[fusion-commits] r1744 - trunk/widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Fri Jan 23 15:41:41 EST 2009
Author: chrisclaydon
Date: 2009-01-23 15:41:41 -0500 (Fri, 23 Jan 2009)
New Revision: 1744
   trunk/widgets/SaveMap.js
re #193 Update SaveMap widget to support basic settings as defined in the widget info file.
Modified: trunk/widgets/SaveMap.js
--- trunk/widgets/SaveMap.js	2009-01-23 20:33:53 UTC (rev 1743)
+++ trunk/widgets/SaveMap.js	2009-01-23 20:41:41 UTC (rev 1744)
@@ -49,10 +49,10 @@
         var json = widgetTag.extension;
         this.format = (json.Format && json.Format[0] != '')?
                        json.Format[0] : 'png';
         //for DWF, parse printLayouts and build menu
         if (this.format == 'DWF' && json.PrintLayout.length) {
             var layouts = json.PrintLayout;
             for (var i = 0; i < layouts.length; i++) {
                 var layout = layouts[i];
@@ -100,6 +100,27 @@
                 this.oMenu.add(menuItem);
+        } else if(this.format.toLowerCase() == 'dwf') {
+            var layout = json;
+            if(layout.ResourceId) {
+                this.printLayout = layout.ResourceId[0];
+            if (layout.PageHeight) {
+                this.pageHeight = layout.PageHeight[0];
+            if (layout.PageWidth) {
+                this.pageWidth = layout.PageWidth[0];
+            if (layout.Margins) {
+                this.margins = [layout.Margins[0].Top[0],
+                                layout.Margins[0].Left[0],
+                                layout.Margins[0].Right[0],
+                                layout.Margins[0].Bottom[0]];
+            if (layout.Scale) {
+                this.printScale = layout.Scale[0];
         } else {
             if (json.Width && json.Width[0] != '') {
                 this.imageWidth = json.Width[0];
@@ -111,11 +132,11 @@
         this.enable = Fusion.Widget.SaveMap.prototype.enable;
     enable: function() {
         Fusion.Widget.prototype.enable.apply(this, []);
     setLayout: function(data) {
         this.printLayout = data.rid;
         this.pageHeight = data.pageHeight;
@@ -148,16 +169,16 @@
         var szPageHeight = '';
         var szPageWidth = '';
         var szPageMargins = '';
-        if (this.format === 'DWF') {
+        if (this.format.toLowerCase() == 'dwf') {
             if (this.printLayout) {
-                szLayout = '&layout=' + this.printLayout;
-            } else {
-                alert('DWF Save is not properly configured.');
-                return;
+                szLayout = '&layout=' + this.printLayout;
+            //} else {
+            //    alert('DWF Save is not properly configured.');
+            //    return;
             if (this.printScale) {
                 szScale = '&scale=' + this.printScale;
             if (this.pageHeight) {
                 szPageHeight = '&pageheight=' + this.pageHeight;
@@ -182,7 +203,7 @@
             w = open(url, "Save", 'menubar=no,height=200,width=300');
         } else {
             var s = Fusion.fusionURL + 'layers/' + m.arch + '/' + Fusion.getScriptLanguage() + "/SaveMap." + Fusion.getScriptLanguage() + '?session='+m.getSessionID() + '&mapname=' + m.getMapName() + '&format=' + this.format.toUpperCase() + szLayout + szScale + szWidth + szHeight + szPageHeight + szPageWidth + szPageMargins;
             this.iframe.src = s;
More information about the fusion-commits mailing list
