[fusion-commits] r1745 - in branches/fusion2-mg21:
layers/MapGuide/php widgets
svn_fusion at osgeo.org
Fri Jan 23 15:43:12 EST 2009
Author: chrisclaydon
Date: 2009-01-23 15:43:12 -0500 (Fri, 23 Jan 2009)
New Revision: 1745
branches/fusion2-mg21/layers/MapGuide/php/SaveMap.php
branches/fusion2-mg21/widgets/SaveMap.js
re #193 - Port changes made to trunk stream to fix SaveMap widget into mg21 stream.
Modified: branches/fusion2-mg21/layers/MapGuide/php/SaveMap.php
--- branches/fusion2-mg21/layers/MapGuide/php/SaveMap.php 2009-01-23 20:41:41 UTC (rev 1744)
+++ branches/fusion2-mg21/layers/MapGuide/php/SaveMap.php 2009-01-23 20:43:12 UTC (rev 1745)
@@ -28,7 +28,7 @@
* Purpose: get map initial information
include('Common.php');
-$format = isset($_REQUEST['format']) ? $_REQUEST['format'] : 'png';
+$format = isset($_REQUEST['format']) ? $_REQUEST['format'] : 'PNG';
$layout = isset($_REQUEST['layout']) ? $_REQUEST['layout'] : null;
$scale = isset($_REQUEST['scale']) ? $_REQUEST['scale'] : null;
$imgWidth = isset($_REQUEST['width']) ? $_REQUEST['width'] : null;
Modified: branches/fusion2-mg21/widgets/SaveMap.js
--- branches/fusion2-mg21/widgets/SaveMap.js 2009-01-23 20:41:41 UTC (rev 1744)
+++ branches/fusion2-mg21/widgets/SaveMap.js 2009-01-23 20:43:12 UTC (rev 1745)
@@ -49,10 +49,10 @@
var json = widgetTag.extension;
this.format = (json.Format && json.Format[0] != '')?
json.Format[0] : 'png';
//for DWF, parse printLayouts and build menu
if (this.format == 'DWF' && json.PrintLayout.length) {
var layouts = json.PrintLayout;
for (var i = 0; i < layouts.length; i++) {
var layout = layouts[i];
@@ -100,8 +100,28 @@
this.oMenu.add(menuItem);
+ } else if(this.format.toLowerCase() == 'dwf') {
+ var layout = json;
+ if(layout.ResourceId) {
+ this.printLayout = layout.ResourceId[0];
+ if (layout.PageHeight) {
+ this.pageHeight = layout.PageHeight[0];
+ if (layout.PageWidth) {
+ this.pageWidth = layout.PageWidth[0];
+ if (layout.Margins) {
+ this.margins = [layout.Margins[0].Top[0],
+ layout.Margins[0].Left[0],
+ layout.Margins[0].Right[0],
+ layout.Margins[0].Bottom[0]];
+ if (layout.Scale) {
+ this.printScale = layout.Scale[0];
} else {
- Object.inheritFrom(this, Fusion.Widget.prototype, []);
if (json.Width && json.Width[0] != '') {
this.imageWidth = json.Width[0];
@@ -112,11 +132,11 @@
this.enable = Fusion.Widget.SaveMap.prototype.enable;
enable: function() {
Fusion.Widget.prototype.enable.apply(this, []);
setLayout: function(data) {
this.printLayout = data.rid;
this.pageHeight = data.pageHeight;
@@ -137,7 +157,7 @@
* called when the button is clicked by the Fusion.Widget widget
* prompts user to save the map.
- execute: function() {
+ activate: function() {
if (!this.iframe) {
this.iframe = document.createElement('iframe');
this.iframe.id = 'w';
@@ -149,16 +169,16 @@
var szPageHeight = '';
var szPageWidth = '';
var szPageMargins = '';
- if (this.format === 'DWF') {
+ if (this.format.toLowerCase() == 'dwf') {
if (this.printLayout) {
- szLayout = '&layout=' + this.printLayout;
- } else {
- alert('DWF Save is not properly configured.');
- return;
+ szLayout = '&layout=' + this.printLayout;
+ //} else {
+ // alert('DWF Save is not properly configured.');
+ // return;
if (this.printScale) {
szScale = '&scale=' + this.printScale;
if (this.pageHeight) {
szPageHeight = '&pageheight=' + this.pageHeight;
@@ -179,11 +199,11 @@
var m = this.getMap().aMaps[0];
if(navigator.appVersion.match(/\bMSIE\b/)) {
- var url = Fusion.fusionURL + '/' + m.arch + '/' + Fusion.getScriptLanguage() + "/SaveMapFrame." + Fusion.getScriptLanguage() + '?session='+m.getSessionID() + '&mapname=' + m.getMapName() + '&format=' + this.format + szLayout + szScale + szWidth + szHeight + szPageHeight + szPageWidth + szPageMargins;
+ var url = Fusion.fusionURL + 'layers/' + m.arch + '/' + Fusion.getScriptLanguage() + "/SaveMapFrame." + Fusion.getScriptLanguage() + '?session='+m.getSessionID() + '&mapname=' + m.getMapName() + '&format=' + this.format.toUpperCase() + szLayout + szScale + szWidth + szHeight + szPageHeight + szPageWidth + szPageMargins;
w = open(url, "Save", 'menubar=no,height=200,width=300');
} else {
- var s = Fusion.fusionURL + '/' + m.arch + '/' + Fusion.getScriptLanguage() + "/SaveMap." + Fusion.getScriptLanguage() + '?session='+m.getSessionID() + '&mapname=' + m.getMapName() + '&format=' + this.format + szLayout + szScale + szWidth + szHeight + szPageHeight + szPageWidth + szPageMargins;
+ var s = Fusion.fusionURL + 'layers/' + m.arch + '/' + Fusion.getScriptLanguage() + "/SaveMap." + Fusion.getScriptLanguage() + '?session='+m.getSessionID() + '&mapname=' + m.getMapName() + '&format=' + this.format.toUpperCase() + szLayout + szScale + szWidth + szHeight + szPageHeight + szPageWidth + szPageMargins;
this.iframe.src = s;
More information about the fusion-commits
