[fusion-commits] r1772 - trunk/widgets/Maptip
svn_fusion at osgeo.org
Wed Feb 4 10:03:00 EST 2009
Author: pdeschamps
Date: 2009-02-04 10:03:00 -0500 (Wed, 04 Feb 2009)
New Revision: 1772
Added:
trunk/widgets/Maptip/Maptip.php
adding backend php script for map tips widget for mapserver
Added: trunk/widgets/Maptip/Maptip.php
--- trunk/widgets/Maptip/Maptip.php (rev 0)
+++ trunk/widgets/Maptip/Maptip.php 2009-02-04 15:03:00 UTC (rev 1772)
@@ -0,0 +1,358 @@
+ * Fusion.Widget.Maptip2
+ * $Id: $
+ * Portions copyright (c) 2007, DM Solutions Group Inc.
+ * Portions copyright (c) 2008, ENPLAN
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+ * Class: Fusion.Widget.Maptip
+ * Displays tooltips over the map when the mouse is hovered for some
+ * time. On the MapGuide platform, you must configure tooltips for
+ * each layer using Studio or Web Studio by editing the LayerDefinition
+ * Settings and specifying an expression for the tooltip. MapServer users
+ * can instead specify which attribute fields in the layer are to be used
+ * for the maptip text and optional hyperlink.
+ * Delay (optional)
+ * This is the delay, in milliseconds, that the user must keep the mouse
+ * in the same position in order for the maptip to appear. The default,
+ * if not specified, is 350 milliseconds.
+ * Layer
+ * -MapGuide(optional, multiple): This is the name of a layer from the MapDefinition
+ * to get the tooltip from. If no Layer elements are specified, then all layers
+ * will be queried and the top-most one will be displayed. Multiple Layer
+ * tags can be added, allowing tooltips to come from different layers.
+ * -Mapserver(required): This is the name of a layer from the MapFile whose attributes
+ * will be used to populate the maptip text. Mapserver only supports a single layer.
+ * If more than one layer is specified, only the first will be used.
+ * Textfield (required for MapServer only)
+ * Field to use for the maptip text for MapServer-based Fusion installs.
+ * Since this is not specified server-side, as in MapGuide, it must be
+ * declared here.
+ * Linkfield (optional for MapServer only)
+ * Field to use for the maptip hyperlink target URL on MapServer fusion installs.
+ * As with Textfield above, it must be declared here if needed.
+Fusion.Widget.Maptip2 = OpenLayers.Class(Fusion.Widget, {
+ oCurrentPosition: null,
+ oMapTipPosition: null,
+ nTimer: null,
+ delay: null,
+ aLayers: null,
+ bOverTip: false,
+ textField: null,
+ linkField: null,
+ customURL: null,
+ sWinFeatures : 'menubar=no,location=no,resizable=no,status=no',
+ initializeWidget: function(widgetTag){
+ // console.log("maptipStarted");
+ // Object.inheritFrom(this, Fusion.Widget.prototype, [widgetTag, true]);
+ var json = widgetTag.extension;
+ this.sTarget = json.Target ? json.Target[0] : "MaptipWindow";
+ if (json.WinFeatures) {
+ this.sWinFeatures = json.WinFeatures[0];
+ this.delay = json.Delay ? parseInt(json.Delay[0]) : 350;
+ this.nTolerance = json.Tolerance ? parseInt(json.Tolerance[0]) : 2;
+ this.aLayers = [];
+ if (json.Layer) {
+ for (var i=0; i<json.Layer.length; i++) {
+ this.aLayers.push(json.Layer[i]);
+ this.customURL = json.CustomURL;
+ this.textField = json.TextField;
+ this.linkField = json.Linkfield;
+ //prepare the container div for the maptips
+ Fusion.addWidgetStyleSheet(widgetTag.location + 'Maptip/Maptip.css');
+ if (this.domObj) {
+ this.domObj.parentNode.removeChild(this.domObj);
+ } else {
+ this.domObj = document.createElement('div');
+ this.domObj.className = 'maptipContainer';
+ this.domObj.style.display = 'none';
+ this.domObj.style.top = '0px';
+ this.domObj.style.left = '0px';
+ //create an iframe to stick behind the maptip to prevent clicks being passed through to the map
+ this.iframe = document.createElement('iframe');
+ this.iframe.className = 'maptipShim';
+ this.iframe.scrolling = 'no';
+ this.iframe.frameborder = 0;
+ OpenLayers.Event.observe(this.domObj, 'mouseover', OpenLayers.Function.bind(this.mouseOverTip, this));
+ OpenLayers.Event.observe(this.domObj, 'mouseout', OpenLayers.Function.bind(this.mouseOutTip, this));
+ var oDomElem = this.getMap().getDomObj();
+ document.getElementsByTagName('BODY')[0].appendChild(this.domObj);
+ this.getMap().observeEvent('mousemove', OpenLayers.Function.bind(this.mouseMove, this));
+ this.getMap().observeEvent('mouseout', OpenLayers.Function.bind(this.mouseOut, this));
+ mouseOut: function(e) {
+ //console.log('maptip mouseOut');
+ if (this.nTimer) {
+ window.clearTimeout(this.nTimer);
+ if (!this.nHideTimer) {
+ /*console.log('mouseOut: set hide timer');*/
+ this.nHideTimer = window.setTimeout(this.hideMaptip.bind(this), 250);
+ mouseMove: function(e) {
+ //console.log('map tip mouseMove');
+ var map = this.getMap();
+ var Map = map.aMaps[0];
+ if (this.bOverTip) {
+ return;
+ var p = this.getMap().getEventPosition(e);
+ this.oCurrentPosition = p;
+ this.oMapTipPosition = {x:e.xy.x, y:e.xy.y};
+ if (this.oCurrentPosition) {
+ this.nTimer = null;
+ //Bind to the appropriate function for the platform
+ var showMaptip = this.showMaptip.bind(this)
+ this.nTimer = window.setTimeout(showMaptip, this.delay);
+ //Event.stop(e);
+ showMaptipMG: function(r) {
+ //Gets the maptip data on MapGuide
+ console.log('showMaptip');
+ if (map == null) {
+ return;
+ var oBroker = Fusion.oBroker;
+ var x = this.oCurrentPosition.x;
+ var y = this.oCurrentPosition.y;
+ var min = map.pixToGeo(x-this.nTolerance, y-this.nTolerance);
+ var max = map.pixToGeo(x+this.nTolerance, y+this.nTolerance);
+ //this can fail if no map is loaded
+ if (!min) {
+ return;
+ var sGeometry = 'POLYGON(('+ min.x + ' ' + min.y + ', ' + min.x + ' ' + max.y + ', ' + max.x + ' ' + max.y + ', ' + max.x + ' ' + min.y + ', ' + min.x + ' ' + min.y + '))';
+ var maxFeatures = 1;
+ var persist = 0;
+ var selection = 'INTERSECTS';
+ // only select visible layers with maptips defined (1+4)
+ var layerAttributeFilter = 5;
+ var maps = this.getMap().getAllMaps();
+ //TODO: possibly make the layer names configurable?
+ var layerNames = this.aLayers.toString();
+ var r = new Fusion.Lib.MGRequest.MGQueryMapFeatures(maps[0].getSessionID(),
+ maps[0]._sMapname,
+ sGeometry,
+ maxFeatures, persist, selection, layerNames,
+ layerAttributeFilter);
+ oBroker.dispatchRequest(r, this.parseMGXML.bind(this));
+ parseMGXML: function(r) {
+ //Parses the XML returned by MG and passes the text & link values to the
+ //mtDisplay function
+ if (r) {
+ var d = new DomNode(r);
+ var t = d.getNodeText('Tooltip');
+ var h = d.getNodeText('Hyperlink');
+ var mtDisplayFunc = this.mtDisplay.bind(this);
+ mtDisplayFunc(t,h);
+ showMaptip: function(r) {
+ var pos = this.getMap().pixToGeo(this.oCurrentPosition.x, this.oCurrentPosition.y);
+ //console.log(pos);
+ var options = {};
+ var dfGeoTolerance = this.getMap().pixToGeoMeasure(this.nTolerance);
+ var minx = pos.x-dfGeoTolerance;
+ var miny = pos.y-dfGeoTolerance;
+ var maxx = pos.x+dfGeoTolerance;
+ var maxy = pos.y+dfGeoTolerance;
+ options.geometry = 'POLYGON(('+ minx + ' ' + miny + ', ' + minx + ' ' + maxy + ', ' + maxx + ' ' + maxy + ', ' + maxx + ' ' + miny + ', ' + minx + ' ' + miny + '))';
+ options.selectionType = "INTERSECTS";
+ if (this.bActiveOnly) {
+ var layer = this.getMap().getActiveLayer();
+ if (layer) {
+ options.layers = layer.layerName;
+ } else {
+ return;
+ var Map = this.getMap().aMaps[0];
+ var bPersistant = options.persistent || true;
+ var zoomTo = options.zoomTo ? true : false;
+ var loadmapScript = '/layers/'+Map.arch + '/php/maptip.php';
+ var params = {
+ 'mapname': Map._sMapname,
+ 'session': Map.getSessionID(),
+ 'spatialfilter': options.geometry || '',
+ 'maxfeatures': options.maxFeatures || 0, //zero means select all features
+ 'variant': 'intersects',
+ 'layer': this.aLayers[0] || '',
+ 'textfield': this.textField || '',
+ 'customURL': this.customURL || ''
+ var ajaxOptions = {
+ onSuccess: function(response){
+ eval("rjson=" + response.responseText);
+ mtDisplayFunc(rjson.mapTipText,rjson.mapTipLink);
+ parameters: params};
+ Fusion.ajaxRequest(loadmapScript, ajaxOptions);
+ mtDisplay: function(t,h) {
+ //console.log("t:" + t);
+ //console.log("h:" + h);
+ if (t !="") {
+ this.domObj.innerHTML = ' ';
+ var contentDiv = document.createElement('div');
+ contentDiv.className = 'maptipContent';
+ this.domObj.appendChild(contentDiv);
+ var empty = true;
+ this.bIsVisible = true;
+ if (t != '') {
+ t = t.replace(/\\n/g, "<br>");
+ if (h != '') {
+ var linkDiv = document.createElement('div');
+ var a = document.createElement('a');
+ a.innerHTML = t;
+ a.href = 'javascript:void(0)';
+ a.url = h;
+ a.onclick = this.openLink.bindAsEventListener(a);
+ linkDiv.appendChild(a);
+ contentDiv.appendChild(linkDiv);
+ empty = false;
+ } else {
+ contentDiv.innerHTML = t;
+ empty = false;
+ if (!empty) {
+ this.domObj.style.visibility = 'hidden';
+ this.domObj.style.display = 'block';
+ var size = Element.getCoordinates(this.domObj);
+ // 5 pixels offset added to clear the div from the mouse
+ var mapOffsetX = this.getMap()._oDomObj.offsets[0];
+ var mapOffsetY= this.getMap()._oDomObj.offsets[1];
+ this.domObj.style.top = (this.oCurrentPosition.y ) + 'px';
+ this.domObj.style.left = (this.oCurrentPosition.x )+ 'px';
+ if (!window.opera) {
+ contentDiv.appendChild(this.iframe);
+ var size = Element.getContentBoxSize(this.domObj);
+ this.iframe.style.width = size.width + "px";
+ this.iframe.style.height = size.height + "px";
+ this.domObj.style.visibility = 'visible';
+ //console.log("maptip visible");
+ } else {
+ this.hideMaptip();
+ } else {
+ this.bIsVisible = false;
+ hideMaptip: function() {
+ //console.log('hideMaptip');
+ this.hideTimer = window.setTimeout(this._hide.bind(this),10);
+ _hide: function() {
+ //console.log('maptip _hide');
+ this.hideTimer = null;
+ //this.oMapTipPosition = null;
+ mouseOverTip: function() {
+ //console.log('mouseOverTip');
+ window.clearTimeout(this.nHideTimer);
+ this.nHideTimer = null;
+ this.bOverTip = true;
+ mouseOutTip: function() {
+ //console.log('mouseOutTip');
+ this.bOverTip = false;
+ openLink : function(evt) {
+ var url = this.url;
+ var taskPaneTarget = Fusion.getWidgetById(this.sTarget);
+ if ( taskPaneTarget ) {
+ taskPaneTarget.setContent(url);
+ } else {
+ var pageElement = $(this.sTarget);
+ if ( pageElement ) {
+ pageElement.src = url;
+ } else {
+ window.open(url, this.sTarget, this.sWinFeatures);
+ OpenLayers.Event.stop(evt, true);
+ return false;
More information about the fusion-commits
