[fusion-commits] r1225 - in trunk: MapGuide lib widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon Mar 10 09:30:25 EDT 2008
Author: pagameba
Date: 2008-03-10 09:30:23 -0400 (Mon, 10 Mar 2008)
New Revision: 1225
   trunk/MapGuide/MapGuide.js
   trunk/lib/ApplicationDefinition.js
   trunk/widgets/Legend.js
Re #20.  Initial rework of Links and LayerEvents support, needs testing.
Modified: trunk/MapGuide/MapGuide.js
--- trunk/MapGuide/MapGuide.js	2008-03-10 13:29:17 UTC (rev 1224)
+++ trunk/MapGuide/MapGuide.js	2008-03-10 13:30:23 UTC (rev 1225)
@@ -876,6 +876,28 @@
         var params = {};
         params.parameters = 'session='+this.getSessionID();
         Fusion.ajaxRequest(s, params);
+    getGroupInfoUrl: function(groupName) {
+        if (this.mapInfo) {
+            var groups = this.mapInfo.links.groups;
+            for (var i=0; i<groups.length; i++) {
+                if (groups[i].name == groupName) {
+                    return groups[i].url;
+        return null;
+    getLayerInfoUrl: function(layerName) {
+            var layers = this.mapInfo.links.layers;
+            for (var i=0; i<layers.length; i++) {
+                if (layers[i].name == layerName) {
+                    return layers[i].url;
+        return null;
Modified: trunk/lib/ApplicationDefinition.js
--- trunk/lib/ApplicationDefinition.js	2008-03-10 13:29:17 UTC (rev 1224)
+++ trunk/lib/ApplicationDefinition.js	2008-03-10 13:30:23 UTC (rev 1225)
@@ -418,61 +418,59 @@
         if (jsonNode.Map instanceof Array) {
             for (var i=0; i<jsonNode.Map.length; i++) {
                 var map = new Fusion.Lib.ApplicationDefinition.Map(jsonNode.Map[i]);
-                this.maps.push(map);
-        } else {
-            //TODO: do we need a warning that there are no layers in this map?
-        this.links = {groups:[], layers:[]};
-        this.layerEvents = {};
-        if (jsonNode.Extension) {
-            var extension = jsonNode.Extension[0];
-            if (extension.Links) {
-                /* process Groups */
-                if (extension.Links[0].Group instanceof Array) {
-                    for (var j=0; j<extension.Links[0].Group.length; j++) {
-                        var group = extension.Links[0].Group[j];
-                        this.links.groups.push({name:group.Name,url:group.Url});
-                if (extension.Links[0].Layer instanceof Array) {
-                    for (var j=0; j<extension.Links[0].Layer.length; j++) {
-                        var layer = extension.Links[0].Layer[j];
-                        this.links.layers.push({name:layer.Name,url:layer.Url});
-            /* process layer events */
-            //TODO: Should this be called MapEvents?
-            if (extension.LayerEvents) {
-                if (extension.LayerEvents[0].Layer instanceof Array) {
-                    for (var j=0; j<extension.LayerEvents[0].Layer.length; j++) {
-                        var layer = extension.LayerEvents[0].Layer[j];
-                        var layerObj = {};
-                        layerObj.name = layer.Name[0];
-                        layerObj.onEnable = [];
-                        layerObj.onDisable = [];
-                        if (layer.OnEnable instanceof Array) {
-                            for (var k=0; k<layer.OnEnable[0].Layer.length; k++) {
-                                var kLayer = layer.OnEnable[0].Layer[k];
-                                layerObj.onEnable.push({name:kLayer.Name[0], enable: kLayer.Enable[0] == 'true' ? true : false});
+                var links = {groups:[], layers:[]};
+                var layerEvents = {};
+                if (jsonNode.Extension) {
+                    var extension = jsonNode.Extension[0];
+                    if (extension.Links) {
+                        /* process Groups */
+                        if (extension.Links[0].Group instanceof Array) {
+                            for (var j=0; j<extension.Links[0].Group.length; j++) {
+                                var group = extension.Links[0].Group[j];
+                                links.groups.push({name:group.Name,url:group.Url});
-                        if (layer.OnDisable instanceof Array) {
-                            for (var k=0; k<layer.OnDisable[0].Layer.length; k++) {
-                                var kLayer = layer.OnDisable[0].Layer[k];
-                                layerObj.onDisable.push({name:kLayer.Name[0], enable: kLayer.Enable[0] == 'true' ? true : false});
+                        if (extension.Links[0].Layer instanceof Array) {
+                            for (var j=0; j<extension.Links[0].Layer.length; j++) {
+                                var layer = extension.Links[0].Layer[j];
+                                links.layers.push({name:layer.Name,url:layer.Url});
-                        this.layerEvents[layerObj.name] = layerObj;
+                    /* process layer events */
+                    //TODO: Should this be called MapEvents?
+                    if (extension.LayerEvents) {
+                        if (extension.LayerEvents[0].Layer instanceof Array) {
+                            for (var j=0; j<extension.LayerEvents[0].Layer.length; j++) {
+                                var layer = extension.LayerEvents[0].Layer[j];
+                                var layerObj = {};
+                                layerObj.name = layer.Name[0];
+                                layerObj.onEnable = [];
+                                layerObj.onDisable = [];
+                                if (layer.OnEnable instanceof Array) {
+                                    for (var k=0; k<layer.OnEnable[0].Layer.length; k++) {
+                                        var kLayer = layer.OnEnable[0].Layer[k];
+                                        layerObj.onEnable.push({name:kLayer.Name[0], enable: kLayer.Enable[0] == 'true' ? true : false});
+                                if (layer.OnDisable instanceof Array) {
+                                    for (var k=0; k<layer.OnDisable[0].Layer.length; k++) {
+                                        var kLayer = layer.OnDisable[0].Layer[k];
+                                        layerObj.onDisable.push({name:kLayer.Name[0], enable: kLayer.Enable[0] == 'true' ? true : false});
+                                layerEvents[layerObj.name] = layerObj;
+                map.mapInfo = {links: links, layerEvents: layerEvents};
+                this.maps.push(map);
         } else {
-            this.extension = {};
+            //TODO: do we need a warning that there are no layers in this map?
     getInitialView: function() {
Modified: trunk/widgets/Legend.js
--- trunk/widgets/Legend.js	2008-03-10 13:29:17 UTC (rev 1224)
+++ trunk/widgets/Legend.js	2008-03-10 13:30:23 UTC (rev 1225)
@@ -210,7 +210,6 @@
         if (this.showRootFolder) {
             this.oRoot.setName(map.getMapTitle());
-        this.oMapInfo = map.oMapInfo;
         var startGroup = map.layerRoot;
         if (!this.showMapFolder) {
           startGroup = map.layerRoot.groups[0];
@@ -247,7 +246,7 @@
             group.legend.checkBox.checked = group.visible?true:false;
             Event.observe(group.legend.checkBox, 'click', this.stateChanged.bind(this, group));
             Event.observe(group.legend.treeItem.domObj, 'mouseover', this.setFolder.bind(this));
-            var groupInfo = this.getGroupInfoUrl(group.groupName);
+            var groupInfo = group.oMap.getGroupInfoUrl(group.groupName);
             if (groupInfo) {
                 var a = document.createElement('a');
                 a.href = groupInfo;
@@ -424,7 +423,7 @@
         opt.imgTreeFolder = this.imgLayerThemeIcon;
         var folder = new Jx.TreeFolder(opt);
         folder.domObj.insertBefore(layer.legend.checkBox, folder.domObj.childNodes[1]);
-        var layerInfo = this.getLayerInfoUrl(layer.layerName);
+        var layerInfo = layer.oMap.getLayerInfoUrl(layer.layerName);
         if (layerInfo) {
             a.href = layerInfo;
@@ -500,27 +499,5 @@
                 obj.hide();
-    getGroupInfoUrl: function(groupName) {
-        if (this.oMapInfo) {
-            var groups = this.oMapInfo.links.groups;
-            for (var i=0; i<groups.length; i++) {
-                if (groups[i].name == groupName) {
-                    return groups[i].url;
-        return null;
-    getLayerInfoUrl: function(layerName) {
-            var layers = this.oMapInfo.links.layers;
-            for (var i=0; i<layers.length; i++) {
-                if (layers[i].name == layerName) {
-                    return layers[i].url;
-        return null;
More information about the fusion-commits mailing list
