[fusion-commits] r1733 - in trunk: layers layers/MapGuide lib
	widgets widgets/LinkToView
    svn_fusion at osgeo.org
    Thu Jan  8 13:35:06 EST 2009
Author: madair
Date: 2009-01-08 13:35:06 -0500 (Thu, 08 Jan 2009)
New Revision: 1733
Added:
   trunk/widgets/LinkToView/
   trunk/widgets/LinkToView/LinkToView.css
   trunk/layers/Layers.js
   trunk/layers/MapGuide/MapGuide.js
   trunk/lib/Map.js
   trunk/lib/fusion.js
   trunk/widgets/LinkToView.js
re #34: added getMapLink functions to Map and Mapguide to return permalink parameters; small bug in Fusion.getQueryParams when param name is a function - applied to trunk
Modified: trunk/layers/Layers.js
--- trunk/layers/Layers.js	2009-01-08 18:34:28 UTC (rev 1732)
+++ trunk/layers/Layers.js	2009-01-08 18:35:06 UTC (rev 1733)
@@ -314,6 +314,7 @@
         this.displayInLegend = o.displayInLegend;
         this.expandInLegend = o.expandInLegend;
         this.visible = o.visible;
+        this.initiallyVisible = o.visible;
         this.actuallyVisible = o.actuallyVisible;
         this.registerEventID(Fusion.Event.GROUP_PROPERTY_CHANGED);
@@ -443,6 +444,7 @@
         this.statusDefault = o.statusdefault;
         this.editable = o.editable;
         this.selectable = o.selectable;
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js	2009-01-08 18:34:28 UTC (rev 1732)
+++ trunk/layers/MapGuide/MapGuide.js	2009-01-08 18:35:06 UTC (rev 1733)
@@ -133,11 +133,25 @@
     mapSessionCreated: function() {
         if (this.sMapResourceId != '') {
-            this.loadMap(this.sMapResourceId);
+          var options = {};
+          if (this.bIsMapWidgetLayer) {
+            var showlayers = Fusion.getQueryParam('showlayers');
+            var hidelayers = Fusion.getQueryParam('hidelayers');
+            var showgroups = Fusion.getQueryParam('showgroups');
+            var hidegroups = Fusion.getQueryParam('hidegroups');
+            var options = {
+              showlayers: showlayers == '' ? [] : showlayers.split(','),
+              hidelayers: hidelayers == '' ? [] : hidelayers.split(','),
+              showgroups: showgroups == '' ? [] : showgroups.split(','),
+              hidegroups: hidegroups == '' ? [] : hidegroups.split(',')
+          this.loadMap(this.sMapResourceId, options);
         window.setInterval(OpenLayers.Function.bind(this.pingServer, this), this.keepAliveInterval * 1000);
     sessionReady: function() {
         return (typeof this.session[0] == 'string');
@@ -978,6 +992,43 @@
         Fusion.ajaxRequest(s, params);
+    getLinkParams: function() {
+      var queryParams = {};
+      queryParams.theme = this.sMapResourceId;
+      //determine which layers have been toggled
+      var showLayers = [];
+      var hideLayers = [];
+      for (var i=0; i<this.aLayers.length; ++i) {
+        var layer = this.aLayers[i];
+        if (layer.visible && !layer.initiallyVisible) {  //layer was turned on
+          showLayers.push(layer.layerName);
+        if (!layer.visible && layer.initiallyVisible) {  //layer was turned off
+          hideLayers.push(layer.layerName);
+      queryParams.showlayers = showLayers.join(',');
+      queryParams.hidelayers = hideLayers.join(',');
+      //determine which groups have been toggled
+      var showGroups = [];
+      var hideGroups = [];
+      for (var i=0; i<this.layerRoot.groups.length; ++i) {
+        var group = this.layerRoot.groups[i];
+        if (group.visible && !group.initiallyVisible) {  //layer was turned on
+          showGroups.push(group.groupName);
+        if (!group.visible && group.initiallyVisible) {  //layer was turned off
+          hideGroups.push(group.groupName);
+      queryParams.showgroups = showGroups.join(',');
+      queryParams.hidegroups = hideGroups.join(',');
+      return queryParams;
     getLegendImageURL: function(fScale, layer, style) {
       var url = Fusion.getConfigurationItem('mapguide', 'mapAgentUrl');
       url += "?OPERATION=GETLEGENDIMAGE&SESSION=" + layer.oMap.getSessionID();
Modified: trunk/lib/Map.js
--- trunk/lib/Map.js	2009-01-08 18:34:28 UTC (rev 1732)
+++ trunk/lib/Map.js	2009-01-08 18:35:06 UTC (rev 1733)
@@ -393,6 +393,7 @@
      * dispatch query requests to maps
     query: function(options) {
+        this.lastQueryOptions = options;
         for (var i=0; i<this.aMaps.length; i++ ) {
             if (this.aMaps[i].query(options)) {
@@ -449,6 +450,7 @@
      clearSelection: function() {
          this.oSelection = null;
+         this.lastQueryOptions = null;
              this.aMaps[i].clearSelection();
@@ -977,6 +979,36 @@
          return (this.oMapOL.getExtent() != null);
+          extent: this.getCurrentExtents().toBBOX()
+        if (this.lastQueryOptions) {
+          if (this.lastQueryOptions.filter) {
+            queryParams.filter = this.lastQueryOptions.filter;
+          if (this.lastQueryOptions.geometry) {
+            queryParams.spatialfilter = this.lastQueryOptions.geometry;
+          if (this.lastQueryOptions.queryHiddenLayers) {
+            queryParams.queryHiddenLayers = this.lastQueryOptions.queryHiddenLayers;
+          if (this.lastQueryOptions.maxFeatures) {
+            queryParams.maxfeatures = this.lastQueryOptions.maxFeatures;
+          if (this.lastQueryOptions.layers) {
+            queryParams.selectlayer = this.lastQueryOptions.layers;
+          if (this.lastQueryOptions.selectionType) {
+            queryParams.variant = this.lastQueryOptions.selectionType;
+        for (var i=0; i< this.aMaps.length; ++i) {
+          queryParams = OpenLayers.Util.extend(queryParams, this.aMaps[i].getLinkParams());
+        return OpenLayers.Util.getParameterString(queryParams);
      supressContextMenu: function( bSupress ) {
          this.bSupressContextMenu = bSupress;
Modified: trunk/lib/fusion.js
--- trunk/lib/fusion.js	2009-01-08 18:34:28 UTC (rev 1732)
+++ trunk/lib/fusion.js	2009-01-08 18:35:06 UTC (rev 1733)
@@ -1010,7 +1010,7 @@
                 this.parseQueryString();
             p = p.toLowerCase();
-            if (this.queryParams[p]) {
+            if (this.queryParams[p] && typeof this.queryParams[p] == 'string') {
                 return this.queryParams[p];
             } else {
                 return '';
Added: trunk/widgets/LinkToView/LinkToView.css
--- trunk/widgets/LinkToView/LinkToView.css	                        (rev 0)
+++ trunk/widgets/LinkToView/LinkToView.css	2009-01-08 18:35:06 UTC (rev 1733)
@@ -0,0 +1,7 @@
+a.anchorLinkToView {
+  font-family:  Arial, Helvetica, sans-serif;
+  font-size: 11px;
+  line-height: 14px;
+  padding: 4px;
Modified: trunk/widgets/LinkToView.js
--- trunk/widgets/LinkToView.js	2009-01-08 18:34:28 UTC (rev 1732)
+++ trunk/widgets/LinkToView.js	2009-01-08 18:35:06 UTC (rev 1733)
@@ -31,41 +31,63 @@
 Fusion.Widget.LinkToView = OpenLayers.Class(Fusion.Widget,  {
     initializeWidget: function(widgetTag) {
         var json = widgetTag.extension;
         this.baseUrl = window.location.protocol + '//' + window.location.host + window.location.pathname + '?';
         //remove any existing extent param
-        var queryParams = Fusion.parseQueryString();
         var join = '';
-        for (var param in queryParams) {
-          if (typeof queryParams[param] == 'function') {
-              continue;
+        for (var param in Fusion.queryParams) {
+          if (typeof Fusion.queryParams[param] == 'string') {
+            if (param == 'extent' ||
+                param == 'filter' ||
+                param == 'spatialfilter' ||
+                param == 'variant' ||
+                param == 'theme' ||
+                param == 'selectlayer' ||
+                param == 'showlayers' ||
+                param == 'hidelayers' ||
+                param == 'showgroups' ||
+                param == 'hidegroups' ) {
+                continue;
+            this.baseUrl += join + param + '=' + Fusion.queryParams[param];
+            join = '&';
-          if (param == 'extent') {
-              continue;
-          this.baseUrl += join + param + '=' + queryParams[param];
-          join = '&';
+        this.anchorLabel = json.Label ? json.Label[0] : (this.domObj ? this.domObj.innerHTML : 'Link to View');
-        this.anchorLabel = json.Label ? json.Label[0] : (this.domObj.innerHTML ? this.domObj.innerHTML : 'Link to View');
+        Fusion.addWidgetStyleSheet(widgetTag.location + 'LinkToView/LinkToView.css');
         this.anchor = document.createElement('a');
         this.anchor.className = 'anchorLinkToView';
         this.anchor.href = this.baseUrl;
         this.anchor.innerHTML = this.anchorLabel;
         this.anchor.title = json.Tooltip ? json.Tooltip[0] : 'Right-click to copy or bookmark link to current view';
-        this.domObj.innerHTML = '';
-        this.domObj.appendChild(this.anchor);
-        this.getMap().registerForEvent(Fusion.Event.MAP_EXTENTS_CHANGED, OpenLayers.Function.bind(this.updateLink, this));
+        this.getMap().oMapOL.events.register("addlayer", this, this.setListener);
         this.enable();
-    updateLink : function() {
-        var sBbox = this.getMap().getCurrentExtents().toBBOX();
+    setUiObject: function(uiObj) {
+        Fusion.Widget.prototype.setUiObject.apply(this, [uiObj]);
+        if (this.uiObj.domObj) {
+            this.uiObj.domObj.appendChild(this.anchor);
+        } else {
+            this.uiObj.appendChild(this.anchor);
+    setListener: function(evt) {
+        var layer = evt.layer;
+        //register on the OL loadend event to update the link because this event
+        //is fired whenever the layers are redrawn
+        layer.events.register("loadend", this, this.updateLink);
+    updateLink: function() {
         var join = (this.baseUrl.indexOf('?')==this.baseUrl.length-1)?'':'&';
-        this.anchor.href = this.baseUrl + join +'extent=' + sBbox;
+        var queryStr = this.getMap().getLinkParams();
+        this.anchor.href = this.baseUrl + join + queryStr;
More information about the fusion-commits
