[fusion-commits] r1827 - in trunk: lib widgets
svn_fusion at osgeo.org
Fri Apr 3 14:30:10 EDT 2009
Author: madair
Date: 2009-04-03 14:30:09 -0400 (Fri, 03 Apr 2009)
New Revision: 1827
trunk/lib/jxlib.uncompressed.js
trunk/widgets/Legend.js
re #241: update to JxLib 2.0 RC1; includes changes to Legend context menu
Modified: trunk/lib/jxlib.uncompressed.js
--- trunk/lib/jxlib.uncompressed.js 2009-04-03 14:48:38 UTC (rev 1826)
+++ trunk/lib/jxlib.uncompressed.js 2009-04-03 18:30:09 UTC (rev 1827)
@@ -4288,7 +4288,6 @@
start: function(event){
- event.stop();
if (this.options.preventDefault) event.preventDefault();
this.fireEvent('beforeStart', this.element);
this.mouse.start = event.page;
@@ -5232,7 +5231,6 @@
clickedElement: function(event){
- event.stop();
var dir = this.range < 0 ? -1 : 1;
var position = event.page[this.axis] - this.element.getPosition()[this.axis] - this.half;
position = position.limit(-this.options.offset, this.full -this.options.offset);
@@ -5444,7 +5442,7 @@
* reset.css - Copyright (c) 2006, Yahoo! Inc. All rights reserved.
* Code licensed under the BSD License: http://developer.yahoo.net/yui/license.txt
- * Jx UI Library, 2.0-beta-6
+ * Jx UI Library, 2.0-rc-1
* Copyright (c) 2006-2008, DM Solutions Group Inc. All rights reserved.
* Permission is hereby granted, free of charge, to any person obtaining a
@@ -5465,7 +5463,7 @@
* FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
* DEALINGS IN THE SOFTWARE.
-// $Id: common.js 241 2008-12-10 15:11:05Z pagameba $
+// $Id: common.js 303 2009-04-02 18:52:21Z pagameba $
* Class: Jx
* Jx is a global singleton object that contains the entire Jx library
@@ -5504,6 +5502,12 @@
+Class.Mutators.Family = function(self,name) {
+ self.$family = {'name': name};
+ return self;
/* Setup global namespace
* If jxcore is loaded by jx.js, then the namespace and baseURL are
* already established
@@ -5536,13 +5540,22 @@
* (end)
- Jx.aPixel = document.createElement('img');
+ Jx.aPixel = document.createElement('img', {alt:'',title:''});
Jx.aPixel.src = matches[1]+'/a_pixel.png';
Jx.baseURL = Jx.aPixel.src.substring(0,
Jx.aPixel.src.indexOf('a_pixel.png'));
+ * Determine if we're running in Adobe AIR. If so, determine which sandbox we're in
+ var src = aScripts[0].src;
+ if (src.contains('app:')){
+ Jx.isAir = true;
+ } else {
+ Jx.isAir = false;
@@ -6024,13 +6037,16 @@
} else if (this.options.contentURL) {
this.contentIsLoaded = false;
- new Request({
+ this.req = new Request({
url: this.options.contentURL,
method:'get',
update: element,
onSuccess:(function(html) {
element.innerHTML = html;
this.contentIsLoaded = true;
+ if (Jx.isAir){
+ $clear(this.reqTimeout);
this.fireEvent('contentLoaded', this);
}).bind(this),
onFailure: (function(){
@@ -6038,7 +6054,12 @@
this.fireEvent('contentLoadFailed', this);
}).bind(this),
headers: {'If-Modified-Since': 'Sat, 1 Jan 2000 00:00:00 GMT'}
- }).send();
+ this.req.send();
+ if (Jx.isAir) {
+ var timeout = $defined(this.options.timeout) ? this.options.timeout : 10000;
+ this.reqTimeout = this.checkRequest.delay(timeout, this);
} else {
@@ -6071,7 +6092,39 @@
+ * It seems AIR never returns an XHR that "fails" by not finding the
+ * appropriate file when run in the application sandbox and retrieving a local
+ * file. This affects Jx.ContentLoader in that a "failed" event is never fired.
+ * To fix this, I've added a timeout that waits about 10 seconds or so in the code above
+ * for the XHR to return, if it hasn't returned at the end of the timeout, we cancel the
+ * XHR and fire the failure event.
+ * This code only gets added if we're in AIR.
+if (Jx.isAir){
+ Jx.ContentLoader.implement({
+ * Method: checkRequest()
+ * Is fired after a delay to check the request to make sure it's not
+ * failing in AIR.
+ checkRequest: function(){
+ if (this.req.xhr.readyState === 1) {
+ //we still haven't gotten the file. Cancel and fire the
+ //failure
+ this.req.cancel();
+ this.contentIsLoaded = true;
+ this.fireEvent('contentLoadFailed', this);
* Class: Jx.AutoPosition
* Mix-in class that provides a method for positioning
* elements relative to other elements.
@@ -6139,6 +6192,7 @@
var ver = $splat(options.vertical || ['center center']);
var offsets = $merge({top:0,right:0,bottom:0,left:0}, options.offsets || {});
+ var coords = relative.getCoordinates(); //top, left, width, height
var page;
var scroll;
if (!$(element.parentNode) || element.parentNode == document.body) {
@@ -6148,7 +6202,18 @@
page = $(element.parentNode).getContentBoxSize(); //width, height
scroll = $(element.parentNode).getScroll();
- var coords = relative.getCoordinates(); //top, left, width, height
+ if (relative == document.body) {
+ // adjust coords for the scroll offsets to make the object
+ // appear in the right part of the page.
+ coords.left += scroll.x;
+ coords.top += scroll.y;
+ } else if (element.parentNode == relative) {
+ // if the element is opening *inside* its relative, we want
+ // it to position correctly within it so top/left becomes
+ // the reference system.
+ coords.left = 0;
+ coords.top = 0;
var size = element.getMarginBoxSize(); //width, height
var left;
var right;
@@ -6329,7 +6394,10 @@
makeChrome: function(element) {
var c = new Element('div', {
- 'class':'jxChrome'
+ 'class':'jxChrome',
+ events: {
+ contextmenu: function(e) { e.stop(); }
/* add to element so we can get the background image style */
@@ -6343,8 +6411,9 @@
c.setStyle('padding', 0);
/* get the chrome image from the background image of the element */
+ /* the app: protocol check is for adobe air support */
var src = c.getStyle('backgroundImage');
- if (!(src.contains('http://') || src.contains('https://') || src.contains('file://'))) {
+ if (!(src.contains('http://') || src.contains('https://') || src.contains('file://') || src.contains('app:/'))) {
src = null;
} else {
src = src.slice(4,-1);
@@ -6366,7 +6435,9 @@
}).adopt(
new Element('img',{
'class':'png24',
- src:src
+ src:src,
+ alt: '',
+ title: ''
}, this);
@@ -6446,8 +6517,12 @@
$(this.addable || this.domObj).inject(reference,where);
this.fireEvent('addTo',this);
return this;
+ toElement: function() {
+ return this.addable || this.domObj;
-});// $Id: button.js 242 2008-12-10 15:19:21Z pagameba $
+});// $Id: button.js 258 2009-03-31 17:26:30Z pagameba $
* Class: Jx.Button
* Jx.Button creates a clickable element that can be added to a web page.
@@ -6540,6 +6615,7 @@
Jx.Button = new Class({
+ Family: 'Jx.Button',
* Implements:
* * Options
@@ -6671,7 +6747,9 @@
if (this.options.image || !this.options.label) {
var i = new Element('img', {
'class':'jx'+this.options.type+'Icon',
- 'src': Jx.aPixel.src
+ 'src': Jx.aPixel.src,
+ alt: '',
+ title: ''
//if image is not a_pixel, set the background image of the image
//otherwise let the default css take over.
@@ -6806,7 +6884,9 @@
if (!this.domImg) {
+ alt: '',
+ title: ''
if (this.options.imageClass) {
i.addClass(this.options.imageClass);
@@ -6875,7 +6955,7 @@
blur: function() {
this.domA.blur();
-});// $Id: button.flyout.js 247 2008-12-10 19:21:02Z fred.warnock $
+});// $Id: button.flyout.js 261 2009-03-31 18:36:52Z pagameba $
* Class: Jx.Button.Flyout
* Flyout buttons expose a panel when the user clicks the button. The
@@ -6929,6 +7009,7 @@
* This file is licensed under an MIT style license
Jx.Button.Flyout = new Class({
+ Family: 'Jx.Button.Flyout',
* Extends:
* <Jx.Button>
@@ -6962,11 +7043,6 @@
if (!Jx.Button.Flyout.Stack) {
Jx.Button.Flyout.Stack = [];
- var content = null;
- if (options && options.content) {
- content = options.content;
- options.content = null;
this.parent(options);
this.domA.addClass('jx'+this.options.type+'Flyout');
@@ -6983,7 +7059,6 @@
this.contentContainer.adopt(this.content);
this.content.store('jxFlyout', this);
- this.options.content = content;
this.loadContent(this.content);
this.keypressWatcher = this.keypressHandler.bindWithEvent(this);
this.hideWatcher = this.clickHandler.bindWithEvent(this);
@@ -7101,7 +7176,7 @@
Jx.Button.Flyout.Stack[Jx.Button.Flyout.Stack.length - 1].hide();
-});// $Id: button.multi.js 246 2008-12-10 19:09:41Z fred.warnock $
+});// $Id: button.multi.js 276 2009-04-01 14:32:54Z pagameba $
* Class: Jx.Button.Multi
* Multi buttons are used to contain multiple buttons in a drop down list
@@ -7154,6 +7229,7 @@
Jx.Button.Multi = new Class({
+ Family: 'Jx.Button.Multi',
* Extends:
* <Jx.Button>
@@ -7223,11 +7299,13 @@
document.addEvent('mousedown', this.hideWatcher);
document.addEvent('keyup', this.keypressWatcher);
+ /* why were we doing this? It was affecting issue 13
if (e.$extended) {
e.stop();
} else if (e.event && e.event.$extended) {
e.event.stop();
this.fireEvent('show', this);
}).bindWithEvent(this.menu),
'mouseenter':(function(){
@@ -7275,7 +7353,11 @@
}).bind(this)
- a.adopt(new Element('img', {src: Jx.aPixel.src}));
+ a.adopt(new Element('img', {
+ src: Jx.aPixel.src,
+ alt: '',
+ title: ''
this.domObj.adopt(a);
this.discloser = a;
if (this.options.items) {
@@ -7388,7 +7470,7 @@
this.setActiveButton(button);
button.clicked();
-});// $Id: colorpalette.js 241 2008-12-10 15:11:05Z pagameba $
+});// $Id: colorpalette.js 258 2009-03-31 17:26:30Z pagameba $
* Class: Jx.ColorPalette
* A Jx.ColorPalette presents a user interface for selecting colors. Currently,
@@ -7418,6 +7500,7 @@
Jx.ColorPalette = new Class({
+ Family: 'Jx.ColorPalette',
* Implements:
* * Options
@@ -7434,7 +7517,8 @@
parent: null,
color: '#000000',
alpha: 1,
- hexColors: ['00', '33', '66', '99', 'CC', 'FF']
+ hexColors: ['00', '33', '66', '99', 'CC', 'FF'],
+ alphaLabel: 'alpha (%)'
@@ -7491,7 +7575,7 @@
top.adopt(this.colorInput);
- this.alphaLabel = new Element('label', {'class':'jxAlphaLabel', 'html':'alpha (%)'});
+ this.alphaLabel = new Element('label', {'class':'jxAlphaLabel', 'html':this.options.alphaLabel});
top.adopt(this.alphaLabel);
this.alphaInput = new Element('input', {
@@ -7692,7 +7776,7 @@
-// $Id: button.color.js 241 2008-12-10 15:11:05Z pagameba $
+// $Id: button.color.js 258 2009-03-31 17:26:30Z pagameba $
* Class: Jx.Button.Color
* A <Jx.ColorPalette> wrapped up in a Jx.Button. The button includes a
@@ -7720,6 +7804,7 @@
Jx.Button.Color = new Class({
+ Family: 'Jx.Button.Color',
* Extends:
* <Jx.Button.Flyout>
@@ -7866,7 +7951,7 @@
this.selectedSwatch.setStyles(styles);
-// $Id: buttonset.js 241 2008-12-10 15:11:05Z pagameba $
+// $Id: buttonset.js 258 2009-03-31 17:26:30Z pagameba $
* Class: Jx.ButtonSet
* A ButtonSet manages a set of <Jx.Button> instances by ensuring that only one
@@ -7895,6 +7980,7 @@
Jx.ButtonSet = new Class({
+ Family: 'Jx.ButtonSet',
* Implements:
* * Events
@@ -7998,7 +8084,7 @@
-// $Id: grid.js 241 2008-12-10 15:11:05Z pagameba $
+// $Id: grid.js 258 2009-03-31 17:26:30Z pagameba $
* Class: Jx.Grid
* A tabular control that has fixed scrolling headers on the rows and columns
@@ -8030,6 +8116,7 @@
Jx.Grid = new Class({
+ Family: 'Jx.Grid',
Implements: [Options, Events, Jx.Addable],
domObj : null,
model : null,
@@ -8923,6 +9010,7 @@
* has selected a cell by clicking on the cell in the grid.
Jx.Grid.Model = new Class({
+ Family: 'Jx.Grid.Model',
Implements: [Events, Options],
options: {
colHeaderHeight: 28,
@@ -8974,7 +9062,7 @@
-// $Id: layout.js 241 2008-12-10 15:11:05Z pagameba $
+// $Id: layout.js 258 2009-03-31 17:26:30Z pagameba $
* Class: Jx.Layout
* Jx.Layout is used to provide more flexible layout options for applications
@@ -9001,6 +9089,7 @@
Jx.Layout = new Class({
+ Family: 'Jx.Layout',
* Implements:
* * Options
@@ -9375,7 +9464,7 @@
this.fireEvent('sizeChange',this);
-});// $Id: menu.js 244 2008-12-10 15:32:49Z pagameba $
+});// $Id: menu.js 304 2009-04-02 18:57:18Z pagameba $
* Class: Jx.Menu
* A main menu as opposed to a sub menu that lives inside the menu.
@@ -9394,6 +9483,7 @@
Jx.Menu = new Class({
+ Family: 'Jx.Menu',
* Implements:
* * Options
@@ -9522,6 +9612,9 @@
eventInMenu: function(e) {
var target = $(e.target);
+ if (!target) {
+ return false;
if (target.descendantOf(this.domObj) ||
target.descendantOf(this.subDomObj)) {
return true;
@@ -9552,7 +9645,11 @@
hide: function(e) {
if (e) {
- if (this.eventInMenu(e)) {
+ if (this.visibleItem && this.visibleItem.eventInMenu) {
+ if (this.visibleItem.eventInMenu(e)) {
+ return;
+ } else if (this.eventInMenu(e)) {
return;
@@ -9579,6 +9676,7 @@
var e = o.event;
if (Jx.Menu.Menus[0]) {
if (Jx.Menu.Menus[0] != this) {
+ Jx.Menu.Menus[0].button.blur();
Jx.Menu.Menus[0].hide(e);
} else {
this.hide();
@@ -9589,7 +9687,7 @@
return;
Jx.Menu.Menus[0] = this;
+ this.button.focus();
this.contentContainer.setStyle('visibility','hidden');
this.contentContainer.setStyle('display','block');
$(document.body).adopt(this.contentContainer);
@@ -9612,7 +9710,9 @@
this.button.domA.addClass('jx'+this.button.options.type+'Active');
if (e) {
- e.stop();
+ //why were we doing this? it is affecting the closing of
+ //other elements like flyouts (issue 13)
+ //e.stop();
/* fix bug in IE that closes the menu as it opens because of bubbling */
@@ -9645,7 +9745,7 @@
-// $Id: menu.item.js 242 2008-12-10 15:19:21Z pagameba $
+// $Id: menu.item.js 258 2009-03-31 17:26:30Z pagameba $
* Class: Jx.Menu.Item
* A menu item is a single entry in a menu. It is typically composed of
@@ -9668,6 +9768,7 @@
Jx.Menu.Item = new Class({
+ Family: 'Jx.Menu.Item',
* Extends:
* <Jx.Button>
@@ -9692,12 +9793,10 @@
* options - {Object} an object containing options for <Jx.Button::initialize>
initialize: function(options) {
- this.parent($merge(
+ this.parent($merge({
image: Jx.aPixel.src
- options,
+ options, {
container:'li',
type:'MenuItem',
toggleClass: (options.image ? null : this.options.toggleClass)
@@ -9760,7 +9859,7 @@
-// $Id: menu.separator.js 241 2008-12-10 15:11:05Z pagameba $
+// $Id: menu.separator.js 258 2009-03-31 17:26:30Z pagameba $
* Class: Jx.Menu.Separator
* A convenience class to create a visual separator in a menu.
@@ -9775,6 +9874,7 @@
Jx.Menu.Separator = new Class({
+ Family: 'Jx.Menu.Separator',
* Property: domObj
* {HTMLElement} the HTML element that the separator is contained
@@ -9815,7 +9915,7 @@
* Show the menu item
show: $empty
-});// $Id: menu.submenu.js 244 2008-12-10 15:32:49Z pagameba $
+});// $Id: menu.submenu.js 305 2009-04-02 18:58:16Z pagameba $
* Class: Jx.Menu.SubMenu
* A sub menu contains menu items within a main menu or another
@@ -9834,6 +9934,7 @@
Jx.Menu.SubMenu = new Class({
+ Family: 'Jx.Menu.SubMenu',
* Extends:
* <Jx.Menu.Item>
@@ -9841,12 +9942,10 @@
Extends: Jx.Menu.Item,
* Implements:
- * * Options
- * * Events
* * <Jx.AutoPosition>
* * <Jx.Chrome>
- Implements: [Options, Events, Jx.AutoPosition, Jx.Chrome],
+ Implements: [Jx.AutoPosition, Jx.Chrome],
* Property: subDomObj
* {HTMLElement} the HTML container for the sub menu.
@@ -9931,6 +10030,11 @@
+ this.visibleItem.eventInMenu &&
+ this.visibleItem.eventInMenu(e)) {
+ return true;
return $(e.target).descendantOf(this.domObj) ||
$(e.target).descendantOf(this.subDomObj) ||
this.items.some(
@@ -10066,7 +10170,7 @@
this.visibleItem.show();
-});// $Id: menu.context.js 241 2008-12-10 15:11:05Z pagameba $
+});// $Id: menu.context.js 258 2009-03-31 17:26:30Z pagameba $
* Class: Jx.Menu.Context
* A <Jx.Menu> that has no button but can be opened at a specific
@@ -10085,6 +10189,7 @@
Jx.Menu.Context = new Class({
+ Family: 'Jx.Menu.Context',
/** Extends:
* <Jx.Menu>
@@ -10140,7 +10245,7 @@
e.stop();
-});// $Id: panel.js 241 2008-12-10 15:11:05Z pagameba $
+});// $Id: panel.js 269 2009-03-31 21:53:04Z pagameba $
* Class: Jx.Panel
* A panel is a fundamental container object that has a content
@@ -10164,6 +10269,7 @@
Jx.Panel = new Class({
+ Family: 'Jx.Panel',
* Implements:
* * <Jx.ContentLoader>
@@ -10184,11 +10290,19 @@
position: 'absolute',
height: null,
collapse: true,
+ collapseTooltip: 'Collapse/Expand Panel',
+ collapseLabel: 'Collapse',
+ expandLabel: 'Expand',
+ maximizeTooltip: 'Maximize Panel',
+ maximizeLabel: 'Maximize',
detach: false,
close: false,
+ closeTooltip: 'Close Panel',
+ closeLabel: 'Close',
closed: false,
hideTitle: false,
- type: 'Panel'
+ type: 'Panel',
+ toolbars: []
@@ -10228,16 +10342,9 @@
* container's width (using the relative option in <Jx.Layout>).
initialize : function(options){
+ this.setOptions(options);
this.toolbars = options ? options.toolbars || [] : [];
- /* ugly hack around $unlink in mootools */
- this.setOptions(options);
if ($defined(this.options.height) && !$defined(options.position)) {
this.options.position = 'relative';
@@ -10249,7 +10356,9 @@
'class': 'jx'+this.options.type+'Icon',
- src: Jx.aPixel.src
+ alt: '',
+ title: ''
if (this.options.image) {
i.setStyle('backgroundImage', 'url('+this.options.image+')');
@@ -10284,7 +10393,7 @@
if (this.options.collapse) {
var b = new Jx.Button({
image: Jx.aPixel.src,
- tooltip: 'Collapse/Expand Panel',
+ tooltip: this.options.collapseTooltip,
onClick: function() {
that.toggleCollapse();
@@ -10293,14 +10402,15 @@
this.toolbar.add(b);
if (this.menu) {
var item = new Jx.Menu.Item({
- label: 'Collapse',
+ label: this.options.collapseLabel,
onClick: function() { that.toggleCollapse(); }
- this.addEvent('collapse', function() {
- if (that.options.closed) {
- item.setLabel('Expand');
- } else {
- item.setLabel('Collapse');
+ this.addEvents({
+ collapse: function() {
+ item.setLabel(this.options.expandLabel);
+ expand: function() {
+ item.setLabel(this.options.collapseLabel);
this.menu.add(item);
@@ -10310,7 +10420,7 @@
if (this.options.maximize) {
- tooltip: 'Maximize Panel',
+ tooltip: this.options.maximizeTooltip,
that.maximize();
@@ -10319,7 +10429,7 @@
if (this.menu) {
- label: 'Maximize',
+ label: this.options.maximizeLabel,
onClick: function() { that.maximize(); }
@@ -10329,7 +10439,7 @@
if (this.options.close) {
- tooltip: 'Close Panel',
+ tooltip: this.options.closeTooltip,
that.close();
@@ -10338,7 +10448,7 @@
if (this.menu) {
- label: 'Close',
+ label: this.options.closeLabel,
that.close();
@@ -10371,17 +10481,18 @@
this.domObj.adopt(this.contentContainer);
- for (var i=0; i<this.toolbars.length; i++) {
- var tb = this.toolbars[i];
- var position = tb.options.position;
- var tbc = this.toolbarContainers[position];
- if (!tbc) {
- var tbc = new Element('div');
- new Jx.Layout(tbc);
- this.contentContainer.adopt(tbc);
- this.toolbarContainers[position] = tbc;
- tb.addTo(tbc);
+ if ($type(this.options.toolbars) == 'array') {
+ this.options.toolbars.each(function(tb){
+ var position = tb.options.position;
+ var tbc = this.toolbarContainers[position];
+ if (!tbc) {
+ var tbc = new Element('div');
+ new Jx.Layout(tbc);
+ this.contentContainer.adopt(tbc);
+ this.toolbarContainers[position] = tbc;
+ tb.addTo(tbc);
+ }, this);
this.content = new Element('div', {
@@ -10391,10 +10502,9 @@
new Jx.Layout(this.contentContainer);
new Jx.Layout(this.content);
- /* continue ugly $unlink hack */
this.toggleCollapse(this.options.closed);
this.addEvent('addTo', function() {
@@ -10443,38 +10553,39 @@
this.toolbarContainers[position].style.height = '';
}, this);
- tb = this.toolbars[i];
- position = tb.options.position;
- tbc = this.toolbarContainers[position];
- // IE 6 doesn't seem to want to measure the width of things
- // correctly
- if (Browser.Engine.trident4) {
- var oldParent = $(tbc.parentNode);
- tbc.style.visibility = 'hidden';
- $(document.body).adopt(tbc);
- var size = tbc.getBorderBoxSize();
- // put it back into its real parent now we are done measuring
- oldParent.adopt(tbc);
- tbc.style.visibility = '';
- switch(position) {
- case 'top':
- top = size.height;
- break;
- case 'bottom':
- bottom = size.height;
- break;
- case 'left':
- left = size.width;
- break;
- case 'right':
- right = size.width;
- break;
+ position = tb.options.position;
+ tbc = this.toolbarContainers[position];
+ // IE 6 doesn't seem to want to measure the width of
+ // things correctly
+ if (Browser.Engine.trident4) {
+ var oldParent = $(tbc.parentNode);
+ tbc.style.visibility = 'hidden';
+ $(document.body).adopt(tbc);
+ var size = tbc.getBorderBoxSize();
+ // put it back into its real parent now we are done
+ // measuring
+ oldParent.adopt(tbc);
+ tbc.style.visibility = '';
+ switch(position) {
+ case 'top':
+ top = size.height;
+ break;
+ case 'bottom':
+ bottom = size.height;
+ break;
+ case 'left':
+ left = size.width;
+ break;
+ case 'right':
+ right = size.width;
+ break;
+ },this);
tbc = this.toolbarContainers['top'];
if (tbc) {
@@ -10564,12 +10675,12 @@
if (url.indexOf('?') == -1) {
url = url + '?';
- //var ts = (new Date()).getTime();
- //url = url + 'ts='+ts;
- var opts = { method: 'get',
- onComplete:this.panelContentLoaded.bind(this),
- requestHeaders: ['If-Modified-Since', 'Sat, 1 Jan 2000 00:00:00 GMT']};
- var a = new Request(url, opts).send();
+ var a = new Request({
+ url: url,
+ method: 'get',
+ onComplete:this.panelContentLoaded.bind(this),
+ requestHeaders: ['If-Modified-Since', 'Sat, 1 Jan 2000 00:00:00 GMT']
+ }).send();
* Method: panelContentLoaded
@@ -10647,7 +10758,7 @@
this.fireEvent('close', this);
-});// $Id: dialog.js 232 2008-12-02 12:42:14Z pagameba $
+});// $Id: dialog.js 291 2009-04-01 18:31:32Z pagameba $
* Class: Jx.Dialog
* A Jx.Dialog implements a floating dialog. Dialogs represent a useful way
@@ -10678,12 +10789,16 @@
* change - triggered when the value of an input in the dialog is changed
* resize - triggered when the dialog is resized
+ * Extends:
+ * Jx.Dialog extends <Jx.Panel>, please go there for more details.
* License:
* Copyright (c) 2008, DM Solutions Group Inc.
Jx.Dialog = new Class({
+ Family: 'Jx.Dialog',
* Extends:
* <Jx.Panel>
@@ -10715,6 +10830,7 @@
parent: null,
resize: false,
+ resizeTooltip: '',
move: true,
close: true,
collapse: true
@@ -10759,13 +10875,6 @@
this.isOpening = false;
this.firstShow = true;
/* initialize the panel overriding the type and position */
this.parent($merge(
{parent:document.body}, // these are defaults that can be overridden
@@ -10773,13 +10882,9 @@
{type:'Dialog', position: 'absolute'} // these override anything passed to the options
- /* ugly hack continued */
- this.loadContent(this.content);
this.options.parent = $(this.options.parent);
- if (!window.opera && this.options.modal) {
+ if (this.options.modal) {
this.blanket = new Element('div',{
'class':'jxDialogModal',
styles:{
@@ -10835,6 +10940,7 @@
if (this.options.resize) {
this.resizeHandle = new Element('div', {
'class':'jxDialogResize',
+ title: this.options.resizeTooltip,
styles: {
'display':this.options.closed?'none':'block'
@@ -10876,6 +10982,34 @@
+ * Method: resize
+ * resize the dialog. This can be called when the dialog is closed
+ * or open.
+ * Parameters:
+ * width - the new width
+ * height - the new height
+ * autoPosition - boolean, false by default, if resizing an open dialog
+ * setting this to true will reposition it according to its position
+ * rules.
+ resize: function(width, height, autoPosition) {
+ this.options.width = width;
+ this.options.height = height;
+ if (this.domObj.getStyle('display') != 'none') {
+ this.layoutContent();
+ this.domObj.resize(this.options);
+ this.fireEvent('resize');
+ this.resizeChrome(this.domObj);
+ if (autoPosition) {
+ this.position(this.domObj, this.options.parent, this.options);
+ } else {
+ this.firstShow = false;
* Method: sizeChanged
* overload panel's sizeChanged method
@@ -10932,17 +11066,6 @@
- * Method: setTitle
- * set the text of the dialog title.
- * Parameters:
- * title - {String} the new title
- setTitle: function( title ) {
- this.title.childNodes[0].innerHTML = title;
* Method: show
* show the dialog, external code should use the <Jx.Dialog::open> method
* to make the dialog visible.
@@ -11010,6 +11133,23 @@
+ * Method: openURL
+ * open the dialog and load content from the provided url. If you don't
+ * provide a URL then the dialog opens normally.
+ * Parameters:
+ * url - <String> the url to load when opening.
+ openURL: function(url) {
+ if (url) {
+ this.options.contentURL = url;
+ this.loadContent(this.content);
+ } else {
+ this.open();
* Method: open
* open the dialog. This may be delayed depending on the
* asynchronous loading of dialog content. The onOpen
@@ -11024,6 +11164,8 @@
this.show();
this.fireEvent('open', this);
+ } else {
+ this.addEvent('contentLoaded', this.open.bind(this));
@@ -11035,18 +11177,6 @@
this.hide();
this.fireEvent('close');
- * Method: onContentLoaded
- * handle the dialog content being loaded. This triggers
- * processing of inputs and the onContentLoaded callback
- * function (if necessary). Also, if the dialog was previously
- * requested to be opened, this will actually open it.
- onContentLoaded : function() {
- if (this.isOpening) {
- this.open();
@@ -11066,7 +11196,7 @@
-// $Id: panelset.js 241 2008-12-10 15:11:05Z pagameba $
+// $Id: panelset.js 258 2009-03-31 17:26:30Z pagameba $
* Class: Jx.PanelSet
@@ -11097,6 +11227,7 @@
Jx.PanelSet = new Class({
+ Family: 'Jx.PanelSet',
* Implements:
* * Options
@@ -11107,7 +11238,8 @@
options: {
parent: null,
- panels: []
+ panels: [],
+ barTooltip: 'drag this bar to resize'
@@ -11165,7 +11297,7 @@
prepareBar: (function(i) {
var bar = new Element('div', {
'class': 'jxPanelBar',
- 'title': 'drag this bar to resize'
+ 'title': this.options.barTooltip
var panel = this.panels[i];
@@ -11296,7 +11428,7 @@
panel.domObj.resize({top: top, height:panelSize, bottom: null});
-});// $Id: button.combo.js 241 2008-12-10 15:11:05Z pagameba $
+});// $Id: button.combo.js 295 2009-04-02 13:40:34Z pagameba $
* Class: Jx.Button.Combo
* A drop down list of selectable items. Items can be either a string, an image or both.
@@ -11326,17 +11458,12 @@
Jx.Button.Combo = new Class({
+ Family: 'Jx.Button.Combo',
* Extends:
* <Jx.Button.Multi>
Extends: Jx.Button.Multi,
- * Implements:
- * * <Jx.AutoPosition>
- * * <Jx.Chrome>
- Implements: [Jx.AutoPosition, Jx.Chrome],
domObj : null,
ul : null,
@@ -11359,12 +11486,23 @@
* is editable.
- this.parent();
+ this.parent(); //we don't want to pass options to parent
this.domA.removeClass('jxButtonMulti');
- this.domA.addClass('jxButtonComboDefault');
if (this.options.editable) {
+ // remove the button's normal A tag and replace it with a span
+ // so the input ends up not being inside an A tag - this was
+ // causing all kinds of problems for selecting text inside it
+ // due to some user-select: none classes that were introduced
+ // to make buttons not selectable in the first place.
+ // Ultimately I think we want to fix this so that the discloser
+ // in Jx.Button.Multi is a separate beast and we can use it here
+ // without inheriting from multi buttons
+ var s = new Element('span', {'class':'jxButton'});
+ s.adopt(this.domA.firstChild);
+ this.domA = s.replaces(this.domA);
+ this.domA.addClass('jxButtonComboDefault');
this.domA.addClass('jxButtonEditCombo');
this.domInput = new Element('input',{
type:'text',
@@ -11380,12 +11518,12 @@
value: this.options.label
+ this.domLabel.empty();
this.domLabel.addClass('jxComboInput');
this.domLabel.adopt(this.domInput);
} else {
this.discloser.dispose();
this.domA.addClass('jxButtonCombo');
- //this.setLabel(this.options.label);
this.addEvent('click', (function(e){
this.discloser.fireEvent('click', e);
}).bindWithEvent(this));
@@ -11530,7 +11668,7 @@
return value;
-});// $Id: splitter.js 241 2008-12-10 15:11:05Z pagameba $
+});// $Id: splitter.js 282 2009-04-01 17:23:37Z pagameba $
* Class: Jx.Splitter
* a Jx.Splitter creates two or more containers within a parent container
@@ -11552,6 +11690,7 @@
Jx.Splitter = new Class({
+ Family: 'Jx.Splitter',
* Implements:
* * Options
@@ -11587,7 +11726,10 @@
containerOptions: [],
barOptions: [],
layout: 'horizontal',
- snaps: []
+ snaps: [],
+ barTooltip: 'drag this bar to resize',
+ onStart: null,
+ onFinish: null
* Constructor: Jx.Splitter
@@ -11750,7 +11892,7 @@
prepareBar: function() {
var o = new Element('div', {
'class': 'jxSplitBar'+this.options.layout.capitalize(),
+ 'title': this.options.barTitle
return o;
@@ -11771,6 +11913,7 @@
fn = this.dragVertical;
this.bars.each(function(bar){
+ var mask;
new Drag(bar, {
//limit: limit,
modifiers: modifiers,
@@ -11778,11 +11921,25 @@
obj.addClass('jxSplitBarDrag');
onComplete : (function(obj) {
+ mask.destroy();
obj.removeClass('jxSplitBarDrag');
if (obj.retrieve('splitterObj') != this) {
return;
fn.apply(this,[obj]);
+ }).bind(this),
+ onBeforeStart: function(obj) {
+ mask = new Element('div',{'class':'jxSplitterMask'}).inject(obj, 'after');
+ onStart: (function() {
+ if (this.options.onStart) {
+ this.options.onStart();
+ }).bind(this),
+ onFinish: (function() {
+ if (this.options.onFinish) {
+ this.options.onFinish();
}).bind(this)
}, this);
@@ -12215,7 +12372,7 @@
-});// $Id: splitter.snap.js 241 2008-12-10 15:11:05Z pagameba $
+});// $Id: splitter.snap.js 258 2009-03-31 17:26:30Z pagameba $
* Class: Jx.Splitter.Snap
* A helper class to create an element that can snap a split panel open or
@@ -12231,6 +12388,7 @@
Jx.Splitter.Snap = new Class({
+ Family: 'Jx.Splitter.Snap',
* Property: snap
* {HTMLElement} the DOM element of the snap (the thing that gets
@@ -12335,7 +12493,7 @@
-});// $Id: tabset.js 241 2008-12-10 15:11:05Z pagameba $
+});// $Id: tabset.js 258 2009-03-31 17:26:30Z pagameba $
* Class: Jx.TabSet
* A TabSet manages a set of <Jx.Button.Tab> content areas by ensuring that only one
@@ -12372,6 +12530,7 @@
Jx.TabSet = new Class({
+ Family: 'Jx.TabSet',
Implements: [Options,Events],
* Property: tabs
@@ -12479,7 +12638,7 @@
-// $Id: tabbox.js 241 2008-12-10 15:11:05Z pagameba $
+// $Id: tabbox.js 258 2009-03-31 17:26:30Z pagameba $
* Class: Jx.TabBox
* A convenience class to handle the common case of a single toolbar
@@ -12504,6 +12663,7 @@
Jx.TabBox = new Class({
+ Family: 'Jx.TabBox',
* Implements:
* * Options
@@ -12536,7 +12696,8 @@
this.tabBar = new Jx.Toolbar({
type: 'TabBar',
- position: this.options.position
+ position: this.options.position,
+ scroll: this.options.scroll
this.panel = new Jx.Panel({
toolbars: [this.tabBar],
@@ -12609,7 +12770,7 @@
this.tabSet.remove(tab);
-// $Id: button.tab.js 241 2008-12-10 15:11:05Z pagameba $
+// $Id: button.tab.js 261 2009-03-31 18:36:52Z pagameba $
* Class: Jx.Button.Tab
* A single tab in a tab set. A tab has a label (displayed in the tab) and a
@@ -12650,6 +12811,7 @@
Jx.Button.Tab = new Class({
+ Family: 'Jx.Button.Tab',
* Extends:
* <Jx.Button>
@@ -12677,15 +12839,9 @@
* valid options.
initialize : function( options) {
- var content;
this.parent($merge(options, {type:'Tab', toggle:true}));
this.content = new Element('div', {'class':'tabContent'});
new Jx.Layout(this.content, options);
var that = this;
this.addEvent('down', function(){that.content.addClass('tabContentActive');});
@@ -12701,7 +12857,11 @@
}).bind(this)
+ alt: '',
+ title: ''
@@ -12715,7 +12875,7 @@
this.setActive(true);
-});// $Id: toolbar.js 241 2008-12-10 15:11:05Z pagameba $
+});// $Id: toolbar.js 258 2009-03-31 17:26:30Z pagameba $
* Class: Jx.Toolbar
* A toolbar is a container object that contains other objects such as
@@ -12763,6 +12923,7 @@
Jx.Toolbar = new Class({
+ Family: 'Jx.Toolbar',
* Property: items
@@ -12944,7 +13105,7 @@
this.fireEvent('show', item);
-// $Id: toolbar.item.js 241 2008-12-10 15:11:05Z pagameba $
+// $Id: toolbar.item.js 258 2009-03-31 17:26:30Z pagameba $
* Class: Jx.Toolbar.Item
* A helper class to provide a container for something to go into
@@ -12956,6 +13117,7 @@
Jx.Toolbar.Item = new Class( {
+ Family: 'Jx.Toolbar.Item',
Implements: [Options],
options: {
active: true
@@ -12990,7 +13152,7 @@
-});// $Id: toolbar.separator.js 241 2008-12-10 15:11:05Z pagameba $
+});// $Id: toolbar.separator.js 258 2009-03-31 17:26:30Z pagameba $
* Class: Jx.Toolbar.Separator
* A helper class that represents a visual separator in a <Jx.Toolbar>
@@ -13005,6 +13167,7 @@
Jx.Toolbar.Separator = new Class({
+ Family: 'Jx.Toolbar.Separator',
* Property: domObj
* {HTMLElement} The DOM element that goes in the <Jx.Toolbar>
@@ -13020,7 +13183,7 @@
this.domObj.appendChild(this.domSpan);
-// $Id: toolbar.container.js 241 2008-12-10 15:11:05Z pagameba $
+// $Id: toolbar.container.js 258 2009-03-31 17:26:30Z pagameba $
* Class: Jx.Toolbar.Container
* A toolbar container contains toolbars. A single toolbar container fills the
@@ -13042,6 +13205,7 @@
Jx.Toolbar.Container = new Class({
+ Family: 'Jx.Toolbar.Container',
Implements: [Options,Events, Jx.Addable],
* Property: domObj
@@ -13164,7 +13328,6 @@
measure: function() {
if ((!this.scrollLeftSize || !this.scrollLeftSize.x) && this.domObj.parentNode) {
this.scrollLeftSize = this.scrollLeft.domObj.getSize();
this.scrollRightSize = this.scrollRight.domObj.getSize();
@@ -13265,8 +13428,22 @@
scrollIntoView: function(item) {
var width = this.domObj.getSize().x;
var coords = item.domObj.getCoordinates(this.scroller);
- var l = this.scroller.getStyle('left').toInt();
+ //left may be set to auto or even a zero length string.
+ //In the previous version, in air, this would evaluate to
+ //NaN which would cause the right hand scroller to show when
+ //the component was first created.
+ //So, get the left value first
+ var l = this.scroller.getStyle('left');
+ //then check to see if it's auto or a zero length string
+ if (l === 'auto' || l.length <= 0) {
+ //If so, set to 0.
+ l = 0;
+ } else {
+ //otherwise, convert to int
+ l = l.toInt();
var slSize = this.scrollLeftSize ? this.scrollLeftSize.x : 0;
var srSize = this.scrollRightSize ? this.scrollRightSize.x : 0;
@@ -13295,13 +13472,12 @@
} else {
this.scrollRight.domObj.setStyle('visibility', '');
if (left != l) {
this.scrollFx.start('left', left);
-// $Id: treeitem.js 239 2008-12-10 14:53:58Z pagameba $
+// $Id: treeitem.js 301 2009-04-02 16:12:11Z pagameba $
* Class: Jx.TreeItem
* An item in a tree. An item is a leaf node that has no children.
@@ -13327,6 +13503,7 @@
Jx.TreeItem = new Class ({
+ Family: 'Jx.TreeItem',
* Property: domObj
@@ -13374,7 +13551,12 @@
this.domObj.id = this.options.id;
- this.domNode = new Element('img',{'class': 'jxTreeImage', src: Jx.aPixel.src});
+ this.domNode = new Element('img',{
+ 'class': 'jxTreeImage',
+ alt: '',
+ title: ''
this.domObj.appendChild(this.domNode);
this.domLabel = (this.options.draw) ?
@@ -13389,7 +13571,12 @@
draw: function() {
- var domImg = new Element('img',{'class':'jxTreeIcon', src: Jx.aPixel.src});
+ var domImg = new Element('img',{
+ 'class':'jxTreeIcon',
+ alt: '',
+ title: ''
domImg.setStyle('backgroundImage', 'url('+this.options.image+')');
@@ -13407,14 +13594,17 @@
domA.addEvents({
click: this.selected.bind(this),
dblclick: this.selected.bind(this),
- contextmenu: this.showMenu.bind(this),
drag: function(e) {e.stop();},
- mousedown: function(e) {
- domA.addClass('jxTreeItemPressed');
- hasFocus = true;
- mouseDown = true;
- domA.focus();
+ contextmenu: function(e) { e.stop(); },
+ mousedown: (function(e) {
+ domA.addClass('jxTreeItemPressed');
+ hasFocus = true;
+ mouseDown = true;
+ domA.focus();
+ if (e.rightClick && this.options.contextMenu) {
+ this.options.contextMenu.show(e);
+ }).bind(this),
mouseup: function(e) {
domA.removeClass('jxTreeItemPressed');
mouseDown = false;
@@ -13502,25 +13692,9 @@
* e - {Event} the DOM event
selected : function(e) {
- this.lastEvent = new Event(e);
this.fireEvent('click', this);
- * Method: showMenu
- * Called when the DOM element for the TreeItem is right-clicked. The
- * node is selected and the context menu displayed (if there is one).
- * Parameters:
- * e - {Event} the DOM event
- showMenu: function(e) {
- if (this.contextMenu) {
- this.contextMenu.show(this.lastEvent);
- this.lastEvent.stop();
* Method: getName
* Get the label associated with a TreeItem
@@ -13544,7 +13718,7 @@
this.domObj.addClass('jxDisabled');
-});// $Id: treefolder.js 240 2008-12-10 15:04:11Z pagameba $
+});// $Id: treefolder.js 258 2009-03-31 17:26:30Z pagameba $
* Class: Jx.TreeFolder
* A Jx.TreeFolder is an item in a tree that can contain other items. It is
@@ -13563,6 +13737,7 @@
Jx.TreeFolder = new Class({
+ Family: 'Jx.TreeFolder',
Extends: Jx.TreeItem,
@@ -13607,7 +13782,6 @@
this.nodes = [];
this.subDomObj = new Element('ul', {'class':'jxTree'});
this.domObj.appendChild(this.subDomObj);
- this.subDomObj.className = 'jxTree';
if (this.options.open) {
this.expand();
} else {
@@ -13878,7 +14052,7 @@
return null;
-});// $Id: tree.js 241 2008-12-10 15:11:05Z pagameba $
+});// $Id: tree.js 258 2009-03-31 17:26:30Z pagameba $
* Class: Jx.Tree
* Jx.Tree displays hierarchical data in a tree structure of folders and nodes.
@@ -13895,6 +14069,7 @@
Jx.Tree = new Class({
+ Family: 'Jx.Tree',
Implements: [Jx.Addable],
Extends: Jx.TreeFolder,
Modified: trunk/widgets/Legend.js
--- trunk/widgets/Legend.js 2009-04-03 14:48:38 UTC (rev 1826)
+++ trunk/widgets/Legend.js 2009-04-03 18:30:09 UTC (rev 1827)
@@ -251,10 +251,20 @@
label: OpenLayers.i18n('defaultMapTitle'),
open: true,
draw: this.renderFolder,
+ contextMenu: this.getContextMenu(),
'class':'fusionLegendFolder'
this.oRoot = new Jx.TreeFolder(opt);
- this.oRoot.contextMenu = this.getContextMenu(this.oRoot);
+ this.oRoot.options.contextMenu.add(
+ new Jx.Menu.Item({
+ label: OpenLayers.i18n('collapse'),
+ onClick: OpenLayers.Function.bind(this.collapseBranch, this, this.oRoot)
+ label: OpenLayers.i18n('expand'),
+ onClick: OpenLayers.Function.bind(this.expandBranch, this, this.oRoot)
this.oTree.append(this.oRoot);
@@ -267,47 +277,23 @@
this.extentsChangedWatcher = this.update.bind(this);
- getContextMenu: function(folder) {
- if (folder instanceof Jx.TreeFolder) {
- return new Jx.Menu.Context(this.name).add(
- new Jx.Menu.Item({
- label: OpenLayers.i18n('collapse'),
- onClick: OpenLayers.Function.bind(this.collapseBranch, this, folder)
- label: OpenLayers.i18n('expand'),
- onClick: OpenLayers.Function.bind(this.expandBranch, this, folder)
- label: OpenLayers.i18n('refresh'),
- onClick: OpenLayers.Function.bind(this.update, this, folder)
- label: OpenLayers.i18n('collapseAll'),
- onClick: OpenLayers.Function.bind(this.collapseAll, this, folder)
- label: OpenLayers.i18n('expandAll'),
- onClick: OpenLayers.Function.bind(this.expandAll, this, folder)
- } else {
+ getContextMenu: function() {
+ return new Jx.Menu.Context(this.name).add(
+ label: OpenLayers.i18n('refresh'),
+ onClick: OpenLayers.Function.bind(this.update, this)
+ label: OpenLayers.i18n('collapseAll'),
+ onClick: OpenLayers.Function.bind(this.collapseAll, this)
+ label: OpenLayers.i18n('expandAll'),
+ onClick: OpenLayers.Function.bind(this.expandAll, this)
expandAll: function(folder) {
for (var i=0; i<this.oTree.nodes.length; i++) {
var item = this.oTree.nodes[i];
@@ -425,12 +411,22 @@
label: group.legendLabel,
open: group.expandInLegend,
group.legend.treeItem = new Jx.TreeFolder(opt);
- group.legend.treeItem.contextMenu = this.getContextMenu(group.legend.treeItem);
group.legend.treeItem.domObj.store('data', group);
+ group.legend.treeItem.options.contextMenu.add(
+ onClick: OpenLayers.Function.bind(this.collapseBranch, this, group.legend.treeItem)
+ onClick: OpenLayers.Function.bind(this.expandBranch, this, group.legend.treeItem)
folder.append(group.legend.treeItem);
group.legend.treeItem.checkBox.checked = group.visible?true:false;
OpenLayers.Event.observe(group.legend.treeItem.checkBox, 'click', OpenLayers.Function.bind(this.stateChanged, this, group));
@@ -616,11 +612,23 @@
isOpen: layer.expandInLegend,
'class':'fusionLegendItemCheckbox',
// image overrides
image: this.imgLayerThemeIcon
var folder = new Jx.TreeFolder(opt);
- folder.contextMenu = this.getContextMenu(folder);
+ folder.options.contextMenu.add(
+ onClick: OpenLayers.Function.bind(this.collapseBranch, this, folder)
+ onClick: OpenLayers.Function.bind(this.expandBranch, this, folder)
var layerInfo = layer.oMap.getLayerInfoUrl(layer.layerName);
if (layerInfo) {
var a = document.createElement('a');
@@ -661,9 +669,9 @@
} else {
opt.image = layer.oMap.getLegendImageURL(scale, layer, style);
+ opt.contextMenu = this.getContextMenu();
var item = new Jx.TreeItem(opt);
- item.contextMenu = this.getContextMenu(item);
if (bCheckBox) {
//item.domObj.insertBefore(layer.legend.checkBox, item.domObj.childNodes[1]);
/* only need to add layer info if it has a check box too */
@@ -726,7 +734,7 @@
events: {
click: this.selected.bindWithEvent(this),
dblclick: this.selected.bindWithEvent(this),
- contextmenu: this.showMenu.bindWithEvent(this)
+ contextmenu: this.options.contextMenu.show.bindWithEvent(this.options.contextMenu)
domA.appendChild(this.domImg);
@@ -756,7 +764,7 @@
events: {
@@ -796,7 +804,7 @@
events: {
More information about the fusion-commits
