[fusion-commits] r1759 - in trunk: lib templates/mapguide/standard templates/mapserver/standard text/en
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu Jan 29 15:47:36 EST 2009
Author: madair
Date: 2009-01-29 15:47:36 -0500 (Thu, 29 Jan 2009)
New Revision: 1759
   trunk/lib/ApplicationDefinition.js
   trunk/templates/mapguide/standard/ApplicationDefinition.xml
   trunk/templates/mapserver/standard/ApplicationDefinition.xml
   trunk/templates/mapserver/standard/index.html
   trunk/text/en/strings.json
closes #68: allow I18n dictionary keys to be used in the AppDef files; change StatusItem to StatusText;
Modified: trunk/lib/ApplicationDefinition.js
--- trunk/lib/ApplicationDefinition.js	2009-01-29 18:22:25 UTC (rev 1758)
+++ trunk/lib/ApplicationDefinition.js	2009-01-29 20:47:36 UTC (rev 1759)
@@ -788,6 +788,7 @@
             this.type = jsonNode.Type[0];
             this.name = jsonNode.Name ? jsonNode.Name[0] : '';
             this.statusText = jsonNode.StatusText ? jsonNode.StatusText[0] : '';
+            this.statusText = OpenLayers.i18n(this.statusText);
             //TODO: this may be an extension
             this.location = jsonNode.Location ? jsonNode.Location[0] : 'widgets/';
             if (this.location.slice(-1) != '/') {
@@ -796,7 +797,9 @@
             this.imageUrl = jsonNode.ImageUrl ? jsonNode.ImageUrl[0] : '';
             this.imageClass = jsonNode.ImageClass ? jsonNode.ImageClass[0] : '';
             this.tooltip = jsonNode.Tooltip ? jsonNode.Tooltip[0] : '';
+            this.tooltip = OpenLayers.i18n(this.tooltip);
             this.label = jsonNode.Label ? jsonNode.Label[0] : '';
+            this.label = OpenLayers.i18n(this.label);
             this.disabled = jsonNode.Disabled ? (jsonNode.Disabled[0].toLowerCase() == 'true' ? true : false) : false;
             //console.log('Widget: ' + this.type + ', ' + this.name + ', ' + this.description);
Modified: trunk/templates/mapguide/standard/ApplicationDefinition.xml
--- trunk/templates/mapguide/standard/ApplicationDefinition.xml	2009-01-29 18:22:25 UTC (rev 1758)
+++ trunk/templates/mapguide/standard/ApplicationDefinition.xml	2009-01-29 20:47:36 UTC (rev 1759)
@@ -316,7 +316,7 @@
     <MapWidget xsi:type="WidgetType">
       <Name>Map</Name>
       <Type>Map</Type>
-      <StatusItem>The map.</StatusItem>
+      <StatusText>The map.</StatusText>
       <Extension xsi:type="CustomContentType">
         <MenuContainer>MapContextMenu</MenuContainer>
         <!--Scales>100000,50000,25000,12500,8000,4000</Scales-->
@@ -335,7 +335,7 @@
     <Widget xsi:type="UiWidgetType">
       <Name>menuPan</Name>
       <Type>Pan</Type>
-      <StatusItem>Drag the map to view areas out of range.</StatusItem>
+      <StatusText>Drag the map to view areas out of range.</StatusText>
       <ImageUrl>images/icons.png</ImageUrl>
       <ImageClass>pan</ImageClass>
       <Tooltip>Pan mode</Tooltip>
@@ -348,7 +348,7 @@
       <Name>menuZoomInRectangle</Name>
       <Type>Zoom</Type>
-      <StatusItem>Zoom in on an area.</StatusItem>
+      <StatusText>Zoom in on an area.</StatusText>
         <Tolerance>5</Tolerance>
         <Factor>2</Factor>
@@ -365,7 +365,7 @@
       <Name>menuZoomInFixed</Name>
       <Type>ZoomOnClick</Type>
-      <StatusItem>Zoom in by a preset increment.</StatusItem>
+      <StatusText>Zoom in by a preset increment.</StatusText>
         <Factor>2</Factor>
       </Extension>
@@ -381,7 +381,7 @@
       <Name>menuRefreshMap</Name>
       <Type>RefreshMap</Type>
-      <StatusItem>Refreshes the map image.</StatusItem>
+      <StatusText>Refreshes the map image.</StatusText>
       <ImageClass>view-refresh</ImageClass>
       <Tooltip>Refresh map and reload all layers, keeping the current center point and scale.</Tooltip>
@@ -394,7 +394,7 @@
       <Name>menuZoomOutFixed</Name>
-      <StatusItem>Zoom out by a preset increment</StatusItem>
+      <StatusText>Zoom out by a preset increment</StatusText>
         <Factor>0.5</Factor>
       </Extension>
@@ -410,7 +410,7 @@
       <Name>menuInitialMapView</Name>
       <Type>InitialMapView</Type>
-      <StatusItem>Fit the extents of the map to the window</StatusItem>
+      <StatusText>Fit the extents of the map to the window</StatusText>
         <ViewType>extent</ViewType>
       </Extension>
@@ -426,7 +426,7 @@
       <Name>menuPreviousView</Name>
       <Type>ExtentHistory</Type>
-      <StatusItem>Go to previous view.</StatusItem>
+      <StatusText>Go to previous view.</StatusText>
         <Direction>previous</Direction>
       </Extension>
@@ -442,7 +442,7 @@
       <Name>menuNextView</Name>
-      <StatusItem>Go to next view.</StatusItem>
+      <StatusText>Go to next view.</StatusText>
         <Direction>next</Direction>
       </Extension>
@@ -458,7 +458,7 @@
       <Name>menuInitialMapScaleAndCenter</Name>
-      <StatusItem>Zoom to initial map center and scale.</StatusItem>
+      <StatusText>Zoom to initial map center and scale.</StatusText>
         <ViewType>center</ViewType>
       </Extension>
@@ -474,7 +474,7 @@
       <Name>menuZoomSelection</Name>
       <Type>ZoomToSelection</Type>
-      <StatusItem>Zoom to the extents of the current selection.</StatusItem>
+      <StatusText>Zoom to the extents of the current selection.</StatusText>
       <ImageClass>select-zoom</ImageClass>
       <Tooltip>Zoom to selection.</Tooltip>
@@ -487,7 +487,7 @@
       <Name>menuSelect</Name>
       <Type>Select</Type>
-      <StatusItem>Select features by clicking and dragging.</StatusItem>
+      <StatusText>Select features by clicking and dragging.</StatusText>
       <ImageClass>select-features</ImageClass>
       <Tooltip>Select mode</Tooltip>
@@ -500,7 +500,7 @@
       <Name>menuClearSelection</Name>
       <Type>ClearSelection</Type>
-      <StatusItem>Clears the current selection.</StatusItem>
+      <StatusText>Clears the current selection.</StatusText>
       <ImageClass>select-clear</ImageClass>
       <Tooltip/>
@@ -513,7 +513,7 @@
       <Name>menuSelectRadius</Name>
       <Type>SelectRadius</Type>
-      <StatusItem>Click and drag to select all features inside a circle.</StatusItem>
+      <StatusText>Click and drag to select all features inside a circle.</StatusText>
       <ImageClass>select-radius</ImageClass>
       <Tooltip>Select Radius</Tooltip>
@@ -526,7 +526,7 @@
       <Name>menuSelectPolygon</Name>
       <Type>SelectPolygon</Type>
-      <StatusItem>Create a polygon and select all features that fall within.</StatusItem>
+      <StatusText>Create a polygon and select all features that fall within.</StatusText>
       <ImageClass>select-polygon</ImageClass>
       <Tooltip>Select Polygon</Tooltip>
@@ -539,7 +539,7 @@
       <Name>menuSelectWithin</Name>
       <Type>SelectWithin</Type>
-      <StatusItem>Select all features that fall within the currently selected area.</StatusItem>
+      <StatusText>Select all features that fall within the currently selected area.</StatusText>
       <ImageClass>select-within</ImageClass>
       <Tooltip>Select Within</Tooltip>
@@ -552,7 +552,7 @@
       <Name>menuBuffer</Name>
       <Type>BufferPanel</Type>
-      <StatusItem>Create buffers around the selected features</StatusItem>
+      <StatusText>Create buffers around the selected features</StatusText>
       <ImageClass>buffer</ImageClass>
       <Tooltip>Buffer</Tooltip>
@@ -565,7 +565,7 @@
       <Name>menuViewOptions</Name>
       <Type>ViewOptions</Type>
-      <StatusItem>Switch between Imperial and Metric units</StatusItem>
+      <StatusText>Switch between Imperial and Metric units</StatusText>
         <DisplayUnits>degrees</DisplayUnits>
       </Extension>
@@ -581,7 +581,7 @@
       <Name>menuHelp</Name>
       <Type>Help</Type>
-      <StatusItem/>
+      <StatusText/>
       <ImageClass>help</ImageClass>
       <Tooltip/>
@@ -594,7 +594,7 @@
       <Name>menuAbout</Name>
       <Type>About</Type>
-      <StatusItem/>
+      <StatusText/>
       <ImageUrl/>
       <ImageClass/>
       <Tooltip/>
@@ -607,7 +607,7 @@
       <Name>menuMeasure</Name>
       <Type>Measure</Type>
-      <StatusItem>Measure distances on the map.</StatusItem>
+      <StatusText>Measure distances on the map.</StatusText>
         <Type>both</Type>
         <MeasureTooltipContainer>MeasureResult</MeasureTooltipContainer>
@@ -635,7 +635,7 @@
       <Name>toolbarBuffer</Name>
@@ -651,7 +651,7 @@
       <Name>toolbarRefreshMap</Name>
@@ -664,7 +664,7 @@
       <Name>toolbarMeasure</Name>
         <Type>both</Type>
@@ -686,7 +686,7 @@
       <Name>toolbarViewOptions</Name>
         <DisplayUnits>meters</DisplayUnits>
       </Extension>
@@ -702,7 +702,7 @@
       <Name>toolbarHelp</Name>
       <Type>Help</Type>
-      <StatusItem/>
+      <StatusText/>
       <Tooltip/>
@@ -715,7 +715,7 @@
       <Name>toolbarAbout</Name>
       <Type>About</Type>
-      <StatusItem/>
+      <StatusText/>
       <ImageUrl/>
       <ImageClass/>
       <Tooltip/>
@@ -728,7 +728,7 @@
       <Name>toolbarClearSelection</Name>
       <Tooltip/>
@@ -741,7 +741,7 @@
       <Name>toolbarSelectRadius</Name>
@@ -754,7 +754,7 @@
       <Name>toolbarSelectPolygon</Name>
@@ -775,7 +775,7 @@
       <Name>toolbarSecondaryInitialMapView</Name>
       </Extension>
@@ -791,7 +791,7 @@
       <Name>toolbarSecondaryPreviousView</Name>
       </Extension>
@@ -807,7 +807,7 @@
       <Name>toolbarSecondaryNextView</Name>
       </Extension>
@@ -823,7 +823,7 @@
       <Name>toolbarSecondaryZoomSelection</Name>
@@ -836,7 +836,7 @@
       <Name>toolbarSelectWithin</Name>
       <ImageUrl>images/icons/select-features.png</ImageUrl>
       <Extension>
         <Target>TaskPane</Target>
@@ -860,7 +860,7 @@
     <Widget xsi:type="WidgetType">
       <Name>StatusCoords</Name>
       <Type>CursorPosition</Type>
-      <StatusItem/>
+      <StatusText/>
         <Template>X: {x} {units}, Y: {y} {units}</Template>
         <Precision>4</Precision>
@@ -873,7 +873,7 @@
       <Name>StatusSelection</Name>
       <Type>SelectionInfo</Type>
-      <StatusItem/>
+      <StatusText/>
       <Extension>
           <EmptyText>No selection.</EmptyText>
      </Extension>
@@ -884,7 +884,7 @@
       <Name>StatusScale</Name>
       <Type>EditableScale</Type>
-      <StatusItem/>
+      <StatusText/>
     </Widget>
 <!-- STATUS VIEWSIZE -->
@@ -892,7 +892,7 @@
       <Name>StatusViewSize</Name>
       <Type>ViewSize</Type>
-      <StatusItem/>
+      <StatusText/>
         <Template>{w} x {h} ({units})</Template>
         <Precision>2</Precision>
@@ -910,7 +910,7 @@
       <Name>Legend</Name>
       <Type>Legend</Type>
-      <StatusItem/>
+      <StatusText/>
     </Widget>
 <!-- SELECTION -->
@@ -918,7 +918,7 @@
       <Name>SelectionPanel</Name>
       <Type>SelectionPanel</Type>
-      <StatusItem/>
+      <StatusText/>
     </Widget>
 <!-- TASKS -->
@@ -926,7 +926,7 @@
       <Name>TaskPane</Name>
       <Type>TaskPane</Type>
-      <StatusItem/>
+      <StatusText/>
       <Extension>
         <MenuContainer>TaskContextMenu</MenuContainer>
       </Extension>
@@ -952,7 +952,7 @@
       <Name>ZoomInRectangle</Name>
       <Type>Zoom</Type>
         <Factor>2</Factor>
@@ -969,7 +969,7 @@
       <Name>ZoomInFixed</Name>
         <Factor>4</Factor>
       </Extension>
@@ -985,7 +985,7 @@
       <Name>ZoomOutFixed</Name>
       </Extension>
@@ -1001,7 +1001,7 @@
       <Name>Select</Name>
       <Type>Select</Type>
@@ -1014,7 +1014,7 @@
     <Widget>
       <Name>MapMenu</Name>
       <Type>MapMenu</Type>
-      <StatusItem/>
+      <StatusText/>
       <Extension/>
       <ImageUrl/>
       <ImageClass/>
@@ -1038,7 +1038,7 @@
       <Name>GetPrintablePage</Name>
       <Type>Print</Type>
-      <StatusItem>Get printer-friendly page.</StatusItem>
+      <StatusText>Get printer-friendly page.</StatusText>
         <ShowPrintUI>true</ShowPrintUI>
         <ShowTitle>true</ShowTitle>
@@ -1059,7 +1059,7 @@
       <Name>Pan</Name>
       <Type>Pan</Type>
Modified: trunk/templates/mapserver/standard/ApplicationDefinition.xml
--- trunk/templates/mapserver/standard/ApplicationDefinition.xml	2009-01-29 18:22:25 UTC (rev 1758)
+++ trunk/templates/mapserver/standard/ApplicationDefinition.xml	2009-01-29 20:47:36 UTC (rev 1759)
@@ -9,12 +9,12 @@
   <MapSet xsi:type="MapSetType">
-    <MapGroup id="reliance-roads" xsi:type="MapType">
+    <MapGroup id="groups" xsi:type="MapType">
       <Map xsi:type="MapLayerType">
         <Type>MapServer</Type>
         <SingleTile>true</SingleTile>
         <Extension>
-            <MapFile>/ms4w/apps/gmap/htdocs/gmap75.map</MapFile>
+            <MapFile>/ms4w/apps/gmap/htdocs/gmap_groups.map</MapFile>
         </Extension>
       </Map>
     </MapGroup>
@@ -366,7 +366,7 @@
       <Name>menuPlaceholder</Name>
       <Type>InvokeScript</Type>
-      <StatusItem/>
+      <StatusText/>
       <Extension>
         <Script>return true</Script>
       </Extension>
@@ -390,7 +390,7 @@
       <Type>Pan</Type>
@@ -403,7 +403,7 @@
       <Type>Zoom</Type>
         <Factor>2</Factor>
@@ -411,7 +411,7 @@
       <ImageClass>zoom-in</ImageClass>
       <Tooltip>Zoom In</Tooltip>
-      <Label>Zoom Rectangle</Label>
+      <Label>zoomRect</Label>
       <Disabled/>
     </Widget>
@@ -420,7 +420,7 @@
         <Factor>2</Factor>
       </Extension>
@@ -436,7 +436,7 @@
@@ -449,7 +449,7 @@
       </Extension>
@@ -465,7 +465,7 @@
       </Extension>
@@ -481,7 +481,7 @@
       </Extension>
@@ -497,7 +497,7 @@
       </Extension>
@@ -513,7 +513,7 @@
       </Extension>
@@ -529,7 +529,7 @@
@@ -542,7 +542,7 @@
       <Type>Select</Type>
@@ -555,7 +555,7 @@
       <Tooltip/>
@@ -568,7 +568,7 @@
@@ -581,7 +581,7 @@
@@ -594,7 +594,7 @@
@@ -607,7 +607,7 @@
@@ -620,7 +620,7 @@
       </Extension>
@@ -636,7 +636,7 @@
       <Type>Help</Type>
-      <StatusItem/>
+      <StatusText/>
       <Tooltip/>
@@ -649,7 +649,7 @@
       <Type>About</Type>
-      <StatusItem/>
+      <StatusText/>
       <ImageUrl/>
       <ImageClass/>
       <Tooltip/>
@@ -662,7 +662,7 @@
         <Type>both</Type>
@@ -684,7 +684,7 @@
       <Name>showOverviewMap</Name>
-      <StatusItem/>
+      <StatusText/>
       <Extension>
         <Script>showOverviewMap()</Script>
       </Extension>
@@ -708,7 +708,7 @@
@@ -724,7 +724,7 @@
@@ -737,7 +737,7 @@
         <Type>both</Type>
@@ -759,7 +759,7 @@
       </Extension>
@@ -775,7 +775,7 @@
       <Type>Help</Type>
-      <StatusItem/>
+      <StatusText/>
       <Tooltip/>
@@ -788,7 +788,7 @@
       <Type>About</Type>
-      <StatusItem/>
+      <StatusText/>
       <ImageUrl/>
       <ImageClass/>
       <Tooltip/>
@@ -801,7 +801,7 @@
       <Tooltip/>
@@ -814,7 +814,7 @@
@@ -827,7 +827,7 @@
@@ -848,7 +848,7 @@
       </Extension>
@@ -864,7 +864,7 @@
       </Extension>
@@ -880,7 +880,7 @@
       </Extension>
@@ -896,7 +896,7 @@
@@ -909,7 +909,7 @@
@@ -930,7 +930,7 @@
-      <StatusItem/>
+      <StatusText/>
@@ -943,7 +943,7 @@
-      <StatusItem/>
+      <StatusText/>
       <Extension>
      </Extension>
@@ -954,7 +954,7 @@
-      <StatusItem/>
+      <StatusText/>
     </Widget>
@@ -962,7 +962,7 @@
-      <StatusItem/>
+      <StatusText/>
@@ -974,7 +974,7 @@
       <Name>StatusNavigator</Name>
-      <StatusItem/>
+      <StatusText/>
       <Extension>
       </Extension>
@@ -998,7 +998,7 @@
       <Name>Legend</Name>
       <Type>Legend</Type>
-      <StatusItem/>
+      <StatusText/>
     </Widget>
 <!-- SELECTION -->
@@ -1006,7 +1006,7 @@
-      <StatusItem/>
+      <StatusText/>
     </Widget>
 <!-- TASKS -->
-      <StatusItem/>
+      <StatusText/>
       <Extension>
       </Extension>
@@ -1040,7 +1040,7 @@
       <Type>Zoom</Type>
         <Factor>2</Factor>
@@ -1057,7 +1057,7 @@
         <Factor>2</Factor>
       </Extension>
@@ -1073,7 +1073,7 @@
       </Extension>
@@ -1089,7 +1089,7 @@
       <Name>Select</Name>
       <Type>Select</Type>
@@ -1102,7 +1102,7 @@
     <Widget>
-      <StatusItem/>
+      <StatusText/>
       <Extension/>
       <ImageUrl/>
       <ImageClass/>
@@ -1116,11 +1116,11 @@
       <Name>Map</Name>
       <Type>Map</Type>
       </Extension>
-      <MapId>reliance-roads</MapId>
+      <MapId>gmap</MapId>
     </MapWidget>
 <!-- OVERVIEW MAP
@@ -1140,7 +1140,7 @@
       <Type>Print</Type>
@@ -1161,7 +1161,7 @@
       <Name>Pan</Name>
       <Type>Pan</Type>
Modified: trunk/templates/mapserver/standard/index.html
--- trunk/templates/mapserver/standard/index.html	2009-01-29 18:22:25 UTC (rev 1758)
+++ trunk/templates/mapserver/standard/index.html	2009-01-29 20:47:36 UTC (rev 1759)
@@ -6,7 +6,7 @@
 <!-- change the source of the following tag to point to your fusion installation
     <script src='http://maps.google.com/maps?file=api&amp;v=2&amp;key=ABQIAAAAjpkAC9ePGem0lIq5XcMiuhR_wWLPFku8Ix9i2SXYRVK3e45q1BQUd_beF8dtzKET_EteAjPdGDwqpQ'></script>
-<script type="text/javascript" src="../../../lib/fusionSF-compressed.js"></script>
+<script type="text/javascript" src="../../../lib/fusion.js" charset="utf-8"></script>
 <link rel="stylesheet" href="themes/delicious/jxtheme.uncompressed.css" type="text/css" media="screen" charset="utf-8">
 <link rel="stylesheet" href="icons.css" type="text/css" media="screen" charset="utf-8">
 <style type="text/css">
Modified: trunk/text/en/strings.json
--- trunk/text/en/strings.json	2009-01-29 18:22:25 UTC (rev 1758)
+++ trunk/text/en/strings.json	2009-01-29 20:47:36 UTC (rev 1759)
@@ -48,6 +48,7 @@
 'zoomIn': 'Zoom In',
 'printCancel': 'Cancel',
 'printGenerate': 'Generate',
+'zoomRect': 'Zoom Rectangle',
 'end': ''
More information about the fusion-commits mailing list
