
+ document.getElementsByTagName('BODY')[0].removeChild(actionObj);
+ actionObj.style.visibility = '';
+ dialogObj.appendChild(actionObj);
+ new Jx.Layout(actionObj, {top: null, left: 0, right: 0, bottom: 0, height: this.actionHeight, width: null});
+ this.action = actionObj;
+ this.setButtons(options.buttons);
+ new Jx.Layout(contentObj, {top: this.titleHeight, left: 0, right: 0, bottom: this.actionHeight});
+ /* build the decorations for the title bar */
+ var atag = document.createElement('a');
+ atag.href = 'javascript:void(0)';
+ atag.className = 'jxDialogCloseButton';
+ atag.onclick = this.close.bindAsEventListener(this);
+ var close = document.createElement('img');
+ if(options.closeImg) {
+ close.src = options.closeImg;
+ else {
+ close.src = this.imageBaseUrl + 'icon_close.png';
+ close.alt = 'Close Dialog';
+ close.title = 'Close Dialog';
+ atag.appendChild(close);
+ titleObj.appendChild(atag);
+ if (options.helpID || options.helpHTML || options.helpURL || options.help) {
+ /* put a button in the title bar to open help */
+ var atag2 = document.createElement('a');
+ atag2.href = 'javascript:void(0)';
+ atag2.className = 'jxDialogHelpButton';
+ atag2.onclick = this.toggleHelp.bindAsEventListener(this);
+ var help = document.createElement('img');
+ help.src = this.imageBaseUrl + 'icon_quickhelp.png';
+ help.alt = 'Help';
+ help.title = 'Help';
+ atag2.appendChild(help);
+ titleObj.appendChild(atag2);
+ /* make the help area */
+ this.help = document.createElement('div');
+ this.help.className = 'jxDialogHelp';
+ this.help.style.display = 'none';
+ this.help.isVisible = false;
+ var helpOpts = {};
+ helpOpts.contentID = options.helpID;
+ helpOpts.content = options.help;
+ helpOpts.contentURL = options.helpURL;
+ helpOpts.contentHTML = options.helpHTML;
+ helpOpts.onContentLoaded = this.onHelpContentLoaded.bind(this);
+ this.loadContent(this.help, helpOpts);
+ dialogObj.appendChild(this.help);
+ var contentOpts = {};
+ contentOpts.contentID = options.contentID;
+ contentOpts.content = options.content;
+ contentOpts.contentURL = options.contentURL;
+ contentOpts.contentHTML = options.contentHTML;
+ contentOpts.onContentLoaded = this.onDialogContentLoaded.bind(this);
+ this.loadContent(contentObj, contentOpts);
+ dialogObj.style.visibility = 'hidden';
+ document.body.appendChild(dialogObj);
+ //force an initial size calculation
+ dialogObj.resize();
+ /* the outer box needs to be sized to the border box size plus margins
+ * of the inner box.
+ this.dialogBoxSize = Element.getBorderBoxSize(dialogObj);
+ this.dialogBoxMargins = Element.getMarginSize(dialogObj);
+ var containerSize = {width: this.dialogBoxSize.width, height: this.dialogBoxSize.height};
+ containerSize.width += this.dialogBoxMargins.left + this.dialogBoxMargins.right;
+ containerSize.height += this.dialogBoxMargins.top + this.dialogBoxMargins.bottom;
+ document.body.removeChild(dialogObj);
+ dialogObj.style.visibility = '';
+ /* now create overall container with the correct size */
+ domObj.style.display = "none";
+ Element.setBorderBoxSize(domObj, {width:(containerSize.width), height:(containerSize.height)});
+ domObj.style.position = 'absolute';
+ if (t != null) {
+ domObj.style.top = (t) + 'px';
+ } else {
+ domObj.style.bottom = (b) + 'px';
+ if (l != null) {
+ domObj.style.left = (l) + 'px';
+ } else {
+ domObj.style.right = (r) + 'px';
+ $(options.parentObj).appendChild(domObj);
+ } else {
+ document.body.appendChild(domObj);
+ /* Background */
+ this.DTOffset = 0;
+ this.DBOffset = 0;
+ this.DROffset = 0;
+ this.DLOffset = 0;
+ this.decorationOffsets = {top:0, right: 0, bottom: 0, left: 0};
+ /* top left */
+ var imgContainer = document.createElement('div');
+ imgContainer.className = 'jxDialogBgTL';
+ var img = document.createElement('img');
+ img.src = this.imageBaseUrl + 'dialog_glow_tl.png';
+ img.className = 'png24'; /* apply png hack for IE */
+ imgContainer.appendChild(img);
+ domObj.appendChild(imgContainer);
+ this.decorationOffsets.top += parseInt(Element.getStyle(img,'width'));
+ this.decorationOffsets.left += parseInt(Element.getStyle(img,'height'));
+ /* top right */
+ imgContainer = document.createElement('div');
+ imgContainer.className = 'jxDialogBgTR';
+ img.src = this.imageBaseUrl + 'dialog_glow_tr.png';
+ this.decorationOffsets.right += parseInt(Element.getStyle(img,'height'));
+ /* bottom right */
+ imgContainer.className = 'jxDialogBgBR';
+ img.src = this.imageBaseUrl + 'dialog_glow_br.png';
+ this.decorationOffsets.bottom += parseInt(Element.getStyle(img,'width'));
+ /* bottom left */
+ imgContainer.className = 'jxDialogBgBL';
+ img.src = this.imageBaseUrl + 'dialog_glow_bl.png';
+ /* top */
+ imgContainer.className = 'jxDialogBgT';
+ img.src = this.imageBaseUrl + 'dialog_glow_t.png';
+ img.style.width = containerSize.width-this.decorationOffsets.top + 'px';
+ this.topImg = img;
+ /* bottom */
+ imgContainer.className = 'jxDialogBgB';
+ img.src = this.imageBaseUrl + 'dialog_glow_b.png';
+ img.style.width = containerSize.width-this.decorationOffsets.bottom + 'px';
+ this.bottomImg = img;
+ /* left */
+ imgContainer.className = 'jxDialogBgL';
+ img.src = this.imageBaseUrl + 'dialog_glow_l.png';
+ img.style.height = containerSize.height-this.decorationOffsets.left + 'px';
+ this.leftImg = img;
+ /* right */
+ imgContainer.className = 'jxDialogBgR';
+ img.src = this.imageBaseUrl + 'dialog_glow_r.png';
+ img.style.height = containerSize.height-this.decorationOffsets.right + 'px';
+ this.rightImg = img;
+ Event.observe(domObj, 'mousedown', this.mouseDown.bind(this));
+ Event.observe(this.title, 'mousedown', this.mouseDown.bind(this));
+ if (options.resizeable) {
+ this.resizeHandle = document.createElement('div');
+ this.resizeHandle.className = 'jxDialogResize';
+ this.resizeHandle.style.position = 'absolute'; //required for Draggable
+ this.domObj.appendChild(this.resizeHandle);
+ this.resizeHandleSize = {width:parseInt(Element.getStyle(this.resizeHandle,'width')),
+ height:parseInt(Element.getStyle(this.resizeHandle,'height'))};
+ this.resizeHandle.style.top = (containerSize.height-this.resizeHandleSize.height) + 'px';
+ this.resizeHandle.style.left = (containerSize.width-this.resizeHandleSize.width) + 'px';
+ new Draggable(this.resizeHandle, {starteffect: false, endeffect: false,change:this.ondrag.bind(this), zindex: 0});
+ this.bOpen = false;
+ * Method: mouseDown
+ * handle the user clicking the title area, promote the dialog to the
+ * top of the stack so it is fully visible to the user.
+ mouseDown: function() {
+ for (var i=0; i<this.stack.length; i++) {
+ if (this.stack[i] == this) {
+ this.stack.splice(i, 1);
+ this.stack.push(this);
+ this.stack[i].domObj.style.zIndex = (101 + i);
+ * Method: ondrag
+ * callback function for user-resizing of the dialog
+ * Parameters:
+ * obj - {Object} a drag object that indicates what happened.
+ ondrag: function(obj) {
+ this.mouseDown();
+ var delta = obj.currentDelta();
+ //delta is top/left of resize image. Bottom/right of the dialog needs to be
+ //adjusted for size of image (20x20).
+ var deltaX = delta[0] + this.resizeHandleSize.width;
+ var deltaY = delta[1] + this.resizeHandleSize.height;
+ this.resize({width: deltaX, height: deltaY});
+ * Method: resize
+ * programmatically resize the dialog in either or both dimensions
+ * Parameters:
+ * newSize - {Object} an object containing either or both 'width' and 'height' properties
+ * that hold the new width or height in pixels
+ resize: function(newSize) {
+ /* let jxLayout manage the internal stuff */
+ this.innerDialogObj.resize(newSize);
+ /* sizing logic for container
+ * we need to set the size of this.innerDialogObj to the requested size
+ * then size the title, content and action area within it and expand
+ * this.domObj to contain it properly. Then we need to position the
+ * images appropriately too.
+ if (newSize.width) {
+ var outerWidth = newSize.width;
+ Element.setBorderBoxSize(this.domObj, {width: outerWidth});
+ Element.setBorderBoxSize(this.topImg, {width:outerWidth-this.decorationOffsets.top});
+ Element.setBorderBoxSize(this.bottomImg, {width:outerWidth-this.decorationOffsets.bottom});
+ if (newSize.height) {
+ var outerHeight = newSize.height;
+ Element.setBorderBoxSize(this.domObj, {height: outerHeight});
+ Element.setBorderBoxSize(this.leftImg, {height:outerHeight-this.decorationOffsets.left});
+ Element.setBorderBoxSize(this.rightImg, {height:outerHeight-this.decorationOffsets.right});
+ if (this.help) {
+ Element.setBorderBoxSize(this.help, {height:newSize.height - this.titleHeight});
+ * Method: setTitle
+ * set the text of the dialog title.
+ * Parameters:
+ * title - {String} the new title
+ setTitle: function( title ) {
+ this.title.childNodes[0].innerHTML = title;
+ * Method: setButtons
+ * create buttons in the action area of the dialog
+ * Parameters:
+ * buttons - {Array} an array of strings containing the labels to place on the
+ * buttons. One button is created for each label.
+ setButtons: function(buttons) {
+ this.action.innerHTML = '';
+ for (var i=0; i<buttons.length;i++) {
+ var button = document.createElement('input');
+ button.id = buttons[i];
+ button.type = 'button';
+ button.className = 'normalButton';
+ button.name = buttons[i];
+ button.value = buttons[i];
+ button.onclick = this.buttonHandler.bind(this, button);
+ this.action.appendChild(button);
+ this.uniqueIdRefs[button.id] = button;
+ * Method: processInputs
+ * look through the DOM obj for nodes of type INPUT and register
+ * for events on them.
+ * Parameters:
+ * obj - {HTMLElement} the DOM obj to process
+ processInputs : function(obj) {
+ for (var i=0;i<obj.childNodes.length; i++) {
+ var node = obj.childNodes[i];
+ if (node.tagName == 'INPUT' || node.tagName == 'SELECT' || node.tagName == 'TEXTAREA') {
+ if (node.type == 'button') {
+ this.actions[node.id] = node;
+ node.onclick = this.buttonHandler.bind(this, node);
+ } else {
+ this.values[node.id] = node;
+ if (this.onChange) {
+ node.onchange = this.onChangeHandler.bind(this, node);
+ } else {
+ if (node.childNodes) {
+ this.processInputs(node);
+ * Method: buttonHandler
+ * handle button events, dispatching to user handler if required.
+ * Parameters:
+ * input - {HTMLElement} the input element that triggered a click event
+ * event - {Event} the event object
+ buttonHandler : function(input, event) {
+ if (this.handler) {
+ this.handler(input.value, this);
+ * Method: onChangeHandler
+ * handle onchange events, dispatching to user handler if required.
+ * Parameters:
+ * input - {HTMLElement} the input element that triggered an onchange event
+ onChangeHandler: function(input, event) {
+ this.onChange(input, this);
+ * Method: getValue
+ * retrieve the value of an input element in the dialog. This is done
+ * safely so depending on the type of the input.
+ * Parameters:
+ * name - {String} the id of the element to get the value of
+ * Returns: {String} the value or an empty string.
+ getValue : function( name ) {
+ var result = '';
+ var input = this.values[name];
+ if (input) {
+ switch (input.tagName) {
+ case 'INPUT':
+ result = input.value;
+ break;
+ case 'SELECT':
+ result = input.options[input.selectedIndex].value;
+ return result;
+ * Method: setValue
+ * set the value of an input element in the dialog. This is done
+ * safely depending on the type of the input.
+ * Parameters:
+ * name - {String} the id of the element to set the value of
+ * value - {String} the value to set
+ setValue : function( name, value ) {
+ if (typeof this.values[name] != 'undefined') {
+ if (this.values[name].type == 'text' || this.values[name].type == 'hidden') {
+ this.values[name].value = value;
+ * Method: show
+ * show the dialog
+ show : function( ) {
+ if (this.modal) {
+ this.blanket.style.zIndex = this.zIndex[0]++;
+ this.blanket.style.visibility = 'visible';
+ this.blanket.style.display = 'block';
+ this.domObj.style.zIndex = this.zIndex[0]++;
+ Effect.Appear(this.domObj, {duration: 0.1});
+ new Draggable(this.domObj, {handle:this.dragHandle, starteffect: false, endeffect: false});
+ this.content.resize({forceResize: this.firstShow});
+ this.firstShow = false;
+ * Method: hide
+ * hide the dialog
+ hide : function() {
+ this.stack.splice(i,1);
+ this.zIndex[0]--;
+ Effect.Fade(this.domObj, {duration: 0.3});
+ //this.domObj.style.display = 'none';
+ if (this.modal) {
+ this.blanket.style.visibility = 'hidden';
+ this.zIndex[0]--;
+ * Method: open
+ * open the dialog. This may be delayed depending on the
+ * asynchronous loading of dialog content. The onOpen
+ * callback function is called when the dialog actually
+ * opens
+ open: function() {
+ if (!this.bOpen) {
+ this.bOpen = true;
+ if (this.bContentLoaded) {
+ this.show();
+ if (this.onOpen) this.onOpen();
+ * Method: close
+ * close the dialog and trigger the onClose callback function
+ * if necessary
+ close: function() {
+ this.hide();
+ if (this.onClose) this.onClose();
+ * Method: onDialogContentLoaded
+ * handle the dialog content being loaded. This triggers
+ * processing of inputs and the onContentLoaded callback
+ * function (if necessary). Also, if the dialog was previously
+ * requested to be opened, this will actually open it.
+ onDialogContentLoaded : function() {
+ this.processInputs(this.content);
+ if (this.onContentLoaded) {
+ this.onContentLoaded(this);
+ if (this.bOpen) {
+ //may need to do this?
+ //window.setTimeout(this.open.bind(this),1);
+ this.open();
+ * Method: onHelpContentLoaded
+ * handle the help content being loaded.
+ onHelpContentLoaded : function() {
+ img.className = 'jxDialogHelpCloseButton png24';
+ img.src = this.imageBaseUrl + 'help_close.png';
+ img.onclick = this.toggleHelp.bind(this);
+ img.alt = 'Close Help';
+ img.title = 'Close Help';
+ this.help.appendChild(img);
+ * Method: toggleHelp
+ * show or hide the help panel.
+ toggleHelp: function() {
+ if (this.help.isVisible) {
+ Effect.Fade(this.help, {duration: 0.3});
+ } else {
+ var actionSize = this.action ? Element.getBorderBoxSize(this.action) : {width: 0, height: 0};
+ var contentSize = Element.getBorderBoxSize(this.content);
+ Element.setBorderBoxSize(this.help, {height:contentSize.height+actionSize.height});
+ Effect.Appear(this.help, {duration: 0.3});
+ this.help.isVisible = !this.help.isVisible;
+Object.extend(Jx.Dialog.prototype, Jx.UniqueId.prototype);
+Object.extend(Jx.Dialog.prototype, Jx.ContentLoader.prototype);/**
+ * $Id: jxgrid.js 512 2008-03-07 21:15:45Z pspencer $
+ * Title: Jx.Grid
+ * Purpose:
+ * Implementation of a javascript Grid control for Jx.
+ * Jx.Grid is a tabular control with convenient controls for resizing columns,
+ * sorting, and inline editing. It is created inside another element, typically a
+ * div. If the div is resizable (for instance it fills the page or there is a
+ * user control allowing it to be resized), you must call the resize() method
+ * of the grid to let it know that its container has been resized.
+ * When creating a new Jx.Grid, you can specify a number of options for the grid
+ * that control its appearance and functionality.
+ * Jx.Grid renders data that comes from an external source. This external
+ * source, called the model, must implement the following interface.
+ * *Mandatory Functions*
+ * addGridListener(l) - mandatory
+ * mandatory. This function accepts one argument, l, which is the listener
+ * to add. The model can then call the gridChanged() method on the grid
+ * listener object when something in the model changes.
+ * removeGridListener(l) - mandatory
+ * to remove. The listener should have been previously added using
+ * addGridListener.
+ * getColumnCount() - mandatory
+ * mandatory. This function returns the number of columns of data in the
+ * model as an integer value.
+ * getColumnHeaderHTML(column) - mandatory
+ * mandatory. This function returns an HTML string to be placed in the
+ * column header for the given column index.
+ * getColumnHeaderHeight() - mandatory
+ * mandatory. This function returns an integer which is the height of the
+ * column header row in pixels.
+ * getColumnWidth(column) - mandatory
+ * mandatory. This function returns an integer which is the width of the
+ * given column in pixels.
+ * getRowHeaderHTML(row) - mandatory
+ * mandatory. This function returns an HTML string to be placed in the row
+ * header for the given row index
+ * getRowHeaderWidth() - mandatory
+ * mandatory. This function returns an integer which is the width of the row
+ * header column in pixels.
+ * getRowHeight(row) - mandatory
+ * given row in pixels.
+ * getRowCount() - mandatory
+ * mandatory. This function returns the number of rows of data in the model
+ * as an integer value.
+ * getValueAt(row, column) - mandatory
+ * mandatory. This function returns an HTML string which is the text to place
+ * in the cell at the given row and column.
+ * isCellEditable(row, column) - mandatory
+ * mandatory. This function returns a boolean value to indicate if a given
+ * cell is editable by the user.
+ * *Optional Functions*
+ * setColumnWidth(column, width) - optional
+ * optional. This function is called with a column index and width in pixels
+ * when a column is resized. This function is only required if the grid
+ * allows resizeable columns.
+ * setValueAt(row, column, value) - optional
+ * optional. This function is called with the row and column of a cell and a
+ * new value for the cell. It is mandatory to provide this function if any of
+ * the cells in the model are editable.
+ * rowSelected(row) - optional
+ * optional. This function is called by the grid to indicate that the user
+ * has selected a row by clicking on the row header.
+ * columnSelected(column) - optional
+ * has selected a column by clicking on the column header.
+ * cellSelected(row, column) - optional
+ * has selected a cell by clicking on the cell in the grid.
+ * Author:
+ * Paul Spencer (pspencer at dmsolutions.ca)
+ * Copyright:
+ * Copyright © 2008, DM Solutions Group Inc.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+/* our default css styles */
+Jx.addStyleSheet('grid/grid.css');
+ * Class: Jx.Grid
+ * A tabular control that has fixed scrolling headers on the rows and columns
+ * like a spreadsheet.
+Jx.Grid = Class.create();
+Jx.Grid.prototype = {
+ domObj : null,
+ model : null,
+ * Constructor: Jx.Grid
+ * construct a new instance of Jx.Grid within the domObj
+ * Parameters:
+ * domObj - {HTMLElement} the HTML element to create the grid inside.
+ * The grid will resize to fill the domObj.
+ * options - you can specify some options as attributes of a
+ * generic object.
+ * Options:
+ * alternateRowColors - defaults to false. If set to true, then
+ * alternating CSS classes are used for rows
+ * rowHeaders - defaults to false. If set to true, then a column
+ * of row header cells are displayed.
+ * columnHeaders - defaults to false. If set to true, then a column
+ * rowSelection - defaults to false. If set to true, allow the
+ * user to select rows.
+ * cellSelection - defaults to false. If set to true, allow the
+ * user to select cells.
+ initialize : function( domObj, options ) {
+ this.domObj = $(domObj);
+ /* if this grid is the content of a Jx Panel, this will
+ allow the grid to resize when the panel resizes
+ if (!this.domObj.jxLayout) {
+ new Jx.Layout(this.domObj);
+ this.domObj.jxLayout.addSizeChangeListener(this);
+ options = options || {};
+ this.rowColObj = document.createElement('div');
+ this.rowColObj.className = 'jxGridContainer';
+ this.colObj = document.createElement('div');
+ this.colObj.className = 'jxGridContainer';
+ this.colTable = document.createElement('table');
+ this.colTable.className = 'jxGridTable';
+ this.colTableHead = document.createElement('thead');
+ this.colTable.appendChild(this.colTableHead);
+ this.colTableBody = document.createElement('tbody');
+ this.colTable.appendChild(this.colTableBody);
+ this.colObj.appendChild(this.colTable);
+ this.rowObj = document.createElement('div');
+ this.rowObj.className = 'jxGridContainer';
+ this.rowTable = document.createElement('table');
+ this.rowTable.className = 'jxGridTable';
+ this.rowTableHead = document.createElement('thead');
+ this.rowTable.appendChild(this.rowTableHead);
+ this.rowObj.appendChild(this.rowTable);
+ this.gridObj = document.createElement('div');
+ this.gridObj.className = 'jxGridContainer';
+ this.gridObj.style.overflow = 'scroll';
+ this.gridTable = document.createElement('table');
+ this.gridTable.className = 'jxGridTable';
+ this.gridTableBody = document.createElement('tbody');
+ this.gridTable.appendChild(this.gridTableBody);
+ this.gridObj.appendChild(this.gridTable);
+ this.domObj.appendChild(this.rowColObj);
+ this.domObj.appendChild(this.rowObj);
+ this.domObj.appendChild(this.colObj);
+ this.domObj.appendChild(this.gridObj);
+ this.bAlternateRowColors = options.alternateRowColors || false;
+ this.showRowHeader = options.rowHeaders || false;
+ this.showColumnHeader = options.columnHeaders || false;
+ this.rowSelection = options.rowSelection || false;
+ this.cellSelection = options.cellSelection || false;
+ Event.observe(this.gridObj, 'scroll', this.onScroll.bind(this));
+ Event.observe(this.gridObj, 'click', this.onClickGrid.bindAsEventListener(this));
+ Event.observe(this.rowObj, 'click', this.onClickRowHeader.bindAsEventListener(this));
+ Event.observe(this.colObj, 'click', this.onClickColumnHeader.bindAsEventListener(this));
+ Event.observe(this.gridObj, 'mousemove', this.onMouseMoveGrid.bindAsEventListener(this));
+ Event.observe(this.rowObj, 'mousemove', this.onMouseMoveRowHeader.bindAsEventListener(this));
+ Event.observe(this.colObj, 'mousemove', this.onMouseMoveColumnHeader.bindAsEventListener(this));
+ * Method: onScroll
+ * handle the grid scrolling by updating the position of the headers
+ onScroll: function() {
+ this.colObj.scrollLeft = this.gridObj.scrollLeft;
+ this.rowObj.scrollTop = this.gridObj.scrollTop;
+ * Method: sizeChanged
+ * Handle the container of the grid resizing
+ sizeChanged: function() {
+ this.resize();
+ * Method: resize
+ * resize the grid to fit inside its container. This involves knowing something
+ * about the model it is displaying (the height of the column header and the
+ * width of the row header) so nothing happens if no model is set
+ resize: function() {
+ if (!this.model) {
+ return;
+ /* TODO: Jx.Grid.resize
+ * if not showing column or row, should we handle the resize differently
+ var colHeight = this.showColumnHeader ? this.model.getColumnHeaderHeight() : 1;
+ var rowWidth = this.showRowHeader ? this.model.getRowHeaderWidth() : 1;
+ var size = Element.getContentBoxSize(this.domObj);
+ /* -1 because of the right/bottom borders */
+ this.rowColObj.style.width = (rowWidth - 1) + 'px';
+ this.rowColObj.style.height = (colHeight - 1) + 'px';
+ this.rowObj.style.top = (colHeight) + 'px';
+ this.rowObj.style.left = '0px';
+ this.rowObj.style.width = (rowWidth - 1) + 'px';
+ this.rowObj.style.height = (size.height - colHeight - 1) + 'px';
+ this.colObj.style.top = '0px';
+ this.colObj.style.left = (rowWidth) + 'px';
+ this.colObj.style.width = (size.width - rowWidth - 1) + 'px';
+ this.colObj.style.height = (colHeight - 1) + 'px';
+ this.gridObj.style.top = (colHeight) + 'px';
+ this.gridObj.style.left = (rowWidth) + 'px';
+ this.gridObj.style.width = (size.width - rowWidth - 1) + 'px';
+ this.gridObj.style.height = (size.height - colHeight - 1) + 'px';
+ * Method: setModel
+ * set the model for the grid to display. If a model is attached to the grid
+ * it is removed and the new model is displayed.
+ * Parameters:
+ * model - {Object} the model to use for this grid
+ setModel: function(model) {
+ if (this.model) {
+ this.model.removeGridListener(this);
+ this.model = model;
+ if (this.model) {
+ this.domObj.jxLayout.resize();
+ this.model.addGridListener(this);
+ this.createGrid();
+ this.resize();
+ } else {
+ this.destroyGrid();
+ * Method: destroyGrid
+ * destroy the contents of the grid safely
+ destroyGrid: function() {
+ var n = this.colTableHead.cloneNode(false);
+ this.colTable.replaceChild(n, this.colTableHead);
+ this.colTableHead = n;
+ n = this.colTableBody.cloneNode(false);
+ this.colTable.replaceChild(n, this.colTableBody);
+ this.colTableBody = n;
+ n = this.rowTableHead.cloneNode(false);
+ this.rowTable.replaceChild(n, this.rowTableHead);
+ this.rowTableHead = n;
+ n = this.gridTableBody.cloneNode(false);
+ this.gridTable.replaceChild(n, this.gridTableBody);
+ this.gridTableBody = n;
+ * Method: createGrid
+ * create the grid for the current model
+ createGrid: function() {
+ if (this.model) {
+ var model = this.model;
+ var nColumns = model.getColumnCount();
+ var nRows = model.getRowCount();
+ /* create header if necessary */
+ if (this.showColumnHeader) {
+ var colHeight = model.getColumnHeaderHeight();
+ var trHead = document.createElement('tr');
+ this.colTableHead.appendChild(trHead);
+ var trBody = document.createElement('tr');
+ this.colTableBody.appendChild(trBody);
+ var th = document.createElement('th');
+ th.style.width = '0px';
+ th.style.height = '0px';
+ trHead.appendChild(th);
+ th = th.cloneNode(true);
+ th.style.height = (colHeight) + 'px';
+ trBody.appendChild(th);
+ for (var i=0; i<nColumns; i++) {
+ var colWidth = model.getColumnWidth(i);
+ th = document.createElement('th');
+ th.className = 'jxGridColHeadHide';
+ th.style.width = (colWidth) + 'px';
+ var p = document.createElement('p');
+ p.style.height = '0px';
+ p.style.width = (colWidth) + 'px';
+ th.appendChild(p);
+ th.className = 'jxGridColHead';
+ th.innerHTML = model.getColumnHeaderHTML(i);
+ /* one extra column at the end for filler */
+ th.style.width = '1000px';
+ th.style.height = (colHeight - 1) + 'px';
+ if (this.showRowHeader) {
+ var rowWidth = model.getRowHeaderWidth();
+ td.style.width = '0px';
+ td.style.height = '0px';
+ th.style.width = (rowWidth) + 'px';
+ tr.appendChild(th);
+ this.rowTableHead.appendChild(tr);
+ for (var i=0; i<nRows; i++) {
+ var rowHeight = model.getRowHeight(i);
+ td.className = 'jxGridRowHeadHide';
+ td.style.height = (rowHeight)+'px';
+ p.style.width = '0px';
+ p.style.height = (rowHeight)+'px';
+ td.appendChild(p);
+ th.className = 'jxGridRowHead';
+ th.innerHTML = model.getRowHeaderHTML(i);
+ /* one extra row at the end for filler */
+ td.style.height = '1000px';
+ th.style.height = '1000px';
+ this.gridTableBody.appendChild(trBody);
+ trBody.appendChild(td);
+ td = document.createElement('td');
+ td.className = 'jxGridColHeadHide';
+ td.style.width = (colWidth) + 'px';
+ for (var j=0; j<nRows; j++) {
+ var rowHeight = model.getRowHeight(j);
+ var actualRowHeight = rowHeight;
+ this.gridTableBody.appendChild(tr);
+ td.style.height = (rowHeight) + 'px';
+ p.style.height = (rowHeight) + 'px';
+ td.className = 'jxGridCell';
+ td.innerHTML = model.getValueAt(j,i);
+ var tdSize = Element.getDimensions(td);
+ if (tdSize.height > actualRowHeight) {
+ actualRowHeight = tdSize.height;
+ /* some notes about row sizing
+ * In Safari, the height of a TR is always returned as 0
+ * In Safari, the height of any given TD is the height it would
+ * render at, not the actual height of the row
+ * In IE, the height is returned 1px bigger than any other browser
+ * Firefox just works
+ * So, for Safari, we have to measure every TD and take the highest one
+ * and if its IE, we subtract 1 from the overall height, making all
+ * browsers identical
+ * Using document.all is not a good hack for this
+ if (document.all) {
+ actualRowHeight -= 1;
+ this.setRowHeaderHeight(j, actualRowHeight);
+ /* if we apply the class before adding content, it
+ * causes a rendering error in IE (off by 1) that is 'fixed'
+ * when another class is applied to the row, causing dynamic
+ * shifting of the row heights
+ if (this.bAlternateRowColors) {
+ tr.className = (j%2) ? 'jxGridRowOdd' : 'jxGridRowEven';
+ } else {
+ tr.className = 'jxGridRowAll';
+ * Method: setRowHeaderHeight
+ * set the height of a row. This is used internally to adjust the height of
+ * the row header when cell contents wrap. A limitation of the table structure
+ * is that overflow: hidden on a td will work horizontally but not vertically
+ * Parameters:
+ * row - {Integer} the row to set the height for
+ * height - {Integer} the height to set the row (in pixels)
+ setRowHeaderHeight: function(row, height) {
+ //this.rowTableHead.childNodes[row+1].childNodes[0].style.height = (height) + 'px';
+ this.rowTableHead.childNodes[row+1].childNodes[0].childNodes[0].style.height = (height) + 'px';
+ * Method: gridChanged
+ * called through the grid listener interface when data has changed in the
+ * underlying model
+ * Parameters:
+ * model - {Object} the model that changed
+ * row - {Integer} the row that changed
+ * col - {Integer} the column that changed
+ * value - {Mixed} the new value
+ gridChanged: function(model, row, col, value) {
+ if (this.model == model) {
+ this.gridObj.childNodes[row].childNodes[col].innerHTML = value;
+ * Method: prelightRowHeader
+ * apply the jxGridRowHeaderPrelight style to the header cell of a row.
+ * This removes the style from the previously pre-lit row header.
+ * Parameters:
+ * row - {Integer} the row to pre-light the header cell of
+ prelightRowHeader: function(row) {
+ var cell = (row >= 0 && row < this.rowTableHead.rows.length-1) ? this.rowTableHead.rows[row+1].cells[1] : null;
+ if (this.prelitRowHeader != cell) {
+ if (this.prelitRowHeader) {
+ Element.removeClassName(this.prelitRowHeader, 'jxGridRowHeaderPrelight');
+ this.prelitRowHeader = cell;
+ Element.addClassName(this.prelitRowHeader, 'jxGridRowHeaderPrelight');
+ * Method: prelightColumnHeader
+ * apply the jxGridColumnHeaderPrelight style to the header cell of a column.
+ * This removes the style from the previously pre-lit column header.
+ * Parameters:
+ * col - {Integer} the column to pre-light the header cell of
+ prelightColumnHeader: function(col) {
+ if (this.colTableBody.rows.length == 0) {
+ return;
+ var cell = (col >= 0 && col < this.colTableBody.rows[0].cells.length-1) ? this.colTableBody.rows[0].cells[col+1] : null;
+ if (this.prelitColumnHeader != cell) {
+ if (this.prelitColumnHeader) {
+ Element.removeClassName(this.prelitColumnHeader, 'jxGridColumnHeaderPrelight');
+ this.prelitColumnHeader = cell;
+ Element.addClassName(this.prelitColumnHeader, 'jxGridColumnHeaderPrelight');
+ * apply the jxGridRowPrelight style to row.
+ * This removes the style from the previously pre-lit row.
+ * Parameters:
+ prelightRow: function(row) {
+ var tr = (row >= 0 && row < this.gridTableBody.rows.length-1) ? this.gridTableBody.rows[row+1] : null;
+ if (this.prelitRow != row) {
+ if (this.prelitRow) {
+ Element.removeClassName(this.prelitRow, 'jxGridRowPrelight');
+ this.prelitRow = tr;
+ if (this.prelitRow && !Element.hasClassName(this.prelitRow, 'jxGridRowSelected')) {
+ this.prelightRowHeader(row);
+ Element.addClassName(this.prelitRow, 'jxGridRowPrelight');
+ * apply the jxGridColumnPrelight style to a column.
+ * This removes the style from the previously pre-lit column.
+ * Parameters:
+ * TODO: Jx.Grid.prelightColumn
+ * Not Yet Implemented.
+ prelightColumn: function(col) {
+ /* TODO: Jx.Grid.prelightColumn
+ * implement column prelighting (possibly)
+ this.prelightColumnHeader(col);
+ * Method: prelightCell
+ * apply the jxGridCellPrelight style to a cell.
+ * This removes the style from the previously pre-lit cell.
+ * Parameters:
+ * row - {Integer} the row of the cell to pre-light
+ * col - {Integer} the column of the cell to pre-light
+ prelightCell: function(row, col) {
+ var td = (row >=0 && col >=0 && row < this.gridTableBody.rows.length - 1 && col < this.gridTableBody.rows[row+1].cells.length - 1) ? this.gridTableBody.rows[row+1].cells[col+1] : null;
+ if (this.prelitCell != td) {
+ if (this.prelitCell) {
+ Element.removeClassName(this.prelitCell, 'jxGridCellPrelight');
+ this.prelitCell = td;
+ Element.addClassName(this.prelitCell, 'jxGridCellPrelight');
+ this.prelightRow(row);
+ this.prelightColumn(col);
+ * Method: selectCell
+ * Select a cell and apply the jxGridCellSelected style to it.
+ * This deselects a previously selected cell.
+ * If the model supports cell selection, it should implement
+ * a cellSelected function to receive notification of the selection.
+ * Parameters:
+ * row - {Integer} the row of the cell to select
+ * col - {Integer} the column of the cell to select
+ selectCell: function(row, col) {
+ if (!td) {
+ return;
+ if (this.selectedCell) {
+ Element.addClassName(this.selectedCell, 'jxGridCellSelected');
+ } else {
+ Element.removeClassName(this.selectedCell, 'jxGridCellSelected');
+ * Method: selectRowHeader
+ * Apply the jxGridRowHeaderSelected style to the row header cell of a
+ * selected row.
+ * Parameters:
+ * row - {Integer} the row header to select
+ * selected - {Boolean} the new state of the row header
+ selectRowHeader: function(row, selected) {
+ if (!cell) {
+ return;
+ if (selected) {
+ Element.addClassName(cell, 'jxGridRowHeaderSelected');
+ } else {
+ Element.removeClassName(cell, 'jxGridRowHeaderSelected');
+ * Select a row and apply the jxGridRowSelected style to it.
+ * If the model supports row selection, it should implement
+ * a rowSelected function to receive notification of the selection.
+ * Parameters:
+ * row - {Integer} the row to select
+ selectRow: function(row, selected) {
+ var tr = (row >= 0 && row < this.gridTableBody.rows.length - 1) ? this.gridTableBody.rows[row+1] : null;
+ if (tr) {
+ if (selected) {
+ Element.addClassName(tr, 'jxGridRowSelected');
+ } else {
+ Element.removeClassName(tr, 'jxGridRowSelected');
+ this.selectRowHeader(row, selected);
+ * method: selectColumnHeader
+ * Apply the jxGridColumnHeaderSelected style to the column header cell of a
+ * selected column.
+ * Parameters:
+ * col - {Integer} the column header to select
+ * selected - {Boolean} the new state of the column header
+ selectColumnHeader: function(col, selected) {
+ return;
+ if (cell == null) {
+ return;
+ if (selected) {
+ Element.addClassName(cell, 'jxGridColumnHeaderSelected');
+ } else {
+ Element.removeClassName(cell, 'jxGridColumnHeaderSelected');
+ * Method: selectColumn
+ * Select a column.
+ * This deselects a previously selected column.
+ * Parameters:
+ * col - {Integer} the column to select
+ selectColumn: function(col, selected) {
+ /* todo: implement column selection */
+ if (col >= 0 && col < this.gridTable.rows[0].cells.length) {
+ if (selected) {
+ for (var i=0; i<this.gridTable.rows.length; i++) {
+ Element.removeClassName(this.gridTable.rows[i].cells[this.selectedColumn + 1], 'jxGridColumnSelected');
+ } else {
+ Element.addClassName(this.gridTable.rows[i].cells[col+1], 'jxGridColumnSelected');
+ this.selectColumnHeader(col, selected);
+ * Method: onMouseMoveGrid
+ * handle the mouse moving over the main grid. This pre-lights the cell,
+ * and subsquently the row and column (and headers).
+ * Parameters:
+ * e - {Event} the browser event object
+ onMouseMoveGrid: function(e) {
+ var rc = this.getRowColumnFromEvent(e);
+ this.prelightCell(rc.row, rc.column);
+ * Method: onMouseMoveRowHeader
+ * handle the mouse moving over the row header cells. This pre-lights
+ * the row and subsequently the row header.
+ * Parameters:
+ onMouseMoveRowHeader: function(e) {
+ this.prelightRow(rc.row);
+ * Method: onMouseMoveColumnHeader
+ * handle the mouse moving over the column header cells. This pre-lights
+ * the column and subsequently the column header.
+ * Parameters:
+ onMouseMoveColumnHeader: function(e) {
+ this.prelightColumn(rc.column);
+ * Method: onClickGrid
+ * handle the user clicking on the grid. This triggers an
+ * event to the model (if a cellSelected function is provided).
+ * The following is an example of a function in the model that selects
+ * a row when the cellSelected function is called and deselects any rows
+ * that are currently selected.
+ * (code)
+ * cellSelected: function(grid, row,col) {
+ * if (this.selectedRow != null) {
+ * grid.selectRow(this.selectedRow, false);
+ * this.selectedRow = row;
+ * grid.selectRow(row, true);
+ * Parameters:
+ onClickGrid: function(e) {
+ //this.selectCell(rc.row, rc.column);
+ if (this.model.cellSelected) {
+ this.model.cellSelected(this, rc.row, rc.column);
+ * Method: onClickRowHeader
+ * handle the user clicking on the row header. This triggers an
+ * event to the model (if a rowSelected function is provided) which
+ * can then select the row if desired.
+ * a row when the rowSelected function is called and deselects any rows
+ * that are currently selected. More complex code could be written to
+ * allow the user to select multiple rows.
+ * (code)
+ * rowSelected: function(grid, row) {
+ * (end)
+ * Parameters:
+ onClickRowHeader: function(e) {
+ if (this.model.rowSelected) {
+ this.model.rowSelected(this, rc.row);
+ * Method: onClickColumnHeader
+ * handle the user clicking on the column header. This triggers column
+ * selection and column (and header) styling changes and an
+ * event to the model (if a columnSelected function is provided)
+ * a column when the columnSelected function is called and deselects any
+ * columns that are currently selected. More complex code could be written
+ * to allow the user to select multiple columns.
+ * (code)
+ * colSelected: function(grid, col) {
+ * if (this.selectedColumn != null) {
+ * grid.selectColumn(this.selectedColumn, false);
+ * this.selectedColumn = col;
+ * grid.selectColumn(col, true);
+ * (end)
+ * Parameters:
+ onClickColumnHeader: function(e) {
+ if (this.model.columnSelected) {
+ this.model.columnSelected(this, rc.column);
+ * method: getRowColumnFromEvent
+ * retrieve the row and column indexes from an event click.
+ * This function is used by the grid, row header and column
+ * header to safely get these numbers.
+ * If the event isn't valid (i.e. it wasn't on a TD or TH) then
+ * the returned values will be -1, -1
+ * Parameters:
+ * @return Object an object with two properties, row and column,
+ * that contain the row and column that was clicked
+ getRowColumnFromEvent: function(e) {
+ var td = Event.element(e);
+ if (td.tagName != 'TD' && td.tagName != 'TH') {
+ return {row:-1,column:-1};
+ var tr = td.parentNode;
+ var col = td.cellIndex - 1; /* because of hidden spacer column */
+ var row = tr.rowIndex - 1; /* because of hidden spacer row */
+ if (col == -1) {
+ /* bug in safari returns 0 for cellIndex - only choice seems
+ * to be to loop through the row
+ for (var i=0; i<tr.childNodes.length; i++) {
+ if (tr.childNodes[i] == td) {
+ col = i - 1;
+ break;
+ return {row:row,column:col};
+ * $Id: jxlayout.js 512 2008-03-07 21:15:45Z pspencer $
+ * Title: Jx.Layout
+ * Purpose:
+ * Implementation of a javascript layout engine for Jx.
+ * Author:
+ * Copyright:
+ * Class: Jx.Layout
+ * Jx.Layout is used to provide more flexible layout options for applications
+ * Jx.Layout wraps an existing DOM element (typically a div) and provides
+ * extra functionality for sizing that element within its parent and sizing
+ * elements contained within it that have a 'resize' function attached to them.
+ * To create a Jx.Layout, pass the element or id plus an options object to
+ * the constructor:
+ * (code)
+ * var myContainer = new Jx.Layout('myDiv', options);
+ * (end)
+ * Inherits From:
+ * <Jx.Listener>
+Jx.Layout = Class.create();
+Jx.Layout.prototype = {
+ scl: null,
+ * Constructor: Jx.Layout
+ * Create a new instance of Jx.Layout.
+ * Parameters:
+ * domObj - {HTMLElement} element or id to apply the layout to
+ * options - {Object} options can be passed to the Jx.Layout as an object
+ * with some, all, or none of the options below.
+ * Options:
+ * position - how to position the element, either 'absolute' or 'relative'.
+ * The default (if not passed) is 'absolute'. When using
+ * 'absolute' positioning, both the width and height are
+ * controlled by Jx.Layout. If 'relative' positioning is used
+ * then only the width is controlled, allowing the height to
+ * be controlled by its content.
+ * left - the distance (in pixels) to maintain the left edge of the element
+ * from its parent element. The default value is 0. If this is set
+ * to 'null', then the left edge can be any distance from its parent
+ * based on other parameters.
+ * right - the distance (in pixels) to maintain the right edge of the element
+ * to 'null', then the right edge can be any distance from its parent
+ * top - the distance (in pixels) to maintain the top edge of the element
+ * to 'null', then the top edge can be any distance from its parent
+ * bottom - the distance (in pixels) to maintain the bottom edge of the element
+ * to 'null', then the bottom edge can be any distance from its parent
+ * width - the width (in pixels) of the element. The default value is null.
+ * If this is set to 'null', then the width can be any value based on
+ * other parameters.
+ * height - the height (in pixels) of the element. The default value is null.
+ * If this is set to 'null', then the height can be any value based on
+ * minWidth - the minimum width that the element can be sized to. The default
+ * value is 0.
+ * minHeight - the minimum height that the element can be sized to. The
+ * default value is 0.
+ * maxWidth - the maximum width that the element can be sized to. The default
+ * value is -1, which means no maximum.
+ * maxHeight - the maximum height that the element can be sized to. The
+ * default value is -1, which means no maximum.
+ initialize: function(domObj, options) {
+ this.options = new Jx.Constraint(options);
+ this.domObj.resize = this.resize.bind(this);
+ this.domObj.style.position = this.options.position;
+ this.domObj.jxLayout = this;
+ if (this.domObj.parentNode && this.domObj.parentNode.tagName == 'BODY') {
+ Event.observe(window, 'resize', this.windowResize.bind(this));
+ this.scl = [];
+ * Method: windowResize
+ * when the window is resized, any Jx.Layout controlled elements that are
+ * direct children of the BODY element are resized
+ windowResize: function() {
+ if (this.resizeTimer) {
+ window.clearTimeout(this.resizeTimer);
+ this.resizeTimer = null;
+ this.resizeTimer = window.setTimeout(this.resize.bind(this), 250);
+ * Method: resize
+ * resize the element controled by this Jx.Layout object.
+ * Parameters:
+ * options - new options to apply, see <Jx.Layout::Jx.Layout>
+ resize: function(options) {
+ var needsResize = false;
+ if (options) {
+ for (var i in options) {
+ if (this.options[i] != options[i]) {
+ needsResize = true;
+ this.options[i] = options[i];
+ if (options.forceResize) {
+ var parentSize;
+ if (this.domObj.parentNode.tagName == 'BODY') {
+ parentSize = Element.getPageDimensions();
+ } else {
+ parentSize = Element.getContentBoxSize(this.domObj.parentNode);
+ if (this.lastParentSize && !needsResize) {
+ needsResize = (this.lastParentSize.width != parentSize.width ||
+ this.lastParentSize.height != parentSize.height);
+ } else {
+ this.lastParentSize = parentSize;
+ if (!needsResize) {
+ return;
+ var l, t, w, h;
+ /* calculate left and width */
+ if (this.options.left != null) {
+ /* fixed left */
+ l = this.options.left;
+ if (this.options.right == null) {
+ /* variable right */
+ if (this.options.width == null) {
+ //console.log( 'fixed left, variable right, variable width' );
+ /* variable right and width
+ * set right to min, stretch width */
+ w = parentSize.width - l;
+ if (w < this.options.minWidth ) {
+ w = this.options.minWidth;
+ if (this.options.maxWidth >= 0 && w > this.options.maxWidth) {
+ w = this.options.maxWidth;
+ } else {
+ //console.log( 'fixed left, variable right, fixed width' );
+ /* variable right, fixed width
+ * use width
+ w = this.options.width;
+ } else {
+ /* fixed right */
+ //console.log( 'fixed left, fixed right, variable width' );
+ /* fixed right, variable width
+ * stretch width
+ w = parentSize.width - l - this.options.right;
+ if (w < this.options.minWidth) {
+ } else {
+ //console.log( 'fixed left, fixed right, fixed width' );
+ /* fixed right, fixed width
+ * respect left and width, allow right to stretch
+ } else {
+ //console.log( 'variable left, variable right, variable width' );
+ /* variable left, width and right
+ * set left, right to min, stretch width
+ l = 0;
+ w = parentSize.width;
+ l = l + parseInt(w - this.options.maxWidth)/2;
+ } else {
+ //console.log( 'variable left, variable right, fixed width' );
+ /* variable left, fixed width, variable right
+ * distribute space between left and right
+ l = parseInt((parentSize.width - w)/2);
+ if (l < 0) {
+ l = 0;
+ } else {
+ if (this.options.width != null) {
+ //console.log( 'variable left, fixed right, fixed width' );
+ /* variable left, fixed width, fixed right
+ * left is calculated directly
+ l = parentSize.width - w - this.options.right;
+ if (l < 0) {
+ l = 0;
+ } else {
+ //console.log( 'variable left, fixed right, variable width' );
+ /* variable left and width, fixed right
+ * set left to min value and stretch width
+ l = 0;
+ w = parentSize.width - this.options.right;
+ l = w - this.options.maxWidth - this.options.right;
+ /* calculate the top and height */
+ if (this.options.top != null) {
+ /* fixed top */
+ t = this.options.top;
+ if (this.options.bottom == null) {
+ /* variable bottom */
+ if (this.options.height == null) {
+ //console.log( 'fixed top, variable bottom, variable height' );
+ /* variable bottom and height
+ * set bottom to min, stretch height */
+ h = parentSize.height - t;
+ if (h < this.options.minHeight) {
+ h = this.options.minHeight;
+ if (this.options.maxHeight >= 0 && h > this.options.maxHeight) {
+ h = this.options.maxHeight;
+ } else {
+ //console.log( 'fixed top, variable bottom, fixed height' );
+ /* variable bottom, fixed height
+ * stretch height
+ h = this.options.height;
+ t = h - this.options.maxHeight;
+ } else {
+ /* fixed bottom */
+ //console.log( 'fixed top, fixed bottom, variable height' );
+ /* fixed bottom, variable height
+ * stretch height
+ h = parentSize.height - t - this.options.bottom;
+ } else {
+ //console.log( 'fixed top, fixed bottom, fixed height' );
+ /* fixed bottom, fixed height
+ * respect top and height, allow bottom to stretch
+ } else {
+ //console.log( 'variable top, variable bottom, variable height' );
+ /* variable top, height and bottom
+ * set top, bottom to min, stretch height
+ t = 0;
+ h = parentSize.height;
+ t = parseInt((parentSize.height - this.options.maxHeight)/2);
+ } else {
+ //console.log( 'variable top, variable bottom, fixed height' );
+ /* variable top, fixed height, variable bottom
+ * distribute space between top and bottom
+ t = parseInt((parentSize.height - h)/2);
+ if (t < 0) {
+ t = 0;
+ } else {
+ if (this.options.height != null) {
+ //console.log( 'variable top, fixed bottom, fixed height' );
+ /* variable top, fixed height, fixed bottom
+ * top is calculated directly
+ t = parentSize.height - h - this.options.bottom;
+ if (t < 0) {
+ t = 0;
+ } else {
+ //console.log( 'variable top, fixed bottom, variable height' );
+ /* variable top and height, fixed bottom
+ * set top to min value and stretch height
+ t = 0;
+ h = parentSize.height - this.options.bottom;
+ t = parentSize.height - this.options.maxHeight - this.options.bottom;
+ if (this.options.position == 'absolute') {
+ var padding = Element.getPaddingSize(this.domObj.parentNode);
+ this.domObj.style.left = (l+padding.left) + 'px';
+ this.domObj.style.top = (t+padding.top) + 'px';
+ Element.setBorderBoxSize(this.domObj, {width: w, height: h} );
+ } else {
+ var sizeOpts = {width: w};
+ if (this.options.height) {
+ sizeOpts.height = this.options.height;
+ Element.setBorderBoxSize(this.domObj, sizeOpts);
+ var o = {forceResize: options ? options.forceResize : false};
+ for (var i=0; i<this.domObj.childNodes.length; i++) {
+ var c = this.domObj.childNodes[i];
+ if (c.resize) {
+ c.resize(o);
+ this.processEvent(this.scl,'sizeChanged',this);
+ * Method: addSizeChangeListener
+ * add a size change listener to be notified when the size of the
+ * element changes.
+ * Parameters:
+ * obj - {Object} a size change listener
+ addSizeChangeListener: function(obj){this.addListener(this.scl, obj);},
+ * Method: removeSizeChangeListener
+ * remove a size change listener
+ * Parameters:
+ removeSizeChangeListener: function(o) {
+ this.removeListener(this.scl, o);
+Object.extend(Jx.Layout.prototype, Jx.Listener.prototype);
+ * Class: Jx.Constraint
+ * A utility class used with <Jx.Layout> to represent the current
+ * set of constraints on an element. This object is not intended
+ * to be instantiated directly by a user
+Jx.Constraint = Class.create();
+Jx.Constraint.prototype = {
+ position: 'absolute',
+ left: 0,
+ right: 0,
+ top: 0,
+ bottom: 0,
+ width: null,
+ height: null,
+ minWidth: 0,
+ minHeight: 0,
+ maxWidth: -1,
+ maxHeight: -1,
+ initialize: function(o) {
+ for( var i in o ) {
+ this[i] = o[i];
+ * $Id: jxmenu.js 512 2008-03-07 21:15:45Z pspencer $
+ * Title: Jx.Menu
+ * Purpose:
+ * Implementation of a javascript menuing system for Jx.
+ * Author:
+ * Copyright:
+ Jx.addStyleSheet('menu/menu.css');
+ Jx.addStyleSheet('button/button.css');
+ * Class: Jx.MenuItem
+ * A menu item is a single entry in a menu. It is typically composed of
+ * a label and an optional icon. Selecting the menu item triggers an
+ * action.
+Jx.MenuItem = Class.create();
+Object.extend(Jx.MenuItem.prototype, Jx.Listener.prototype);
+Object.extend(Jx.MenuItem.prototype, {
+ * Property: al
+ * {Array} action listeners
+ al: null,
+ * Property: domObj
+ * {HTMLElement} the HTML element for this menu item.
+ domObj: null,
+ * Property: parent
+ * {<Jx.SubMenu> or <Jx.Menu>} the menu that contains the menu item.
+ parent: null,
+ * Property: enabled
+ * {Boolean} whether the menu item is enabled or not
+ enabled: false,
+ * Property: button
+ * {<Jx.Button>} the clickable part of the menu item is managed as a
+ * <Jx.Button>
+ button: null,
+ * Constructor: Jx.MenuItem
+ * Create a new instance of Jx.MenuItem
+ * Parameters:
+ * action - {<Jx.Action>} the action to invoke when the menu item is
+ * invoked
+ * options - {Object} an object containing options as below.
+ * Options:
+ * image - {String} URL to an image to use as an icon on this menu item
+ * label - {String} the label for the menu item.
+ initialize: function(action, options) {
+ this.initializeItem(options);
+ action.bindTo(this);
+ this.propertyChanged(action);
+ * Method: initializeItem
+ * Internal method to initalize the button for this menu item.
+ * Parameters:
+ * Options:
+ * label - {String} the label for the menu item. */
+ initializeItem: function(options) {
+ if (!options.image) {
+ options.image = Jx.baseURL + 'images/a_pixel.png';
+ if (!options.label) {
+ options.label = ' ';
+ this.label = options.label || ' ';
+ this.image = options.image || null;
+ this.al = [];
+ this.domObj = document.createElement('li');
+ this.domObj.className = 'jxMenuItem';
+ /* menu items are buttons without the jxButton class */
+ var action = new Jx.Action(this.processActionEvent.bindAsEventListener(this))
+ this.button = new Jx.Button(action, options);
+ //Element.removeClassName(this.button.domA, 'jxButton');
+ Event.observe(this.button.domObj, 'mouseover', this.onmouseover.bindAsEventListener(this), true);
+ this.domObj.appendChild(this.button.domObj);
+ * Method: setParent
+ * Set the parent of this menu item
+ * Parameters:
+ * obj - {Object} the new parent
+ setParent: function(obj) {
+ this.parent = obj;
+ * Method: hide
+ * Hide the menu item.
+ hide: function() {},
+ * Method: show
+ * Show the menu item
+ show: function() {},
+ * Method: addActionListener
+ * Add an action listener to this menu item
+ * Parameters:
+ * obj - {Object} the action listener
+ addActionListener: function(obj) { this.addListener(this.al,obj); },
+ * Method: removeActionListener
+ * Remove an action listener from this menu item
+ * Parameters:
+ removeActionListener : function(obj) { this.removeListener(this.al, obj); },
+ * Method: processActionEvent
+ * Process an action event by informing any action listeners that the action
+ * associated with this menu item and hiding the menu.
+ * Parameters:
+ * e - {Event} the event associated with the user clicking on the menu item
+ processActionEvent: function(e) {
+ if (this.enabled) {
+ this.processEvent(this.al, 'actionPerformed', this);
+ if (this.parent && this.parent.deactivate) {
+ this.parent.deactivate(e);
+ * Method: propertyChanged
+ * Track when a property of the action changes and update the state of the
+ * menu item accordingly.
+ * Parameters:
+ * obj - {<Jx.Action>} the action object
+ propertyChanged: function(obj) {
+ this.enabled = obj.isEnabled();
+ Element.removeClassName( this.domObj.childNodes[0].childNodes[0], 'jxDisabled' );
+ } else {
+ Element.addClassName( this.domObj.childNodes[0].childNodes[0], 'jxDisabled' );
+ * Method: onmouseover
+ * handle the mouse moving over the menu item
+ * Parameters:
+ * e - {Event} the mousemove event
+ onmouseover: function(e) {
+ var target = Event.element(e);
+ if (this.parent && this.parent.setVisibleItem) {
+ this.parent.setVisibleItem(this);
+ this.show();
+ * Class: Jx.MenuSeparator
+ * A convenience class to create a visual separator in a menu.
+Jx.MenuSeparator = Class.create();
+Object.extend(Jx.MenuSeparator.prototype, {
+ * {HTMLElement} the HTML element that the separator is contained
+ * within
+ domObj: null,
+ * {<Jx.Menu>, <Jx.SubMenu>} the menu that the separator is in.
+ parent: null,
+ * Constructor: Jx.MenuSeparator
+ * Create a new instance of a menu separator
+ initialize: function() {
+ var span = document.createElement('span');
+ span.className = 'jxMenuSeparator';
+ span.innerHTML = ' ';
+ this.domObj.appendChild(span);
+ * Parameters:
+ * Method: hide
+ * Method: show
+ * Class: Jx.SubMenu
+ * A sub menu contains menu items within a main menu or another
+ * sub menu.
+ * Inherits From:
+ * <Jx.MenuItem>
+Jx.SubMenu = Class.create();
+Object.extend(Jx.SubMenu.prototype, Jx.MenuItem.prototype);
+Object.extend(Jx.SubMenu.prototype, {
+ * Property: subDomObj
+ * {HTMLElement} the HTML container for the sub menu.
+ subDomObj: null,
+ * {<Jx.Menu> or <Jx.SubMenu>} the menu or sub menu that this sub menu
+ * belongs
+ parent: null,
+ * Property: visibleItem
+ * {<Jx.MenuItem>} the visible item within the menu
+ visibleItem: null,
+ * Property: items
+ * {Array} the menu items that are in this sub menu.
+ items: null,
+ * Constructor: Jx.SubMenu
+ * Create a new instance of Jx.SubMenu
+ * Parameters:
+ * options - see <Jx.MenuItem::Jx.MenuItem>
+ initialize: function(options) {
+ this.open = false;
+ this.items = [];
+ Element.addClassName(this.domObj.childNodes[0].childNodes[0], 'jxButtonSubMenu');
+ this.iframe = document.createElement('iframe');
+ this.iframe.className = 'jxMenuShim';
+ this.iframe.scrolling = 'no';
+ this.iframe.frameborder = 0;
+ this.subDomObj = document.createElement('ul');
+ this.subDomObj.className = 'jxSubMenu';
+ this.subDomObj.style.display = 'none';
+ // this.button.domObj.appendChild(this.subDomObj);
+ this.domObj.appendChild(this.subDomObj);
+ * Set the parent of this sub menu
+ * Parameters:
+ * obj - {Object} the parent
+ * Method: show
+ * Show the sub menu
+ if (this.open || this.items.length == 0) {
+ return;
+ this.open = true;
+ this.subDomObj.style.display = 'block';
+ if (!window.opera) {
+ this.subDomObj.childNodes[0].appendChild(this.iframe);
+ var size = Element.getBorderBoxSize(this.subDomObj);
+ this.iframe.style.width = size.width + "px";
+ this.iframe.style.height = size.height + "px";
+ this.setActive(true);
+ * Method: hide
+ * Hide the sub menu
+ if (!this.open) {
+ return;
+ for (var i=0; i<this.items.length; i++) {
+ this.items[i].hide();
+ if (!window.opera && this.iframe.parentNode) {
+ this.subDomObj.childNodes[0].removeChild(this.iframe);
+ this.visibleItem = null;
+ * Method: add
+ * Add menu items to the sub menu.
+ * Parameters:
+ * item - {<Jx.MenuItem>} the menu item to add. Multiple menu items
+ * can be added by passing multiple arguments to this function.
+ add : function() { /* menu */
+ for (var i=0; i<arguments.length; i++) {
+ var item = arguments[i];
+ this.items.push(item);
+ item.setParent(this);
+ this.subDomObj.appendChild(item.domObj);
+ * Method: insertBefore
+ * Insert a menu item before another menu item.
+ * Parameters:
+ * newItem - {<Jx.MenuItem>} the menu item to insert
+ * targetItem - {<Jx.MenuItem>} the menu item to insert before
+ insertBefore: function(newItem, targetItem) {
+ var bInserted = false;
+ if (this.items[i] == targetItem) {
+ this.items.splice(i, 0, newItem);
+ this.subDomObj.insertBefore(newItem.domObj, targetItem.domObj);
+ bInserted = true;
+ break;
+ if (!bInserted) {
+ this.add(newItem);
+ * Method: remove
+ * Remove a single menu item from the menu.
+ * Parameters:
+ * item - {<Jx.MenuItem} the menu item to remove.
+ remove: function(item) {
+ if (this.items[i] == item) {
+ this.items.splice(i,1);
+ this.subDomObj.removeChild(item.domObj);
+ break;
+ * Process an action event coming from the menu item that
+ * represents the sub menu in its parent by showing or hiding
+ * the sub menu.
+ if (this.open) {
+ this.hide();
+ } else {
+ this.show();
+ return Event.stop(e);
+ * Method: deactivate
+ * Deactivate the sub menu
+ * Parameters:
+ * e - {Event} the event that triggered the menu being
+ * deactivated.
+ deactivate: function(e) {
+ if (this.parent) {
+ * Method: isActive
+ * Indicate if this sub menu is active
+ * Returns:
+ * {Boolean} true if the <Jx.Menu> that ultimately contains
+ * this sub menu is active, false otherwise.
+ isActive: function() {
+ return this.parent.isActive();
+ } else {
+ return false;
+ * Method: setActive
+ * Set the active state of the <Jx.Menu> that contains this sub menu
+ * Parameters:
+ * isActive - {Boolean} the new active state
+ setActive: function(isActive) {
+ if (this.parent && this.parent.setActive) {
+ this.parent.setActive(isActive);
+ * Method: setVisibleItem
+ * Set a sub menu of this menu to be visible and hide the previously
+ * visible one.
+ * Parameters:
+ * obj - {<Jx.SubMenu>} the sub menu that should be visible
+ setVisibleItem: function(obj) {
+ if (this.visibleItem != obj) {
+ if (this.visibleItem && this.visibleItem.hide) {
+ this.visibleItem.hide();
+ this.visibleItem = obj;
+ this.visibleItem.show();
+ * Class: Jx.Menu
+ * A main menu as opposed to a sub menu that lives inside the menu.
+ * TODO: Jx.Menu
+ * revisit this to see if Jx.Menu and Jx.SubMenu can be merged into
+ * a single implementation.
+Jx.Menu = Class.create();
+Jx.Menu.prototype = {
+ * {HTMLElement} The HTML element containing the menu.
+ domObj : null,
+ * Property: buttonObj
+ * {<Jx.Button>} The button that represents this menu in a toolbar and
+ * opens the menu.
+ buttonObj : null,
+ * {HTMLElement} the HTML element that contains the menu items
+ * within the menu.
+ subDomObj : null,
+ * Property: items
+ * {Array} the items in this menu
+ items : null,
+ * Property: menus
+ * {Array} Class variable that contains a reference to all
+ * menus shared by all menu instances.
+ menus : [],
+ * Create a new instance of Jx.Menu.
+ * Parameters:
+ * options - {Object} an options object passed directly to the
+ * <Jx.Button> when creating the button that triggers this menu.
+ * If options is not passed, then no button is created.
+ initialize : function(options) {
+ /* stores menu items and sub menus */
+ this.items = [];
+ /* iframe shim to prevent scrollbars and
+ inputs from showing through the menu */
+ /* the DOM element that holds the actual menu */
+ this.subDomObj.className = 'jxMenu';
+ /* if options are passed, make a button inside an LI so the
+ menu can be embedded inside a toolbar */
+ if (options) {
+ var action = new Jx.Action(this.show.bind(this));
+ Element.addClassName(this.button.domObj.firstChild, 'jxButtonMenu');
+ Event.observe(this.domObj, 'mouseover', this.onMouseOver.bindAsEventListener(this));
+ //this.button.domObj.appendChild(this.subDomObj);
+ /* pre-bind the hide function for efficiency */
+ this.hideWatcher = this.hide.bindAsEventListener(this);
+ * Method: add
+ * Parameters:
+ * Deactivate the menu by hiding it.
+ deactivate: function() { this.hide(); },
+ * Method: actionPerformed
+ * Any action performed in the menu ultimately calls this
+ * method to hide the menu.
+ actionPerformed : function() {this.hide();},
+ * Method: onMouseOver
+ * Handle the user moving the mouse over the button for this menu
+ * by showing this menu and hiding the other menu.
+ * Parameters:
+ * e - {Event} the mouse event
+ onMouseOver: function(e) {
+ if (this.menus[0] && this.menus[0] != this) {
+ this.show(e);
+ * Method: hide
+ * Hide the menu.
+ * Parameters:
+ hide: function(e) {
+ if (e) {
+ var root = Event.findElement(e, 'LI');
+ if (root == this.domObj) {
+ return;
+ if (this.menus[0] && this.menus[0] == this) {
+ this.menus[0] = null;
+ this.items[i].hide(e);
+ Event.stopObserving(document, 'click', this.hideWatcher, true);
+ * Method: show
+ * Show the menu
+ * Parameters:
+ show : function(e) {
+ this.menus[0].hide(e);
+ if (this.items.length ==0) {
+ return;
+ this.menus[0] = this;
+ this.subDomObj.style.visibility = 'visible';
+ var size = Element.getContentBoxSize(this.subDomObj);
+ Event.stop(e);
+ /* fix bug in IE that closes the menu as it opens because of bubbling */
+ Event.observe(document, 'click', this.hideWatcher, true);
+ * Set the sub menu that is currently open
+ * Parameters:
+ * obj- {<Jx.SubMenu>} the sub menu that just became visible
+ * Class: Jx.ContextMenu
+ * A <Jx.Menu> that has no button but can be opened at a specific
+ * browser location to implement context menus (for instance).
+ * Inherits From:
+ * <Jx.Menu>
+Jx.ContextMenu = Class.create();
+Object.extend(Jx.ContextMenu.prototype, Jx.Menu.prototype);
+Object.extend(Jx.ContextMenu.prototype, {
+ * Constructor: Jx.ContextMenu
+ * create a new context menu
+ * Parameters:
+ * id - {HTMLElement} element or id to make this the context menu
+ * for. The menu hooks the oncontextmenu event of the element
+ * and shows itself at the mouse position where the right-click
+ * happened.
+ initialize : function(id) {
+ Jx.Menu.prototype.initialize.apply(this, []);
+ document.getElementsByTagName('BODY')[0].appendChild(this.subDomObj);
+ if ($(id)) {
+ $(id).oncontextmenu = this.show.bindAsEventListener(this);;
+ * Method: show
+ * Show the context menu at the location of the mouse click
+ * Parameters:
+ this.subDomObj.style.left = Event.pointerX(e) + "px";
+ this.subDomObj.style.top = Event.pointerY(e) + "px";
+ Jx.Menu.prototype.show.apply(this, [e]);
+ * $Id: jxpanel.js 512 2008-03-07 21:15:45Z pspencer $
+ * Title: Jx.Panel
+ * Purpose:
+ * Implementation of a javascript panels for Jx. Panels are vertically
+ * oriented areas that can be resized by the user dragging the panel title
+ * bar.
+ * Author:
+ * Copyright:
+Jx.addStyleSheet('panel/panel.css');
+ * Class: Jx.PanelManager
+ * A panel manager manages a set of panels within a DOM element.
+Jx.PanelManager = Class.create();
+Jx.PanelManager.prototype = {
+ * Property: panels
+ * {Array} the panels being managed by the manager
+ panels: null,
+ * Property: height
+ * {Integer} the height of the container, cached for speed
+ height: null,
+ * Property: firstLayout
+ * {Boolean} true until the panel manager has first been resized
+ firstLayout: true,
+ * Constructor: Jx.PanelManager
+ * Create a new instance of Jx.PanelManager.
+ * Parameters:
+ * domObj - {HTMLElement} the HTML element that will contain the panels
+ * panels - {Array} the panels to go into the PanelManager
+ * TODO: Jx.PanelManager.initialize
+ * Remove the panels parameter in favour of an add method.
+ initialize: function(domObj, panels) {
+ this.panels = panels;
+ var d = document.createElement('div');
+ d.style.position = 'absolute';
+ new Jx.Layout(d, {minHeight:0,maxHeight:0,height:0});
+ var elements = [d];
+ for (var i=0; i<this.panels.length; i++) {
+ elements.push(this.panels[i].domObj);
+ this.splitter = new Jx.Splitter(this.domObj, {splitInto: panels.length+1,
+ layout: 'vertical',
+ elements: elements });
+ /* redirect splitter sizeChanged so we can capture the first time the
+ * splitter is layed out in the client in a way that we can measure
+ * the title bar heights
+ this.splitter.sizeChanged = this.sizeChanged.bind(this);
+ /* create the bars for the panel manager */
+ var panel = this.panels[i];
+ this.splitter.bars[i].appendChild(panel.title);
+ this.splitter.bars[i].style.height = Element.getBorderBoxSize(panel.title).height + 'px';
+ Element.removeClassName(this.splitter.bars[i], 'jxSplitterBar');
+ Element.addClassName(this.splitter.bars[i], 'jxPanelBar');
+ panel.manager = this;
+ * called when the size of the container of the splitter changes. This tracks the
+ * first time the panel titles have a non-zero height (i.e. they are put in the
+ * DOM and are visible) and recalculates the panel title height then.
+ if (this.firstLayout) {
+ if (Element.getBorderBoxSize(this.panels[0].title).height != 0) {
+ for (var i=0; i<this.splitter.bars.length; i++) {
+ this.splitter.bars[i].size = null;
+ this.firstLayout = false;
+ Jx.Splitter.prototype.sizeChanged.apply(this.splitter, []);
+ } else {
+ * Method: maximizePanel
+ * Maximize the panel, taking up all available space (taking into
+ * consideration any minimum or maximum values)
+ maximizePanel: function(panel) {
+ var h = Element.getContentBoxSize(this.domObj).height;
+ var t = 0;
+ for (var i=1; i<this.splitter.elements.length; i++) {
+ var p = this.splitter.elements[i];
+ t += Element.getBorderBoxSize(p.leftBar).height;
+ if (p !== panel.domObj) {
+ p.jxLayout.resize({top: t, height: p.jxLayout.options.minHeight, bottom: null});
+ t += p.jxLayout.options.minHeight;
+ p.rightBar.style.top = t + 'px';
+ } else {
+ break;
+ b = h;
+ for (var i=this.splitter.elements.length - 1; i > 0; i--) {
+ p = this.splitter.elements[i];
+ b -= p.jxLayout.options.minHeight;
+ p.jxLayout.resize({top: b, height: p.jxLayout.options.minHeight, bottom: null});
+ b -= Element.getBorderBoxSize(p.leftBar).height;
+ p.leftBar.style.top = b + 'px';
+ } else {
+ break;
+ panel.domObj.jxLayout.resize({top: t, height:b - t, bottom: null});
+ * Class: Jx.Panel
+ * A panel that can be displayed inside a panel manager.
+Jx.Panel = Class.create();
+Jx.Panel.prototype = {
+ * Property: labelObj
+ * the DOM object that holds the label in the title bar.
+ labelObj : null,
+ * Property: state
+ * the state of this panel
+ state : 'open',
+ * Property: busyCount
+ * track the busy state of this panel - used to control a 'loading' image
+ busyCount : null,
+ * Property: bContentReady
+ * {Boolean} is the content ready to be displayed?
+ bContentReady : null,
+ * Property: onContentReady
+ * {Function} a function to call when the content is ready
+ onContentReady : null,
+ * Initialize a new Jx.Panel instance
+ * Options:
+ * label - String, the title of the Jx Panel
+ * toolbar - element to use as the toolbar
+ * menubar - element to use as the menu
+ * content - element to use as the content. A content area is created
+ * if none is provided. Otherwise, the content element is moved
+ * in the DOM
+ * statusbar - element to use as the statusbar
+ * helpCallback - function to call when the user clicks the contextual help button
+ * state - initial state of the panel (open or closed)
+ * Inherits From:
+ * <Jx.UniqueId>, <Jx.ContentLoader>
+ initialize : function(options){
+ //console.log("Jx.Panel::initialize('"+options.label+"')");
+ this.initUniqueId();
+ /* set up the title object */
+ this.title = document.createElement('div');
+ this.title.className = "jxPanelTitle";
+ //TODO: Jx.Panel.initialize
+ //Opera is broken because it doesn't report the height of the
+ //title bars at all unless set through javascript
+ //this is a hack until we can figure out from css what the height is
+ this.title.style.height = '22px';
+ this.labelObj = document.createElement('span');
+ this.labelObj.className = 'jxPanelLabel';
+ this.labelObj.innerHTML = options.label?options.label:'empty';
+ this.imageBaseUrl = options.imageBaseUrl || Jx.baseURL + 'images/';
+ var a, img;
+ if (options.helpCallback) {
+ a = document.createElement('a');
+ a.className = 'jxPanelHelp';
+ a.href = 'javascript:void(0)';
+ Event.observe(a, 'click', options.helpCallback);
+ img = document.createElement('img');
+ img.src = this.imageBaseUrl + "help.png";
+ img.alt = 'Help on this panel';
+ img.title = 'Help on this panel';
+ a.appendChild(img);
+ this.title.appendChild(a);
+ a.className = 'jxPanelMaximize';
+ Event.observe(a, 'click', this.maximize.bindAsEventListener(this));
+ img.src = this.imageBaseUrl + "maximize.png";
+ img.alt = 'Maximize Panel';
+ img.title = 'Maximize Panel';
+ a.className = 'jxPanelLoading';
+ img.src = this.imageBaseUrl + "loading.gif";
+ img.alt = 'Loading Panel';
+ img.title = 'Loading Panel';
+ this.loadingObj = {};
+ this.loadingObj.link = a;
+ this.loadingObj.img = img;
+ this.title.appendChild(this.loadingObj.link);
+ this.title.appendChild(this.labelObj);
+ Event.observe(this.title, 'dblclick', this.maximize.bindAsEventListener(this));
+ this.domObj = document.createElement('div');
+ this.domObj.className = 'jxPanel';
+ this.jxLayout = new Jx.Layout(this.domObj, options.constraint || {});
+ this.jxLayout.addSizeChangeListener(this);
+ var top = 0;
+ var bottom = 0;
+ if (options.menubar) {
+ this.menubar = options.menubar;
+ this.domObj.appendChild(options.menubar);
+ var h = Element.getBorderBoxSize(options.menubar).height;
+ new Jx.Layout(this.menubar, {top: top, height:h});
+ top += h;
+ if (options.toolbar) {
+ this.toolbar = options.toolbar;
+ this.domObj.appendChild(options.toolbar);
+ var h = Element.getBorderBoxSize(options.toolbar).height;
+ new Jx.Layout(this.toolbar, {top:top, height: h});
+ if (options.statusbar) {
+ this.statusbar = options.statusbar;
+ this.domObj.appendChild(options.statusbar);
+ var h = Element.getBorderBoxSize(options.statusbar).height;
+ new Jx.Layout(this.statusbar, {bottom: bottom, height: h, top: null});
+ bottom += h;
+ this.content = document.createElement('div');
+ Element.addClassName(this.content, 'jxPanelContent');
+ new Jx.Layout(this.content, {top: top, bottom: bottom});
+ this.domObj.appendChild(this.content);
+ this.loadContent(this.content, options);
+ this.busyCount = 0;
+ this.bContentReady = false;
+ * Method: setLabel
+ * Set the label in the title bar of this panel
+ * Parameters:
+ * s - {String} the new label
+ setLabel: function(s) {
+ this.labelObj.innerHTML = s;
+ * Method: getLabel
+ * Get the label of the title bar of this panel
+ * Returns:
+ * {String} the label
+ getLabel: function() {
+ return this.labelObj.innerHTML;
+ * Method: finalize
+ * Clean up the panel
+ finalize: function() {
+ this.domObj = null;
+ this.deregisterIds();
+ * Maximize this panel
+ maximize: function() {
+ if (this.manager) {
+ this.manager.maximizePanel(this);
+ * Method: setContent
+ * set the content of this panel to some HTML
+ * Parameters:
+ * html - {String} the new HTML to go in the panel
+ setContent : function (html) {
+ //console.log('Jx.Panel::setContent()');
+ this.content.innerHTML = html;
+ this.bContentReady = true;
+ * Method: setContentURL
+ * Set the content of this panel to come from some URL.
+ * Parameters:
+ * url - {String} URL to some HTML content for this panel
+ setContentURL : function (url) {
+ this.setBusy(true);
+ if (arguments[1]) {
+ this.onContentReady = arguments[1];
+ if (url.indexOf('?') == -1) {
+ url = url + '?';
+ //var ts = (new Date()).getTime();
+ //url = url + 'ts='+ts;
+ var opts = { method: 'get',
+ onComplete:this.panelContentLoaded.bind(this),
+ requestHeaders: ['If-Modified-Since', 'Sat, 1 Jan 2000 00:00:00 GMT']};
+ var a = new Ajax.Request( url, opts);
+ * Method: panelContentLoaded
+ * When the content of the panel is loaded from a remote URL, this
+ * method is called when the ajax request returns.
+ * Parameters:
+ * r - {XmlHttpRequest} the XmlHttpRequest object
+ panelContentLoaded: function(r) {
+ this.content.innerHTML = r.responseText;
+ this.setBusy(false);
+ if (this.onContentReady) {
+ window.setTimeout(this.onContentReady.bind(this),1);
+ * Method: setBusy
+ * Set the panel as busy or not busy, which displays a loading image
+ * in the title bar.
+ * Parameters:
+ * isBusy - {Boolean} the busy state
+ setBusy : function(isBusy) {
+ this.busyCount += isBusy?1:-1;
+ this.loadingObj.img.style.visibility = (this.busyCount>0)?'visible':'hidden';
+ * handle the size of the container changing by resizing the various
+ * elements of the panel.
+ var top = 0;
+ var bottom = 0;
+ if (this.menubar) {
+ this.menubar.style.height = '';
+ var size = Element.getBorderBoxSize(this.menubar);
+ this.menubar.resize({height:size.height});
+ top += size.height;
+ if (this.toolbar) {
+ this.toolbar.style.height = '';
+ var size = Element.getBorderBoxSize(this.toolbar);
+ this.toolbar.resize({height:size.height});
+ if (this.statusbar) {
+ this.statusbar.style.height = '';
+ var size = Element.getBorderBoxSize(this.statusbar);
+ this.statusbar.resize({height:size.height});
+ bottom += size.height;
+ if (top || bottom) {
+ this.content.resize({bottom: bottom, top: top});
+Object.extend(Jx.Panel.prototype, Jx.UniqueId.prototype);
+Object.extend(Jx.Panel.prototype, Jx.ContentLoader.prototype);/**
+ * $Id: jxpicker.js 512 2008-03-07 21:15:45Z pspencer $
+ * Title: Jx.Picker
+ * Purpose:
+ * Implementation of a javascript Pick List for Jx. This is analagous to an
+ * HTML select except that it allows other things to be put in the list. The
+ * selected item from the list can also be editable.
+ * Author:
+ * Copyright:
+Jx.addStyleSheet('picker/picker.css');
+ * Class: Jx.Picker
+ * A drop down list of selectable items that can be any HTML.
+ * Inherits From:
+ * <Jx.Listener>
+Jx.Picker = Class.create();
+Jx.Picker.prototype = {
+ * Property: sl
+ * {Array} selection listeners
+ sl : null,
+ * {HTMLElement} the div that contains the control,
+ * used to show/hide the control
+ domObj : null,
+ * Property: ul
+ * {HTMLElement} the ul that contains the selectable items
+ ul : null,
+ * Property: currentSelection
+ * {Object} current selection in the list
+ currentSelection : null,
+ * Property: isEditable
+ * {Boolean} is the selected item editable?
+ isEditable: false,
+ * Constructor: Jx.Picker
+ * create a new instance of Jx.Picker
+ * Options:
+ * editable - {Boolean} defaults to false. If true, then the selected item
+ * is editable.
+ this.domObj.className = 'jxPicker';
+ this.isEditable = options.editable || false;
+ if (this.isEditable) {
+ this.domInput = document.createElement('input');
+ this.domInput.type = 'text';
+ Event.observe(this.domInput, 'change', this.valueChanged.bind(this));
+ Event.observe(this.domInput, 'keydown', this.onKeyPress.bind(this));
+ } else {
+ this.domInput = document.createElement('span');
+ this.domInput.className = 'jxPickerInput';
+ this.domObj.appendChild(this.domInput);
+ this.domA = document.createElement('a');
+ this.domA.href = 'javascript:void(0)';
+ this.domA.className = 'jxPickerDiscloser';
+ Event.observe(this.domA, 'click', this.toggle.bind(this));
+ this.domButton = document.createElement('img');
+ this.domButton.src = Jx.baseURL + 'images/disclose2.png';
+ Element.addClassName(this.domButton, 'png24');
+ this.domA.appendChild(this.domButton);
+ this.domObj.appendChild(this.domA);
+ //insert iframeShim for IE to cover other controls in the page.
+ var iframe = document.createElement('iframe');
+ iframe.className = 'jxDialogShim';
+ iframe.scrolling = 'no';
+ iframe.frameborder = 0;
+ this.domObj.appendChild(iframe);
+ this.domListDiv = document.createElement('div');
+ this.domListDiv.className = 'jxPickerOptions';
+ this.domListDiv.style.display = 'none';
+ this.domObj.appendChild(this.domListDiv);
+ this.domList = document.createElement('ul');
+ this.domListDiv.appendChild(this.domList);
+ this.sl = [];
+ * Method: onKeyPress
+ * Handle the user pressing a key by looking for an ENTER key to set the
+ * value.
+ * Parameters:
+ * e - {Event} the keypress event
+ onKeyPress: function(e) {
+ var charCode = (e.charCode) ? e.charCode : ((e.keyCode) ? e.keyCode : e.which);
+ if (charCode == Event.KEY_RETURN) {
+ this.valueChanged();
+ * Method: valueChanged
+ * When the value is changed, propogate the change to the selection
+ * listeners
+ valueChanged: function() {
+ this.processEvent(this.sl, 'selectionChanged', this);
+ * Method: add
+ * add a new item to the pick list
+ * Parameters:
+ * domObj - {HTMLElement} the element to add
+ * idx - {Integer} the index to add the element add
+ add: function(domObj, idx) {
+ var li = document.createElement('li');
+ var a = document.createElement('a');
+ a.href="javascript:void(0)";
+ if (typeof(domObj) == 'string') {
+ a.innerHTML = domObj;
+ } else {
+ a.appendChild(domObj);
+ Event.observe(a, 'click', this.pick.bindAsEventListener(this));
+ li.appendChild(a);
+ if (arguments.length > 1 && this.domList.childNodes.length > idx) {
+ this.domList.insertBefore(li, this.domList.childNodes[idx]);
+ } else {
+ this.domList.appendChild(li);
+ * Method: remove
+ * Remove the item at the given index
+ * Parameters:
+ * idx - {Integer} the item to remove.
+ remove: function(idx) {
+ if (idx > 0 && idx < this.domList.childNodes.length) {
+ this.domList.removeChild(this.domList.childNodes[idx]);
+ * Method: pick
+ * user has clicked something in the list, select it
+ * Parameters:
+ * e - {Event} the mouse event from the user's click
+ pick: function(e) {
+ if (target.tagName == 'A') {
+ this.currentSelection = target;
+ this.setValue(this.currentSelection.childNodes[0]);
+ this.close();
+ * Method: setValue
+ * set the value of the picker
+ * Parameters:
+ * value - {Object} the new value. May be a string, a text node, or
+ * another DOM element.
+ setValue: function(value) {
+ if (typeof(value) == 'string') {
+ this.domInput.value = value;
+ } else if (value.nodeType && value.nodeType == 3) {
+ this.domInput.value = value.nodeValue;
+ } else {
+ this.domInput.value = value.innerHTML;
+ } else if (!this.isEditable) {
+ this.domInput.innerHTML = value;
+ this.domInput.innerHTML = value.nodeValue;
+ } else {
+ this.domInput.appendChild(value);
+ * Method: getValue
+ * Return the current value
+ * Returns:
+ * {Object} returns the currently selected item
+ getValue: function() {
+ value = '';
+ value = this.domInput.value;
+ } else {
+ if (this.domInput.childNodes[0].nodeType == 3) {
+ value = this.domInput.innerHTML;
+ } else {
+ value = this.domInput.childNodes[0];
+ return value;
+ * Method: toggle
+ * Toggle the display of the list associated with the picker
+ toggle: function() {
+ if (this.domListDiv.style.display == 'block') {
+ this.close();
+ } else {
+ this.open();
+ * Method: open
+ * Open the pick list
+ open: function() {
+ if (!this.keypressListener) {
+ this.keypressListener = this.keypress.bindAsEventListener(this);
+ this.domListDiv.style.display = 'block';
+ Event.observe(document, 'keypress', this.keypressListener);
+ //Effect.SlideDown(this.domObj, 0.2);
+ * Method: keypress
+ * Handle a key press event when the list is open so we can close it if the
+ * user hits the ESC key.
+ * Parameters:
+ keypress: function(e) {
+ var charCode=(e.charCode)?e.charCode:e.keyCode;
+ if (charCode == Event.KEY_ESC) {
+ this.close();
+ * Method: close
+ * Close the picker.
+ close: function() {
+ Event.stopObserving(document, 'keypress', this.keypressListener);
+ //Effect.SlideUp(this.domObj, 0.2);
+ * Method: addSelectionListener
+ * Add a selection listener to the picker
+ * Parameters:
+ * obj - {Object} the selection listener
+ addSelectionListener: function(obj) { this.addListener(this.sl, obj); },
+ * Method: removeSelectionListener
+ * Remove a selection listener to the picker
+ * Parameters:
+ removeSelectionListener: function(obj) { this.removeListener(this.sl, obj); },
+ * Method: getSelection
+ * return the current selection
+ * Returns:
+ * {Object} the current selection or an empty string.
+ getSelection: function() {
+ return this.currentSelection ? this.currentSelection.name : '';
+Object.extend(Jx.Picker.prototype, Jx.Listener.prototype);/**
+ * $Id: jxsplitter.js 512 2008-03-07 21:15:45Z pspencer $
+ * Title: Jx.Splitter
+ * Purpose:
+ * Implementation of a javascript Splitter for Jx.
+ * Author:
+ * Paul Spencer (pspencer at dmsolutions.ca)
+ * Copyright:
+ * Copyright © 2008, DM Solutions Group Inc.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+ * Class: Jx.Splitter
+ * a Jx.Splitter creates two or more containers within a parent container
+ * and provides user control over the size of the containers. The split
+ * can be made horizontally or vertically.
+ * A horizontal split creates containers that divide the space horizontally
+ * with vertical bars between the containers. A vertical split divides
+ * the space vertically and creates horizontal bars between the containers.
+Jx.Splitter = Class.create();
+Jx.Splitter.prototype = {
+ * {HTMLElement} the element being split
+ domObj: null,
+ * Property: elements
+ * {Array} an array of elements that are displayed in each of the split
+ * areas
+ elements: null,
+ * Property: bars
+ * {Array} an array of the bars between each of the elements used to
+ * resize the split areas.
+ bars: null,
+ * Property: firstUpdate
+ * {Boolean} track the first resize event so that unexposed Jx things
+ * can be forced to calculate their size the first time they are exposed.
+ firstUpdate: true,
+ * Constructor: Jx.Splitter
+ * Create a new instance of Jx.Splitter
+ * Parameters:
+ * domObj - {HTMLElement} the element or id of the element to split
+ * options - {Object} optional arguments specified as properties of
+ * this object are as below.
+ * Options:
+ * elements - {Array} an array of elements to put into the split areas.
+ * If splitInto is not set, then it is calculated from the length of
+ * this array.
+ * splitInto - {Integer} the number of elements to split the domObj into.
+ * If not set, then the length of the elements option is used, or 2 if
+ * elements is not specified. If splitInto is specified and elements
+ * is specified, then splitInto is used. If there are more elements than
+ * splitInto specifies, then the extras are ignored. If there are less
+ * elements than splitInto specifies, then extras are created.
+ * containerOptions - {Array} an array of objects that provide options
+ * for the <Jx.Layout> constraints on each element.
+ * layout - {String} either 'horizontal' or 'vertical', indicating the
+ * direction in which the domObj is to be split.
+ * snappers - {Array} an array of objects which can be used to snap
+ * elements open or closed.
+ options = options || {};
+ this.domObj = $(domObj);
+ this.domObj.style.overflow = 'hidden';
+ if (this.domObj.jxLayout) {
+ this.domObj.jxLayout.addSizeChangeListener(this);
+ this.elements = [];
+ this.bars = [];
+ var nSplits = options.splitInto || (options.elements ? options.elements.length : 2);
+ var aContainerOpts = options.containerOptions || [];
+ for (var i=0; i<nSplits; i++) {
+ this.elements[i] = options.elements ? options.elements[i] : this.prepareElement();
+ this.domObj.appendChild(this.elements[i]);
+ if (!this.elements[i].jxLayout) {
+ new Jx.Layout(this.elements[i], aContainerOpts[i]);
+ for (var i=1; i<nSplits; i++) {
+ this.bars[i-1] = this.prepareBar();
+ this.bars[i-1].leftSide = this.elements[i-1];
+ this.bars[i-1].rightSide = this.elements[i];
+ this.elements[i-1].rightBar = this.bars[i-1];
+ this.elements[i].leftBar = this.bars[i-1];
+ this.domObj.appendChild(this.bars[i-1]);
+ this.layout = options.layout || 'horizontal';
+ this.establishConstraints();
+ if (options.snappers) {
+ for (var i=0; i<options.snappers.length; i++) {
+ if (options.snappers[i]) {
+ new Jx.Splitter.Snapper(options.snappers[i], this.elements[i], this);
+ * Method: prepareElement
+ * Prepare a new, empty element to go into a split area.
+ * Returns:
+ * {HTMLElement} an HTMLElement that goes into a split area.
+ prepareElement: function(){
+ var o = document.createElement('div');
+ o.style.position = 'absolute';
+ o.leftBar = null;
+ o.rightBar = null;
+ return o;
+ * Method: prepareBar
+ * Prepare a new, empty bar to go into between split areas.
+ * Returns:
+ * {HTMLElement} an HTMLElement that becomes a bar.
+ prepareBar: function() {
+ o.className = 'jxSplitterBar';
+ o.title = 'drag this bar to resize';
+ o.style.lineHeight = '1px'; // for IE, horizontal bars
+ o.splitterObj = this;
+ return o;
+ * Method: establishConstraints
+ * Setup the initial set of constraints that set the behaviour of the
+ * bars between the elements in the split area.
+ establishConstraints: function() {
+ if (this.layout == 'horizontal') {
+ for (var i=0; i< this.bars.length; i++) {
+ this.bars[i].style.top = '0px';
+ this.bars[i].style.height = '100%';
+ new Draggable(this.bars[i], { constraint: 'horizontal' ,
+ starteffect : function(element) {
+ element.style.backgroundColor = '#eee';
+ endeffect : function(element) {
+ element.style.backgroundColor = '';
+ } else {
+ this.bars[i].style.left = '0px';
+ this.bars[i].style.width = '100%';
+ new Draggable(this.bars[i], { constraint: 'vertical' ,
+ Draggables.addObserver(this);
+ * Method: onEnd
+ * Handle the end of a drag event on a bar.
+ * Parameters:
+ * eventName - {String} the name associated with the drag event
+ * obj - {HTMLElement} the bar that was dragged
+ * event - {Event} the event object associated with the drag
+ onEnd: function(eventName, obj, event) {
+ if (obj.element.splitterObj != this) {
+ return;
+ this.dragHorizontal(eventName, obj, event);
+ } else {
+ this.dragVertical(eventName, obj, event);
+ * Method: dragHorizontal
+ * In a horizontally split container, handle a bar being dragged left or
+ * right by resizing the elements on either side of the bar.
+ * Parameters:
+ dragHorizontal: function(eventName, obj, event) {
+ var leftEdge = parseInt(obj.element.style.left);
+ var leftSide = obj.element.leftSide;
+ var rightSide = obj.element.rightSide;
+ /* process right side first */
+ var rsLeft, rsWidth, rsRight;
+ if (!obj.element.size) {
+ obj.element.size = Element.getBorderBoxSize(obj.element);
+ var barSize = obj.element.size;
+ rsLeft = leftEdge + barSize.width;
+ var parentSize = Element.getContentBoxSize(this.domObj);
+ if (rightSide.jxLayout.options.width != null) {
+ rsWidth = rightSide.jxLayout.options.width + rightSide.jxLayout.options.left - rsLeft;
+ rsRight = parentSize.width - rsLeft - rsWidth;
+ } else {
+ rsWidth = parentSize.width - rightSide.jxLayout.options.right - rsLeft;
+ rsRight = rightSide.jxLayout.options.right;
+ /* enforce constraints on right side */
+ if (rsWidth < 0) {
+ rsWidth = 0;
+ if (rsWidth < rightSide.jxLayout.options.minWidth) {
+ rsWidth = rightSide.jxLayout.options.minWidth;
+ if (rightSide.jxLayout.options.maxWidth >= 0 && rsWidth > rightSide.jxLayout.options.maxWidth) {
+ rsWidth = rightSide.jxLayout.options.maxWidth;
+ rsLeft = parentSize.width - rsRight - rsWidth;
+ leftEdge = rsLeft - barSize.width;
+ /* process left side */
+ var lsLeft, lsWidth;
+ lsLeft = leftSide.jxLayout.options.left;
+ lsWidth = leftEdge - lsLeft;
+ /* enforce constraints on left */
+ if (lsWidth < 0) {
+ lsWidth = 0;
+ if (lsWidth < leftSide.jxLayout.options.minWidth) {
+ lsWidth = leftSide.jxLayout.options.minWidth;
+ if (leftSide.jxLayout.options.maxWidth >= 0 &&
+ lsWidth > leftSide.jxLayout.options.maxWidth) {
+ lsWidth = leftSide.jxLayout.options.maxWidth;
+ /* update the leftEdge to accomodate constraints */
+ if (lsLeft + lsWidth != leftEdge) {
+ /* need to update right side, ignoring constraints because left side
+ constraints take precedence (arbitrary decision)
+ leftEdge = lsLeft + lsWidth;
+ var delta = leftEdge + barSize.width - rsLeft;
+ rsLeft += delta;
+ rsWidth -= delta;
+ /* put bar in its final location based on constraints */
+ obj.element.style.left = leftEdge + 'px';
+ /* update leftSide positions */
+ if (leftSide.jxLayout.options.width == null) {
+ leftSide.jxLayout.resize({right: parentSize.width - lsLeft-lsWidth});
+ } else {
+ leftSide.jxLayout.resize({width: lsWidth});
+ /* update rightSide position */
+ if (rightSide.jxLayout.options.width == null) {
+ rightSide.jxLayout.resize({left:rsLeft});
+ } else {
+ rightSide.jxLayout.resize({left: rsLeft, width: rsWidth});
+ * Method: dragVertical
+ * In a vertically split container, handle a bar being dragged up or
+ * down by resizing the elements on either side of the bar.
+ * Parameters:
+ dragVertical: function(eventName, obj, event) {
+ /* top edge of the bar */
+ var topEdge = parseInt(obj.element.style.top);
+ /* the containers on either side of the bar */
+ var topSide = obj.element.leftSide;
+ var bottomSide = obj.element.rightSide;
+ /* measure the bar and parent container for later use */
+ /* process top side first */
+ var bsTop, bsHeight, bsBottom;
+ /* top edge of bottom side is the top edge of bar plus the height of the bar */
+ bsTop = topEdge + barSize.height;
+ if (bottomSide.jxLayout.options.height != null) {
+ /* bottom side height is fixed */
+ bsHeight = bottomSide.jxLayout.options.height + bottomSide.jxLayout.options.top - bsTop;
+ bsBottom = parentSize.height - bsTop - bsHeight;
+ } else {
+ /* bottom side height is not fixed. */
+ bsHeight = parentSize.height - bottomSide.jxLayout.options.bottom - bsTop;
+ bsBottom = bottomSide.jxLayout.options.bottom;
+ /* enforce constraints on bottom side */
+ if (bsHeight < 0) {
+ bsHeight = 0;
+ if (bsHeight < bottomSide.jxLayout.options.minHeight) {
+ bsHeight = bottomSide.jxLayout.options.minHeight;
+ if (bottomSide.jxLayout.options.maxHeight >= 0 && bsHeight > bottomSide.jxLayout.options.maxHeight) {
+ bsHeight = bottomSide.jxLayout.options.maxHeight;
+ /* recalculate the top of the bottom side in case it changed
+ due to a constraint. The bar may have moved also.
+ bsTop = parentSize.height - bsBottom - bsHeight;
+ topEdge = bsTop - barSize.height;
+ var tsTop, tsHeight;
+ tsTop = topSide.jxLayout.options.top;
+ tsHeight = topEdge - tsTop;
+ if (tsHeight < 0) {
+ tsHeight = 0;
+ if (tsHeight < topSide.jxLayout.options.minHeight) {
+ tsHeight = topSide.jxLayout.options.minHeight;
+ if (topSide.jxLayout.options.maxHeight >= 0 &&
+ tsHeight > topSide.jxLayout.options.maxHeight) {
+ tsHeight = topSide.jxLayout.options.maxHeight;
+ /* update the topEdge to accomodate constraints */
+ if (tsTop + tsHeight != topEdge) {
+ topEdge = tsTop + tsHeight;
+ var delta = topEdge + barSize.height - bsTop;
+ bsTop += delta;
+ bsHeight -= delta;
+ obj.element.style.top = topEdge + 'px';
+ /* update topSide positions */
+ if (topSide.jxLayout.options.height == null) {
+ topSide.jxLayout.resize({bottom: parentSize.height - tsTop-tsHeight});
+ } else {
+ topSide.jxLayout.resize({height: tsHeight});
+ /* update bottomSide position */
+ if (bottomSide.jxLayout.options.height == null) {
+ bottomSide.jxLayout.resize({top:bsTop});
+ } else {
+ bottomSide.jxLayout.resize({top: bsTop, height: bsHeight});
+ * Method: sizeChanged
+ * handle the size of the container being changed.
+ sizeChanged: function() {
+ this.horizontalResize();
+ } else {
+ this.verticalResize();
+ * Method: horizontalResize
+ * Resize a horizontally layed-out container
+ horizontalResize: function() {
+ var availableSpace = Element.getContentBoxSize(this.domObj).width;
+ var overallWidth = availableSpace;
+ for (var i=0; i<this.bars.length; i++) {
+ var bar = this.bars[i];
+ if (!bar.size) {
+ bar.size = Element.getBorderBoxSize(bar);
+ availableSpace -= bar.size.width;
+ var nVariable = 0;
+ var jxo;
+ for (var i=0; i<this.elements.length; i++) {
+ var e = this.elements[i];
+ jxo = e.jxLayout.options;
+ if (jxo.width != null) {
+ availableSpace -= parseInt(jxo.width);
+ } else {
+ var w = 0;
+ if (jxo.right != 0 ||
+ jxo.left != 0) {
+ w = Element.getBorderBoxSize(e).width;
+ availableSpace -= w;
+ nVariable++;
+ if (nVariable == 0) { /* all fixed */
+ /* stick all available space in the last one */
+ availableSpace += jxo.width;
+ jxo.width = null;
+ nVariable = 1;
+ var amount = parseInt(availableSpace / nVariable);
+ /* account for rounding errors */
+ var remainder = availableSpace % nVariable;
+ var currentPosition = 0;
+ var jxl = e.jxLayout;
+ var jxo = jxl.options;
+ jxl.resize({left: currentPosition});
+ currentPosition += jxo.width;
+ } else {
+ var a = amount;
+ if (nVariable == 1) {
+ a += remainder;
+ nVariable--;
+ var w = 0;
+ if (jxo.right != 0 || jxo.left != 0) {
+ w = Element.getBorderBoxSize(e).width + a;
+ } else {
+ w = a;
+ if (w < 0) {
+ if (nVariable > 0) {
+ amount = amount + w/nVariable;
+ w = 0;
+ if (w < jxo.minWidth) {
+ amount = amount + (w - jxo.minWidth)/nVariable;
+ w = jxo.minWidth;
+ if (jxo.maxWidth >= 0 && w > jxo.maxWidth) {
+ amount = amount + (w - jxo.maxWidth)/nVariable;
+ w = e.options.maxWidth;
+ var r = overallWidth - currentPosition - w;
+ jxl.resize({left: currentPosition, right: r});
+ currentPosition += w;
+ if (e.rightBar) {
+ e.rightBar.style.left = currentPosition + 'px';
+ currentPosition += e.rightBar.size.width;
+ * Method: verticalResize
+ * Resize a vertically layed out container.
+ verticalResize: function() {
+ var availableSpace = Element.getContentBoxSize(this.domObj).height;
+ var overallHeight = availableSpace;
+ if (!bar.size) {
+ availableSpace -= bar.size.height;
+ var jxo;
+ if (jxo.height != null) {
+ availableSpace -= parseInt(jxo.height);
+ } else {
+ var h = 0;
+ if (jxo.bottom != 0 || jxo.top != 0) {
+ h = Element.getBorderBoxSize(e).height;
+ availableSpace -= h;
+ nVariable++;
+ availableSpace += jxo.height;
+ jxo.height = null;
+ nVariable = 1;
+ jxl.resize({top: currentPosition});
+ currentPosition += jxo.height;
+ } else {
+ var a = amount;
+ a += remainder;
+ nVariable--;
+ var h = 0;
+ jxo.top != 0) {
+ h = Element.getBorderBoxSize(e).height + a;
+ } else {
+ h = a;
+ if (h < 0) {
+ amount = amount + h/nVariable;
+ h = 0;
+ if (h < jxo.minHeight) {
+ amount = amount + (h - jxo.minHeight)/nVariable;
+ h = jxo.minHeight;
+ if (jxo.maxHeight >= 0 && h > jxo.maxHeight) {
+ amount = amount + (h - jxo.maxHeight)/nVariable;
+ h = jxo.maxHeight;
+ var r = overallHeight - currentPosition - h;
+ jxl.resize({top: currentPosition, bottom: r});
+ currentPosition += h;
+ if (e.rightBar) {
+ e.rightBar.style.top = currentPosition + 'px';
+ currentPosition += e.rightBar.size.height;
+ * Class: Jx.Splitter.Snapper
+ * A helper class to create an element that can snap a split panel open or
+ * closed.
+Jx.Splitter.Snapper = Class.create();
+Jx.Splitter.Snapper.prototype = {
+ * Property: snapper
+ * {HTMLElement} the DOM element of the snapper (the thing that gets
+ * clicked).
+ snapper: null,
+ * {HTMLElement} An element of the <Jx.Splitter> that gets controlled
+ * by this snapper
+ element: null,
+ * Property: splitter
+ * {<Jx.Splitter>} the splitter that this snapper is associated with.
+ splitter: null,
+ * Property: layout
+ * {String} track the layout of the splitter for convenience.
+ * Constructor: Jx.Splitter.Snapper
+ * Create a new Jx.Splitter.Snapper
+ * Parameters:
+ * snapper - {HTMLElement} the clickable thing that snaps the element
+ * open and closed
+ * element - {HTMLElement} the element that gets controlled by the snapper
+ * splitter - {<Jx.Splitter>} the splitter that this all happens inside of.
+ initialize: function(snapper, element, splitter) {
+ this.snapper = snapper;
+ this.element = element;
+ element.jxLayout.addSizeChangeListener(this);
+ this.splitter = splitter;
+ this.layout = splitter.layout;
+ var jxo = this.element.jxLayout.options;
+ var size = Element.getBorderBoxSize(this.element);
+ if (this.layout == 'vertical') {
+ this.originalSize = size.height;
+ this.minimumSize = jxo.minHeight ? jxo.minHeight : 0;
+ } else {
+ this.originalSize = size.width;
+ this.minimumSize = jxo.minWidth ? jxo.minWidth : 0;
+ Event.observe(snapper, 'click', this.toggleElement.bind(this));
+ * Method: toggleElement
+ * Snap the element open or closed.
+ toggleElement: function() {
+ var newSize = {};
+ if (size.height == this.minimumSize) {
+ newSize.height = this.originalSize;
+ } else {
+ newSize.height = this.minimumSize;
+ } else {
+ if (size.width == this.minimumSize) {
+ newSize.width = this.originalSize;
+ } else {
+ newSize.width = this.minimumSize;
+ this.element.jxLayout.resize(newSize);
+ this.splitter.sizeChanged();
+ * Handle the size of the element changing to see if the
+ * toggle state has changed.
+ Element.addClassName(this.snapper, 'jxSnapClosed');
+ Element.removeClassName(this.snapper, 'jxSnapOpened');
+ } else {
+ Element.addClassName(this.snapper, 'jxSnapOpened');
+ Element.removeClassName(this.snapper, 'jxSnapClosed');
+ } else {
+ } else {
+ * $Id: jxtab.js 512 2008-03-07 21:15:45Z pspencer $
+ * Title: Jx.Tab
+ * Purpose:
+ * Implementation of a javascript tabbed panel capability for Jx.
+ * Author:
+ * Copyright:
+Jx.addStyleSheet('tab/tabs.css');
+Jx.addStyleSheet('tabs/tabs_ie.css', true);
+ * Class: Jx.TabSet
+ * A TabSet manages a set of <Jx.Tab> content areas by ensuring that only one
+ * of the content areas is visible (i.e. the active tab). TabSet does not
+ * manage the actual tabs. The instances of <Jx.Tab> that are to be managed
+ * as a set have to be added to both a TabSet and a <Jx.Toolbar>. The content
+ * areas of the <Jx.Tab>s are sized to fit the content area that the TabSet
+ * is managing.
+ * (code)
+ * var tabBar = new Jx.Toolbar('tabBar');
+ * var tabSet = new Jx.TabSet('tabArea');
+ * var tab1 = new Jx.Tab('tab 1', {contentID: 'content1'});
+ * var tab2 = new Jx.Tab('tab 2', {contentID: 'content2'});
+ * var tab3 = new Jx.Tab('tab 3', {contentID: 'content3'});
+ * var tab4 = new Jx.Tab('tab 4', {contentURL: 'test_content.html'});
+ * tabSet.add(t1, t2, t3, t4);
+ * tabBar.add(t1, t2, t3, t4);
+ * (end)
+ * Inherits From:
+ * <Jx.Listener>
+Jx.TabSet = Class.create();
+Jx.TabSet.prototype = {
+ * {HTMLElement} The HTML element that represents this tab set in the DOM.
+ * The content areas of each tab are sized to fill the domObj.
+ domObj : null,
+ * Property: sl
+ * {Array} array of selection listeners.
+ sl: null,
+ * Constructor: Jx.TabSet
+ * Create a new instance of <Jx.TabSet> within a specific element of
+ * the DOM.
+ * Parameters:
+ * domObj - {HTMLElement} an element or id of an element to put the
+ * content of the tabs into.
+ initialize : function(domObj) {
+ if (!Element.hasClassName(this.domObj, 'jxTabSetContainer')) {
+ Element.addClassName(this.domObj, 'jxTabSetContainer');
+ this.sl = [];
+ * Respond to the size of the container changing.
+ * TODO: is this needed?
+ this.resizeTabBox();
+ * Method: resizeTabBox
+ * Resize the tab set content area and propogate the changes to
+ * each of the tabs managed by the tab set.
+ resizeTabBox: function() {
+ var parentSize = Element.getContentBoxSize(this.domObj.parentNode);
+ Element.setBorderBoxSize(this.domObj, {width: parentSize.width, height: parentSize.height});
+ // this is a bullshit hack for IE. We need to set the tab content height
+ // for IE when the tabs are in a snap panel, otherwise the tab content
+ // doesn't collapse with the panel and no scrollbars appear. This only
+ // affects the height. In fact, setting the width breaks tab placement
+ // don't try to set the height on a text node
+ if (this.domObj.childNodes[i].nodeType == 3) {
+ continue;
+ Element.setBorderBoxSize(this.domObj.childNodes[i], {height: parentSize.height});
+ if (this.domObj.childNodes[i].resize) {
+ this.domObj.childNodes[i].resize({forceResize: true});
+ * Method: add
+ * Add one or more <Jx.Tab>s to the TabSet.
+ * Parameters:
+ * tab - {<Jx.Tab>} an instance of <Jx.Tab> to add to the tab set. More
+ * than one tab can be added by passing extra parameters to this method.
+ var tab = arguments[i];
+ tab.addSelectionListener(this);
+ this.domObj.appendChild(tab.content);
+ if (!this.activeTab) {
+ this.setActiveTab(tab);
+ * Method: remove
+ * Remove a tab from the TabSet.
+ * Parameters:
+ * tab - {<Jx.Tab>} the tab to remove.
+ * TODO: Implement remove for Jx.TabSet
+ remove : function(tab) {},
+ * Method: setActiveTab
+ * Set the active tab to the one passed to this method
+ * Parameters:
+ * tab - {<Jx.Tab>} the tab to make active.
+ setActiveTab: function(tab) {
+ if (this.activeTab) {
+ Element.removeClassName(this.activeTab.domObj, 'tabActive');
+ Element.removeClassName(this.activeTab.content, 'tabContentActive');
+ this.activeTab = tab;
+ Element.addClassName(this.activeTab.domObj, 'tabActive');
+ Element.addClassName(this.activeTab.content, 'tabContentActive');
+ if (this.activeTab.content.resize) {
+ this.activeTab.content.resize({forceResize: true});
+ * Method: selectionChanged
+ * Handle selection changing on the tabs themselves and activate the
+ * appropriate tab in response.
+ * Parameters:
+ selectionChanged: function(tab) {
+ this.processEvent(this.sl, 'selectionChanged', tab);
+ * Parameters:
+ * obj - {Object} the selection listener to add
+ * Parameters:
+ * obj - {Object} the selection listener to remove
+Object.extend(Jx.TabSet.prototype, Jx.Listener.prototype);
+ * Class: Jx.Tab
+ * A single tab in a tab set. A tab has a label (displayed in the tab) and a
+ * content area that is displayed when the tab is active. A tab has to be
+ * added to both a <Jx.TabSet> (for the content) and <Jx.Toolbar> (for the
+ * actual tab itself) in order to be useful. Alternately, you can use
+ * a <Jx.TabBox> which combines both into a single control at the cost of
+ * some flexibility in layout options.
+ * A tab is a <Jx.ContentLoader> and you can specify the initial content of
+ * the tab using any of the methods supported by
+ * <Jx.ContentLoader::loadContent>. You can acccess the actual DOM element
+ * that contains the content (if you want to dynamically insert content
+ * for instance) via the <Jx.Tab::content> property.
+ * (code)
+ * (end)
+ * Inherits From:
+ * <Jx.Listener>, <Jx.ContentLoader>
+Jx.Tab = Class.create();
+Jx.Tab.prototype = {
+ * {HTMLElement} The button that is used to activate the tab.
+ domObj: null,
+ * Property: content
+ * {HTMLElement} The content area that is displayed when the tab is active.
+ content: null,
+ * Property: name
+ * {String} the name of the tab is also the label.
+ name: null,
+ * Property: sl
+ * {Array} an array of selection listeners.
+ sl: null,
+ * Create a new instance of Jx.Tab.
+ * Parameters:
+ * name - {String} the name (and label) of the tab.
+ * options - {Object} an object containing options that are used
+ * to control the appearance of the tab. See
+ * <Jx.ContentLoader::loadContent> and <Jx.Layout::Jx.Layout> for
+ * valid options.
+ initialize : function(name, options) {
+ this.sl = [];
+ this.name = name;
+ this.content.className = 'tabContent';
+ var a = new Jx.Action(this.clicked.bind(this));
+ var b = new Jx.Button(a, {label: name});
+ this.domObj = b.domA;
+ // rename the element from jxButton to jxTab
+ // Element.removeClassName(this.domObj, 'jxButton');
+ Element.addClassName(this.domObj, 'jxTab');
+ new Jx.Layout(this.content, options);
+ //this.content.resize = this.resize.bind(this);
+ * Method: clicked
+ * Handle the tab being clicked by generating a selectionChanged
+ * event.
+ clicked: function() {
+ this.domObj.childNodes[0].blur();
+ * Parameters:
+ * Parameters:
+Object.extend(Jx.Tab.prototype, Jx.Listener.prototype);
+Object.extend(Jx.Tab.prototype, Jx.ContentLoader.prototype);
+ * Class: Jx.TabBox
+ * A convenience class to handle the common case of a single toolbar
+ * directly attached to the content area of the tabs. It manages both a
+ * <Jx.Toolbar> and a <Jx.TabSet> so that you don't have to. If you are using
+ * a TabBox, then tabs only have to be added to the TabBox rather than to
+ * both a <Jx.TabSet> and a <Jx.Toolbar>.
+ * (code)
+ * var tabBox = new Jx.TabBox('subTabArea', 'top');
+ * var tab1 = new Jx.Tab('Tab 1', {contentID: 'content4'});
+ * var tab2 = new Jx.Tab('Tab 2', {contentID: 'content5'});
+ * tabBox.add(tab1, tab2);
+ * (end)
+ * Inherits From:
+ * <Jx.Listener>
+Jx.TabBox = Class.create();
+Jx.TabBox.prototype = {
+ * Property: tabBar
+ * {<Jx.Toolbar>} the toolbar for this tab box.
+ tabBar: null,
+ * Property: tabSet
+ * {<Jx.TabSet>} the tab set for this tab box.
+ tabSet: null,
+ * Constructor: Jx.TabBox
+ initialize : function(domObj, position) {
+ var parent = $(domObj);
+ position = position || 'top';
+ var tabBarDiv = document.createElement('div');
+ parent.appendChild(tabBarDiv);
+ this.tabBar = new Jx.Toolbar(tabBarDiv, position);
+ this.tabSet = new Jx.TabSet(parent);
+ switch (position) {
+ case 'top':
+ Element.addClassName(parent, 'jxTabBoxTop');
+ break;
+ case 'bottom':
+ Element.addClassName(parent, 'jxTabBoxBottom');
+ break;
+ case 'left':
+ Element.addClassName(parent, 'jxTabBoxLeft');
+ Element.addClassName(tabBarDiv, 'verticalToolbar');
+ break;
+ case 'right':
+ Element.addClassName(parent, 'jxTabBoxRight');
+ break;
+ this.sl = [];
+ * Handle the size of the content area of the tab box changing.
+ sizeChanged: function() { this.tabSet.sizeChanged(); },
+ * Method: add
+ * Add one or more <Jx.Tab>s to the TabBox.
+ * Parameters:
+ * tab - {<Jx.Tab>} an instance of <Jx.Tab> to add to the tab box. More
+ * Unlike <Jx.TabSet>, tabs do not have to be added to a separate
+ * <Jx.Toolbar>.
+ this.tabBar.add.apply(this.tabBar, arguments);
+ this.tabSet.add.apply(this.tabSet, arguments);
+ * Method: remove
+ * Parameters:
+ * TODO: implement remove for Jx.TabBox.
+ remove : function(tab) { /* TODO */ }
+Object.extend(Jx.TabBox.prototype, Jx.Listener.prototype);
+ * $Id: jxtoolbar.js 512 2008-03-07 21:15:45Z pspencer $
+ * Title: Jx.Toolbar
+ * Purpose:
+ * Implementation of a javascript Toolbar for Jx.
+ * Author:
+ * Copyright:
+ * import stylesheets
+Jx.addStyleSheet('toolbar/toolbar.css');
+Jx.addStyleSheet('button/button.css');
+ * Class: Jx.Toolbar
+ * A toolbar is a container object that contains other objects such as
+ * buttons. The toolbar organizes the objects it contains automatically,
+ * wrapping them as necessary. Multiple toolbars may be placed within
+ * the same containing object.
+ * Jx.Toolbar includes CSS classes for styling the appearance of a
+ * toolbar to be similar to traditional desktop application toolbars.
+ * There is one special object, Jx.ToolbarSeparator, that provides
+ * a visual separation between objects in a toolbar.
+ * The following example shows how to create a Jx.Toolbar instance and place two objects in it.
+ * (code)
+ * //myToolbarContainer is the id of a <div> in the HTML page.
+ * function myFunction() {}
+ * var myToolbar = new Jx.Toolbar('myToolbarContainer');
+ * var myAction = new Jx.Action(myFunction):
+ * var myButton = new Jx.Button(myAction);
+ * var myElement = document.createElement('select');
+ * myToolbar.add(myButton, new Jx.ToolbarSeparator(), myElement);
+ * (end)
+ * While a toolbar is generally a *dumb* container, it serves a special purpose
+ * for menus by providing some infrastructure so that menus can behave
+ * properly.
+ * In general, almost anything can be placed in a Toolbar, and mixed with
+ * anything else.
+Jx.Toolbar = Class.create();
+Jx.Toolbar.prototype = {
+ * Property: items
+ * {Array} an array of the things in the toolbar.
+ items : null,
+ * {HTMLElement} the HTML element that the toolbar lives in
+ domObj : null,
+ * Property: isActive
+ * When a toolbar contains <Jx.Menu> instances, they want to know
+ * if any menu in the toolbar is active and this is how they
+ * find out.
+ isActive : false,
+ * Constructor: Jx.Toolbar
+ * Create a new instance of Jx.Toolbar.
+ * Parameters:
+ * domObj - {HTMLElement} object reference or id to place the toolbar in.
+ * position - one of 'top', 'right', 'bottom', or 'left', indicates how
+ * the toolbar is being placed in the page and may influence the behaviour
+ * of items in the toolbar that open sub panels, they will tend to open
+ * them towards the center of the page. Default is top.
+ this.domObj = document.createElement('ul');
+ Element.addClassName(this.domObj,'jxToolbar');
+ if (!Element.hasClassName(parent, 'jxToolbarContainer')) {
+ Element.addClassName(parent, 'jxToolbarContainer');
+ parent.appendChild(this.domObj);
+ var clearer = document.createElement('div');
+ clearer.className = 'jxClearer';
+ parent.appendChild(clearer);
+ } else {
+ parent.insertBefore(this.domObj, parent.lastChild);
+ case 'top':
+ Element.addClassName(parent, 'jxBarTop');
+ break;
+ case 'right':
+ Element.addClassName(parent, 'jxBarRight');
+ break;
+ case 'bottom':
+ Element.addClassName(parent, 'jxBarBottom');
+ break;
+ case 'left':
+ Element.addClassName(parent, 'jxBarLeft');
+ break;
+ default:
+ this.deactivateWatcher = this.deactivate.bindAsEventListener(this);
+ * Method: add
+ * Add an item to the toolbar. If the item being added is a Jx component
+ * with a domObj property, the domObj is added. If the item being added
+ * is an LI element, then it is given a CSS class of *jxToolItem*.
+ * Otherwise, the thing is wrapped in a <Jx.ToolbarItem>.
+ * Parameters:
+ * thing - {Object} the thing to add. More than one thing can be added
+ * by passing multiple arguments.
+ add : function( ) {
+ var thing = arguments[i];
+ thing.toolbar = this;
+ if (thing.domObj) {
+ thing = thing.domObj;
+ if (thing.tagName == 'LI') {
+ if (!Element.hasClassName(thing, 'jxToolItem')) {
+ Element.addClassName(thing, 'jxToolItem');
+ this.domObj.appendChild(thing);
+ } else {
+ var item = new Jx.ToolbarItem(thing);
+ this.domObj.appendChild(item.domObj);
+ * Deactivate the Toolbar (when it is acting as a menu bar).
+ this.setActive(false);
+ * Indicate if the toolbar is currently active (as a menu bar)
+ * Returns:
+ * {Boolean}
+ return this.isActive;
+ * Set the active state of the toolbar (for menus)
+ * Parameters:
+ * b - {Boolean} the new state
+ setActive: function(b) {
+ this.isActive = b;
+ if (this.isActive) {
+ Event.observe(document, 'click', this.deactivateWatcher);
+ } else {
+ Event.stopObserving(document, 'click', this.deactivateWatcher);
+ * For menus, they want to know which menu is currently open.
+ * Parameters:
+ * obj - {<Jx.Menu>} the menu that just opened.
+ if (this.visibleItem && this.visibleItem.hide && this.visibleItem != obj) {
+ if (this.isActive()) {
+ * Class: Jx.ToolbarItem
+ * A helper class to provide a container for something to go into
+ * a <Jx.Toolbar>.
+Jx.ToolbarItem = Class.create();
+Jx.ToolbarItem.prototype = {
+ * Property: domObj
+ * {HTMLElement} an element to contain the thing to be placed in the
+ * toolbar.
+ domObj: null,
+ * Constructor: Jx.ToolbarItem
+ * Create a new instance of Jx.ToolbarItem.
+ * Parameters:
+ * jxThing - {Object} the thing to be contained.
+ initialize : function( jxThing ) {
+ this.al = [];
+ this.domObj = document.createElement('li');
+ this.domObj.className = 'jxToolItem';
+ if (jxThing) {
+ if (jxThing.domObj) {
+ this.domObj.appendChild(jxThing.domObj);
+ if (jxThing instanceof Jx.Tab) {
+ // this.domObj.className = 'jxTabItem';
+ Element.addClassName(this.domObj, 'jxTabItem');
+ } else {
+ this.domObj.appendChild(jxThing);
+ if (Element.hasClassName(jxThing, 'jxTab')) {
+ * Class: Jx.ToolbarSeparator
+ * A helper class that represents a visual separator in a <Jx.Toolbar>
+Jx.ToolbarSeparator = Class.create();
+Jx.ToolbarSeparator.prototype = {
+ * {HTMLElement} The DOM element that goes in the <Jx.Toolbar>
+ domObj: null,
+ * Constructor: Jx.ToolbarSeparator
+ * Create a new Jx.ToolbarSeparator
+ this.domSpan = document.createElement('span');
+ this.domSpan.className = 'separator';
+ this.domObj.appendChild(this.domSpan);
+ * $Id: jxtree.js 512 2008-03-07 21:15:45Z pspencer $
+ * Title: Jx.Tree
+ * Purpose:
+ * Implementation of a javascript Tree for Jx.
+ * Author:
+ * Copyright:
+Jx.addStyleSheet('tree/tree.css');
+Jx.addStyleSheet('tree/tree_ie.css', true);
+ * Class: Jx.TreeItem
+ * An item in a tree. An item is a leaf node that has no children.
+ * Jx.TreeItem supports selection listeners. When an item in the tree
+ * is selected by the user, listeners are called by invoking the
+ * selectionChanged method on the listener and passing the tree item
+ * object that was selected. The application is responsible for
+ * changing the style of the selected item in the tree and for
+ * tracking selection if that is important.
+ * When the selection changes, the mouse event that triggered the
+ * selection change is passed to the listener as a lastEvent
+ * member of the tree item object. You can use this to determine
+ * if the item was clicked, double-clicked, right clicked etc.
+ * Inherits From:
+ * <Jx.Listener>
+Jx.TreeItem = Class.create();
+Jx.TreeItem.prototype = {
+ * Property: data
+ * {Object} arbitrary data associated with the TreeItem
+ data : null,
+ * {HTMLElement} a reference to the HTML element that is the TreeItem
+ * in the DOM
+ domObj : null,
+ * Property: parent
+ * {Object} the folder or tree that this item belongs to
+ parent : null,
+ * Property: currentClassName
+ * {String} the current CSS class name for this TreeItem.
+ * TODO: Property currentClassName
+ * This property does not appear to be used?
+ currentClassName : null,
+ * Property: onClick
+ * {Function} callback function to invoke with the TreeItem is clicked
+ onClick : null,
+ * Property: sl
+ sl : null,
+ * Property: enabled
+ * {Boolean} is the TreeItem enabled or not?
+ enabled : null,
+ * Property: contextMenu
+ * {<Jx.ContextMenu>} an optional context menu for the TreeItem
+ contextMenu : null,
+ * Constructor: Jx.TreeItem
+ * Create a new instance of Jx.TreeItem with the associated options
+ * Parameters:
+ * options - {Object} an object containing the below optional
+ * attributes that control how the TreeItem functions.
+ * Options:
+ * label - {String} the label to display for the TreeItem
+ * data - {Object} any arbitrary data to be associated with the TreeItem
+ * contextMenu - {<Jx.ContextMenu>} the context menu to trigger if there
+ * is a right click on the node
+ * imgNode - {String} URL to an image to use for the node of this
+ * TreeItem. Not sure if this should ever be set.
+ * imgIcon - {String} URL to an image to use as the icon next to the
+ * label of this TreeItem
+ * enabled - {Boolean} the initial state of the TreeItem. If the
+ * TreeItem is not enabled, it cannot be clicked.
+ initialize : function( options ) {
+ this.initializeItem(options);
+ * Method: initializeItem
+ * internal method to initialize the TreeItem.
+ * Parameters:
+ * options - See <Jx.TreeItem::Jx.TreeItem>
+ initializeItem: function(options) {
+ this.sl = [];
+ var label = options.label || 'new node';
+ this.data = options.data || null;
+ this.contextMenu = options.contextMenu || null;
+ this.imgNode = options.imgNode || Jx.baseURL + 'images/tree_none.png';
+ this.imgIcon = options.imgIcon || Jx.baseURL + 'images/tree_page.png';
+ this.domObj.className = 'jxTreeNode';
+ this.currentClassName = 'jxTreeNode';
+ var elm = document.createElement('img');
+ elm.className = 'jxTreeNodeImage';
+ //elm.src = this.imgNode;
+ Jx.addToImgQueue({domElement: elm, src: this.imgNode});
+ this.domObj.appendChild(elm);
+ elm = document.createElement('img');
+ elm.className = 'jxTreeNodeIcon';
+ //elm.src = this.imgIcon;
+ Jx.addToImgQueue({domElement: elm, src: this.imgIcon});
+ elm = document.createElement('a');
+ elm.href = 'javascript:void(0)';
+ elm.onclick = this.selected.bindAsEventListener(this);
+ elm.ondblclick = this.selected.bindAsEventListener(this);
+ elm.oncontextmenu = this.showMenu.bindAsEventListener(this);
+ elm.innerHTML = label;
+ //this.update(false);
+ //TODO: this could cause a memory leak in remove
+ this.domObj.jxTreeItem = this;
+ this.domObj.childNodes[2].jxTreeItem = this;
+ this.onClick = options.onClick || null;
+ this.enabled = typeof options.enabled != 'undefined' ? options.enabled : true;
+ if (this.enabled) {
+ Element.removeClassName(this.domObj, 'jxDisabled');
+ } else {
+ Element.addClassName(this.domObj, 'jxDisabled');
+ var clearer = document.createElement('span');
+ this.domObj.appendChild(clearer);
+ * Clean up the TreeItem and remove all DOM references
+ finalize: function() { this.finalizeItem(); },
+ * Method: finalizeItem
+ finalizeItem: function() {
+ if (!this.domObj) {
+ return;
+ this.domObj.childNodes[2].onclick = null;
+ this.domObj.childNodes[2].ondblclick = null;
+ this.domObj.childNodes[2].oncontextmenu = null;
+ this.contextMenu = null;
+ this.onClick = null;
+ for (var i=this.sl.length; i>=0; i--) {
+ this.removeSelectionListener(this.sl[i]);
+ this.parent = null;
+ this.domObj.jxTreeItem = null;
+ * Method: clone
+ * Create a clone of the TreeItem
+ * Returns:
+ * {<Jx.TreeItem>} a copy of the TreeItem
+ clone : function() {
+ var options = { label : this.domObj.childNodes[2].innerHTML,
+ data : this.data,
+ onClick : this.onClick,
+ imgNode : this.imgNode,
+ imgIcon : this.imgIcon
+ var item = new Jx.TreeItem(options);
+ return item;
+ * Method: update
+ * Update the CSS of the TreeItem's DOM element in case it has changed
+ * position
+ * Parameters:
+ * shouldDescend - {Boolean} propagate changes to child nodes?
+ update : function(shouldDescend) {
+ var isLast = (arguments.length > 1) ? arguments[1] :
+ (this.parent && this.parent.isLastNode(this));
+ if (isLast) {
+ Element.removeClassName(this.domObj, 'jxTreeNode');
+ Element.addClassName(this.domObj, 'jxTreeNodeLast');
+ } else {
+ Element.removeClassName(this.domObj, 'jxTreeNodeLast');
+ Element.addClassName(this.domObj, 'jxTreeNode');
+ * Method: selected
+ * Called when the DOM element for the TreeItem is clicked, the
+ * node is selected.
+ * Parameters:
+ * e - {Event} the DOM event
+ selected : function(e) {
+ this.lastEvent = e?e:event;
+ this.processEvent(this.sl,'selectionChanged',this);
+ * Method: showMenu
+ * Called when the DOM element for the TreeItem is right-clicked. The
+ * node is selected and the context menu displayed (if there is one).
+ * Parameters:
+ showMenu: function(e) {
+ if (this.contextMenu) {
+ this.contextMenu.show(this.lastEvent);
+ Event.stop(e);
+ * Add a selection listener.
+ * Parameters:
+ * obj - {Object} the object to add as a selection listener
+ addSelectionListener: function(obj){this.addListener(this.sl, obj);},
+ * Remove a selection listener.
+ * Parameters:
+ * obj - {Object} the object to remove as a selection listener
+ removeSelectionListener: function(obj) {this.removeListener(this.sl, obj);},
+ * Method: getName
+ * Get the label associated with a TreeItem
+ * Returns:
+ getName : function() { return this.domObj.childNodes[2].innerHTML; },
+ * Method: setName
+ * Set the label of a TreeItem
+ * Parameters:
+ * name - {String} the new label
+ setName : function(name) { this.domObj.childNodes[2].innerHTML = name; },
+ * Method: propertyChanged
+ * A property of an object has changed, synchronize the state of the
+ * TreeItem with the state of the object
+ * Parameters:
+ * obj - {Object} the object whose state has changed
+ propertyChanged : function(obj) {
+ this.enabled = obj.isEnabled();
+ } else {
+Object.extend(Jx.TreeItem.prototype, Jx.Listener.prototype);
+ * Class: Jx.TreeFolder
+ * A Jx.TreeFolder is an item in a tree that can contain other items. It is
+ * expandable and collapsible.
+ * Inherits From:
+ * <Jx.TreeItem>
+Jx.TreeFolder = Class.create();
+Object.extend(Jx.TreeFolder.prototype, Jx.TreeItem.prototype);
+Object.extend(Jx.TreeFolder.prototype, {
+ * Property: subDomObj
+ * {HTMLElement} an HTML container for the things inside the folder
+ subDomObj : null,
+ * Property: nodes
+ * {Array} an array of references to the javascript objects that are
+ * children of this folder
+ nodes : null,
+ * Property: isOpen
+ * {Boolean} is the folder open or not?
+ isOpen : false,
+ * Property: dl
+ * {Array} disclosure listeners
+ dl : null,
+ * Constructor: Jx.TreeFolder
+ * Create a new instance of Jx.TreeFolder
+ * Parameters:
+ * options - {Object} an object containing any of the options of a
+ * <Jx.TreeItem> (see <Jx.TreeItem::Jx.TreeItem>) plus the following
+ * optional attributes that control how the TreeFolder functions.
+ * Options:
+ * imgTreePlus - {String} a URL to an image for opening the folder
+ * imgTreeMinus - {String} a URL to an image for closing the folder
+ * imgTreeFolder - {String} a URL to an image to represent the folder
+ * when it is closed
+ * imgTreeFolderOpen - {String} a URL to an image to represent the folder
+ * when it is open
+ this.initializeFolder(options);
+ * Method: initializeFolder
+ * Internal method for initializing a folder.
+ * Parameters:
+ * options - {Object} see <Jx.TreeFolder::Jx.TreeFolder> for options.
+ initializeFolder : function(options) {
+ this.imgTreePlus = options.imgTreePlus || Jx.baseURL + 'images/tree_plus.png';
+ this.imgTreeMinus = options.imgTreeMinus || Jx.baseURL + 'images/tree_minus.png';
+ this.imgTreeFolder = options.imgTreeFolder || Jx.baseURL + 'images/tree_folder.png';
+ this.imgTreeFolderOpen = options.imgTreeFolderOpen || Jx.baseURL + 'images/tree_folder_open.png';
+ //console.log('imgTreePlus is ' + this.imgTreePlus);
+ //this.domObj.childNodes[0].src = this.imgTreePlus;
+ //this.domObj.childNodes[1].src = this.imgTreeFolder;
+ Jx.addToImgQueue({domElement: this.domObj.childNodes[0], src: this.imgTreePlus});
+ Jx.addToImgQueue({domElement: this.domObj.childNodes[1], src: this.imgTreeFolder});
+ this.domObj.childNodes[0].onclick = this.clicked.bindAsEventListener(this);
+ this.nodes = [];
+ this.subDomObj = document.createElement('ul');
+ this.domObj.appendChild(this.subDomObj);
+ this.subDomObj.className = 'jxTree';
+ this.isOpen = options.isOpen || false;
+ this.dl = [];
+ if (this.isOpen) {
+ this.expand();
+ } else {
+ this.collapse();
+ //this.makeDroppable();
+ * Clean up a TreeFolder.
+ this.finalizeFolder();
+ this.finalizeItem();
+ this.subDomObj = null;
+ * Method: finalizeFolder
+ * Internal method to clean up folder-related stuff.
+ finalizeFolder: function() {
+ this.domObj.childNodes[0].onclick = null;
+ for (var i=this.nodes.length-1; i>=0; i--) {
+ this.nodes[i].finalize();
+ if (this.nodes[i].domObj) this.subDomObj.removeChild(this.nodes[i].domObj);
+ this.nodes.pop();
+ for (var i=this.dl.length-1; i>=0; i--) {
+ this.removeDisclosureListener(this.dl[i]);
+ makeDroppable : function() {
+ if (!document.Jx.TreeCurrentTimeout) document.Jx.TreeCurrentTimeout = null;
+ Droppables.add(this.domObj.childNodes[2], {
+ greedy : true,
+ onHover : function(draggable, droppable, overlap) {
+ var dropped = droppable.parentNode.jxTreeItem;
+ if (document.Jx.TreeCurrentTimeout &&
+ document.currentDroppable != droppable) {
+ window.clearTimeout(document.Jx.TreeCurrentTimeout);
+ document.Jx.TreeCurrentTimeout = null;
+ if (!document.Jx.TreeCurrentTimeout &&
+ dropped.nodes &&
+ !dropped.isOpen)
+ document.Jx.TreeCurrentTimeout = window.setTimeout(dropped.expand.bind(dropped), 700);
+ if (!document.currentHighlight != droppable) {
+ if (droppable == draggable)
+ Droppables.remove(droppable);
+ if (document.currentDroppable &&
+ Element.removeClassName(document.currentDroppable,
+ 'jxTreeDropzone');
+ Element.addClassName(droppable, 'jxTreeDropzone');
+ document.currentDroppable = droppable;
+ onDrop : function(draggable, droppable) {
+ var dragged = draggable.jxTreeItem;
+ Element.removeClassName(droppable,
+ if (dropped.nodes) {
+ dragged.parent.remove(dragged);
+ dropped.append(dragged);
+ dropped.expand();
+ } else if (dropped.parent != null) {
+ dropped.parent.insert(dragged,dropped);
+ * Method: clone
+ * Create a clone of the TreeFolder
+ * Returns:
+ * {<Jx.TreeFolder>} a copy of the TreeFolder
+ data : this.data,
+ imgTreePlus : this.imgTreePlus,
+ imgTreeMinus : this.imgTreeMinus,
+ imgTreeFolder : this.imgTreeFolder,
+ imgTreeFolderOpen : this.imgTreeFolderOpen
+ var node = new Jx.TreeFolder(options);
+ for (var i=0;i<this.nodes.length;i++) {
+ node.append(this.nodes[i].clone());
+ return node;
+ * Method: isLastNode
+ * Indicates if a node is the last thing in the folder.
+ * Parameters:
+ * node - {Jx.TreeItem} the node to check
+ * Returns:
+ * {Boolean}
+ isLastNode : function(node) {
+ if (this.nodes.length == 0) {
+ return false;
+ } else {
+ return this.nodes[this.nodes.length-1] == node;
+ * Method: update
+ * Update the CSS of the TreeFolder's DOM element in case it has changed
+ * position.
+ * Parameters:
+ update : function(bDescend) {
+ /* avoid update if not attached to tree yet */
+ if (!this.parent) return;
+ var bLast = false;
+ if (arguments.length > 1) {
+ bLast = arguments[1];
+ } else {
+ bLast = (this.parent && this.parent.isLastNode(this));
+ if (bLast) {
+ this.domObj.className = 'jxTreeNodeLast';
+ } else {
+ this.subDomObj.className = 'jxTree jxTreeNest';
+ //this.domObj.childNodes[0].src = this.imgTreeMinus;
+ //this.domObj.childNodes[1].src = this.imgTreeFolderOpen;
+ Jx.addToImgQueue({domElement: this.domObj.childNodes[0], src: this.imgTreeMinus});
+ Jx.addToImgQueue({domElement: this.domObj.childNodes[1], src: this.imgTreeFolderOpen});
+ } else {
+ if (this.nodes && bDescend) {
+ //this.nodes.each(function(n){n.update(true);});
+ for(var i=0; i<this.nodes.length; i++) {
+ this.nodes[i].update(false, i==this.nodes.length-1);
+ * Method: append
+ * append a node at the end of the sub-tree
+ * Parameters:
+ * node - {Object} the node to append.
+ append : function( node ) {
+ node.parent = this;
+ this.nodes.push(node);
+ this.subDomObj.appendChild( node.domObj );
+ this.update(true);
+ * Method: insert
+ * insert a node after refNode. If refNode is null, insert at beginning
+ * Parameters:
+ * node - {Object} the node to insert
+ * refNode - {Object} the node to insert before
+ insert : function( node, refNode ) {
+ //if refNode is not supplied, insert at the beginning.
+ if (!refNode) {
+ this.nodes.unshift(node);
+ //sanity check to make sure there is actually something there
+ if (this.subDomObj.childNodes.length ==0) {
+ this.subDomObj.appendChild(node.domObj);
+ } else {
+ this.subDomObj.insertBefore(node.domObj, this.subDomObj.childNodes[0]);
+ } else {
+ //walk all nodes looking for the ref node. Track if it actually
+ //happens so we can append if it fails.
+ var b = false;
+ for(var i=0;i<this.nodes.length;i++) {
+ if (this.nodes[i] == refNode) {
+ //increment to append after ref node. If this pushes us
+ //past the end, it'll get appended below anyway
+ i = i + 1;
+ if (i < this.nodes.length) {
+ this.nodes.splice(i, 0, node);
+ this.subDomObj.insertBefore(node.domObj, this.subDomObj.childNodes[i]);
+ b = true;
+ break;
+ //if the node wasn't inserted, it is because refNode didn't exist
+ //and so the fallback is to just append the node.
+ if (!b) {
+ //if (this.parent)
+ // this.parent.update(true);
+ * Method: remove
+ * remove the specified node from the tree
+ * Parameters:
+ * node - {Object} the node to remove
+ remove : function(node) {
+ node.parent = null;
+ if (this.nodes[i] == node) {
+ this.nodes.splice(i, 1);
+ this.subDomObj.removeChild(this.subDomObj.childNodes[i]);
+ break;
+ * Method: replace
+ * Replace a node with another node
+ * Parameters:
+ * newNode - {Object} the node to put into the tree
+ * refNode - {Object} the node to replace
+ * Returns:
+ * {Boolean} true if the replacement was successful.
+ replace: function( newNode, refNode ) {
+ var b = false;
+ newNode.parent = this;
+ this.nodes.splice(i, 1, newNode);
+ this.subDomObj.replaceChild(newNode.domObj, refNode.domObj);
+ return true;
+ return false;
+ * Method: clicked
+ * handle the user clicking on this folder by expanding or
+ * collapsing it.
+ * Parameters:
+ * e - {Event} the event object
+ clicked : function(e) {
+ e = e?e:event;
+ this.collapse();
+ } else {
+ this.expand();
+ * Method: expand
+ * Expands the folder
+ expand : function() {
+ this.isOpen = true;
+ this.subDomObj.style.display = 'block';
+ this.processEvent(this.dl, 'disclosed', this);
+ * Method: collapse
+ * Collapses the folder
+ collapse : function() {
+ this.isOpen = false;
+ this.subDomObj.style.display = 'none';
+ * Method: addDisclosureListener
+ * Add a disclosure (when the folder is opened) listener
+ * Parameters:
+ * obj - {Object} a discloser listener to add
+ addDisclosureListener: function(obj){this.addListener(this.dl, obj);},
+ * Method: removeDisclosureListener
+ * Remove a disclosure listener
+ * Parameters:
+ * obj - {Object} a discloser listener to remove
+ removeDisclosureListener: function(obj) {this.removeListener(this.dl, obj);},
+ * Method: findChild
+ * Get a reference to a child node by recursively searching the tree
+ * Parameters:
+ * path - {Array} an array of labels of nodes to search for
+ * Returns:
+ * {Object} the node or null if the path was not found
+ findChild : function(path) {
+ //path is empty - we are asking for this node
+ if (path.length == 0)
+ return this;
+ //path has only one thing in it - looking for something in this folder
+ if (path.length == 1)
+ for (var i=0; i<this.nodes.length; i++)
+ if (this.nodes[i].getName() == path[0])
+ return this.nodes[i];
+ return null;
+ //path has more than one thing in it, find a folder and descend into it
+ var childName = path.shift();
+ if (this.nodes[i].getName() == childName && this.nodes[i].findChild)
+ return this.nodes[i].findChild(path);
+ return null;
+ * Class: Jx.Tree
+ * Jx.Tree displays hierarchical data in a tree structure of folders and nodes.
+ * Inherits From:
+ * <Jx.TreeFolder>
+Jx.Tree = Class.create();
+Object.extend( Jx.Tree.prototype, Jx.TreeFolder.prototype );
+Object.extend( Jx.Tree.prototype, {
+ * Parameters:
+ * id - {String} the id of the DOM element to create the tree inside.
+ initialize : function( id ) {
+ this.subDomObj.className = 'jxTreeRoot';
+ $(id).appendChild(this.subDomObj);
+ this.nodes = [];
+ this.dl = [];
+ * Clean up a Jx.Tree instance
+ this.clear();
+ this.subDomObj.parentNode.removeChild(this.subDomObj);
+ * Method: clear
+ * Clear the tree of all child nodes
+ clear: function() {
+ this.subDomObj.removeChild(this.nodes[i].domObj);
+ this.nodes.pop();
+ * Method: update
+ * Update the CSS of the Tree's DOM element in case it has changed
+ * position
+ * Parameters:
+ update: function(shouldDescend) {
+ var bLast = true;
+ if (this.subDomObj)
+ if (bLast) {
+ Element.removeClassName(this.subDomObj, 'jxTreeNest');
+ } else {
+ Element.addClassName(this.subDomObj, 'jxTreeNest');
+ if (this.nodes && shouldDescend) {
+ this.nodes.each(function(n){n.update(false);});
+ * Method: append
+ * Append a node at the end of the sub-tree
+ * Parameters:
+ append: function( node ) {
+ * this file is to be loaded/included after all other Jx files
+if (Jx.COMBINED_CSS) {
+ //console.log('Jx.COMBINED_CSS');
+ document.write('<link type="text/css" rel="stylesheet" href="'+Jx.baseURL+'lib/jx_combined.css" />\n');
+} else {
+ //console.log('no Jx.COMBINED_CSS');
+ for (var styleSheet in Jx.importRules) {
+ var url = Jx.baseURL+styleSheet;
+ document.write('<link type="text/css" rel="stylesheet" href="'+url+'" />\n');
+ document.write('<!--[if IE]>');
+ for (var styleSheet in Jx.importRulesIE) {
+ document.write('<![endif]-->\n');
\ No newline at end of file
Added: trunk/jx/lib/jx_compressed.js
--- trunk/jx/lib/jx_compressed.js (rev 0)
+++ trunk/jx/lib/jx_compressed.js 2008-03-10 13:29:17 UTC (rev 1224)
@@ -0,0 +1,638 @@
+var Prototype={Version:'1.5.0',BrowserFeatures:{XPath:!!document.evaluate},ScriptFragment:'(?:<script.*?>)((\n|\r|.)*?)(?:<\/script>)',emptyFunction:function(){},K:function(x){return x}}
+var Class={create:function(){return function(){this.initialize.apply(this,arguments);}}}
+var Abstract=new Object();Object.extend=function(destination,source){for(var property in source){destination[property]=source[property];}
+return destination;}
+Object.extend(Object,{inspect:function(object){try{if(object===undefined)return'undefined';if(object===null)return'null';return object.inspect?object.inspect():object.toString();}catch(e){if(e instanceof RangeError)return'...';throw e;}},keys:function(object){var keys=[];for(var property in object)
+keys.push(property);return keys;},values:function(object){var values=[];for(var property in object)
+values.push(object[property]);return values;},clone:function(object){return Object.extend({},object);}});Function.prototype.bind=function(){var __method=this,args=$A(arguments),object=args.shift();return function(){return __method.apply(object,args.concat($A(arguments)));}}
+Function.prototype.bindAsEventListener=function(object){var __method=this,args=$A(arguments),object=args.shift();return function(event){return __method.apply(object,[(event||window.event)].concat(args).concat($A(arguments)));}}
+Object.extend(Number.prototype,{toColorPart:function(){var digits=this.toString(16);if(this<16)return'0'+digits;return digits;},succ:function(){return this+1;},times:function(iterator){$R(0,this,true).each(iterator);return this;}});var Try={these:function(){var returnValue;for(var i=0,length=arguments.length;i<length;i++){var lambda=arguments[i];try{returnValue=lambda();break;}catch(e){}}
+return returnValue;}}
+var PeriodicalExecuter=Class.create();PeriodicalExecuter.prototype={initialize:function(callback,frequency){this.callback=callback;this.frequency=frequency;this.currentlyExecuting=false;this.registerCallback();},registerCallback:function(){this.timer=setInterval(this.onTimerEvent.bind(this),this.frequency*1000);},stop:function(){if(!this.timer)return;clearInterval(this.timer);this.timer=null;},onTimerEvent:function(){if(!this.currentlyExecuting){try{this.currentlyExecuting=true;this.callback(this);}finally{this.currentlyExecuting=false;}}}}
+String.interpret=function(value){return value==null?'':String(value);}
+Object.extend(String.prototype,{gsub:function(pattern,replacement){var result='',source=this,match;replacement=arguments.callee.prepareReplacement(replacement);while(source.length>0){if(match=source.match(pattern)){result+=source.slice(0,match.index);result+=String.interpret(replacement(match));source=source.slice(match.index+match[0].length);}else{result+=source,source='';}}
+return result;},sub:function(pattern,replacement,count){replacement=this.gsub.prepareReplacement(replacement);count=count===undefined?1:count;return this.gsub(pattern,function(match){if(--count<0)return match[0];return replacement(match);});},scan:function(pattern,iterator){this.gsub(pattern,iterator);return this;},truncate:function(length,truncation){length=length||30;truncation=truncation===undefined?'...':truncation;return this.length>length?this.slice(0,length-truncation.length)+truncation:this;},strip:function(){return this.replace(/^\s+/,'').replace(/\s+$/,'');},stripTags:function(){return this.replace(/<\/?[^>]+>/gi,'');},stripScripts:function(){return this.replace(new RegExp(Prototype.ScriptFragment,'img'),'');},extractScripts:function(){var matchAll=new RegExp(Prototype.ScriptFragment,'img');var matchOne=new RegExp(Prototype.ScriptFragment,'im');return(this.match(matchAll)||[]).map(function(scriptTag){return(scriptTag.match(matchOne)||['',''])[1];});},evalScripts:function(){return this.extractScripts().map(function(script){return eval(script)});},escapeHTML:function(){var div=document.createElement('div');var text=document.createTextNode(this);div.appendChild(text);return div.innerHTML;},unescapeHTML:function(){var div=document.createElement('div');div.innerHTML=this.stripTags();return div.childNodes[0]?(div.childNodes.length>1?$A(div.childNodes).inject('',function(memo,node){return memo+node.nodeValue}):div.childNodes[0].nodeValue):'';},toQueryParams:function(separator){var match=this.strip().match(/([^?#]*)(#.*)?$/);if(!match)return{};return match[1].split(separator||'&').inject({},function(hash,pair){if((pair=pair.split('='))[0]){var name=decodeURIComponent(pair[0]);var value=pair[1]?decodeURIComponent(pair[1]):undefined;if(hash[name]!==undefined){if(hash[name].constructor!=Array)
+hash[name]=[hash[name]];if(value)hash[name].push(value);}
+else hash[name]=value;}
+return hash;});},toArray:function(){return this.split('');},succ:function(){return this.slice(0,this.length-1)+
+String.fromCharCode(this.charCodeAt(this.length-1)+1);},camelize:function(){var parts=this.split('-'),len=parts.length;if(len==1)return parts[0];var camelized=this.charAt(0)=='-'?parts[0].charAt(0).toUpperCase()+parts[0].substring(1):parts[0];for(var i=1;i<len;i++)
+camelized+=parts[i].charAt(0).toUpperCase()+parts[i].substring(1);return camelized;},capitalize:function(){return this.charAt(0).toUpperCase()+this.substring(1).toLowerCase();},underscore:function(){return this.gsub(/::/,'/').gsub(/([A-Z]+)([A-Z][a-z])/,'#{1}_#{2}').gsub(/([a-z\d])([A-Z])/,'#{1}_#{2}').gsub(/-/,'_').toLowerCase();},dasherize:function(){return this.gsub(/_/,'-');},inspect:function(useDoubleQuotes){var escapedString=this.replace(/\\/g,'\\\\');if(useDoubleQuotes)
+return'"'+escapedString.replace(/"/g,'\\"')+'"';else
+return"'"+escapedString.replace(/'/g,'\\\'')+"'";}});String.prototype.gsub.prepareReplacement=function(replacement){if(typeof replacement=='function')return replacement;var template=new Template(replacement);return function(match){return template.evaluate(match)};}
+String.prototype.parseQuery=String.prototype.toQueryParams;var Template=Class.create();Template.Pattern=/(^|.|\r|\n)(#\{(.*?)\})/;Template.prototype={initialize:function(template,pattern){this.template=template.toString();this.pattern=pattern||Template.Pattern;},evaluate:function(object){return this.template.gsub(this.pattern,function(match){var before=match[1];if(before=='\\')return match[2];return before+String.interpret(object[match[3]]);});}}
+var $break=new Object();var $continue=new Object();var Enumerable={each:function(iterator){var index=0;try{this._each(function(value){try{iterator(value,index++);}catch(e){if(e!=$continue)throw e;}});}catch(e){if(e!=$break)throw e;}
+return this;},eachSlice:function(number,iterator){var index=-number,slices=[],array=this.toArray();while((index+=number)<array.length)
+slices.push(array.slice(index,index+number));return slices.map(iterator);},all:function(iterator){var result=true;this.each(function(value,index){result=result&&!!(iterator||Prototype.K)(value,index);if(!result)throw $break;});return result;},any:function(iterator){var result=false;this.each(function(value,index){if(result=!!(iterator||Prototype.K)(value,index))
+throw $break;});return result;},collect:function(iterator){var results=[];this.each(function(value,index){results.push((iterator||Prototype.K)(value,index));});return results;},detect:function(iterator){var result;this.each(function(value,index){if(iterator(value,index)){result=value;throw $break;}});return result;},findAll:function(iterator){var results=[];this.each(function(value,index){if(iterator(value,index))
+results.push(value);});return results;},grep:function(pattern,iterator){var results=[];this.each(function(value,index){var stringValue=value.toString();if(stringValue.match(pattern))
+results.push((iterator||Prototype.K)(value,index));})
+return results;},include:function(object){var found=false;this.each(function(value){if(value==object){found=true;throw $break;}});return found;},inGroupsOf:function(number,fillWith){fillWith=fillWith===undefined?null:fillWith;return this.eachSlice(number,function(slice){while(slice.length<number)slice.push(fillWith);return slice;});},inject:function(memo,iterator){this.each(function(value,index){memo=iterator(memo,value,index);});return memo;},invoke:function(method){var args=$A(arguments).slice(1);return this.map(function(value){return value[method].apply(value,args);});},max:function(iterator){var result;this.each(function(value,index){value=(iterator||Prototype.K)(value,index);if(result==undefined||value>=result)
+result=value;});return result;},min:function(iterator){var result;this.each(function(value,index){value=(iterator||Prototype.K)(value,index);if(result==undefined||value<result)
+result=value;});return result;},partition:function(iterator){var trues=[],falses=[];this.each(function(value,index){((iterator||Prototype.K)(value,index)?trues:falses).push(value);});return[trues,falses];},pluck:function(property){var results=[];this.each(function(value,index){results.push(value[property]);});return results;},reject:function(iterator){var results=[];this.each(function(value,index){if(!iterator(value,index))
+results.push(value);});return results;},sortBy:function(iterator){return this.map(function(value,index){return{value:value,criteria:iterator(value,index)};}).sort(function(left,right){var a=left.criteria,b=right.criteria;return a<b?-1:a>b?1:0;}).pluck('value');},toArray:function(){return this.map();},zip:function(){var iterator=Prototype.K,args=$A(arguments);if(typeof args.last()=='function')
+iterator=args.pop();var collections=[this].concat(args).map($A);return this.map(function(value,index){return iterator(collections.pluck(index));});},size:function(){return this.toArray().length;},inspect:function(){return'#<Enumerable:'+this.toArray().inspect()+'>';}}
+Object.extend(Enumerable,{map:Enumerable.collect,find:Enumerable.detect,select:Enumerable.findAll,member:Enumerable.include,entries:Enumerable.toArray});var $A=Array.from=function(iterable){if(!iterable)return[];if(iterable.toArray){return iterable.toArray();}else{var results=[];for(var i=0,length=iterable.length;i<length;i++)
+results.push(iterable[i]);return results;}}
+Object.extend(Array.prototype,Enumerable);if(!Array.prototype._reverse)
+Array.prototype._reverse=Array.prototype.reverse;Object.extend(Array.prototype,{_each:function(iterator){for(var i=0,length=this.length;i<length;i++)
+iterator(this[i]);},clear:function(){this.length=0;return this;},first:function(){return this[0];},last:function(){return this[this.length-1];},compact:function(){return this.select(function(value){return value!=null;});},flatten:function(){return this.inject([],function(array,value){return array.concat(value&&value.constructor==Array?value.flatten():[value]);});},without:function(){var values=$A(arguments);return this.select(function(value){return!values.include(value);});},indexOf:function(object){for(var i=0,length=this.length;i<length;i++)
+if(this[i]==object)return i;return-1;},reverse:function(inline){return(inline!==false?this:this.toArray())._reverse();},reduce:function(){return this.length>1?this:this[0];},uniq:function(){return this.inject([],function(array,value){return array.include(value)?array:array.concat([value]);});},clone:function(){return[].concat(this);},size:function(){return this.length;},inspect:function(){return'['+this.map(Object.inspect).join(', ')+']';}});Array.prototype.toArray=Array.prototype.clone;function $w(string){string=string.strip();return string?string.split(/\s+/):[];}
+if(window.opera){Array.prototype.concat=function(){var array=[];for(var i=0,length=this.length;i<length;i++)array.push(this[i]);for(var i=0,length=arguments.length;i<length;i++){if(arguments[i].constructor==Array){for(var j=0,arrayLength=arguments[i].length;j<arrayLength;j++)
+array.push(arguments[i][j]);}else{array.push(arguments[i]);}}
+return array;}}
+var Hash=function(obj){Object.extend(this,obj||{});};Object.extend(Hash,{toQueryString:function(obj){var parts=[];this.prototype._each.call(obj,function(pair){if(!pair.key)return;if(pair.value&&pair.value.constructor==Array){var values=pair.value.compact();if(values.length<2)pair.value=values.reduce();else{key=encodeURIComponent(pair.key);values.each(function(value){value=value!=undefined?encodeURIComponent(value):'';parts.push(key+'='+encodeURIComponent(value));});return;}}
+if(pair.value==undefined)pair[1]='';parts.push(pair.map(encodeURIComponent).join('='));});return parts.join('&');}});Object.extend(Hash.prototype,Enumerable);Object.extend(Hash.prototype,{_each:function(iterator){for(var key in this){var value=this[key];if(value&&value==Hash.prototype[key])continue;var pair=[key,value];pair.key=key;pair.value=value;iterator(pair);}},keys:function(){return this.pluck('key');},values:function(){return this.pluck('value');},merge:function(hash){return $H(hash).inject(this,function(mergedHash,pair){mergedHash[pair.key]=pair.value;return mergedHash;});},remove:function(){var result;for(var i=0,length=arguments.length;i<length;i++){var value=this[arguments[i]];if(value!==undefined){if(result===undefined)result=value;else{if(result.constructor!=Array)result=[result];result.push(value)}}
+delete this[arguments[i]];}
+return result;},toQueryString:function(){return Hash.toQueryString(this);},inspect:function(){return'#<Hash:{'+this.map(function(pair){return pair.map(Object.inspect).join(': ');}).join(', ')+'}>';}});function $H(object){if(object&&object.constructor==Hash)return object;return new Hash(object);};ObjectRange=Class.create();Object.extend(ObjectRange.prototype,Enumerable);Object.extend(ObjectRange.prototype,{initialize:function(start,end,exclusive){this.start=start;this.end=end;this.exclusive=exclusive;},_each:function(iterator){var value=this.start;while(this.include(value)){iterator(value);value=value.succ();}},include:function(value){if(value<this.start)
+return false;if(this.exclusive)
+return value<this.end;return value<=this.end;}});var $R=function(start,end,exclusive){return new ObjectRange(start,end,exclusive);}
+var Ajax={getTransport:function(){return Try.these(function(){return new XMLHttpRequest()},function(){return new ActiveXObject('Msxml2.XMLHTTP')},function(){return new ActiveXObject('Microsoft.XMLHTTP')})||false;},activeRequestCount:0}
+Ajax.Responders={responders:[],_each:function(iterator){this.responders._each(iterator);},register:function(responder){if(!this.include(responder))
+this.responders.push(responder);},unregister:function(responder){this.responders=this.responders.without(responder);},dispatch:function(callback,request,transport,json){this.each(function(responder){if(typeof responder[callback]=='function'){try{responder[callback].apply(responder,[request,transport,json]);}catch(e){}}});}};Object.extend(Ajax.Responders,Enumerable);Ajax.Responders.register({onCreate:function(){Ajax.activeRequestCount++;},onComplete:function(){Ajax.activeRequestCount--;}});Ajax.Base=function(){};Ajax.Base.prototype={setOptions:function(options){this.options={method:'post',asynchronous:true,contentType:'application/x-www-form-urlencoded',encoding:'UTF-8',parameters:''}
+Object.extend(this.options,options||{});this.options.method=this.options.method.toLowerCase();if(typeof this.options.parameters=='string')
+this.options.parameters=this.options.parameters.toQueryParams();}}
+Ajax.Request=Class.create();Ajax.Request.Events=['Uninitialized','Loading','Loaded','Interactive','Complete'];Ajax.Request.prototype=Object.extend(new Ajax.Base(),{_complete:false,initialize:function(url,options){this.transport=Ajax.getTransport();this.setOptions(options);this.request(url);},request:function(url){this.url=url;this.method=this.options.method;var params=this.options.parameters;if(!['get','post'].include(this.method)){params['_method']=this.method;this.method='post';}
+params=Hash.toQueryString(params);if(params&&/Konqueror|Safari|KHTML/.test(navigator.userAgent))params+='&_='
+if(this.method=='get'&¶ms)
+this.url+=(this.url.indexOf('?')>-1?'&':'?')+params;try{Ajax.Responders.dispatch('onCreate',this,this.transport);this.transport.open(this.method.toUpperCase(),this.url,this.options.asynchronous);if(this.options.asynchronous)
+setTimeout(function(){this.respondToReadyState(1)}.bind(this),10);this.transport.onreadystatechange=this.onStateChange.bind(this);this.setRequestHeaders();var body=this.method=='post'?(this.options.postBody||params):null;this.transport.send(body);if(!this.options.asynchronous&&this.transport.overrideMimeType)
+this.onStateChange();}
+catch(e){this.dispatchException(e);}},onStateChange:function(){var readyState=this.transport.readyState;if(readyState>1&&!((readyState==4)&&this._complete))
+this.respondToReadyState(this.transport.readyState);},setRequestHeaders:function(){var headers={'X-Requested-With':'XMLHttpRequest','X-Prototype-Version':Prototype.Version,'Accept':'text/javascript, text/html, application/xml, text/xml, */*'};if(this.method=='post'){headers['Content-type']=this.options.contentType+
+(this.options.encoding?'; charset='+this.options.encoding:'');if(this.transport.overrideMimeType&&(navigator.userAgent.match(/Gecko\/(\d{4})/)||[0,2005])[1]<2005)
+headers['Connection']='close';}
+if(typeof this.options.requestHeaders=='object'){var extras=this.options.requestHeaders;if(typeof extras.push=='function')
+for(var i=0,length=extras.length;i<length;i+=2)
+headers[extras[i]]=extras[i+1];else
+$H(extras).each(function(pair){headers[pair.key]=pair.value});}
+for(var name in headers)
+this.transport.setRequestHeader(name,headers[name]);},success:function(){return!this.transport.status||(this.transport.status>=200&&this.transport.status<300);},respondToReadyState:function(readyState){var state=Ajax.Request.Events[readyState];var transport=this.transport,json=this.evalJSON();if(state=='Complete'){try{this._complete=true;(this.options['on'+this.transport.status]||this.options['on'+(this.success()?'Success':'Failure')]||Prototype.emptyFunction)(transport,json);}catch(e){this.dispatchException(e);}
+if((this.getHeader('Content-type')||'text/javascript').strip().match(/^(text|application)\/(x-)?(java|ecma)script(;.*)?$/i))
+this.evalResponse();}
+try{(this.options['on'+state]||Prototype.emptyFunction)(transport,json);Ajax.Responders.dispatch('on'+state,this,transport,json);}catch(e){this.dispatchException(e);}
+if(state=='Complete'){this.transport.onreadystatechange=Prototype.emptyFunction;}},getHeader:function(name){try{return this.transport.getResponseHeader(name);}catch(e){return null}},evalJSON:function(){try{var json=this.getHeader('X-JSON');return json?eval('('+json+')'):null;}catch(e){return null}},evalResponse:function(){try{return eval(this.transport.responseText);}catch(e){this.dispatchException(e);}},dispatchException:function(exception){(this.options.onException||Prototype.emptyFunction)(this,exception);Ajax.Responders.dispatch('onException',this,exception);}});Ajax.Updater=Class.create();Object.extend(Object.extend(Ajax.Updater.prototype,Ajax.Request.prototype),{initialize:function(container,url,options){this.container={success:(container.success||container),failure:(container.failure||(container.success?null:container))}
+this.transport=Ajax.getTransport();this.setOptions(options);var onComplete=this.options.onComplete||Prototype.emptyFunction;this.options.onComplete=(function(transport,param){this.updateContent();onComplete(transport,param);}).bind(this);this.request(url);},updateContent:function(){var receiver=this.container[this.success()?'success':'failure'];var response=this.transport.responseText;if(!this.options.evalScripts)response=response.stripScripts();if(receiver=$(receiver)){if(this.options.insertion)
+new this.options.insertion(receiver,response);else
+receiver.update(response);}
+if(this.success()){if(this.onComplete)
+setTimeout(this.onComplete.bind(this),10);}}});Ajax.PeriodicalUpdater=Class.create();Ajax.PeriodicalUpdater.prototype=Object.extend(new Ajax.Base(),{initialize:function(container,url,options){this.setOptions(options);this.onComplete=this.options.onComplete;this.frequency=(this.options.frequency||2);this.decay=(this.options.decay||1);this.updater={};this.container=container;this.url=url;this.start();},start:function(){this.options.onComplete=this.updateComplete.bind(this);this.onTimerEvent();},stop:function(){this.updater.options.onComplete=undefined;clearTimeout(this.timer);(this.onComplete||Prototype.emptyFunction).apply(this,arguments);},updateComplete:function(request){if(this.options.decay){this.decay=(request.responseText==this.lastText?this.decay*this.options.decay:1);this.lastText=request.responseText;}
+this.timer=setTimeout(this.onTimerEvent.bind(this),this.decay*this.frequency*1000);},onTimerEvent:function(){this.updater=new Ajax.Updater(this.container,this.url,this.options);}});function $(element){if(arguments.length>1){for(var i=0,elements=[],length=arguments.length;i<length;i++)
+elements.push($(arguments[i]));return elements;}
+if(typeof element=='string')
+element=document.getElementById(element);return Element.extend(element);}
+if(Prototype.BrowserFeatures.XPath){document._getElementsByXPath=function(expression,parentElement){var results=[];var query=document.evaluate(expression,$(parentElement)||document,null,XPathResult.ORDERED_NODE_SNAPSHOT_TYPE,null);for(var i=0,length=query.snapshotLength;i<length;i++)
+results.push(query.snapshotItem(i));return results;};}
+document.getElementsByClassName=function(className,parentElement){if(Prototype.BrowserFeatures.XPath){var q=".//*[contains(concat(' ', @class, ' '), ' "+className+" ')]";return document._getElementsByXPath(q,parentElement);}else{var children=($(parentElement)||document.body).getElementsByTagName('*');var elements=[],child;for(var i=0,length=children.length;i<length;i++){child=children[i];if(Element.hasClassName(child,className))
+elements.push(Element.extend(child));}
+return elements;}};if(!window.Element)
+var Element=new Object();Element.extend=function(element){if(!element||_nativeExtensions||element.nodeType==3)return element;if(!element._extended&&element.tagName&&element!=window){var methods=Object.clone(Element.Methods),cache=Element.extend.cache;if(element.tagName=='FORM')
+Object.extend(methods,Form.Methods);if(['INPUT','TEXTAREA','SELECT'].include(element.tagName))
+Object.extend(methods,Form.Element.Methods);Object.extend(methods,Element.Methods.Simulated);for(var property in methods){var value=methods[property];if(typeof value=='function'&&!(property in element))
+element[property]=cache.findOrStore(value);}}
+element._extended=true;return element;};Element.extend.cache={findOrStore:function(value){return this[value]=this[value]||function(){return value.apply(null,[this].concat($A(arguments)));}}};Element.Methods={visible:function(element){return $(element).style.display!='none';},toggle:function(element){element=$(element);Element[Element.visible(element)?'hide':'show'](element);return element;},hide:function(element){$(element).style.display='none';return element;},show:function(element){$(element).style.display='';return element;},remove:function(element){element=$(element);element.parentNode.removeChild(element);return element;},update:function(element,html){html=typeof html=='undefined'?'':html.toString();$(element).innerHTML=html.stripScripts();setTimeout(function(){html.evalScripts()},10);return element;},replace:function(element,html){element=$(element);html=typeof html=='undefined'?'':html.toString();if(element.outerHTML){element.outerHTML=html.stripScripts();}else{var range=element.ownerDocument.createRange();range.selectNodeContents(element);element.parentNode.replaceChild(range.createContextualFragment(html.stripScripts()),element);}
+setTimeout(function(){html.evalScripts()},10);return element;},inspect:function(element){element=$(element);var result='<'+element.tagName.toLowerCase();$H({'id':'id','className':'class'}).each(function(pair){var property=pair.first(),attribute=pair.last();var value=(element[property]||'').toString();if(value)result+=' '+attribute+'='+value.inspect(true);});return result+'>';},recursivelyCollect:function(element,property){element=$(element);var elements=[];while(element=element[property])
+if(element.nodeType==1)
+elements.push(Element.extend(element));return elements;},ancestors:function(element){return $(element).recursivelyCollect('parentNode');},descendants:function(element){return $A($(element).getElementsByTagName('*'));},immediateDescendants:function(element){if(!(element=$(element).firstChild))return[];while(element&&element.nodeType!=1)element=element.nextSibling;if(element)return[element].concat($(element).nextSiblings());return[];},previousSiblings:function(element){return $(element).recursivelyCollect('previousSibling');},nextSiblings:function(element){return $(element).recursivelyCollect('nextSibling');},siblings:function(element){element=$(element);return element.previousSiblings().reverse().concat(element.nextSiblings());},match:function(element,selector){if(typeof selector=='string')
+selector=new Selector(selector);return selector.match($(element));},up:function(element,expression,index){return Selector.findElement($(element).ancestors(),expression,index);},down:function(element,expression,index){return Selector.findElement($(element).descendants(),expression,index);},previous:function(element,expression,index){return Selector.findElement($(element).previousSiblings(),expression,index);},next:function(element,expression,index){return Selector.findElement($(element).nextSiblings(),expression,index);},getElementsBySelector:function(){var args=$A(arguments),element=$(args.shift());return Selector.findChildElements(element,args);},getElementsByClassName:function(element,className){return document.getElementsByClassName(className,element);},readAttribute:function(element,name){element=$(element);if(document.all&&!window.opera){var t=Element._attributeTranslations;if(t.values[name])return t.values[name](element,name);if(t.names[name])name=t.names[name];var attribute=element.attributes[name];if(attribute)return attribute.nodeValue;}
+return element.getAttribute(name);},getHeight:function(element){return $(element).getDimensions().height;},getWidth:function(element){return $(element).getDimensions().width;},classNames:function(element){return new Element.ClassNames(element);},hasClassName:function(element,className){if(!(element=$(element)))return;var elementClassName=element.className;if(elementClassName.length==0)return false;if(elementClassName==className||elementClassName.match(new RegExp("(^|\\s)"+className+"(\\s|$)")))
+return true;return false;},addClassName:function(element,className){if(!(element=$(element)))return;Element.classNames(element).add(className);return element;},removeClassName:function(element,className){if(!(element=$(element)))return;Element.classNames(element).remove(className);return element;},toggleClassName:function(element,className){if(!(element=$(element)))return;Element.classNames(element)[element.hasClassName(className)?'remove':'add'](className);return element;},observe:function(){Event.observe.apply(Event,arguments);return $A(arguments).first();},stopObserving:function(){Event.stopObserving.apply(Event,arguments);return $A(arguments).first();},cleanWhitespace:function(element){element=$(element);var node=element.firstChild;while(node){var nextNode=node.nextSibling;if(node.nodeType==3&&!/\S/.test(node.nodeValue))
+element.removeChild(node);node=nextNode;}
+return element;},empty:function(element){return $(element).innerHTML.match(/^\s*$/);},descendantOf:function(element,ancestor){element=$(element),ancestor=$(ancestor);while(element=element.parentNode)
+if(element==ancestor)return true;return false;},scrollTo:function(element){element=$(element);var pos=Position.cumulativeOffset(element);window.scrollTo(pos[0],pos[1]);return element;},getStyle:function(element,style){element=$(element);if(['float','cssFloat'].include(style))
+style=(typeof element.style.styleFloat!='undefined'?'styleFloat':'cssFloat');style=style.camelize();var value=element.style[style];if(!value){if(document.defaultView&&document.defaultView.getComputedStyle){var css=document.defaultView.getComputedStyle(element,null);value=css?css[style]:null;}else if(element.currentStyle){value=element.currentStyle[style];}}
+if((value=='auto')&&['width','height'].include(style)&&(element.getStyle('display')!='none'))
+value=element['offset'+style.capitalize()]+'px';if(window.opera&&['left','top','right','bottom'].include(style))
+if(Element.getStyle(element,'position')=='static')value='auto';if(style=='opacity'){if(value)return parseFloat(value);if(value=(element.getStyle('filter')||'').match(/alpha\(opacity=(.*)\)/))
+if(value[1])return parseFloat(value[1])/100;return 1.0;}
+return value=='auto'?null:value;},setStyle:function(element,style){element=$(element);for(var name in style){var value=style[name];if(name=='opacity'){if(value==1){value=(/Gecko/.test(navigator.userAgent)&&!/Konqueror|Safari|KHTML/.test(navigator.userAgent))?0.999999:1.0;if(/MSIE/.test(navigator.userAgent)&&!window.opera)
+element.style.filter=element.getStyle('filter').replace(/alpha\([^\)]*\)/gi,'');}else if(value===''){if(/MSIE/.test(navigator.userAgent)&&!window.opera)
+element.style.filter=element.getStyle('filter').replace(/alpha\([^\)]*\)/gi,'');}else{if(value<0.00001)value=0;if(/MSIE/.test(navigator.userAgent)&&!window.opera)
+element.style.filter=element.getStyle('filter').replace(/alpha\([^\)]*\)/gi,'')+'alpha(opacity='+value*100+')';}}else if(['float','cssFloat'].include(name))name=(typeof element.style.styleFloat!='undefined')?'styleFloat':'cssFloat';element.style[name.camelize()]=value;}
+return element;},getDimensions:function(element){element=$(element);var display=$(element).getStyle('display');if(display!='none'&&display!=null)
+return{width:element.offsetWidth,height:element.offsetHeight};var els=element.style;var originalVisibility=els.visibility;var originalPosition=els.position;var originalDisplay=els.display;els.visibility='hidden';els.position='absolute';els.display='block';var originalWidth=element.clientWidth;var originalHeight=element.clientHeight;els.display=originalDisplay;els.position=originalPosition;els.visibility=originalVisibility;return{width:originalWidth,height:originalHeight};},makePositioned:function(element){element=$(element);var pos=Element.getStyle(element,'position');if(pos=='static'||!pos){element._madePositioned=true;element.style.position='relative';if(window.opera){element.style.top=0;element.style.left=0;}}
+return element;},undoPositioned:function(element){element=$(element);if(element._madePositioned){element._madePositioned=undefined;element.style.position=element.style.top=element.style.left=element.style.bottom=element.style.right='';}
+return element;},makeClipping:function(element){element=$(element);if(element._overflow)return element;element._overflow=element.style.overflow||'auto';if((Element.getStyle(element,'overflow')||'visible')!='hidden')
+element.style.overflow='hidden';return element;},undoClipping:function(element){element=$(element);if(!element._overflow)return element;element.style.overflow=element._overflow=='auto'?'':element._overflow;element._overflow=null;return element;}};Object.extend(Element.Methods,{childOf:Element.Methods.descendantOf});Element._attributeTranslations={};Element._attributeTranslations.names={colspan:"colSpan",rowspan:"rowSpan",valign:"vAlign",datetime:"dateTime",accesskey:"accessKey",tabindex:"tabIndex",enctype:"encType",maxlength:"maxLength",readonly:"readOnly",longdesc:"longDesc"};Element._attributeTranslations.values={_getAttr:function(element,attribute){return element.getAttribute(attribute,2);},_flag:function(element,attribute){return $(element).hasAttribute(attribute)?attribute:null;},style:function(element){return element.style.cssText.toLowerCase();},title:function(element){var node=element.getAttributeNode('title');return node.specified?node.nodeValue:null;}};Object.extend(Element._attributeTranslations.values,{href:Element._attributeTranslations.values._getAttr,src:Element._attributeTranslations.values._getAttr,disabled:Element._attributeTranslations.values._flag,checked:Element._attributeTranslations.values._flag,readonly:Element._attributeTranslations.values._flag,multiple:Element._attributeTranslations.values._flag});Element.Methods.Simulated={hasAttribute:function(element,attribute){var t=Element._attributeTranslations;attribute=t.names[attribute]||attribute;return $(element).getAttributeNode(attribute).specified;}};if(document.all&&!window.opera){Element.Methods.update=function(element,html){element=$(element);html=typeof html=='undefined'?'':html.toString();var tagName=element.tagName.toUpperCase();if(['THEAD','TBODY','TR','TD'].include(tagName)){var div=document.createElement('div');switch(tagName){case'THEAD':case'TBODY':div.innerHTML='<table><tbody>'+html.stripScripts()+'</tbody></table>';depth=2;break;case'TR':div.innerHTML='<table><tbody><tr>'+html.stripScripts()+'</tr></tbody></table>';depth=3;break;case'TD':div.innerHTML='<table><tbody><tr><td>'+html.stripScripts()+'</td></tr></tbody></table>';depth=4;}
+$A(element.childNodes).each(function(node){element.removeChild(node)});depth.times(function(){div=div.firstChild});$A(div.childNodes).each(function(node){element.appendChild(node)});}else{element.innerHTML=html.stripScripts();}
+setTimeout(function(){html.evalScripts()},10);return element;}};Object.extend(Element,Element.Methods);var _nativeExtensions=false;if(/Konqueror|Safari|KHTML/.test(navigator.userAgent))
+['','Form','Input','TextArea','Select'].each(function(tag){var className='HTML'+tag+'Element';if(window[className])return;var klass=window[className]={};klass.prototype=document.createElement(tag?tag.toLowerCase():'div').__proto__;});Element.addMethods=function(methods){Object.extend(Element.Methods,methods||{});function copy(methods,destination,onlyIfAbsent){onlyIfAbsent=onlyIfAbsent||false;var cache=Element.extend.cache;for(var property in methods){var value=methods[property];if(!onlyIfAbsent||!(property in destination))
+destination[property]=cache.findOrStore(value);}}
+if(typeof HTMLElement!='undefined'){copy(Element.Methods,HTMLElement.prototype);copy(Element.Methods.Simulated,HTMLElement.prototype,true);copy(Form.Methods,HTMLFormElement.prototype);[HTMLInputElement,HTMLTextAreaElement,HTMLSelectElement].each(function(klass){copy(Form.Element.Methods,klass.prototype);});_nativeExtensions=true;}}
+var Toggle=new Object();Toggle.display=Element.toggle;Abstract.Insertion=function(adjacency){this.adjacency=adjacency;}
+Abstract.Insertion.prototype={initialize:function(element,content){this.element=$(element);this.content=content.stripScripts();if(this.adjacency&&this.element.insertAdjacentHTML){try{this.element.insertAdjacentHTML(this.adjacency,this.content);}catch(e){var tagName=this.element.tagName.toUpperCase();if(['TBODY','TR'].include(tagName)){this.insertContent(this.contentFromAnonymousTable());}else{throw e;}}}else{this.range=this.element.ownerDocument.createRange();if(this.initializeRange)this.initializeRange();this.insertContent([this.range.createContextualFragment(this.content)]);}
+setTimeout(function(){content.evalScripts()},10);},contentFromAnonymousTable:function(){var div=document.createElement('div');div.innerHTML='<table><tbody>'+this.content+'</tbody></table>';return $A(div.childNodes[0].childNodes[0].childNodes);}}
+var Insertion=new Object();Insertion.Before=Class.create();Insertion.Before.prototype=Object.extend(new Abstract.Insertion('beforeBegin'),{initializeRange:function(){this.range.setStartBefore(this.element);},insertContent:function(fragments){fragments.each((function(fragment){this.element.parentNode.insertBefore(fragment,this.element);}).bind(this));}});Insertion.Top=Class.create();Insertion.Top.prototype=Object.extend(new Abstract.Insertion('afterBegin'),{initializeRange:function(){this.range.selectNodeContents(this.element);this.range.collapse(true);},insertContent:function(fragments){fragments.reverse(false).each((function(fragment){this.element.insertBefore(fragment,this.element.firstChild);}).bind(this));}});Insertion.Bottom=Class.create();Insertion.Bottom.prototype=Object.extend(new Abstract.Insertion('beforeEnd'),{initializeRange:function(){this.range.selectNodeContents(this.element);this.range.collapse(this.element);},insertContent:function(fragments){fragments.each((function(fragment){this.element.appendChild(fragment);}).bind(this));}});Insertion.After=Class.create();Insertion.After.prototype=Object.extend(new Abstract.Insertion('afterEnd'),{initializeRange:function(){this.range.setStartAfter(this.element);},insertContent:function(fragments){fragments.each((function(fragment){this.element.parentNode.insertBefore(fragment,this.element.nextSibling);}).bind(this));}});Element.ClassNames=Class.create();Element.ClassNames.prototype={initialize:function(element){this.element=$(element);},_each:function(iterator){this.element.className.split(/\s+/).select(function(name){return name.length>0;})._each(iterator);},set:function(className){this.element.className=className;},add:function(classNameToAdd){if(this.include(classNameToAdd))return;this.set($A(this).concat(classNameToAdd).join(' '));},remove:function(classNameToRemove){if(!this.include(classNameToRemove))return;this.set($A(this).without(classNameToRemove).join(' '));},toString:function(){return $A(this).join(' ');}};Object.extend(Element.ClassNames.prototype,Enumerable);var Selector=Class.create();Selector.prototype={initialize:function(expression){this.params={classNames:[]};this.expression=expression.toString().strip();this.parseExpression();this.compileMatcher();},parseExpression:function(){function abort(message){throw'Parse error in selector: '+message;}
+if(this.expression=='')abort('empty expression');var params=this.params,expr=this.expression,match,modifier,clause,rest;while(match=expr.match(/^(.*)\[([a-z0-9_:-]+?)(?:([~\|!]?=)(?:"([^"]*)"|([^\]\s]*)))?\]$/i)){params.attributes=params.attributes||[];params.attributes.push({name:match[2],operator:match[3],value:match[4]||match[5]||''});expr=match[1];}
+if(expr=='*')return this.params.wildcard=true;while(match=expr.match(/^([^a-z0-9_-])?([a-z0-9_-]+)(.*)/i)){modifier=match[1],clause=match[2],rest=match[3];switch(modifier){case'#':params.id=clause;break;case'.':params.classNames.push(clause);break;case'':case undefined:params.tagName=clause.toUpperCase();break;default:abort(expr.inspect());}
+expr=rest;}
+if(expr.length>0)abort(expr.inspect());},buildMatchExpression:function(){var params=this.params,conditions=[],clause;if(params.wildcard)
+conditions.push('true');if(clause=params.id)
+conditions.push('element.readAttribute("id") == '+clause.inspect());if(clause=params.tagName)
+conditions.push('element.tagName.toUpperCase() == '+clause.inspect());if((clause=params.classNames).length>0)
+for(var i=0,length=clause.length;i<length;i++)
+conditions.push('element.hasClassName('+clause[i].inspect()+')');if(clause=params.attributes){clause.each(function(attribute){var value='element.readAttribute('+attribute.name.inspect()+')';var splitValueBy=function(delimiter){return value+' && '+value+'.split('+delimiter.inspect()+')';}
+switch(attribute.operator){case'=':conditions.push(value+' == '+attribute.value.inspect());break;case'~=':conditions.push(splitValueBy(' ')+'.include('+attribute.value.inspect()+')');break;case'|=':conditions.push(splitValueBy('-')+'.first().toUpperCase() == '+attribute.value.toUpperCase().inspect());break;case'!=':conditions.push(value+' != '+attribute.value.inspect());break;case'':case undefined:conditions.push('element.hasAttribute('+attribute.name.inspect()+')');break;default:throw'Unknown operator '+attribute.operator+' in selector';}});}
+return conditions.join(' && ');},compileMatcher:function(){this.match=new Function('element','if (!element.tagName) return false; element = $(element); return '+this.buildMatchExpression());},findElements:function(scope){var element;if(element=$(this.params.id))
+if(this.match(element))
+if(!scope||Element.childOf(element,scope))
+return[element];scope=(scope||document).getElementsByTagName(this.params.tagName||'*');var results=[];for(var i=0,length=scope.length;i<length;i++)
+if(this.match(element=scope[i]))
+results.push(Element.extend(element));return results;},toString:function(){return this.expression;}}
+Object.extend(Selector,{matchElements:function(elements,expression){var selector=new Selector(expression);return elements.select(selector.match.bind(selector)).map(Element.extend);},findElement:function(elements,expression,index){if(typeof expression=='number')index=expression,expression=false;return Selector.matchElements(elements,expression||'*')[index||0];},findChildElements:function(element,expressions){return expressions.map(function(expression){return expression.match(/[^\s"]+(?:"[^"]*"[^\s"]+)*/g).inject([null],function(results,expr){var selector=new Selector(expr);return results.inject([],function(elements,result){return elements.concat(selector.findElements(result||element));});});}).flatten();}});function $$(){return Selector.findChildElements(document,$A(arguments));}
+var Form={reset:function(form){$(form).reset();return form;},serializeElements:function(elements,getHash){var data=elements.inject({},function(result,element){if(!element.disabled&&element.name){var key=element.name,value=$(element).getValue();if(value!=undefined){if(result[key]){if(result[key].constructor!=Array)result[key]=[result[key]];result[key].push(value);}
+else result[key]=value;}}
+return result;});return getHash?data:Hash.toQueryString(data);}};Form.Methods={serialize:function(form,getHash){return Form.serializeElements(Form.getElements(form),getHash);},getElements:function(form){return $A($(form).getElementsByTagName('*')).inject([],function(elements,child){if(Form.Element.Serializers[child.tagName.toLowerCase()])
+elements.push(Element.extend(child));return elements;});},getInputs:function(form,typeName,name){form=$(form);var inputs=form.getElementsByTagName('input');if(!typeName&&!name)return $A(inputs).map(Element.extend);for(var i=0,matchingInputs=[],length=inputs.length;i<length;i++){var input=inputs[i];if((typeName&&input.type!=typeName)||(name&&input.name!=name))
+continue;matchingInputs.push(Element.extend(input));}
+return matchingInputs;},disable:function(form){form=$(form);form.getElements().each(function(element){element.blur();element.disabled='true';});return form;},enable:function(form){form=$(form);form.getElements().each(function(element){element.disabled='';});return form;},findFirstElement:function(form){return $(form).getElements().find(function(element){return element.type!='hidden'&&!element.disabled&&['input','select','textarea'].include(element.tagName.toLowerCase());});},focusFirstElement:function(form){form=$(form);form.findFirstElement().activate();return form;}}
+Object.extend(Form,Form.Methods);Form.Element={focus:function(element){$(element).focus();return element;},select:function(element){$(element).select();return element;}}
+Form.Element.Methods={serialize:function(element){element=$(element);if(!element.disabled&&element.name){var value=element.getValue();if(value!=undefined){var pair={};pair[element.name]=value;return Hash.toQueryString(pair);}}
+return'';},getValue:function(element){element=$(element);var method=element.tagName.toLowerCase();return Form.Element.Serializers[method](element);},clear:function(element){$(element).value='';return element;},present:function(element){return $(element).value!='';},activate:function(element){element=$(element);element.focus();if(element.select&&(element.tagName.toLowerCase()!='input'||!['button','reset','submit'].include(element.type)))
+element.select();return element;},disable:function(element){element=$(element);element.disabled=true;return element;},enable:function(element){element=$(element);element.blur();element.disabled=false;return element;}}
+Object.extend(Form.Element,Form.Element.Methods);var Field=Form.Element;var $F=Form.Element.getValue;Form.Element.Serializers={input:function(element){switch(element.type.toLowerCase()){case'checkbox':case'radio':return Form.Element.Serializers.inputSelector(element);default:return Form.Element.Serializers.textarea(element);}},inputSelector:function(element){return element.checked?element.value:null;},textarea:function(element){return element.value;},select:function(element){return this[element.type=='select-one'?'selectOne':'selectMany'](element);},selectOne:function(element){var index=element.selectedIndex;return index>=0?this.optionValue(element.options[index]):null;},selectMany:function(element){var values,length=element.length;if(!length)return null;for(var i=0,values=[];i<length;i++){var opt=element.options[i];if(opt.selected)values.push(this.optionValue(opt));}
+return values;},optionValue:function(opt){return Element.extend(opt).hasAttribute('value')?opt.value:opt.text;}}
+Abstract.TimedObserver=function(){}
+Abstract.TimedObserver.prototype={initialize:function(element,frequency,callback){this.frequency=frequency;this.element=$(element);this.callback=callback;this.lastValue=this.getValue();this.registerCallback();},registerCallback:function(){setInterval(this.onTimerEvent.bind(this),this.frequency*1000);},onTimerEvent:function(){var value=this.getValue();var changed=('string'==typeof this.lastValue&&'string'==typeof value?this.lastValue!=value:String(this.lastValue)!=String(value));if(changed){this.callback(this.element,value);this.lastValue=value;}}}
+Form.Element.Observer=Class.create();Form.Element.Observer.prototype=Object.extend(new Abstract.TimedObserver(),{getValue:function(){return Form.Element.getValue(this.element);}});Form.Observer=Class.create();Form.Observer.prototype=Object.extend(new Abstract.TimedObserver(),{getValue:function(){return Form.serialize(this.element);}});Abstract.EventObserver=function(){}
+Abstract.EventObserver.prototype={initialize:function(element,callback){this.element=$(element);this.callback=callback;this.lastValue=this.getValue();if(this.element.tagName.toLowerCase()=='form')
+this.registerFormCallbacks();else
+this.registerCallback(this.element);},onElementEvent:function(){var value=this.getValue();if(this.lastValue!=value){this.callback(this.element,value);this.lastValue=value;}},registerFormCallbacks:function(){Form.getElements(this.element).each(this.registerCallback.bind(this));},registerCallback:function(element){if(element.type){switch(element.type.toLowerCase()){case'checkbox':case'radio':Event.observe(element,'click',this.onElementEvent.bind(this));break;default:Event.observe(element,'change',this.onElementEvent.bind(this));break;}}}}
+Form.Element.EventObserver=Class.create();Form.Element.EventObserver.prototype=Object.extend(new Abstract.EventObserver(),{getValue:function(){return Form.Element.getValue(this.element);}});Form.EventObserver=Class.create();Form.EventObserver.prototype=Object.extend(new Abstract.EventObserver(),{getValue:function(){return Form.serialize(this.element);}});if(!window.Event){var Event=new Object();}
+Object.extend(Event,{KEY_BACKSPACE:8,KEY_TAB:9,KEY_RETURN:13,KEY_ESC:27,KEY_LEFT:37,KEY_UP:38,KEY_RIGHT:39,KEY_DOWN:40,KEY_DELETE:46,KEY_HOME:36,KEY_END:35,KEY_PAGEUP:33,KEY_PAGEDOWN:34,element:function(event){return event.target||event.srcElement;},isLeftClick:function(event){return(((event.which)&&(event.which==1))||((event.button)&&(event.button==1)));},pointerX:function(event){return event.pageX||(event.clientX+
+(document.documentElement.scrollLeft||document.body.scrollLeft));},pointerY:function(event){return event.pageY||(event.clientY+
+(document.documentElement.scrollTop||document.body.scrollTop));},stop:function(event){if(event.preventDefault){event.preventDefault();event.stopPropagation();}else{event.returnValue=false;event.cancelBubble=true;}},findElement:function(event,tagName){var element=Event.element(event);while(element.parentNode&&(!element.tagName||(element.tagName.toUpperCase()!=tagName.toUpperCase())))
+element=element.parentNode;return element;},observers:false,_observeAndCache:function(element,name,observer,useCapture){if(!this.observers)this.observers=[];if(element.addEventListener){this.observers.push([element,name,observer,useCapture]);element.addEventListener(name,observer,useCapture);}else if(element.attachEvent){this.observers.push([element,name,observer,useCapture]);element.attachEvent('on'+name,observer);}},unloadCache:function(){if(!Event.observers)return;for(var i=0,length=Event.observers.length;i<length;i++){Event.stopObserving.apply(this,Event.observers[i]);Event.observers[i][0]=null;}
+Event.observers=false;},observe:function(element,name,observer,useCapture){element=$(element);useCapture=useCapture||false;if(name=='keypress'&&(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||element.attachEvent))
+name='keydown';Event._observeAndCache(element,name,observer,useCapture);},stopObserving:function(element,name,observer,useCapture){element=$(element);useCapture=useCapture||false;if(name=='keypress'&&(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||element.detachEvent))
+name='keydown';if(element.removeEventListener){element.removeEventListener(name,observer,useCapture);}else if(element.detachEvent){try{element.detachEvent('on'+name,observer);}catch(e){}}}});if(navigator.appVersion.match(/\bMSIE\b/))
+Event.observe(window,'unload',Event.unloadCache,false);var Position={includeScrollOffsets:false,prepare:function(){this.deltaX=window.pageXOffset||document.documentElement.scrollLeft||document.body.scrollLeft||0;this.deltaY=window.pageYOffset||document.documentElement.scrollTop||document.body.scrollTop||0;},realOffset:function(element){var valueT=0,valueL=0;do{valueT+=element.scrollTop||0;valueL+=element.scrollLeft||0;element=element.parentNode;}while(element);return[valueL,valueT];},cumulativeOffset:function(element){var valueT=0,valueL=0;do{valueT+=element.offsetTop||0;valueL+=element.offsetLeft||0;element=element.offsetParent;}while(element);return[valueL,valueT];},positionedOffset:function(element){var valueT=0,valueL=0;do{valueT+=element.offsetTop||0;valueL+=element.offsetLeft||0;element=element.offsetParent;if(element){if(element.tagName=='BODY')break;var p=Element.getStyle(element,'position');if(p=='relative'||p=='absolute')break;}}while(element);return[valueL,valueT];},offsetParent:function(element){if(element.offsetParent)return element.offsetParent;if(element==document.body)return element;while((element=element.parentNode)&&element!=document.body)
+if(Element.getStyle(element,'position')!='static')
+return element;return document.body;},within:function(element,x,y){if(this.includeScrollOffsets)
+return this.withinIncludingScrolloffsets(element,x,y);this.xcomp=x;this.ycomp=y;this.offset=this.cumulativeOffset(element);return(y>=this.offset[1]&&y<this.offset[1]+element.offsetHeight&&x>=this.offset[0]&&x<this.offset[0]+element.offsetWidth);},withinIncludingScrolloffsets:function(element,x,y){var offsetcache=this.realOffset(element);this.xcomp=x+offsetcache[0]-this.deltaX;this.ycomp=y+offsetcache[1]-this.deltaY;this.offset=this.cumulativeOffset(element);return(this.ycomp>=this.offset[1]&&this.ycomp<this.offset[1]+element.offsetHeight&&this.xcomp>=this.offset[0]&&this.xcomp<this.offset[0]+element.offsetWidth);},overlap:function(mode,element){if(!mode)return 0;if(mode=='vertical')
+return((this.offset[1]+element.offsetHeight)-this.ycomp)/element.offsetHeight;if(mode=='horizontal')
+return((this.offset[0]+element.offsetWidth)-this.xcomp)/element.offsetWidth;},page:function(forElement){var valueT=0,valueL=0;var element=forElement;do{valueT+=element.offsetTop||0;valueL+=element.offsetLeft||0;if(element.offsetParent==document.body)
+if(Element.getStyle(element,'position')=='absolute')break;}while(element=element.offsetParent);element=forElement;do{if(!window.opera||element.tagName=='BODY'){valueT-=element.scrollTop||0;valueL-=element.scrollLeft||0;}}while(element=element.parentNode);return[valueL,valueT];},clone:function(source,target){var options=Object.extend({setLeft:true,setTop:true,setWidth:true,setHeight:true,offsetTop:0,offsetLeft:0},arguments[2]||{})
+source=$(source);var p=Position.page(source);target=$(target);var delta=[0,0];var parent=null;if(Element.getStyle(target,'position')=='absolute'){parent=Position.offsetParent(target);delta=Position.page(parent);}
+if(parent==document.body){delta[0]-=document.body.offsetLeft;delta[1]-=document.body.offsetTop;}
+if(options.setLeft)target.style.left=(p[0]-delta[0]+options.offsetLeft)+'px';if(options.setTop)target.style.top=(p[1]-delta[1]+options.offsetTop)+'px';if(options.setWidth)target.style.width=source.offsetWidth+'px';if(options.setHeight)target.style.height=source.offsetHeight+'px';},absolutize:function(element){element=$(element);if(element.style.position=='absolute')return;Position.prepare();var offsets=Position.positionedOffset(element);var top=offsets[1];var left=offsets[0];var width=element.clientWidth;var height=element.clientHeight;element._originalLeft=left-parseFloat(element.style.left||0);element._originalTop=top-parseFloat(element.style.top||0);element._originalWidth=element.style.width;element._originalHeight=element.style.height;element.style.position='absolute';element.style.top=top+'px';element.style.left=left+'px';element.style.width=width+'px';element.style.height=height+'px';},relativize:function(element){element=$(element);if(element.style.position=='relative')return;Position.prepare();element.style.position='relative';var top=parseFloat(element.style.top||0)-(element._originalTop||0);var left=parseFloat(element.style.left||0)-(element._originalLeft||0);element.style.top=top+'px';element.style.left=left+'px';element.style.height=element._originalHeight;element.style.width=element._originalWidth;}}
+if(/Konqueror|Safari|KHTML/.test(navigator.userAgent)){Position.cumulativeOffset=function(element){var valueT=0,valueL=0;do{valueT+=element.offsetTop||0;valueL+=element.offsetLeft||0;if(element.offsetParent==document.body)
+if(Element.getStyle(element,'position')=='absolute')break;element=element.offsetParent;}while(element);return[valueL,valueT];}}
+Element.addMethods();var Builder={NODEMAP:{AREA:'map',CAPTION:'table',COL:'table',COLGROUP:'table',LEGEND:'fieldset',OPTGROUP:'select',OPTION:'select',PARAM:'object',TBODY:'table',TD:'table',TFOOT:'table',TH:'table',THEAD:'table',TR:'table'},node:function(elementName){elementName=elementName.toUpperCase();var parentTag=this.NODEMAP[elementName]||'div';var parentElement=document.createElement(parentTag);try{parentElement.innerHTML="<"+elementName+"></"+elementName+">";}catch(e){}
+var element=parentElement.firstChild||null;if(element&&(element.tagName.toUpperCase()!=elementName))
+element=element.getElementsByTagName(elementName)[0];if(!element)element=document.createElement(elementName);if(!element)return;if(arguments[1])
+if(this._isStringOrNumber(arguments[1])||(arguments[1]instanceof Array)){this._children(element,arguments[1]);}else{var attrs=this._attributes(arguments[1]);if(attrs.length){try{parentElement.innerHTML="<"+elementName+" "+
+attrs+"></"+elementName+">";}catch(e){}
+element=parentElement.firstChild||null;if(!element){element=document.createElement(elementName);for(attr in arguments[1])
+element[attr=='class'?'className':attr]=arguments[1][attr];}
+if(element.tagName.toUpperCase()!=elementName)
+element=parentElement.getElementsByTagName(elementName)[0];}}
+if(arguments[2])
+this._children(element,arguments[2]);return element;},_text:function(text){return document.createTextNode(text);},ATTR_MAP:{'className':'class','htmlFor':'for'},_attributes:function(attributes){var attrs=[];for(attribute in attributes)
+attrs.push((attribute in this.ATTR_MAP?this.ATTR_MAP[attribute]:attribute)+'="'+attributes[attribute].toString().escapeHTML()+'"');return attrs.join(" ");},_children:function(element,children){if(typeof children=='object'){children.flatten().each(function(e){if(typeof e=='object')
+element.appendChild(e)
+else
+if(Builder._isStringOrNumber(e))
+element.appendChild(Builder._text(e));});}else
+if(Builder._isStringOrNumber(children))
+element.appendChild(Builder._text(children));},_isStringOrNumber:function(param){return(typeof param=='string'||typeof param=='number');},build:function(html){var element=this.node('div');$(element).update(html.strip());return element.down();},dump:function(scope){if(typeof scope!='object'&&typeof scope!='function')scope=window;var tags=("A ABBR ACRONYM ADDRESS APPLET AREA B BASE BASEFONT BDO BIG BLOCKQUOTE BODY "+"BR BUTTON CAPTION CENTER CITE CODE COL COLGROUP DD DEL DFN DIR DIV DL DT EM FIELDSET "+"FONT FORM FRAME FRAMESET H1 H2 H3 H4 H5 H6 HEAD HR HTML I IFRAME IMG INPUT INS ISINDEX "+"KBD LABEL LEGEND LI LINK MAP MENU META NOFRAMES NOSCRIPT OBJECT OL OPTGROUP OPTION P "+"PARAM PRE Q S SAMP SCRIPT SELECT SMALL SPAN STRIKE STRONG STYLE SUB SUP TABLE TBODY TD "+"TEXTAREA TFOOT TH THEAD TITLE TR TT U UL VAR").split(/\s+/);tags.each(function(tag){scope[tag]=function(){return Builder.node.apply(Builder,[tag].concat($A(arguments)));}});}}
+String.prototype.parseColor=function(){var color='#';if(this.slice(0,4)=='rgb('){var cols=this.slice(4,this.length-1).split(',');var i=0;do{color+=parseInt(cols[i]).toColorPart()}while(++i<3);}else{if(this.slice(0,1)=='#'){if(this.length==4)for(var i=1;i<4;i++)color+=(this.charAt(i)+this.charAt(i)).toLowerCase();if(this.length==7)color=this.toLowerCase();}}
+return(color.length==7?color:(arguments[0]||this));}
+Element.collectTextNodes=function(element){return $A($(element).childNodes).collect(function(node){return(node.nodeType==3?node.nodeValue:(node.hasChildNodes()?Element.collectTextNodes(node):''));}).flatten().join('');}
+Element.collectTextNodesIgnoreClass=function(element,className){return $A($(element).childNodes).collect(function(node){return(node.nodeType==3?node.nodeValue:((node.hasChildNodes()&&!Element.hasClassName(node,className))?Element.collectTextNodesIgnoreClass(node,className):''));}).flatten().join('');}
+Element.setContentZoom=function(element,percent){element=$(element);element.setStyle({fontSize:(percent/100)+'em'});if(navigator.appVersion.indexOf('AppleWebKit')>0)window.scrollBy(0,0);return element;}
+Element.getOpacity=function(element){return $(element).getStyle('opacity');}
+Element.setOpacity=function(element,value){return $(element).setStyle({opacity:value});}
+Element.getInlineOpacity=function(element){return $(element).style.opacity||'';}
+Element.forceRerendering=function(element){try{element=$(element);var n=document.createTextNode(' ');element.appendChild(n);element.removeChild(n);}catch(e){}};Array.prototype.call=function(){var args=arguments;this.each(function(f){f.apply(this,args)});}
+var Effect={_elementDoesNotExistError:{name:'ElementDoesNotExistError',message:'The specified DOM element does not exist, but is required for this effect to operate'},tagifyText:function(element){if(typeof Builder=='undefined')
+throw("Effect.tagifyText requires including script.aculo.us' builder.js library");var tagifyStyle='position:relative';if(/MSIE/.test(navigator.userAgent)&&!window.opera)tagifyStyle+=';zoom:1';element=$(element);$A(element.childNodes).each(function(child){if(child.nodeType==3){child.nodeValue.toArray().each(function(character){element.insertBefore(Builder.node('span',{style:tagifyStyle},character==' '?String.fromCharCode(160):character),child);});Element.remove(child);}});},multiple:function(element,effect){var elements;if(((typeof element=='object')||(typeof element=='function'))&&(element.length))
+elements=element;else
+elements=$(element).childNodes;var options=Object.extend({speed:0.1,delay:0.0},arguments[2]||{});var masterDelay=options.delay;$A(elements).each(function(element,index){new effect(element,Object.extend(options,{delay:index*options.speed+masterDelay}));});},PAIRS:{'slide':['SlideDown','SlideUp'],'blind':['BlindDown','BlindUp'],'appear':['Appear','Fade']},toggle:function(element,effect){element=$(element);effect=(effect||'appear').toLowerCase();var options=Object.extend({queue:{position:'end',scope:(element.id||'global'),limit:1}},arguments[2]||{});Effect[element.visible()?Effect.PAIRS[effect][1]:Effect.PAIRS[effect][0]](element,options);}};var Effect2=Effect;Effect.Transitions={linear:Prototype.K,sinoidal:function(pos){return(-Math.cos(pos*Math.PI)/2)+0.5;},reverse:function(pos){return 1-pos;},flicker:function(pos){return((-Math.cos(pos*Math.PI)/4)+0.75)+Math.random()/4;},wobble:function(pos){return(-Math.cos(pos*Math.PI*(9*pos))/2)+0.5;},pulse:function(pos,pulses){pulses=pulses||5;return(Math.round((pos%(1/pulses))*pulses)==0?((pos*pulses*2)-Math.floor(pos*pulses*2)):1-((pos*pulses*2)-Math.floor(pos*pulses*2)));},none:function(pos){return 0;},full:function(pos){return 1;}};Effect.ScopedQueue=Class.create();Object.extend(Object.extend(Effect.ScopedQueue.prototype,Enumerable),{initialize:function(){this.effects=[];this.interval=null;},_each:function(iterator){this.effects._each(iterator);},add:function(effect){var timestamp=new Date().getTime();var position=(typeof effect.options.queue=='string')?effect.options.queue:effect.options.queue.position;switch(position){case'front':this.effects.findAll(function(e){return e.state=='idle'}).each(function(e){e.startOn+=effect.finishOn;e.finishOn+=effect.finishOn;});break;case'with-last':timestamp=this.effects.pluck('startOn').max()||timestamp;break;case'end':timestamp=this.effects.pluck('finishOn').max()||timestamp;break;}
+effect.startOn+=timestamp;effect.finishOn+=timestamp;if(!effect.options.queue.limit||(this.effects.length<effect.options.queue.limit))
+this.effects.push(effect);if(!this.interval)
+this.interval=setInterval(this.loop.bind(this),15);},remove:function(effect){this.effects=this.effects.reject(function(e){return e==effect});if(this.effects.length==0){clearInterval(this.interval);this.interval=null;}},loop:function(){var timePos=new Date().getTime();for(var i=0,len=this.effects.length;i<len;i++)
+if(this.effects[i])this.effects[i].loop(timePos);}});Effect.Queues={instances:$H(),get:function(queueName){if(typeof queueName!='string')return queueName;if(!this.instances[queueName])
+this.instances[queueName]=new Effect.ScopedQueue();return this.instances[queueName];}}
+Effect.Queue=Effect.Queues.get('global');Effect.DefaultOptions={transition:Effect.Transitions.sinoidal,duration:1.0,fps:60.0,sync:false,from:0.0,to:1.0,delay:0.0,queue:'parallel'}
+Effect.Base=function(){};Effect.Base.prototype={position:null,start:function(options){this.options=Object.extend(Object.extend({},Effect.DefaultOptions),options||{});this.currentFrame=0;this.state='idle';this.startOn=this.options.delay*1000;this.finishOn=this.startOn+(this.options.duration*1000);this.event('beforeStart');if(!this.options.sync)
+Effect.Queues.get(typeof this.options.queue=='string'?'global':this.options.queue.scope).add(this);},loop:function(timePos){if(timePos>=this.startOn){if(timePos>=this.finishOn){this.render(1.0);this.cancel();this.event('beforeFinish');if(this.finish)this.finish();this.event('afterFinish');return;}
+var pos=(timePos-this.startOn)/(this.finishOn-this.startOn);var frame=Math.round(pos*this.options.fps*this.options.duration);if(frame>this.currentFrame){this.render(pos);this.currentFrame=frame;}}},render:function(pos){if(this.state=='idle'){this.state='running';this.event('beforeSetup');if(this.setup)this.setup();this.event('afterSetup');}
+if(this.state=='running'){if(this.options.transition)pos=this.options.transition(pos);pos*=(this.options.to-this.options.from);pos+=this.options.from;this.position=pos;this.event('beforeUpdate');if(this.update)this.update(pos);this.event('afterUpdate');}},cancel:function(){if(!this.options.sync)
+Effect.Queues.get(typeof this.options.queue=='string'?'global':this.options.queue.scope).remove(this);this.state='finished';},event:function(eventName){if(this.options[eventName+'Internal'])this.options[eventName+'Internal'](this);if(this.options[eventName])this.options[eventName](this);},inspect:function(){var data=$H();for(property in this)
+if(typeof this[property]!='function')data[property]=this[property];return'#<Effect:'+data.inspect()+',options:'+$H(this.options).inspect()+'>';}}
+Effect.Parallel=Class.create();Object.extend(Object.extend(Effect.Parallel.prototype,Effect.Base.prototype),{initialize:function(effects){this.effects=effects||[];this.start(arguments[1]);},update:function(position){this.effects.invoke('render',position);},finish:function(position){this.effects.each(function(effect){effect.render(1.0);effect.cancel();effect.event('beforeFinish');if(effect.finish)effect.finish(position);effect.event('afterFinish');});}});Effect.Event=Class.create();Object.extend(Object.extend(Effect.Event.prototype,Effect.Base.prototype),{initialize:function(){var options=Object.extend({duration:0},arguments[0]||{});this.start(options);},update:Prototype.emptyFunction});Effect.Opacity=Class.create();Object.extend(Object.extend(Effect.Opacity.prototype,Effect.Base.prototype),{initialize:function(element){this.element=$(element);if(!this.element)throw(Effect._elementDoesNotExistError);if(/MSIE/.test(navigator.userAgent)&&!window.opera&&(!this.element.currentStyle.hasLayout))
+this.element.setStyle({zoom:1});var options=Object.extend({from:this.element.getOpacity()||0.0,to:1.0},arguments[1]||{});this.start(options);},update:function(position){this.element.setOpacity(position);}});Effect.Move=Class.create();Object.extend(Object.extend(Effect.Move.prototype,Effect.Base.prototype),{initialize:function(element){this.element=$(element);if(!this.element)throw(Effect._elementDoesNotExistError);var options=Object.extend({x:0,y:0,mode:'relative'},arguments[1]||{});this.start(options);},setup:function(){this.element.makePositioned();this.originalLeft=parseFloat(this.element.getStyle('left')||'0');this.originalTop=parseFloat(this.element.getStyle('top')||'0');if(this.options.mode=='absolute'){this.options.x=this.options.x-this.originalLeft;this.options.y=this.options.y-this.originalTop;}},update:function(position){this.element.setStyle({left:Math.round(this.options.x*position+this.originalLeft)+'px',top:Math.round(this.options.y*position+this.originalTop)+'px'});}});Effect.MoveBy=function(element,toTop,toLeft){return new Effect.Move(element,Object.extend({x:toLeft,y:toTop},arguments[3]||{}));};Effect.Scale=Class.create();Object.extend(Object.extend(Effect.Scale.prototype,Effect.Base.prototype),{initialize:function(element,percent){this.element=$(element);if(!this.element)throw(Effect._elementDoesNotExistError);var options=Object.extend({scaleX:true,scaleY:true,scaleContent:true,scaleFromCenter:false,scaleMode:'box',scaleFrom:100.0,scaleTo:percent},arguments[2]||{});this.start(options);},setup:function(){this.restoreAfterFinish=this.options.restoreAfterFinish||false;this.elementPositioning=this.element.getStyle('position');this.originalStyle={};['top','left','width','height','fontSize'].each(function(k){this.originalStyle[k]=this.element.style[k];}.bind(this));this.originalTop=this.element.offsetTop;this.originalLeft=this.element.offsetLeft;var fontSize=this.element.getStyle('font-size')||'100%';['em','px','%','pt'].each(function(fontSizeType){if(fontSize.indexOf(fontSizeType)>0){this.fontSize=parseFloat(fontSize);this.fontSizeType=fontSizeType;}}.bind(this));this.factor=(this.options.scaleTo-this.options.scaleFrom)/100;this.dims=null;if(this.options.scaleMode=='box')
+this.dims=[this.element.offsetHeight,this.element.offsetWidth];if(/^content/.test(this.options.scaleMode))
+this.dims=[this.element.scrollHeight,this.element.scrollWidth];if(!this.dims)
+this.dims=[this.options.scaleMode.originalHeight,this.options.scaleMode.originalWidth];},update:function(position){var currentScale=(this.options.scaleFrom/100.0)+(this.factor*position);if(this.options.scaleContent&&this.fontSize)
+this.element.setStyle({fontSize:this.fontSize*currentScale+this.fontSizeType});this.setDimensions(this.dims[0]*currentScale,this.dims[1]*currentScale);},finish:function(position){if(this.restoreAfterFinish)this.element.setStyle(this.originalStyle);},setDimensions:function(height,width){var d={};if(this.options.scaleX)d.width=Math.round(width)+'px';if(this.options.scaleY)d.height=Math.round(height)+'px';if(this.options.scaleFromCenter){var topd=(height-this.dims[0])/2;var leftd=(width-this.dims[1])/2;if(this.elementPositioning=='absolute'){if(this.options.scaleY)d.top=this.originalTop-topd+'px';if(this.options.scaleX)d.left=this.originalLeft-leftd+'px';}else{if(this.options.scaleY)d.top=-topd+'px';if(this.options.scaleX)d.left=-leftd+'px';}}
+this.element.setStyle(d);}});Effect.Highlight=Class.create();Object.extend(Object.extend(Effect.Highlight.prototype,Effect.Base.prototype),{initialize:function(element){this.element=$(element);if(!this.element)throw(Effect._elementDoesNotExistError);var options=Object.extend({startcolor:'#ffff99'},arguments[1]||{});this.start(options);},setup:function(){if(this.element.getStyle('display')=='none'){this.cancel();return;}
+this.oldStyle={};if(!this.options.keepBackgroundImage){this.oldStyle.backgroundImage=this.element.getStyle('background-image');this.element.setStyle({backgroundImage:'none'});}
+if(!this.options.endcolor)
+this.options.endcolor=this.element.getStyle('background-color').parseColor('#ffffff');if(!this.options.restorecolor)
+this.options.restorecolor=this.element.getStyle('background-color');this._base=$R(0,2).map(function(i){return parseInt(this.options.startcolor.slice(i*2+1,i*2+3),16)}.bind(this));this._delta=$R(0,2).map(function(i){return parseInt(this.options.endcolor.slice(i*2+1,i*2+3),16)-this._base[i]}.bind(this));},update:function(position){this.element.setStyle({backgroundColor:$R(0,2).inject('#',function(m,v,i){return m+(Math.round(this._base[i]+(this._delta[i]*position)).toColorPart());}.bind(this))});},finish:function(){this.element.setStyle(Object.extend(this.oldStyle,{backgroundColor:this.options.restorecolor}));}});Effect.ScrollTo=Class.create();Object.extend(Object.extend(Effect.ScrollTo.prototype,Effect.Base.prototype),{initialize:function(element){this.element=$(element);this.start(arguments[1]||{});},setup:function(){Position.prepare();var offsets=Position.cumulativeOffset(this.element);if(this.options.offset)offsets[1]+=this.options.offset;var max=window.innerHeight?window.height-window.innerHeight:document.body.scrollHeight-
+(document.documentElement.clientHeight?document.documentElement.clientHeight:document.body.clientHeight);this.scrollStart=Position.deltaY;this.delta=(offsets[1]>max?max:offsets[1])-this.scrollStart;},update:function(position){Position.prepare();window.scrollTo(Position.deltaX,this.scrollStart+(position*this.delta));}});Effect.Fade=function(element){element=$(element);var oldOpacity=element.getInlineOpacity();var options=Object.extend({from:element.getOpacity()||1.0,to:0.0,afterFinishInternal:function(effect){if(effect.options.to!=0)return;effect.element.hide().setStyle({opacity:oldOpacity});}},arguments[1]||{});return new Effect.Opacity(element,options);}
+Effect.Appear=function(element){element=$(element);var options=Object.extend({from:(element.getStyle('display')=='none'?0.0:element.getOpacity()||0.0),to:1.0,afterFinishInternal:function(effect){effect.element.forceRerendering();},beforeSetup:function(effect){effect.element.setOpacity(effect.options.from).show();}},arguments[1]||{});return new Effect.Opacity(element,options);}
+Effect.Puff=function(element){element=$(element);var oldStyle={opacity:element.getInlineOpacity(),position:element.getStyle('position'),top:element.style.top,left:element.style.left,width:element.style.width,height:element.style.height};return new Effect.Parallel([new Effect.Scale(element,200,{sync:true,scaleFromCenter:true,scaleContent:true,restoreAfterFinish:true}),new Effect.Opacity(element,{sync:true,to:0.0})],Object.extend({duration:1.0,beforeSetupInternal:function(effect){Position.absolutize(effect.effects[0].element)},afterFinishInternal:function(effect){effect.effects[0].element.hide().setStyle(oldStyle);}},arguments[1]||{}));}
+Effect.BlindUp=function(element){element=$(element);element.makeClipping();return new Effect.Scale(element,0,Object.extend({scaleContent:false,scaleX:false,restoreAfterFinish:true,afterFinishInternal:function(effect){effect.element.hide().undoClipping();}},arguments[1]||{}));}
+Effect.BlindDown=function(element){element=$(element);var elementDimensions=element.getDimensions();return new Effect.Scale(element,100,Object.extend({scaleContent:false,scaleX:false,scaleFrom:0,scaleMode:{originalHeight:elementDimensions.height,originalWidth:elementDimensions.width},restoreAfterFinish:true,afterSetup:function(effect){effect.element.makeClipping().setStyle({height:'0px'}).show();},afterFinishInternal:function(effect){effect.element.undoClipping();}},arguments[1]||{}));}
+Effect.SwitchOff=function(element){element=$(element);var oldOpacity=element.getInlineOpacity();return new Effect.Appear(element,Object.extend({duration:0.4,from:0,transition:Effect.Transitions.flicker,afterFinishInternal:function(effect){new Effect.Scale(effect.element,1,{duration:0.3,scaleFromCenter:true,scaleX:false,scaleContent:false,restoreAfterFinish:true,beforeSetup:function(effect){effect.element.makePositioned().makeClipping();},afterFinishInternal:function(effect){effect.element.hide().undoClipping().undoPositioned().setStyle({opacity:oldOpacity});}})}},arguments[1]||{}));}
+Effect.DropOut=function(element){element=$(element);var oldStyle={top:element.getStyle('top'),left:element.getStyle('left'),opacity:element.getInlineOpacity()};return new Effect.Parallel([new Effect.Move(element,{x:0,y:100,sync:true}),new Effect.Opacity(element,{sync:true,to:0.0})],Object.extend({duration:0.5,beforeSetup:function(effect){effect.effects[0].element.makePositioned();},afterFinishInternal:function(effect){effect.effects[0].element.hide().undoPositioned().setStyle(oldStyle);}},arguments[1]||{}));}
+Effect.Shake=function(element){element=$(element);var oldStyle={top:element.getStyle('top'),left:element.getStyle('left')};return new Effect.Move(element,{x:20,y:0,duration:0.05,afterFinishInternal:function(effect){new Effect.Move(effect.element,{x:-40,y:0,duration:0.1,afterFinishInternal:function(effect){new Effect.Move(effect.element,{x:40,y:0,duration:0.1,afterFinishInternal:function(effect){new Effect.Move(effect.element,{x:-40,y:0,duration:0.1,afterFinishInternal:function(effect){new Effect.Move(effect.element,{x:40,y:0,duration:0.1,afterFinishInternal:function(effect){new Effect.Move(effect.element,{x:-20,y:0,duration:0.05,afterFinishInternal:function(effect){effect.element.undoPositioned().setStyle(oldStyle);}})}})}})}})}})}});}
+Effect.SlideDown=function(element){element=$(element).cleanWhitespace();var oldInnerBottom=element.down().getStyle('bottom');var elementDimensions=element.getDimensions();return new Effect.Scale(element,100,Object.extend({scaleContent:false,scaleX:false,scaleFrom:window.opera?0:1,scaleMode:{originalHeight:elementDimensions.height,originalWidth:elementDimensions.width},restoreAfterFinish:true,afterSetup:function(effect){effect.element.makePositioned();effect.element.down().makePositioned();if(window.opera)effect.element.setStyle({top:''});effect.element.makeClipping().setStyle({height:'0px'}).show();},afterUpdateInternal:function(effect){effect.element.down().setStyle({bottom:(effect.dims[0]-effect.element.clientHeight)+'px'});},afterFinishInternal:function(effect){effect.element.undoClipping().undoPositioned();effect.element.down().undoPositioned().setStyle({bottom:oldInnerBottom});}},arguments[1]||{}));}
+Effect.SlideUp=function(element){element=$(element).cleanWhitespace();var oldInnerBottom=element.down().getStyle('bottom');return new Effect.Scale(element,window.opera?0:1,Object.extend({scaleContent:false,scaleX:false,scaleMode:'box',scaleFrom:100,restoreAfterFinish:true,beforeStartInternal:function(effect){effect.element.makePositioned();effect.element.down().makePositioned();if(window.opera)effect.element.setStyle({top:''});effect.element.makeClipping().show();},afterUpdateInternal:function(effect){effect.element.down().setStyle({bottom:(effect.dims[0]-effect.element.clientHeight)+'px'});},afterFinishInternal:function(effect){effect.element.hide().undoClipping().undoPositioned().setStyle({bottom:oldInnerBottom});effect.element.down().undoPositioned();}},arguments[1]||{}));}
+Effect.Squish=function(element){return new Effect.Scale(element,window.opera?1:0,{restoreAfterFinish:true,beforeSetup:function(effect){effect.element.makeClipping();},afterFinishInternal:function(effect){effect.element.hide().undoClipping();}});}
+Effect.Grow=function(element){element=$(element);var options=Object.extend({direction:'center',moveTransition:Effect.Transitions.sinoidal,scaleTransition:Effect.Transitions.sinoidal,opacityTransition:Effect.Transitions.full},arguments[1]||{});var oldStyle={top:element.style.top,left:element.style.left,height:element.style.height,width:element.style.width,opacity:element.getInlineOpacity()};var dims=element.getDimensions();var initialMoveX,initialMoveY;var moveX,moveY;switch(options.direction){case'top-left':initialMoveX=initialMoveY=moveX=moveY=0;break;case'top-right':initialMoveX=dims.width;initialMoveY=moveY=0;moveX=-dims.width;break;case'bottom-left':initialMoveX=moveX=0;initialMoveY=dims.height;moveY=-dims.height;break;case'bottom-right':initialMoveX=dims.width;initialMoveY=dims.height;moveX=-dims.width;moveY=-dims.height;break;case'center':initialMoveX=dims.width/2;initialMoveY=dims.height/2;moveX=-dims.width/2;moveY=-dims.height/2;break;}
+return new Effect.Move(element,{x:initialMoveX,y:initialMoveY,duration:0.01,beforeSetup:function(effect){effect.element.hide().makeClipping().makePositioned();},afterFinishInternal:function(effect){new Effect.Parallel([new Effect.Opacity(effect.element,{sync:true,to:1.0,from:0.0,transition:options.opacityTransition}),new Effect.Move(effect.element,{x:moveX,y:moveY,sync:true,transition:options.moveTransition}),new Effect.Scale(effect.element,100,{scaleMode:{originalHeight:dims.height,originalWidth:dims.width},sync:true,scaleFrom:window.opera?1:0,transition:options.scaleTransition,restoreAfterFinish:true})],Object.extend({beforeSetup:function(effect){effect.effects[0].element.setStyle({height:'0px'}).show();},afterFinishInternal:function(effect){effect.effects[0].element.undoClipping().undoPositioned().setStyle(oldStyle);}},options))}});}
+Effect.Shrink=function(element){element=$(element);var options=Object.extend({direction:'center',moveTransition:Effect.Transitions.sinoidal,scaleTransition:Effect.Transitions.sinoidal,opacityTransition:Effect.Transitions.none},arguments[1]||{});var oldStyle={top:element.style.top,left:element.style.left,height:element.style.height,width:element.style.width,opacity:element.getInlineOpacity()};var dims=element.getDimensions();var moveX,moveY;switch(options.direction){case'top-left':moveX=moveY=0;break;case'top-right':moveX=dims.width;moveY=0;break;case'bottom-left':moveX=0;moveY=dims.height;break;case'bottom-right':moveX=dims.width;moveY=dims.height;break;case'center':moveX=dims.width/2;moveY=dims.height/2;break;}
+return new Effect.Parallel([new Effect.Opacity(element,{sync:true,to:0.0,from:1.0,transition:options.opacityTransition}),new Effect.Scale(element,window.opera?1:0,{sync:true,transition:options.scaleTransition,restoreAfterFinish:true}),new Effect.Move(element,{x:moveX,y:moveY,sync:true,transition:options.moveTransition})],Object.extend({beforeStartInternal:function(effect){effect.effects[0].element.makePositioned().makeClipping();},afterFinishInternal:function(effect){effect.effects[0].element.hide().undoClipping().undoPositioned().setStyle(oldStyle);}},options));}
+Effect.Pulsate=function(element){element=$(element);var options=arguments[1]||{};var oldOpacity=element.getInlineOpacity();var transition=options.transition||Effect.Transitions.sinoidal;var reverser=function(pos){return transition(1-Effect.Transitions.pulse(pos,options.pulses))};reverser.bind(transition);return new Effect.Opacity(element,Object.extend(Object.extend({duration:2.0,from:0,afterFinishInternal:function(effect){effect.element.setStyle({opacity:oldOpacity});}},options),{transition:reverser}));}
+Effect.Fold=function(element){element=$(element);var oldStyle={top:element.style.top,left:element.style.left,width:element.style.width,height:element.style.height};element.makeClipping();return new Effect.Scale(element,5,Object.extend({scaleContent:false,scaleX:false,afterFinishInternal:function(effect){new Effect.Scale(element,1,{scaleContent:false,scaleY:false,afterFinishInternal:function(effect){effect.element.hide().undoClipping().setStyle(oldStyle);}});}},arguments[1]||{}));};Effect.Morph=Class.create();Object.extend(Object.extend(Effect.Morph.prototype,Effect.Base.prototype),{initialize:function(element){this.element=$(element);if(!this.element)throw(Effect._elementDoesNotExistError);var options=Object.extend({style:{}},arguments[1]||{});if(typeof options.style=='string'){if(options.style.indexOf(':')==-1){var cssText='',selector='.'+options.style;$A(document.styleSheets).reverse().each(function(styleSheet){if(styleSheet.cssRules)cssRules=styleSheet.cssRules;else if(styleSheet.rules)cssRules=styleSheet.rules;$A(cssRules).reverse().each(function(rule){if(selector==rule.selectorText){cssText=rule.style.cssText;throw $break;}});if(cssText)throw $break;});this.style=cssText.parseStyle();options.afterFinishInternal=function(effect){effect.element.addClassName(effect.options.style);effect.transforms.each(function(transform){if(transform.style!='opacity')
+effect.element.style[transform.style.camelize()]='';});}}else this.style=options.style.parseStyle();}else this.style=$H(options.style)
+this.start(options);},setup:function(){function parseColor(color){if(!color||['rgba(0, 0, 0, 0)','transparent'].include(color))color='#ffffff';color=color.parseColor();return $R(0,2).map(function(i){return parseInt(color.slice(i*2+1,i*2+3),16)});}
+this.transforms=this.style.map(function(pair){var property=pair[0].underscore().dasherize(),value=pair[1],unit=null;if(value.parseColor('#zzzzzz')!='#zzzzzz'){value=value.parseColor();unit='color';}else if(property=='opacity'){value=parseFloat(value);if(/MSIE/.test(navigator.userAgent)&&!window.opera&&(!this.element.currentStyle.hasLayout))
+this.element.setStyle({zoom:1});}else if(Element.CSS_LENGTH.test(value))
+var components=value.match(/^([\+\-]?[0-9\.]+)(.*)$/),value=parseFloat(components[1]),unit=(components.length==3)?components[2]:null;var originalValue=this.element.getStyle(property);return $H({style:property,originalValue:unit=='color'?parseColor(originalValue):parseFloat(originalValue||0),targetValue:unit=='color'?parseColor(value):value,unit:unit});}.bind(this)).reject(function(transform){return((transform.originalValue==transform.targetValue)||(transform.unit!='color'&&(isNaN(transform.originalValue)||isNaN(transform.targetValue))))});},update:function(position){var style=$H(),value=null;this.transforms.each(function(transform){value=transform.unit=='color'?$R(0,2).inject('#',function(m,v,i){return m+(Math.round(transform.originalValue[i]+
+(transform.targetValue[i]-transform.originalValue[i])*position)).toColorPart()}):transform.originalValue+Math.round(((transform.targetValue-transform.originalValue)*position)*1000)/1000+transform.unit;style[transform.style]=value;});this.element.setStyle(style);}});Effect.Transform=Class.create();Object.extend(Effect.Transform.prototype,{initialize:function(tracks){this.tracks=[];this.options=arguments[1]||{};this.addTracks(tracks);},addTracks:function(tracks){tracks.each(function(track){var data=$H(track).values().first();this.tracks.push($H({ids:$H(track).keys().first(),effect:Effect.Morph,options:{style:data}}));}.bind(this));return this;},play:function(){return new Effect.Parallel(this.tracks.map(function(track){var elements=[$(track.ids)||$$(track.ids)].flatten();return elements.map(function(e){return new track.effect(e,Object.extend({sync:true},track.options))});}).flatten(),this.options);}});Element.CSS_PROPERTIES=$w('backgroundColor backgroundPosition borderBottomColor borderBottomStyle '+'borderBottomWidth borderLeftColor borderLeftStyle borderLeftWidth '+'borderRightColor borderRightStyle borderRightWidth borderSpacing '+'borderTopColor borderTopStyle borderTopWidth bottom clip color '+'fontSize fontWeight height left letterSpacing lineHeight '+'marginBottom marginLeft marginRight marginTop markerOffset maxHeight '+'maxWidth minHeight minWidth opacity outlineColor outlineOffset '+'outlineWidth paddingBottom paddingLeft paddingRight paddingTop '+'right textIndent top width wordSpacing zIndex');Element.CSS_LENGTH=/^(([\+\-]?[0-9\.]+)(em|ex|px|in|cm|mm|pt|pc|\%))|0$/;String.prototype.parseStyle=function(){var element=Element.extend(document.createElement('div'));element.innerHTML='<div style="'+this+'"></div>';var style=element.down().style,styleRules=$H();Element.CSS_PROPERTIES.each(function(property){if(style[property])styleRules[property]=style[property];});if(/MSIE/.test(navigator.userAgent)&&!window.opera&&this.indexOf('opacity')>-1){styleRules.opacity=this.match(/opacity:\s*((?:0|1)?(?:\.\d*)?)/)[1];}
+return styleRules;};Element.morph=function(element,style){new Effect.Morph(element,Object.extend({style:style},arguments[2]||{}));return element;};['setOpacity','getOpacity','getInlineOpacity','forceRerendering','setContentZoom','collectTextNodes','collectTextNodesIgnoreClass','morph'].each(function(f){Element.Methods[f]=Element[f];});Element.Methods.visualEffect=function(element,effect,options){s=effect.gsub(/_/,'-').camelize();effect_class=s.charAt(0).toUpperCase()+s.substring(1);new Effect[effect_class](element,options);return $(element);};Element.addMethods();if(typeof Effect=='undefined')
+throw("dragdrop.js requires including script.aculo.us' effects.js library");var Droppables={drops:[],remove:function(element){this.drops=this.drops.reject(function(d){return d.element==$(element)});},add:function(element){element=$(element);var options=Object.extend({greedy:true,hoverclass:null,tree:false},arguments[1]||{});if(options.containment){options._containers=[];var containment=options.containment;if((typeof containment=='object')&&(containment.constructor==Array)){containment.each(function(c){options._containers.push($(c))});}else{options._containers.push($(containment));}}
+if(options.accept)options.accept=[options.accept].flatten();Element.makePositioned(element);options.element=element;this.drops.push(options);},findDeepestChild:function(drops){deepest=drops[0];for(i=1;i<drops.length;++i)
+if(Element.isParent(drops[i].element,deepest.element))
+deepest=drops[i];return deepest;},isContained:function(element,drop){var containmentNode;if(drop.tree){containmentNode=element.treeNode;}else{containmentNode=element.parentNode;}
+return drop._containers.detect(function(c){return containmentNode==c});},isAffected:function(point,element,drop){return((drop.element!=element)&&((!drop._containers)||this.isContained(element,drop))&&((!drop.accept)||(Element.classNames(element).detect(function(v){return drop.accept.include(v)})))&&Position.within(drop.element,point[0],point[1]));},deactivate:function(drop){if(drop.hoverclass)
+Element.removeClassName(drop.element,drop.hoverclass);this.last_active=null;},activate:function(drop){if(drop.hoverclass)
+Element.addClassName(drop.element,drop.hoverclass);this.last_active=drop;},show:function(point,element){if(!this.drops.length)return;var affected=[];if(this.last_active)this.deactivate(this.last_active);this.drops.each(function(drop){if(Droppables.isAffected(point,element,drop))
+affected.push(drop);});if(affected.length>0){drop=Droppables.findDeepestChild(affected);Position.within(drop.element,point[0],point[1]);if(drop.onHover)
+drop.onHover(element,drop.element,Position.overlap(drop.overlap,drop.element));Droppables.activate(drop);}},fire:function(event,element){if(!this.last_active)return;Position.prepare();if(this.isAffected([Event.pointerX(event),Event.pointerY(event)],element,this.last_active))
+if(this.last_active.onDrop)
+this.last_active.onDrop(element,this.last_active.element,event);},reset:function(){if(this.last_active)
+this.deactivate(this.last_active);}}
+var Draggables={drags:[],observers:[],register:function(draggable){if(this.drags.length==0){this.eventMouseUp=this.endDrag.bindAsEventListener(this);this.eventMouseMove=this.updateDrag.bindAsEventListener(this);this.eventKeypress=this.keyPress.bindAsEventListener(this);Event.observe(document,"mouseup",this.eventMouseUp);Event.observe(document,"mousemove",this.eventMouseMove);Event.observe(document,"keypress",this.eventKeypress);}
+this.drags.push(draggable);},unregister:function(draggable){this.drags=this.drags.reject(function(d){return d==draggable});if(this.drags.length==0){Event.stopObserving(document,"mouseup",this.eventMouseUp);Event.stopObserving(document,"mousemove",this.eventMouseMove);Event.stopObserving(document,"keypress",this.eventKeypress);}},activate:function(draggable){if(draggable.options.delay){this._timeout=setTimeout(function(){Draggables._timeout=null;window.focus();Draggables.activeDraggable=draggable;}.bind(this),draggable.options.delay);}else{window.focus();this.activeDraggable=draggable;}},deactivate:function(){this.activeDraggable=null;},updateDrag:function(event){if(!this.activeDraggable)return;var pointer=[Event.pointerX(event),Event.pointerY(event)];if(this._lastPointer&&(this._lastPointer.inspect()==pointer.inspect()))return;this._lastPointer=pointer;this.activeDraggable.updateDrag(event,pointer);},endDrag:function(event){if(this._timeout){clearTimeout(this._timeout);this._timeout=null;}
+if(!this.activeDraggable)return;this._lastPointer=null;this.activeDraggable.endDrag(event);this.activeDraggable=null;},keyPress:function(event){if(this.activeDraggable)
+this.activeDraggable.keyPress(event);},addObserver:function(observer){this.observers.push(observer);this._cacheObserverCallbacks();},removeObserver:function(element){this.observers=this.observers.reject(function(o){return o.element==element});this._cacheObserverCallbacks();},notify:function(eventName,draggable,event){if(this[eventName+'Count']>0)
+this.observers.each(function(o){if(o[eventName])o[eventName](eventName,draggable,event);});if(draggable.options[eventName])draggable.options[eventName](draggable,event);},_cacheObserverCallbacks:function(){['onStart','onEnd','onDrag'].each(function(eventName){Draggables[eventName+'Count']=Draggables.observers.select(function(o){return o[eventName];}).length;});}}
+var Draggable=Class.create();Draggable._dragging={};Draggable.prototype={initialize:function(element){var defaults={handle:false,reverteffect:function(element,top_offset,left_offset){var dur=Math.sqrt(Math.abs(top_offset^2)+Math.abs(left_offset^2))*0.02;new Effect.Move(element,{x:-left_offset,y:-top_offset,duration:dur,queue:{scope:'_draggable',position:'end'}});},endeffect:function(element){var toOpacity=typeof element._opacity=='number'?element._opacity:1.0;new Effect.Opacity(element,{duration:0.2,from:0.7,to:toOpacity,queue:{scope:'_draggable',position:'end'},afterFinish:function(){Draggable._dragging[element]=false}});},zindex:1000,revert:false,scroll:false,scrollSensitivity:20,scrollSpeed:15,snap:false,delay:0};if(!arguments[1]||typeof arguments[1].endeffect=='undefined')
+Object.extend(defaults,{starteffect:function(element){element._opacity=Element.getOpacity(element);Draggable._dragging[element]=true;new Effect.Opacity(element,{duration:0.2,from:element._opacity,to:0.7});}});var options=Object.extend(defaults,arguments[1]||{});this.element=$(element);if(options.handle&&(typeof options.handle=='string'))
+this.handle=this.element.down('.'+options.handle,0);if(!this.handle)this.handle=$(options.handle);if(!this.handle)this.handle=this.element;if(options.scroll&&!options.scroll.scrollTo&&!options.scroll.outerHTML){options.scroll=$(options.scroll);this._isScrollChild=Element.childOf(this.element,options.scroll);}
+Element.makePositioned(this.element);this.delta=this.currentDelta();this.options=options;this.dragging=false;this.eventMouseDown=this.initDrag.bindAsEventListener(this);Event.observe(this.handle,"mousedown",this.eventMouseDown);Draggables.register(this);},destroy:function(){Event.stopObserving(this.handle,"mousedown",this.eventMouseDown);Draggables.unregister(this);},currentDelta:function(){return([parseInt(Element.getStyle(this.element,'left')||'0'),parseInt(Element.getStyle(this.element,'top')||'0')]);},initDrag:function(event){if(typeof Draggable._dragging[this.element]!='undefined'&&Draggable._dragging[this.element])return;if(Event.isLeftClick(event)){var src=Event.element(event);if((tag_name=src.tagName.toUpperCase())&&(tag_name=='INPUT'||tag_name=='SELECT'||tag_name=='OPTION'||tag_name=='BUTTON'||tag_name=='TEXTAREA'))return;var pointer=[Event.pointerX(event),Event.pointerY(event)];var pos=Position.cumulativeOffset(this.element);this.offset=[0,1].map(function(i){return(pointer[i]-pos[i])});Draggables.activate(this);Event.stop(event);}},startDrag:function(event){this.dragging=true;if(this.options.zindex){this.originalZ=parseInt(Element.getStyle(this.element,'z-index')||0);this.element.style.zIndex=this.options.zindex;}
+if(this.options.ghosting){this._clone=this.element.cloneNode(true);Position.absolutize(this.element);this.element.parentNode.insertBefore(this._clone,this.element);}
+if(this.options.scroll){if(this.options.scroll==window){var where=this._getWindowScroll(this.options.scroll);this.originalScrollLeft=where.left;this.originalScrollTop=where.top;}else{this.originalScrollLeft=this.options.scroll.scrollLeft;this.originalScrollTop=this.options.scroll.scrollTop;}}
+Draggables.notify('onStart',this,event);if(this.options.starteffect)this.options.starteffect(this.element);},updateDrag:function(event,pointer){if(!this.dragging)this.startDrag(event);Position.prepare();Droppables.show(pointer,this.element);Draggables.notify('onDrag',this,event);this.draw(pointer);if(this.options.change)this.options.change(this);if(this.options.scroll){this.stopScrolling();var p;if(this.options.scroll==window){with(this._getWindowScroll(this.options.scroll)){p=[left,top,left+width,top+height];}}else{p=Position.page(this.options.scroll);p[0]+=this.options.scroll.scrollLeft+Position.deltaX;p[1]+=this.options.scroll.scrollTop+Position.deltaY;p.push(p[0]+this.options.scroll.offsetWidth);p.push(p[1]+this.options.scroll.offsetHeight);}
+var speed=[0,0];if(pointer[0]<(p[0]+this.options.scrollSensitivity))speed[0]=pointer[0]-(p[0]+this.options.scrollSensitivity);if(pointer[1]<(p[1]+this.options.scrollSensitivity))speed[1]=pointer[1]-(p[1]+this.options.scrollSensitivity);if(pointer[0]>(p[2]-this.options.scrollSensitivity))speed[0]=pointer[0]-(p[2]-this.options.scrollSensitivity);if(pointer[1]>(p[3]-this.options.scrollSensitivity))speed[1]=pointer[1]-(p[3]-this.options.scrollSensitivity);this.startScrolling(speed);}
+if(navigator.appVersion.indexOf('AppleWebKit')>0)window.scrollBy(0,0);Event.stop(event);},finishDrag:function(event,success){this.dragging=false;if(this.options.ghosting){Position.relativize(this.element);Element.remove(this._clone);this._clone=null;}
+if(success)Droppables.fire(event,this.element);Draggables.notify('onEnd',this,event);var revert=this.options.revert;if(revert&&typeof revert=='function')revert=revert(this.element);var d=this.currentDelta();if(revert&&this.options.reverteffect){this.options.reverteffect(this.element,d[1]-this.delta[1],d[0]-this.delta[0]);}else{this.delta=d;}
+if(this.options.zindex)
+this.element.style.zIndex=this.originalZ;if(this.options.endeffect)
+this.options.endeffect(this.element);Draggables.deactivate(this);Droppables.reset();},keyPress:function(event){if(event.keyCode!=Event.KEY_ESC)return;this.finishDrag(event,false);Event.stop(event);},endDrag:function(event){if(!this.dragging)return;this.stopScrolling();this.finishDrag(event,true);Event.stop(event);},draw:function(point){var pos=Position.cumulativeOffset(this.element);if(this.options.ghosting){var r=Position.realOffset(this.element);pos[0]+=r[0]-Position.deltaX;pos[1]+=r[1]-Position.deltaY;}
+var d=this.currentDelta();pos[0]-=d[0];pos[1]-=d[1];if(this.options.scroll&&(this.options.scroll!=window&&this._isScrollChild)){pos[0]-=this.options.scroll.scrollLeft-this.originalScrollLeft;pos[1]-=this.options.scroll.scrollTop-this.originalScrollTop;}
+var p=[0,1].map(function(i){return(point[i]-pos[i]-this.offset[i])}.bind(this));if(this.options.snap){if(typeof this.options.snap=='function'){p=this.options.snap(p[0],p[1],this);}else{if(this.options.snap instanceof Array){p=p.map(function(v,i){return Math.round(v/this.options.snap[i])*this.options.snap[i]}.bind(this))}else{p=p.map(function(v){return Math.round(v/this.options.snap)*this.options.snap}.bind(this))}}}
+var style=this.element.style;if((!this.options.constraint)||(this.options.constraint=='horizontal'))
+style.left=p[0]+"px";if((!this.options.constraint)||(this.options.constraint=='vertical'))
+style.top=p[1]+"px";if(style.visibility=="hidden")style.visibility="";},stopScrolling:function(){if(this.scrollInterval){clearInterval(this.scrollInterval);this.scrollInterval=null;Draggables._lastScrollPointer=null;}},startScrolling:function(speed){if(!(speed[0]||speed[1]))return;this.scrollSpeed=[speed[0]*this.options.scrollSpeed,speed[1]*this.options.scrollSpeed];this.lastScrolled=new Date();this.scrollInterval=setInterval(this.scroll.bind(this),10);},scroll:function(){var current=new Date();var delta=current-this.lastScrolled;this.lastScrolled=current;if(this.options.scroll==window){with(this._getWindowScroll(this.options.scroll)){if(this.scrollSpeed[0]||this.scrollSpeed[1]){var d=delta/1000;this.options.scroll.scrollTo(left+d*this.scrollSpeed[0],top+d*this.scrollSpeed[1]);}}}else{this.options.scroll.scrollLeft+=this.scrollSpeed[0]*delta/1000;this.options.scroll.scrollTop+=this.scrollSpeed[1]*delta/1000;}
+Position.prepare();Droppables.show(Draggables._lastPointer,this.element);Draggables.notify('onDrag',this);if(this._isScrollChild){Draggables._lastScrollPointer=Draggables._lastScrollPointer||$A(Draggables._lastPointer);Draggables._lastScrollPointer[0]+=this.scrollSpeed[0]*delta/1000;Draggables._lastScrollPointer[1]+=this.scrollSpeed[1]*delta/1000;if(Draggables._lastScrollPointer[0]<0)
+Draggables._lastScrollPointer[0]=0;if(Draggables._lastScrollPointer[1]<0)
+Draggables._lastScrollPointer[1]=0;this.draw(Draggables._lastScrollPointer);}
+if(this.options.change)this.options.change(this);},_getWindowScroll:function(w){var T,L,W,H;with(w.document){if(w.document.documentElement&&documentElement.scrollTop){T=documentElement.scrollTop;L=documentElement.scrollLeft;}else if(w.document.body){T=body.scrollTop;L=body.scrollLeft;}
+if(w.innerWidth){W=w.innerWidth;H=w.innerHeight;}else if(w.document.documentElement&&documentElement.clientWidth){W=documentElement.clientWidth;H=documentElement.clientHeight;}else{W=body.offsetWidth;H=body.offsetHeight}}
+return{top:T,left:L,width:W,height:H};}}
+var SortableObserver=Class.create();SortableObserver.prototype={initialize:function(element,observer){this.element=$(element);this.observer=observer;this.lastValue=Sortable.serialize(this.element);},onStart:function(){this.lastValue=Sortable.serialize(this.element);},onEnd:function(){Sortable.unmark();if(this.lastValue!=Sortable.serialize(this.element))
+this.observer(this.element)}}
+var Sortable={SERIALIZE_RULE:/^[^_\-](?:[A-Za-z0-9\-\_]*)[_](.*)$/,sortables:{},_findRootElement:function(element){while(element.tagName.toUpperCase()!="BODY"){if(element.id&&Sortable.sortables[element.id])return element;element=element.parentNode;}},options:function(element){element=Sortable._findRootElement($(element));if(!element)return;return Sortable.sortables[element.id];},destroy:function(element){var s=Sortable.options(element);if(s){Draggables.removeObserver(s.element);s.droppables.each(function(d){Droppables.remove(d)});s.draggables.invoke('destroy');delete Sortable.sortables[s.element.id];}},create:function(element){element=$(element);var options=Object.extend({element:element,tag:'li',dropOnEmpty:false,tree:false,treeTag:'ul',overlap:'vertical',constraint:'vertical',containment:element,handle:false,only:false,delay:0,hoverclass:null,ghosting:false,scroll:false,scrollSensitivity:20,scrollSpeed:15,format:this.SERIALIZE_RULE,onChange:Prototype.emptyFunction,onUpdate:Prototype.emptyFunction},arguments[1]||{});this.destroy(element);var options_for_draggable={revert:true,scroll:options.scroll,scrollSpeed:options.scrollSpeed,scrollSensitivity:options.scrollSensitivity,delay:options.delay,ghosting:options.ghosting,constraint:options.constraint,handle:options.handle};if(options.starteffect)
+options_for_draggable.starteffect=options.starteffect;if(options.reverteffect)
+options_for_draggable.reverteffect=options.reverteffect;else
+if(options.ghosting)options_for_draggable.reverteffect=function(element){element.style.top=0;element.style.left=0;};if(options.endeffect)
+options_for_draggable.endeffect=options.endeffect;if(options.zindex)
+options_for_draggable.zindex=options.zindex;var options_for_droppable={overlap:options.overlap,containment:options.containment,tree:options.tree,hoverclass:options.hoverclass,onHover:Sortable.onHover}
+var options_for_tree={onHover:Sortable.onEmptyHover,overlap:options.overlap,containment:options.containment,hoverclass:options.hoverclass}
+Element.cleanWhitespace(element);options.draggables=[];options.droppables=[];if(options.dropOnEmpty||options.tree){Droppables.add(element,options_for_tree);options.droppables.push(element);}
+(this.findElements(element,options)||[]).each(function(e){var handle=options.handle?$(e).down('.'+options.handle,0):e;options.draggables.push(new Draggable(e,Object.extend(options_for_draggable,{handle:handle})));Droppables.add(e,options_for_droppable);if(options.tree)e.treeNode=element;options.droppables.push(e);});if(options.tree){(Sortable.findTreeElements(element,options)||[]).each(function(e){Droppables.add(e,options_for_tree);e.treeNode=element;options.droppables.push(e);});}
+this.sortables[element.id]=options;Draggables.addObserver(new SortableObserver(element,options.onUpdate));},findElements:function(element,options){return Element.findChildren(element,options.only,options.tree?true:false,options.tag);},findTreeElements:function(element,options){return Element.findChildren(element,options.only,options.tree?true:false,options.treeTag);},onHover:function(element,dropon,overlap){if(Element.isParent(dropon,element))return;if(overlap>.33&&overlap<.66&&Sortable.options(dropon).tree){return;}else if(overlap>0.5){Sortable.mark(dropon,'before');if(dropon.previousSibling!=element){var oldParentNode=element.parentNode;element.style.visibility="hidden";dropon.parentNode.insertBefore(element,dropon);if(dropon.parentNode!=oldParentNode)
+Sortable.options(oldParentNode).onChange(element);Sortable.options(dropon.parentNode).onChange(element);}}else{Sortable.mark(dropon,'after');var nextElement=dropon.nextSibling||null;if(nextElement!=element){var oldParentNode=element.parentNode;element.style.visibility="hidden";dropon.parentNode.insertBefore(element,nextElement);if(dropon.parentNode!=oldParentNode)
+Sortable.options(oldParentNode).onChange(element);Sortable.options(dropon.parentNode).onChange(element);}}},onEmptyHover:function(element,dropon,overlap){var oldParentNode=element.parentNode;var droponOptions=Sortable.options(dropon);if(!Element.isParent(dropon,element)){var index;var children=Sortable.findElements(dropon,{tag:droponOptions.tag,only:droponOptions.only});var child=null;if(children){var offset=Element.offsetSize(dropon,droponOptions.overlap)*(1.0-overlap);for(index=0;index<children.length;index+=1){if(offset-Element.offsetSize(children[index],droponOptions.overlap)>=0){offset-=Element.offsetSize(children[index],droponOptions.overlap);}else if(offset-(Element.offsetSize(children[index],droponOptions.overlap)/2)>=0){child=index+1<children.length?children[index+1]:null;break;}else{child=children[index];break;}}}
+dropon.insertBefore(element,child);Sortable.options(oldParentNode).onChange(element);droponOptions.onChange(element);}},unmark:function(){if(Sortable._marker)Sortable._marker.hide();},mark:function(dropon,position){var sortable=Sortable.options(dropon.parentNode);if(sortable&&!sortable.ghosting)return;if(!Sortable._marker){Sortable._marker=($('dropmarker')||Element.extend(document.createElement('DIV'))).hide().addClassName('dropmarker').setStyle({position:'absolute'});document.getElementsByTagName("body").item(0).appendChild(Sortable._marker);}
+var offsets=Position.cumulativeOffset(dropon);Sortable._marker.setStyle({left:offsets[0]+'px',top:offsets[1]+'px'});if(position=='after')
+if(sortable.overlap=='horizontal')
+Sortable._marker.setStyle({left:(offsets[0]+dropon.clientWidth)+'px'});else
+Sortable._marker.setStyle({top:(offsets[1]+dropon.clientHeight)+'px'});Sortable._marker.show();},_tree:function(element,options,parent){var children=Sortable.findElements(element,options)||[];for(var i=0;i<children.length;++i){var match=children[i].id.match(options.format);if(!match)continue;var child={id:encodeURIComponent(match?match[1]:null),element:element,parent:parent,children:[],position:parent.children.length,container:$(children[i]).down(options.treeTag)}
+if(child.container)
+this._tree(child.container,options,child)
+parent.children.push(child);}
+return parent;},tree:function(element){element=$(element);var sortableOptions=this.options(element);var options=Object.extend({tag:sortableOptions.tag,treeTag:sortableOptions.treeTag,only:sortableOptions.only,name:element.id,format:sortableOptions.format},arguments[1]||{});var root={id:null,parent:null,children:[],container:element,position:0}
+return Sortable._tree(element,options,root);},_constructIndex:function(node){var index='';do{if(node.id)index='['+node.position+']'+index;}while((node=node.parent)!=null);return index;},sequence:function(element){element=$(element);var options=Object.extend(this.options(element),arguments[1]||{});return $(this.findElements(element,options)||[]).map(function(item){return item.id.match(options.format)?item.id.match(options.format)[1]:'';});},setSequence:function(element,new_sequence){element=$(element);var options=Object.extend(this.options(element),arguments[2]||{});var nodeMap={};this.findElements(element,options).each(function(n){if(n.id.match(options.format))
+nodeMap[n.id.match(options.format)[1]]=[n,n.parentNode];n.parentNode.removeChild(n);});new_sequence.each(function(ident){var n=nodeMap[ident];if(n){n[1].appendChild(n[0]);delete nodeMap[ident];}});},serialize:function(element){element=$(element);var options=Object.extend(Sortable.options(element),arguments[1]||{});var name=encodeURIComponent((arguments[1]&&arguments[1].name)?arguments[1].name:element.id);if(options.tree){return Sortable.tree(element,arguments[1]).children.map(function(item){return[name+Sortable._constructIndex(item)+"[id]="+
+encodeURIComponent(item.id)].concat(item.children.map(arguments.callee));}).flatten().join('&');}else{return Sortable.sequence(element,arguments[1]).map(function(item){return name+"[]="+encodeURIComponent(item);}).join('&');}}}
+Element.isParent=function(child,element){if(!child.parentNode||child==element)return false;if(child.parentNode==element)return true;return Element.isParent(child.parentNode,element);}
+Element.findChildren=function(element,only,recursive,tagName){if(!element.hasChildNodes())return null;tagName=tagName.toUpperCase();if(only)only=[only].flatten();var elements=[];$A(element.childNodes).each(function(e){if(e.tagName&&e.tagName.toUpperCase()==tagName&&(!only||(Element.classNames(e).detect(function(v){return only.include(v)}))))
+elements.push(e);if(recursive){var grandchildren=Element.findChildren(e,only,recursive,tagName);if(grandchildren)elements.push(grandchildren);}});return(elements.length>0?elements.flatten():[]);}
+Element.offsetSize=function(element,type){return element['offset'+((type=='vertical'||type=='height')?'Height':'Width')];}
+if(typeof Effect=='undefined')
+throw("controls.js requires including script.aculo.us' effects.js library");var Autocompleter={}
+Autocompleter.Base=function(){};Autocompleter.Base.prototype={baseInitialize:function(element,update,options){this.element=$(element);this.update=$(update);this.hasFocus=false;this.changed=false;this.active=false;this.index=0;this.entryCount=0;if(this.setOptions)
+this.setOptions(options);else
+this.options=options||{};this.options.paramName=this.options.paramName||this.element.name;this.options.tokens=this.options.tokens||[];this.options.frequency=this.options.frequency||0.4;this.options.minChars=this.options.minChars||1;this.options.onShow=this.options.onShow||function(element,update){if(!update.style.position||update.style.position=='absolute'){update.style.position='absolute';Position.clone(element,update,{setHeight:false,offsetTop:element.offsetHeight});}
+Effect.Appear(update,{duration:0.15});};this.options.onHide=this.options.onHide||function(element,update){new Effect.Fade(update,{duration:0.15})};if(typeof(this.options.tokens)=='string')
+this.options.tokens=new Array(this.options.tokens);this.observer=null;this.element.setAttribute('autocomplete','off');Element.hide(this.update);Event.observe(this.element,"blur",this.onBlur.bindAsEventListener(this));Event.observe(this.element,"keypress",this.onKeyPress.bindAsEventListener(this));},show:function(){if(Element.getStyle(this.update,'display')=='none')this.options.onShow(this.element,this.update);if(!this.iefix&&(navigator.appVersion.indexOf('MSIE')>0)&&(navigator.userAgent.indexOf('Opera')<0)&&(Element.getStyle(this.update,'position')=='absolute')){new Insertion.After(this.update,'<iframe id="'+this.update.id+'_iefix" '+'style="display:none;position:absolute;filter:progid:DXImageTransform.Microsoft.Alpha(opacity=0);" '+'src="javascript:false;" frameborder="0" scrolling="no"></iframe>');this.iefix=$(this.update.id+'_iefix');}
+if(this.iefix)setTimeout(this.fixIEOverlapping.bind(this),50);},fixIEOverlapping:function(){Position.clone(this.update,this.iefix,{setTop:(!this.update.style.height)});this.iefix.style.zIndex=1;this.update.style.zIndex=2;Element.show(this.iefix);},hide:function(){this.stopIndicator();if(Element.getStyle(this.update,'display')!='none')this.options.onHide(this.element,this.update);if(this.iefix)Element.hide(this.iefix);},startIndicator:function(){if(this.options.indicator)Element.show(this.options.indicator);},stopIndicator:function(){if(this.options.indicator)Element.hide(this.options.indicator);},onKeyPress:function(event){if(this.active)
+switch(event.keyCode){case Event.KEY_TAB:case Event.KEY_RETURN:this.selectEntry();Event.stop(event);case Event.KEY_ESC:this.hide();this.active=false;Event.stop(event);return;case Event.KEY_LEFT:case Event.KEY_RIGHT:return;case Event.KEY_UP:this.markPrevious();this.render();if(navigator.appVersion.indexOf('AppleWebKit')>0)Event.stop(event);return;case Event.KEY_DOWN:this.markNext();this.render();if(navigator.appVersion.indexOf('AppleWebKit')>0)Event.stop(event);return;}
+else
+if(event.keyCode==Event.KEY_TAB||event.keyCode==Event.KEY_RETURN||(navigator.appVersion.indexOf('AppleWebKit')>0&&event.keyCode==0))return;this.changed=true;this.hasFocus=true;if(this.observer)clearTimeout(this.observer);this.observer=setTimeout(this.onObserverEvent.bind(this),this.options.frequency*1000);},activate:function(){this.changed=false;this.hasFocus=true;this.getUpdatedChoices();},onHover:function(event){var element=Event.findElement(event,'LI');if(this.index!=element.autocompleteIndex)
+{this.index=element.autocompleteIndex;this.render();}
+Event.stop(event);},onClick:function(event){var element=Event.findElement(event,'LI');this.index=element.autocompleteIndex;this.selectEntry();this.hide();},onBlur:function(event){setTimeout(this.hide.bind(this),250);this.hasFocus=false;this.active=false;},render:function(){if(this.entryCount>0){for(var i=0;i<this.entryCount;i++)
+this.index==i?Element.addClassName(this.getEntry(i),"selected"):Element.removeClassName(this.getEntry(i),"selected");if(this.hasFocus){this.show();this.active=true;}}else{this.active=false;this.hide();}},markPrevious:function(){if(this.index>0)this.index--
+else this.index=this.entryCount-1;this.getEntry(this.index).scrollIntoView(true);},markNext:function(){if(this.index<this.entryCount-1)this.index++
+else this.index=0;this.getEntry(this.index).scrollIntoView(false);},getEntry:function(index){return this.update.firstChild.childNodes[index];},getCurrentEntry:function(){return this.getEntry(this.index);},selectEntry:function(){this.active=false;this.updateElement(this.getCurrentEntry());},updateElement:function(selectedElement){if(this.options.updateElement){this.options.updateElement(selectedElement);return;}
+var value='';if(this.options.select){var nodes=document.getElementsByClassName(this.options.select,selectedElement)||[];if(nodes.length>0)value=Element.collectTextNodes(nodes[0],this.options.select);}else
+value=Element.collectTextNodesIgnoreClass(selectedElement,'informal');var lastTokenPos=this.findLastToken();if(lastTokenPos!=-1){var newValue=this.element.value.substr(0,lastTokenPos+1);var whitespace=this.element.value.substr(lastTokenPos+1).match(/^\s+/);if(whitespace)
+newValue+=whitespace[0];this.element.value=newValue+value;}else{this.element.value=value;}
+this.element.focus();if(this.options.afterUpdateElement)
+this.options.afterUpdateElement(this.element,selectedElement);},updateChoices:function(choices){if(!this.changed&&this.hasFocus){this.update.innerHTML=choices;Element.cleanWhitespace(this.update);Element.cleanWhitespace(this.update.down());if(this.update.firstChild&&this.update.down().childNodes){this.entryCount=this.update.down().childNodes.length;for(var i=0;i<this.entryCount;i++){var entry=this.getEntry(i);entry.autocompleteIndex=i;this.addObservers(entry);}}else{this.entryCount=0;}
+this.stopIndicator();this.index=0;if(this.entryCount==1&&this.options.autoSelect){this.selectEntry();this.hide();}else{this.render();}}},addObservers:function(element){Event.observe(element,"mouseover",this.onHover.bindAsEventListener(this));Event.observe(element,"click",this.onClick.bindAsEventListener(this));},onObserverEvent:function(){this.changed=false;if(this.getToken().length>=this.options.minChars){this.startIndicator();this.getUpdatedChoices();}else{this.active=false;this.hide();}},getToken:function(){var tokenPos=this.findLastToken();if(tokenPos!=-1)
+var ret=this.element.value.substr(tokenPos+1).replace(/^\s+/,'').replace(/\s+$/,'');else
+var ret=this.element.value;return/\n/.test(ret)?'':ret;},findLastToken:function(){var lastTokenPos=-1;for(var i=0;i<this.options.tokens.length;i++){var thisTokenPos=this.element.value.lastIndexOf(this.options.tokens[i]);if(thisTokenPos>lastTokenPos)
+lastTokenPos=thisTokenPos;}
+return lastTokenPos;}}
+Ajax.Autocompleter=Class.create();Object.extend(Object.extend(Ajax.Autocompleter.prototype,Autocompleter.Base.prototype),{initialize:function(element,update,url,options){this.baseInitialize(element,update,options);this.options.asynchronous=true;this.options.onComplete=this.onComplete.bind(this);this.options.defaultParams=this.options.parameters||null;this.url=url;},getUpdatedChoices:function(){entry=encodeURIComponent(this.options.paramName)+'='+
+encodeURIComponent(this.getToken());this.options.parameters=this.options.callback?this.options.callback(this.element,entry):entry;if(this.options.defaultParams)
+this.options.parameters+='&'+this.options.defaultParams;new Ajax.Request(this.url,this.options);},onComplete:function(request){this.updateChoices(request.responseText);}});Autocompleter.Local=Class.create();Autocompleter.Local.prototype=Object.extend(new Autocompleter.Base(),{initialize:function(element,update,array,options){this.baseInitialize(element,update,options);this.options.array=array;},getUpdatedChoices:function(){this.updateChoices(this.options.selector(this));},setOptions:function(options){this.options=Object.extend({choices:10,partialSearch:true,partialChars:2,ignoreCase:true,fullSearch:false,selector:function(instance){var ret=[];var partial=[];var entry=instance.getToken();var count=0;for(var i=0;i<instance.options.array.length&&ret.length<instance.options.choices;i++){var elem=instance.options.array[i];var foundPos=instance.options.ignoreCase?elem.toLowerCase().indexOf(entry.toLowerCase()):elem.indexOf(entry);while(foundPos!=-1){if(foundPos==0&&elem.length!=entry.length){ret.push("<li><strong>"+elem.substr(0,entry.length)+"</strong>"+
+elem.substr(entry.length)+"</li>");break;}else if(entry.length>=instance.options.partialChars&&instance.options.partialSearch&&foundPos!=-1){if(instance.options.fullSearch||/\s/.test(elem.substr(foundPos-1,1))){partial.push("<li>"+elem.substr(0,foundPos)+"<strong>"+
+elem.substr(foundPos,entry.length)+"</strong>"+elem.substr(foundPos+entry.length)+"</li>");break;}}
+foundPos=instance.options.ignoreCase?elem.toLowerCase().indexOf(entry.toLowerCase(),foundPos+1):elem.indexOf(entry,foundPos+1);}}
+if(partial.length)
+ret=ret.concat(partial.slice(0,instance.options.choices-ret.length))
+return"<ul>"+ret.join('')+"</ul>";}},options||{});}});Field.scrollFreeActivate=function(field){setTimeout(function(){Field.activate(field);},1);}
+Ajax.InPlaceEditor=Class.create();Ajax.InPlaceEditor.defaultHighlightColor="#FFFF99";Ajax.InPlaceEditor.prototype={initialize:function(element,url,options){this.url=url;this.element=$(element);this.options=Object.extend({paramName:"value",okButton:true,okText:"ok",cancelLink:true,cancelText:"cancel",savingText:"Saving...",clickToEditText:"Click to edit",okText:"ok",rows:1,onComplete:function(transport,element){new Effect.Highlight(element,{startcolor:this.options.highlightcolor});},onFailure:function(transport){alert("Error communicating with the server: "+transport.responseText.stripTags());},callback:function(form){return Form.serialize(form);},handleLineBreaks:true,loadingText:'Loading...',savingClassName:'inplaceeditor-saving',loadingClassName:'inplaceeditor-loading',formClassName:'inplaceeditor-form',highlightcolor:Ajax.InPlaceEditor.defaultHighlightColor,highlightendcolor:"#FFFFFF",externalControl:null,submitOnBlur:false,ajaxOptions:{},evalScripts:false},options||{});if(!this.options.formId&&this.element.id){this.options.formId=this.element.id+"-inplaceeditor";if($(this.options.formId)){this.options.formId=null;}}
+if(this.options.externalControl){this.options.externalControl=$(this.options.externalControl);}
+this.originalBackground=Element.getStyle(this.element,'background-color');if(!this.originalBackground){this.originalBackground="transparent";}
+this.element.title=this.options.clickToEditText;this.onclickListener=this.enterEditMode.bindAsEventListener(this);this.mouseoverListener=this.enterHover.bindAsEventListener(this);this.mouseoutListener=this.leaveHover.bindAsEventListener(this);Event.observe(this.element,'click',this.onclickListener);Event.observe(this.element,'mouseover',this.mouseoverListener);Event.observe(this.element,'mouseout',this.mouseoutListener);if(this.options.externalControl){Event.observe(this.options.externalControl,'click',this.onclickListener);Event.observe(this.options.externalControl,'mouseover',this.mouseoverListener);Event.observe(this.options.externalControl,'mouseout',this.mouseoutListener);}},enterEditMode:function(evt){if(this.saving)return;if(this.editing)return;this.editing=true;this.onEnterEditMode();if(this.options.externalControl){Element.hide(this.options.externalControl);}
+Element.hide(this.element);this.createForm();this.element.parentNode.insertBefore(this.form,this.element);if(!this.options.loadTextURL)Field.scrollFreeActivate(this.editField);if(evt){Event.stop(evt);}
+return false;},createForm:function(){this.form=document.createElement("form");this.form.id=this.options.formId;Element.addClassName(this.form,this.options.formClassName)
+this.form.onsubmit=this.onSubmit.bind(this);this.createEditField();if(this.options.textarea){var br=document.createElement("br");this.form.appendChild(br);}
+if(this.options.okButton){okButton=document.createElement("input");okButton.type="submit";okButton.value=this.options.okText;okButton.className='editor_ok_button';this.form.appendChild(okButton);}
+if(this.options.cancelLink){cancelLink=document.createElement("a");cancelLink.href="javascript:void(0)";cancelLink.appendChild(document.createTextNode(this.options.cancelText));cancelLink.onclick=this.onclickCancel.bind(this);cancelLink.className='editor_cancel';this.form.appendChild(cancelLink);}},hasHTMLLineBreaks:function(string){if(!this.options.handleLineBreaks)return false;return string.match(/<br/i)||string.match(/<p>/i);},convertHTMLLineBreaks:function(string){return string.replace(/<br>/gi,"\n").replace(/<br\/>/gi,"\n").replace(/<\/p>/gi,"\n").replace(/<p>/gi,"");},createEditField:function(){var text;if(this.options.loadTextURL){text=this.options.loadingText;}else{text=this.getText();}
+var obj=this;if(this.options.rows==1&&!this.hasHTMLLineBreaks(text)){this.options.textarea=false;var textField=document.createElement("input");textField.obj=this;textField.type="text";textField.name=this.options.paramName;textField.value=text;textField.style.backgroundColor=this.options.highlightcolor;textField.className='editor_field';var size=this.options.size||this.options.cols||0;if(size!=0)textField.size=size;if(this.options.submitOnBlur)
+textField.onblur=this.onSubmit.bind(this);this.editField=textField;}else{this.options.textarea=true;var textArea=document.createElement("textarea");textArea.obj=this;textArea.name=this.options.paramName;textArea.value=this.convertHTMLLineBreaks(text);textArea.rows=this.options.rows;textArea.cols=this.options.cols||40;textArea.className='editor_field';if(this.options.submitOnBlur)
+textArea.onblur=this.onSubmit.bind(this);this.editField=textArea;}
+if(this.options.loadTextURL){this.loadExternalText();}
+this.form.appendChild(this.editField);},getText:function(){return this.element.innerHTML;},loadExternalText:function(){Element.addClassName(this.form,this.options.loadingClassName);this.editField.disabled=true;new Ajax.Request(this.options.loadTextURL,Object.extend({asynchronous:true,onComplete:this.onLoadedExternalText.bind(this)},this.options.ajaxOptions));},onLoadedExternalText:function(transport){Element.removeClassName(this.form,this.options.loadingClassName);this.editField.disabled=false;this.editField.value=transport.responseText.stripTags();Field.scrollFreeActivate(this.editField);},onclickCancel:function(){this.onComplete();this.leaveEditMode();return false;},onFailure:function(transport){this.options.onFailure(transport);if(this.oldInnerHTML){this.element.innerHTML=this.oldInnerHTML;this.oldInnerHTML=null;}
+return false;},onSubmit:function(){var form=this.form;var value=this.editField.value;this.onLoading();if(this.options.evalScripts){new Ajax.Request(this.url,Object.extend({parameters:this.options.callback(form,value),onComplete:this.onComplete.bind(this),onFailure:this.onFailure.bind(this),asynchronous:true,evalScripts:true},this.options.ajaxOptions));}else{new Ajax.Updater({success:this.element,failure:null},this.url,Object.extend({parameters:this.options.callback(form,value),onComplete:this.onComplete.bind(this),onFailure:this.onFailure.bind(this)},this.options.ajaxOptions));}
+if(arguments.length>1){Event.stop(arguments[0]);}
+return false;},onLoading:function(){this.saving=true;this.removeForm();this.leaveHover();this.showSaving();},showSaving:function(){this.oldInnerHTML=this.element.innerHTML;this.element.innerHTML=this.options.savingText;Element.addClassName(this.element,this.options.savingClassName);this.element.style.backgroundColor=this.originalBackground;Element.show(this.element);},removeForm:function(){if(this.form){if(this.form.parentNode)Element.remove(this.form);this.form=null;}},enterHover:function(){if(this.saving)return;this.element.style.backgroundColor=this.options.highlightcolor;if(this.effect){this.effect.cancel();}
+Element.addClassName(this.element,this.options.hoverClassName)},leaveHover:function(){if(this.options.backgroundColor){this.element.style.backgroundColor=this.oldBackground;}
+Element.removeClassName(this.element,this.options.hoverClassName)
+if(this.saving)return;this.effect=new Effect.Highlight(this.element,{startcolor:this.options.highlightcolor,endcolor:this.options.highlightendcolor,restorecolor:this.originalBackground});},leaveEditMode:function(){Element.removeClassName(this.element,this.options.savingClassName);this.removeForm();this.leaveHover();this.element.style.backgroundColor=this.originalBackground;Element.show(this.element);if(this.options.externalControl){Element.show(this.options.externalControl);}
+this.editing=false;this.saving=false;this.oldInnerHTML=null;this.onLeaveEditMode();},onComplete:function(transport){this.leaveEditMode();this.options.onComplete.bind(this)(transport,this.element);},onEnterEditMode:function(){},onLeaveEditMode:function(){},dispose:function(){if(this.oldInnerHTML){this.element.innerHTML=this.oldInnerHTML;}
+this.leaveEditMode();Event.stopObserving(this.element,'click',this.onclickListener);Event.stopObserving(this.element,'mouseover',this.mouseoverListener);Event.stopObserving(this.element,'mouseout',this.mouseoutListener);if(this.options.externalControl){Event.stopObserving(this.options.externalControl,'click',this.onclickListener);Event.stopObserving(this.options.externalControl,'mouseover',this.mouseoverListener);Event.stopObserving(this.options.externalControl,'mouseout',this.mouseoutListener);}}};Ajax.InPlaceCollectionEditor=Class.create();Object.extend(Ajax.InPlaceCollectionEditor.prototype,Ajax.InPlaceEditor.prototype);Object.extend(Ajax.InPlaceCollectionEditor.prototype,{createEditField:function(){if(!this.cached_selectTag){var selectTag=document.createElement("select");var collection=this.options.collection||[];var optionTag;collection.each(function(e,i){optionTag=document.createElement("option");optionTag.value=(e instanceof Array)?e[0]:e;if((typeof this.options.value=='undefined')&&((e instanceof Array)?this.element.innerHTML==e[1]:e==optionTag.value))optionTag.selected=true;if(this.options.value==optionTag.value)optionTag.selected=true;optionTag.appendChild(document.createTextNode((e instanceof Array)?e[1]:e));selectTag.appendChild(optionTag);}.bind(this));this.cached_selectTag=selectTag;}
+this.editField=this.cached_selectTag;if(this.options.loadTextURL)this.loadExternalText();this.form.appendChild(this.editField);this.options.callback=function(form,value){return"value="+encodeURIComponent(value);}}});Form.Element.DelayedObserver=Class.create();Form.Element.DelayedObserver.prototype={initialize:function(element,delay,callback){this.delay=delay||0.5;this.element=$(element);this.callback=callback;this.timer=null;this.lastValue=$F(this.element);Event.observe(this.element,'keyup',this.delayedListener.bindAsEventListener(this));},delayedListener:function(event){if(this.lastValue==$F(this.element))return;if(this.timer)clearTimeout(this.timer);this.timer=setTimeout(this.onTimerEvent.bind(this),this.delay*1000);this.lastValue=$F(this.element);},onTimerEvent:function(){this.timer=null;this.callback(this.element,$F(this.element));}};if(!Control)var Control={};Control.Slider=Class.create();Control.Slider.prototype={initialize:function(handle,track,options){var slider=this;if(handle instanceof Array){this.handles=handle.collect(function(e){return $(e)});}else{this.handles=[$(handle)];}
+this.track=$(track);this.options=options||{};this.axis=this.options.axis||'horizontal';this.increment=this.options.increment||1;this.step=parseInt(this.options.step||'1');this.range=this.options.range||$R(0,1);this.value=0;this.values=this.handles.map(function(){return 0});this.spans=this.options.spans?this.options.spans.map(function(s){return $(s)}):false;this.options.startSpan=$(this.options.startSpan||null);this.options.endSpan=$(this.options.endSpan||null);this.restricted=this.options.restricted||false;this.maximum=this.options.maximum||this.range.end;this.minimum=this.options.minimum||this.range.start;this.alignX=parseInt(this.options.alignX||'0');this.alignY=parseInt(this.options.alignY||'0');this.trackLength=this.maximumOffset()-this.minimumOffset();this.handleLength=this.isVertical()?(this.handles[0].offsetHeight!=0?this.handles[0].offsetHeight:this.handles[0].style.height.replace(/px$/,"")):(this.handles[0].offsetWidth!=0?this.handles[0].offsetWidth:this.handles[0].style.width.replace(/px$/,""));this.active=false;this.dragging=false;this.disabled=false;if(this.options.disabled)this.setDisabled();this.allowedValues=this.options.values?this.options.values.sortBy(Prototype.K):false;if(this.allowedValues){this.minimum=this.allowedValues.min();this.maximum=this.allowedValues.max();}
+this.eventMouseDown=this.startDrag.bindAsEventListener(this);this.eventMouseUp=this.endDrag.bindAsEventListener(this);this.eventMouseMove=this.update.bindAsEventListener(this);this.handles.each(function(h,i){i=slider.handles.length-1-i;slider.setValue(parseFloat((slider.options.sliderValue instanceof Array?slider.options.sliderValue[i]:slider.options.sliderValue)||slider.range.start),i);Element.makePositioned(h);Event.observe(h,"mousedown",slider.eventMouseDown);});Event.observe(this.track,"mousedown",this.eventMouseDown);Event.observe(document,"mouseup",this.eventMouseUp);Event.observe(document,"mousemove",this.eventMouseMove);this.initialized=true;},dispose:function(){var slider=this;Event.stopObserving(this.track,"mousedown",this.eventMouseDown);Event.stopObserving(document,"mouseup",this.eventMouseUp);Event.stopObserving(document,"mousemove",this.eventMouseMove);this.handles.each(function(h){Event.stopObserving(h,"mousedown",slider.eventMouseDown);});},setDisabled:function(){this.disabled=true;},setEnabled:function(){this.disabled=false;},getNearestValue:function(value){if(this.allowedValues){if(value>=this.allowedValues.max())return(this.allowedValues.max());if(value<=this.allowedValues.min())return(this.allowedValues.min());var offset=Math.abs(this.allowedValues[0]-value);var newValue=this.allowedValues[0];this.allowedValues.each(function(v){var currentOffset=Math.abs(v-value);if(currentOffset<=offset){newValue=v;offset=currentOffset;}});return newValue;}
+if(value>this.range.end)return this.range.end;if(value<this.range.start)return this.range.start;return value;},setValue:function(sliderValue,handleIdx){if(!this.active){this.activeHandleIdx=handleIdx||0;this.activeHandle=this.handles[this.activeHandleIdx];this.updateStyles();}
+handleIdx=handleIdx||this.activeHandleIdx||0;if(this.initialized&&this.restricted){if((handleIdx>0)&&(sliderValue<this.values[handleIdx-1]))
+sliderValue=this.values[handleIdx-1];if((handleIdx<(this.handles.length-1))&&(sliderValue>this.values[handleIdx+1]))
+sliderValue=this.values[handleIdx+1];}
+sliderValue=this.getNearestValue(sliderValue);this.values[handleIdx]=sliderValue;this.value=this.values[0];this.handles[handleIdx].style[this.isVertical()?'top':'left']=this.translateToPx(sliderValue);this.drawSpans();if(!this.dragging||!this.event)this.updateFinished();},setValueBy:function(delta,handleIdx){this.setValue(this.values[handleIdx||this.activeHandleIdx||0]+delta,handleIdx||this.activeHandleIdx||0);},translateToPx:function(value){return Math.round(((this.trackLength-this.handleLength)/(this.range.end-this.range.start))*(value-this.range.start))+"px";},translateToValue:function(offset){return((offset/(this.trackLength-this.handleLength)*(this.range.end-this.range.start))+this.range.start);},getRange:function(range){var v=this.values.sortBy(Prototype.K);range=range||0;return $R(v[range],v[range+1]);},minimumOffset:function(){return(this.isVertical()?this.alignY:this.alignX);},maximumOffset:function(){return(this.isVertical()?(this.track.offsetHeight!=0?this.track.offsetHeight:this.track.style.height.replace(/px$/,""))-this.alignY:(this.track.offsetWidth!=0?this.track.offsetWidth:this.track.style.width.replace(/px$/,""))-this.alignY);},isVertical:function(){return(this.axis=='vertical');},drawSpans:function(){var slider=this;if(this.spans)
+$R(0,this.spans.length-1).each(function(r){slider.setSpan(slider.spans[r],slider.getRange(r))});if(this.options.startSpan)
+this.setSpan(this.options.startSpan,$R(0,this.values.length>1?this.getRange(0).min():this.value));if(this.options.endSpan)
+this.setSpan(this.options.endSpan,$R(this.values.length>1?this.getRange(this.spans.length-1).max():this.value,this.maximum));},setSpan:function(span,range){if(this.isVertical()){span.style.top=this.translateToPx(range.start);span.style.height=this.translateToPx(range.end-range.start+this.range.start);}else{span.style.left=this.translateToPx(range.start);span.style.width=this.translateToPx(range.end-range.start+this.range.start);}},updateStyles:function(){this.handles.each(function(h){Element.removeClassName(h,'selected')});Element.addClassName(this.activeHandle,'selected');},startDrag:function(event){if(Event.isLeftClick(event)){if(!this.disabled){this.active=true;var handle=Event.element(event);var pointer=[Event.pointerX(event),Event.pointerY(event)];var track=handle;if(track==this.track){var offsets=Position.cumulativeOffset(this.track);this.event=event;this.setValue(this.translateToValue((this.isVertical()?pointer[1]-offsets[1]:pointer[0]-offsets[0])-(this.handleLength/2)));var offsets=Position.cumulativeOffset(this.activeHandle);this.offsetX=(pointer[0]-offsets[0]);this.offsetY=(pointer[1]-offsets[1]);}else{while((this.handles.indexOf(handle)==-1)&&handle.parentNode)
+handle=handle.parentNode;if(this.handles.indexOf(handle)!=-1){this.activeHandle=handle;this.activeHandleIdx=this.handles.indexOf(this.activeHandle);this.updateStyles();var offsets=Position.cumulativeOffset(this.activeHandle);this.offsetX=(pointer[0]-offsets[0]);this.offsetY=(pointer[1]-offsets[1]);}}}
+Event.stop(event);}},update:function(event){if(this.active){if(!this.dragging)this.dragging=true;this.draw(event);if(navigator.appVersion.indexOf('AppleWebKit')>0)window.scrollBy(0,0);Event.stop(event);}},draw:function(event){var pointer=[Event.pointerX(event),Event.pointerY(event)];var offsets=Position.cumulativeOffset(this.track);pointer[0]-=this.offsetX+offsets[0];pointer[1]-=this.offsetY+offsets[1];this.event=event;this.setValue(this.translateToValue(this.isVertical()?pointer[1]:pointer[0]));if(this.initialized&&this.options.onSlide)
+this.options.onSlide(this.values.length>1?this.values:this.value,this);},endDrag:function(event){if(this.active&&this.dragging){this.finishDrag(event,true);Event.stop(event);}
+this.active=false;this.dragging=false;},finishDrag:function(event,success){this.active=false;this.dragging=false;this.updateFinished();},updateFinished:function(){if(this.initialized&&this.options.onChange)
+this.options.onChange(this.values.length>1?this.values:this.value,this);this.event=null;}};if(!("console"in window)||!("firebug"in console)){var names=["log","debug","info","warn","error","assert","dir","dirxml","group","groupEnd","time","timeEnd","count","trace","profile","profileEnd"];window.console={};for(var i=0;i<names.length;++i){window.console[names[i]]=function(){};}}
+var ua=navigator.userAgent.toLowerCase();var isIE=ua.indexOf("msie")>-1,isIE7=ua.indexOf("msie 7")>-1;if(isIE&&!isIE7){try{document.execCommand("BackgroundImageCache",false,true);}catch(e){}}
+if(typeof Jx=='undefined'){var Jx={};Jx.COMBINED_CSS=true;var aScripts=document.getElementsByTagName('SCRIPT');for(var i=0;i<aScripts.length;i++){var s=aScripts[i].src;var n=s.indexOf('lib/jx');if(n!=-1){Jx.baseURL=s.substring(0,n);break;}}}
+Jx.importRules={};Jx.importRulesIE={};Jx.addStyleSheet=function(styleSheet,ieOnly){if(ieOnly){this.importRulesIE[styleSheet]=styleSheet;}else{this.importRules[styleSheet]=styleSheet;}};Jx.addStyleSheet('reset.css');Jx.applyPNGFilter=function(o){var t=Jx.baseURL+"images/a_pixel.png";if(o.src!=t){var s=o.src;o.src=t;o.runtimeStyle.filter="progid:DXImageTransform.Microsoft.AlphaImageLoader(src='"+s+"',sizingMethod='scale')";}};Jx.imgQueue=[];Jx.imgLoaded={};Jx.imagesLoading=0;Jx.addToImgQueue=function(obj){if(Jx.imgLoaded[obj.src]){obj.domElement.src=obj.src;}else{Jx.imgQueue.push(obj);Jx.imgLoaded[obj.src]=true;}
+Jx.checkImgQueue();};Jx.checkImgQueue=function(){while(Jx.imagesLoading<2&&Jx.imgQueue.length>0){Jx.loadNextImg();}};Jx.loadNextImg=function(){var obj=Jx.imgQueue.shift();if(obj){++Jx.imagesLoading;obj.domElement.onload=function(){--Jx.imagesLoading;Jx.checkImgQueue();};obj.domElement.onerror=function(){--Jx.imagesLoading;Jx.checkImgQueue();};obj.domElement.src=obj.src;}};Jx.Listener=Class.create();Jx.Listener.prototype={addListener:function(list,obj){list.push(obj);},removeListener:function(list,obj){for(var i=0;i<list.length;i++){if(list[i]==obj){list.splice(i,1);break;}}},processEvent:function(list,fnName,obj){list.each(function(o){if(o[fnName]){o[fnName](obj);}});}};Jx.UniqueId=Class.create();Jx.UniqueId.prototype={uniqueIdRefs:null,initUniqueId:function(){this.uniqueIdRefs=[];},deregisterIds:function(){this.uniqueIdRefs.length=0;},registerIds:function(aIds,domObj){if(aIds.indexOf(domObj.id)!=-1){this.uniqueIdRefs[domObj.id]=domObj;}
+for(var i=0;i<domObj.childNodes.length;i++){this.registerIds(aIds,domObj.childNodes[i]);}},getObj:function(id){return this.uniqueIdRefs[id]||null;}};Jx.Action=Class.create();Jx.Action.prototype={pcl:null,enabled:null,initialize:function(f){this.pcl=[];this.enabled=true;this.actionPerformed=f;},addPropertyChangeListener:function(obj){this.addListener(this.pcl,obj);},removePropertyChangeListener:function(obj){this.removeListener(this.pcl,obj);},isEnabled:function(){return this.enabled;},setEnabled:function(b){if(this.enabled==b){return;}
+this.enabled=b;this.processEvent(this.pcl,'propertyChanged',this);},bindTo:function(item){this.addPropertyChangeListener(item);item.addActionListener(this);},unbindFrom:function(item){this.removePropertyChangeListener(item);item.removeActionListener(this);},actionPerformed:function(obj){alert('actionPerformed');}};Object.extend(Jx.Action.prototype,Jx.Listener.prototype);Object.extend(Element,{getBoxSizing:function(elem){var result='content-box';elem=$(elem);if(elem.currentStyle||window.opera){var cm=document["compatMode"];if(cm=="BackCompat"||cm=="QuirksMode"){result='border-box';}else{result='content-box';}}else{if(arguments.length==0){node=document.documentElement;}
+var sizing=Element.getStyle(elem,"-moz-box-sizing");if(!sizing){sizing=Element.getStyle(elem,"box-sizing");}
+result=(sizing?sizing:'content-box');}
+return result;},getContentBoxSize:function(elem){elem=$(elem);Element.toggleMeasurable(elem);var w=elem.offsetWidth;var h=elem.offsetHeight;var padding=Element.getPaddingSize(elem);var border=Element.getBorderSize(elem);Element.toggleMeasurable(elem);w=w-padding.left-padding.right-border.left-border.right;h=h-padding.bottom-padding.top-border.bottom-border.top;return{width:w,height:h};},getBorderBoxSize:function(elem){elem=$(elem);Element.toggleMeasurable(elem);var w=elem.offsetWidth;var h=elem.offsetHeight;Element.toggleMeasurable(elem);return{width:w,height:h};},setContentBoxSize:function(elem,size){elem=$(elem);if(Element.getBoxSizing(elem)=='border-box'){var padding=Element.getPaddingSize(elem);var border=Element.getBorderSize(elem);if(typeof size.width!='undefined'){var width=(size.width+padding.left+padding.right+border.left+border.right);if(width<0){width=0;}
+elem.style.width=width+'px';}
+if(typeof size.height!='undefined'){var height=(size.height+padding.top+padding.bottom+border.top+border.bottom);if(height<0){height=0;}
+elem.style.height=height+'px';}}else{if(typeof size.width!='undefined'){elem.style.width=size.width+'px';}
+if(typeof size.height!='undefined'){elem.style.height=size.height+'px';}}},setBorderBoxSize:function(elem,size){elem=$(elem);if(Element.getBoxSizing(elem)=='content-box'){var padding=Element.getPaddingSize(elem);var border=Element.getBorderSize(elem);var margin=Element.getMarginSize(elem);if(typeof size.width!='undefined'){var width=(size.width-padding.left-padding.right-border.left-border.right-margin.left-margin.right);if(width<0){width=0;}
+if(typeof size.height!='undefined'){var height=(size.height-padding.top-padding.bottom-border.top-border.bottom-margin.top-margin.bottom);if(height<0){height=0;}
+elem.style.height=height+'px';}}else{if(typeof size.width!='undefined'&&size.width>=0){elem.style.width=size.width+'px';}
+if(typeof size.height!='undefined'&&size.height>=0){elem.style.height=size.height+'px';}}},getPaddingSize:function(elem){elem=$(elem);Element.toggleMeasurable(elem);var l=Element.getNumber(Element.getStyle(elem,'padding-left'));var t=Element.getNumber(Element.getStyle(elem,'padding-top'));var r=Element.getNumber(Element.getStyle(elem,'padding-right'));var b=Element.getNumber(Element.getStyle(elem,'padding-bottom'));Element.toggleMeasurable(elem);return{left:l,top:t,right:r,bottom:b};},getBorderSize:function(elem){elem=$(elem);Element.toggleMeasurable(elem);var l=Element.getNumber(Element.getStyle(elem,'border-left-width'));var t=Element.getNumber(Element.getStyle(elem,'border-top-width'));var r=Element.getNumber(Element.getStyle(elem,'border-right-width'));var b=Element.getNumber(Element.getStyle(elem,'border-bottom-width'));Element.toggleMeasurable(elem);return{left:l,top:t,right:r,bottom:b};},getMarginSize:function(elem){elem=$(elem);Element.toggleMeasurable(elem);var l=Element.getNumber(Element.getStyle(elem,'margin-left'));var t=Element.getNumber(Element.getStyle(elem,'margin-top'));var r=Element.getNumber(Element.getStyle(elem,'margin-right'));var b=Element.getNumber(Element.getStyle(elem,'margin-bottom'));Element.toggleMeasurable(elem);return{left:l,top:t,right:r,bottom:b};},getNumber:function(n){var result=n==null||isNaN(parseInt(n))?0:parseInt(n);return result;},getPageDimensions:function(){return{width:Element.getInsideWindowWidth(),height:Element.getInsideWindowHeight()};},getInsideWindowWidth:function(){if(window.innerWidth){return window.innerWidth;}else if(document.compatMode&&document.compatMode.indexOf("CSS1")>=0){return document.body.parentElement.clientWidth;}else if(document.body&&document.body.clientWidth){return document.body.clientWidth;}
+return 0;},getInsideWindowHeight:function(){if(window.innerHeight){return window.innerHeight;}else if(document.compatMode&&document.compatMode.indexOf("CSS1")>=0){return document.body.parentElement.clientHeight;}else if(document.body&&document.body.clientHeight){return document.body.clientHeight;}
+return 0;},toggleMeasurable:function(elem){if(Element.getStyle(elem,'display')=='none'){elem.old={};elem.old.display=elem.style.display;elem.old.visibility=elem.style.visibility;elem.old.position=elem.style.position;elem.style.position='absolute';elem.style.visibility='hidden';elem.style.display='block';}else{if(elem.old){elem.style.display=elem.old.display;elem.style.visibility=elem.old.visibility;elem.style.position=elem.old.position;elem.old=null;}}}});Jx.ContentLoader=Class.create();Jx.ContentLoader.prototype={bContentLoaded:false,contentLoaded:function(element,options,r){element.innerHTML=r.responseText;this.bContentLoaded=true;if(options.onContentLoaded){options.onContentLoaded();}},contentLoadFailed:function(options,r){this.bContentLoaded=false;if(options.onContentLoadFailed){options.onContentLoadFailed();}},loadContent:function(element,options){options=options||{};element=$(element);if(options.content){element.appendChild(options.content);this.bContentLoaded=true;}else if(options.contentID){var c=$(options.contentID);if(c){element.appendChild(c);this.bContentLoaded=true;}}else if(options.contentURL){this.bContentLoaded=false;var ts='';var a=new Ajax.Request(options.contentURL,Object.extend({method:'get',onSuccess:this.contentLoaded.bind(this,element,options),onFailure:this.contentLoadFailed.bind(this,options),requestHeaders:['If-Modified-Since','Sat, 1 Jan 2000 00:00:00 GMT'],parameters:ts}));}else if(options.contentHTML){element.innerHTML=options.contentHTML;this.bContentLoaded=true;}else{this.bContentLoaded=true;}
+if(this.bContentLoaded&&options.onContentLoaded){options.onContentLoaded();}}};Jx.addStyleSheet('button/button.css');Jx.Button=Class.create();Object.extend(Jx.Button.prototype,Jx.Listener.prototype);Object.extend(Jx.Button.prototype,{al:null,domObj:null,enabled:null,initialize:function(action,options){options=options||{};this.al=[];this.action=action;var imgPath=(options.imgPath||options.image)||'';var tooltip=options.tooltip||'';var label=options.label||'';this.disabledClass=options.disabledClass||'jxDisabled';this.domA=document.createElement('a');this.domA.className='jxButton';this.domA.href='javascript:void(0)';this.domA.onclick=this.onclick.bindAsEventListener(this);this.domA.title=tooltip;this.domA.alt=tooltip;var span=document.createElement('span');span.className='jxButtonSpan';this.domA.appendChild(span);this.domLabel=document.createElement('span');this.domLabel.className='jxButtonContent';this.domLabel.innerHTML=label!=''?label:' ';span.appendChild(this.domLabel);if(label!=''){Element.addClassName(this.domLabel,'jxButtonLabel');}
+if(imgPath!=''){Element.addClassName(this.domLabel,'jxButtonIcon');this.domLabel.style.backgroundImage="url("+imgPath+")";}
+if(this.action){this.action.bindTo(this);this.propertyChanged(this.action);}
+this.domObj=document.createElement('div');this.domObj.className='jxButtonContainer';this.domObj.appendChild(this.domA);if(options.halign&&options.halign=='left'){Element.addClassName(this.domObj,'jxButtonContentLeft');}
+if(options.valign&&options.valign=='top'){Element.addClassName(this.domObj,'jxButtonContentTop');}},onclick:function(){if(this.enabled){this.processEvent(this.al,'actionPerformed',this);}
+return false;},addActionListener:function(obj){this.addListener(this.al,obj);},removeActionListener:function(obj){this.removeListener(this.al,obj);},propertyChanged:function(obj){this.enabled=obj.isEnabled();if(this.enabled){Element.removeClassName(this.domObj,this.disabledClass);}else{Element.addClassName(this.domObj,this.disabledClass);}},setImage:function(path){if(this.domImg){this.domImg.src=path;}},setLabel:function(label){if(this.domLabel){this.domLabel.innerHTML=label;}},setTooltip:function(tooltip){if(this.domImg){this.domImg.title=tooltip;this.domImg.alt=tooltip;}}});Jx.Button.Flyout=Class.create();Object.extend(Jx.Button.Flyout.prototype,Jx.Button.prototype);Object.extend(Jx.Button.Flyout.prototype,Jx.ContentLoader.prototype);Object.extend(Jx.Button.Flyout.prototype,{content:null,initialize:function(options){options=options||{};var a=new Jx.Action(this.show.bind(this));Jx.Button.prototype.initialize.apply(this,[a,options]);Element.addClassName(this.domA,'jxButtonFlyout');this.iframe=document.createElement('iframe');this.iframe.className='jxMenuShim';this.iframe.scrolling='no';this.iframe.frameborder=0;this.content=document.createElement('div');Element.addClassName(this.content,'jxFlyout');this.loadContent(this.content,options);this.domObj.appendChild(this.content);this.content.style.display='none';this.keypressWatcher=this.keypressHandler.bindAsEventListener(this);this.hideWatcher=this.clickHandler.bindAsEventListener(this);},show:function(){if(!window.opera&&!this.iframe.parentNode){this.content.appendChild(this.iframe);}
+this.content.style.display='block';Event.observe(window,'keypress',this.keypressWatcher);Event.observe(document,'click',this.hideWatcher);},hide:function(){this.content.style.display='none';Event.stopObserving(window,'keypress',this.keypressWatcher);Event.stopObserving(document,'click',this.hideWatcher);},clickHandler:function(e){var elm=Event.element(e);if(!Element.descendantOf(elm,this.domObj.parentNode)){this.hide();}},keypressHandler:function(e){var charCode=(e.charCode)?e.charCode:e.keyCode;if(charCode==Event.KEY_ESC){this.hide();}}});Jx.Button.Multi=Class.create();Jx.Button.Multi.prototype={activeButton:null,buttons:null,initialize:function(){this.buttons=[];this.content=document.createElement('div');this.tb=new Jx.Toolbar(this.content,'right');this.flyout=new Jx.Button.Flyout({content:this.content,label:' '});Element.addClassName(this.flyout.domObj.firstChild,'jxButtonMulti');this.domObj=document.createElement('div');this.buttonContainer=document.createElement('div');this.buttonContainer.className='jxButtonMultiContainer';this.domObj.appendChild(this.buttonContainer);this.domObj.appendChild(this.flyout.domObj);},add:function(){for(var i=0;i<arguments.length;i++){var theButton=arguments[i];var action=new Jx.Action(this.setButton.bind(this,theButton));var button=new Jx.Button(action,{});var click=button.domA.onclick;button.domObj=theButton.domObj.cloneNode(true);button.domObj.onclick=click;this.tb.add(button);if(!this.activeButton){this.buttonContainer.appendChild(theButton.domObj);this.activeButton=theButton;}}},setActiveButton:function(button){while(this.buttonContainer.childNodes.length>0){this.buttonContainer.removeChild(this.buttonContainer.firstChild);}
+this.buttonContainer.appendChild(button.domObj);},setButton:function(button){this.setActiveButton(button);button.onclick();this.flyout.hide();}};Jx.Button.Picker=Class.create();Object.extend(Jx.Button.Picker.prototype,Jx.Button.Flyout.prototype);Object.extend(Jx.Button.Picker.prototype,{ul:null,selectedItem:null,initialize:function(){Jx.Button.Flyout.prototype.initialize.apply(this,arguments);this.ul=document.createElement('ul');this.content.appendChild(this.ul);Element.removeClassName(this.domLabel,'jxButtonEmptyLabel');},add:function(){for(var i=0;i<arguments.length;i++){var thing=arguments[i];if(thing.domObj){thing=thing.domObj;}
+var li=document.createElement('li');var a=document.createElement('a');li.appendChild(a);if(typeof(thing)=='string'){a.innerHTML=thing;}else{a.appendChild(thing);}
+this.ul.appendChild(li);if(!this.selectedItem){this.updateButton(a);}}},clickHandler:function(e){var elm=Event.element(e);if(!Element.descendantOf(elm,this.domObj.parentNode)){this.hide();return;}
+var a=Event.findElement(e,'A');if(a&&Element.descendantOf(a,this.ul)){this.updateButton(a);this.hide();}},updateButton:function(a){while(this.domLabel.childNodes.length>0){this.domLabel.removeChild(this.domLabel.firstChild);}
+this.domLabel.appendChild(a.firstChild.cloneNode(true));this.selectedItem=a.firstChild;}});Jx.addStyleSheet('color/color.css');Jx.ColorPanel=Class.create();Jx.ColorPanel.prototype={domObj:null,color:null,alpha:null,ccl:null,hexColors:['00','33','66','99','CC','FF'],initialize:function(options){options=options||{};this.keypressWatcher=this.keypressHandler.bind(this);this.ccl=[];this.color=options.color||'#000000';this.alpha=options.alpha||1;this.domObj=document.createElement('div');this.domObj.className='jxColorPanel';var top=document.createElement('div');top.className='jxColorBar';var d=document.createElement('div');d.className='jxColorPreview';this.selectedSwatch=document.createElement('div');d.appendChild(this.selectedSwatch);top.appendChild(d);this.colorInputLabel=document.createElement('label');this.colorInputLabel.className='jxColorLabel';this.colorInputLabel.innerHTML='#';top.appendChild(this.colorInputLabel);this.colorInput=document.createElement('input');this.colorInput.className='jxHexInput';this.colorInput.type='text';this.colorInput.maxLength=6;Event.observe(this.colorInput,'keyup',this.colorChanged.bind(this));Event.observe(this.colorInput,'blur',this.colorChanged.bind(this));Event.observe(this.colorInput,'change',this.colorChanged.bind(this));top.appendChild(this.colorInput);this.alphaLabel=document.createElement('label');this.alphaLabel.className='jxAlphaLabel';this.alphaLabel.innerHTML='alpha (%)';top.appendChild(this.alphaLabel);this.alphaInput=document.createElement('input');this.alphaInput.className='jxAlphaInput';this.alphaInput.type='text';this.alphaInput.maxLength=3;Event.observe(this.alphaInput,'keyup',this.alphaChanged.bind(this));top.appendChild(this.alphaInput);this.domObj.appendChild(top);var a=document.createElement('a');a.href="javascript:void(0)";a.className='jxColorClose';a.alt='Close';a.title='Close';Event.observe(a,'click',this.hide.bind(this));img=document.createElement('img');img.className='png24';img.src=Jx.baseURL+'images/close.png';a.appendChild(img);this.domObj.appendChild(a);d=document.createElement('div');d.className='jxClearer';this.domObj.appendChild(d);var swatchClick=this.swatchClick.bindAsEventListener(this);var swatchOver=this.swatchOver.bindAsEventListener(this);var table=document.createElement('table');table.className='jxColorGrid';var tbody=document.createElement('tbody');table.appendChild(tbody);for(var i=0;i<12;i++){var tr=document.createElement('tr');for(var j=-3;j<18;j++){var bSkip=false;var r,g,b;if(j<0){if(j==-3||j==-1){r=g=b=0;bSkip=true;}else{if(i<6){r=g=b=i;}else{if(i==6){r=5;g=0;b=0;}else if(i==7){r=0;g=5;b=0;}else if(i==8){r=0;g=0;b=5;}else if(i==9){r=5;g=5;b=0;}else if(i==10){r=0;g=5;b=5;}else if(i==11){r=5;g=0;b=5;}}}}else{r=parseInt(i/6)*3+parseInt(j/6);g=j%6;b=i%6;}
+var bgColor='#'+this.hexColors[r]+this.hexColors[g]+this.hexColors[b];var td=document.createElement('td');if(!bSkip){td.style.backgroundColor=bgColor;var a=document.createElement('a');if((r>2&&g>2)||(r>2&&b>2)||(g>2&&b>2)){a.className='colorSwatch borderBlack';}else{a.className='colorSwatch borderWhite';}
+a.href='#';a.title=bgColor;a.alt=bgColor;a.swatchColor=bgColor;a.onmouseover=swatchOver;a.onclick=swatchClick;td.appendChild(a);}else{var span=document.createElement('span');td.className='emptyCell';td.appendChild(span);}
+tr.appendChild(td);}
+tbody.appendChild(tr);}
+this.domObj.appendChild(table);var d=document.createElement('div');d.className='jxColorPreview';this.previewSwatch=document.createElement('div');d.appendChild(this.previewSwatch);this.previewSwatch.style.backgroundColor=this.color;this.domObj.appendChild(d);this.previewLabel=document.createElement('label');this.previewLabel.className='jxColorLabel';this.previewLabel.innerHTML=this.color;this.domObj.appendChild(this.previewLabel);d=document.createElement('div');d.className='jxClearer';this.domObj.appendChild(d);this.updateSelected();},swatchOver:function(e){var a=Event.element(e);this.previewSwatch.style.backgroundColor=a.swatchColor;this.previewLabel.innerHTML=a.swatchColor;},swatchClick:function(e){var a=Event.element(e);this.color=a.swatchColor;this.updateSelected();this.hide();},colorChanged:function(){var color=this.colorInput.value;if(color.substring(0,1)=='#'){color=color.substring(1);}
+if(color.toLowerCase().match(/^[0-9a-f]{6}$/)){this.color='#'+color.toUpperCase();this.updateSelected();}},alphaChanged:function(){var alpha=this.alphaInput.value;if(alpha.match(/^[0-9]{1,3}$/)){this.alpha=parseFloat(alpha/100);this.updateSelected();}},setColor:function(color){this.colorInput.value=color;this.colorChanged();},setAlpha:function(alpha){this.alphaInput.value=alpha;this.alphaChanged();},updateSelected:function(){this.selectedSwatch.style.backgroundColor=this.color;this.colorInput.value=this.color.substring(1);this.alphaInput.value=parseInt(this.alpha*100);if(this.alpha<1){this.selectedSwatch.style.opacity=this.alpha;this.selectedSwatch.style.filter='Alpha(opacity='+(this.alpha*100)+')';}else{this.selectedSwatch.style.opacity='';this.selectedSwatch.style.filter='';}
+this.processEvent(this.ccl,'colorChanged',this);},show:function(){this.domObj.style.display='block';Event.observe(window,'keypress',this.keypressWatcher);},hide:function(){this.domObj.style.display='none';Event.stopObserving(window,'keypress',this.keypressWatcher);},keypressHandler:function(e){var charCode=(e.charCode)?e.charCode:e.keyCode;if(charCode==Event.KEY_ESC){this.hide();}},addColorChangeListener:function(obj){this.addListener(this.ccl,obj);},removeColorChangeListener:function(obj){this.removeListener(this.ccl,obj);}};Object.extend(Jx.ColorPanel.prototype,Jx.Listener.prototype);Jx.Button.Color=Class.create();Object.extend(Jx.Button.Color.prototype,Jx.Button.Flyout.prototype);Object.extend(Jx.Button.Color.prototype,{colorPanel:[],swatch:null,color:null,alpha:null,ccl:null,initialize:function(options){options=options||{};options.label=options.label||' ';this.color=options.color||'#000000';this.alpha=options.alpha||100;this.ccl=[];if(this.colorPanel.length==0){this.colorPanel[0]=new Jx.ColorPanel();}
+var d=document.createElement('div');d.className='jxColorButtonPreview';this.selectedSwatch=document.createElement('div');d.appendChild(this.selectedSwatch);Jx.Button.Flyout.prototype.initialize.apply(this,[options]);Element.addClassName(this.domObj.firstChild,'jxButtonColor');this.domObj.firstChild.firstChild.insertBefore(d,this.domObj.firstChild.firstChild.firstChild);this.updateSwatch();},show:function(){if(this.colorPanel[0].currentButton){this.colorPanel[0].currentButton.hide();}
+this.colorPanel[0].currentButton=this;this.colorPanel[0].addColorChangeListener(this);this.content.appendChild(this.colorPanel[0].domObj);this.colorPanel[0].domObj.style.display='block';Jx.Button.Flyout.prototype.show.apply(this,arguments);this.colorPanel[0].setColor(this.color);this.colorPanel[0].setAlpha(this.alpha);},hide:function(){this.colorPanel[0].removeColorChangeListener(this);Jx.Button.Flyout.prototype.hide.apply(this,arguments);this.colorPanel[0].currentButton=null;},setColor:function(color){this.color=color;this.updateSwatch();},setAlpha:function(alpha){this.alpha=alpha;this.updateSwatch();},colorChanged:function(panel){this.color=panel.color;this.alpha=panel.alpha*100;this.updateSwatch();this.processEvent(this.ccl,'colorChanged',this);},updateSwatch:function(){this.selectedSwatch.style.backgroundColor=this.color;if(this.alpha<100){this.selectedSwatch.style.opacity=this.alpha/100;this.selectedSwatch.style.filter='Alpha(opacity='+(this.alpha)+')';}else{this.selectedSwatch.style.opacity='';this.selectedSwatch.style.filter='';}},addColorChangeListener:function(obj){this.addListener(this.ccl,obj);},removeColorChangeListener:function(obj){this.removeListener(this.ccl,obj);}});Jx.addStyleSheet('dialog/dialog.css');Jx.Dialog=Class.create();Jx.Dialog.prototype={onClose:null,onOpen:null,onChange:null,title:null,content:null,action:null,values:null,actions:null,handler:null,bContentLoaded:null,zIndex:[101],stack:[],blanket:null,firstShow:true,modal:true,initialize:function(options){this.initUniqueId();this.values={};this.actions={};this.handler=options.handler?options.handler:null;if(options.onChange){this.onChange=options.onChange;}
+if(options.onClose){this.onClose=options.onClose;}
+if(options.onOpen){this.onOpen=options.onOpen;}
+if(options.onContentLoaded){this.onContentLoaded=options.onContentLoaded;}
+this.imageBaseUrl=options.imageBaseUrl||Jx.baseURL+"/images/";if(this.imageBaseUrl.slice(-1)!='/'){this.imageBaseUrl+='/';}
+this.modal=typeof options.modal=='undefined'?true:options.modal;var w=options.width||250;var h=options.height||250;var b=(typeof options.bottom!='undefined')?options.bottom:null;var r=(typeof options.right!='undefined')?options.right:null;var t=(typeof options.top!='undefined')?options.top:(b!=null?null:0);var l=(typeof options.left!='undefined')?options.left:(r!=null?null:0);this.blanket=document.createElement('div');this.blanket.className='jxDialogModal';this.blanket.style.display='none';if(!window.opera&&this.modal){var iframe=document.createElement('iframe');iframe.className='jxDialogShim';iframe.scrolling='no';iframe.frameborder=0;this.blanket.appendChild(iframe);if(options.parentObj){$(options.parentObj).appendChild(this.blanket);}else{document.body.appendChild(this.blanket);}}
+this.dragHandle=document.createElement('div');this.dragHandle.innerHTML=options.title||' ';this.dragHandle.style.width='100%';var domObj=document.createElement('div');domObj.className='jxDialogContainer';this.domObj=domObj;if(options.id){domObj.id=options.id;}
+var dialogObj=document.createElement('div');dialogObj.className='jxDialog';this.innerDialogObj=dialogObj;var titleObj=document.createElement('div');titleObj.className='jxDialogTitle';this.title=titleObj;titleObj.appendChild(this.dragHandle);titleObj.style.visibility='hidden';document.getElementsByTagName('BODY')[0].appendChild(titleObj);this.titleHeight=Element.getBorderBoxSize(titleObj).height;document.getElementsByTagName('BODY')[0].removeChild(titleObj);titleObj.style.visibility='';var contentObj=document.createElement('div');contentObj.className='jxDialogContent';this.content=contentObj;domObj.appendChild(dialogObj);dialogObj.appendChild(titleObj);dialogObj.appendChild(contentObj);new Jx.Layout(dialogObj,{width:w,height:h});new Jx.Layout(titleObj,{top:0,left:0,right:0,bottom:null,height:this.titleHeight,width:null});this.actionHeight=0;if(options.buttons){var actionObj=document.createElement('div');actionObj.className='jxDialogAction';actionObj.style.visibility='hidden';document.getElementsByTagName('BODY')[0].appendChild(actionObj);this.actionHeight=parseInt(Element.getStyle(actionObj,'height'));document.getElementsByTagName('BODY')[0].removeChild(actionObj);actionObj.style.visibility='';dialogObj.appendChild(actionObj);new Jx.Layout(actionObj,{top:null,left:0,right:0,bottom:0,height:this.actionHeight,width:null});this.action=actionObj;this.setButtons(options.buttons);}
+new Jx.Layout(contentObj,{top:this.titleHeight,left:0,right:0,bottom:this.actionHeight});var atag=document.createElement('a');atag.href='javascript:void(0)';atag.className='jxDialogCloseButton';atag.onclick=this.close.bindAsEventListener(this);var close=document.createElement('img');if(options.closeImg){close.src=options.closeImg;}
+else{close.src=this.imageBaseUrl+'icon_close.png';}
+close.alt='Close Dialog';close.title='Close Dialog';atag.appendChild(close);titleObj.appendChild(atag);if(options.helpID||options.helpHTML||options.helpURL||options.help){var atag2=document.createElement('a');atag2.href='javascript:void(0)';atag2.className='jxDialogHelpButton';atag2.onclick=this.toggleHelp.bindAsEventListener(this);var help=document.createElement('img');help.src=this.imageBaseUrl+'icon_quickhelp.png';help.alt='Help';help.title='Help';atag2.appendChild(help);titleObj.appendChild(atag2);this.help=document.createElement('div');this.help.className='jxDialogHelp';this.help.style.display='none';this.help.isVisible=false;var helpOpts={};helpOpts.contentID=options.helpID;helpOpts.content=options.help;helpOpts.contentURL=options.helpURL;helpOpts.contentHTML=options.helpHTML;helpOpts.onContentLoaded=this.onHelpContentLoaded.bind(this);this.loadContent(this.help,helpOpts);dialogObj.appendChild(this.help);}
+var contentOpts={};contentOpts.contentID=options.contentID;contentOpts.content=options.content;contentOpts.contentURL=options.contentURL;contentOpts.contentHTML=options.contentHTML;contentOpts.onContentLoaded=this.onDialogContentLoaded.bind(this);this.loadContent(contentObj,contentOpts);dialogObj.style.visibility='hidden';document.body.appendChild(dialogObj);dialogObj.resize();this.dialogBoxSize=Element.getBorderBoxSize(dialogObj);this.dialogBoxMargins=Element.getMarginSize(dialogObj);var containerSize={width:this.dialogBoxSize.width,height:this.dialogBoxSize.height};containerSize.width+=this.dialogBoxMargins.left+this.dialogBoxMargins.right;containerSize.height+=this.dialogBoxMargins.top+this.dialogBoxMargins.bottom;document.body.removeChild(dialogObj);dialogObj.style.visibility='';domObj.appendChild(dialogObj);domObj.style.display="none";Element.setBorderBoxSize(domObj,{width:(containerSize.width),height:(containerSize.height)});domObj.style.position='absolute';if(t!=null){domObj.style.top=(t)+'px';}else{domObj.style.bottom=(b)+'px';}
+if(l!=null){domObj.style.left=(l)+'px';}else{domObj.style.right=(r)+'px';}
+if(options.parentObj){$(options.parentObj).appendChild(domObj);}else{document.body.appendChild(domObj);}
+this.DTOffset=0;this.DBOffset=0;this.DROffset=0;this.DLOffset=0;this.decorationOffsets={top:0,right:0,bottom:0,left:0};var imgContainer=document.createElement('div');imgContainer.className='jxDialogBgTL';var img=document.createElement('img');img.src=this.imageBaseUrl+'dialog_glow_tl.png';img.className='png24';imgContainer.appendChild(img);domObj.appendChild(imgContainer);this.decorationOffsets.top+=parseInt(Element.getStyle(img,'width'));this.decorationOffsets.left+=parseInt(Element.getStyle(img,'height'));imgContainer=document.createElement('div');imgContainer.className='jxDialogBgTR';img=document.createElement('img');img.src=this.imageBaseUrl+'dialog_glow_tr.png';img.className='png24';imgContainer.appendChild(img);domObj.appendChild(imgContainer);this.decorationOffsets.top+=parseInt(Element.getStyle(img,'width'));this.decorationOffsets.right+=parseInt(Element.getStyle(img,'height'));imgContainer=document.createElement('div');imgContainer.className='jxDialogBgBR';img=document.createElement('img');img.src=this.imageBaseUrl+'dialog_glow_br.png';img.className='png24';imgContainer.appendChild(img);domObj.appendChild(imgContainer);this.decorationOffsets.bottom+=parseInt(Element.getStyle(img,'width'));this.decorationOffsets.right+=parseInt(Element.getStyle(img,'height'));imgContainer=document.createElement('div');imgContainer.className='jxDialogBgBL';img=document.createElement('img');img.src=this.imageBaseUrl+'dialog_glow_bl.png';img.className='png24';imgContainer.appendChild(img);domObj.appendChild(imgContainer);this.decorationOffsets.bottom+=parseInt(Element.getStyle(img,'width'));this.decorationOffsets.left+=parseInt(Element.getStyle(img,'height'));imgContainer=document.createElement('div');imgContainer.className='jxDialogBgT';img=document.createElement('img');img.src=this.imageBaseUrl+'dialog_glow_t.png';img.className='png24';img.style.width=containerSize.width-this.decorationOffsets.top+'px';imgContainer.appendChild(img);domObj.appendChild(imgContainer);this.topImg=img;imgContainer=document.createElement('div');imgContainer.className='jxDialogBgB';img=document.createElement('img');img.src=this.imageBaseUrl+'dialog_glow_b.png';img.className='png24';img.style.width=containerSize.width-this.decorationOffsets.bottom+'px';imgContainer.appendChild(img);domObj.appendChild(imgContainer);this.bottomImg=img;imgContainer=document.createElement('div');imgContainer.className='jxDialogBgL';img=document.createElement('img');img.src=this.imageBaseUrl+'dialog_glow_l.png';img.className='png24';img.style.height=containerSize.height-this.decorationOffsets.left+'px';imgContainer.appendChild(img);domObj.appendChild(imgContainer);this.leftImg=img;imgContainer=document.createElement('div');imgContainer.className='jxDialogBgR';img=document.createElement('img');img.src=this.imageBaseUrl+'dialog_glow_r.png';img.className='png24';img.style.height=containerSize.height-this.decorationOffsets.right+'px';imgContainer.appendChild(img);domObj.appendChild(imgContainer);this.rightImg=img;Event.observe(domObj,'mousedown',this.mouseDown.bind(this));Event.observe(this.title,'mousedown',this.mouseDown.bind(this));if(options.resizeable){this.resizeHandle=document.createElement('div');this.resizeHandle.className='jxDialogResize';this.resizeHandle.style.position='absolute';this.domObj.appendChild(this.resizeHandle);this.resizeHandleSize={width:parseInt(Element.getStyle(this.resizeHandle,'width')),height:parseInt(Element.getStyle(this.resizeHandle,'height'))};this.resizeHandle.style.top=(containerSize.height-this.resizeHandleSize.height)+'px';this.resizeHandle.style.left=(containerSize.width-this.resizeHandleSize.width)+'px';new Draggable(this.resizeHandle,{starteffect:false,endeffect:false,change:this.ondrag.bind(this),zindex:0});}
+this.bOpen=false;},mouseDown:function(){for(var i=0;i<this.stack.length;i++){if(this.stack[i]==this){this.stack.splice(i,1);this.stack.push(this);}}
+for(var i=0;i<this.stack.length;i++){this.stack[i].domObj.style.zIndex=(101+i);}},ondrag:function(obj){this.mouseDown();var delta=obj.currentDelta();var deltaX=delta[0]+this.resizeHandleSize.width;var deltaY=delta[1]+this.resizeHandleSize.height;this.resize({width:deltaX,height:deltaY});},resize:function(newSize){this.innerDialogObj.resize(newSize);if(newSize.width){var outerWidth=newSize.width;Element.setBorderBoxSize(this.domObj,{width:outerWidth});Element.setBorderBoxSize(this.topImg,{width:outerWidth-this.decorationOffsets.top});Element.setBorderBoxSize(this.bottomImg,{width:outerWidth-this.decorationOffsets.bottom});}
+if(newSize.height){var outerHeight=newSize.height;Element.setBorderBoxSize(this.domObj,{height:outerHeight});Element.setBorderBoxSize(this.leftImg,{height:outerHeight-this.decorationOffsets.left});Element.setBorderBoxSize(this.rightImg,{height:outerHeight-this.decorationOffsets.right});if(this.help){Element.setBorderBoxSize(this.help,{height:newSize.height-this.titleHeight});}}},setTitle:function(title){this.title.childNodes[0].innerHTML=title;},setButtons:function(buttons){this.action.innerHTML='';for(var i=0;i<buttons.length;i++){var button=document.createElement('input');button.id=buttons[i];button.type='button';button.className='normalButton';button.name=buttons[i];button.value=buttons[i];button.onclick=this.buttonHandler.bind(this,button);this.action.appendChild(button);this.uniqueIdRefs[button.id]=button;}},processInputs:function(obj){for(var i=0;i<obj.childNodes.length;i++){var node=obj.childNodes[i];if(node.tagName=='INPUT'||node.tagName=='SELECT'||node.tagName=='TEXTAREA'){if(node.type=='button'){this.actions[node.id]=node;node.onclick=this.buttonHandler.bind(this,node);}else{this.values[node.id]=node;if(this.onChange){node.onchange=this.onChangeHandler.bind(this,node);}}}else{if(node.childNodes){this.processInputs(node);}}}},buttonHandler:function(input,event){if(this.handler){this.handler(input.value,this);}},onChangeHandler:function(input,event){if(this.onChange){this.onChange(input,this);}},getValue:function(name){var result='';var input=this.values[name];if(input){switch(input.tagName){case'INPUT':result=input.value;break;case'SELECT':result=input.options[input.selectedIndex].value;}}
+return result;},setValue:function(name,value){if(typeof this.values[name]!='undefined'){if(this.values[name].type=='text'||this.values[name].type=='hidden'){this.values[name].value=value;}}},show:function(){this.stack.push(this);if(this.modal){this.blanket.style.zIndex=this.zIndex[0]++;this.blanket.style.visibility='visible';this.blanket.style.display='block';}
+this.domObj.style.zIndex=this.zIndex[0]++;Effect.Appear(this.domObj,{duration:0.1});this.domObj.style.display='block';new Draggable(this.domObj,{handle:this.dragHandle,starteffect:false,endeffect:false});this.content.resize({forceResize:this.firstShow});this.firstShow=false;},hide:function(){for(var i=0;i<this.stack.length;i++){if(this.stack[i]==this){this.stack.splice(i,1);}}
+this.zIndex[0]--;Effect.Fade(this.domObj,{duration:0.3});if(this.modal){this.blanket.style.visibility='hidden';this.zIndex[0]--;}},open:function(){if(!this.bOpen){this.bOpen=true;}
+if(this.bContentLoaded){this.show();if(this.onOpen)this.onOpen();}},close:function(){this.bOpen=false;this.hide();if(this.onClose)this.onClose();},onDialogContentLoaded:function(){this.processInputs(this.content);if(this.onContentLoaded){this.onContentLoaded(this);}
+if(this.bOpen){this.open();this.bOpen=false;}},onHelpContentLoaded:function(){var img=document.createElement('img');img.className='jxDialogHelpCloseButton png24';img.src=this.imageBaseUrl+'help_close.png';img.onclick=this.toggleHelp.bind(this);img.alt='Close Help';img.title='Close Help';this.help.appendChild(img);},toggleHelp:function(){if(this.help.isVisible){Effect.Fade(this.help,{duration:0.3});}else{var actionSize=this.action?Element.getBorderBoxSize(this.action):{width:0,height:0};var contentSize=Element.getBorderBoxSize(this.content);Element.setBorderBoxSize(this.help,{height:contentSize.height+actionSize.height});Effect.Appear(this.help,{duration:0.3});}
+this.help.isVisible=!this.help.isVisible;}};Object.extend(Jx.Dialog.prototype,Jx.UniqueId.prototype);Object.extend(Jx.Dialog.prototype,Jx.ContentLoader.prototype);Jx.addStyleSheet('grid/grid.css');Jx.Grid=Class.create();Jx.Grid.prototype={domObj:null,model:null,initialize:function(domObj,options){this.domObj=$(domObj);if(!this.domObj.jxLayout){new Jx.Layout(this.domObj);}
+this.domObj.jxLayout.addSizeChangeListener(this);options=options||{};this.rowColObj=document.createElement('div');this.rowColObj.className='jxGridContainer';this.colObj=document.createElement('div');this.colObj.className='jxGridContainer';this.colTable=document.createElement('table');this.colTable.className='jxGridTable';this.colTableHead=document.createElement('thead');this.colTable.appendChild(this.colTableHead);this.colTableBody=document.createElement('tbody');this.colTable.appendChild(this.colTableBody);this.colObj.appendChild(this.colTable);this.rowObj=document.createElement('div');this.rowObj.className='jxGridContainer';this.rowTable=document.createElement('table');this.rowTable.className='jxGridTable';this.rowTableHead=document.createElement('thead');this.rowTable.appendChild(this.rowTableHead);this.rowObj.appendChild(this.rowTable);this.gridObj=document.createElement('div');this.gridObj.className='jxGridContainer';this.gridObj.style.overflow='scroll';this.gridTable=document.createElement('table');this.gridTable.className='jxGridTable';this.gridTableBody=document.createElement('tbody');this.gridTable.appendChild(this.gridTableBody);this.gridObj.appendChild(this.gridTable);this.domObj.appendChild(this.rowColObj);this.domObj.appendChild(this.rowObj);this.domObj.appendChild(this.colObj);this.domObj.appendChild(this.gridObj);this.bAlternateRowColors=options.alternateRowColors||false;this.showRowHeader=options.rowHeaders||false;this.showColumnHeader=options.columnHeaders||false;this.rowSelection=options.rowSelection||false;this.cellSelection=options.cellSelection||false;Event.observe(this.gridObj,'scroll',this.onScroll.bind(this));Event.observe(this.gridObj,'click',this.onClickGrid.bindAsEventListener(this));Event.observe(this.rowObj,'click',this.onClickRowHeader.bindAsEventListener(this));Event.observe(this.colObj,'click',this.onClickColumnHeader.bindAsEventListener(this));Event.observe(this.gridObj,'mousemove',this.onMouseMoveGrid.bindAsEventListener(this));Event.observe(this.rowObj,'mousemove',this.onMouseMoveRowHeader.bindAsEventListener(this));Event.observe(this.colObj,'mousemove',this.onMouseMoveColumnHeader.bindAsEventListener(this));},onScroll:function(){this.colObj.scrollLeft=this.gridObj.scrollLeft;this.rowObj.scrollTop=this.gridObj.scrollTop;},sizeChanged:function(){this.resize();},resize:function(){if(!this.model){return;}
+var colHeight=this.showColumnHeader?this.model.getColumnHeaderHeight():1;var rowWidth=this.showRowHeader?this.model.getRowHeaderWidth():1;var size=Element.getContentBoxSize(this.domObj);this.rowColObj.style.width=(rowWidth-1)+'px';this.rowColObj.style.height=(colHeight-1)+'px';this.rowObj.style.top=(colHeight)+'px';this.rowObj.style.left='0px';this.rowObj.style.width=(rowWidth-1)+'px';this.rowObj.style.height=(size.height-colHeight-1)+'px';this.colObj.style.top='0px';this.colObj.style.left=(rowWidth)+'px';this.colObj.style.width=(size.width-rowWidth-1)+'px';this.colObj.style.height=(colHeight-1)+'px';this.gridObj.style.top=(colHeight)+'px';this.gridObj.style.left=(rowWidth)+'px';this.gridObj.style.width=(size.width-rowWidth-1)+'px';this.gridObj.style.height=(size.height-colHeight-1)+'px';},setModel:function(model){if(this.model){this.model.removeGridListener(this);}
+this.model=model;if(this.model){this.domObj.jxLayout.resize();this.model.addGridListener(this);this.createGrid();this.resize();}else{this.destroyGrid();}},destroyGrid:function(){var n=this.colTableHead.cloneNode(false);this.colTable.replaceChild(n,this.colTableHead);this.colTableHead=n;n=this.colTableBody.cloneNode(false);this.colTable.replaceChild(n,this.colTableBody);this.colTableBody=n;n=this.rowTableHead.cloneNode(false);this.rowTable.replaceChild(n,this.rowTableHead);this.rowTableHead=n;n=this.gridTableBody.cloneNode(false);this.gridTable.replaceChild(n,this.gridTableBody);this.gridTableBody=n;},createGrid:function(){this.destroyGrid();if(this.model){var model=this.model;var nColumns=model.getColumnCount();var nRows=model.getRowCount();if(this.showColumnHeader){var colHeight=model.getColumnHeaderHeight();var trHead=document.createElement('tr');this.colTableHead.appendChild(trHead);var trBody=document.createElement('tr');this.colTableBody.appendChild(trBody);var th=document.createElement('th');th.style.width='0px';th.style.height='0px';trHead.appendChild(th);th=th.cloneNode(true);th.style.height=(colHeight)+'px';trBody.appendChild(th);for(var i=0;i<nColumns;i++){var colWidth=model.getColumnWidth(i);th=document.createElement('th');th.className='jxGridColHeadHide';th.style.width=(colWidth)+'px';var p=document.createElement('p');p.style.height='0px';p.style.width=(colWidth)+'px';th.appendChild(p);trHead.appendChild(th);th=document.createElement('th');th.className='jxGridColHead';th.innerHTML=model.getColumnHeaderHTML(i);trBody.appendChild(th);}
+var th=document.createElement('th');th.style.width='1000px';th.style.height='0px';trHead.appendChild(th);th=th.cloneNode(true);th.style.height=(colHeight-1)+'px';th.className='jxGridColHead';trBody.appendChild(th);}
+if(this.showRowHeader){var rowWidth=model.getRowHeaderWidth();var tr=document.createElement('tr');var td=document.createElement('td');td.style.width='0px';td.style.height='0px';tr.appendChild(td);var th=document.createElement('th');th.style.width=(rowWidth)+'px';th.style.height='0px';tr.appendChild(th);this.rowTableHead.appendChild(tr);for(var i=0;i<nRows;i++){var rowHeight=model.getRowHeight(i);var tr=document.createElement('tr');var td=document.createElement('td');td.className='jxGridRowHeadHide';td.style.width='0px';td.style.height=(rowHeight)+'px';var p=document.createElement('p');p.style.width='0px';p.style.height=(rowHeight)+'px';td.appendChild(p);tr.appendChild(td);var th=document.createElement('th');th.className='jxGridRowHead';th.innerHTML=model.getRowHeaderHTML(i);tr.appendChild(th);this.rowTableHead.appendChild(tr);}
+var tr=document.createElement('tr');var td=document.createElement('td');td.style.width='0px';td.style.height='1000px';tr.appendChild(td);var th=document.createElement('th');th.style.width=(rowWidth)+'px';th.style.height='1000px';th.className='jxGridRowHead';tr.appendChild(th);this.rowTableHead.appendChild(tr);}
+var colHeight=model.getColumnHeaderHeight();var trBody=document.createElement('tr');this.gridTableBody.appendChild(trBody);var td=document.createElement('td');td.style.width='0px';td.style.height='0px';trBody.appendChild(td);for(var i=0;i<nColumns;i++){var colWidth=model.getColumnWidth(i);td=document.createElement('td');td.className='jxGridColHeadHide';td.style.width=(colWidth)+'px';var p=document.createElement('p');p.style.height='0px';p.style.width=(colWidth)+'px';td.appendChild(p);trBody.appendChild(td);}
+for(var j=0;j<nRows;j++){var rowHeight=model.getRowHeight(j);var actualRowHeight=rowHeight;var tr=document.createElement('tr');this.gridTableBody.appendChild(tr);var td=document.createElement('td');td.className='jxGridRowHeadHide';td.style.width='0px';td.style.height=(rowHeight)+'px';var p=document.createElement('p');p.style.height=(rowHeight)+'px';td.appendChild(p);tr.appendChild(td);for(var i=0;i<nColumns;i++){var colWidth=model.getColumnWidth(i);td=document.createElement('td');td.className='jxGridCell';td.innerHTML=model.getValueAt(j,i);tr.appendChild(td);var tdSize=Element.getDimensions(td);if(tdSize.height>actualRowHeight){actualRowHeight=tdSize.height;}}
+if(document.all){actualRowHeight-=1;}
+if(this.showRowHeader){this.setRowHeaderHeight(j,actualRowHeight);}
+if(this.bAlternateRowColors){tr.className=(j%2)?'jxGridRowOdd':'jxGridRowEven';}else{tr.className='jxGridRowAll';}}}},setRowHeaderHeight:function(row,height){this.rowTableHead.childNodes[row+1].childNodes[0].childNodes[0].style.height=(height)+'px';},gridChanged:function(model,row,col,value){if(this.model==model){this.gridObj.childNodes[row].childNodes[col].innerHTML=value;}},prelightRowHeader:function(row){var cell=(row>=0&&row<this.rowTableHead.rows.length-1)?this.rowTableHead.rows[row+1].cells[1]:null;if(this.prelitRowHeader!=cell){if(this.prelitRowHeader){Element.removeClassName(this.prelitRowHeader,'jxGridRowHeaderPrelight');}
+this.prelitRowHeader=cell;if(this.prelitRowHeader){Element.addClassName(this.prelitRowHeader,'jxGridRowHeaderPrelight');}}},prelightColumnHeader:function(col){if(this.colTableBody.rows.length==0){return;}
+var cell=(col>=0&&col<this.colTableBody.rows[0].cells.length-1)?this.colTableBody.rows[0].cells[col+1]:null;if(this.prelitColumnHeader!=cell){if(this.prelitColumnHeader){Element.removeClassName(this.prelitColumnHeader,'jxGridColumnHeaderPrelight');}
+this.prelitColumnHeader=cell;if(this.prelitColumnHeader){Element.addClassName(this.prelitColumnHeader,'jxGridColumnHeaderPrelight');}}},prelightRow:function(row){var tr=(row>=0&&row<this.gridTableBody.rows.length-1)?this.gridTableBody.rows[row+1]:null;if(this.prelitRow!=row){if(this.prelitRow){Element.removeClassName(this.prelitRow,'jxGridRowPrelight');}
+this.prelitRow=tr;if(this.prelitRow&&!Element.hasClassName(this.prelitRow,'jxGridRowSelected')){this.prelightRowHeader(row);Element.addClassName(this.prelitRow,'jxGridRowPrelight');}}},prelightColumn:function(col){this.prelightColumnHeader(col);},prelightCell:function(row,col){var td=(row>=0&&col>=0&&row<this.gridTableBody.rows.length-1&&col<this.gridTableBody.rows[row+1].cells.length-1)?this.gridTableBody.rows[row+1].cells[col+1]:null;if(this.prelitCell!=td){if(this.prelitCell){Element.removeClassName(this.prelitCell,'jxGridCellPrelight');}
+this.prelitCell=td;if(this.prelitCell){Element.addClassName(this.prelitCell,'jxGridCellPrelight');this.prelightRow(row);this.prelightColumn(col);}}},selectCell:function(row,col){var td=(row>=0&&col>=0&&row<this.gridTableBody.rows.length-1&&col<this.gridTableBody.rows[row+1].cells.length-1)?this.gridTableBody.rows[row+1].cells[col+1]:null;if(!td){return;}
+if(this.selectedCell){Element.addClassName(this.selectedCell,'jxGridCellSelected');}else{Element.removeClassName(this.selectedCell,'jxGridCellSelected');}},selectRowHeader:function(row,selected){var cell=(row>=0&&row<this.rowTableHead.rows.length-1)?this.rowTableHead.rows[row+1].cells[1]:null;if(!cell){return;}
+if(selected){Element.addClassName(cell,'jxGridRowHeaderSelected');}else{Element.removeClassName(cell,'jxGridRowHeaderSelected');}},selectRow:function(row,selected){var tr=(row>=0&&row<this.gridTableBody.rows.length-1)?this.gridTableBody.rows[row+1]:null;if(tr){if(selected){Element.addClassName(tr,'jxGridRowSelected');}else{Element.removeClassName(tr,'jxGridRowSelected');}}
+this.selectRowHeader(row,selected);},selectColumnHeader:function(col,selected){if(this.colTableBody.rows.length==0){return;}
+var cell=(col>=0&&col<this.colTableBody.rows[0].cells.length-1)?this.colTableBody.rows[0].cells[col+1]:null;if(cell==null){return;}
+if(selected){Element.addClassName(cell,'jxGridColumnHeaderSelected');}else{Element.removeClassName(cell,'jxGridColumnHeaderSelected');}},selectColumn:function(col,selected){if(col>=0&&col<this.gridTable.rows[0].cells.length){if(selected){for(var i=0;i<this.gridTable.rows.length;i++){Element.removeClassName(this.gridTable.rows[i].cells[this.selectedColumn+1],'jxGridColumnSelected');}}else{for(var i=0;i<this.gridTable.rows.length;i++){Element.addClassName(this.gridTable.rows[i].cells[col+1],'jxGridColumnSelected');}}}
+this.selectColumnHeader(col,selected);},onMouseMoveGrid:function(e){var rc=this.getRowColumnFromEvent(e);this.prelightCell(rc.row,rc.column);},onMouseMoveRowHeader:function(e){var rc=this.getRowColumnFromEvent(e);this.prelightRow(rc.row);},onMouseMoveColumnHeader:function(e){var rc=this.getRowColumnFromEvent(e);this.prelightColumn(rc.column);},onClickGrid:function(e){var rc=this.getRowColumnFromEvent(e);if(this.model.cellSelected){this.model.cellSelected(this,rc.row,rc.column);}},onClickRowHeader:function(e){var rc=this.getRowColumnFromEvent(e);if(this.model.rowSelected){this.model.rowSelected(this,rc.row);}},onClickColumnHeader:function(e){var rc=this.getRowColumnFromEvent(e);if(this.model.columnSelected){this.model.columnSelected(this,rc.column);}},getRowColumnFromEvent:function(e){var td=Event.element(e);if(td.tagName!='TD'&&td.tagName!='TH'){return{row:-1,column:-1};}
+var tr=td.parentNode;var col=td.cellIndex-1;var row=tr.rowIndex-1;if(col==-1){for(var i=0;i<tr.childNodes.length;i++){if(tr.childNodes[i]==td){col=i-1;break;}}}
+return{row:row,column:col};}};Jx.Layout=Class.create();Jx.Layout.prototype={scl:null,initialize:function(domObj,options){options=options||{};this.options=new Jx.Constraint(options);this.domObj=$(domObj);this.domObj.resize=this.resize.bind(this);this.domObj.style.position=this.options.position;this.domObj.jxLayout=this;if(this.domObj.parentNode&&this.domObj.parentNode.tagName=='BODY'){Event.observe(window,'resize',this.windowResize.bind(this));}
+this.scl=[];},windowResize:function(){if(this.resizeTimer){window.clearTimeout(this.resizeTimer);this.resizeTimer=null;}
+this.resizeTimer=window.setTimeout(this.resize.bind(this),250);},resize:function(options){this.resizeTimer=null;var needsResize=false;if(options){for(var i in options){if(this.options[i]!=options[i]){needsResize=true;this.options[i]=options[i];}}
+if(options.forceResize){needsResize=true;}}
+var parentSize;if(this.domObj.parentNode.tagName=='BODY'){parentSize=Element.getPageDimensions();}else{parentSize=Element.getContentBoxSize(this.domObj.parentNode);}
+if(this.lastParentSize&&!needsResize){needsResize=(this.lastParentSize.width!=parentSize.width||this.lastParentSize.height!=parentSize.height);}else{needsResize=true;}
+this.lastParentSize=parentSize;if(!needsResize){return;}
+var l,t,w,h;if(this.options.left!=null){l=this.options.left;if(this.options.right==null){if(this.options.width==null){w=parentSize.width-l;if(w<this.options.minWidth){w=this.options.minWidth;}
+if(this.options.maxWidth>=0&&w>this.options.maxWidth){w=this.options.maxWidth;}}else{w=this.options.width;}}else{if(this.options.width==null){w=parentSize.width-l-this.options.right;if(w<this.options.minWidth){w=this.options.minWidth;}
+if(this.options.maxWidth>=0&&w>this.options.maxWidth){w=this.options.maxWidth;}}else{w=this.options.width;}}}else{if(this.options.right==null){if(this.options.width==null){l=0;w=parentSize.width;if(this.options.maxWidth>=0&&w>this.options.maxWidth){l=l+parseInt(w-this.options.maxWidth)/2;w=this.options.maxWidth;}}else{w=this.options.width;l=parseInt((parentSize.width-w)/2);if(l<0){l=0;}}}else{if(this.options.width!=null){w=this.options.width;l=parentSize.width-w-this.options.right;if(l<0){l=0;}}else{l=0;w=parentSize.width-this.options.right;if(w<this.options.minWidth){w=this.options.minWidth;}
+if(this.options.maxWidth>=0&&w>this.options.maxWidth){l=w-this.options.maxWidth-this.options.right;w=this.options.maxWidth;}}}}
+if(this.options.top!=null){t=this.options.top;if(this.options.bottom==null){if(this.options.height==null){h=parentSize.height-t;if(h<this.options.minHeight){h=this.options.minHeight;}
+if(this.options.maxHeight>=0&&h>this.options.maxHeight){h=this.options.maxHeight;}}else{h=this.options.height;if(this.options.maxHeight>=0&&h>this.options.maxHeight){t=h-this.options.maxHeight;h=this.options.maxHeight;}}}else{if(this.options.height==null){h=parentSize.height-t-this.options.bottom;if(h<this.options.minHeight){h=this.options.minHeight;}
+if(this.options.maxHeight>=0&&h>this.options.maxHeight){h=this.options.maxHeight;}}else{h=this.options.height;}}}else{if(this.options.bottom==null){if(this.options.height==null){t=0;h=parentSize.height;if(h<this.options.minHeight){h=this.options.minHeight;}
+if(this.options.maxHeight>=0&&h>this.options.maxHeight){t=parseInt((parentSize.height-this.options.maxHeight)/2);h=this.options.maxHeight;}}else{h=this.options.height;t=parseInt((parentSize.height-h)/2);if(t<0){t=0;}}}else{if(this.options.height!=null){h=this.options.height;t=parentSize.height-h-this.options.bottom;if(t<0){t=0;}}else{t=0;h=parentSize.height-this.options.bottom;if(h<this.options.minHeight){h=this.options.minHeight;}
+if(this.options.maxHeight>=0&&h>this.options.maxHeight){t=parentSize.height-this.options.maxHeight-this.options.bottom;h=this.options.maxHeight;}}}}
+this.domObj.style.position=this.options.position;if(this.options.position=='absolute'){var padding=Element.getPaddingSize(this.domObj.parentNode);this.domObj.style.left=(l+padding.left)+'px';this.domObj.style.top=(t+padding.top)+'px';Element.setBorderBoxSize(this.domObj,{width:w,height:h});}else{var sizeOpts={width:w};if(this.options.height){sizeOpts.height=this.options.height;}
+Element.setBorderBoxSize(this.domObj,sizeOpts);}
+var o={forceResize:options?options.forceResize:false};for(var i=0;i<this.domObj.childNodes.length;i++){var c=this.domObj.childNodes[i];if(c.resize){c.resize(o);}}
+this.processEvent(this.scl,'sizeChanged',this);},addSizeChangeListener:function(obj){this.addListener(this.scl,obj);},removeSizeChangeListener:function(o){this.removeListener(this.scl,o);}};Object.extend(Jx.Layout.prototype,Jx.Listener.prototype);Jx.Constraint=Class.create();Jx.Constraint.prototype={position:'absolute',left:0,right:0,top:0,bottom:0,width:null,height:null,minWidth:0,minHeight:0,maxWidth:-1,maxHeight:-1,initialize:function(o){for(var i in o){this[i]=o[i];}}};Jx.addStyleSheet('menu/menu.css');Jx.addStyleSheet('button/button.css');Jx.MenuItem=Class.create();Object.extend(Jx.MenuItem.prototype,Jx.Listener.prototype);Object.extend(Jx.MenuItem.prototype,{al:null,domObj:null,parent:null,enabled:false,button:null,initialize:function(action,options){this.initializeItem(options);action.bindTo(this);this.propertyChanged(action);},initializeItem:function(options){if(!options.image){options.image=Jx.baseURL+'images/a_pixel.png';}
+if(!options.label){options.label=' ';}
+this.label=options.label||' ';this.image=options.image||null;this.al=[];this.domObj=document.createElement('li');this.domObj.className='jxMenuItem';var action=new Jx.Action(this.processActionEvent.bindAsEventListener(this))
+this.button=new Jx.Button(action,options);Event.observe(this.button.domObj,'mouseover',this.onmouseover.bindAsEventListener(this),true);this.domObj.appendChild(this.button.domObj);},setParent:function(obj){this.parent=obj;},hide:function(){},show:function(){},addActionListener:function(obj){this.addListener(this.al,obj);},removeActionListener:function(obj){this.removeListener(this.al,obj);},processActionEvent:function(e){if(this.enabled){this.processEvent(this.al,'actionPerformed',this);if(this.parent&&this.parent.deactivate){this.parent.deactivate(e);}}},propertyChanged:function(obj){this.enabled=obj.isEnabled();if(this.enabled){Element.removeClassName(this.domObj.childNodes[0].childNodes[0],'jxDisabled');}else{Element.addClassName(this.domObj.childNodes[0].childNodes[0],'jxDisabled');}},onmouseover:function(e){var target=Event.element(e);if(this.parent&&this.parent.setVisibleItem){this.parent.setVisibleItem(this);}
+this.show();}});Jx.MenuSeparator=Class.create();Object.extend(Jx.MenuSeparator.prototype,{domObj:null,parent:null,initialize:function(){this.domObj=document.createElement('li');this.domObj.className='jxMenuItem';var span=document.createElement('span');span.className='jxMenuSeparator';span.innerHTML=' ';this.domObj.appendChild(span);},setParent:function(obj){this.parent=obj;},hide:function(){},show:function(){}});Jx.SubMenu=Class.create();Object.extend(Jx.SubMenu.prototype,Jx.MenuItem.prototype);Object.extend(Jx.SubMenu.prototype,{subDomObj:null,parent:null,visibleItem:null,items:null,initialize:function(options){this.open=false;this.items=[];this.initializeItem(options);Element.addClassName(this.domObj.childNodes[0].childNodes[0],'jxButtonSubMenu');this.iframe=document.createElement('iframe');this.iframe.className='jxMenuShim';this.iframe.scrolling='no';this.iframe.frameborder=0;this.subDomObj=document.createElement('ul');this.subDomObj.className='jxSubMenu';this.subDomObj.style.display='none';this.domObj.appendChild(this.subDomObj);},setParent:function(obj){this.parent=obj;},show:function(){if(this.open||this.items.length==0){return;}
+this.open=true;this.subDomObj.style.display='block';if(!window.opera){this.subDomObj.childNodes[0].appendChild(this.iframe);var size=Element.getBorderBoxSize(this.subDomObj);this.iframe.style.width=size.width+"px";this.iframe.style.height=size.height+"px";}
+this.setActive(true);},hide:function(){if(!this.open){return;}
+this.open=false;for(var i=0;i<this.items.length;i++){this.items[i].hide();}
+this.subDomObj.style.display='none';if(!window.opera&&this.iframe.parentNode){this.subDomObj.childNodes[0].removeChild(this.iframe);}
+this.visibleItem=null;},add:function(){for(var i=0;i<arguments.length;i++){var item=arguments[i];this.items.push(item);item.setParent(this);this.subDomObj.appendChild(item.domObj);}},insertBefore:function(newItem,targetItem){var bInserted=false;for(var i=0;i<this.items.length;i++){if(this.items[i]==targetItem){this.items.splice(i,0,newItem);this.subDomObj.insertBefore(newItem.domObj,targetItem.domObj);bInserted=true;break;}}
+if(!bInserted){this.add(newItem);}},remove:function(item){for(var i=0;i<this.items.length;i++){if(this.items[i]==item){this.items.splice(i,1);this.subDomObj.removeChild(item.domObj);break;}}},processActionEvent:function(e){if(this.open){this.hide();}else{this.show();}
+return Event.stop(e);},deactivate:function(e){if(this.parent){this.parent.deactivate(e);}},isActive:function(){if(this.parent){return this.parent.isActive();}else{return false;}},setActive:function(isActive){if(this.parent&&this.parent.setActive){this.parent.setActive(isActive);}},setVisibleItem:function(obj){if(this.visibleItem!=obj){if(this.visibleItem&&this.visibleItem.hide){this.visibleItem.hide();}
+this.visibleItem=obj;this.visibleItem.show();}}});Jx.Menu=Class.create();Jx.Menu.prototype={domObj:null,buttonObj:null,subDomObj:null,items:null,menus:[],initialize:function(options){this.items=[];this.iframe=document.createElement('iframe');this.iframe.className='jxMenuShim';this.iframe.scrolling='no';this.iframe.frameborder=0;this.subDomObj=document.createElement('ul');this.subDomObj.className='jxMenu';this.subDomObj.style.display='none';if(options){this.domObj=document.createElement('li');var action=new Jx.Action(this.show.bind(this));this.button=new Jx.Button(action,options);Element.addClassName(this.button.domObj.firstChild,'jxButtonMenu');this.domObj.appendChild(this.button.domObj);Event.observe(this.domObj,'mouseover',this.onMouseOver.bindAsEventListener(this));this.domObj.appendChild(this.subDomObj);}
+this.hideWatcher=this.hide.bindAsEventListener(this);},add:function(){for(var i=0;i<arguments.length;i++){var item=arguments[i];this.items.push(item);item.setParent(this);this.subDomObj.appendChild(item.domObj);}},deactivate:function(){this.hide();},actionPerformed:function(){this.hide();},onMouseOver:function(e){if(this.menus[0]&&this.menus[0]!=this){this.show(e);}},hide:function(e){if(e){var root=Event.findElement(e,'LI');if(root==this.domObj){return;}}
+if(this.menus[0]&&this.menus[0]==this){this.menus[0]=null;}
+for(var i=0;i<this.items.length;i++){this.items[i].hide(e);}
+Event.stopObserving(document,'click',this.hideWatcher,true);this.subDomObj.style.display='none';},show:function(e){if(this.menus[0]&&this.menus[0]!=this){this.menus[0].hide(e);}
+if(this.items.length==0){return;}
+this.menus[0]=this;this.subDomObj.style.display='block';this.subDomObj.style.visibility='visible';if(!window.opera){this.subDomObj.childNodes[0].appendChild(this.iframe);var size=Element.getContentBoxSize(this.subDomObj);this.iframe.style.width=size.width+"px";this.iframe.style.height=size.height+"px";}
+Event.stop(e);Event.observe(document,'click',this.hideWatcher,true);},setVisibleItem:function(obj){if(this.visibleItem!=obj){if(this.visibleItem&&this.visibleItem.hide){this.visibleItem.hide();}
+this.visibleItem=obj;this.visibleItem.show();}}};Jx.ContextMenu=Class.create();Object.extend(Jx.ContextMenu.prototype,Jx.Menu.prototype);Object.extend(Jx.ContextMenu.prototype,{initialize:function(id){Jx.Menu.prototype.initialize.apply(this,[]);document.getElementsByTagName('BODY')[0].appendChild(this.subDomObj);if($(id)){$(id).oncontextmenu=this.show.bindAsEventListener(this);;}},show:function(e){this.subDomObj.style.left=Event.pointerX(e)+"px";this.subDomObj.style.top=Event.pointerY(e)+"px";Jx.Menu.prototype.show.apply(this,[e]);}});Jx.addStyleSheet('panel/panel.css');Jx.PanelManager=Class.create();Jx.PanelManager.prototype={panels:null,height:null,firstLayout:true,initialize:function(domObj,panels){this.domObj=$(domObj);this.panels=panels;var d=document.createElement('div');d.style.position='absolute';new Jx.Layout(d,{minHeight:0,maxHeight:0,height:0});var elements=[d];for(var i=0;i<this.panels.length;i++){elements.push(this.panels[i].domObj);}
+this.splitter=new Jx.Splitter(this.domObj,{splitInto:panels.length+1,layout:'vertical',elements:elements});this.splitter.sizeChanged=this.sizeChanged.bind(this);for(var i=0;i<this.panels.length;i++){var panel=this.panels[i];this.splitter.bars[i].appendChild(panel.title);this.splitter.bars[i].style.height=Element.getBorderBoxSize(panel.title).height+'px';Element.removeClassName(this.splitter.bars[i],'jxSplitterBar');Element.addClassName(this.splitter.bars[i],'jxPanelBar');panel.manager=this;}},sizeChanged:function(){if(this.firstLayout){if(Element.getBorderBoxSize(this.panels[0].title).height!=0){for(var i=0;i<this.splitter.bars.length;i++){var panel=this.panels[i];this.splitter.bars[i].style.height=Element.getBorderBoxSize(panel.title).height+'px';this.splitter.bars[i].size=null;}
+this.firstLayout=false;Jx.Splitter.prototype.sizeChanged.apply(this.splitter,[]);}}else{Jx.Splitter.prototype.sizeChanged.apply(this.splitter,[]);}},maximizePanel:function(panel){var h=Element.getContentBoxSize(this.domObj).height;var t=0;for(var i=1;i<this.splitter.elements.length;i++){var p=this.splitter.elements[i];t+=Element.getBorderBoxSize(p.leftBar).height;if(p!==panel.domObj){p.jxLayout.resize({top:t,height:p.jxLayout.options.minHeight,bottom:null});t+=p.jxLayout.options.minHeight;p.rightBar.style.top=t+'px';}else{break;}}
+b=h;for(var i=this.splitter.elements.length-1;i>0;i--){p=this.splitter.elements[i];if(p!==panel.domObj){b-=p.jxLayout.options.minHeight;p.jxLayout.resize({top:b,height:p.jxLayout.options.minHeight,bottom:null});b-=Element.getBorderBoxSize(p.leftBar).height;p.leftBar.style.top=b+'px';}else{break;}}
+panel.domObj.jxLayout.resize({top:t,height:b-t,bottom:null});}};Jx.Panel=Class.create();Jx.Panel.prototype={labelObj:null,state:'open',busyCount:null,bContentReady:null,onContentReady:null,initialize:function(options){this.initUniqueId();this.title=document.createElement('div');this.title.className="jxPanelTitle";this.title.style.height='22px';this.labelObj=document.createElement('span');this.labelObj.className='jxPanelLabel';this.labelObj.innerHTML=options.label?options.label:'empty';this.imageBaseUrl=options.imageBaseUrl||Jx.baseURL+'images/';var a,img;if(options.helpCallback){a=document.createElement('a');a.className='jxPanelHelp';a.href='javascript:void(0)';Event.observe(a,'click',options.helpCallback);img=document.createElement('img');img.src=this.imageBaseUrl+"help.png";img.alt='Help on this panel';img.title='Help on this panel';a.appendChild(img);this.title.appendChild(a);}
+a=document.createElement('a');a.className='jxPanelMaximize';a.href='javascript:void(0)';Event.observe(a,'click',this.maximize.bindAsEventListener(this));img=document.createElement('img');img.src=this.imageBaseUrl+"maximize.png";img.alt='Maximize Panel';img.title='Maximize Panel';a.appendChild(img);this.title.appendChild(a);a=document.createElement('a');a.className='jxPanelLoading';a.href='javascript:void(0)';img=document.createElement('img');img.src=this.imageBaseUrl+"loading.gif";img.alt='Loading Panel';img.title='Loading Panel';a.appendChild(img);this.loadingObj={};this.loadingObj.link=a;this.loadingObj.img=img;this.title.appendChild(this.loadingObj.link);this.title.appendChild(this.labelObj);Event.observe(this.title,'dblclick',this.maximize.bindAsEventListener(this));this.domObj=document.createElement('div');this.domObj.className='jxPanel';this.jxLayout=new Jx.Layout(this.domObj,options.constraint||{});this.jxLayout.addSizeChangeListener(this);var top=0;var bottom=0;if(options.menubar){this.menubar=options.menubar;this.domObj.appendChild(options.menubar);var h=Element.getBorderBoxSize(options.menubar).height;new Jx.Layout(this.menubar,{top:top,height:h});top+=h;}
+if(options.toolbar){this.toolbar=options.toolbar;this.domObj.appendChild(options.toolbar);var h=Element.getBorderBoxSize(options.toolbar).height;new Jx.Layout(this.toolbar,{top:top,height:h});}
+if(options.statusbar){this.statusbar=options.statusbar;this.domObj.appendChild(options.statusbar);var h=Element.getBorderBoxSize(options.statusbar).height;new Jx.Layout(this.statusbar,{bottom:bottom,height:h,top:null});bottom+=h;}
+this.content=document.createElement('div');Element.addClassName(this.content,'jxPanelContent');new Jx.Layout(this.content,{top:top,bottom:bottom});this.domObj.appendChild(this.content);this.loadContent(this.content,options);this.busyCount=0;this.bContentReady=false;},setLabel:function(s){this.labelObj.innerHTML=s;},getLabel:function(){return this.labelObj.innerHTML;},finalize:function(){this.domObj=null;this.deregisterIds();},maximize:function(){if(this.manager){this.manager.maximizePanel(this);}},setContent:function(html){this.content.innerHTML=html;this.bContentReady=true;},setContentURL:function(url){this.bContentReady=false;this.setBusy(true);if(arguments[1]){this.onContentReady=arguments[1];}
+if(url.indexOf('?')==-1){url=url+'?';}
+var opts={method:'get',onComplete:this.panelContentLoaded.bind(this),requestHeaders:['If-Modified-Since','Sat, 1 Jan 2000 00:00:00 GMT']};var a=new Ajax.Request(url,opts);},panelContentLoaded:function(r){this.content.innerHTML=r.responseText;this.bContentReady=true;this.setBusy(false);if(this.onContentReady){window.setTimeout(this.onContentReady.bind(this),1);}},setBusy:function(isBusy){this.busyCount+=isBusy?1:-1;this.loadingObj.img.style.visibility=(this.busyCount>0)?'visible':'hidden';},sizeChanged:function(){var top=0;var bottom=0;if(this.menubar){this.menubar.style.height='';var size=Element.getBorderBoxSize(this.menubar);this.menubar.resize({height:size.height});top+=size.height;}
+if(this.toolbar){this.toolbar.style.height='';var size=Element.getBorderBoxSize(this.toolbar);this.toolbar.resize({height:size.height});top+=size.height;}
+if(this.statusbar){this.statusbar.style.height='';var size=Element.getBorderBoxSize(this.statusbar);this.statusbar.resize({height:size.height});bottom+=size.height;}
+if(top||bottom){this.content.resize({bottom:bottom,top:top});}}};Object.extend(Jx.Panel.prototype,Jx.UniqueId.prototype);Object.extend(Jx.Panel.prototype,Jx.ContentLoader.prototype);Jx.addStyleSheet('picker/picker.css');Jx.Picker=Class.create();Jx.Picker.prototype={sl:null,domObj:null,ul:null,currentSelection:null,isEditable:false,initialize:function(options){options=options||{};this.domObj=document.createElement('div');this.domObj.className='jxPicker';this.isEditable=options.editable||false;if(this.isEditable){this.domInput=document.createElement('input');this.domInput.type='text';Event.observe(this.domInput,'change',this.valueChanged.bind(this));Event.observe(this.domInput,'keydown',this.onKeyPress.bind(this));}else{this.domInput=document.createElement('span');}
+this.domInput.className='jxPickerInput';this.domObj.appendChild(this.domInput);this.domA=document.createElement('a');this.domA.href='javascript:void(0)';this.domA.className='jxPickerDiscloser';Event.observe(this.domA,'click',this.toggle.bind(this));this.domButton=document.createElement('img');this.domButton.src=Jx.baseURL+'images/disclose2.png';Element.addClassName(this.domButton,'png24');this.domA.appendChild(this.domButton);this.domObj.appendChild(this.domA);if(!window.opera){var iframe=document.createElement('iframe');iframe.className='jxDialogShim';iframe.scrolling='no';iframe.frameborder=0;this.domObj.appendChild(iframe);}
+this.domListDiv=document.createElement('div');this.domListDiv.className='jxPickerOptions';this.domListDiv.style.display='none';this.domObj.appendChild(this.domListDiv);this.domList=document.createElement('ul');this.domListDiv.appendChild(this.domList);this.sl=[];},onKeyPress:function(e){var charCode=(e.charCode)?e.charCode:((e.keyCode)?e.keyCode:e.which);if(charCode==Event.KEY_RETURN){this.valueChanged();}},valueChanged:function(){this.processEvent(this.sl,'selectionChanged',this);},add:function(domObj,idx){var li=document.createElement('li');var a=document.createElement('a');a.href="javascript:void(0)";if(typeof(domObj)=='string'){a.innerHTML=domObj;}else{a.appendChild(domObj);}
+Event.observe(a,'click',this.pick.bindAsEventListener(this));li.appendChild(a);if(arguments.length>1&&this.domList.childNodes.length>idx){this.domList.insertBefore(li,this.domList.childNodes[idx]);}else{this.domList.appendChild(li);}},remove:function(idx){if(idx>0&&idx<this.domList.childNodes.length){this.domList.removeChild(this.domList.childNodes[idx]);}},pick:function(e){var target=Event.element(e);if(target.tagName=='A'){this.currentSelection=target;this.setValue(this.currentSelection.childNodes[0]);this.valueChanged();}
+this.close();},setValue:function(value){if(this.isEditable){if(typeof(value)=='string'){this.domInput.value=value;}else if(value.nodeType&&value.nodeType==3){this.domInput.value=value.nodeValue;}else{this.domInput.value=value.innerHTML;}}else if(!this.isEditable){if(typeof(value)=='string'){this.domInput.innerHTML=value;}else if(value.nodeType&&value.nodeType==3){this.domInput.innerHTML=value.nodeValue;}else{this.domInput.appendChild(value);}}},getValue:function(){value='';if(this.isEditable){value=this.domInput.value;}else{if(this.domInput.childNodes[0].nodeType==3){value=this.domInput.innerHTML;}else{value=this.domInput.childNodes[0];}}
+return value;},toggle:function(){if(this.domListDiv.style.display=='block'){this.close();}else{this.open();}},open:function(){if(!this.keypressListener){this.keypressListener=this.keypress.bindAsEventListener(this);}
+this.domListDiv.style.display='block';Event.observe(document,'keypress',this.keypressListener);},keypress:function(e){var charCode=(e.charCode)?e.charCode:e.keyCode;if(charCode==Event.KEY_ESC){this.close();}},close:function(){this.domListDiv.style.display='none';Event.stopObserving(document,'keypress',this.keypressListener);},addSelectionListener:function(obj){this.addListener(this.sl,obj);},removeSelectionListener:function(obj){this.removeListener(this.sl,obj);},getSelection:function(){return this.currentSelection?this.currentSelection.name:'';}};Object.extend(Jx.Picker.prototype,Jx.Listener.prototype);Jx.Splitter=Class.create();Jx.Splitter.prototype={domObj:null,elements:null,bars:null,firstUpdate:true,initialize:function(domObj,options){options=options||{};this.domObj=$(domObj);this.domObj.style.overflow='hidden';if(this.domObj.jxLayout){this.domObj.jxLayout.addSizeChangeListener(this);}
+this.elements=[];this.bars=[];var nSplits=options.splitInto||(options.elements?options.elements.length:2);var aContainerOpts=options.containerOptions||[];for(var i=0;i<nSplits;i++){this.elements[i]=options.elements?options.elements[i]:this.prepareElement();this.domObj.appendChild(this.elements[i]);if(!this.elements[i].jxLayout){new Jx.Layout(this.elements[i],aContainerOpts[i]);}}
+for(var i=1;i<nSplits;i++){this.bars[i-1]=this.prepareBar();this.bars[i-1].leftSide=this.elements[i-1];this.bars[i-1].rightSide=this.elements[i];this.elements[i-1].rightBar=this.bars[i-1];this.elements[i].leftBar=this.bars[i-1];this.domObj.appendChild(this.bars[i-1]);}
+this.layout=options.layout||'horizontal';this.establishConstraints();if(options.snappers){for(var i=0;i<options.snappers.length;i++){if(options.snappers[i]){new Jx.Splitter.Snapper(options.snappers[i],this.elements[i],this);}}}},prepareElement:function(){var o=document.createElement('div');o.style.position='absolute';o.leftBar=null;o.rightBar=null;return o;},prepareBar:function(){var o=document.createElement('div');o.className='jxSplitterBar';o.style.position='absolute';o.title='drag this bar to resize';o.style.lineHeight='1px';o.splitterObj=this;return o;},establishConstraints:function(){if(this.layout=='horizontal'){for(var i=0;i<this.bars.length;i++){this.bars[i].style.top='0px';this.bars[i].style.height='100%';new Draggable(this.bars[i],{constraint:'horizontal',starteffect:function(element){element.style.backgroundColor='#eee';},endeffect:function(element){element.style.backgroundColor='';}});}}else{for(var i=0;i<this.bars.length;i++){this.bars[i].style.left='0px';this.bars[i].style.width='100%';new Draggable(this.bars[i],{constraint:'vertical',starteffect:function(element){element.style.backgroundColor='#eee';},endeffect:function(element){element.style.backgroundColor='';}});}}
+Draggables.addObserver(this);},onEnd:function(eventName,obj,event){if(obj.element.splitterObj!=this){return;}
+if(this.layout=='horizontal'){this.dragHorizontal(eventName,obj,event);}else{this.dragVertical(eventName,obj,event);}},dragHorizontal:function(eventName,obj,event){var leftEdge=parseInt(obj.element.style.left);var leftSide=obj.element.leftSide;var rightSide=obj.element.rightSide;var rsLeft,rsWidth,rsRight;if(!obj.element.size){obj.element.size=Element.getBorderBoxSize(obj.element);}
+var barSize=obj.element.size;rsLeft=leftEdge+barSize.width;var parentSize=Element.getContentBoxSize(this.domObj);if(rightSide.jxLayout.options.width!=null){rsWidth=rightSide.jxLayout.options.width+rightSide.jxLayout.options.left-rsLeft;rsRight=parentSize.width-rsLeft-rsWidth;}else{rsWidth=parentSize.width-rightSide.jxLayout.options.right-rsLeft;rsRight=rightSide.jxLayout.options.right;}
+if(rsWidth<0){rsWidth=0;}
+if(rsWidth<rightSide.jxLayout.options.minWidth){rsWidth=rightSide.jxLayout.options.minWidth;}
+if(rightSide.jxLayout.options.maxWidth>=0&&rsWidth>rightSide.jxLayout.options.maxWidth){rsWidth=rightSide.jxLayout.options.maxWidth;}
+rsLeft=parentSize.width-rsRight-rsWidth;leftEdge=rsLeft-barSize.width;var lsLeft,lsWidth;lsLeft=leftSide.jxLayout.options.left;lsWidth=leftEdge-lsLeft;if(lsWidth<0){lsWidth=0;}
+if(lsWidth<leftSide.jxLayout.options.minWidth){lsWidth=leftSide.jxLayout.options.minWidth;}
+if(leftSide.jxLayout.options.maxWidth>=0&&lsWidth>leftSide.jxLayout.options.maxWidth){lsWidth=leftSide.jxLayout.options.maxWidth;}
+if(lsLeft+lsWidth!=leftEdge){leftEdge=lsLeft+lsWidth;var delta=leftEdge+barSize.width-rsLeft;rsLeft+=delta;rsWidth-=delta;}
+obj.element.style.left=leftEdge+'px';if(leftSide.jxLayout.options.width==null){var parentSize=Element.getContentBoxSize(this.domObj);leftSide.jxLayout.resize({right:parentSize.width-lsLeft-lsWidth});}else{leftSide.jxLayout.resize({width:lsWidth});}
+if(rightSide.jxLayout.options.width==null){rightSide.jxLayout.resize({left:rsLeft});}else{rightSide.jxLayout.resize({left:rsLeft,width:rsWidth});}},dragVertical:function(eventName,obj,event){var topEdge=parseInt(obj.element.style.top);var topSide=obj.element.leftSide;var bottomSide=obj.element.rightSide;if(!obj.element.size){obj.element.size=Element.getBorderBoxSize(obj.element);}
+var barSize=obj.element.size;var parentSize=Element.getContentBoxSize(this.domObj);var bsTop,bsHeight,bsBottom;bsTop=topEdge+barSize.height;if(bottomSide.jxLayout.options.height!=null){bsHeight=bottomSide.jxLayout.options.height+bottomSide.jxLayout.options.top-bsTop;bsBottom=parentSize.height-bsTop-bsHeight;}else{bsHeight=parentSize.height-bottomSide.jxLayout.options.bottom-bsTop;bsBottom=bottomSide.jxLayout.options.bottom;}
+if(bsHeight<0){bsHeight=0;}
+if(bsHeight<bottomSide.jxLayout.options.minHeight){bsHeight=bottomSide.jxLayout.options.minHeight;}
+if(bottomSide.jxLayout.options.maxHeight>=0&&bsHeight>bottomSide.jxLayout.options.maxHeight){bsHeight=bottomSide.jxLayout.options.maxHeight;}
+bsTop=parentSize.height-bsBottom-bsHeight;topEdge=bsTop-barSize.height;var tsTop,tsHeight;tsTop=topSide.jxLayout.options.top;tsHeight=topEdge-tsTop;if(tsHeight<0){tsHeight=0;}
+if(tsHeight<topSide.jxLayout.options.minHeight){tsHeight=topSide.jxLayout.options.minHeight;}
+if(topSide.jxLayout.options.maxHeight>=0&&tsHeight>topSide.jxLayout.options.maxHeight){tsHeight=topSide.jxLayout.options.maxHeight;}
+if(tsTop+tsHeight!=topEdge){topEdge=tsTop+tsHeight;var delta=topEdge+barSize.height-bsTop;bsTop+=delta;bsHeight-=delta;}
+obj.element.style.top=topEdge+'px';if(topSide.jxLayout.options.height==null){topSide.jxLayout.resize({bottom:parentSize.height-tsTop-tsHeight});}else{topSide.jxLayout.resize({height:tsHeight});}
+if(bottomSide.jxLayout.options.height==null){bottomSide.jxLayout.resize({top:bsTop});}else{bottomSide.jxLayout.resize({top:bsTop,height:bsHeight});}},sizeChanged:function(){if(this.layout=='horizontal'){this.horizontalResize();}else{this.verticalResize();}},horizontalResize:function(){var availableSpace=Element.getContentBoxSize(this.domObj).width;var overallWidth=availableSpace;for(var i=0;i<this.bars.length;i++){var bar=this.bars[i];if(!bar.size){bar.size=Element.getBorderBoxSize(bar);}
+availableSpace-=bar.size.width;}
+var nVariable=0;var jxo;for(var i=0;i<this.elements.length;i++){var e=this.elements[i];jxo=e.jxLayout.options;if(jxo.width!=null){availableSpace-=parseInt(jxo.width);}else{var w=0;if(jxo.right!=0||jxo.left!=0){w=Element.getBorderBoxSize(e).width;}
+availableSpace-=w;nVariable++;}}
+if(nVariable==0){availableSpace+=jxo.width;jxo.width=null;nVariable=1;}
+var amount=parseInt(availableSpace/nVariable);var remainder=availableSpace%nVariable;var currentPosition=0;for(var i=0;i<this.elements.length;i++){var e=this.elements[i];var jxl=e.jxLayout;var jxo=jxl.options;if(jxo.width!=null){jxl.resize({left:currentPosition});currentPosition+=jxo.width;}else{var a=amount;if(nVariable==1){a+=remainder;}
+nVariable--;var w=0;if(jxo.right!=0||jxo.left!=0){w=Element.getBorderBoxSize(e).width+a;}else{w=a;}
+if(w<0){if(nVariable>0){amount=amount+w/nVariable;}
+w=0;}
+if(w<jxo.minWidth){if(nVariable>0){amount=amount+(w-jxo.minWidth)/nVariable;}
+w=jxo.minWidth;}
+if(jxo.maxWidth>=0&&w>jxo.maxWidth){if(nVariable>0){amount=amount+(w-jxo.maxWidth)/nVariable;}
+w=e.options.maxWidth;}
+var r=overallWidth-currentPosition-w;jxl.resize({left:currentPosition,right:r});currentPosition+=w;}
+if(e.rightBar){e.rightBar.style.left=currentPosition+'px';currentPosition+=e.rightBar.size.width;}}},verticalResize:function(){var availableSpace=Element.getContentBoxSize(this.domObj).height;var overallHeight=availableSpace;for(var i=0;i<this.bars.length;i++){var bar=this.bars[i];if(!bar.size){bar.size=Element.getBorderBoxSize(bar);}
+availableSpace-=bar.size.height;}
+var nVariable=0;var jxo;for(var i=0;i<this.elements.length;i++){var e=this.elements[i];jxo=e.jxLayout.options;if(jxo.height!=null){availableSpace-=parseInt(jxo.height);}else{var h=0;if(jxo.bottom!=0||jxo.top!=0){h=Element.getBorderBoxSize(e).height;}
+availableSpace-=h;nVariable++;}}
+if(nVariable==0){availableSpace+=jxo.height;jxo.height=null;nVariable=1;}
+var amount=parseInt(availableSpace/nVariable);var remainder=availableSpace%nVariable;var currentPosition=0;for(var i=0;i<this.elements.length;i++){var e=this.elements[i];var jxl=e.jxLayout;var jxo=jxl.options;if(jxo.height!=null){jxl.resize({top:currentPosition});currentPosition+=jxo.height;}else{var a=amount;if(nVariable==1){a+=remainder;}
+nVariable--;var h=0;if(jxo.bottom!=0||jxo.top!=0){h=Element.getBorderBoxSize(e).height+a;}else{h=a;}
+if(h<0){if(nVariable>0){amount=amount+h/nVariable;}
+h=0;}
+if(h<jxo.minHeight){if(nVariable>0){amount=amount+(h-jxo.minHeight)/nVariable;}
+h=jxo.minHeight;}
+if(jxo.maxHeight>=0&&h>jxo.maxHeight){if(nVariable>0){amount=amount+(h-jxo.maxHeight)/nVariable;}
+h=jxo.maxHeight;}
+var r=overallHeight-currentPosition-h;jxl.resize({top:currentPosition,bottom:r});currentPosition+=h;}
+if(e.rightBar){e.rightBar.style.top=currentPosition+'px';currentPosition+=e.rightBar.size.height;}}}};Jx.Splitter.Snapper=Class.create();Jx.Splitter.Snapper.prototype={snapper:null,element:null,splitter:null,layout:'vertical',initialize:function(snapper,element,splitter){this.snapper=snapper;this.element=element;element.jxLayout.addSizeChangeListener(this);this.splitter=splitter;this.layout=splitter.layout;var jxo=this.element.jxLayout.options;var size=Element.getBorderBoxSize(this.element);if(this.layout=='vertical'){this.originalSize=size.height;this.minimumSize=jxo.minHeight?jxo.minHeight:0;}else{this.originalSize=size.width;this.minimumSize=jxo.minWidth?jxo.minWidth:0;}
+Event.observe(snapper,'click',this.toggleElement.bind(this));},toggleElement:function(){var size=Element.getBorderBoxSize(this.element);var newSize={};if(this.layout=='vertical'){if(size.height==this.minimumSize){newSize.height=this.originalSize;}else{this.originalSize=size.height;newSize.height=this.minimumSize;}}else{if(size.width==this.minimumSize){newSize.width=this.originalSize;}else{this.originalSize=size.width;newSize.width=this.minimumSize;}}
+this.element.jxLayout.resize(newSize);this.splitter.sizeChanged();},sizeChanged:function(){var size=Element.getBorderBoxSize(this.element);if(this.layout=='vertical'){if(size.height==this.minimumSize){Element.addClassName(this.snapper,'jxSnapClosed');Element.removeClassName(this.snapper,'jxSnapOpened');}else{Element.addClassName(this.snapper,'jxSnapOpened');Element.removeClassName(this.snapper,'jxSnapClosed');}}else{if(size.width==this.minimumSize){Element.addClassName(this.snapper,'jxSnapClosed');Element.removeClassName(this.snapper,'jxSnapOpened');}else{Element.addClassName(this.snapper,'jxSnapOpened');Element.removeClassName(this.snapper,'jxSnapClosed');}}}};Jx.addStyleSheet('tab/tabs.css');Jx.addStyleSheet('tabs/tabs_ie.css',true);Jx.TabSet=Class.create();Jx.TabSet.prototype={domObj:null,sl:null,initialize:function(domObj){this.domObj=$(domObj);if(!Element.hasClassName(this.domObj,'jxTabSetContainer')){Element.addClassName(this.domObj,'jxTabSetContainer');}
+this.sl=[];},sizeChanged:function(){this.resizeTabBox();},resizeTabBox:function(){var parentSize=Element.getContentBoxSize(this.domObj.parentNode);Element.setBorderBoxSize(this.domObj,{width:parentSize.width,height:parentSize.height});for(var i=0;i<this.domObj.childNodes.length;i++){if(this.domObj.childNodes[i].nodeType==3){continue;}
+Element.setBorderBoxSize(this.domObj.childNodes[i],{height:parentSize.height});if(this.domObj.childNodes[i].resize){this.domObj.childNodes[i].resize({forceResize:true});}}},add:function(){for(var i=0;i<arguments.length;i++){var tab=arguments[i];tab.addSelectionListener(this);this.domObj.appendChild(tab.content);if(!this.activeTab){this.setActiveTab(tab);}}},remove:function(tab){},setActiveTab:function(tab){if(this.activeTab){Element.removeClassName(this.activeTab.domObj,'tabActive');Element.removeClassName(this.activeTab.content,'tabContentActive');}
+this.activeTab=tab;Element.addClassName(this.activeTab.domObj,'tabActive');Element.addClassName(this.activeTab.content,'tabContentActive');if(this.activeTab.content.resize){this.activeTab.content.resize({forceResize:true});}},selectionChanged:function(tab){this.setActiveTab(tab);this.processEvent(this.sl,'selectionChanged',tab);},addSelectionListener:function(obj){this.addListener(this.sl,obj);},removeSelectionListener:function(obj){this.removeListener(this.sl,obj);}};Object.extend(Jx.TabSet.prototype,Jx.Listener.prototype);Jx.Tab=Class.create();Jx.Tab.prototype={domObj:null,content:null,name:null,sl:null,initialize:function(name,options){this.sl=[];options=options||{};this.name=name;this.content=document.createElement('div');this.content.className='tabContent';this.loadContent(this.content,options);var a=new Jx.Action(this.clicked.bind(this));var b=new Jx.Button(a,{label:name});this.domObj=b.domA;Element.addClassName(this.domObj,'jxTab');new Jx.Layout(this.content,options);},clicked:function(){this.processEvent(this.sl,'selectionChanged',this);this.domObj.childNodes[0].blur();},addSelectionListener:function(obj){this.addListener(this.sl,obj);},removeSelectionListener:function(obj){this.removeListener(this.sl,obj);}};Object.extend(Jx.Tab.prototype,Jx.Listener.prototype);Object.extend(Jx.Tab.prototype,Jx.ContentLoader.prototype);Jx.TabBox=Class.create();Jx.TabBox.prototype={tabBar:null,tabSet:null,initialize:function(domObj,position){var parent=$(domObj);position=position||'top';var tabBarDiv=document.createElement('div');parent.appendChild(tabBarDiv);this.tabBar=new Jx.Toolbar(tabBarDiv,position);this.tabSet=new Jx.TabSet(parent);switch(position){case'top':Element.addClassName(parent,'jxTabBoxTop');break;case'bottom':Element.addClassName(parent,'jxTabBoxBottom');break;case'left':Element.addClassName(parent,'jxTabBoxLeft');Element.addClassName(tabBarDiv,'verticalToolbar');break;case'right':Element.addClassName(parent,'jxTabBoxRight');Element.addClassName(tabBarDiv,'verticalToolbar');break;}
+this.sl=[];},sizeChanged:function(){this.tabSet.sizeChanged();},add:function(){this.tabBar.add.apply(this.tabBar,arguments);this.tabSet.add.apply(this.tabSet,arguments);},remove:function(tab){}};Object.extend(Jx.TabBox.prototype,Jx.Listener.prototype);Jx.addStyleSheet('toolbar/toolbar.css');Jx.addStyleSheet('button/button.css');Jx.Toolbar=Class.create();Jx.Toolbar.prototype={items:null,domObj:null,isActive:false,initialize:function(domObj,position){var parent=$(domObj);this.domObj=document.createElement('ul');Element.addClassName(this.domObj,'jxToolbar');if(!Element.hasClassName(parent,'jxToolbarContainer')){Element.addClassName(parent,'jxToolbarContainer');parent.appendChild(this.domObj);var clearer=document.createElement('div');clearer.className='jxClearer';parent.appendChild(clearer);}else{parent.insertBefore(this.domObj,parent.lastChild);}
+switch(position){case'top':Element.addClassName(parent,'jxBarTop');break;case'right':Element.addClassName(parent,'jxBarRight');break;case'bottom':Element.addClassName(parent,'jxBarBottom');break;case'left':Element.addClassName(parent,'jxBarLeft');break;default:Element.addClassName(parent,'jxBarTop');}
+this.deactivateWatcher=this.deactivate.bindAsEventListener(this);},add:function(){for(var i=0;i<arguments.length;i++){var thing=arguments[i];thing.toolbar=this;if(thing.domObj){thing=thing.domObj;}
+if(thing.tagName=='LI'){if(!Element.hasClassName(thing,'jxToolItem')){Element.addClassName(thing,'jxToolItem');}
+this.domObj.appendChild(thing);}else{var item=new Jx.ToolbarItem(thing);this.domObj.appendChild(item.domObj);}}},deactivate:function(){for(var i=0;i<this.items.length;i++){this.items[i].hide();}
+this.setActive(false);},isActive:function(){return this.isActive;},setActive:function(b){this.isActive=b;if(this.isActive){Event.observe(document,'click',this.deactivateWatcher);}else{Event.stopObserving(document,'click',this.deactivateWatcher);}},setVisibleItem:function(obj){if(this.visibleItem&&this.visibleItem.hide&&this.visibleItem!=obj){this.visibleItem.hide();}
+this.visibleItem=obj;if(this.isActive()){this.visibleItem.show();}}};Jx.ToolbarItem=Class.create();Jx.ToolbarItem.prototype={domObj:null,initialize:function(jxThing){this.al=[];this.domObj=document.createElement('li');this.domObj.className='jxToolItem';if(jxThing){if(jxThing.domObj){this.domObj.appendChild(jxThing.domObj);if(jxThing instanceof Jx.Tab){Element.addClassName(this.domObj,'jxTabItem');}}else{this.domObj.appendChild(jxThing);if(Element.hasClassName(jxThing,'jxTab')){Element.addClassName(this.domObj,'jxTabItem');}}}}};Jx.ToolbarSeparator=Class.create();Jx.ToolbarSeparator.prototype={domObj:null,initialize:function(){this.domObj=document.createElement('li');this.domObj.className='jxToolItem';this.domSpan=document.createElement('span');this.domSpan.className='separator';this.domObj.appendChild(this.domSpan);}};Jx.addStyleSheet('tree/tree.css');Jx.addStyleSheet('tree/tree_ie.css',true);Jx.TreeItem=Class.create();Jx.TreeItem.prototype={data:null,domObj:null,parent:null,currentClassName:null,onClick:null,sl:null,enabled:null,contextMenu:null,initialize:function(options){this.initializeItem(options);},initializeItem:function(options){options=options||{};this.sl=[];var label=options.label||'new node';this.data=options.data||null;this.contextMenu=options.contextMenu||null;this.imgNode=options.imgNode||Jx.baseURL+'images/tree_none.png';this.imgIcon=options.imgIcon||Jx.baseURL+'images/tree_page.png';this.domObj=document.createElement('li');this.domObj.className='jxTreeNode';this.currentClassName='jxTreeNode';var elm=document.createElement('img');elm.className='jxTreeNodeImage';Jx.addToImgQueue({domElement:elm,src:this.imgNode});this.domObj.appendChild(elm);elm=document.createElement('img');elm.className='jxTreeNodeIcon';Jx.addToImgQueue({domElement:elm,src:this.imgIcon});this.domObj.appendChild(elm);elm=document.createElement('a');elm.href='javascript:void(0)';elm.onclick=this.selected.bindAsEventListener(this);elm.ondblclick=this.selected.bindAsEventListener(this);elm.oncontextmenu=this.showMenu.bindAsEventListener(this);elm.innerHTML=label;this.domObj.appendChild(elm);this.domObj.jxTreeItem=this;this.domObj.childNodes[2].jxTreeItem=this;this.onClick=options.onClick||null;this.enabled=typeof options.enabled!='undefined'?options.enabled:true;if(this.enabled){Element.removeClassName(this.domObj,'jxDisabled');}else{Element.addClassName(this.domObj,'jxDisabled');}
+var clearer=document.createElement('span');clearer.className='jxClearer';this.domObj.appendChild(clearer);},finalize:function(){this.finalizeItem();},finalizeItem:function(){if(!this.domObj){return;}
+this.domObj.childNodes[2].onclick=null;this.domObj.childNodes[2].ondblclick=null;this.domObj.childNodes[2].oncontextmenu=null;this.contextMenu=null;this.onClick=null;for(var i=this.sl.length;i>=0;i--){this.removeSelectionListener(this.sl[i]);}
+this.parent=null;this.domObj.jxTreeItem=null;this.domObj=null;},clone:function(){var options={label:this.domObj.childNodes[2].innerHTML,data:this.data,onClick:this.onClick,imgNode:this.imgNode,imgIcon:this.imgIcon};var item=new Jx.TreeItem(options);return item;},update:function(shouldDescend){var isLast=(arguments.length>1)?arguments[1]:(this.parent&&this.parent.isLastNode(this));if(isLast){Element.removeClassName(this.domObj,'jxTreeNode');Element.addClassName(this.domObj,'jxTreeNodeLast');}else{Element.removeClassName(this.domObj,'jxTreeNodeLast');Element.addClassName(this.domObj,'jxTreeNode');}},selected:function(e){this.lastEvent=e?e:event;this.processEvent(this.sl,'selectionChanged',this);},showMenu:function(e){this.lastEvent=e?e:event;this.processEvent(this.sl,'selectionChanged',this);if(this.contextMenu){this.contextMenu.show(this.lastEvent);}
+Event.stop(e);},addSelectionListener:function(obj){this.addListener(this.sl,obj);},removeSelectionListener:function(obj){this.removeListener(this.sl,obj);},getName:function(){return this.domObj.childNodes[2].innerHTML;},setName:function(name){this.domObj.childNodes[2].innerHTML=name;},propertyChanged:function(obj){this.enabled=obj.isEnabled();if(this.enabled){Element.removeClassName(this.domObj,'jxDisabled');}else{Element.addClassName(this.domObj,'jxDisabled');}}};Object.extend(Jx.TreeItem.prototype,Jx.Listener.prototype);Jx.TreeFolder=Class.create();Object.extend(Jx.TreeFolder.prototype,Jx.TreeItem.prototype);Object.extend(Jx.TreeFolder.prototype,{subDomObj:null,nodes:null,isOpen:false,dl:null,initialize:function(options){this.initializeFolder(options);},initializeFolder:function(options){options=options||{};this.initializeItem(options);this.imgTreePlus=options.imgTreePlus||Jx.baseURL+'images/tree_plus.png';this.imgTreeMinus=options.imgTreeMinus||Jx.baseURL+'images/tree_minus.png';this.imgTreeFolder=options.imgTreeFolder||Jx.baseURL+'images/tree_folder.png';this.imgTreeFolderOpen=options.imgTreeFolderOpen||Jx.baseURL+'images/tree_folder_open.png';Jx.addToImgQueue({domElement:this.domObj.childNodes[0],src:this.imgTreePlus});Jx.addToImgQueue({domElement:this.domObj.childNodes[1],src:this.imgTreeFolder});this.domObj.childNodes[0].onclick=this.clicked.bindAsEventListener(this);this.nodes=[];this.subDomObj=document.createElement('ul');this.domObj.appendChild(this.subDomObj);this.subDomObj.className='jxTree';this.isOpen=options.isOpen||false;this.dl=[];if(this.isOpen){this.expand();}else{this.collapse();}},finalize:function(){this.finalizeFolder();this.finalizeItem();this.subDomObj=null;},finalizeFolder:function(){this.domObj.childNodes[0].onclick=null;for(var i=this.nodes.length-1;i>=0;i--){this.nodes[i].finalize();if(this.nodes[i].domObj)this.subDomObj.removeChild(this.nodes[i].domObj);this.nodes.pop();}
+for(var i=this.dl.length-1;i>=0;i--){this.removeDisclosureListener(this.dl[i]);}},clone:function(){var options={label:this.domObj.childNodes[2].innerHTML,data:this.data,onClick:this.onClick,imgTreePlus:this.imgTreePlus,imgTreeMinus:this.imgTreeMinus,imgTreeFolder:this.imgTreeFolder,imgTreeFolderOpen:this.imgTreeFolderOpen};var node=new Jx.TreeFolder(options);for(var i=0;i<this.nodes.length;i++){node.append(this.nodes[i].clone());}
+return node;},isLastNode:function(node){if(this.nodes.length==0){return false;}else{return this.nodes[this.nodes.length-1]==node;}},update:function(bDescend){if(!this.parent)return;var bLast=false;if(arguments.length>1){bLast=arguments[1];}else{bLast=(this.parent&&this.parent.isLastNode(this));}
+if(bLast){this.domObj.className='jxTreeNodeLast';this.subDomObj.className='jxTree';}else{this.domObj.className='jxTreeNode';this.subDomObj.className='jxTree jxTreeNest';}
+if(this.isOpen){Jx.addToImgQueue({domElement:this.domObj.childNodes[0],src:this.imgTreeMinus});Jx.addToImgQueue({domElement:this.domObj.childNodes[1],src:this.imgTreeFolderOpen});}else{Jx.addToImgQueue({domElement:this.domObj.childNodes[0],src:this.imgTreePlus});Jx.addToImgQueue({domElement:this.domObj.childNodes[1],src:this.imgTreeFolder});}
+if(this.nodes&&bDescend){for(var i=0;i<this.nodes.length;i++){this.nodes[i].update(false,i==this.nodes.length-1);}}},append:function(node){node.parent=this;this.nodes.push(node);this.subDomObj.appendChild(node.domObj);this.update(true);},insert:function(node,refNode){node.parent=this;if(!refNode){this.nodes.unshift(node);if(this.subDomObj.childNodes.length==0){this.subDomObj.appendChild(node.domObj);}else{this.subDomObj.insertBefore(node.domObj,this.subDomObj.childNodes[0]);}}else{var b=false;for(var i=0;i<this.nodes.length;i++){if(this.nodes[i]==refNode){i=i+1;if(i<this.nodes.length){this.nodes.splice(i,0,node);this.subDomObj.insertBefore(node.domObj,this.subDomObj.childNodes[i]);b=true;break;}}}
+if(!b){this.nodes.push(node);this.subDomObj.appendChild(node.domObj);}}
+this.update(true);},remove:function(node){node.parent=null;for(var i=0;i<this.nodes.length;i++){if(this.nodes[i]==node){this.nodes.splice(i,1);this.subDomObj.removeChild(this.subDomObj.childNodes[i]);break;}}
+this.update(true);},replace:function(newNode,refNode){var b=false;for(var i=0;i<this.nodes.length;i++){if(this.nodes[i]==refNode){if(i<this.nodes.length){newNode.parent=this;this.nodes.splice(i,1,newNode);this.subDomObj.replaceChild(newNode.domObj,refNode.domObj);return true;}}}
+return false;},clicked:function(e){e=e?e:event;if(this.isOpen){this.collapse();}else{this.expand();}},expand:function(){this.isOpen=true;this.subDomObj.style.display='block';this.update(true);this.processEvent(this.dl,'disclosed',this);},collapse:function(){this.isOpen=false;this.subDomObj.style.display='none';this.update(true);this.processEvent(this.dl,'disclosed',this);},addDisclosureListener:function(obj){this.addListener(this.dl,obj);},removeDisclosureListener:function(obj){this.removeListener(this.dl,obj);},findChild:function(path){if(path.length==0)
+return this;if(path.length==1)
+{for(var i=0;i<this.nodes.length;i++)
+{if(this.nodes[i].getName()==path[0])
+return this.nodes[i];}
+return null;}
+var childName=path.shift();for(var i=0;i<this.nodes.length;i++)
+{if(this.nodes[i].getName()==childName&&this.nodes[i].findChild)
+return this.nodes[i].findChild(path);}
+return null;}});Jx.Tree=Class.create();Object.extend(Jx.Tree.prototype,Jx.TreeFolder.prototype);Object.extend(Jx.Tree.prototype,{initialize:function(id){this.subDomObj=document.createElement('ul');this.subDomObj.className='jxTreeRoot';$(id).appendChild(this.subDomObj);this.nodes=[];this.dl=[];this.isOpen=true;},finalize:function(){this.clear();this.subDomObj.parentNode.removeChild(this.subDomObj);},clear:function(){for(var i=this.nodes.length-1;i>=0;i--){this.subDomObj.removeChild(this.nodes[i].domObj);this.nodes[i].finalize();this.nodes.pop();}},update:function(shouldDescend){var bLast=true;if(this.subDomObj)
+{if(bLast){Element.removeClassName(this.subDomObj,'jxTreeNest');}else{Element.addClassName(this.subDomObj,'jxTreeNest');}}
+if(this.nodes&&shouldDescend){this.nodes.each(function(n){n.update(false);});}},append:function(node){node.parent=this;this.nodes.push(node);this.subDomObj.appendChild(node.domObj);this.update(true);}});if(Jx.COMBINED_CSS){document.write('<link type="text/css" rel="stylesheet" href="'+Jx.baseURL+'lib/jx_combined.css" />\n');}else{for(var styleSheet in Jx.importRules){var url=Jx.baseURL+styleSheet;document.write('<link type="text/css" rel="stylesheet" href="'+url+'" />\n');}
+document.write('<!--[if IE]>');for(var styleSheet in Jx.importRulesIE){var url=Jx.baseURL+styleSheet;document.write('<link type="text/css" rel="stylesheet" href="'+url+'" />\n');}
+document.write('<![endif]-->\n');}
\ No newline at end of file
More information about the fusion-commits
