[fusion-commits] r1249 - trunk/templates/mapguide/standard
svn_fusion at osgeo.org
Thu Mar 13 12:57:26 EDT 2008
Author: jfournier
Date: 2008-03-13 12:57:26 -0400 (Thu, 13 Mar 2008)
New Revision: 1249
trunk/templates/mapguide/standard/ApplicationDefinition.xml
updated toolbar definition.
Modified: trunk/templates/mapguide/standard/ApplicationDefinition.xml
--- trunk/templates/mapguide/standard/ApplicationDefinition.xml 2008-03-13 15:40:48 UTC (rev 1248)
+++ trunk/templates/mapguide/standard/ApplicationDefinition.xml 2008-03-13 16:57:26 UTC (rev 1249)
@@ -192,10 +192,6 @@
</Item>
<Item xsi:type="WidgetItemType">
<Function>Widget</Function>
- <Widget>toolbarAbout</Widget>
- </Item>
- <Item xsi:type="WidgetItemType">
- <Function>Widget</Function>
<Widget>toolbarViewOptions</Widget>
</Item>
@@ -207,37 +203,48 @@
</Item>
- <Widget>toolbarSelectRadius</Widget>
+ <Widget>Select</Widget>
</Item>
- <Widget>toolbarSelectPolygon</Widget>
+ <Widget>Pan</Widget>
</Item>
+ <Item xsi:type="SeparatorItemType">
+ <Function>Separator</Function>
+ </Item>
- <Widget>toolbarSelectWithin</Widget>
+ <Widget>ZoomInRectangle</Widget>
</Item>
- <Widget>toolbarClearSelection</Widget>
+ <Widget>ZoomInFixed</Widget>
</Item>
+ <Item xsi:type="WidgetItemType">
+ <Function>Widget</Function>
+ <Widget>ZoomOutFixed</Widget>
+ </Item>
</Item>
- <Widget>toolbarMeasure</Widget>
+ <Widget>toolbarSecondaryInitialMapView</Widget>
</Item>
- <Widget>toolbarBuffer</Widget>
+ <Widget>toolbarSecondaryPreviousView</Widget>
</Item>
+ <Widget>toolbarSecondaryNextView</Widget>
+ </Item>
</Item>
- <Widget>toolbarRefreshMap</Widget>
+ <Widget>toolbarSecondaryZoomSelection</Widget>
</Item>
</Container>
More information about the fusion-commits
