[fusion-commits] r1734 - trunk/lib
svn_fusion at osgeo.org
Wed Jan 14 10:23:02 EST 2009
Author: madair
Date: 2009-01-14 10:23:01 -0500 (Wed, 14 Jan 2009)
New Revision: 1734
trunk/lib/ApplicationDefinition.js
re #34: support for URL mapid param to override mapid specified in AppDef
Modified: trunk/lib/ApplicationDefinition.js
--- trunk/lib/ApplicationDefinition.js 2009-01-08 18:35:06 UTC (rev 1733)
+++ trunk/lib/ApplicationDefinition.js 2009-01-14 15:23:01 UTC (rev 1734)
@@ -89,7 +89,7 @@
this.applicationDefinition = Fusion.getApplicationDefinitionURL();
this.widgetSets = [];
- this.mapGroups = [];
+ this.mapGroups = {};
this.searchDefinitions = [];
this.searchCategories = [];
this.parse();
@@ -184,7 +184,7 @@
if (mapSet.MapGroup instanceof Array) {
for (var i=0; i<mapSet.MapGroup.length; i++) {
var mapGroup = new Fusion.Lib.ApplicationDefinition.MapGroup(mapSet.MapGroup[i]);
- this.mapGroups.push(mapGroup);
+ this.mapGroups[mapGroup.mapId] = mapGroup;
} else {
@@ -320,14 +320,7 @@
* Returns: {Object} a MapGroup appdef or null if not found.
getMapGroup : function(mapGroupId) {
- var mapGroup = null;
- for (var i=0; i<this.mapGroups.length; ++i) {
- if (this.mapGroups[i].mapId == mapGroupId) {
- mapGroup = this.mapGroups[i];
- break;
- return mapGroup;
+ return this.mapGroups[mapGroupId];
@@ -510,7 +503,7 @@
this.layerOptions[key] = false;
if (key == 'maxExtent' || key == 'minExtent') {
- this.layerOptions[key] = OpenLayers.Bounds.fromString(this.layerOptions[key])
+ this.layerOptions[key] = OpenLayers.Bounds.fromString(this.layerOptions[key]);
@@ -569,12 +562,6 @@
- //allow over-ride of mapId via URL parameter
- var paramMapId = Fusion.getQueryParam('mapid');
- if (paramMapId.length>0) {
- this.mapId = paramMapId;
/* process widgets */
if (jsonNode.Widget) {
for (var i=0; i<jsonNode.Widget.length; i++) {
@@ -631,17 +618,23 @@
create: function(appDef) {
- //find the map group for the map requested
+ //allow over-ride of mapId via URL parameter
- if (this.mapId) {
- for (var i=0; i<appDef.mapGroups.length; ++i) {
- if (this.mapId == appDef.mapGroups[i].mapId) {
- mapGroup = appDef.mapGroups[i];
- break;
+ var paramMapId = Fusion.getQueryParam('mapid');
+ if (paramMapId.length>0) {
+ mapGroup = appDef.getMapGroup(paramMapId);
+ if (mapGroup) {
+ this.mapId = paramMapId;
+ } else {
+ Fusion.reportError(new Fusion.Error(Fusion.Error.WARNING,
+ "can't find MapGroup: " + paramMapId + ' - reverting to default map'));
+ if (!mapGroup) {
+ mapGroup = appDef.getMapGroup(this.mapId);
//create the Map widget for this WidgetSet
this.mapWidget = new Fusion.Widget.Map(this.mapWidgetTag,mapGroup,this);
this.mapWidget.setMenu();
@@ -906,7 +899,6 @@
break;
case 'Separator':
break;
- break;
More information about the fusion-commits
