[fusion-commits] r1863 - in trunk/widgets: . Redline
svn_fusion at osgeo.org
Thu May 21 16:21:44 EDT 2009
Author: aboudreault
Date: 2009-05-21 16:21:44 -0400 (Thu, 21 May 2009)
New Revision: 1863
trunk/widgets/Redline.js
trunk/widgets/Redline/Redline.php
Fixed bugs for IE 7 and 8
Modified: trunk/widgets/Redline/Redline.php
--- trunk/widgets/Redline/Redline.php 2009-05-20 19:55:01 UTC (rev 1862)
+++ trunk/widgets/Redline/Redline.php 2009-05-21 20:21:44 UTC (rev 1863)
@@ -29,7 +29,6 @@
* The max file size should be setted in the php5.ini.
$fileUpload = false;
$action = $_POST['action'];
@@ -53,6 +52,7 @@
+ else if (isset($action)){ echo "--> ".$_FILES['uploadedfile']['error']; exit(1);}
@@ -118,7 +118,14 @@
</td>
</tr>
<tr>
- <td id="RedlineWidgetUploadTd" colspan="2"/>
+ <td id="RedlineWidgetUploadTd" colspan="2">
+ <form id="RedlineWidgetUploadForm" enctype="multipart/form-data" action="Redline.php" method="post">
+ <input type="file" name="uploadedfile"/>
+ <input type="hidden" name="action" value="upload"/>
+ <br/>
+ <input id="RedlineWidgetUploadButton" type="submit" name="submit_element" value="Upload" />
+ </form>
+ </td>
</tr>
<tr><td><!-- dummy col --></td></tr>
<tr>
Modified: trunk/widgets/Redline.js
--- trunk/widgets/Redline.js 2009-05-20 19:55:01 UTC (rev 1862)
+++ trunk/widgets/Redline.js 2009-05-21 20:21:44 UTC (rev 1863)
@@ -70,7 +70,6 @@
// the hidden html form for the save action
saveForm: null,
- uploadForm: null,
initializeWidget: function(widgetTag) {
var json = widgetTag.extension;
@@ -114,7 +113,6 @@
this.createSaveForm();
- this.createUploadForm();
createDrawControls: function() {
@@ -168,7 +166,7 @@
- createSaveForm: function() {
+ createSaveForm: function(panelDocument) {
/* Create a hidden form for the Save action */
var sl = Fusion.getScriptLanguage();
var scriptURL = Fusion.getFusionURL() + 'layers/Generic/' + sl + '/save.' + sl;
@@ -200,33 +198,6 @@
document.body.appendChild(div);
- createUploadForm: function() {
- /* Create a hidden form for the Upload action ,
- this form will be placed the the TaskPane manager */
- var sl = Fusion.getScriptLanguage();
- var scriptURL = Fusion.getFusionURL() + 'widgets/Redline/Redline.php';
- var file = document.createElement("input");
- var submit = document.createElement("input");
- var action = document.createElement("input");
- this.uploadForm = document.createElement("form");
- submit.type="submit";
- submit.name="submit_element";
- submit.value="Upload";
- action.type = "hidden";
- action.name = "action";
- action.value = "upload";
- this.uploadForm.enctype = "multipart/form-data";
- this.uploadForm.action = scriptURL;
- this.uploadForm.method = "POST";
- file.name="uploadedfile";
- file.type="file";
- this.uploadForm.appendChild(file);
- this.uploadForm.appendChild(action);
- this.uploadForm.appendChild(document.createElement("br"));
- this.uploadForm.appendChild(submit);
// activate the redline widget
activate: function() {
if (this.taskPane) {
@@ -354,13 +325,7 @@
// select the default control
var radioName = this.widget.defaultControl.charAt(0).toUpperCase() + this.widget.defaultControl.substr(1);
this.taskPaneWin.document.getElementById("RedlineWidget"+radioName+"Radio").checked = true;
- // wrapper around the original upload button of the form
- var uploadButton = document.createElement("button");
- uploadButton.id = "RedlineWidgetUploadButton";
- uploadButton.innerHTML = "Upload";
- this.widget.uploadForm.elements[2].style.display = "none";
- this.taskPaneWin.document.getElementById("RedlineWidgetUploadTd").appendChild(this.widget.uploadForm);
- this.taskPaneWin.document.getElementById("RedlineWidgetUploadTd").appendChild(uploadButton);
// do we have an uploaded file ?
if (this.taskPaneWin.document.getElementById("uploadedFileName")) {
this.widget.activateControl(this.widget.defaultControl,0); //hack to reset the right control/radio
@@ -402,7 +367,7 @@
removeLayer: function() {
var i = this.taskPaneWin.document.getElementById("RedlineWidgetLayerList").selectedIndex;
this.widget.removeLayer(i);
- this.updateLayerList();
+ this.updateLayerList();
this.updateFeatureList();
@@ -426,7 +391,6 @@
uploadFile: function() {
- this.widget.uploadForm.submit();
var initFunction = OpenLayers.Function.bind(this.initPanel, this);
setTimeout(initFunction,300);
@@ -441,7 +405,14 @@
opt.text = this.widget.vectorLayers[i].name;
if (i == selectedIndex)
opt.selected = true;
- select.add(opt,null);
+ try
+ select.add(opt,null); // standards compliant
+ catch(ex)
+ select.add(opt); // IE only
@@ -449,7 +420,14 @@
var select = this.taskPaneWin.document.getElementById('RedlineWidgetFeatureList');
var opt = document.createElement('option');
opt.text = feature.id;
+ try
+ catch(ex)
removeFeature: function() {
@@ -481,7 +459,14 @@
opt.text = this.widget.activeLayer.features[i].id;
+ try
+ catch(ex)
More information about the fusion-commits
