[fusion-commits] r1227 - trunk/MapGuide
svn_fusion at osgeo.org
Mon Mar 10 11:47:07 EDT 2008
Author: pagameba
Date: 2008-03-10 11:47:06 -0400 (Mon, 10 Mar 2008)
New Revision: 1227
trunk/MapGuide/MapGuide.js
Re #20. Change oMapInfo to mapInfo
Modified: trunk/MapGuide/MapGuide.js
--- trunk/MapGuide/MapGuide.js 2008-03-10 15:45:49 UTC (rev 1226)
+++ trunk/MapGuide/MapGuide.js 2008-03-10 15:47:06 UTC (rev 1227)
@@ -265,9 +265,6 @@
- //TODO: get this from the layerTag.extension
- //this.oMapInfo = Fusion.oConfigMgr.getMapInfo(this._sResourceId);
//set projection units and code if supplied
//TODO: consider passing the metersPerUnit value into the framework
//to allow for scaling that doesn't match any of the pre-canned units
@@ -803,8 +800,8 @@
showLayer: function( layer ) {
- if (this.oMapInfo && this.oMapInfo.layerEvents[layer.layerName]) {
- var layerEvent = this.oMapInfo.layerEvents[layer.layerName];
+ if (this.mapInfo && this.mapInfo.layerEvents[layer.layerName]) {
+ var layerEvent = this.mapInfo.layerEvents[layer.layerName];
for (var i=0; i<layerEvent.onEnable.length; i++) {
var l = this.layerRoot.findLayer(layerEvent.onEnable[i].name);
if (l) {
@@ -821,8 +818,8 @@
hideLayer: function( layer ) {
for (var i=0; i<layerEvent.onDisable.length; i++) {
var l = this.layerRoot.findLayer(layerEvent.onDisable[i].name);
if (l) {
More information about the fusion-commits
