[fusion-commits] r1969 - trunk/widgets
svn_fusion at osgeo.org
Tue Nov 10 14:54:33 EST 2009
Author: tnolte
Date: 2009-11-10 14:54:32 -0500 (Tue, 10 Nov 2009)
New Revision: 1969
trunk/widgets/Legend.js
re #131: fixed multiple maps in mapgroup rendering issue, fixed returning background image position to '0px 0px' when reverting back to old LegendIcon rendering.
Modified: trunk/widgets/Legend.js
--- trunk/widgets/Legend.js 2009-11-10 19:43:25 UTC (rev 1968)
+++ trunk/widgets/Legend.js 2009-11-10 19:54:32 UTC (rev 1969)
@@ -1,381 +1,406 @@
- * Fusion.Widget.Legend
- * $Id$
- * Copyright (c) 2007, DM Solutions Group Inc.
- * Permission is hereby granted, free of charge, to any person obtaining a
- * copy of this software and associated documentation files (the "Software"),
- * to deal in the Software without restriction, including without limitation
- * the rights to use, copy, modify, merge, publish, distribute, sublicense,
- * and/or sell copies of the Software, and to permit persons to whom the
- * Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included
- * in all copies or substantial portions of the Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
- * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
- * DEALINGS IN THE SOFTWARE.
- * Class: Fusion.Widget.Legend
- * A widget to display a legend of all layers.
-Fusion.Widget.Legend = OpenLayers.Class(Fusion.Widget, {
- * Constant: defaultLayerDWFIcon
- * {String} The default image for DWF layer
- defaultLayerDWFIcon: 'images/icons/legend-DWF.png',
- * Constant: defaultLayerRasterIcon
- * {String} The default image for Raster layer
- defaultLayerRasterIcon: 'images/icons/legend-raster.png',
- * Constant: defaultLayerThemeIcon
- * {String} The default image for layers that are currently themed.
- defaultLayerThemeIcon: 'images/icons/legend-theme.png',
- * Constant: defaultDisabledLayerIcon
- * {String} The default image for layers that are out of scale.
- defaultDisabledLayerIcon: 'images/icons/legend-layer.png',
- * Constant: defaultRootFolderIcon
- * {String} The default image for the root folder
- defaultRootFolderIcon: 'images/icons/legend-map.png',
- * Constant: defaultLayerInfoIcon
- * {String} The default image for layer info
- defaultLayerInfoIcon: 'images/icons/tree_layer_info.png',
- * Constant: defaultGroupInfoIcon
- * {String} The default image for groupd info
- defaultGroupInfoIcon: 'images/icons/tree_group_info.png',
- initializeWidget: function(widgetTag) {
- // TODO: maybe it's a good idea to do a function like Fusion.Widget.BindRenderer.. for limit the code
- // duplication if we plan to apply this pattern to others widgets
- Fusion.addWidgetStyleSheet(widgetTag.location + 'Legend/Legend.css');
- var json = widgetTag.extension;
- if (json.LegendRenderer)
- var renderer = eval(json.LegendRenderer[0]);
- if (renderer && renderer.prototype.CLASS_NAME
- && renderer.prototype.CLASS_NAME == "Fusion.Widget.Legend.LegendRenderer") {
- this.renderer = new renderer(this, widgetTag);
- } else if (typeof renderer == "function") {
- var renderFunction = renderer;
- this.renderer = new Fusion.Widget.Legend.LegendRenderer(this);
- this.renderer.mapLoaded = renderFunction;
- this.renderer.mapReloaded = renderFunction;
- this.renderer.mapLoading = false;
- } else {
- this.renderer = new Fusion.Widget.Legend.LegendRendererDefault(this, widgetTag);
- } else {
- if (this.renderer.mapReloaded)
- this.getMap().registerForEvent(Fusion.Event.MAP_RELOADED,
- OpenLayers.Function.bind(this.renderer.mapReloaded, this.renderer));
- if (this.renderer.mapLoading)
- this.getMap().registerForEvent(Fusion.Event.MAP_LOADING,
- OpenLayers.Function.bind(this.renderer.mapLoading,this.renderer));
- if (this.renderer.mapLoaded)
- this.getMap().registerForEvent(Fusion.Event.MAP_LOADED,
- OpenLayers.Function.bind(this.renderer.mapLoaded, this.renderer));
-/* Class: Fusion.Widget.Legend.LegendRenderer
- * This is a class designed to help users to create their own renderer
- * for customize the legend.
-Fusion.Widget.Legend.LegendRenderer = OpenLayers.Class(
- * Property: oLegend
- * {<Fusion.Widget.Legend>} The parent widget that uses
- * the renderer.
- oLegend: null,
- * Property: layerRoot
- * {Groups} The groups of all layers.
- layerRoot: null,
- initialize: function(legend) {
- this.oLegend = legend;
- this.layerRoot = this.getMap().layerRoot;
- * Method: renderLegend
- * Abstract method that have the main purpose to draw the legend. This method
- * should be implemented by all concrete class.
- renderLegend: function() {},
- /**defaultDisabledLayerIcon
- * Method: mapLoading
- * Abstract method that handle the event: Fusion.Event.MAP_LOADING. This method
- * is optional.
- mapLoading: function() {},
- * Method: mapLoaded
- * Abstract method that handle the event: Fusion.Event.MAP_LOADED. This method
- * occur only at the first load of the map and should be implemented by all concrete class.
- mapLoaded: function() {},
- * Method: mapReloaded
- * Abstract method that handle the event: Fusion.Event.MAP_RELOADED. This method
- mapReloaded: function() {},
- * Method: getMap
- * Helper method to obtains the map.
- * Returns:
- * {<Fusion.Maps>} The map that uses the SelectionPanel Widget.
- getMap: function() {
- return this.oLegend.getMap();
- CLASS_NAME: "Fusion.Widget.Legend.LegendRenderer"
-/* Class: Fusion.Widget.Legend.LegendRendererDefault
- * This class provide a default legend as a collapsable tree.
-Fusion.Widget.Legend.LegendRendererDefault = OpenLayers.Class(Fusion.Widget.Legend.LegendRenderer,
- * Property: showRootFolder
- * {Boolean} This controls whether the tree will have a single root node that
- * contains the name of the map as its label. By default, the root node does
- * not appear. Set to "true" or "1" to make the root node appear.
- showRootFolder: false,
- * Property: currentNode
- * {Jx.TreeNode} The current selected node.
- currentNode: null,
- * Property: bIsDrawn
- * {Boolean} Determine if the map is drawn.
- bIsDrawn: false,
- * Property: targetFolder
- * {Jx.TreeFolder} The current TreeFolder that the mouse will interact with.
- targetFolder: null,
- * Property: bIncludeVisToggle
- * {Boolean} Determine if non-visible layer must be draw in the legend.
- bIncludeVisToggle: true,
- initialize: function(legend, widgetTag) {
- Fusion.Widget.Legend.LegendRenderer.prototype.initialize.apply(this, [legend]);
- this.imgLayerDWFIcon = json.LayerDWFIcon ? json.LayerDWFIcon[0] : this.oLegend.defaultLayerDWFIcon;
- this.imgLayerRasterIcon = json.LayerRasterIcon ? json.LayerRasterIcon[0] : this.oLegend.defaultLayerRasterIcon;
- this.imgLayerThemeIcon = json.LayerThemeIcon ? json.LayerThemeIcon[0] : this.oLegend.defaultLayerThemeIcon;
- this.imgDisabledLayerIcon = json.DisabledLayerIcon ? json.DisabledLayerIcon[0] : this.oLegend.defaultDisabledLayerIcon;
- this.imgLayerInfoIcon = json.LayerInfoIcon ? json.LayerInfoIcon[0] : this.oLegend.defaultLayerInfoIcon;
- this.imgGroupInfoIcon = json.GroupInfoIcon ? json.GroupInfoIcon[0] : this.oLegend.defaultGroupInfoIcon;
- //not used?
- //this.layerInfoURL = json.LayerInfoURL ? json.LayerInfoURL[0] : '';
- this.selectedLayer = null;
- this.oTree = new Jx.Tree({parent:this.oLegend.domObj});
- this.hideInvisibleLayers = (json.HideInvisibleLayers && json.HideInvisibleLayers[0]) == 'true' ? true : false;
- //don't show the root folder by default
- this.showRootFolder = (json.ShowRootFolder && json.ShowRootFolder[0] == 'true') ? true:false;
- //do show the map folder by default
- this.showMapFolder = (json.ShowMapFolder && json.ShowMapFolder[0] == 'false') ? false:true;
- if (!this.showRootFolder) {
- //console.log('supressing root folder');
- this.oRoot = this.oTree;
- } else {
- // console.log('showing root folder');
- var opt = {
- label: OpenLayers.i18n('defaultMapTitle'),
- open: true,
- draw: this.renderFolder,
- contextMenu: this.getContextMenu(),
- 'class':'fusionLegendFolder'
- this.oRoot = new Jx.TreeFolder(opt);
- this.oTree.append(this.oRoot);
- this.oRoot.options.contextMenu.add(
- new Jx.Menu.Item({
- label: OpenLayers.i18n('collapse'),
- onClick: OpenLayers.Function.bind(this.collapseBranch, this, this.oRoot)
- label: OpenLayers.i18n('expand'),
- onClick: OpenLayers.Function.bind(this.expandBranch, this, this.oRoot)
- this.extentsChangedWatcher = this.update.bind(this);
- getContextMenu: function() {
- return new Jx.Menu.Context(this.name).add(
- label: OpenLayers.i18n('refresh'),
- onClick: OpenLayers.Function.bind(this.update, this)
- label: OpenLayers.i18n('collapseAll'),
- onClick: OpenLayers.Function.bind(this.collapseAll, this)
- label: OpenLayers.i18n('expandAll'),
- onClick: OpenLayers.Function.bind(this.expandAll, this)
- expandAll: function(folder) {
- for (var i=0; i<this.oTree.nodes.length; i++) {
- var item = this.oTree.nodes[i];
- if (item instanceof Jx.TreeFolder) {
- this.recurseTree('expand', item);
- if (this.showRootFolder) {
- this.oRoot.expand();
- collapseAll: function(folder) {
- this.recurseTree('collapse', item);
- this.oRoot.collapse();
- collapseBranch: function(folder) {
- folder.collapse();
- expandBranch: function(folder) {
- folder.expand();
- * recursively descend the tree applying the request operation which is either 'collapse' or 'expand'
- * @param op the operation to execute
- * @param the folder to operate on
- recurseTree: function(op, folder) {
- for (var i=0; i<folder.nodes.length; i++) {
- var item = folder.nodes[i];
- this.recurseTree(op, item);
- item[op]();
- scaleRangesLoaded: function() {
- this.renderLegend();
- this.getMap().deregisterForEvent(Fusion.Event.MAP_EXTENTS_CHANGED, this.extentsChangedWatcher);
- this.clear();
- this.getMap().registerForEvent(Fusion.Event.MAP_EXTENTS_CHANGED, this.extentsChangedWatcher);
- this.getMap().loadScaleRanges(OpenLayers.Function.bind(this.scaleRangesLoaded, this));
- * the map state has become invalid in some way (layer added, removed,
- * ect). For now, we just re-request the map state from the server
- * which calls draw which recreates the entire legend from scratch
- * TODO: more fine grained updating of the legend would be nice
- invalidate: function() {
- this.draw();
- * Callback for legend XML response. Creates a list of layers and sets up event
- * handling. Create groups if applicable.
- * TODO: error handling
- * @param r Object the reponse xhr object
+ * Fusion.Widget.Legend
+ * $Id$
+ * Copyright (c) 2007, DM Solutions Group Inc.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+ * Class: Fusion.Widget.Legend
+ * A widget to display a legend of all layers.
+Fusion.Widget.Legend = OpenLayers.Class(Fusion.Widget, {
+ * Constant: defaultLayerDWFIcon
+ * {String} The default image for DWF layer
+ defaultLayerDWFIcon: 'images/icons/legend-DWF.png',
+ * Constant: defaultLayerRasterIcon
+ * {String} The default image for Raster layer
+ defaultLayerRasterIcon: 'images/icons/legend-raster.png',
+ * Constant: defaultLayerThemeIcon
+ * {String} The default image for layers that are currently themed.
+ defaultLayerThemeIcon: 'images/icons/legend-theme.png',
+ * Constant: defaultDisabledLayerIcon
+ * {String} The default image for layers that are out of scale.
+ defaultDisabledLayerIcon: 'images/icons/legend-layer.png',
+ * Constant: defaultRootFolderIcon
+ * {String} The default image for the root folder
+ defaultRootFolderIcon: 'images/icons/legend-map.png',
+ * Constant: defaultLayerInfoIcon
+ * {String} The default image for layer info
+ defaultLayerInfoIcon: 'images/icons/tree_layer_info.png',
+ * Constant: defaultGroupInfoIcon
+ * {String} The default image for groupd info
+ defaultGroupInfoIcon: 'images/icons/tree_group_info.png',
+ initializeWidget: function(widgetTag) {
+ // TODO: maybe it's a good idea to do a function like Fusion.Widget.BindRenderer.. for limit the code
+ // duplication if we plan to apply this pattern to others widgets
+ Fusion.addWidgetStyleSheet(widgetTag.location + 'Legend/Legend.css');
+ var json = widgetTag.extension;
+ if (json.LegendRenderer)
+ var renderer = eval(json.LegendRenderer[0]);
+ if (renderer && renderer.prototype.CLASS_NAME
+ && renderer.prototype.CLASS_NAME == "Fusion.Widget.Legend.LegendRenderer") {
+ this.renderer = new renderer(this, widgetTag);
+ } else if (typeof renderer == "function") {
+ var renderFunction = renderer;
+ this.renderer = new Fusion.Widget.Legend.LegendRenderer(this);
+ this.renderer.mapLoaded = renderFunction;
+ this.renderer.mapReloaded = renderFunction;
+ this.renderer.mapLoading = false;
+ } else {
+ this.renderer = new Fusion.Widget.Legend.LegendRendererDefault(this, widgetTag);
+ } else {
+ if (this.renderer.mapReloaded)
+ this.getMap().registerForEvent(Fusion.Event.MAP_RELOADED,
+ OpenLayers.Function.bind(this.renderer.mapReloaded, this.renderer));
+ if (this.renderer.mapLoading)
+ this.getMap().registerForEvent(Fusion.Event.MAP_LOADING,
+ OpenLayers.Function.bind(this.renderer.mapLoading,this.renderer));
+ if (this.renderer.mapLoaded)
+ this.getMap().registerForEvent(Fusion.Event.MAP_LOADED,
+ OpenLayers.Function.bind(this.renderer.mapLoaded, this.renderer));
+/* Class: Fusion.Widget.Legend.LegendRenderer
+ * This is a class designed to help users to create their own renderer
+ * for customize the legend.
+Fusion.Widget.Legend.LegendRenderer = OpenLayers.Class(
+ * Property: oLegend
+ * {<Fusion.Widget.Legend>} The parent widget that uses
+ * the renderer.
+ oLegend: null,
+ * Property: layerRoot
+ * {Groups} The groups of all layers.
+ layerRoot: null,
+ initialize: function(legend) {
+ this.oLegend = legend;
+ this.layerRoot = this.getMap().layerRoot;
+ * Method: renderLegend
+ * Abstract method that have the main purpose to draw the legend. This method
+ * should be implemented by all concrete class.
+ renderLegend: function() {},
+ /**defaultDisabledLayerIcon
+ * Method: mapLoading
+ * Abstract method that handle the event: Fusion.Event.MAP_LOADING. This method
+ * is optional.
+ mapLoading: function() {},
+ * Method: mapLoaded
+ * Abstract method that handle the event: Fusion.Event.MAP_LOADED. This method
+ * occur only at the first load of the map and should be implemented by all concrete class.
+ mapLoaded: function() {},
+ * Method: mapReloaded
+ * Abstract method that handle the event: Fusion.Event.MAP_RELOADED. This method
+ mapReloaded: function() {},
+ * Method: getMap
+ * Helper method to obtains the map.
+ * Returns:
+ * {<Fusion.Maps>} The map that uses the SelectionPanel Widget.
+ getMap: function() {
+ return this.oLegend.getMap();
+ CLASS_NAME: "Fusion.Widget.Legend.LegendRenderer"
+/* Class: Fusion.Widget.Legend.LegendRendererDefault
+ * This class provide a default legend as a collapsable tree.
+Fusion.Widget.Legend.LegendRendererDefault = OpenLayers.Class(Fusion.Widget.Legend.LegendRenderer,
+ * Property: showRootFolder
+ * {Boolean} This controls whether the tree will have a single root node that
+ * contains the name of the map as its label. By default, the root node does
+ * not appear. Set to "true" or "1" to make the root node appear.
+ showRootFolder: false,
+ * Property: currentNode
+ * {Jx.TreeNode} The current selected node.
+ currentNode: null,
+ * Property: bIsDrawn
+ * {Boolean} Determine if the map is drawn.
+ bIsDrawn: false,
+ * Property: targetFolder
+ * {Jx.TreeFolder} The current TreeFolder that the mouse will interact with.
+ targetFolder: null,
+ * Property: bIncludeVisToggle
+ * {Boolean} Determine if non-visible layer must be draw in the legend.
+ bIncludeVisToggle: true,
+ initialize: function(legend, widgetTag) {
+ Fusion.Widget.Legend.LegendRenderer.prototype.initialize.apply(this, [legend]);
+ this.imgLayerDWFIcon = json.LayerDWFIcon ? json.LayerDWFIcon[0] : this.oLegend.defaultLayerDWFIcon;
+ this.imgLayerRasterIcon = json.LayerRasterIcon ? json.LayerRasterIcon[0] : this.oLegend.defaultLayerRasterIcon;
+ this.imgLayerThemeIcon = json.LayerThemeIcon ? json.LayerThemeIcon[0] : this.oLegend.defaultLayerThemeIcon;
+ this.imgDisabledLayerIcon = json.DisabledLayerIcon ? json.DisabledLayerIcon[0] : this.oLegend.defaultDisabledLayerIcon;
+ this.imgLayerInfoIcon = json.LayerInfoIcon ? json.LayerInfoIcon[0] : this.oLegend.defaultLayerInfoIcon;
+ this.imgGroupInfoIcon = json.GroupInfoIcon ? json.GroupInfoIcon[0] : this.oLegend.defaultGroupInfoIcon;
+ //not used?
+ //this.layerInfoURL = json.LayerInfoURL ? json.LayerInfoURL[0] : '';
+ this.selectedLayer = null;
+ this.oTree = new Jx.Tree({parent:this.oLegend.domObj});
+ this.hideInvisibleLayers = (json.HideInvisibleLayers && json.HideInvisibleLayers[0]) == 'true' ? true : false;
+ //don't show the root folder by default
+ this.showRootFolder = (json.ShowRootFolder && json.ShowRootFolder[0] == 'true') ? true:false;
+ //do show the map folder by default
+ this.showMapFolder = (json.ShowMapFolder && json.ShowMapFolder[0] == 'false') ? false:true;
+ if (!this.showRootFolder) {
+ //console.log('supressing root folder');
+ this.oRoot = this.oTree;
+ } else {
+ // console.log('showing root folder');
+ var opt = {
+ label: OpenLayers.i18n('defaultMapTitle'),
+ open: true,
+ draw: this.renderFolder,
+ contextMenu: this.getContextMenu(),
+ 'class':'fusionLegendFolder'
+ this.oRoot = new Jx.TreeFolder(opt);
+ this.oTree.append(this.oRoot);
+ this.oRoot.options.contextMenu.add(
+ new Jx.Menu.Item({
+ label: OpenLayers.i18n('collapse'),
+ onClick: OpenLayers.Function.bind(this.collapseBranch, this, this.oRoot)
+ label: OpenLayers.i18n('expand'),
+ onClick: OpenLayers.Function.bind(this.expandBranch, this, this.oRoot)
+ this.extentsChangedWatcher = this.update.bind(this);
+ getContextMenu: function() {
+ return new Jx.Menu.Context(this.name).add(
+ label: OpenLayers.i18n('refresh'),
+ onClick: OpenLayers.Function.bind(this.update, this)
+ label: OpenLayers.i18n('collapseAll'),
+ onClick: OpenLayers.Function.bind(this.collapseAll, this)
+ label: OpenLayers.i18n('expandAll'),
+ onClick: OpenLayers.Function.bind(this.expandAll, this)
+ expandAll: function(folder) {
+ for (var i=0; i<this.oTree.nodes.length; i++) {
+ var item = this.oTree.nodes[i];
+ if (item instanceof Jx.TreeFolder) {
+ this.recurseTree('expand', item);
+ if (this.showRootFolder) {
+ this.oRoot.expand();
+ collapseAll: function(folder) {
+ this.recurseTree('collapse', item);
+ this.oRoot.collapse();
+ collapseBranch: function(folder) {
+ folder.collapse();
+ expandBranch: function(folder) {
+ folder.expand();
+ * recursively descend the tree applying the request operation which is either 'collapse' or 'expand'
+ * @param op the operation to execute
+ * @param the folder to operate on
+ recurseTree: function(op, folder) {
+ for (var i=0; i<folder.nodes.length; i++) {
+ var item = folder.nodes[i];
+ this.recurseTree(op, item);
+ item[op]();
+ scaleRangesLoaded: function() {
+ this.renderLegend();
+ this.getMap().deregisterForEvent(Fusion.Event.MAP_EXTENTS_CHANGED, this.extentsChangedWatcher);
+ this.clear();
+ this.getMap().registerForEvent(Fusion.Event.MAP_EXTENTS_CHANGED, this.extentsChangedWatcher);
+ this.getMap().loadScaleRanges(OpenLayers.Function.bind(this.scaleRangesLoaded, this));
+ * the map state has become invalid in some way (layer added, removed,
+ * ect). For now, we just re-request the map state from the server
+ * which calls draw which recreates the entire legend from scratch
+ * TODO: more fine grained updating of the legend would be nice
+ invalidate: function() {
+ this.draw();
+ * Callback for legend XML response. Creates a list of layers and sets up event
+ * handling. Create groups if applicable.
+ * TODO: error handling
+ * @param r Object the reponse xhr object
+ /*renderLegend: function(r) {
+ this.bIsDrawn = false;
+ this.clear();
+ this.oRoot.itemLabelobj.innerHTML = this.getMap().getMapTitle();
+ var startGroup = this.layerRoot;
+ if (!this.showMapFolder) {
+ startGroup = this.layerRoot.groups[0];
+ if (!startGroup.legend) {
+ startGroup.legend = {};
+ startGroup.legend.treeItem = this.oRoot;
+ for (var i=0; i<startGroup.groups.length; i++) {
+ //startGroup.groups[i].visible = true;
+ this.processMapGroup(startGroup.groups[i], this.oRoot);
+ for (var i=0; i<startGroup.layers.length; i++) {
+ this.processMapLayer(startGroup.layers[i], this.oRoot);
+ this.bIsDrawn = true;
+ this.update();
this.clear();
@@ -383,477 +408,489 @@
- var startGroup = this.layerRoot;
- if (!this.showMapFolder) {
- startGroup = this.layerRoot.groups[0];
- if (!startGroup.legend) {
- startGroup.legend = {};
- startGroup.legend.treeItem = this.oRoot;
- for (var i=0; i<startGroup.groups.length; i++) {
- //startGroup.groups[i].visible = true;
- this.processMapGroup(startGroup.groups[i], this.oRoot);
- for (var i=0; i<startGroup.layers.length; i++) {
- this.processMapLayer(startGroup.layers[i], this.oRoot);
- this.bIsDrawn = true;
- this.update();
- processMapGroup: function(group, folder) {
- if (group.displayInLegend) {
- /* make a 'namespace' on the group object to store legend-related info */
- group.legend = {};
- var opt = {
- label: group.legendLabel,
- open: group.expandInLegend,
- group.legend.treeItem = new Jx.TreeFolder(opt);
- group.legend.treeItem.domObj.store('data', group);
- group.legend.treeItem.options.contextMenu.add(
- onClick: OpenLayers.Function.bind(this.collapseBranch, this, group.legend.treeItem)
- onClick: OpenLayers.Function.bind(this.expandBranch, this, group.legend.treeItem)
- folder.append(group.legend.treeItem);
- group.legend.treeItem.checkBox.checked = group.visible?true:false;
- OpenLayers.Event.observe(group.legend.treeItem.checkBox, 'click', OpenLayers.Function.bind(this.stateChanged, this, group));
- var groupInfo = group.oMap.getGroupInfoUrl(group.groupName);
- if (groupInfo) {
- var a = document.createElement('a');
- a.href = groupInfo;
- if (groupInfo.indexOf('javascript:') < 0) {
- a.target = '_blank';
- var img = document.createElement('img');
- Jx.addToImgQueue({element:img, src: this.imgGroupInfoIcon});
- img.border = 0;
- a.appendChild(img);
- group.legend.treeItem.domObj.insertBefore(a, group.legend.treeItem.domObj.childNodes[4]);
- if (this.oSelectionListener) {
- group.legend.treeItem.addEvent('click', OpenLayers.Function.bind(this.selectionChanged, this));
- for (var i=0; i<group.groups.length; i++) {
- this.processMapGroup(group.groups[i], group.legend.treeItem);
- for (var i=0; i<group.layers.length; i++) {
- this.processMapLayer(group.layers[i], group.legend.treeItem);
- processMapLayer: function(layer, folder) {
- /* make a 'namespace' on the layer object to store legend-related info */
- layer.legend = {};
- layer.legend.parentItem = folder;
- layer.legend.currentRange = null;
- layer.oMap.registerForEvent(Fusion.Event.LAYER_PROPERTY_CHANGED, OpenLayers.Function.bind(this.layerPropertyChanged, this));
- layerPropertyChanged: function(eventID, layer) {
- layer.legend.treeItem.checkBox.checked = layer.isVisible();
- update: function() {
- if (this.bIsDrawn) {
- window.setTimeout(OpenLayers.Function.bind(this._update, this), 1);
- * update the tree when the map scale changes
- _update: function() {
- var map = this.getMap();
- var currentScale = map.getScale();
- for (var i=0; i<map.layerRoot.groups.length; i++) {
- this.updateGroupLayers(map.layerRoot.groups[i], currentScale);
- for (var i=0; i<map.layerRoot.layers.length; i++) {
- this.updateLayer(map.layerRoot.layers[i], currentScale);
- * remove the dom objects representing the legend layers and groups
- clear: function() {
- while (this.oRoot.nodes.length > 0) {
- this.oRoot.remove(this.oRoot.nodes[0]);
- selectionChanged: function(o) {
- if (this.currentNode) {
- //console.log(this.currentNode);
- $(this.currentNode.domObj.childNodes[1]).removeClass('jxTreeItemSelected');
- this.currentNode = o;
- $(this.currentNode.domObj.childNodes[1]).addClass('jxTreeItemSelected');
- var data = o.domObj.retrieve('data');
- if (data instanceof Fusion.Layers.Group) {
- this.getMap().setActiveLayer(null);
+ if (this.showMapFolder) {
+ this.renderGroup(this.layerRoot);
} else {
- this.getMap().setActiveLayer(data);
+ if (this.layerRoot.groups.length > 0) {
+ for (var i = 0; i < this.layerRoot.groups.length; i++)
+ this.renderGroup(this.layerRoot.groups[i]);
+ } else {
+ for (var i = 0; i < group.layers.length; i++)
+ this.processMapLayer(group.layers[i], this.oRoot);
- updateGroupLayers: function(group, fScale) {
- this.updateGroupLayers(group.groups[i], fScale);
- this.updateLayer(group.layers[i], fScale);
- updateLayer: function(layer, fScale) {
- var checkbox = layer.oMap.bSingleTile ? this.bIncludeVisToggle : false;
- if (!layer.displayInLegend || !layer.legend) {
- return;
- var range = layer.getScaleRange(fScale);
- if (range == layer.legend.currentRange && layer.legend.treeItem) {
- return;
- layer.legend.currentRange = range;
- if (range != null) {
- if (range.styles.length > 1) {
- //tree item needs to be a folder
- if (!layer.legend.treeItem) {
- layer.legend.treeItem = this.createFolderItem(layer);
- OpenLayers.Event.observe(layer.legend.treeItem.checkBox, 'click', OpenLayers.Function.bind(this.stateChanged, this, layer));
- layer.parentGroup.legend.treeItem.append(layer.legend.treeItem);
- } else if (layer.legend.treeItem instanceof Jx.TreeItem) {
- this.clearTreeItem(layer);
- } else {
- while(layer.legend.treeItem.nodes.length > 0) {
- layer.legend.treeItem.remove(layer.legend.treeItem.nodes[0]);
- for (var i=0; i<range.styles.length; i++) {
- var item = this.createTreeItem(layer,
- range.styles[i], fScale, false);
- layer.legend.treeItem.append(item);
- } else {
- var style = range.styles[0];
- if (style && !style.legendLabel) {
- style.legendLabel = layer.legendLabel;
- layer.legend.treeItem = this.createTreeItem(layer, style, fScale, checkbox);
- if (checkbox) {
- } else if (layer.legend.treeItem instanceof Jx.TreeFolder) {
- if (checkbox) {
- } else {
- if (range.styles.length > 0) {
- layer.legend.treeItem.domImg.style.backgroundImage = 'url('+layer.oMap.getLegendImageURL(fScale, layer, range.styles[0])+')' ;
- $(layer.legend.treeItem.domObj).removeClass('jxDisabled');
- } else {
- $(layer.legend.treeItem.domObj).addClass('jxDisabled');
- if (checkbox) {
- layer.legend.treeItem.checkBox.checked = layer.visible?true:false;
- if (layer.layerTypes[0] == 4 || range.styles.length > 0) {
- layer.legend.treeItem.checkBox.disabled = false;
- } else {
- layer.legend.treeItem.checkBox.disabled = true;
- } else {
- if (this.hideInvisibleLayers) {
- if (layer.legend.treeItem) {
- layer.parentGroup.legend.treeItem.remove(layer.legend.treeItem);
- layer.legend.treeItem = null;
- } else {
- var newTreeItem = this.createTreeItem(layer, {legendLabel: layer.legendLabel}, null, checkbox);
- if (checkbox) {
- OpenLayers.Event.observe(newTreeItem.checkBox, 'click', OpenLayers.Function.bind(this.stateChanged, this, layer));
- if (checkbox) layer.legend.treeItem.checkBox.disabled = true;
- layer.parentGroup.legend.treeItem.replace(newTreeItem, layer.legend.treeItem);
- layer.legend.treeItem.finalize();
- } else {
- layer.parentGroup.legend.treeItem.append(newTreeItem);
- layer.legend.treeItem = newTreeItem;
- layer.legend.treeItem.domObj.store('data', layer);
+ this.update();
- createFolderItem: function(layer) {
- var opt = {
- label: layer.legendLabel == '' ? ' ' : layer.legendLabel,
- isOpen: layer.expandInLegend,
- 'class':'fusionLegendItemCheckbox',
- // image overrides
- image: this.imgLayerThemeIcon
- var folder = new Jx.TreeFolder(opt);
- folder.options.contextMenu.add(
- onClick: OpenLayers.Function.bind(this.collapseBranch, this, folder)
- onClick: OpenLayers.Function.bind(this.expandBranch, this, folder)
- var layerInfo = layer.oMap.getLayerInfoUrl(layer.layerName);
- if (layerInfo) {
- a.href = layerInfo;
- if (layerInfo.indexOf('javascript:') < 0) {
- Jx.addToImgQueue({element:img, src:this.imgLayerInfoIcon});
- img.border = 0;
- folder.domObj.insertBefore(a, folder.domObj.childNodes[4]);
+ renderGroup: function(group) {
+ if (!group.legend) {
+ group.legend = {};
+ group.legend.treeItem = this.oRoot;
- folder.addEvent('click', OpenLayers.Function.bind(this.selectionChanged, this));
- return folder;
- createTreeItem: function(layer, style, scale, bCheckBox) {
- var opt = {};
- opt.statusIsDefault = layer.statusDefault;
- if (bCheckBox ) {
- opt.label = layer.legendLabel == '' ? ' ' : layer.legendLabel;
- opt.draw = this.renderItemCheckBox;
- } else {
- opt.label = style.legendLabel == '' ? ' ' : style.legendLabel;
- opt.draw = this.renderItem;
+ for (var i = 0; i < group.groups.length; i++) {
+ this.processMapGroup(group.groups[i], this.oRoot);
- if (!style) {
- opt.image = this.imgDisabledLayerIcon;
- opt.enabled = false;
- } else {
- var defaultIcon = this.imgDisabledLayerIcon;
- if (layer.layerTypes[0] == 4) {
- if (style.staticIcon == Fusion.Constant.LAYER_DWF_TYPE) {
- defaultIcon = this.imgLayerDWFIcon;
- } else {
- defaultIcon = this.imgLayerRasterIcon;
- if (style.iconOpt && style.iconOpt.url) {
- opt.image = style.iconOpt.url;
- } else {
- opt.image = layer.oMap.getLegendImageURL(scale, layer, style, defaultIcon);
+ for (var i = 0; i < group.layers.length; i++) {
- opt.contextMenu = this.getContextMenu();
- var item = new Jx.TreeItem(opt);
- if (style && style.iconX >= 0 && style.iconY >= 0) {
- item.domImg;
- item.domImg.style.backgroundImage = 'url('+opt.image+')';
- item.domImg.src = Jx.aPixel.src;
- item.domImg.style.backgroundPosition = (-1*style.iconX) + 'px ' + (-1*style.iconY) + 'px';
- if (style.iconOpt.width) {
- item.domImg.style.width = style.iconOpt.width + 'px';
- if (style.iconOpt.height) {
- item.domImg.style.height = style.iconOpt.height + 'px';
- if (bCheckBox) {
- //item.domObj.insertBefore(layer.legend.checkBox, item.domObj.childNodes[1]);
- /* only need to add layer info if it has a check box too */
- if (layerInfo) {
- Jx.addToImgQueue({element:img, src: this.imgLayerInfoIcon});
- img.border = 0;
- item.domObj.insertBefore(a, item.domObj.childNodes[4]);
- item.addEvent('click', OpenLayers.Function.bind(this.selectionChanged, this));
- return item;
- clearTreeItem: function(layer) {
- if (layer.legend.treeItem && layer.legend.treeItem.owner) {
- layer.legend.treeItem.domObj.store('data', null);
- layer.legend.treeItem.owner.remove(layer.legend.treeItem);
- stateChanged: function(obj, event) {
- if (obj.legend && obj.legend.treeItem.checkBox) {
- if (obj.legend.treeItem.checkBox.checked) {
- obj.show();
- } else {
- obj.hide();
- OpenLayers.Event.stop(event, true);
- renderFolder: function() {
- var domA = new Element('a',{
- 'class':this.options['class'],
- href:'javascript:void(0)',
- events: {
- click: this.selected.bindWithEvent(this),
- dblclick: this.selected.bindWithEvent(this),
- contextmenu: this.options.contextMenu.show.bindWithEvent(this.options.contextMenu)
- this.checkBox = document.createElement('input');
- this.checkBox.type = 'checkbox';
- this.domImg = document.createElement('img');
- this.domImg.className = 'jxTreeIcon ' + (this.options.imageClass ? this.options.imageClass : '');
- this.domImg.src = Jx.aPixel.src;
- if (this.options.image) {
- this.domImg.style.backgroundImage = 'url('+this.options.image+')';
- var domLabel = new Element('span',{
- 'class': 'fusionLegendLabel',
- html: this.options.label
- domA.appendChild(this.checkBox);
- domA.appendChild(this.domImg);
- domA.appendChild(domLabel);
- this.itemLabelobj = domA;
- return domA;
- renderItem: function() {
- var domA = new Element('a', {
- 'class': 'fusionLegendItem',
- href: 'javascript:void(0)',
- events: {
- return domA;
- renderItemCheckBox: function() {
- 'class': 'fusionLegendItemCheckbox',
- 'href':'javascript:void(0);',
- events: {
- /* layer is set to "status default" set checkbox to checked , disabled , read only*/
- if(this.options.statusIsDefault){
- this.checkBox.checked = true;
- this.checkBox.disabled = true;
- this.checkBox.readOnly = true;
- return domA;
+ processMapGroup: function(group, folder) {
+ if (group.displayInLegend) {
+ /* make a 'namespace' on the group object to store legend-related info */
+ var opt = {
+ label: group.legendLabel,
+ open: group.expandInLegend,
+ group.legend.treeItem = new Jx.TreeFolder(opt);
+ group.legend.treeItem.domObj.store('data', group);
+ group.legend.treeItem.options.contextMenu.add(
+ onClick: OpenLayers.Function.bind(this.collapseBranch, this, group.legend.treeItem)
+ onClick: OpenLayers.Function.bind(this.expandBranch, this, group.legend.treeItem)
+ folder.append(group.legend.treeItem);
+ group.legend.treeItem.checkBox.checked = group.visible?true:false;
+ OpenLayers.Event.observe(group.legend.treeItem.checkBox, 'click', OpenLayers.Function.bind(this.stateChanged, this, group));
+ var groupInfo = group.oMap.getGroupInfoUrl(group.groupName);
+ if (groupInfo) {
+ var a = document.createElement('a');
+ a.href = groupInfo;
+ if (groupInfo.indexOf('javascript:') < 0) {
+ a.target = '_blank';
+ var img = document.createElement('img');
+ Jx.addToImgQueue({element:img, src: this.imgGroupInfoIcon});
+ img.border = 0;
+ a.appendChild(img);
+ group.legend.treeItem.domObj.insertBefore(a, group.legend.treeItem.domObj.childNodes[4]);
+ if (this.oSelectionListener) {
+ group.legend.treeItem.addEvent('click', OpenLayers.Function.bind(this.selectionChanged, this));
+ for (var i=0; i<group.groups.length; i++) {
+ this.processMapGroup(group.groups[i], group.legend.treeItem);
+ for (var i=0; i<group.layers.length; i++) {
+ this.processMapLayer(group.layers[i], group.legend.treeItem);
+ processMapLayer: function(layer, folder) {
+ /* make a 'namespace' on the layer object to store legend-related info */
+ layer.legend = {};
+ layer.legend.parentItem = folder;
+ layer.legend.currentRange = null;
+ layer.oMap.registerForEvent(Fusion.Event.LAYER_PROPERTY_CHANGED, OpenLayers.Function.bind(this.layerPropertyChanged, this));
+ layerPropertyChanged: function(eventID, layer) {
+ layer.legend.treeItem.checkBox.checked = layer.isVisible();
+ update: function() {
+ if (this.bIsDrawn) {
+ window.setTimeout(OpenLayers.Function.bind(this._update, this), 1);
+ * update the tree when the map scale changes
+ _update: function() {
+ var map = this.getMap();
+ var currentScale = map.getScale();
+ for (var i=0; i<map.layerRoot.groups.length; i++) {
+ this.updateGroupLayers(map.layerRoot.groups[i], currentScale);
+ for (var i=0; i<map.layerRoot.layers.length; i++) {
+ this.updateLayer(map.layerRoot.layers[i], currentScale);
+ * remove the dom objects representing the legend layers and groups
+ clear: function() {
+ while (this.oRoot.nodes.length > 0) {
+ this.oRoot.remove(this.oRoot.nodes[0]);
+ selectionChanged: function(o) {
+ if (this.currentNode) {
+ //console.log(this.currentNode);
+ $(this.currentNode.domObj.childNodes[1]).removeClass('jxTreeItemSelected');
+ this.currentNode = o;
+ $(this.currentNode.domObj.childNodes[1]).addClass('jxTreeItemSelected');
+ var data = o.domObj.retrieve('data');
+ if (data instanceof Fusion.Layers.Group) {
+ this.getMap().setActiveLayer(null);
+ } else {
+ this.getMap().setActiveLayer(data);
+ updateGroupLayers: function(group, fScale) {
+ this.updateGroupLayers(group.groups[i], fScale);
+ this.updateLayer(group.layers[i], fScale);
+ updateLayer: function(layer, fScale) {
+ var checkbox = layer.oMap.bSingleTile ? this.bIncludeVisToggle : false;
+ if (!layer.displayInLegend || !layer.legend) {
+ return;
+ var range = layer.getScaleRange(fScale);
+ if (range == layer.legend.currentRange && layer.legend.treeItem) {
+ return;
+ layer.legend.currentRange = range;
+ if (range != null) {
+ if (range.styles.length > 1) {
+ //tree item needs to be a folder
+ if (!layer.legend.treeItem) {
+ layer.legend.treeItem = this.createFolderItem(layer);
+ OpenLayers.Event.observe(layer.legend.treeItem.checkBox, 'click', OpenLayers.Function.bind(this.stateChanged, this, layer));
+ layer.parentGroup.legend.treeItem.append(layer.legend.treeItem);
+ } else if (layer.legend.treeItem instanceof Jx.TreeItem) {
+ this.clearTreeItem(layer);
+ } else {
+ while(layer.legend.treeItem.nodes.length > 0) {
+ layer.legend.treeItem.remove(layer.legend.treeItem.nodes[0]);
+ for (var i=0; i<range.styles.length; i++) {
+ var item = this.createTreeItem(layer,
+ range.styles[i], fScale, false);
+ layer.legend.treeItem.append(item);
+ } else {
+ var style = range.styles[0];
+ if (style && !style.legendLabel) {
+ style.legendLabel = layer.legendLabel;
+ layer.legend.treeItem = this.createTreeItem(layer, style, fScale, checkbox);
+ if (checkbox) {
+ } else if (layer.legend.treeItem instanceof Jx.TreeFolder) {
+ if (checkbox) {
+ } else {
+ if (range.styles.length > 0) {
+ layer.legend.treeItem.domImg.style.backgroundImage = 'url('+layer.oMap.getLegendImageURL(fScale, layer, range.styles[0])+')';
+ layer.legend.treeItem.domImg.style.backgroundPosition = '0px 0px';
+ $(layer.legend.treeItem.domObj).removeClass('jxDisabled');
+ } else {
+ $(layer.legend.treeItem.domObj).addClass('jxDisabled');
+ if (checkbox) {
+ layer.legend.treeItem.checkBox.checked = layer.visible?true:false;
+ if (layer.layerTypes[0] == 4 || range.styles.length > 0) {
+ layer.legend.treeItem.checkBox.disabled = false;
+ } else {
+ layer.legend.treeItem.checkBox.disabled = true;
+ } else {
+ if (this.hideInvisibleLayers) {
+ if (layer.legend.treeItem) {
+ layer.parentGroup.legend.treeItem.remove(layer.legend.treeItem);
+ layer.legend.treeItem = null;
+ } else {
+ var newTreeItem = this.createTreeItem(layer, {legendLabel: layer.legendLabel}, null, checkbox);
+ if (checkbox) {
+ OpenLayers.Event.observe(newTreeItem.checkBox, 'click', OpenLayers.Function.bind(this.stateChanged, this, layer));
+ if (checkbox) layer.legend.treeItem.checkBox.disabled = true;
+ layer.parentGroup.legend.treeItem.replace(newTreeItem, layer.legend.treeItem);
+ layer.legend.treeItem.finalize();
+ } else {
+ layer.parentGroup.legend.treeItem.append(newTreeItem);
+ layer.legend.treeItem = newTreeItem;
+ layer.legend.treeItem.domObj.store('data', layer);
+ createFolderItem: function(layer) {
+ var opt = {
+ label: layer.legendLabel == '' ? ' ' : layer.legendLabel,
+ isOpen: layer.expandInLegend,
+ 'class':'fusionLegendItemCheckbox',
+ // image overrides
+ image: this.imgLayerThemeIcon
+ var folder = new Jx.TreeFolder(opt);
+ folder.options.contextMenu.add(
+ onClick: OpenLayers.Function.bind(this.collapseBranch, this, folder)
+ onClick: OpenLayers.Function.bind(this.expandBranch, this, folder)
+ var layerInfo = layer.oMap.getLayerInfoUrl(layer.layerName);
+ if (layerInfo) {
+ a.href = layerInfo;
+ if (layerInfo.indexOf('javascript:') < 0) {
+ Jx.addToImgQueue({element:img, src:this.imgLayerInfoIcon});
+ img.border = 0;
+ folder.domObj.insertBefore(a, folder.domObj.childNodes[4]);
+ folder.addEvent('click', OpenLayers.Function.bind(this.selectionChanged, this));
+ return folder;
+ createTreeItem: function(layer, style, scale, bCheckBox) {
+ var opt = {};
+ opt.statusIsDefault = layer.statusDefault;
+ if (bCheckBox ) {
+ opt.label = layer.legendLabel == '' ? ' ' : layer.legendLabel;
+ opt.draw = this.renderItemCheckBox;
+ } else {
+ opt.label = style.legendLabel == '' ? ' ' : style.legendLabel;
+ opt.draw = this.renderItem;
+ if (!style) {
+ opt.image = this.imgDisabledLayerIcon;
+ opt.enabled = false;
+ } else {
+ var defaultIcon = this.imgDisabledLayerIcon;
+ if (layer.layerTypes[0] == 4) {
+ if (style.staticIcon == Fusion.Constant.LAYER_DWF_TYPE) {
+ defaultIcon = this.imgLayerDWFIcon;
+ } else {
+ defaultIcon = this.imgLayerRasterIcon;
+ if (style.iconOpt && style.iconOpt.url) {
+ opt.image = style.iconOpt.url;
+ } else {
+ opt.image = layer.oMap.getLegendImageURL(scale, layer, style, defaultIcon);
+ opt.contextMenu = this.getContextMenu();
+ var item = new Jx.TreeItem(opt);
+ if (style && style.iconX >= 0 && style.iconY >= 0) {
+ item.domImg;
+ item.domImg.style.backgroundImage = 'url('+opt.image+')';
+ item.domImg.src = Jx.aPixel.src;
+ item.domImg.style.backgroundPosition = (-1*style.iconX) + 'px ' + (-1*style.iconY) + 'px';
+ if (style.iconOpt.width) {
+ item.domImg.style.width = style.iconOpt.width + 'px';
+ if (style.iconOpt.height) {
+ item.domImg.style.height = style.iconOpt.height + 'px';
+ if (bCheckBox) {
+ //item.domObj.insertBefore(layer.legend.checkBox, item.domObj.childNodes[1]);
+ /* only need to add layer info if it has a check box too */
+ if (layerInfo) {
+ Jx.addToImgQueue({element:img, src: this.imgLayerInfoIcon});
+ img.border = 0;
+ item.domObj.insertBefore(a, item.domObj.childNodes[4]);
+ item.addEvent('click', OpenLayers.Function.bind(this.selectionChanged, this));
+ return item;
+ clearTreeItem: function(layer) {
+ if (layer.legend.treeItem && layer.legend.treeItem.owner) {
+ layer.legend.treeItem.domObj.store('data', null);
+ layer.legend.treeItem.owner.remove(layer.legend.treeItem);
+ stateChanged: function(obj, event) {
+ if (obj.legend && obj.legend.treeItem.checkBox) {
+ if (obj.legend.treeItem.checkBox.checked) {
+ obj.show();
+ } else {
+ obj.hide();
+ OpenLayers.Event.stop(event, true);
+ renderFolder: function() {
+ var domA = new Element('a',{
+ 'class':this.options['class'],
+ href:'javascript:void(0)',
+ events: {
+ click: this.selected.bindWithEvent(this),
+ dblclick: this.selected.bindWithEvent(this),
+ contextmenu: this.options.contextMenu.show.bindWithEvent(this.options.contextMenu)
+ this.checkBox = document.createElement('input');
+ this.checkBox.type = 'checkbox';
+ this.domImg = document.createElement('img');
+ this.domImg.className = 'jxTreeIcon ' + (this.options.imageClass ? this.options.imageClass : '');
+ this.domImg.src = Jx.aPixel.src;
+ if (this.options.image) {
+ this.domImg.style.backgroundImage = 'url('+this.options.image+')';
+ var domLabel = new Element('span',{
+ 'class': 'fusionLegendLabel',
+ html: this.options.label
+ domA.appendChild(this.checkBox);
+ domA.appendChild(this.domImg);
+ domA.appendChild(domLabel);
+ this.itemLabelobj = domA;
+ return domA;
+ renderItem: function() {
+ var domA = new Element('a', {
+ 'class': 'fusionLegendItem',
+ href: 'javascript:void(0)',
+ events: {
+ return domA;
+ renderItemCheckBox: function() {
+ 'class': 'fusionLegendItemCheckbox',
+ 'href':'javascript:void(0);',
+ events: {
+ /* layer is set to "status default" set checkbox to checked , disabled , read only*/
+ if(this.options.statusIsDefault){
+ this.checkBox.checked = true;
+ this.checkBox.disabled = true;
+ this.checkBox.readOnly = true;
+ return domA;
Property changes on: trunk/widgets/Legend.js
___________________________________________________________________
Deleted: svn:eol-style
- native
More information about the fusion-commits
