[fusion-commits] r1840 - in trunk/widgets/Theme: . classes templates
svn_fusion at osgeo.org svn_fusion at osgeo.org
Wed Apr 29 14:05:43 EDT 2009
Author: pagameba
Date: 2009-04-29 14:05:43 -0400 (Wed, 29 Apr 2009)
New Revision: 1840
Added:
   trunk/widgets/Theme/templates/arearuletemplate-1.0.0.xml
   trunk/widgets/Theme/templates/arearuletemplate-1.1.0.xml
   trunk/widgets/Theme/templates/arearuletemplate-1.2.0.xml
   trunk/widgets/Theme/templates/arearuletemplate-1.3.0.xml
Removed:
   trunk/widgets/Theme/templates/arearuletemplate.xml
   trunk/widgets/Theme/classes/layerinfo.php
   trunk/widgets/Theme/classes/property.php
   trunk/widgets/Theme/classes/theme.php
   trunk/widgets/Theme/themecontroller.php
   trunk/widgets/Theme/thememain.php
Re #250, add version-specfic templates for theming as the schema has changed for AreaRule in some versions of the layer schema.  Also clean up some of the PHP so it doesn't output blank text.
Modified: trunk/widgets/Theme/classes/layerinfo.php
--- trunk/widgets/Theme/classes/layerinfo.php	2009-04-29 15:58:44 UTC (rev 1839)
+++ trunk/widgets/Theme/classes/layerinfo.php	2009-04-29 18:05:43 UTC (rev 1840)
@@ -1,36 +1,33 @@
-<?php
-//  Copyright (C) 2004-2006  Autodesk, Inc.
-//  This library is free software; you can redistribute it and/or
-//  modify it under the terms of version 2.1 of the GNU Lesser
-//  General Public License as published by the Free Software Foundation.
-//  This library is distributed in the hope that it will be useful,
-//  but WITHOUT ANY WARRANTY; without even the implied warranty of
-//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
-//  Lesser General Public License for more details.
-//  You should have received a copy of the GNU Lesser General Public
-//  License along with this library; if not, write to the Free Software
-//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
-<?php
-class LayerInfo
-	public $properties = null;
-	public $scaleRanges = null;
-	function __construct($properties, $scaleRanges)
-		$this->properties = $properties;
-		$this->scaleRanges = $scaleRanges;
+<?php
+//  Copyright (C) 2004-2006  Autodesk, Inc.
+//  This library is free software; you can redistribute it and/or
+//  modify it under the terms of version 2.1 of the GNU Lesser
+//  General Public License as published by the Free Software Foundation.
+//  This library is distributed in the hope that it will be useful,
+//  but WITHOUT ANY WARRANTY; without even the implied warranty of
+//  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+//  Lesser General Public License for more details.
+//  You should have received a copy of the GNU Lesser General Public
+//  License along with this library; if not, write to the Free Software
+//  Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA  02110-1301  USA
+class LayerInfo
+	public $properties = null;
+	public $scaleRanges = null;
+	function __construct($properties, $scaleRanges)
+		$this->properties = $properties;
+		$this->scaleRanges = $scaleRanges;
\ No newline at end of file
Modified: trunk/widgets/Theme/classes/property.php
--- trunk/widgets/Theme/classes/property.php	2009-04-29 15:58:44 UTC (rev 1839)
+++ trunk/widgets/Theme/classes/property.php	2009-04-29 18:05:43 UTC (rev 1840)
@@ -1,38 +1,34 @@
-<?php
-<?php
-class Property
-	public $name = '';
-	public $dataType = 0;
-	public $distroTypes = null;
-	function __construct($name, $dataType, $distroTypes)
-		$this->name = $name;
-		$this->dataType = $dataType;
-		$this->distroTypes = $distroTypes;
+<?php
+class Property
+	public $name = '';
+	public $dataType = 0;
+	public $distroTypes = null;
+	function __construct($name, $dataType, $distroTypes)
+		$this->name = $name;
+		$this->dataType = $dataType;
+		$this->distroTypes = $distroTypes;
Modified: trunk/widgets/Theme/classes/theme.php
--- trunk/widgets/Theme/classes/theme.php	2009-04-29 15:58:44 UTC (rev 1839)
+++ trunk/widgets/Theme/classes/theme.php	2009-04-29 18:05:43 UTC (rev 1840)
@@ -16,11 +16,6 @@
-<?php
 require_once('layerinfo.php');
 require_once('property.php');
 // require_once('../Common/constants.php');
@@ -87,6 +82,7 @@
         $map = new MgMap();
         $map->Open($resourceService, $this->args['MAPNAME']);
         $layer = $map->GetLayers()->GetItem($this->args['LAYERNAME']);
         // First get a list of all of the Feature Class properties that can be used for theming.
@@ -229,6 +225,8 @@
         // Load the Layer Definition and Navigate to the specified <VectorScaleRange>
         $doc = DOMDocument::loadXML($byteReader->ToString());
+        $version = $doc->documentElement->getAttribute('version');
+        $template = 'templates/arearuletemplate-'.$version.'.xml';
         $nodeList = $doc->getElementsByTagName('VectorScaleRange');
         $vectorScaleRangecElement = $nodeList->item($this->args['SCALERANGEINDEX']);
@@ -246,7 +244,7 @@
         // Now create the new <AreaRule> elements.
-        $areaRuleTemplate = file_get_contents("templates/arearuletemplate.xml");
+        $areaRuleTemplate = file_get_contents($template);
         $aggregateOptions = new MgFeatureAggregateOptions();
         $portion = 0.0;
Copied: trunk/widgets/Theme/templates/arearuletemplate-1.0.0.xml (from rev 1836, trunk/widgets/Theme/templates/arearuletemplate.xml)
--- trunk/widgets/Theme/templates/arearuletemplate-1.0.0.xml	                        (rev 0)
+++ trunk/widgets/Theme/templates/arearuletemplate-1.0.0.xml	2009-04-29 18:05:43 UTC (rev 1840)
@@ -0,0 +1,17 @@
+<AreaRule>
+ <LegendLabel>%s</LegendLabel>
+ <Filter>%s</Filter>
+ <AreaSymbolization2D>
+  <Fill>
+   <FillPattern>Solid</FillPattern>
+   <ForegroundColor>%s</ForegroundColor>
+   <BackgroundColor>FF000000</BackgroundColor>
+  </Fill>
+  <Stroke>
+   <LineStyle>Solid</LineStyle>
+   <Thickness>0</Thickness>
+   <Color>%s</Color>
+   <Unit>Inches</Unit>
+  </Stroke>
+ </AreaSymbolization2D>
+</AreaRule>
Added: trunk/widgets/Theme/templates/arearuletemplate-1.1.0.xml
--- trunk/widgets/Theme/templates/arearuletemplate-1.1.0.xml	                        (rev 0)
+++ trunk/widgets/Theme/templates/arearuletemplate-1.1.0.xml	2009-04-29 18:05:43 UTC (rev 1840)
@@ -0,0 +1,18 @@
+<AreaRule>
+  <Fill>
+  </Fill>
+  <Stroke>
+   <Color>%s</Color>
+   <SizeContext>DeviceUnits</SizeContext>
+  </Stroke>
+</AreaRule>
Property changes on: trunk/widgets/Theme/templates/arearuletemplate-1.1.0.xml
___________________________________________________________________
Added: trunk/widgets/Theme/templates/arearuletemplate-1.2.0.xml
--- trunk/widgets/Theme/templates/arearuletemplate-1.2.0.xml	                        (rev 0)
+++ trunk/widgets/Theme/templates/arearuletemplate-1.2.0.xml	2009-04-29 18:05:43 UTC (rev 1840)
@@ -0,0 +1,18 @@
+<AreaRule>
+  <Fill>
+  </Fill>
+  <Stroke>
+   <Color>%s</Color>
+  </Stroke>
+</AreaRule>
Property changes on: trunk/widgets/Theme/templates/arearuletemplate-1.2.0.xml
Added: trunk/widgets/Theme/templates/arearuletemplate-1.3.0.xml
--- trunk/widgets/Theme/templates/arearuletemplate-1.3.0.xml	                        (rev 0)
+++ trunk/widgets/Theme/templates/arearuletemplate-1.3.0.xml	2009-04-29 18:05:43 UTC (rev 1840)
@@ -0,0 +1,18 @@
+<AreaRule>
+  <Fill>
+  </Fill>
+  <Stroke>
+   <Color>%s</Color>
+  </Stroke>
+</AreaRule>
Property changes on: trunk/widgets/Theme/templates/arearuletemplate-1.3.0.xml
Deleted: trunk/widgets/Theme/templates/arearuletemplate.xml
--- trunk/widgets/Theme/templates/arearuletemplate.xml	2009-04-29 15:58:44 UTC (rev 1839)
+++ trunk/widgets/Theme/templates/arearuletemplate.xml	2009-04-29 18:05:43 UTC (rev 1840)
@@ -1,18 +0,0 @@
-<AreaRule>
- <LegendLabel>%s</LegendLabel>
- <Filter>%s</Filter>
- <AreaSymbolization2D>
-  <Fill>
-   <FillPattern>Solid</FillPattern>
-   <ForegroundColor>%s</ForegroundColor>
-   <BackgroundColor>FF000000</BackgroundColor>
-  </Fill>
-  <Stroke>
-   <LineStyle>Solid</LineStyle>
-   <Thickness>0</Thickness>
-   <Color>%s</Color>
-   <Unit>Inches</Unit>
-   <SizeContext>DeviceUnits</SizeContext>
-  </Stroke>
- </AreaSymbolization2D>
-</AreaRule>
Modified: trunk/widgets/Theme/themecontroller.php
--- trunk/widgets/Theme/themecontroller.php	2009-04-29 15:58:44 UTC (rev 1839)
+++ trunk/widgets/Theme/themecontroller.php	2009-04-29 18:05:43 UTC (rev 1840)
@@ -16,10 +16,6 @@
-<?php
     $fusionMGpath = '../../layers/MapGuide/php/';
     require_once $fusionMGpath . 'Common.php';
     require_once $fusionMGpath . 'Utilities.php';
@@ -74,4 +70,4 @@
     <tr><td class="Title">Error<hr></td></tr>
     <tr><td><?= $errorMsg ?></td></tr>
     <tr><td><?= $errorDetail ?></td></tr>
-</table>
+</table>
Modified: trunk/widgets/Theme/thememain.php
--- trunk/widgets/Theme/thememain.php	2009-04-29 15:58:44 UTC (rev 1839)
+++ trunk/widgets/Theme/thememain.php	2009-04-29 18:05:43 UTC (rev 1840)
@@ -16,10 +16,6 @@
-<?php
@@ -459,4 +455,4 @@
 </body>
-</html>
+</html>
More information about the fusion-commits mailing list
