[fusion-commits] r1670 - trunk
svn_fusion at osgeo.org
Tue Nov 18 15:45:38 EST 2008
Author: madair
Date: 2008-11-18 15:45:38 -0500 (Tue, 18 Nov 2008)
New Revision: 1670
trunk/build.xml
re #140: update of build.xml to reflect new directory structure
Modified: trunk/build.xml
--- trunk/build.xml 2008-11-17 21:33:23 UTC (rev 1669)
+++ trunk/build.xml 2008-11-18 20:45:38 UTC (rev 1670)
@@ -118,8 +118,7 @@
<copy todir="${build.home}">
<fileset dir="${basedir}"
includes="configHeader.json
- MapGuide/**
- MapServer/**
+ layers/**
common/**
containerinfo/**
docs/**
@@ -194,7 +193,7 @@
<!-- =================== concat build ================================== -->
- <target description="concatenate core files into a single file" name="concat" depends="clean,prepare">
+ <target description="concatenate core files into a single file" name="concat" depends="prepare">
<echo message="concatenating core files"/>
<delete dir="${buildOutput}.js"/>
@@ -234,7 +233,7 @@
<!-- merge everything into a single file -->
<concat destfile="${buildOutput}.js" outputencoding="UTF-8" append="true">
<fileset dir="${build.home}/widgets" includes="**/*.js"/>
- <filelist dir="${build.home}" files="MapGuide/MapGuide.js MapServer/MapServer.js"/>
+ <fileset dir="${build.home}" includes="layers/**"/>
</concat>
</target>
@@ -322,7 +321,7 @@
dependencies) will have been assembled
- <target name="dist" description="Create binary distribution" depends="docs,compress">
+ <target name="dist" description="Create binary distribution" depends="clean,docs,compress">
<echo message="Creating distribution archive"/>
<mkdir dir="${dist.home}"/>
More information about the fusion-commits
