[fusion-commits] r1246 - trunk/templates/mapguide/standard
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Mar 13 11:26:20 EDT 2008
Author: pagameba
Date: 2008-03-13 11:26:20 -0400 (Thu, 13 Mar 2008)
New Revision: 1246
   trunk/templates/mapguide/standard/ApplicationDefinition.xml
Remove extra statusbar container, remove extra MapGroup
Modified: trunk/templates/mapguide/standard/ApplicationDefinition.xml
--- trunk/templates/mapguide/standard/ApplicationDefinition.xml	2008-03-13 15:23:32 UTC (rev 1245)
+++ trunk/templates/mapguide/standard/ApplicationDefinition.xml	2008-03-13 15:26:20 UTC (rev 1246)
@@ -10,12 +10,6 @@
   <MapSet xsi:type="MapSetType">
     <MapGroup id="sheboygan" xsi:type="MapType">
-      <!-- should be centered on intersection of Lower Fallss Rd and S.Taylor Dr. -->
-      <!--InitialView xsi:type="MapViewType">
-        <CenterX>-87.745061</CenterX>
-        <CenterY>43.740283</CenterY>
-        <Scale>8000</Scale>
-      </InitialView-->
       <Map xsi:type="MapGuideLayerType">
         <Type>MapGuide</Type>
         <SingleTile>true</SingleTile>
@@ -24,15 +18,6 @@
         </Extension>
       </Map>
     </MapGroup>
-    <MapGroup id="sheboyganOverview" xsi:type="MapType">
-      <Map xsi:type="MapGuideLayerType">
-        <Type>MapGuide</Type>
-        <SingleTile>true</SingleTile>
-        <Extension>
-          <ResourceId>Library://Samples/Sheboygan/Maps/SheboyganOverview.MapDefinition</ResourceId>
-        </Extension>
-      </Map>
-    </MapGroup>
   </MapSet>
@@ -45,33 +30,6 @@
   <WidgetSet xsi:type="WidgetSetType">
-* Statusbar
-* Splitterbar used to show items in the status bar
-    <Container xsi:type="UiItemContainerType">
-      <Name>Statusbar</Name>
-      <Type>Splitterbar</Type>
-      <Item xsi:type="WidgetItemType">
-        <Function>Widget</Function>
-        <Widget>StatusCoords</Widget>
-      </Item>
-        <Widget>StatusSelection</Widget>
-      </Item>
-        <Widget>StatusScale</Widget>
-      </Item>
-        <Widget>StatusViewSize</Widget>
-      </Item>
-    </Container>
 * ContextMenu (Tasks)
 * Menu available to the Task Pane
More information about the fusion-commits mailing list
