[fusion-commits] r1771 - in trunk: layers/MapGuide layers/MapServer lib widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Tue Feb 3 15:55:51 EST 2009
Author: madair
Date: 2009-02-03 15:55:51 -0500 (Tue, 03 Feb 2009)
New Revision: 1771
   trunk/layers/MapGuide/MapGuide.js
   trunk/layers/MapServer/MapServer.js
   trunk/lib/Map.js
   trunk/widgets/Maptip.js
re #127: refactor maptip code into the MapGuide layer type (as was done for MapServer) - also related to issue #166
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js	2009-02-03 20:13:48 UTC (rev 1770)
+++ trunk/layers/MapGuide/MapGuide.js	2009-02-03 20:55:51 UTC (rev 1771)
@@ -1095,7 +1095,54 @@
       return queryParams;
+    getMapTip: function(mapTipWidget) {
+      //console.log('showMaptip');
+        var oBroker = Fusion.oBroker;
+        var x = mapTipWidget.oCurrentPosition.x;
+        var y = mapTipWidget.oCurrentPosition.y;
+        var min = this.mapWidget.pixToGeo(x-mapTipWidget.nTolerance, y-mapTipWidget.nTolerance);
+        var max = this.mapWidget.pixToGeo(x+mapTipWidget.nTolerance, y+mapTipWidget.nTolerance);
+        //this can fail if no map is loaded
+        if (!min) {
+            return;
+        var sGeometry = 'POLYGON(('+ min.x + ' ' +  min.y + ', ' +  min.x + ' ' +  max.y + ', ' + max.x + ' ' +  max.y + ', ' + max.x + ' ' +  min.y + ', ' + min.x + ' ' +  min.y + '))';
+        //var sGeometry = 'POINT('+ min.x + ' ' +  min.y + ')';
+        var maxFeatures = 1;
+        var persist = 0;
+        var selection = 'INTERSECTS';
+        // only select visible layers with maptips defined (1+4)
+        var layerAttributeFilter = 5;
+        //TODO: possibly make the layer names configurable?
+        var layerNames = mapTipWidget.aLayers.toString();
+        var r = new Fusion.Lib.MGRequest.MGQueryMapFeatures(this.getSessionID(),
+                                        this._sMapname,
+                                        sGeometry,
+                                        maxFeatures, persist, selection, layerNames,
+                                        layerAttributeFilter);
+        oBroker.dispatchRequest(r,
+            OpenLayers.Function.bind(Fusion.xml2json, this,
+                  OpenLayers.Function.bind(this.parseMapTip, this)));
+    parseMapTip: function(xhr) {
+        var o;
+        eval("tooltip="+xhr.responseText);
+        this.oMaptip = {t:"",h:""};
+        var t = tooltip['FeatureInformation']['Tooltip'];
+        if (t) {
+          this.oMaptip.t = t[0].replace(/\\n/g, "<br>");
+        var h = tooltip['FeatureInformation']['Hyperlink'];
+        if (h) {
+          this.oMaptip.h = h[0];
+        this.mapWidget.triggerEvent(Fusion.Event.MAP_MAPTIP_REQ_FINISHED, this.oMaptip);
     getLegendImageURL: function(fScale, layer, style) {
       var url = Fusion.getConfigurationItem('mapguide', 'mapAgentUrl');
       url += "?OPERATION=GETLEGENDIMAGE&SESSION=" + layer.oMap.getSessionID();
Modified: trunk/layers/MapServer/MapServer.js
--- trunk/layers/MapServer/MapServer.js	2009-02-03 20:13:48 UTC (rev 1770)
+++ trunk/layers/MapServer/MapServer.js	2009-02-03 20:55:51 UTC (rev 1771)
@@ -29,7 +29,6 @@
  * Implementation of the map widget for MapServer CGI interface services
 Fusion.Event.MAP_LAYER_ORDER_CHANGED = Fusion.Event.lastEventId++;
-Fusion.Event.MAP_MAPTIP_REQ_FINISHED = Fusion.Event.lastEventId++;
 Fusion.Layers.MapServer = OpenLayers.Class(Fusion.Layers, {
     arch: 'MapServer',
@@ -50,7 +49,6 @@
         //console.log('Fusion.Layers.MapServer.initialize');
         Fusion.Layers.prototype.initialize.apply(this, arguments);
         this.registerEventID(Fusion.Event.MAP_SESSION_CREATED);
-        this.registerEventID(Fusion.Event.MAP_MAPTIP_REQ_FINISHED);
         //this.selectionType = extension.SelectionType ? extension.SelectionType[0] : 'INTERSECTS';
         this.sMapFile = mapTag.extension.MapFile ? mapTag.extension.MapFile[0] : '';
@@ -768,13 +766,13 @@
         return oLayer;
-  getMetadata: function(key) {
-      if (typeof this.metadata[key] != 'undefined') {
-          return this.metadata[key];
-      } else {
-          return '';
+    getMetadata: function(key) {
+        if (typeof this.metadata[key] != 'undefined') {
+            return this.metadata[key];
+        } else {
+            return '';
     getLegendImageURL: function(fScale, layer) {
         var sl = Fusion.getScriptLanguage();
@@ -784,31 +782,27 @@
         return url + '?'+params;
-    getMapTip: function(oMapTips,oOptions){
+    getMapTip: function(oMapTips){
         //console.log("MAPSERVER:getMapTip");
         var pos = this.mapWidget.pixToGeo(oMapTips.oCurrentPosition.x, oMapTips.oCurrentPosition.y);
-        var options = {};
-        var dfGeoTolerance = this.mapWidget.pixToGeoMeasure(oOptions.nTolerance);
+        var dfGeoTolerance = this.mapWidget.pixToGeoMeasure(oMapTips.nTolerance);
         var minx = pos.x-dfGeoTolerance;
         var miny = pos.y-dfGeoTolerance;
         var maxx = pos.x+dfGeoTolerance;
         var maxy = pos.y+dfGeoTolerance;
-        options.geometry = 'POLYGON(('+ minx + ' ' + miny + ', ' + minx + ' ' + maxy + ', ' + maxx + ' ' + maxy + ', ' + maxx + ' ' + miny + ', ' + minx + ' ' + miny + '))';
-        options.selectionType = "INTERSECTS";
+        var geometry = 'POLYGON(('+ minx + ' ' + miny + ', ' + minx + ' ' + maxy + ', ' + maxx + ' ' + maxy + ', ' + maxx + ' ' + miny + ', ' + minx + ' ' + miny + '))';
+        var selectionType = "INTERSECTS";
-        var Map = this.mapWidget.aMaps[0];
-        var bPersistant = options.persistent || true;
-        var zoomTo = options.zoomTo ?  true : false;
-        var loadmapScript = '/layers/'+Map.arch + '/php/Maptip.php';
+        var loadmapScript = '/layers/'+ this.arch + '/php/Maptip.php';
         var params = {
-            'mapname': Map._sMapname,
-            'session': Map.getSessionID(),
-            'spatialfilter': options.geometry || '',
-            'maxfeatures': options.maxFeatures || 0, //zero means select all features
-            'variant': 'intersects',
-            'layer': oOptions.layer[0] || '',
-            'textfield': oOptions.textField || '',
-            'customURL': oOptions.customURL || ''
+            'mapname': this._sMapname,
+            'session': this.getSessionID(),
+            'spatialfilter': geometry,
+            'maxfeatures': 0, //zero means select all features
+            'variant': selectionType,
+            'layer': oMapTips.aLayers[0] || '',
+            'textfield': oMapTips.textField || '',
+            'customURL': oMapTips.customURL || ''
         var parseMapTip = this.parseMapTip.bind(this);
         var ajaxOptions = {
@@ -822,10 +816,10 @@
     parseMapTip: function(json){
         this.oMaptip = {};
-        this.oMaptip.t =json.mapTipText;
-        this.oMaptip. h =json.mapTipLink;
-        this.triggerEvent(Fusion.Event.MAP_MAPTIP_REQ_FINISHED,this.oMaptip);
+        this.oMaptip.t = json.mapTipText;
+        this.oMaptip.h = json.mapTipLink;
Modified: trunk/lib/Map.js
--- trunk/lib/Map.js	2009-02-03 20:13:48 UTC (rev 1770)
+++ trunk/lib/Map.js	2009-02-03 20:55:51 UTC (rev 1771)
@@ -40,6 +40,7 @@
 Fusion.Event.MAP_LOADING = Fusion.Event.lastEventId++;
 Fusion.Event.MAP_RELOADED = Fusion.Event.lastEventId++;
 Fusion.Event.MAP_SESSION_CREATED = Fusion.Event.lastEventId++;
+Fusion.Event.MAP_MAPTIP_REQ_FINISHED = Fusion.Event.lastEventId++;
 Fusion.Constant.LAYER_POINT_TYPE = 0;
@@ -166,6 +167,7 @@
         this.registerEventID(Fusion.Event.MAP_RELOADED);
         this.registerEventID(Fusion.Event.MAP_SELECTION_ON);
         this.registerEventID(Fusion.Event.MAP_SELECTION_OFF);
+        this.registerEventID(Fusion.Event.MAP_MAPTIP_REQ_FINISHED);
         this.registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.mapLoaded,this));
@@ -1009,6 +1011,11 @@
         return OpenLayers.Util.getParameterString(queryParams);
+     getMapTip: function(oMapTips) {
+        //TODO send this to the correct aMap object
+        this.aMaps[0].getMapTip(oMapTips);
      supressContextMenu: function( bSupress ) {
          this.bSupressContextMenu = bSupress;
Modified: trunk/widgets/Maptip.js
--- trunk/widgets/Maptip.js	2009-02-03 20:13:48 UTC (rev 1770)
+++ trunk/widgets/Maptip.js	2009-02-03 20:55:51 UTC (rev 1771)
@@ -70,9 +70,14 @@
         this.delay = json.Delay ? parseInt(json.Delay[0]) : 350;
         this.nTolerance = json.Tolerance ? parseInt(json.Tolerance[0]) : 2;
-        this.layer = json.Layer;
         this.customURL =  json.CustomURL;
         this.textField = json.TextField;
+        this.aLayers = [];
+        if (json.Layer) {
+            for (var i=0; i<json.Layer.length; i++) {
+                this.aLayers.push(json.Layer[i]);
         //prepare the container div for the maptips
         Fusion.addWidgetStyleSheet(widgetTag.location + 'Maptip/Maptip.css');
@@ -104,7 +109,7 @@
         this.getMap().observeEvent('mouseout', OpenLayers.Function.bind(this.mouseOut, this));
         this.eventListener = false;
-        this.getMap().aMaps[0].registerForEvent(Fusion.Event.MAP_MAPTIP_REQ_FINISHED,OpenLayers.Function.bind(this._display,this));
+        this.getMap().registerForEvent(Fusion.Event.MAP_MAPTIP_REQ_FINISHED,OpenLayers.Function.bind(this._display,this));
@@ -142,14 +147,7 @@
             this.nTimer = null;
-        this.options = {};
-        this.options.e = e;
-        this.options.nTolerance = this.nTolerance;
-        this.options.textField = this.textField
-        this.options.layer = this.layer
-        this.options.customURL = this.customURL
-        this.nTimer = window.setTimeout(OpenLayers.Function.bind(this.showMaptip, this,this.options,e), this.delay);
+        this.nTimer = window.setTimeout(OpenLayers.Function.bind(this.showMaptip, this), this.delay);
         //Event.stop(e);
@@ -162,9 +160,9 @@
         this.mouseIsDown = false;
-    showMaptip: function(oOptions) {
+    showMaptip: function() {
         //console.log("MAPTIP: showMaptip");
-        this.getMap().aMaps[0].getMapTip(this,oOptions);
+        this.getMap().getMapTip(this);
More information about the fusion-commits mailing list
