[fusion-commits] r1226 - in trunk: MapGuide lib widgets
svn_fusion at osgeo.org
Mon Mar 10 11:45:49 EDT 2008
Author: pagameba
Date: 2008-03-10 11:45:49 -0400 (Mon, 10 Mar 2008)
New Revision: 1226
trunk/MapGuide/MapGuide.js
trunk/lib/ApplicationDefinition.js
trunk/widgets/Legend.js
Re #20. Link now works.
Modified: trunk/MapGuide/MapGuide.js
--- trunk/MapGuide/MapGuide.js 2008-03-10 13:30:23 UTC (rev 1225)
+++ trunk/MapGuide/MapGuide.js 2008-03-10 15:45:49 UTC (rev 1226)
@@ -67,7 +67,7 @@
if (isMapWidgetLayer != null) {
this.bIsMapWidgetLayer = isMapWidgetLayer;
+ this.mapInfo = mapTag.mapInfo;
var extension = mapTag.extension; //TBD: this belongs in layer tag?
this.selectionType = extension.SelectionType ? extension.SelectionType[0] : 'INTERSECTS';
this.ratio = extension.MapRatio ? extension.MapRatio[0] : 1.0;
Modified: trunk/lib/ApplicationDefinition.js
--- trunk/lib/ApplicationDefinition.js 2008-03-10 13:30:23 UTC (rev 1225)
+++ trunk/lib/ApplicationDefinition.js 2008-03-10 15:45:49 UTC (rev 1226)
@@ -420,8 +420,8 @@
var map = new Fusion.Lib.ApplicationDefinition.Map(jsonNode.Map[i]);
var links = {groups:[], layers:[]};
var layerEvents = {};
- if (jsonNode.Extension) {
- var extension = jsonNode.Extension[0];
+ if (jsonNode.Map[i].Extension) {
+ var extension = jsonNode.Map[i].Extension[0];
if (extension.Links) {
/* process Groups */
if (extension.Links[0].Group instanceof Array) {
Modified: trunk/widgets/Legend.js
--- trunk/widgets/Legend.js 2008-03-10 13:30:23 UTC (rev 1225)
+++ trunk/widgets/Legend.js 2008-03-10 15:45:49 UTC (rev 1226)
@@ -467,7 +467,7 @@
if (bCheckBox) {
item.domObj.insertBefore(layer.legend.checkBox, item.domObj.childNodes[1]);
/* only need to add layer info if it has a check box too */
- var layerInfo = this.getLayerInfoUrl(layer.layerName);
+ var layerInfo = layer.oMap.getLayerInfoUrl(layer.layerName);
if (layerInfo) {
var a = document.createElement('a');
a.href = layerInfo;
More information about the fusion-commits
