[fusion-commits] r1562 - trunk/lib
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon Sep 29 13:02:49 EDT 2008
Author: pagameba
Date: 2008-09-29 13:02:49 -0400 (Mon, 29 Sep 2008)
New Revision: 1562
   trunk/lib/ApplicationDefinition.js
   trunk/lib/Widget.js
Widgets not in toolbars or menus were not registering for the click events on button UI objects.  This is fixed by moving the event registration into the Widget's setUIObject method.
Modified: trunk/lib/ApplicationDefinition.js
--- trunk/lib/ApplicationDefinition.js	2008-09-26 19:43:29 UTC (rev 1561)
+++ trunk/lib/ApplicationDefinition.js	2008-09-29 17:02:49 UTC (rev 1562)
@@ -880,10 +880,7 @@
                                 label: widgetTag.label,
                                 image: widgetTag.imageUrl,
                                 imageClass: widgetTag.imageClass,
-                                toggle: widget.isExclusive,
-                                onClick: OpenLayers.Function.bind(widget.activate, widget),
-                                onUp: OpenLayers.Function.bind(widget.deactivate, widget),
-                                onDown: OpenLayers.Function.bind(widget.activate, widget)
+                                toggle: widget.isExclusive
                             if (widget.isExclusive) {
                                 widget.getMap().buttonSet.add(widget.uiObj);
@@ -911,10 +908,7 @@
                         container.add(widget.uiObj);
                         if (widget.uiObj.setEnabled) {
Modified: trunk/lib/Widget.js
--- trunk/lib/Widget.js	2008-09-26 19:43:29 UTC (rev 1561)
+++ trunk/lib/Widget.js	2008-09-29 17:02:49 UTC (rev 1562)
@@ -91,6 +91,9 @@
             uiObj.domA.addClass('jx' + uiObj.options.type + 'Active');
         uiObj.addEvents({
+            'click': (function() {
+                this.activate();
+            }).bind(this),
             'up': (function() {
                 var instances = Fusion.Widget.uiInstances[this.type];
                 for (var i=0; i<instances.length; i++) {
@@ -98,6 +101,7 @@
                     instance.options.isActive = false;
                     instance.domA.removeClass('jx' + instance.options.type + 'Active');
+                this.deactivate();
             }).bind(this),
             'down': (function() {
@@ -106,6 +110,7 @@
                     instance.options.isActive = true;
                     instance.domA.addClass('jx' + instance.options.type + 'Active');
+                this.activate();
             }).bind(this)
         this.uiObj = uiObj;
More information about the fusion-commits mailing list
