[fusion-commits] r1743 - in trunk/layers/MapGuide: . php
svn_fusion at osgeo.org svn_fusion at osgeo.org
Fri Jan 23 15:33:54 EST 2009
Author: chrisclaydon
Date: 2009-01-23 15:33:53 -0500 (Fri, 23 Jan 2009)
New Revision: 1743
Added:
   trunk/layers/MapGuide/php/GetSelectionProperties.php
   trunk/layers/MapGuide/php/SaveSelection.php
Removed:
   trunk/layers/MapGuide/php/SetSelection.php
   trunk/layers/MapGuide/MapGuide.js
Fix #199 - Add selection enhancements previously added to mg21 branch to trunk code stream.
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js	2009-01-22 21:01:39 UTC (rev 1742)
+++ trunk/layers/MapGuide/MapGuide.js	2009-01-23 20:33:53 UTC (rev 1743)
@@ -147,13 +147,12 @@
               showgroups: showgroups == '' ? [] : showgroups.split(','),
               hidegroups: hidegroups == '' ? [] : hidegroups.split(',')
           this.loadMap(this.sMapResourceId, options);
         window.setInterval(OpenLayers.Function.bind(this.pingServer, this), this.keepAliveInterval * 1000);
     sessionReady: function() {
         return (typeof this.session[0] == 'string');
@@ -643,14 +642,13 @@
-     * advertise a new selection is available and redraw the map
+     * advertise a new selection is available
     newSelection: function() {
         if (this.oSelection) {
             this.oSelection = null;
         this.bSelectionOn = true;
-        this.drawSelection();
         this.triggerEvent(Fusion.Event.MAP_SELECTION_ON);
@@ -691,22 +689,62 @@
       return layers;
+     * Updates the current map selection with the provided XML selection string.
+     * Optionally zooms to the new selection on the map, if zoomTo is set to true.
     setSelection: function (selText, zoomTo) {
+        //TODO Update this.previousSelection when the selection is set using
+        //this API to allow the selection to be extended with a shift-click.
+        if(selText != "" && selText != null) {
+            this.updateSelection(selText, zoomTo, false);
+        else {
+            this.clearSelection();
+    updateSelection: function (selText, zoomTo, extendSelection) {
+        this.updateMapSelection(selText, zoomTo);
+        this.getSelectedFeatureProperties(selText);
+    getSelectedFeatureProperties: function (selText) {
       this.mapWidget._addWorker();
       var sl = Fusion.getScriptLanguage();
-      var setSelectionScript = 'layers/' + this.arch + '/' + sl  + '/SetSelection.' + sl;
+      var getPropertiesScript = 'layers/' + this.arch + '/' + sl  + '/GetSelectionProperties.' + sl;
       var params = {
           'mapname': this.getMapName(),
           'session': this.getSessionID(),
           'selection': selText,
           'seq': Math.random()
-      var options = {onSuccess: OpenLayers.Function.bind(this.processQueryResults, this, zoomTo),
-                     parameters:params, asynchronous:false};
-      Fusion.ajaxRequest(setSelectionScript, options);
+      var options = {onSuccess: OpenLayers.Function.bind(this.processSelectedFeatureProperties, this),
+                     parameters:params};
+      Fusion.ajaxRequest(getPropertiesScript, options);
+    updateMapSelection: function (selText, zoomTo) {
+      this.mapWidget._addWorker();
+      var sl = Fusion.getScriptLanguage();
+      var updateSelectionScript = 'layers/' + this.arch + '/' + sl  + '/SaveSelection.' + sl;
+      var params = {
+          'mapname': this.getMapName(),
+          'session': this.getSessionID(),
+          'selection': selText,
+          'seq': Math.random(),
+          'getextents' : zoomTo ? 'true' : 'false'
+      var options = {onSuccess: OpenLayers.Function.bind(this.renderSelection, this, zoomTo),
+      Fusion.ajaxRequest(updateSelectionScript, options);
      * asynchronously load the current selection.  When the current
      * selection changes, the selection is not loaded because it
@@ -782,6 +820,10 @@
           Fusion.ajaxRequest(s, options);
+      if (this.previousSelection != null)
+          this.previousSelection.clear();
@@ -796,15 +838,35 @@
-       Call back function when slect functions are called (eg queryRect)
+       Call back function when select functions are called (eg queryRect)
+       to handle feature attributes
-    processQueryResults: function(zoomTo, r) {
+    processSelectedFeatureProperties: function(r) {
         this.mapWidget._removeWorker();
         if (r.responseText) {   //TODO: make the equivalent change to MapServer.js
             var oNode;
             eval('oNode='+r.responseText);
             if (oNode.hasSelection) {
+              this.newSelection();
+            } else {
+              return;
+       to render the selection
+    renderSelection: function(zoomTo, r) {
+        this.mapWidget._removeWorker();
+        if (r.responseText) {   //TODO: make the equivalent change to MapServer.js
+            var oNode;
+            eval('oNode='+r.responseText);
+            if (oNode.hasSelection) {
               if (this.selectionAsOverlay) {
                 if (!this.queryLayer) {
                   this.queryLayer = this.createOLLayer("query layer", false, true, 5);
@@ -831,7 +893,7 @@
                 var extents = new OpenLayers.Bounds(ext.minx, ext.miny, ext.maxx, ext.maxy);
                 this.mapWidget.setExtents(extents);
-              this.newSelection();
+              this.drawSelection();
             } else {
               return;
@@ -850,34 +912,23 @@
           this.aLayers[j].selectedFeatureCount = 0;
-        var bPersistant = options.persistent || true;
-        var zoomTo = options.zoomTo ?  true : false;
-        var sl = Fusion.getScriptLanguage();
-        var loadmapScript = 'layers/' + this.arch + '/' + sl  + '/Query.' + sl;
-        var params = {
-            'mapname': this._sMapname,
-            'session': this.getSessionID(),
-            'spatialfilter': options.geometry || '',
-            'computed': options.computed || '',
-            'queryHiddenLayers': options.queryHiddenLayers || 'false',
-            'maxfeatures': options.maxFeatures || 0, //zero means select all features
-            'layers': options.layers || '',
-            'variant': options.selectionType || this.selectionType
-        if (options.filter) {
-            params.filter= options.filter;
+        var persist = 1;
+        var layerAttributeFilter = 3;
+        var maxFeatures = options.maxFeatures;
+        if(maxFeatures == null || maxFeatures == 0)
+            maxFeatures = -1;
-        if (options.extendSelection) {
-            params.extendselection = true;
-        if (options.computedProperties) {
-            params.computed = true;
-        var ajaxOptions = {
-            onSuccess: OpenLayers.Function.bind(this.processQueryResults, this, zoomTo),
-            parameters: params};
-        Fusion.ajaxRequest(loadmapScript, ajaxOptions);
+        var r = new Fusion.Lib.MGRequest.MGQueryMapFeatures(this.getSessionID(),
+        this._sMapname,
+        options.geometry,
+        maxFeatures,
+        persist,
+        options.selectionType || this.selectionType,
+        options.layers,
+        layerAttributeFilter);
+        var callback = (options.extendSelection == true) ? OpenLayers.Function.bind(this.processAndMergeFeatureInfo, this) : OpenLayers.Function.bind(this.processFeatureInfo, this);
+        Fusion.oBroker.dispatchRequest(r, OpenLayers.Function.bind(Fusion.xml2json, this, callback));
     showLayer: function( layer, noDraw ) {
@@ -1044,7 +1095,250 @@
         url += "&TS=" + (new Date()).getTime();
       return url;
+    processAndMergeFeatureInfo: function (r) {
+        this.processSelectedFeatureInfo(r, true);
+    processFeatureInfo: function (r) {
+        this.processSelectedFeatureInfo(r, false);
+    processSelectedFeatureInfo: function (r, mergeSelection) {
+        eval('o='+r.responseText);
+        var newSelection = new Fusion.SimpleSelectionObject(o);
+        if(mergeSelection == true)
+            newSelection.merge(this.previousSelection);
+        this.previousSelection = newSelection;
+        var selText = newSelection.getSelectionXml();
+        this.setSelection(selText, false);
+Fusion.SimpleSelectionObject = OpenLayers.Class({
+    aLayers : null,
+    nLayers : 0,
+    initialize: function(featureInfoResponse)
+        this.aLayers = [];
+        this.nLayers = 0;
+        try
+            var layers = featureInfoResponse.FeatureInformation.FeatureSet[0].Layer;
+            if (layers != null)
+                for(var i = 0; i < layers.length; i++)
+                    var layerId = o['FeatureInformation']['FeatureSet'][0]['Layer'][i]['@id'][0];
+                    var classElt = o['FeatureInformation']['FeatureSet'][0]['Layer'][i]['Class'][0];
+                    var className = o['FeatureInformation']['FeatureSet'][0]['Layer'][i]['Class'][0]['@id'][0];
+                    var layer = new Fusion.SimpleSelectionObject.Layer(layerId, className);
+                    this.addLayer(layer);
+                    var features = classElt.ID;
+                    for(var j=0; j < features.length; j++)
+                        layer.addFeature(features[j]);
+        catch(e) {}
+    addLayer: function(layer)
+        this.aLayers[this.nLayers] = layer;
+        this.nLayers++;
+    getNumLayers : function()
+        return this.nLayers;
+    getLayerByName : function(name)
+        var oLayer = null;
+        for (var i=0; i<this.nLayers; i++)
+            if (this.aLayers[i].getName() == name)
+                oLayer = this.aLayers[i];
+                break;
+        return oLayer;
+    getLayer : function(iIndice)
+        if (iIndice >=0 && iIndice < this.nLayers)
+            return this.aLayers[iIndice];
+        else
+            return null;
+    getSelectionXml : function()
+        var xmlSelection = "";
+        if(this.nLayers > 0)
+            xmlSelection = "<?xml version=\"1.0\" encoding=\"UTF-8\"?>\n<FeatureSet>\n";
+            for(var i = 0; i < this.nLayers; i++)
+                var layer = this.aLayers[i];
+                xmlSelection += "<Layer id=\"" + layer.getName() + "\">\n";
+                xmlSelection += "<Class id=\"" + layer.getClassName() + "\">\n";
+                for(var j = 0; j < layer.getNumFeatures(); j++)
+                    var featId = layer.featIds[j];
+                    xmlSelection += "<ID>" +  featId + "</ID>\n";
+                xmlSelection += "</Class>\n</Layer>\n";
+            xmlSelection += "</FeatureSet>\n";
+        return xmlSelection;
+    merge : function(previousSelection)
+        if (previousSelection != null && previousSelection.nLayers > 0)
+            for (var prevSelIndex = 0; prevSelIndex < previousSelection.nLayers; prevSelIndex++)
+                var prevSelLayer = previousSelection.aLayers[prevSelIndex];
+                // find the previously selected layer name in the current selection
+                var currentLayer = this.getLayerByName(prevSelLayer.getName());
+                if (currentLayer != null)
+                    // add the previously selected features for this layer
+                    for (var j = 0; j < prevSelLayer.getNumFeatures(); j++)
+                        var prevSelFeatureIndexes = currentLayer.featIds.find(prevSelLayer.featIds[j]);
+                        if (prevSelFeatureIndexes == null)
+                            currentLayer.addFeature(prevSelLayer.featIds[j]);
+                        else
+                            // the feature was previously selected, so toggle it off when selected again
+                            currentLayer.removeFeatures(prevSelFeatureIndexes);
+                    if (currentLayer.featIds.length == 0)
+                        this.clear();
+                else
+                    // the current selection does not include this previously selected layer
+                    // need to add this previously selected layer and its features
+                    var missingLayer = new Fusion.SimpleSelectionObject.Layer(prevSelLayer.getName(), prevSelLayer.getClassName());
+                    for (var k = 0; k < prevSelLayer.getNumFeatures(); k++)
+                        missingLayer.addFeature(prevSelLayer.featIds[k]);
+                    this.addLayer(missingLayer);
+    clear: function()
+        this.nLayers = 0;
+Fusion.SimpleSelectionObject.Layer = OpenLayers.Class({
+    name: "",
+    className: "",
+    featIds: null,
+    nFeatures: 0,
+    initialize: function(layerName, className)
+        this.name =  layerName;
+        this.className = className;
+        this.nFeatures = 0;
+        this.featIds =  [];
+    addFeature : function (featId)
+        this.featIds[this.nFeatures] = featId;
+        this.nFeatures++;
+    getName : function()
+        return this.name;
+    getClassName : function()
+        return this.className;
+    getNumFeatures : function()
+        return this.nFeatures;
+    removeFeatures : function (featureIndexes)
+        var numIndexes = featureIndexes.length;
+        for (var featIndex = 0; featIndex < numIndexes; featIndex++)
+            this.featIds.remove(featureIndexes[featIndex]);
+            this.nFeatures--;
+Array.prototype.find = function(searchStr) {
+  var returnArray = null;
+  for (i=0; i<this.length; i++) {
+    if (typeof(searchStr) == 'function') {
+      if (searchStr.test(this[i])) {
+        if (!returnArray) { returnArray = [] }
+        returnArray.push(i);
+    } else {
+      if (this[i]===searchStr) {
+  return returnArray;
+Array.prototype.remove = function(indexToRemove) {
+    this.splice(indexToRemove, 1);
Added: trunk/layers/MapGuide/php/GetSelectionProperties.php
--- trunk/layers/MapGuide/php/GetSelectionProperties.php	                        (rev 0)
+++ trunk/layers/MapGuide/php/GetSelectionProperties.php	2009-01-23 20:33:53 UTC (rev 1743)
@@ -0,0 +1,208 @@
+<?php
+ * SetSelection
+ * $Id: SetSelection.php 1664 2008-11-12 21:41:00Z madair $
+ * Copyright (c) 2007, DM Solutions Group Inc.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+include('Common.php');
+include('../../../common/php/Utilities.php');
+include('Utilities.php');
+    $selText = "";
+    GetRequestParameters();
+    try
+        //load the map runtime state
+        $map = new MgMap();
+        $map->Open($resourceService, $mapName);
+        // Create the selection set
+        $selection = new MgSelection($map);
+        if($selText != "") {
+            $selection->FromXml($selText);
+        //now return a data struture which is the same as Query.php
+        $featureService = $siteConnection->CreateService(MgServiceType::FeatureService);
+        /* Get the map SRS - we use this to convert distances */
+        $srsFactory = new MgCoordinateSystemFactory();
+        //safely get an SRS ... (in Utilities)
+        $srsDefMap = GetMapSRS($map);
+        $srsMap = $srsFactory->Create($srsDefMap);
+        /*holds selection array*/
+        $properties = NULL;
+        $properties->layers = array();
+        //process
+        header('Content-type: text/x-json');
+        header('X-JSON: true');
+        $layers = $selection->GetLayers();
+        $nLayers = $layers->GetCount();
+        echo "/* nLayers:".$nLayers."*/";
+        for ($i=0; $i<$nLayers; $i++) {
+            $oLayer = $layers->GetItem($i);
+            $featureResId = new MgResourceIdentifier($oLayer->GetFeatureSourceId());
+            /* the class that is used for this layer will be used to select  features */
+            $class = $oLayer->GetFeatureClassName();
+            /* select the features */
+            $queryOptions = new MgFeatureQueryOptions();
+            //TODO : seems that property mapping breaks the selection ????
+            //could it be that $selection->AddFeatures($layerObj, $featureReader, 0) is
+            //the one causing a problem when the properies are limited ?
+            $mappings = $_SESSION['property_mappings'][$oLayer->GetObjectId()];
+            if (0 && count($mappings) > 0) {
+                foreach($mappings as $name => $value) {
+                    $queryOptions->AddFeatureProperty($name);
+                    //echo "$name $value <br>\n";
+                $geomName = $oLayer->GetFeatureGeometryName();
+                $queryOptions->AddFeatureProperty($geomName);
+            $filter = $selection->GenerateFilter($oLayer, $class);
+            $queryOptions->SetFilter($filter);
+            $featureReader = $featureService->SelectFeatures($featureResId, $class, $queryOptions);
+            //$featureReader = $selection->GetSelectedFeatures($oLayer, $class, true );//this doesn't seem to work but would replace much of the above code
+            $layerName = $oLayer->GetName();
+            array_push($properties->layers, $layerName);
+	    // TODO: Check if computed properties are needed?
+            $bComputedProperties = false;
+            $bNeedsTransform = false;
+            $srsLayer = NULL;
+            if ($bComputedProperties)
+		$spatialContext = $featureService->GetSpatialContexts($featureResId, true);
+		$srsLayerWkt = false;
+		if($spatialContext != null && $spatialContext->ReadNext() != null) {
+		    $srsLayerWkt = $spatialContext->GetCoordinateSystemWkt();
+		    /* skip this layer if the srs is empty */
+		if ($srsLayerWkt == null) {
+		    $srsLayerWkt = $srsDefMap;
+		/* create a coordinate system from the layer's SRS wkt */
+		$srsLayer = $srsFactory->Create($srsLayerWkt);
+		// exclude layer if:
+		//  the map is non-arbitrary and the layer is arbitrary or vice-versa
+		//     or
+		//  layer and map are both arbitrary but have different units
+		$bLayerSrsIsArbitrary = ($srsLayer->GetType() == MgCoordinateSystemType::Arbitrary);
+		$bMapSrsIsArbitrary = ($srsMap->GetType() == MgCoordinateSystemType::Arbitrary);
+		if (($bLayerSrsIsArbitrary != $bMapSrsIsArbitrary) ||
+		    ($bLayerSrsIsArbitrary && ($srsLayer->GetUnits() != $srsMap->GetUnits()))) {
+		} else {
+		    $srsTarget = null;
+		    $srsXform = null;
+		    $bNeedsTransform = ($srsLayer->GetUnitScale() != 1.0);
+            $properties = BuildSelectionArray($featureReader, $layerName, $properties,
+                                              $bComputedProperties,
+                                              $srsLayer, $bNeedsTransform, $oLayer);
+            $featureReader->Close();
+        $result = NULL;
+        $result->hasSelection = false;
+        if ($layers && $layers->GetCount() >= 0)
+            $result->hasSelection = true;
+            $oExtents = $selection->GetExtents($featureService);
+            if ($oExtents)
+                $oMin = $oExtents->GetLowerLeftCoordinate();
+                $oMax = $oExtents->GetUpperRightCoordinate();
+                $result->extents = NULL;
+                $result->extents->minx = $oMin->GetX();
+                $result->extents->miny = $oMin->GetY();
+                $result->extents->maxx = $oMax->GetX();
+                $result->extents->maxy = $oMax->GetY();
+                /*keep the full extents of the selection when saving the selection in the session*/
+                $properties->extents = NULL;
+                $properties->extents->minx = $oMin->GetX();
+                $properties->extents->miny = $oMin->GetY();
+                $properties->extents->maxx = $oMax->GetX();
+                $properties->extents->maxy = $oMax->GetY();
+            $result->layers = array();
+            for ($i=0; $i<$layers->GetCount(); $i++) {
+              $layer = $layers->GetItem($i);
+              $layerName = $layer->GetName();
+              array_push($result->layers, $layerName);
+              $layerClassName = $layer->GetFeatureClassName();
+              $result->$layerName->featureCount = $selection->GetSelectedFeaturesCount($layer, $layerClassName);
+            /*save selection in the session*/
+            $_SESSION['selection_array'] = $properties;
+        echo var2json($result);
+    } catch(MgException $e) {
+        echo "/* SetSelection Exception: " . $e->GetDetails()."*/";
+function GetParameters($params)
+    global $selText;
+    $selText = UnescapeMagicQuotes($params['selection']);
+function UnescapeMagicQuotes($str)
+    if(ini_get("magic_quotes_sybase") == "1")
+        return str_replace("''", "'", $str);
+    else if(get_magic_quotes_gpc() == "1")
+        //Unescape double quotes
+        $str = str_replace('\\"', '"', $str);
+        //remove additional backslash
+        return str_replace("\\", "", $str);
+    return $str;
+function GetRequestParameters()
+    if($_SERVER['REQUEST_METHOD'] == "POST")
+        GetParameters($_POST);
+    else
+        GetParameters($_GET);
Property changes on: trunk/layers/MapGuide/php/GetSelectionProperties.php
___________________________________________________________________
   + native
Added: trunk/layers/MapGuide/php/SaveSelection.php
--- trunk/layers/MapGuide/php/SaveSelection.php	                        (rev 0)
+++ trunk/layers/MapGuide/php/SaveSelection.php	2009-01-23 20:33:53 UTC (rev 1743)
@@ -0,0 +1,126 @@
+<?php
+ * SetSelection
+    $selText = "";
+    $getExtents = false;
+    try
+        // Create the selection set and save it
+        $selection->Save($resourceService, $mapName);
+        //process
+        $result = NULL;
+            if($getExtents)
+                if ($oExtents)
+    global $selText;
+    global $getExtents;
+    $getExtents = ($params['getextents'] == "true") ? true : false;
+    return $str;
+    else
Property changes on: trunk/layers/MapGuide/php/SaveSelection.php
   + native
Deleted: trunk/layers/MapGuide/php/SetSelection.php
--- trunk/layers/MapGuide/php/SetSelection.php	2009-01-22 21:01:39 UTC (rev 1742)
+++ trunk/layers/MapGuide/php/SetSelection.php	2009-01-23 20:33:53 UTC (rev 1743)
@@ -1,206 +0,0 @@
-<?php
- * SetSelection
- * $Id$
- * Copyright (c) 2007, DM Solutions Group Inc.
- * Permission is hereby granted, free of charge, to any person obtaining a
- * copy of this software and associated documentation files (the "Software"),
- * to deal in the Software without restriction, including without limitation
- * the rights to use, copy, modify, merge, publish, distribute, sublicense,
- * and/or sell copies of the Software, and to permit persons to whom the
- * Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included
- * in all copies or substantial portions of the Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
- * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
- * DEALINGS IN THE SOFTWARE.
-include('Common.php');
-include('../../../common/php/Utilities.php');
-include('Utilities.php');
-    $selText = "";
-    GetRequestParameters();
-    try
-        //load the map runtime state
-        $map = new MgMap();
-        $map->Open($resourceService, $mapName);
-        // Create the selection set and save it
-        $selection = new MgSelection($map);
-        if($selText != "") {
-            $selection->FromXml($selText);
-        $selection->Save($resourceService, $mapName);
-        //now return a data struture which is the same as Query.php
-        $featureService = $siteConnection->CreateService(MgServiceType::FeatureService);
-        /* Get the map SRS - we use this to convert distances */
-        $srsFactory = new MgCoordinateSystemFactory();
-        //safely get an SRS ... (in Utilities)
-        $srsDefMap = GetMapSRS($map);
-        $srsMap = $srsFactory->Create($srsDefMap);
-        /*holds selection array*/
-        $properties = NULL;
-        $properties->layers = array();
-        //process
-        header('Content-type: text/x-json');
-        header('X-JSON: true');
-        $layers = $selection->GetLayers();
-        $nLayers = $layers->GetCount();
-        echo "/* nLayers:".$nLayers."*/";
-        for ($i=0; $i<$nLayers; $i++) {
-            $oLayer = $layers->GetItem($i);
-            $featureResId = new MgResourceIdentifier($oLayer->GetFeatureSourceId());
-            /* the class that is used for this layer will be used to select  features */
-            $class = $oLayer->GetFeatureClassName();
-            /* select the features */
-            $queryOptions = new MgFeatureQueryOptions();
-            //TODO : seems that property mapping breaks the selection ????
-            //could it be that $selection->AddFeatures($layerObj, $featureReader, 0) is
-            //the one causing a problem when the properies are limited ?
-            $mappings = $_SESSION['property_mappings'][$oLayer->GetObjectId()];
-            if (0 && count($mappings) > 0) {
-                foreach($mappings as $name => $value) {
-                    $queryOptions->AddFeatureProperty($name);
-                    //echo "$name $value <br>\n";
-                $geomName = $oLayer->GetFeatureGeometryName();
-                $queryOptions->AddFeatureProperty($geomName);
-            $filter = $selection->GenerateFilter($oLayer, $class);
-            $queryOptions->SetFilter($filter);
-            $featureReader = $featureService->SelectFeatures($featureResId, $class, $queryOptions);
-            //$featureReader = $selection->GetSelectedFeatures($oLayer, $class, true );//this doesn't seem to work but would replace much of the above code
-            $layerName = $oLayer->GetName();
-            array_push($properties->layers, $layerName);
-            $spatialContext = $featureService->GetSpatialContexts($featureResId, true);
-            $srsLayerWkt = false;
-            if($spatialContext != null && $spatialContext->ReadNext() != null) {
-                $srsLayerWkt = $spatialContext->GetCoordinateSystemWkt();
-                /* skip this layer if the srs is empty */
-            if ($srsLayerWkt == null) {
-                $srsLayerWkt = $srsDefMap;
-            /* create a coordinate system from the layer's SRS wkt */
-            $srsLayer = $srsFactory->Create($srsLayerWkt);
-            // exclude layer if:
-            //  the map is non-arbitrary and the layer is arbitrary or vice-versa
-            //     or
-            //  layer and map are both arbitrary but have different units
-            $bLayerSrsIsArbitrary = ($srsLayer->GetType() == MgCoordinateSystemType::Arbitrary);
-            $bMapSrsIsArbitrary = ($srsMap->GetType() == MgCoordinateSystemType::Arbitrary);
-            $bComputedProperties = false;
-            $bNeedsTransform = false;
-            if (($bLayerSrsIsArbitrary != $bMapSrsIsArbitrary) ||
-                ($bLayerSrsIsArbitrary && ($srsLayer->GetUnits() != $srsMap->GetUnits()))) {
-            } else {
-                $srsTarget = null;
-                $srsXform = null;
-                $bNeedsTransform = ($srsLayer->GetUnitScale() != 1.0);
-            $properties = BuildSelectionArray($featureReader, $layerName, $properties,
-                                              $bComputedProperties,
-                                              $srsLayer, $bNeedsTransform, $oLayer);
-            $featureReader->Close();
-        $result = NULL;
-        $result->hasSelection = false;
-        if ($layers && $layers->GetCount() >= 0)
-            $result->hasSelection = true;
-            $oExtents = $selection->GetExtents($featureService);
-            if ($oExtents)
-                $oMin = $oExtents->GetLowerLeftCoordinate();
-                $oMax = $oExtents->GetUpperRightCoordinate();
-                $result->extents = NULL;
-                $result->extents->minx = $oMin->GetX();
-                $result->extents->miny = $oMin->GetY();
-                $result->extents->maxx = $oMax->GetX();
-                $result->extents->maxy = $oMax->GetY();
-                /*keep the full extents of the selection when saving the selection in the session*/
-                $properties->extents = NULL;
-                $properties->extents->minx = $oMin->GetX();
-                $properties->extents->miny = $oMin->GetY();
-                $properties->extents->maxx = $oMax->GetX();
-                $properties->extents->maxy = $oMax->GetY();
-            $result->layers = array();
-            for ($i=0; $i<$layers->GetCount(); $i++) {
-              $layer = $layers->GetItem($i);
-              $layerName = $layer->GetName();
-              array_push($result->layers, $layerName);
-              $layerClassName = $layer->GetFeatureClassName();
-              $filter = $selection->GenerateFilter($layer, $layerClassName);
-              $a = explode('OR', $filter);
-              $result->$layerName->featureCount = count($a);
-            /*save selection in the session*/
-            $_SESSION['selection_array'] = $properties;
-        echo var2json($result);
-    } catch(MgException $e) {
-        echo "/* SetSelection Exception: " . $e->GetDetails()."*/";
-function GetParameters($params)
-    global $selText;
-    $selText = UnescapeMagicQuotes($params['selection']);
-function UnescapeMagicQuotes($str)
-    if(ini_get("magic_quotes_sybase") == "1")
-        return str_replace("''", "'", $str);
-    else if(get_magic_quotes_gpc() == "1")
-        //Unescape double quotes
-        $str = str_replace('\\"', '"', $str);
-        //remove additional backslash
-        return str_replace("\\", "", $str);
-    return $str;
-function GetRequestParameters()
-    if($_SERVER['REQUEST_METHOD'] == "POST")
-        GetParameters($_POST);
-    else
-        GetParameters($_GET);
More information about the fusion-commits mailing list
