[fusion-commits] r1982 - in sandbox/jxlib-3.0: . layers/Generic lib
widgets widgets/About widgets/Help widgets/Print
widgets/Query widgets/Query/classes widgets/TaskPane
widgets/Theme/classes
svn_fusion at osgeo.org
Tue Nov 17 11:48:54 EST 2009
Author: pagameba
Date: 2009-11-17 11:48:54 -0500 (Tue, 17 Nov 2009)
New Revision: 1982
sandbox/jxlib-3.0/
sandbox/jxlib-3.0/layers/Generic/Generic.js
sandbox/jxlib-3.0/lib/fusion.js
sandbox/jxlib-3.0/widgets/About/About.html
sandbox/jxlib-3.0/widgets/Help/Help.html
sandbox/jxlib-3.0/widgets/Legend.js
sandbox/jxlib-3.0/widgets/Print/Print.html
sandbox/jxlib-3.0/widgets/Query/classes/query.php
sandbox/jxlib-3.0/widgets/Query/querymain.php
sandbox/jxlib-3.0/widgets/TaskPane/TaskPane.html
sandbox/jxlib-3.0/widgets/Theme/classes/theme.php
sync with trunk, fix small legend issue with themed layers
Property changes on: sandbox/jxlib-3.0
___________________________________________________________________
Modified: svn:mergeinfo
- /trunk:1958-1971
+ /trunk:1958-1971,1973-1980
Modified: sandbox/jxlib-3.0/layers/Generic/Generic.js
--- sandbox/jxlib-3.0/layers/Generic/Generic.js 2009-11-17 16:47:42 UTC (rev 1981)
+++ sandbox/jxlib-3.0/layers/Generic/Generic.js 2009-11-17 16:48:54 UTC (rev 1982)
@@ -103,20 +103,32 @@
this.mapTag.layerOptions.type = G_SATELLITE_MAP;
break;
case 'G_NORMAL_MAP':
+ this.mapTag.layerOptions.type = G_NORMAL_MAP;
default:
- this.mapTag.layerOptions.type = G_NORMAL_MAP;
+ // For the re-loaded Google layers
+ if(this.mapTag.layerOptions.type == G_PHYSICAL_MAP)
+ this.mapTag.layerOptions.type = G_PHYSICAL_MAP;
+ else if(this.mapTag.layerOptions.type == G_HYBRID_MAP)
+ this.mapTag.layerOptions.type = G_HYBRID_MAP;
+ else if(this.mapTag.layerOptions.type == G_SATELLITE_MAP)
+ this.mapTag.layerOptions.type = G_SATELLITE_MAP;
+ else
break;
break;
case 'VirtualEarth':
switch (this.mapTag.layerOptions.type) { //VE layer types are enumerated values
case 'Aerial': //defined in VEMapStyle from the VE api
+ case 'a':
this.mapTag.layerOptions.type = VEMapStyle.Aerial;
break;
case 'Shaded':
+ case 's':
this.mapTag.layerOptions.type = VEMapStyle.Shaded;
break;
case 'Hybrid':
+ case 'h':
this.mapTag.layerOptions.type = VEMapStyle.Hybrid;
break;
default:
@@ -127,12 +139,15 @@
case 'Yahoo':
switch (this.mapTag.layerOptions.type) { //Yahoo is similar to google
case 'YAHOO_MAP_SAT': //defined by YMap, not a string
+ case 'YAHOO_SAT':
this.mapTag.layerOptions.type = YAHOO_MAP_SAT;
break;
case 'YAHOO_MAP_HYB':
+ case 'YAHOO_HYB':
this.mapTag.layerOptions.type = YAHOO_MAP_HYB;
break;
case 'YAHOO_MAP_REG':
+ case "YAHOO_REG":
default:
this.mapTag.layerOptions.type = YAHOO_MAP_REG;
break;
Modified: sandbox/jxlib-3.0/lib/fusion.js
--- sandbox/jxlib-3.0/lib/fusion.js 2009-11-17 16:47:42 UTC (rev 1981)
+++ sandbox/jxlib-3.0/lib/fusion.js 2009-11-17 16:48:54 UTC (rev 1982)
@@ -1215,9 +1215,9 @@
var appDefUrl = Fusion.getQueryParam('ApplicationDefinition');
- if(appDefUrl &&
- (appDefUrl.indexOf('Library://') == 0 ||
- appDefUrl.indexOf('Session://') == 0)){
+ if(appDefUrl && (
+ appDefUrl.indexOf('Library') == 0 ||
+ appDefUrl.indexOf('Session') == 0)){
createSessionId();
var xhr = new getXmlHttpRequest();
var mapAgentUrl = getAgentUrl();
Modified: sandbox/jxlib-3.0/widgets/About/About.html
--- sandbox/jxlib-3.0/widgets/About/About.html 2009-11-17 16:47:42 UTC (rev 1981)
+++ sandbox/jxlib-3.0/widgets/About/About.html 2009-11-17 16:48:54 UTC (rev 1982)
@@ -1,4 +1,4 @@
-<html>
+<html>
<head>
<title>About Fusion</title>
</head>
Modified: sandbox/jxlib-3.0/widgets/Help/Help.html
--- sandbox/jxlib-3.0/widgets/Help/Help.html 2009-11-17 16:47:42 UTC (rev 1981)
+++ sandbox/jxlib-3.0/widgets/Help/Help.html 2009-11-17 16:48:54 UTC (rev 1982)
@@ -1,4 +1,4 @@
-<html>
+<html>
<head>
<title></title>
</head>
Modified: sandbox/jxlib-3.0/widgets/Legend.js
--- sandbox/jxlib-3.0/widgets/Legend.js 2009-11-17 16:47:42 UTC (rev 1981)
+++ sandbox/jxlib-3.0/widgets/Legend.js 2009-11-17 16:48:54 UTC (rev 1982)
@@ -769,6 +769,7 @@
domIcon: 'jxTreeIcon',
domLabel: 'jxTreeLabel',
domTree: 'jxTree',
+ checkbox: 'fusionLegendCheckboxInput',
layerInfo: 'fusionLayerInfo',
layerInfoIcon: 'fusionLayerInfoIcon',
groupInfo: 'fusionGroupInfo',
Modified: sandbox/jxlib-3.0/widgets/Print/Print.html
--- sandbox/jxlib-3.0/widgets/Print/Print.html 2009-11-17 16:47:42 UTC (rev 1981)
+++ sandbox/jxlib-3.0/widgets/Print/Print.html 2009-11-17 16:48:54 UTC (rev 1982)
@@ -1,4 +1,4 @@
-<div class="PrintDialogForm">
+<div class="PrintDialogForm">
<fieldset class="PrintDialogOptions">
<legend>Options</legend>
<label class="block" for="dialogPrintShowtitle"><input name="dialogPrintShowtitle" id="dialogPrintShowtitle" type="checkbox" value="showtitle" checked>
Modified: sandbox/jxlib-3.0/widgets/Query/classes/query.php
--- sandbox/jxlib-3.0/widgets/Query/classes/query.php 2009-11-17 16:47:42 UTC (rev 1981)
+++ sandbox/jxlib-3.0/widgets/Query/classes/query.php 2009-11-17 16:48:54 UTC (rev 1982)
@@ -209,8 +209,9 @@
$featureService = $this->site->CreateService(MgServiceType::FeatureService);
$resId = new MgResourceIdentifier($layer->GetFeatureSourceId());
$featureClass = $layer->GetFeatureClassName();
+ $filter = $layer->GetFilter();
$featureGeometry = $layer->GetFeatureGeometryName();
// Initialize the coordinate system transform
$schemaAndClass = explode(":", $featureClass);
@@ -240,6 +241,7 @@
$queryMax = (int) $this->args['QUERYMAX'];
$queryOptions = new MgFeatureQueryOptions();
+ $propertyFilter = '';
if ($this->args['USEPROPERTYFILTER'] == 'true')
$propertyFilter = $this->args['PROPERTYNAME'];
@@ -247,10 +249,18 @@
$propertyFilter .= sprintf($this->strExpressions[$this->args['OPERATOR']], $this->args['VALUE']);
else
$propertyFilter .= sprintf($this->numExpressions[$this->args['OPERATOR']], $this->args['VALUE']);
+ if($filter != '')
+ $propertyFilter = $propertyFilter . ' AND (' . $filter . ')';
+ else
+ if($filter != '')
+ $propertyFilter = $filter;
+ if($propertyFilter != '')
$queryOptions->SetFilter($propertyFilter);
if ($this->args['USESPATIALFILTER'] == 'true')
$polygon = $this->CreatePolygonFromGeomText($this->args['GEOMTEXT']);
Modified: sandbox/jxlib-3.0/widgets/Query/querymain.php
--- sandbox/jxlib-3.0/widgets/Query/querymain.php 2009-11-17 16:47:42 UTC (rev 1981)
+++ sandbox/jxlib-3.0/widgets/Query/querymain.php 2009-11-17 16:48:54 UTC (rev 1982)
@@ -140,6 +140,9 @@
ToggleSpatialFilter(document.getElementById("spatialFilter").checked);
+ if(document.getElementById("spatialFilter").checked == false)
+ ClearDigitization();
function OnDigitizeRectangle()
Modified: sandbox/jxlib-3.0/widgets/TaskPane/TaskPane.html
--- sandbox/jxlib-3.0/widgets/TaskPane/TaskPane.html 2009-11-17 16:47:42 UTC (rev 1981)
+++ sandbox/jxlib-3.0/widgets/TaskPane/TaskPane.html 2009-11-17 16:48:54 UTC (rev 1982)
@@ -1,4 +1,4 @@
-<html>
+<html>
<head>
<style type="text/css">
@import url(TaskPane.css);
Modified: sandbox/jxlib-3.0/widgets/Theme/classes/theme.php
--- sandbox/jxlib-3.0/widgets/Theme/classes/theme.php 2009-11-17 16:47:42 UTC (rev 1981)
+++ sandbox/jxlib-3.0/widgets/Theme/classes/theme.php 2009-11-17 16:48:54 UTC (rev 1982)
@@ -231,7 +231,7 @@
$vectorScaleRangecElement = $nodeList->item($this->args['SCALERANGEINDEX']);
$areaTypeStyle = $vectorScaleRangecElement->getElementsByTagName('AreaTypeStyle')->item(0);
// Remove any existing <AreaRule> elements.
$areaRuleList = $areaTypeStyle->getElementsByTagName('AreaRule');
@@ -241,6 +241,11 @@
$areaTypeStyle->removeChild($areaRuleList->item(0));
+ $hasChild = $areaTypeStyle->hasChildNodes();
+ if($hasChild)
+ $element = $areaTypeStyle->childNodes->item(0);
// Now create the new <AreaRule> elements.
@@ -255,7 +260,7 @@
$aggregateOptions->AddFeatureProperty($this->args['PROPERTYNAME']);
$aggregateOptions->SelectDistinct(true);
- $dataReader = $featureService->SelectAggregate($resId, $layer->GetFeatureClassName(), $aggregateOptions);
+ $dataReader = $featureService->SelectAggregate($resId, $layer->GetFeatureClassName(), $aggregateOptions);
while ($dataReader->ReadNext())
$value = $this->GetFeaturePropertyValue($dataReader, $this->args['PROPERTYNAME']);
@@ -274,7 +279,14 @@
$areaDoc = DOMDocument::loadXML($areaRuleXML);
$areaNode = $doc->importNode($areaDoc->documentElement, true);
- $areaTypeStyle->appendChild($areaNode);
+ if($hasChild)
+ $areaTypeStyle->insertBefore($areaNode, $element);
+ else
+ $areaTypeStyle->appendChild($areaNode);
$portion += $increment;
@@ -311,7 +323,14 @@
+ if($hasChild)
+ else
More information about the fusion-commits
