[fusion-commits] r1968 - trunk/layers/MapServer/php
svn_fusion at osgeo.org
Tue Nov 10 14:43:26 EST 2009
Author: tnolte
Date: 2009-11-10 14:43:25 -0500 (Tue, 10 Nov 2009)
New Revision: 1968
trunk/layers/MapServer/php/LegendIcon.php
trunk/layers/MapServer/php/LoadScaleRanges.php
re #131: moved away from using $_SESSION, now directly accessing session map file.
Modified: trunk/layers/MapServer/php/LegendIcon.php
--- trunk/layers/MapServer/php/LegendIcon.php 2009-11-10 19:38:52 UTC (rev 1967)
+++ trunk/layers/MapServer/php/LegendIcon.php 2009-11-10 19:43:25 UTC (rev 1968)
@@ -1,125 +1,130 @@
-<?php
- * LegendIcon
- * $Id$
- * Copyright (c) 2007, DM Solutions Group Inc.
- * Permission is hereby granted, free of charge, to any person obtaining a
- * copy of this software and associated documentation files (the "Software"),
- * to deal in the Software without restriction, including without limitation
- * the rights to use, copy, modify, merge, publish, distribute, sublicense,
- * and/or sell copies of the Software, and to permit persons to whom the
- * Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included
- * in all copies or substantial portions of the Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
- * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
- * DEALINGS IN THE SOFTWARE.
+<?php
+ * LegendIcon
+ * $Id$
+ * Copyright (c) 2007, DM Solutions Group Inc.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+ * Purpose: Draw a legend icon
+/* set up the session */
+include(dirname(__FILE__).'/../../../common/php/Utilities.php');
+include(dirname(__FILE__).'/Common.php');
+include(dirname(__FILE__).'/Utilities.php');
- * Purpose: Draw a legend icon
-include(dirname(__FILE__).'/Common.php');
-if (!isset($mapName)) {
- die('mapname not set');
-$legendIconCacheFile = "";
-if (isset($_SESSION['maps']) && isset($_SESSION['maps'][$mapName])) {
- $configObj = $_SESSION['fusionConfig'];
- /* if the legendIconCache dir is set */
- if (isset($configObj->mapserver->legendIconCacheDir)) {
- $legendIconCacheDir = $configObj->mapserver->legendIconCacheDir;
- // check for closing '/'
- $legendIconCacheDir = str_replace( '\\', '/', trim( $legendIconCacheDir ) );
- if ( substr( $legendIconCacheDir, -1 ) != '/' )
- $legendIconCacheDir .= '/';
- $cacheLegendIcons = true;
- $str = file_get_contents($_SESSION['maps'][$mapName]);
- /* create a unique location for the map icons based on
- * the content of the of map file. If the content changes
- * then the icons should be rebuilt anyway
- $legendIconCacheDir = $legendIconCacheDir.md5($str)."/";
- if (!is_dir($legendIconCacheDir)) {
- mkdir($legendIconCacheDir);
- /* TODO: can we figure out what the content type is? */
- $legendIconCacheFile = $legendIconCacheDir."_".$REQUEST_VARS['layername']."_".$REQUEST_VARS['classindex'].".png";
- /* if the icon exists, return it */
- if (file_exists($legendIconCacheFile)) {
- header('Content-type: image/png');
- $etag = '"' . md5_file($legendIconCacheFile) . '"';
- header ("ETag: " . $etag );
- $cache_time = mktime(0, 0, 0, 1, 1, 2004);
- $expires = 3600 * 256;
- header("last-modified: " . gmdate("D, d M Y H:i:s",$cache_time) . " GMT");
- $inm = split(',', getenv("HTTP_IF_NONE_MATCH"));
- $send_body = true;
- foreach ($inm as $i) {
- if (trim($i) == $etag || trim($i) == $cache_time) {
- header ("HTTP/1.0 304 Not Modified");
- $send_body = false;
- //last modified test
- if(getenv("HTTP_IF_MODIFIED_SINCE") == gmdate("D, d M Y H:i:s",$cache_time). " GMT") {
- //more headers
- header("Expires: " . gmdate("D, d M Y H:i:s",$cache_time+$expires) . " GMT");
- header("Cache-Control: max-age=$expires, must-revalidate");
- //header('Content-Length: ' . strlen($body));
- //if we're not cacheing
- if ($send_body) {
- readfile($legendIconCacheFile);
- exit;
- $oMap = ms_newMapObj($_SESSION['maps'][$mapName]);
- $oLayer = $oMap->getLayerByName($REQUEST_VARS['layername']);
- $oClass = $oLayer->getClass($REQUEST_VARS['classindex']);
- $width = $oMap->legend->keysizex;
- $height = $oMap->legend->keysizey;
- if ($width <=0) {
- $width = 16;
- if ($height <=0) {
- $height = 16;
- $oImg = $oClass->createLegendIcon($width, $height);
- if ($cacheLegendIcons) {
- $oImg->saveImage($legendIconCacheFile);
- } else {
- $oImg->saveImage("");
- $oImg->free();
+if (!isset($mapName)) {
+ die('mapname not set');
+$mapFile = getSessionSavePath().$mapName.".map";
+$str = file_get_contents($mapFile);
+$legendIconCacheFile = "";
+if ($str) {
+ $configObj = $_SESSION['fusionConfig'];
+ /* if the legendIconCache dir is set */
+ if (isset($configObj->mapserver->legendIconCacheDir)) {
+ $legendIconCacheDir = $configObj->mapserver->legendIconCacheDir;
+ // check for closing '/'
+ $legendIconCacheDir = str_replace( '\\', '/', trim( $legendIconCacheDir ) );
+ if ( substr( $legendIconCacheDir, -1 ) != '/' )
+ $legendIconCacheDir .= '/';
+ $cacheLegendIcons = true;
+ //$str = file_get_contents($_SESSION['maps'][$mapName]);
+ /* create a unique location for the map icons based on
+ * the content of the of map file. If the content changes
+ * then the icons should be rebuilt anyway
+ $legendIconCacheDir = $legendIconCacheDir.md5($str)."/";
+ if (!is_dir($legendIconCacheDir)) {
+ mkdir($legendIconCacheDir);
+ /* TODO: can we figure out what the content type is? */
+ $legendIconCacheFile = $legendIconCacheDir."_".$REQUEST_VARS['layername']."_".$REQUEST_VARS['classindex'].".png";
+ /* if the icon exists, return it */
+ if (file_exists($legendIconCacheFile)) {
+ header('Content-type: image/png');
+ $etag = '"' . md5_file($legendIconCacheFile) . '"';
+ header ("ETag: " . $etag );
+ $cache_time = mktime(0, 0, 0, 1, 1, 2004);
+ $expires = 3600 * 256;
+ header("last-modified: " . gmdate("D, d M Y H:i:s",$cache_time) . " GMT");
+ $inm = split(',', getenv("HTTP_IF_NONE_MATCH"));
+ $send_body = true;
+ foreach ($inm as $i) {
+ if (trim($i) == $etag || trim($i) == $cache_time) {
+ header ("HTTP/1.0 304 Not Modified");
+ $send_body = false;
+ //last modified test
+ if(getenv("HTTP_IF_MODIFIED_SINCE") == gmdate("D, d M Y H:i:s",$cache_time). " GMT") {
+ //more headers
+ header("Expires: " . gmdate("D, d M Y H:i:s",$cache_time+$expires) . " GMT");
+ header("Cache-Control: max-age=$expires, must-revalidate");
+ //header('Content-Length: ' . strlen($body));
+ //if we're not cacheing
+ if ($send_body) {
+ readfile($legendIconCacheFile);
+ exit;
+ $oMap = ms_newMapObj($mapFile);
+ $oLayer = $oMap->getLayerByName($REQUEST_VARS['layername']);
+ $oClass = $oLayer->getClass($REQUEST_VARS['classindex']);
+ $width = $oMap->legend->keysizex;
+ $height = $oMap->legend->keysizey;
+ if ($width <=0) {
+ $width = 16;
+ if ($height <=0) {
+ $height = 16;
+ $oImg = $oClass->createLegendIcon($width, $height);
+ if ($cacheLegendIcons) {
+ $oImg->saveImage($legendIconCacheFile);
+ } else {
+ $oImg->saveImage("");
+ $oImg->free();
Property changes on: trunk/layers/MapServer/php/LegendIcon.php
___________________________________________________________________
Deleted: svn:eol-style
- native
Modified: trunk/layers/MapServer/php/LoadScaleRanges.php
--- trunk/layers/MapServer/php/LoadScaleRanges.php 2009-11-10 19:38:52 UTC (rev 1967)
+++ trunk/layers/MapServer/php/LoadScaleRanges.php 2009-11-10 19:43:25 UTC (rev 1968)
@@ -32,53 +32,165 @@
-include ("Common.php");
-include('../../../common/php/Utilities.php');
-include ("Utilities.php");
+/*if (isset($_SESSION['maps']) && isset($_SESSION['maps'][$mapName])) {
+ $oMap = ms_newMapObj($_SESSION['maps'][$mapName]);
+/* if scales are not set, these become the default values */
+define('MIN_SCALE', 1);
+define('MAX_SCALE', 1000000000);
+$oMap = ms_newMapObj(getSessionSavePath().$mapName.".map");
+if ($oMap) {
+ $minScale = $oMap->web->minscale == -1 ? MIN_SCALE : $oMap->web->minscale;
+ $maxScale = $oMap->web->maxscale == -1 ? MAX_SCALE : $oMap->web->maxscale;
+ //layers
+ for ($i=0;$i<$oMap->numlayers;$i++) {
+ $layer=$oMap->getLayer($i);
+ /* rename layes names with invalid characters */
+ $layer->set("name",replaceInvalidLayerName($layer->name));
+ switch($layer->type) {
+ case MS_LAYER_POINT:
+ $type = 0;
+ break;
+ case MS_LAYER_LINE:
+ $type = 1;
+ break;
+ case MS_LAYER_POLYGON:
+ $type = 2;
+ break;
+ case MS_LAYER_RASTER:
+ $type = 4;
+ break;
+ case MS_LAYER_ANNOTATION:
+ $type = 8;
+ break;
+ default:
+ $type = 0;
+ $displayInLegend = strtolower($layer->getMetaData('displayInLegend'));
+ $expandInLegend = strtolower($layer->getMetaData('expandInLegend'));
+ $legendLabel = $layer->getMetaData('legendLabel');
+ if ($legendLabel == '') {
+ $legendLabel = $layer->name;
+ $selectable = strtolower($layer->getMetaData('selectable'));
+ $editable = strtolower($layer->getMetaData('editable'));
+ /* process the classes. The legend expects things
+ * organized by scale range so we have to first
+ * find all the scale breaks, then create ranges
+ * for each scale break pair, then slot the classes
+ * into the scale ranges that they apply to.
+ $aScaleRanges = array();
+ //create a default scale range for the layer as a whole
+ $layerMin = $layer->minscale == -1 ? $minScale : $layer->minscale;
+ $layerMax = $layer->maxscale == -1 ? $maxScale : $layer->maxscale;
+ /* check to see that the layer has a vaild scale range
+ * inside the defined map's main min max scale ranges
+ * set them to the maps scale ranges if they exceede
+ if($layer->minscale != -1 && $layerMin < $minScale)
+ $layerMin = $minScale;
+ if($layer->maxscale != -1 && $layerMax > $maxScale)
+ $layerMax = $maxScale;
+ //find all the unique scale breaks in this layer
+ $aScaleBreaks = array($layerMin, $layerMax);
+ for ($j=0; $j<$layer->numclasses; $j++) {
+ $oClass = $layer->getClass($j);
+ $classMin = $oClass->minscale == -1 ? $layerMin : max($oClass->minscale, $layerMin);
+ $classMax = $oClass->maxscale == -1 ? $layerMax : min($oClass->maxscale, $layerMax);
+ if (!in_array($classMin, $aScaleBreaks)) {
+ array_push($aScaleBreaks, $classMin);
+ if (!in_array($classMax, $aScaleBreaks)) {
+ array_push($aScaleBreaks, $classMax);
+ //sort them
+ sort($aScaleBreaks);
+ //create scale ranges for each pair of breaks
+ for ($j=0; $j<count($aScaleBreaks)-1; $j++) {
+ $scaleRange = NULL;
+ $scaleRange->minScale = $aScaleBreaks[$j];
+ $scaleRange->maxScale = $aScaleBreaks[$j+1];
+ $scaleRange->styles = array();
+ array_push($aScaleRanges, $scaleRange);
+ //create classes and slot them into the scale breaks
+ $classObj = NULL;
+ // Use formatted legend label as defined by CLASS->TITLE
+ $classObj->legendLabel = $oClass->title != '' ? $oClass->title : $oClass->name;
+ //$classObj->legendLabel = $oClass->name;
+ $classObj->filter = $oClass->getExpression();
+ $classObj->minScale = $classMin;
+ $classObj->maxScale = $classMax;
+ $classObj->index = $j;
+ for ($k=0; $k<count($aScaleRanges); $k++) {
+ if ($classMin < $aScaleRanges[$k]->maxScale &&
+ $classMax > $aScaleRanges[$k]->minScale) {
+ array_push($aScaleRanges[$k]->styles, $classObj);
+ //$layerObj->scaleRanges = $aScaleRanges;
+ $_SESSION['scale_ranges'][$mapName][$layer->name] = $aScaleRanges;
-$scaleObj = NULL;
-$scaleObj->layers = array();
+ $scaleObj = NULL;
+ $scaleObj->layers = array();
-define('ICON_SIZE', 16);
-$nIconWidth = $oMap->legend->keysizex;
-$nIconHeight = $oMap->legend->keysizey;
-if ($nIconWidth <=0)
+ define('ICON_SIZE', 16);
+ $nIconWidth = $oMap->legend->keysizex;
+ $nIconHeight = $oMap->legend->keysizey;
+ if ($nIconWidth <=0)
$nIconWidth = ICON_SIZE;
-$nTotalClasses=0;
-$aIcons = array();
+ $nTotalClasses=0;
+ $aIcons = array();
-/*special case to force the the legend icons to be drawn using a gd driver
+ /*special case to force the the legend icons to be drawn using a gd driver
This was fixed in ticket http://trac.osgeo.org/mapserver/ticket/2682 which
will be available for mapserver version 5.2.1 and 5.4
Note that we do not check the outputformat of the map (assuming that we are
using GD or AGG renderers)
-$nVersion = ms_GetVersionInt();
-if ($nVersion <= 50200) /*5.2 and before*/
+ $nVersion = ms_GetVersionInt();
+ if ($nVersion <= 50200) /*5.2 and before*/
$oMap->selectOutputFormat("png24");
-for($i=0;$i<$oMap->numlayers;$i++)
- if (isset($_SESSION['scale_ranges']) && isset($_SESSION['scale_ranges'][$i]))
+ for($i=0;$i<$oMap->numlayers;$i++)
$layer = $oMap->getLayer($i);
- $scaleranges = $_SESSION['scale_ranges'][$i];
- //print_r($scaleranges);
- //echo "aaa <br>";
+ if (isset($_SESSION['scale_ranges']) && isset($_SESSION['scale_ranges'][$mapName]) && isset($_SESSION['scale_ranges'][$mapName][$layer->name]))
+ $scaleranges = $_SESSION['scale_ranges'][$mapName][$layer->name];
$layerObj = NULL;
$layerObj->uniqueId = $i;
/*generate the legend icons here*/
- //echo count($scaleranges) . "<br>\n";
$nScaleRanges = count($scaleranges);
for ($j=0; $j<$nScaleRanges; $j++)
@@ -102,8 +214,7 @@
-if ($nTotalClasses > 0)
+ if ($nTotalClasses > 0) {
//set the image path and image dir based on what fusion config file
@@ -130,19 +241,47 @@
for ($i=0; $i<$nTotalClasses;$i++)
$oImage->pasteImage($aIcons[$i], -1, $i*$nIconWidth, 0);
$scaleObj->icons_url = $oImage->saveWebImage();
$scaleObj->icons_width = $nIconWidth;
$scaleObj->icons_height = $nIconHeight;
$oMap->web->set("imagepath", $original_imagepath);
$oMap->web->set("imageurl", $original_imageurl);
+function replaceInvalidLayerName($szLayerName){
+ bug http://trac.osgeo.org/fusion/ticket/96 - Invalid characters in layer name (pdeschamps)
+ Fusion requests the map imavge via the Mapserver CGI to toggle the layer visibility.
+ The layer paramerter for the cgi uses spaces as a delimiter for the layer names this creates
+ an issue for the mapserver binary to toggle layers that have these reserved URI characters.
+ also removing characters that could pose potential issues with json.
+ $aInvalidLayerNameCharacters = array();
+ $aInvalidLayerNameCharacters[0] ="&";
+ $aInvalidLayerNameCharacters[1] =" ";
+ $aInvalidLayerNameCharacters[2] ="#";
+ $aInvalidLayerNameCharacters[3] ="\\";
+ $aInvalidLayerNameCharacters[4] ="=";
+ $aInvalidLayerNameCharacters[5] ="/";
+ $aInvalidLayerNameCharacters[6] ="'";
+ $aReplace[0] = "_";
+ $aReplace[1] = "_";
+ $aReplace[2] = "_";
+ $aReplace[3] = "_";
+ $aReplace[4] = "_";
+ $aReplace[5] = "_";
+ $aReplace[6] = "_";
+ return str_replace($aInvalidLayerNameCharacters,$aReplace,$szLayerName);
header('Content-type: application/json');
header('X-JSON: true');
echo var2json($scaleObj);
exit;
\ No newline at end of file
More information about the fusion-commits
