[fusion-commits] r1250 - in trunk: MapServer templates/mapguide/standard
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Mar 13 13:25:47 EDT 2008
Author: pagameba
Date: 2008-03-13 13:25:47 -0400 (Thu, 13 Mar 2008)
New Revision: 1250
   trunk/MapServer/MapServer.js
   trunk/templates/mapguide/standard/ApplicationDefinition.xml
Re #23.  Bring patch for missing functions into trunk.  Still need to actually do an implementation before closing.
Modified: trunk/MapServer/MapServer.js
--- trunk/MapServer/MapServer.js	2008-03-13 16:57:26 UTC (rev 1249)
+++ trunk/MapServer/MapServer.js	2008-03-13 17:25:47 UTC (rev 1250)
@@ -215,8 +215,9 @@
             this.layerRoot.legendLabel = this._sMapTitle;
             this.parseMapLayersAndGroups(o);
-      			var minScale = 1.0e10;
-      			var maxScale = 0;
+            var minScale = 1.0e10;
+            var maxScale = 0;
             for (var i=0; i<this.aLayers.length; i++) {
               if (this.aLayers[i].visible) {
                   this.aVisibleLayers.push(this.aLayers[i].layerName);
@@ -675,7 +676,16 @@
         var params = {};
         params.parameters = 'session='+this.getSessionID();
         Fusion.ajaxRequest(s, params);
+    getGroupInfoUrl: function(groupName) {
+      return null;
+    getLayerInfoUrl: function(layerName) {
+      return null;
Modified: trunk/templates/mapguide/standard/ApplicationDefinition.xml
--- trunk/templates/mapguide/standard/ApplicationDefinition.xml	2008-03-13 16:57:26 UTC (rev 1249)
+++ trunk/templates/mapguide/standard/ApplicationDefinition.xml	2008-03-13 17:25:47 UTC (rev 1250)
@@ -277,28 +277,7 @@
       </Item>
     </Container>
-* Placeholder Widget
-    <Widget xsi:type="WidgetType">
-      <Name>menuPlaceholder</Name>
-      <Type>InvokeScript</Type>
-      <StatusItem/>
-      <Extension>
-        <Script>return true</Script>
-      </Extension>
-      <ImageUrl/>
-      <ImageClass/>
-      <Tooltip/>
-      <Label>menu item</Label>
-      <Disabled/>
-    </Widget>
 * Context Menu - Widgets
 * Widgets belonging to the map context menu
@@ -597,25 +576,6 @@
       <Disabled/>
     </Widget>
-<!-- FILE MENU LAUNCH NAVIGATOR -->
-      <Name>showOverviewMap</Name>
-      <StatusItem/>
-      <Extension>
-        <Script>showOverviewMap()</Script>
-      </Extension>
-      <ImageUrl>images/icons/navigator.png</ImageUrl>
-      <ImageClass/>
-      <Tooltip>Launch Overview Map</Tooltip>
-      <Label>Launch Overview Map</Label>
-      <Disabled/>
-    </Widget>
 * Toolbar - Widgets
@@ -698,7 +658,7 @@
       <ImageUrl>images/icons/help.png</ImageUrl>
       <ImageClass/>
       <Tooltip/>
-      <Label>Help</Label>
+      <Label></Label>
       <Disabled/>
     </Widget>
@@ -724,7 +684,7 @@
       <ImageUrl>images/icons/select-clear.png</ImageUrl>
       <ImageClass/>
       <Tooltip/>
-      <Label>Clear Selection</Label>
+      <Label></Label>
       <Disabled/>
     </Widget>
@@ -737,7 +697,7 @@
       <ImageUrl>images/icons/select-radius.png</ImageUrl>
       <ImageClass/>
       <Tooltip>Select Radius</Tooltip>
-      <Label>Select Radius</Label>
+      <Label></Label>
       <Disabled/>
     </Widget>
@@ -750,7 +710,7 @@
       <ImageUrl>images/icons/select-polygon.png</ImageUrl>
       <ImageClass/>
       <Tooltip>Select Polygon</Tooltip>
-      <Label>Select Polygon</Label>
+      <Label></Label>
       <Disabled/>
     </Widget>
@@ -832,7 +792,7 @@
       <ImageUrl>images/icons/select-features.png</ImageUrl>
       <ImageClass/>
       <Tooltip>Select Within</Tooltip>
-      <Label>Select Within</Label>
+      <Label></Label>
       <Disabled/>
     </Widget>
@@ -888,24 +848,6 @@
       </Extension>
     </Widget>
-<!-- STATUS NAVIGATOR -->
-      <Name>StatusNavigator</Name>
-      <StatusItem/>
-      <Extension>
-      </Extension>
-      <ImageClass/>
-      <Label/>
-      <Disabled/>
-    </Widget>
 * Panels - Widgets
@@ -1070,7 +1012,7 @@
       <ImageUrl>images/icons/file-print.png</ImageUrl>
       <ImageClass/>
       <Tooltip>Get printable page.</Tooltip>
-      <Label>Print</Label>
+      <Label></Label>
       <Disabled/>
     </Widget>
More information about the fusion-commits mailing list
