[fusion-commits] r1838 - trunk/layers/MapGuide
svn_fusion at osgeo.org
Wed Apr 29 11:44:26 EDT 2009
Author: pagameba
Date: 2009-04-29 11:44:26 -0400 (Wed, 29 Apr 2009)
New Revision: 1838
trunk/layers/MapGuide/MapGuideViewerApi.js
re #249, #250 update viewer API to correctly locate the Fusion instance and add a ClearDigitization method.
Modified: trunk/layers/MapGuide/MapGuideViewerApi.js
--- trunk/layers/MapGuide/MapGuideViewerApi.js 2009-04-29 15:05:58 UTC (rev 1837)
+++ trunk/layers/MapGuide/MapGuideViewerApi.js 2009-04-29 15:44:26 UTC (rev 1838)
@@ -30,6 +30,13 @@
var mgApimgApiActiveWidget = null;
var mgApiActiveControl = null;
var mgApiDrawControls;
+var mgApiDigitizingLayer = null;
+var mgApiInitialized = false;
+var MainFusionWindow = GetFusionWindow();
+var OpenLayers = MainFusionWindow.OpenLayers;
+var Fusion = MainFusionWindow.Fusion;
+var Class = MainFusionWindow.Class;
+var Object = MainFusionWindow.Object;
function Refresh() {
var Fusion = window.top.Fusion;
@@ -76,6 +83,12 @@
mgApiStartDigitizing('polygon', handler)
+function ClearDigitization() {
+ if (mgApiDigitizingLayer) {
+ mgApiDigitizingLayer.removeFeatures(mgApiDigitizingLayer.features);
//Theses are the Geometry classes used in the MapGuide Viewer API
function Point(x, y) {
this.X = x;
@@ -129,6 +142,7 @@
//The following methods are private and not intended for use by applications
function mgApiStartDigitizing(type, handler) {
+ mgApiInit();
if (handler) {
var mapWidget = Fusion.getWidgetById(mgApiMapWidgetId);
@@ -204,13 +218,17 @@
//set up of digitizing tools once everything is initialized
function mgApiInit() {
+ if (mgApiInitialized) {
+ return;
+ mgApiInitialized = true;
var map = window.top.Fusion.getWidgetById(mgApiMapWidgetId).oMapOL;
- var digiLayer = new OpenLayers.Layer.Vector("Digitizing Layer", {styleMap: mgApiStyleMap});
- map.addLayers([digiLayer]);
+ mgApiDigitizingLayer = new OpenLayers.Layer.Vector("Digitizing Layer", {styleMap: mgApiStyleMap});
+ map.addLayers([mgApiDigitizingLayer]);
mgApiDrawControls = {
- point: new OpenLayers.Control.DrawFeature(digiLayer,
+ point: new OpenLayers.Control.DrawFeature(mgApiDigitizingLayer,
OpenLayers.Handler.Point, {
handlerOptions: {
layerOptions: {
@@ -218,7 +236,7 @@
- line: new OpenLayers.Control.DrawFeature(digiLayer,
+ line: new OpenLayers.Control.DrawFeature(mgApiDigitizingLayer,
OpenLayers.Handler.Path, {
handlerOptions: {
freehandToggle: null,
@@ -233,7 +251,7 @@
'point': mgApiCheckLine
- linestr: new OpenLayers.Control.DrawFeature(digiLayer,
+ linestr: new OpenLayers.Control.DrawFeature(mgApiDigitizingLayer,
handlerOptions: {
freehand: false,
@@ -244,7 +262,7 @@
- rectangle: new OpenLayers.Control.DrawFeature(digiLayer,
+ rectangle: new OpenLayers.Control.DrawFeature(mgApiDigitizingLayer,
OpenLayers.Handler.RegularPolygon, {
handlerOptions: {
persist: true,
@@ -256,7 +274,7 @@
- polygon: new OpenLayers.Control.DrawFeature(digiLayer,
+ polygon: new OpenLayers.Control.DrawFeature(mgApiDigitizingLayer,
OpenLayers.Handler.Polygon, {
handlerOptions: {
freehand: false,
@@ -286,4 +304,18 @@
+/* locate the Fusion window */
+function GetFusionWindow() {
+ var curWindow = window;
+ while (!curWindow.Fusion) {
+ if (curWindow.parent && curWindow != curWindow.parent) {
+ curWindow = curWindow.parent;
+ } else if(curWindow.opener) {
+ curWindow = curWindow.opener;
+ } else {
+ alert('Could not find Fusion instance');
+ break;
+ return curWindow;
More information about the fusion-commits
