[fusion-commits] r1839 - trunk/layers/MapGuide
svn_fusion at osgeo.org
Wed Apr 29 11:58:45 EDT 2009
Author: pagameba
Date: 2009-04-29 11:58:44 -0400 (Wed, 29 Apr 2009)
New Revision: 1839
trunk/layers/MapGuide/MapGuideViewerApi.js
re #249, #250 fix up the mapguide viewer api callbacks for digitizing Rectangles to actually return a rectangle geometry. Also avoid the toJSONString method added to Object prototype when enumerating controls during initialization.
Modified: trunk/layers/MapGuide/MapGuideViewerApi.js
--- trunk/layers/MapGuide/MapGuideViewerApi.js 2009-04-29 15:44:26 UTC (rev 1838)
+++ trunk/layers/MapGuide/MapGuideViewerApi.js 2009-04-29 15:58:44 UTC (rev 1839)
@@ -161,26 +161,29 @@
function mgApiCallHandler(evt) {
var geom = evt.feature.geometry;
var apiGeom = null;
- switch (geom.CLASS_NAME) {
- case 'OpenLayers.Geometry.Point':
- apiGeom = new Point(geom.x, geom.y);
- break;
- case 'OpenLayers.Geometry.LineString':
- apiGeom = new LineString();
- var nodes = geom.components;
- for (var i=0; i<nodes.length; ++i) {
- var node = nodes[i];
- apiGeom.AddPoint(new Point(node.x, node.y));
- break;
- case 'OpenLayers.Geometry.Polygon':
- var nodes = geom.components[0].components;
- break;
+ if (this.handler.CLASS_NAME == 'OpenLayers.Handler.RegularPolygon') {
+ var v = geom.getVertices();
+ apiGeom = new Rectangle(new Point(v[0].x, v[0].y), new Point(v[2].x, v[2].y));
+ } else {
+ switch (geom.CLASS_NAME) {
+ case 'OpenLayers.Geometry.Point':
+ apiGeom = new Point(geom.x, geom.y);
+ break;
+ case 'OpenLayers.Geometry.LineString':
+ apiGeom = new LineString();
+ for (var i=0; i<v.length; ++i) {
+ apiGeom.AddPoint(new Point(v[i].x, v[i].y));
+ break;
+ case 'OpenLayers.Geometry.Polygon':
+ break;
this.userHandler(apiGeom);
@@ -288,8 +291,10 @@
for(var key in mgApiDrawControls) {
- mgApiDrawControls[key].events.register('featureadded', null, mgApiCallHandler);
- map.addControl(mgApiDrawControls[key]);
+ if (mgApiDrawControls[key].events) {
+ mgApiDrawControls[key].events.register('featureadded', null, mgApiCallHandler);
+ map.addControl(mgApiDrawControls[key]);
More information about the fusion-commits
