[fusion-commits] r1862 - trunk/widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Wed May 20 15:55:01 EDT 2009
Author: pagameba
Date: 2009-05-20 15:55:01 -0400 (Wed, 20 May 2009)
New Revision: 1862
   trunk/widgets/Redline.js
change to setTimeout as setInterval never seems to clear.
Modified: trunk/widgets/Redline.js
--- trunk/widgets/Redline.js	2009-05-20 19:54:28 UTC (rev 1861)
+++ trunk/widgets/Redline.js	2009-05-20 19:55:01 UTC (rev 1862)
@@ -329,7 +329,7 @@
         var url = Fusion.getFusionURL() + this.panelUrl;
         var taskPaneTarget = Fusion.getWidgetById(this.widget.sTarget);
-        var outpuWin = window;
+        var outputWin = window;
         if ( taskPaneTarget ) {
             taskPaneTarget.setContent(url);
@@ -337,19 +337,20 @@
         } else {
             outputWin = window.open(url, this.widget.sTarget, this.widget.sWinFeatures);
-        outputWin.parent = window;
+        //outputWin.parent = window;
         this.taskPaneWin = outputWin;
         var initFunction = OpenLayers.Function.bind(this.initPanel, this);
-        this.intervalID = setInterval(initFunction,300);
+        setTimeout(initFunction,300);
     // when the panel is loaded....
     initPanel: function() {
-        if (!this.taskPaneWin.document.getElementById("panelIsLoaded"))
-            return;
-        clearInterval(this.intervalID);
-        this.intervalID = null;
+        if (!this.taskPaneWin.document.getElementById("panelIsLoaded")) {
+            var initFunction = OpenLayers.Function.bind(this.initPanel, this);
+            return;
         // select the default control
         var radioName = this.widget.defaultControl.charAt(0).toUpperCase() + this.widget.defaultControl.substr(1);
         this.taskPaneWin.document.getElementById("RedlineWidget"+radioName+"Radio").checked = true;
@@ -427,7 +428,7 @@
     uploadFile: function() {
         this.widget.uploadForm.submit();
     updateLayerList: function() {
More information about the fusion-commits mailing list
