[fusion-commits] r1983 - trunk/layers/Generic
svn_fusion at osgeo.org
Wed Nov 18 11:08:27 EST 2009
Author: chrisclaydon
Date: 2009-11-18 11:08:27 -0500 (Wed, 18 Nov 2009)
New Revision: 1983
trunk/layers/Generic/Generic.js
Fixes #330 "Theme doesn't work on the map with commercial layers" Submitted on behalf or Arthur Liu.
Modified: trunk/layers/Generic/Generic.js
--- trunk/layers/Generic/Generic.js 2009-11-17 16:48:54 UTC (rev 1982)
+++ trunk/layers/Generic/Generic.js 2009-11-18 16:08:27 UTC (rev 1983)
@@ -88,6 +88,7 @@
this.oLayerOL.events.unregister("loadend", this, this.loadEnd);
this.oLayerOL.events.unregister("loadcancel", this, this.loadEnd);
this.oLayerOL.destroy();
+ this.oLayerOL = null;
switch (this.layerType) {
@@ -103,32 +104,32 @@
this.mapTag.layerOptions.type = G_SATELLITE_MAP;
break;
case 'G_NORMAL_MAP':
- this.mapTag.layerOptions.type = G_NORMAL_MAP;
+ this.mapTag.layerOptions.type = G_NORMAL_MAP;
default:
- // For the re-loaded Google layers
- if(this.mapTag.layerOptions.type == G_PHYSICAL_MAP)
- this.mapTag.layerOptions.type = G_PHYSICAL_MAP;
- else if(this.mapTag.layerOptions.type == G_HYBRID_MAP)
- this.mapTag.layerOptions.type = G_HYBRID_MAP;
- else if(this.mapTag.layerOptions.type == G_SATELLITE_MAP)
- this.mapTag.layerOptions.type = G_SATELLITE_MAP;
- else
+ // For the re-loaded Google layers
+ if(this.mapTag.layerOptions.type == G_PHYSICAL_MAP)
+ this.mapTag.layerOptions.type = G_PHYSICAL_MAP;
+ else if(this.mapTag.layerOptions.type == G_HYBRID_MAP)
+ this.mapTag.layerOptions.type = G_HYBRID_MAP;
+ else if(this.mapTag.layerOptions.type == G_SATELLITE_MAP)
+ this.mapTag.layerOptions.type = G_SATELLITE_MAP;
+ else
break;
break;
case 'VirtualEarth':
switch (this.mapTag.layerOptions.type) { //VE layer types are enumerated values
case 'Aerial': //defined in VEMapStyle from the VE api
- case 'a':
+ case 'a':
this.mapTag.layerOptions.type = VEMapStyle.Aerial;
break;
case 'Shaded':
- case 's':
+ case 's':
this.mapTag.layerOptions.type = VEMapStyle.Shaded;
break;
case 'Hybrid':
- case 'h':
+ case 'h':
this.mapTag.layerOptions.type = VEMapStyle.Hybrid;
break;
default:
@@ -139,15 +140,15 @@
case 'Yahoo':
switch (this.mapTag.layerOptions.type) { //Yahoo is similar to google
case 'YAHOO_MAP_SAT': //defined by YMap, not a string
- case 'YAHOO_SAT':
+ case 'YAHOO_SAT':
this.mapTag.layerOptions.type = YAHOO_MAP_SAT;
break;
case 'YAHOO_MAP_HYB':
- case 'YAHOO_HYB':
+ case 'YAHOO_HYB':
this.mapTag.layerOptions.type = YAHOO_MAP_HYB;
break;
case 'YAHOO_MAP_REG':
- case "YAHOO_REG":
+ case "YAHOO_REG":
default:
this.mapTag.layerOptions.type = YAHOO_MAP_REG;
break;
More information about the fusion-commits
