[fusion-commits] r1915 - trunk/text
    svn_fusion at osgeo.org
    Thu Sep 24 16:28:33 EDT 2009
Author: pagameba
Date: 2009-09-24 16:28:32 -0400 (Thu, 24 Sep 2009)
New Revision: 1915
Added:
   trunk/text/en.json
   trunk/text/en.php
   trunk/text/fr.json
   trunk/text/fr.php
Removed:
   trunk/text/en/
   trunk/text/fr/
re #138, renaming string files part 1
Copied: trunk/text/en.json (from rev 1907, trunk/text/en/strings.json)
--- trunk/text/en.json	                        (rev 0)
+++ trunk/text/en.json	2009-09-24 20:28:32 UTC (rev 1915)
@@ -0,0 +1,54 @@
+Fusion.Strings.en = {
+'scriptFailed': 'failed to load script: ${script}',
+'configParseError': 'Error parsing fusion configuration file, initialization aborted',
+'configLoadError': 'Error loading fusion configuration file, initialization aborted.' +
+                  'Make sure that you have copied config_dist.json to config.json ' +
+                  'and have configured the settings for your system',
+'ajaxError': 'Exception occurred in AJAX callback.\nMessage: ${exception}\nLocation: ${filename} (${line})\nResponse: ${response}',
+'importFailed': 'failed to import stylesheet: ${url}',
+'registerEventError': 'Error registering eventID, invalid (empty) eventID.',
+'appDefLoadFailed': 'failed to load: ${script}',
+'appDefParseError': 'failed to parse ApplicationDefinition',
+'widgetSetParseError': 'failed to parse the WidgetSet',
+'fusionError': 'Fusion Error: ${type}\n${message}',
+'nullExtents': 'Map.setExtents called with null extents',
+'mapLoadError': 'Failed to load requested map:\n${error}',
+'setLayersError': "setLayers failure: ${error}",
+'printTitle': 'Printable Page ',
+'noSelection': 'No Selection',
+'selectionInfo': '${features} features selected on ${layers} layers',
+'attribute': 'Attribute',
+'value': 'Value',
+'taskHome': 'return to the task pane home',
+'prevTask': 'go to previous task executed',
+'nextTask': 'go to next task executed',
+'taskList': 'Task List',
+'taskPane': 'Task Pane',
+'imperial': 'Imperial',
+'metric': 'Metric',
+'deg': 'Degrees',
+'refresh': 'Refresh',
+'expandAll': 'Expand All',
+'expand': 'Expand',
+'collapseAll': 'Collapse All',
+'collapse': 'Collapse',
+'defaultMapTitle': 'Map',
+'legendTitle': 'Legend',
+'selectionPanelTitle': 'Selection',
+'ovmapTitle': 'Overview Map',
+'ovmapTitleShort': 'Overview',
+'taskPaneTitle': 'Tasks',
+'segment': 'Segment ${seg}',
+'calculating': 'calculating ...',
+'panWest': 'Pan West',
+'panEast': 'Pan East',
+'panSouth': 'Pan South',
+'panNorth': 'Pan North',
+'zoomOut': 'Zoom Out',
+'zoomIn': 'Zoom In',
+'printCancel': 'Cancel',
+'printGenerate': 'Generate',
+'zoomRect': 'Zoom Rectangle',
+'end': ''
Copied: trunk/text/en.php (from rev 1907, trunk/text/en/strings.php)
--- trunk/text/en.php	                        (rev 0)
+++ trunk/text/en.php	2009-09-24 20:28:32 UTC (rev 1915)
@@ -0,0 +1,243 @@
+# Web surround localized strings
+# English language
+# Important: This file must be saved with UTF-8 encoding
+# General
+# Fonts - the 6 following entries are mandatory
+ at fontWindows        = Arial
+ at fontsizeWindows    = 8pt
+ at fontLinux          = Arial
+ at fontsizeLinux      = 8pt
+ at fontMacintosh      = Arial
+ at fontsizeMacintosh  = 8pt
+# Distances
+DISTANCEMILES       = Miles
+DISTANCEKILOMETERS  = Kilometers
+DISTANCEFEET        = Feet
+DISTANCEMETERS      = Meters
+# Fill Patterns/Values
+FILLSOLID           = Solid
+FILLNET             = Net
+FILLLINE            = Line
+FILLLINE45          = Line_45
+FILLLINE90          = Line_90
+FILLLINE135         = Line_135
+FILLSQUARE          = Square
+FILLBOX             = Box
+FILLCROSS           = Cross
+FILLDASH            = Dash
+FILLDOLMIT          = Dolmit
+FILLHEX             = Hex
+FILLSACNCR          = Sacncr
+FILLSTEEL           = Steel
+# Transparency
+TRANSPARENT         = transparent
+# Line Styles/Values
+LINESOLID           = Solid
+LINEDASH            = Dash
+LINEDOT             = Dot
+LINEDASHDOT         = DashDot
+LINEDASHDOTDOT      = DashDotDot
+LINERAIL            = Rail
+LINEBORDER          = Border
+LINEDIVIDE          = Divide
+LINEFENCELINE       = FenceLine
+# Buttons
+BUTTONOK            = OK
+BUTTONDONE          = Done
+BUTTONCANCEL        = Cancel
+BUTTONREFRESH       = Refresh
+BUTTONCLOSE         = Close
+BUTTONCLEAR         = Clear
+BUTTONSAVE          = Save
+# Colors
+COLORRED            = Red
+COLORGREEN          = Green
+COLORBLUE           = Blue
+# BufferReport
+BUFFERREPORTTITLE               = Create Buffer
+BUFFERREPORTCREATED             = %s has been created.
+BUFFERREPORTUPDATED             = %s has been updated.
+BUFFERREPORTFEATURESSINGULAR    = %s buffer feature was created.
+BUFFERREPORTFEATURESPLURAL      = %s buffer features were created.
+BUFFERREPORTWARNINGSINGULAR     = <b>Warning:</b> %s layer was excluded from buffer computation because its coordinate system is incompatible with the coordinate system of the map, or because it has no coordinate system at all
+BUFFERREPORTWARNINGPLURAL       = <b>Warning:</b> %s layers were excluded from buffer computation because their coordinate systems are incompatible with the coordinate system of the map, or because they have no coordinate system at all
+BUFFERREPORTERRORTITLE          = Buffer Error
+# Buffer
+BUFFERCLASSDESCR                = Feature class for buffer layer
+BUFFERSCHEMADESCR               = Temporary buffer schema
+BUFFERDIFFARBXY                 = Cannot compute a unique buffer around features with different 'Arbitrary X-Y' coordinate systems. Please uncheck the option 'Merge buffer areas' or select only one layer
+# BufferUI
+BUFFERTITLE                     = Create a Buffer
+BUFFERSUBTITLE                  =  Buffer settings
+BUFFERINFOTEXT                  = Select features on the image.
+BUFFERDISTANCE                  = Distance around features:
+BUFFERLAYERS                    = Layers to include in the buffer:
+BUFFERNOLAYER                   = <No layer selected>
+BUFFERNAME                      = Name for the resulting buffer layer:
+BUFFERNAMETEXT                  = Buffer 1
+BUFFERMERGE                     = Merge buffer areas
+BUFFERFILLSTYLE                 =  Fill style
+BUFFERFILLPATTERN               = Fill pattern:
+BUFFERFOREGROUNDCOLOR           = Foreground color:
+BUFFERTRANSPARENCY              = Transparency:
+BUFFERBACKGROUNDCOLOR           = Background color:
+BUFFERBORDERSTYLE               =  Border style
+BUFFERBORDERLINEPATTERN         = Line pattern:
+BUFFERBORDERLINECOLOR           = Line color:
+BUFFERBORDERLINETHICKNESS       = Line thickness:
+BUFFERHELP                      = <li><p align="left">Results of the buffer are put into a new layer above the top feature layer. This buffer layer has the name you enter here.</li><li><p align="left">To create multiple buffer layers, use different buffer names.</li><li><p align="left">To hide buffer layers, turn them off.</li><li><p align="left">Buffer layers are temporary and are removed when you close the viewer.</li>
+BUFFERERRORZERODISTANCE         = Please enter a nonzero distance.
+BUFFERERRORNOLAYERNAME          = Please enter a layer name.
+BUFFERERRORNEGATIVETHICKNESS    = Please enter positive or null thickness.
+BUFFERERRORNOSELECTION          = Please select feature(s) to calculate a buffer around.
+# ColorPicker
+COLORPICKERDLGTITLE             = Select a color
+COLORPICKERTITLE                = Color palette
+COLORPICKERSUBTITLE             = Specify a color
+COLORPICKER100TRANSPARENCY      = 100%% transparency
+COLORPICKERHEXFORMAT            = Hex format
+# MeasureUI
+MEASUREDISTANCETITLE    = Measure Distance
+MEASUREAREATITLE        = Measure Area
+MEASUREBOTHTITLE        = Measure Distance And Area
+MEASUREINFO             = Click a start and end point.
+RESUME                  = Resume
+STOP                    = Stop
+CLEAR                   = Clear
+MILES                   = Miles
+KILOMETERS              = Kilometers
+MEASUREHELP             = <li>To measure multiple distances, continue clicking new points.</li><li>To finish, click "Stop".</li><li>You can pan or zoom and continue measuring by clicking "Resume".</li><li>To start over, click "Clear".</li>
+SEGMENT                 = Segment
+LENGTH                  = Length
+TOTALLENGTH             = Total Length
+TOTALAREA               = Total Area
+MEASUREERROR            = Measure Error
+# Measure
+MEASUREFEATURECLASS     = Feature class for measure layer
+MEASURESCHEMADESCR      = Temporary measure schema
+MEASUREPARTIAL          = Partial
+MEASURETOTAL            = total
+MEASURELAYER            = Measure
+# HtmlViewerAbout
+HTMLABOUTTITLE          = About %s
+HTMLABOUTTITLEBAR       = MapGuide Viewer
+HTMLABOUTSERVERTITLE    = MapGuide Server
+HTMLABOUTVIEWERTITLE    = MapGuide Viewer
+HTMLABOUTSERVERVERSION  = %s (Version %s)
+HTMLABOUTVIEWERVERSION  = %s (Version %s)
+HTMLABOUTTEXT           = <br>This product is made available subject to the terms of GNU Lesser General Public License Version 2.1 ("LGPL").  A copy of the LGPL, as well as additional copyright notices and license terms applicable to portions of this product are set forth in the <a href="../localized/license_en.htm" target="blank">license</a> file.<br><br>All trademarks and registered trademarks mentioned herein are the property of their respective owners.<br><br>Copyright © 2007 Autodesk, Inc.<br><br>
+HTMLABOUTLICENSE        = license file
+HTMLABOUTLICENSEFILE    = license_en.htm
+# LegendUI
+LEGENDLISTSEPARATOR     = ,
+# PrintablePageUi
+PRINTTITLE              = Get Printable Page
+PRINTELEMENTS           = Select the elements to include in the print layout.
+PRINTPAGETITLE          = Page title:
+PRINTLEGEND             = Legend
+PRINTNORTHARROW         = North arrow
+PRINTCREATEPAGE         = Create Page
+# PropertyCtrl
+PROPERTIESNONE          = None Selected
+PROPERTIESNAME          = Name
+PROPERTIESVALUE         = Value
+PROPERTIESITEMSEL       = Items selected: {0}
+# Search
+SEARCHDLGTITLE          = Search features
+SEARCHTITLE             = Search results
+SEARCHERROR             = Search error
+SEARCHREPORT            = Search report
+SEARCHLAYERNOTFOUND     = Layer {0} not found!
+SEARCHNOMULTIPROP       = Multi-properties identity not supported yet
+SEARCHTYYPENOTSUP       = Identity property type not supported yet ({0})
+SEARCHNOMATCHES         = No matches.
+# SearchPrompt
+SEARCHPROMPTFIND        = Find
+# SelectWithinUi
+SELECTWITHINTITLE       = Select Within
+SELECTWITHINAREAS       = Select areas on the image.
+SELECTWITHINRESTRICTION = Restrict results to selected layers:
+SELECTWITHINTEXT        = <li>If you continue to select areas on the image, click "Refresh" to update the layer list.</li><li>To finish and select all features within the highlighted areas, click "Done".</li><li>To start over, click "Clear".</li>
+# Error/Report
+REPORTTITLE             = Report
+# Legend UI
+REFRESH                 = Refresh
+EXPANDALL               = Expand
+COLLAPSEALL             = Collapse All
+DISPLAYALLINGROUP       = Display All in Group
+HIDEALLINGROUP          = Hide All in Group
+SHOWLONGTHEME           = Show Long Theme
+# Task Bar
+TASKS                   = Tasks
+# Viewer Options
+OPTIONSTITLE            = Viewer Options
+OPTIONSINFOTEXT         = Select viewing options for status bar and tool tips.
+OPTIONSDISTANCE         = Display distances in
+OPTIONSMETRIC           = Metric (Kilometers, Meters)
+OPTIONSUSENGLISH        = US/English (Miles, Feet)
+OPTIONSPOSITION         = Display cursor position in
+OPTIONSLATLON           = Latitude, Longitude (Degrees)
+OPTIONSMAPUNITS         = Map Coordinate System (X,Y)
+# AJAX Viewer
+VIEWERLAYERS            = Layers
+VIEWERPROPS             = Properties
+VIEWERPANNORTH          = Pan North
+VIEWERPANWEST           = Pan West
+VIEWERPANSOUTH          = Pan South
+VIEWERPANEAST           = Pan East
+VIEWERZOOMIN            = Zoom In
+VIEWERZOOMOUT           = Zoom Out
+VIEWERMOVESLIDER        = Drag to move slider
+VIEWERDRAGZOOM          = Drag to zoom
+ENDSEL                  = CTRL + click to end
+ENDSELSAFARI            = SHIFT + click to end
+DECIMALSEPARATOR        = .
+THOUSANDSEPARATOR       = ,
+# Main Frame
+NEEDLOGIN               = You must enter a valid login ID and password to access this site
+ALREADYINMEASURE        = Only one measure command is allowed in a web layout
+ACCESSDENIED            = Access Denied
+LATLONCURPOS            = Lat: {0}, Lon: {1}
+MAPUNITSCURPOS          = X: {0}, Y: {1}
+FEATURESSELECTED        = {0} features selected
+FEATURESELECTED         = {0} feature selected
+MI                      = mi
+FT                      = ft
+IN                      = in
+KM                      = km
+MT                      = m
+CM                      = cm
+DIGALREADYRUNNING       = Cannot execute measure: A digitization command is in progress.
+MEASALREADYRUNNING      = Cannot execute digitization: A measure is in progress.
+# Localized Icon Files
Copied: trunk/text/fr.json (from rev 1907, trunk/text/fr/strings.json)
--- trunk/text/fr.json	                        (rev 0)
+++ trunk/text/fr.json	2009-09-24 20:28:32 UTC (rev 1915)
@@ -0,0 +1,53 @@
+Fusion.Strings.fr = {
+'ajaxError': 'Exception occurred in AJAX callback.\n${exception}\nLocation: ${file} (${line}))',
+'noSelection': 'Aucun Sélection',
+'value': 'Value',
+'deg': 'Degrees',
+'selectionPanelTitle': 'Sélection',
+'panWest': 'Ouest',
+'panEast': 'Est',
+'panSouth': 'Sud',
+'panNorth': 'Nord',
+'zoomOut': 'Cliquer pour réduire',
+'zoomIn': 'Cliquer pour agrandir',
+'end': ''
Copied: trunk/text/fr.php (from rev 1907, trunk/text/fr/strings.php)
--- trunk/text/fr.php	                        (rev 0)
+++ trunk/text/fr.php	2009-09-24 20:28:32 UTC (rev 1915)
@@ -0,0 +1,240 @@
+# English language
+# General
+# Distances
+FILLSOLID           = Solid
+FILLNET             = Net
+FILLLINE            = Line
+FILLBOX             = Box
+FILLCROSS           = Cross
+FILLDASH            = Dash
+FILLHEX             = Hex
+FILLSTEEL           = Steel
+# Transparency
+LINESOLID           = Solid
+LINEDASH            = Dash
+LINEDOT             = Dot
+LINERAIL            = Rail
+# Buttons
+BUTTONOK            = OK
+BUTTONDONE          = Done
+BUTTONSAVE          = Save
+# Colors
+COLORRED            = Red
+COLORGREEN          = Green
+COLORBLUE           = Blue
+# BufferReport
+# Buffer
+# BufferUI
+# ColorPicker
+# MeasureUI
+MEASURETITLE            = Measure Distance
+RESUME                  = Resume
+STOP                    = Stop
+CLEAR                   = Clear
+MILES                   = Miles
+SEGMENT                 = Segment
+TOTAL                   = Total
+LENGTH                  = Length
+# Measure
+# HtmlViewerAbout
+# LegendUI
+# PrintablePageUi
+# PropertyCtrl
+# Search
+# SearchPrompt
+# SelectWithinUi
+# Error/Report
+# Legend UI
+REFRESH                 = Refresh
+EXPANDALL               = Expand
+# Task Bar
+TASKS                   = Tasks
+# Viewer Options
+# AJAX Viewer
+# Main Frame
+MI                      = mi
+FT                      = ft
+IN                      = in
+KM                      = km
+MT                      = m
+CM                      = cm
More information about the fusion-commits
