[fusion-commits] r1563 - trunk/widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon Sep 29 14:03:10 EDT 2008
Author: pagameba
Date: 2008-09-29 14:03:09 -0400 (Mon, 29 Sep 2008)
New Revision: 1563
   trunk/widgets/SelectRadius.js
change SelectRadius interpretation of Radius property to be pixels instead of map units to avoid problems with different projections.
Modified: trunk/widgets/SelectRadius.js
--- trunk/widgets/SelectRadius.js	2008-09-29 17:02:49 UTC (rev 1562)
+++ trunk/widgets/SelectRadius.js	2008-09-29 18:03:09 UTC (rev 1563)
@@ -36,7 +36,7 @@
     uiClass: Jx.Button,
     selectionType: 'INTERSECTS',
     nTolerance : 3, //default pixel tolernace for a point click
-    defaultRadius: 20,    //this is in map units
+    defaultRadius: 20, //this is now in pixels
     initializeWidget: function(widgetTag) {
         this.initializeCanvas();
@@ -127,11 +127,10 @@
      * @param e Event the event that happened on the mapObj
     mouseDown: function(e) {
-        //console.log('SelectRadius.mouseDown'+this.isDigitizing);
         if (OpenLayers.Event.isLeftClick(e)) {
             var p = this.getMap().getEventPosition(e);
             var point = this.getMap().pixToGeo(p.x, p.y);
-            var radius = this.defaultRadius;
+            var radius = this.getMap().pixToGeoMeasure(this.defaultRadius);
             if (!this.isDigitizing) {
                 this.circle.setCenter(point.x, point.y);
@@ -162,18 +161,18 @@
     mouseMove: function(e) {
-        //console.log('SelectRadius.mouseMove'+this.isDigitizing);
             return;
         var map = this.getMap();
         var p = map.getEventPosition(e);
         var point = map.pixToGeo(p.x, p.y);
         var center = this.circle.center;
         var radius = Math.sqrt(Math.pow(center.x-point.x,2) + Math.pow(center.y-point.y,2));
-        if (radius > this.nTolerance) {
+        if (radius > this.getMap().pixToGeoMeasure(this.nTolerance)) {
             this.circle.setRadius(radius);
         this.clearContext();
@@ -190,11 +189,9 @@
             this.radiusTip.innerHTML = r + this.units;
     mouseUp: function(e) {
-        //console.log('SelectRadius.mouseUp'+this.isDigitizing);
         if (this.isDigitizing) {
             this.event = e;
@@ -234,7 +231,6 @@
             sep = ',';
         wkt = wkt + sep + first + '))';
         var options = {};
         options.geometry = wkt;
         options.selectionType = this.selectionType;
More information about the fusion-commits mailing list
