[fusion-commits] r1669 - trunk/widgets/widgetinfo
svn_fusion at osgeo.org
Mon Nov 17 16:33:24 EST 2008
Author: chrisclaydon
Date: 2008-11-17 16:33:23 -0500 (Mon, 17 Nov 2008)
New Revision: 1669
trunk/widgets/widgetinfo/about.xml
trunk/widgets/widgetinfo/buffer.xml
trunk/widgets/widgetinfo/bufferpanel.xml
trunk/widgets/widgetinfo/centerselection.xml
trunk/widgets/widgetinfo/clearselection.xml
trunk/widgets/widgetinfo/extenthistory.xml
trunk/widgets/widgetinfo/help.xml
trunk/widgets/widgetinfo/initialmapview.xml
trunk/widgets/widgetinfo/invokescript.xml
trunk/widgets/widgetinfo/invokeurl.xml
trunk/widgets/widgetinfo/mapmenu.xml
trunk/widgets/widgetinfo/measure.xml
trunk/widgets/widgetinfo/pan.xml
trunk/widgets/widgetinfo/panonclick.xml
trunk/widgets/widgetinfo/panquery.xml
trunk/widgets/widgetinfo/print.xml
trunk/widgets/widgetinfo/refreshmap.xml
trunk/widgets/widgetinfo/savemap.xml
trunk/widgets/widgetinfo/search.xml
trunk/widgets/widgetinfo/select.xml
trunk/widgets/widgetinfo/selectpolygon.xml
trunk/widgets/widgetinfo/selectradius.xml
trunk/widgets/widgetinfo/selectwithin.xml
trunk/widgets/widgetinfo/viewoptions.xml
trunk/widgets/widgetinfo/zoom.xml
trunk/widgets/widgetinfo/zoomonclick.xml
trunk/widgets/widgetinfo/zoomtoselection.xml
Fixes #171 - Updated widget info files to use CSS image sprites by default for widget icons.
CSS image sprites allow multiple icons to be obtained from a single image strip image. This greatly reduces the number of downloads required when a Fusion layout is loaded, allowing for a quicker start-up.
Modified: trunk/widgets/widgetinfo/about.xml
--- trunk/widgets/widgetinfo/about.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/about.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -6,8 +6,8 @@
<Label>About</Label>
<Tooltip>Click to show information about this application</Tooltip>
<StatusText></StatusText>
- <ImageUrl>images/icons/about.png</ImageUrl>
- <ImageClass></ImageClass>
+ <ImageUrl>images/icons.png</ImageUrl>
+ <ImageClass>about</ImageClass>
<StandardUi>true</StandardUi>
<ContainableBy>Any</ContainableBy>
<Parameter>
Modified: trunk/widgets/widgetinfo/buffer.xml
--- trunk/widgets/widgetinfo/buffer.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/buffer.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -6,7 +6,8 @@
<Description>This widget will perform a buffering operation on selected features in the Map. Either a popup window or the task pane will be used to gather user input, depending on the setting of the Target parameter</Description>
<Label>Create a buffer</Label>
<Tooltip>Click to create a buffer</Tooltip>
- <ImageUrl>images/icons/buffer.png</ImageUrl>
+ <ImageClass>buffer</ImageClass>
<Parameter>
Modified: trunk/widgets/widgetinfo/bufferpanel.xml
--- trunk/widgets/widgetinfo/bufferpanel.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/bufferpanel.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -4,7 +4,8 @@
<Label>Buffer</Label>
<Parameter>
Modified: trunk/widgets/widgetinfo/centerselection.xml
--- trunk/widgets/widgetinfo/centerselection.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/centerselection.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -6,8 +6,8 @@
<Label>Center selection</Label>
<Tooltip>Click to center the map on the current selection</Tooltip>
- <ImageUrl>images/icons/select-centre.png</ImageUrl>
+ <ImageClass>select-centre</ImageClass>
</WidgetInfo>
Modified: trunk/widgets/widgetinfo/clearselection.xml
--- trunk/widgets/widgetinfo/clearselection.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/clearselection.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -4,8 +4,10 @@
<Description>Clears the current selection</Description>
<Label>Clear Selection</Label>
<Tooltip>Click to clear the current selection</Tooltip>
- <ImageUrl>images/icons/select-clear.png</ImageUrl>
+ <ImageClass>select-clear</ImageClass>
</WidgetInfo>
Modified: trunk/widgets/widgetinfo/extenthistory.xml
--- trunk/widgets/widgetinfo/extenthistory.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/extenthistory.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -3,7 +3,8 @@
<LocalizedType>Extent History</LocalizedType>
<Description>A widget to navigate forward or backward in the map view extent history</Description>
<Label>Go To Extent</Label>
- <ImageUrl>images/icons/view-back.png</ImageUrl>
+ <ImageClass>view-back</ImageClass>
<Tooltip>Navigate to the previous extents</Tooltip>
<Direction>Previous</Direction>
Modified: trunk/widgets/widgetinfo/help.xml
--- trunk/widgets/widgetinfo/help.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/help.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -6,8 +6,8 @@
<Label>Help</Label>
<Tooltip>Click to get help</Tooltip>
- <ImageUrl>images/icons/help.png</ImageUrl>
+ <ImageClass>help</ImageClass>
<Parameter>
Modified: trunk/widgets/widgetinfo/initialmapview.xml
--- trunk/widgets/widgetinfo/initialmapview.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/initialmapview.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -6,8 +6,8 @@
<Label>Zoom Extents</Label>
<Tooltip>Click to zoom to the full map extents</Tooltip>
- <ImageUrl>images/icons/zoom-full.png</ImageUrl>
+ <ImageClass>zoom-full</ImageClass>
<Parameter>
Modified: trunk/widgets/widgetinfo/invokescript.xml
--- trunk/widgets/widgetinfo/invokescript.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/invokescript.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -6,8 +6,8 @@
<Label>Invoke script</Label>
<Tooltip>Click to invoke a javascript method</Tooltip>
- <ImageUrl>images/icons/invoke-script.png</ImageUrl>
+ <ImageClass>invoke-script</ImageClass>
<Parameter>
Modified: trunk/widgets/widgetinfo/invokeurl.xml
--- trunk/widgets/widgetinfo/invokeurl.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/invokeurl.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -6,8 +6,8 @@
<Label>Invoke URL</Label>
<Tooltip>Click to execute the URL</Tooltip>
- <ImageUrl>images/icons/invoke-url.png</ImageUrl>
+ <ImageClass>invoke-url</ImageClass>
<Parameter>
Modified: trunk/widgets/widgetinfo/mapmenu.xml
--- trunk/widgets/widgetinfo/mapmenu.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/mapmenu.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -6,7 +6,7 @@
<Label>Maps</Label>
<Tooltip>Choose a map theme</Tooltip>
- <ImageUrl>images/icons/map-manager.png</ImageUrl>
+ <ImageUrl></ImageUrl>
@@ -15,7 +15,7 @@
<Label>MapDefinition root folder</Label>
<Type>string</Type>
<Description>The hierarchy below this folder will be searched for MapDefinitions to display</Description>
- <DefaultValue>Library://</DefaultValue>
+ <DefaultValue></DefaultValue>
<IsMandatory>0</IsMandatory>
</Parameter>
</WidgetInfo>
Modified: trunk/widgets/widgetinfo/measure.xml
--- trunk/widgets/widgetinfo/measure.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/measure.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -6,8 +6,8 @@
<Label>Measure</Label>
<Tooltip>Measure distances on the map</Tooltip>
- <ImageUrl>images/icons/measure.png</ImageUrl>
+ <ImageClass>measure</ImageClass>
<Parameter>
Modified: trunk/widgets/widgetinfo/pan.xml
--- trunk/widgets/widgetinfo/pan.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/pan.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -6,8 +6,8 @@
<Label>Pan</Label>
<Tooltip>Click and drag to pan the map</Tooltip>
- <ImageUrl>images/icons/pan.png</ImageUrl>
+ <ImageClass>pan</ImageClass>
</WidgetInfo>
Modified: trunk/widgets/widgetinfo/panonclick.xml
--- trunk/widgets/widgetinfo/panonclick.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/panonclick.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -6,8 +6,8 @@
<Label>Pan on click</Label>
<Tooltip>Pan the map</Tooltip>
<Parameter>
@@ -47,3 +47,4 @@
</WidgetInfo>
Modified: trunk/widgets/widgetinfo/panquery.xml
--- trunk/widgets/widgetinfo/panquery.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/panquery.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -6,8 +6,8 @@
<Label>Pan query</Label>
<Tooltip>Drag the mouse to pan, click to query</Tooltip>
<Parameter>
Modified: trunk/widgets/widgetinfo/print.xml
--- trunk/widgets/widgetinfo/print.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/print.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -4,7 +4,8 @@
<Description>Produces a printable version of the page</Description>
<Label>Print</Label>
<Tooltip>Print the current map view</Tooltip>
- <ImageUrl>images/icons/file-print.png</ImageUrl>
+ <ImageClass>file-print</ImageClass>
<Parameter>
Modified: trunk/widgets/widgetinfo/refreshmap.xml
--- trunk/widgets/widgetinfo/refreshmap.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/refreshmap.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -6,8 +6,8 @@
<Label>Refresh</Label>
<Tooltip>Click to redraw the map</Tooltip>
- <ImageUrl>images/icons/view-refresh.png</ImageUrl>
+ <ImageClass>view-refresh</ImageClass>
</WidgetInfo>
Modified: trunk/widgets/widgetinfo/savemap.xml
--- trunk/widgets/widgetinfo/savemap.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/savemap.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -1,10 +1,11 @@
<WidgetInfo>
<Type>SaveMap</Type>
- <LocalizedType>Save Map</LocalizedType>
+ <LocalizedType>Save Map</LocalizedType>
<Description>A widget to save the map as an image</Description>
<Label>Save map</Label>
<Tooltip>Click to save the map as an image</Tooltip>
- <ImageUrl>images/icons/file-save.png</ImageUrl>
+ <ImageClass>file-save</ImageClass>
<Parameter>
@@ -15,7 +16,7 @@
<AllowedValue>
<Name>dwf</Name>
<Label>DWF</Label>
- </AllowedValue>
+ </AllowedValue>
<AllowedValue>
<Name>png</Name>
<Label>PNG</Label>
Modified: trunk/widgets/widgetinfo/search.xml
--- trunk/widgets/widgetinfo/search.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/search.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -6,8 +6,8 @@
<Label>Search</Label>
<Tooltip>Click to carry out a search on the map data</Tooltip>
- <ImageUrl>images/icons/search.png</ImageUrl>
+ <ImageClass>search</ImageClass>
<Parameter>
Modified: trunk/widgets/widgetinfo/select.xml
--- trunk/widgets/widgetinfo/select.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/select.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -6,8 +6,8 @@
<Label>Select</Label>
<Tooltip>Click to select features</Tooltip>
- <ImageUrl>images/icons/select.png</ImageUrl>
+ <ImageClass>select</ImageClass>
<Parameter>
Modified: trunk/widgets/widgetinfo/selectpolygon.xml
--- trunk/widgets/widgetinfo/selectpolygon.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/selectpolygon.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -6,8 +6,8 @@
<Label>Select Polygon</Label>
<Tooltip>Draw a polygon to perform a selection</Tooltip>
- <ImageUrl>images/icons/select-polygon.png</ImageUrl>
+ <ImageClass>select-polygon</ImageClass>
<Parameter>
Modified: trunk/widgets/widgetinfo/selectradius.xml
--- trunk/widgets/widgetinfo/selectradius.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/selectradius.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -4,7 +4,8 @@
<Description>Perform a selection within a certain radius of a click</Description>
<Label>Select Radius</Label>
<Tooltip>Click to select within a radius</Tooltip>
- <ImageUrl>images/icons/select-radius.png</ImageUrl>
+ <ImageClass>select-radius</ImageClass>
<Parameter>
Modified: trunk/widgets/widgetinfo/selectwithin.xml
--- trunk/widgets/widgetinfo/selectwithin.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/selectwithin.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -6,8 +6,8 @@
<Label>Select within</Label>
<Tooltip>Click to select features within this selection</Tooltip>
- <ImageUrl>images/icons/select-features.png</ImageUrl>
+ <ImageClass>select-features</ImageClass>
<Parameter>
Modified: trunk/widgets/widgetinfo/viewoptions.xml
--- trunk/widgets/widgetinfo/viewoptions.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/viewoptions.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -6,8 +6,8 @@
<Label>Options</Label>
<Tooltip>Click to change the units displayed</Tooltip>
- <ImageUrl>images/icons/options.png</ImageUrl>
+ <ImageClass>options</ImageClass>
<Parameter>
Modified: trunk/widgets/widgetinfo/zoom.xml
--- trunk/widgets/widgetinfo/zoom.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/zoom.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -5,8 +5,8 @@
<Label>Zoom Rectangle</Label>
<Tooltip>Click or click and drag on the map to zoom in</Tooltip>
<StatusText>Click or click and drag on the map to zoom in</StatusText>
- <ImageUrl>images/icons/zoom-in.png</ImageUrl>
+ <ImageClass>zoom-in</ImageClass>
<Parameter>
@@ -44,5 +44,5 @@
<DefaultValue>in</DefaultValue>
<IsMandatory>false</IsMandatory>
</Parameter>
</WidgetInfo>
Modified: trunk/widgets/widgetinfo/zoomonclick.xml
--- trunk/widgets/widgetinfo/zoomonclick.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/zoomonclick.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -6,8 +6,8 @@
<Label>ZoomOnClick</Label>
<Tooltip>Click to zoom in</Tooltip>
- <ImageUrl>images/icons/zoom-out-fixed.png</ImageUrl>
+ <ImageClass>zoom-out-fixed</ImageClass>
<Parameter>
Modified: trunk/widgets/widgetinfo/zoomtoselection.xml
--- trunk/widgets/widgetinfo/zoomtoselection.xml 2008-11-17 18:53:17 UTC (rev 1668)
+++ trunk/widgets/widgetinfo/zoomtoselection.xml 2008-11-17 21:33:23 UTC (rev 1669)
@@ -6,8 +6,8 @@
<Label>Zoom Selection</Label>
<Tooltip>Click to zoom to the selection</Tooltip>
- <ImageUrl>images/icons/select-zoom.png</ImageUrl>
+ <ImageClass>select-zoom</ImageClass>
<Parameter>
More information about the fusion-commits
