[fusion-commits] r1247 - in
trunk/templates/mapguide/standard/images: . icons
svn_fusion at osgeo.org
Thu Mar 13 11:30:44 EDT 2008
Author: pagameba
Date: 2008-03-13 11:30:44 -0400 (Thu, 13 Mar 2008)
New Revision: 1247
Added:
trunk/templates/mapguide/standard/images/icons/
trunk/templates/mapguide/standard/images/icons/buffer.png
trunk/templates/mapguide/standard/images/icons/edit-copy.png
trunk/templates/mapguide/standard/images/icons/edit-cut.png
trunk/templates/mapguide/standard/images/icons/edit-duplicate.png
trunk/templates/mapguide/standard/images/icons/edit-paste.png
trunk/templates/mapguide/standard/images/icons/edit-redo.png
trunk/templates/mapguide/standard/images/icons/edit-undo.png
trunk/templates/mapguide/standard/images/icons/file-open.png
trunk/templates/mapguide/standard/images/icons/file-print.png
trunk/templates/mapguide/standard/images/icons/file-save.png
trunk/templates/mapguide/standard/images/icons/help.png
trunk/templates/mapguide/standard/images/icons/legend-layer.png
trunk/templates/mapguide/standard/images/icons/legend-map.png
trunk/templates/mapguide/standard/images/icons/legend-raster.png
trunk/templates/mapguide/standard/images/icons/legend-theme.png
trunk/templates/mapguide/standard/images/icons/measure.png
trunk/templates/mapguide/standard/images/icons/move-down.png
trunk/templates/mapguide/standard/images/icons/move-up.png
trunk/templates/mapguide/standard/images/icons/navigator.png
trunk/templates/mapguide/standard/images/icons/pan-east.png
trunk/templates/mapguide/standard/images/icons/pan-north.png
trunk/templates/mapguide/standard/images/icons/pan-south.png
trunk/templates/mapguide/standard/images/icons/pan.png
trunk/templates/mapguide/standard/images/icons/search.png
trunk/templates/mapguide/standard/images/icons/select-attribute.png
trunk/templates/mapguide/standard/images/icons/select-centre.png
trunk/templates/mapguide/standard/images/icons/select-clear.png
trunk/templates/mapguide/standard/images/icons/select-features.png
trunk/templates/mapguide/standard/images/icons/select-polygon.png
trunk/templates/mapguide/standard/images/icons/select-query.png
trunk/templates/mapguide/standard/images/icons/select-radius.png
trunk/templates/mapguide/standard/images/icons/select-rectangle.png
trunk/templates/mapguide/standard/images/icons/select-zoom.png
trunk/templates/mapguide/standard/images/icons/select.png
trunk/templates/mapguide/standard/images/icons/view-back.png
trunk/templates/mapguide/standard/images/icons/view-forward.png
trunk/templates/mapguide/standard/images/icons/view-refresh.png
trunk/templates/mapguide/standard/images/icons/warning.png
trunk/templates/mapguide/standard/images/icons/west.png
trunk/templates/mapguide/standard/images/icons/zoom-full.png
trunk/templates/mapguide/standard/images/icons/zoom-in-fixed.png
trunk/templates/mapguide/standard/images/icons/zoom-in.png
trunk/templates/mapguide/standard/images/icons/zoom-out-fixed.png
trunk/templates/mapguide/standard/images/icons/zoom-out.png
adding icons to standard template
Added: trunk/templates/mapguide/standard/images/icons/buffer.png
(Binary files differ)
Property changes on: trunk/templates/mapguide/standard/images/icons/buffer.png
___________________________________________________________________
+ application/octet-stream
Added: trunk/templates/mapguide/standard/images/icons/edit-copy.png
Property changes on: trunk/templates/mapguide/standard/images/icons/edit-copy.png
Added: trunk/templates/mapguide/standard/images/icons/edit-cut.png
Property changes on: trunk/templates/mapguide/standard/images/icons/edit-cut.png
Added: trunk/templates/mapguide/standard/images/icons/edit-duplicate.png
Property changes on: trunk/templates/mapguide/standard/images/icons/edit-duplicate.png
Added: trunk/templates/mapguide/standard/images/icons/edit-paste.png
Property changes on: trunk/templates/mapguide/standard/images/icons/edit-paste.png
Added: trunk/templates/mapguide/standard/images/icons/edit-redo.png
Property changes on: trunk/templates/mapguide/standard/images/icons/edit-redo.png
Added: trunk/templates/mapguide/standard/images/icons/edit-undo.png
Property changes on: trunk/templates/mapguide/standard/images/icons/edit-undo.png
Added: trunk/templates/mapguide/standard/images/icons/file-open.png
Property changes on: trunk/templates/mapguide/standard/images/icons/file-open.png
Added: trunk/templates/mapguide/standard/images/icons/file-print.png
Property changes on: trunk/templates/mapguide/standard/images/icons/file-print.png
Added: trunk/templates/mapguide/standard/images/icons/file-save.png
Property changes on: trunk/templates/mapguide/standard/images/icons/file-save.png
Added: trunk/templates/mapguide/standard/images/icons/help.png
Property changes on: trunk/templates/mapguide/standard/images/icons/help.png
Added: trunk/templates/mapguide/standard/images/icons/legend-layer.png
Property changes on: trunk/templates/mapguide/standard/images/icons/legend-layer.png
Added: trunk/templates/mapguide/standard/images/icons/legend-map.png
Property changes on: trunk/templates/mapguide/standard/images/icons/legend-map.png
Added: trunk/templates/mapguide/standard/images/icons/legend-raster.png
Property changes on: trunk/templates/mapguide/standard/images/icons/legend-raster.png
Added: trunk/templates/mapguide/standard/images/icons/legend-theme.png
Property changes on: trunk/templates/mapguide/standard/images/icons/legend-theme.png
Added: trunk/templates/mapguide/standard/images/icons/measure.png
Property changes on: trunk/templates/mapguide/standard/images/icons/measure.png
Added: trunk/templates/mapguide/standard/images/icons/move-down.png
Property changes on: trunk/templates/mapguide/standard/images/icons/move-down.png
Added: trunk/templates/mapguide/standard/images/icons/move-up.png
Property changes on: trunk/templates/mapguide/standard/images/icons/move-up.png
Added: trunk/templates/mapguide/standard/images/icons/navigator.png
Property changes on: trunk/templates/mapguide/standard/images/icons/navigator.png
Added: trunk/templates/mapguide/standard/images/icons/pan-east.png
Property changes on: trunk/templates/mapguide/standard/images/icons/pan-east.png
Added: trunk/templates/mapguide/standard/images/icons/pan-north.png
Property changes on: trunk/templates/mapguide/standard/images/icons/pan-north.png
Added: trunk/templates/mapguide/standard/images/icons/pan-south.png
Property changes on: trunk/templates/mapguide/standard/images/icons/pan-south.png
Added: trunk/templates/mapguide/standard/images/icons/pan.png
Property changes on: trunk/templates/mapguide/standard/images/icons/pan.png
Added: trunk/templates/mapguide/standard/images/icons/search.png
Property changes on: trunk/templates/mapguide/standard/images/icons/search.png
Added: trunk/templates/mapguide/standard/images/icons/select-attribute.png
Property changes on: trunk/templates/mapguide/standard/images/icons/select-attribute.png
Added: trunk/templates/mapguide/standard/images/icons/select-centre.png
Property changes on: trunk/templates/mapguide/standard/images/icons/select-centre.png
Added: trunk/templates/mapguide/standard/images/icons/select-clear.png
Property changes on: trunk/templates/mapguide/standard/images/icons/select-clear.png
Added: trunk/templates/mapguide/standard/images/icons/select-features.png
Property changes on: trunk/templates/mapguide/standard/images/icons/select-features.png
Added: trunk/templates/mapguide/standard/images/icons/select-polygon.png
Property changes on: trunk/templates/mapguide/standard/images/icons/select-polygon.png
Added: trunk/templates/mapguide/standard/images/icons/select-query.png
Property changes on: trunk/templates/mapguide/standard/images/icons/select-query.png
Added: trunk/templates/mapguide/standard/images/icons/select-radius.png
Property changes on: trunk/templates/mapguide/standard/images/icons/select-radius.png
Added: trunk/templates/mapguide/standard/images/icons/select-rectangle.png
Property changes on: trunk/templates/mapguide/standard/images/icons/select-rectangle.png
Added: trunk/templates/mapguide/standard/images/icons/select-zoom.png
Property changes on: trunk/templates/mapguide/standard/images/icons/select-zoom.png
Added: trunk/templates/mapguide/standard/images/icons/select.png
Property changes on: trunk/templates/mapguide/standard/images/icons/select.png
Added: trunk/templates/mapguide/standard/images/icons/view-back.png
Property changes on: trunk/templates/mapguide/standard/images/icons/view-back.png
Added: trunk/templates/mapguide/standard/images/icons/view-forward.png
Property changes on: trunk/templates/mapguide/standard/images/icons/view-forward.png
Added: trunk/templates/mapguide/standard/images/icons/view-refresh.png
Property changes on: trunk/templates/mapguide/standard/images/icons/view-refresh.png
Added: trunk/templates/mapguide/standard/images/icons/warning.png
Property changes on: trunk/templates/mapguide/standard/images/icons/warning.png
Added: trunk/templates/mapguide/standard/images/icons/west.png
Property changes on: trunk/templates/mapguide/standard/images/icons/west.png
Added: trunk/templates/mapguide/standard/images/icons/zoom-full.png
Property changes on: trunk/templates/mapguide/standard/images/icons/zoom-full.png
Added: trunk/templates/mapguide/standard/images/icons/zoom-in-fixed.png
Property changes on: trunk/templates/mapguide/standard/images/icons/zoom-in-fixed.png
Added: trunk/templates/mapguide/standard/images/icons/zoom-in.png
Property changes on: trunk/templates/mapguide/standard/images/icons/zoom-in.png
Added: trunk/templates/mapguide/standard/images/icons/zoom-out-fixed.png
Property changes on: trunk/templates/mapguide/standard/images/icons/zoom-out-fixed.png
Added: trunk/templates/mapguide/standard/images/icons/zoom-out.png
Property changes on: trunk/templates/mapguide/standard/images/icons/zoom-out.png
More information about the fusion-commits
