[fusion-commits] r1758 - trunk
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Jan 29 13:22:25 EST 2009
Author: chrisclaydon
Date: 2009-01-29 13:22:25 -0500 (Thu, 29 Jan 2009)
New Revision: 1758
   trunk/build.xml
re #206 - Fix problems with character encoding
Modified: trunk/build.xml
--- trunk/build.xml	2009-01-29 18:21:25 UTC (rev 1757)
+++ trunk/build.xml	2009-01-29 18:22:25 UTC (rev 1758)
@@ -43,7 +43,7 @@
   <property file="build.properties"/>
   <property file="${user.home}/build.properties"/>
-  <property file="default.properties"/>
+  <property file="default.properties"/>
 <!-- ==================== File and Directory Names ======================== -->
@@ -85,7 +85,7 @@
   Use property values to define the locations of external libraries on which
-  your application will depend.
+  your application will depend.
   <property name="YUIcompressor"  value="${basedir}/utils/yuicompressor-2.3.6.jar"/>
@@ -113,25 +113,25 @@
     <echo message="Preparing uncompressed build"/>
     <!-- Create build directories as needed -->
     <mkdir dir="${build.home}"/>
     <!-- first copy over the distributed version of the config file -->
     <copy file="config_dist.json" tofile="${build.home}/config.json"/>
     <!-- overwrite that with the customized config.json file if it exists
          it is safe to ignore warnings issued by this step -->
     <copy file="config.json" tofile="${build.home}/config.json" overwrite="true" failonerror="false"/>
     <!-- Copy static content -->
     <copy todir="${build.home}">
-      <fileset dir="${basedir}"
+      <fileset dir="${basedir}"
             includes="configHeader.json
-                      layers/**
-                      common/**
+                      layers/**
+                      common/**
                       containerinfo/**
-                      docs/**
-                      ext/**
-                      lib/**
-                      templates/**
-                      text/**
+                      docs/**
+                      ext/**
+                      lib/**
+                      templates/**
+                      text/**
                       widgets/**"
             excludes="selenium/**"
@@ -141,33 +141,33 @@
 <!-- ==================== Documentation =================================== -->
   <target description="Create documentation" name="docs" depends="prepare">
     <delete dir="${build.home}/docs/NaturalDocs"/>
     <mkdir dir="${build.home}/docs"/>
     <mkdir dir="${build.home}/docs/NaturalDocs"/>
     <echo message="Generating documentation"/>
     <exec executable="cmd" os="Windows Vista, Windows XP" dir="${build.home}">
         <arg value="/c"/>
-		<arg value="NaturalDocs.bat"/>
+        <arg value="NaturalDocs.bat"/>
         <arg value="-i ./"/>
         <arg value="-o html ./docs"/>
         <arg value="-p ./docs/NaturalDocs"/>
         <arg value="-xi ./scriptaculous"/>
         <arg value="-xi ./lib"/>
         <arg value="-r"/>
         <arg line="/c perl C:\Progra~1\NaturalDocs\NaturalDocs -i ./lib -i ./widgets -o html ./docs/NaturalDocs -p ./docs/NaturalDocs -r"/>
     </exec>
   </target>
   <target description="Create documentation" name="widgetInfo" depends="prepare">
     <delete dir="${build.home}/docs/widgetinfo"/>
     <mkdir dir="${build.home}/docs/widgetinfo"/>
-    <xslt basedir="${basedir}/widgets/widgetinfo"
+    <xslt basedir="${basedir}/widgets/widgetinfo"
           destdir="${build.home}/docs/widgetinfo"
-          style="${basedir}/widgets/widgetinfo/widgetInfo.xsl"
+          style="${basedir}/widgets/widgetinfo/widgetInfo.xsl"
           excludes="WidgetInfoTemplate.xml widgetInfo.xsl"/>
   </target>
@@ -175,21 +175,21 @@
   <target description="convert AppDef to JSON" name="appDef2Json" if="appDef">
     <echo message="converting ${appDef} to JSON"/>
     <delete dir="${build.home}/appDefFileset.xml"/>
     <!-- generate the list of files for this Application and load as a property -->
-    <xslt in="${appDef}"
+    <xslt in="${appDef}"
           out="${build.home}/appDefFileset.xml"
           style="${basedir}/parseAppDef.xsl">
       <param name="buildHome" expression="${build.home}"/>
     </xslt>
     <xmlproperty file="${build.home}/appDefFileset.xml"/>
     <!-- convert the application definition file to JSON -->
-    <exec executable="php" os="Windows Vista, Windows XP"
+    <exec executable="php" os="Windows Vista, Windows XP"
               output="${build.home}/appDef.json">
         <arg line="common\php\Xml2JSON.php --file='${appDef}'"/>
     </exec>
   </target>
 <!-- =================== single file build ================================== -->
@@ -198,27 +198,27 @@
     <copy file="${buildOutput}.js" todir="${basedir}/lib"/>
   </target>
 <!-- =================== concat build ================================== -->
   <target description="concatenate core files into a single file" name="concat" depends="prepare">
     <echo message="concatenating core files"/>
     <delete file="${buildOutput}.js"/>
     <!-- Fusion looks for it's own script name to set paths for other widgets
         so replace the value to look for with the sfName used to create the file-->
     <!-- merge everything into a single file -->
-    <concat destfile="${buildOutput}.js" outputencoding="UTF-8">
-        <filelist dir="${build.home}/lib"
+    <concat destfile="${buildOutput}.js" encoding="UTF-8" outputencoding="UTF-8">
+        <filelist dir="${build.home}/lib"
                   files=" SingleFile.js
                           fusion.js
                           OpenLayers/OpenLayers.js
                           jxlib.uncompressed.js
-                          Error.js
+                          Error.js
                           EventMgr.js
                           ApplicationDefinition.js
-                          MGBroker.js
-                          Widget.js
+                          MGBroker.js
+                          Widget.js
                           Search.js
                           Map.js"
@@ -227,16 +227,16 @@
         <fileset dir="${build.home}/lib/OpenLayers/Lang" includes="**/*.js"/>
         <filelist dir="${build.home}" files="configHeader.json config.json"/>
     </concat>
-    <replace file="${buildOutput}.js" token="lib/fusion" value="lib/${sfName}"/>
+    <replace file="${buildOutput}.js" token="lib/fusion" value="lib/${sfName}" encoding="UTF-8"/>
   </target>
 <!-- =================== concat all support files (no appdef supplied) ================================== -->
   <target description="concatenate core files into a single file" name="concatNoAppDef" unless="appDef">
     <echo message="concatenating all widget and map layer files"/>
-    <concat destfile="${buildOutput}.js" outputencoding="UTF-8" append="true">
+    <concat destfile="${buildOutput}.js" encoding="UTF-8" outputencoding="UTF-8" append="true">
         <fileset dir="${build.home}/widgets" includes="**/*.js"/>
         <fileset dir="${build.home}/layers" includes="**/*.js" excludes="Layers.js MapGuide/MapGuideViewerApi.js"/>
     </concat>
@@ -245,14 +245,14 @@
 <!-- =================== concat support files included in AppDef ================================== -->
   <target description="concatenate core files into a single file" name="concatWithAppDef" depends="appDef2Json" if="appDef">
     <echo message="preparing single file build for ${appDef}"/>
         <filelist dir="${build.home}" files="${AppDef.Maps}"/>
         <filelist dir="${build.home}" files="${AppDef.Widgets}"/>
         <filelist dir="${build.home}" files="appDef.json"/>
     </concat>
   </target>
@@ -265,20 +265,20 @@
         <arg value="${buildOutput}.js"/>
     </java>
     <copy file="${buildOutput}-compressed.js" todir="${basedir}/lib"/>
   </target>
 <!-- =================== concat all CSS files ================================== -->
   <target description="concatenate CSS files into a single file" name="concatCSS" depends="prepare">
     <echo message="concatenating all CSS files"/>
     <echo message="merging with ${cssFiles}"/>
-    <concat destfile="${cssOutput}.css">
+    <concat destfile="${cssOutput}.css" encoding="UTF-8" outputencoding="UTF-8">
         <filelist files="${cssFiles}"/>
         <fileset dir="${build.home}/widgets" includes="**/*.css" excludes="**/*scalebar*"/>
     </concat>
     <java jar="${YUIcompressor}" fork="true"
           output="${cssOutput}-compressed.css">
         <arg value="${cssOutput}.css"/>
@@ -288,13 +288,13 @@
 <!-- =================== concat and compress a list of CSS files ================================== -->
   <target description="concatenate and compress CSS files into a single file" name="compressCSS" if="cssFiles">
     <echo message="merging ${cssFiles}"/>
     </concat>
@@ -329,7 +329,7 @@
   <target name="dist" description="Create binary distribution" depends="clean,docs,compress">
     <echo message="Creating distribution archive"/>
     <mkdir dir="${dist.home}"/>
@@ -337,15 +337,15 @@
     <zip destfile="${dist.home}/${app.name}-${app.version}.zip" update="true">
       <zipfileset dir="${build.home}" prefix="${app.name}"/>
     </zip>
     <!-- create tar file -->
     <tar destfile="${dist.home}/${app.name}-${app.version}.tar">
       <tarfileset dir="${build.home}" prefix="${app.name}"/>
     </tar>
     <gzip src="${dist.home}/${app.name}-${app.version}.tar" destfile="${dist.home}/${app.name}-${app.version}.tar.gz"/>
     <!--tar destfile=""/-->
   </target>
 <!-- ==================== Clean Target ==================================== -->
More information about the fusion-commits mailing list
