[fusion-commits] r2137 - sandbox/adsk/2.2gp/text
svn_fusion at osgeo.org svn_fusion at osgeo.org
Wed Apr 7 18:54:19 EDT 2010
Author: chrisclaydon
Date: 2010-04-07 18:54:19 -0400 (Wed, 07 Apr 2010)
New Revision: 2137
Removed:
   sandbox/adsk/2.2gp/text/fr
   sandbox/adsk/2.2gp/text/fr.json
Re #389 - French string resources are not properly translated and should be removed
Deleted: sandbox/adsk/2.2gp/text/fr
--- sandbox/adsk/2.2gp/text/fr	2010-04-07 21:58:02 UTC (rev 2136)
+++ sandbox/adsk/2.2gp/text/fr	2010-04-07 22:54:19 UTC (rev 2137)
@@ -1,335 +0,0 @@
-# Web surround localized strings
-# English language
-# Important: This file must be saved with UTF-8 encoding
-# General
-# Fonts - the 6 following entries are mandatory
- at fontWindows        = Arial
- at fontsizeWindows    = 8pt
- at fontLinux          = Arial
- at fontsizeLinux      = 8pt
- at fontMacintosh      = Arial
- at fontsizeMacintosh  = 8pt
-# Distances
-DISTANCEMILES       = Miles
-DISTANCEKILOMETERS  = Kilometers
-DISTANCEFEET        = Feet
-DISTANCEMETERS      = Meters
-# Fill Patterns/Values
-FILLSOLID           = Solid
-FILLNET             = Net
-FILLLINE            = Line
-FILLLINE45          = Line_45
-FILLLINE90          = Line_90
-FILLLINE135         = Line_135
-FILLSQUARE          = Square
-FILLBOX             = Box
-FILLCROSS           = Cross
-FILLDASH            = Dash
-FILLDOLMIT          = Dolmit
-FILLHEX             = Hex
-FILLSACNCR          = Sacncr
-FILLSTEEL           = Steel
-# Transparency
-TRANSPARENT         = transparent
-# Line Styles/Values
-LINESOLID           = Solid
-LINEDASH            = Dash
-LINEDOT             = Dot
-LINEDASHDOT         = DashDot
-LINEDASHDOTDOT      = DashDotDot
-LINERAIL            = Rail
-LINEBORDER          = Border
-LINEDIVIDE          = Divide
-LINEFENCELINE       = FenceLine
-# Buttons
-BUTTONOK            = OK
-BUTTONDONE          = Done
-BUTTONCANCEL        = Cancel
-BUTTONREFRESH       = Refresh
-BUTTONCLOSE         = Close
-BUTTONCLEAR         = Clear
-BUTTONSAVE          = Save
-# Colors
-COLORRED            = Red
-COLORGREEN          = Green
-COLORBLUE           = Blue
-# BufferReport
-BUFFERREPORTTITLE               = Create Buffer
-BUFFERREPORTCREATED             = %s has been created.
-BUFFERREPORTUPDATED             = %s has been updated.
-BUFFERREPORTFEATURESSINGULAR    = %s buffer feature was created.
-BUFFERREPORTFEATURESPLURAL      = %s buffer features were created.
-BUFFERREPORTWARNINGSINGULAR     = <b>Warning:</b> %s layer was excluded from buffer computation because its coordinate system is incompatible with the coordinate system of the map, or because it has no coordinate system at all
-BUFFERREPORTWARNINGPLURAL       = <b>Warning:</b> %s layers were excluded from buffer computation because their coordinate systems are incompatible with the coordinate system of the map, or because they have no coordinate system at all
-BUFFERREPORTERRORTITLE          = Buffer Error
-# Buffer
-BUFFERCLASSDESCR                = Feature class for buffer layer
-BUFFERSCHEMADESCR               = Temporary buffer schema
-BUFFERDIFFARBXY                 = Cannot compute a unique buffer around features with different 'Arbitrary X-Y' coordinate systems. Please uncheck the option 'Merge buffer areas' or select only one layer
-# BufferUI
-BUFFERTITLE                     = Create a Buffer
-BUFFERSUBTITLE                  = &nbsp;Buffer settings
-BUFFERINFOTEXT                  = Select features on the image.
-BUFFERDISTANCE                  = Distance around features:
-BUFFERLAYERS                    = Layers to include in the buffer:
-BUFFERNOLAYER                   = <No layer selected>
-BUFFERNAME                      = Name for the resulting buffer layer:
-BUFFERNAMETEXT                  = Buffer 1
-BUFFERMERGE                     = Merge buffer areas
-BUFFERFILLSTYLE                 = &nbsp;Fill style
-BUFFERFILLPATTERN               = Fill pattern:
-BUFFERFOREGROUNDCOLOR           = Foreground color:
-BUFFERTRANSPARENCY              = Transparency:
-BUFFERBACKGROUNDCOLOR           = Background color:
-BUFFERBORDERSTYLE               = &nbsp;Border style
-BUFFERBORDERLINEPATTERN         = Line pattern:
-BUFFERBORDERLINECOLOR           = Line color:
-BUFFERBORDERLINETHICKNESS       = Line thickness:
-BUFFERHELP                      = <li><p align="left">Results of the buffer are put into a new layer above the top feature layer. This buffer layer has the name you enter here.</li><li><p align="left">To create multiple buffer layers, use different buffer names.</li><li><p align="left">To hide buffer layers, turn them off.</li><li><p align="left">Buffer layers are temporary and are removed when you close the viewer.</li>
-BUFFERERRORZERODISTANCE         = Please enter a nonzero distance.
-BUFFERERRORNOLAYERNAME          = Please enter a layer name.
-BUFFERERRORNEGATIVETHICKNESS    = Please enter positive or null thickness.
-BUFFERERRORNOSELECTION          = Please select feature(s) to calculate a buffer around.
-# ColorPicker
-COLORPICKERDLGTITLE             = Select a color
-COLORPICKERTITLE                = Color palette
-COLORPICKERSUBTITLE             = Specify a color
-COLORPICKER100TRANSPARENCY      = 100%% transparency
-COLORPICKERHEXFORMAT            = Hex format
-# MeasureUI
-MEASUREDISTANCETITLE    = Measure Distance
-MEASUREAREATITLE        = Measure Area
-MEASUREBOTHTITLE        = Measure Distance And Area
-MEASUREINFO             = Click a start and end point.
-RESUME                  = Resume
-STOP                    = Stop
-CLEAR                   = Clear
-MILES                   = Miles
-KILOMETERS              = Kilometers
-MEASUREHELP             = <li>To measure multiple distances, continue clicking new points.</li><li>To finish, click &quot;Stop&quot;.</li><li>You can pan or zoom and continue measuring by clicking &quot;Resume&quot;.</li><li>To start over, click &quot;Clear&quot;.</li>
-SEGMENT                 = Segment
-TOTAL                   = Total
-LENGTH                  = Length
-TOTALLENGTH             = Total Length
-TOTALAREA               = Total Area
-MEASUREERROR            = Measure Error
-# Measure
-MEASUREFEATURECLASS     = Feature class for measure layer
-MEASURESCHEMADESCR      = Temporary measure schema
-MEASUREPARTIAL          = Partial
-MEASURETOTAL            = total
-MEASURELAYER            = Measure
-# FeatureInfoUI
-FEATUREINFOTITLE        = Feature Information
-FEATUREINFOSUBTITLE     = Select a Layer
-FEATUREINFOLAYER        = Layer:
-FEATUREINFOSELECTFEATURE= Select Features:
-FEATUREINFODIGITIZE     = Digitize:
-FEATUREINFOPOINT        = Point
-FEATUREINFORECTANGLE    = Rectangle
-FEATUREINFOPOLYGON      = Polygon
-FEATUREINFOTOTAL        = Total:
-FEATUREINFONOSELECTED   = no features selected.
-FEATUREINFOERROR        = Error
-FEATUREINFOFETCHINFO    = fetching feature info ...
-FEATUREINFOFEATURESEL   = features selected
-FEATUREINFOAREA         = Area:
-FEATUREINFOAREAUNDEFINE = areaIdx undefined
-FEATUREINFONOINFO       = no layer info
-FEATUREINFONOFEATUREIN  = no features in selected layer.
-# QueryUI
-QUERYTITLE              = Query Features
-QUERYSELECTLAYER        = Select a Layer
-QUERYLAYER              = Layer:
-QUERYPROPERTYFILTER     = Property Filter
-QUERYPROPERTY           = Property:
-QUERYOPERATOR           = Operator:
-QUERYVALUE              = Value:
-QUERYSPATIALFILTER      = Spatial Filter
-QUERYDIGITIZE           = Digitize:
-QUERYRECTANGLE          = Rectangle
-QUERYPOLYGON            = Polygon
-QUERYCLEAR              = Clear
-QUERYOUTPUT             = Output
-QUERYOUTPUTPROPERTY     = Output property:
-QUERYEXECUTE            = Execute
-QUERYMAXRESULT          = Max results:
-QUERYRESULTS            = Results
-QUERYSCALE              = Scale:
-QUERYZOOM               = Zoom
-QUERYSELECT             = Select
-QUERYERROR              = Error
-QUERYEQUALTO            = Equal to
-QUERYNOTEQUALTO         = Not equal to
-QUERYGREATTHAN          = Greater than
-QUERYGREATTHANEQUAL     = Greater than or equal to
-QUERYLESSTHAN           = Less than
-QUERYLESSTHANEQUAL      = Less than or equal to
-QUERYBEGIN              = Begins with
-QUERYCONTAINS           = Contains
-# Theme UI
-THEMETITLE              = Theme Layer
-THEMESELECTLAYER        = Select a Layer
-THEMELAYER              = Layer:
-THEMENAME               = Theme Name:
-THEMECONDITIONS         = Define Conditions
-THEMEPROPERTY           = Property:
-THEMEMIN                = Min:
-THEMEMAX                = Max:
-THEMEDISTRIBUTION       = Distribution:
-THEMERULE               = # of Rules:
-THEMESCALERANGE         = Scale Range
-THEMESTYLERAMP          = Style Ramp
-THEMEFILLTRANS          = Fill Transparency:
-THEMEFILLCOLOR          = Fill Color:
-THEMEFROM               = From:
-THEMETO                 = To:
-THEMEBORDERCOLOR        = Border Color:
-THEMEAPPLY              = Apply
-THEMEERROR              = Error
-THEMEINDIVIDUAL         = Individual
-THEMEEQUAL              = Equal
-THEMESTANDARD           = Standard Deviation
-THEMEQUANTILE           = Quantile
-THEMEJENKS              = Jenks (Natural Breaks)
-# Redline UI
-REDLINEOPTIONS          = Digitizing Options
-REDLINESELECTLAYER      = Select Layer:
-REDLINENEW              = New
-REDLINERENAME           = Rename
-REDLINEREMOVE           = Remove
-REDLINEDRAW             = Draw:
-REDLINEPOINT            = Point
-REDLINELINE             = Line
-REDLINERECTANGLE        = Rectangle
-REDLINEPOLYGON          = Polygon
-REDLINESAVE             = Save
-REDLINEUPLOAD           = Upload
-REDLINEFEATURES         = Features
-# HtmlViewerAbout
-HTMLABOUTTITLE          = About %s
-HTMLABOUTTITLEBAR       = MapGuide Viewer
-HTMLABOUTSERVERTITLE    = MapGuide Server
-HTMLABOUTVIEWERTITLE    = MapGuide Viewer
-HTMLABOUTSERVERVERSION  = %s (Version %s)
-HTMLABOUTVIEWERVERSION  = %s (Version %s)
-HTMLABOUTTEXT           = <br>This product is made available subject to the terms of GNU Lesser General Public License Version 2.1 ("LGPL").  A copy of the LGPL, as well as additional copyright notices and license terms applicable to portions of this product are set forth in the <a href="../localized/license_en.htm" target="blank">license</a> file.<br><br>All trademarks and registered trademarks mentioned herein are the property of their respective owners.<br><br>Copyright &copy; 2007 Autodesk, Inc.<br><br>
-HTMLABOUTLICENSE        = license file
-HTMLABOUTLICENSEFILE    = license_en.htm
-# LegendUI
-LEGENDLISTSEPARATOR     = ,
-# PrintablePageUi
-PRINTTITLE              = Get Printable Page
-PRINTELEMENTS           = Select the elements to include in the print layout.
-PRINTPAGETITLE          = Page title:
-PRINTLEGEND             = Legend
-PRINTNORTHARROW         = North arrow
-PRINTCREATEPAGE         = Create Page
-# PropertyCtrl
-PROPERTIESNONE          = None Selected
-PROPERTIESNAME          = Name
-PROPERTIESVALUE         = Value
-PROPERTIESITEMSEL       = Items selected: {0}
-# Search
-SEARCHDLGTITLE          = Search features
-SEARCHTITLE             = Search results
-SEARCHERROR             = Search error
-SEARCHREPORT            = Search report
-SEARCHLAYERNOTFOUND     = Layer {0} not found!
-SEARCHNOMULTIPROP       = Multi-properties identity not supported yet
-SEARCHTYYPENOTSUP       = Identity property type not supported yet ({0})
-SEARCHNOMATCHES         = No matches.
-# SearchPrompt
-SEARCHPROMPTFIND        = Find
-# SelectWithinUi
-SELECTWITHINTITLE       = Select Within
-SELECTWITHINAREAS       = Select areas on the image.
-SELECTWITHINRESTRICTION = Restrict results to selected layers:
-SELECTWITHINTEXT        = <li>If you continue to select areas on the image, click &quot;Refresh&quot; to update the layer list.</li><li>To finish and select all features within the highlighted areas, click &quot;Done&quot;.</li><li>To start over, click &quot;Clear&quot;.</li>
-# Error/Report
-REPORTTITLE             = Report
-# Legend UI
-REFRESH                 = Refresh
-EXPANDALL               = Expand
-COLLAPSEALL             = Collapse All
-DISPLAYALLINGROUP       = Display All in Group
-HIDEALLINGROUP          = Hide All in Group
-SHOWLONGTHEME           = Show Long Theme
-# Task Bar
-TASKS                   = Tasks
-# Viewer Options
-OPTIONSTITLE            = Viewer Options
-OPTIONSINFOTEXT         = Select viewing options for status bar and tool tips.
-OPTIONSDISTANCE         = Display distances in
-OPTIONSMETRIC           = Metric (Kilometers, Meters)
-OPTIONSUSENGLISH        = US/English (Miles, Feet)
-OPTIONSPOSITION         = Display cursor position in
-OPTIONSLATLON           = Latitude, Longitude (Degrees)
-OPTIONSMAPUNITS         = Map Coordinate System (X,Y)
-# AJAX Viewer
-VIEWERLAYERS            = Layers
-VIEWERPROPS             = Properties
-VIEWERPANNORTH          = Pan North
-VIEWERPANWEST           = Pan West
-VIEWERPANSOUTH          = Pan South
-VIEWERPANEAST           = Pan East
-VIEWERZOOMIN            = Zoom In
-VIEWERZOOMOUT           = Zoom Out
-VIEWERMOVESLIDER        = Drag to move slider
-VIEWERDRAGZOOM          = Drag to zoom
-ENDSEL                  = CTRL + click to end
-ENDSELSAFARI            = SHIFT + click to end
-DECIMALSEPARATOR        = .
-THOUSANDSEPARATOR       = ,
-# Main Frame
-NEEDLOGIN               = You must enter a valid login ID and password to access this site
-ALREADYINMEASURE        = Only one measure command is allowed in a web layout
-ACCESSDENIED            = Access Denied
-LATLONCURPOS            = Lat: {0}, Lon: {1}
-MAPUNITSCURPOS          = X: {0}, Y: {1}
-FEATURESSELECTED        = {0} features selected
-FEATURESELECTED         = {0} feature selected
-MI                      = mi
-FT                      = ft
-IN                      = in
-KM                      = km
-MT                      = m
-CM                      = cm
-DIGALREADYRUNNING       = Cannot execute measure: A digitization command is in progress.
-MEASALREADYRUNNING      = Cannot execute digitization: A measure is in progress.
-# Localized Icon Files
Deleted: sandbox/adsk/2.2gp/text/fr.json
--- sandbox/adsk/2.2gp/text/fr.json	2010-04-07 21:58:02 UTC (rev 2136)
+++ sandbox/adsk/2.2gp/text/fr.json	2010-04-07 22:54:19 UTC (rev 2137)
@@ -1,54 +0,0 @@
-Fusion.Strings.fr = {
-'scriptFailed': 'failed to load script: ${script}',
-'configParseError': 'Error parsing fusion configuration file, initialization aborted',
-'configLoadError': 'Error loading fusion configuration file, initialization aborted.' +
-                  'Make sure that you have copied config_dist.json to config.json ' +
-                  'and have configured the settings for your system',
-'ajaxError': 'Exception occurred in AJAX callback.\n${exception}\nLocation: ${file} (${line}))',
-'importFailed': 'failed to import stylesheet: ${url}',
-'registerEventError': 'Error registering eventID, invalid (empty) eventID.',
-'appDefLoadFailed': 'failed to load: ${script}',
-'appDefParseError': 'failed to parse ApplicationDefinition',
-'widgetSetParseError': 'failed to parse the WidgetSet',
-'fusionError': 'Fusion Error: ${type}\n${message}',
-'nullExtents': 'Map.setExtents called with null extents',
-'mapLoadError': 'Failed to load requested map:\n${error}',
-'setLayersError': "setLayers failure: ${error}",
-'printTitle': 'Printable Page ',
-'noSelection': 'Aucun Sélection',
-'selectionInfo': '${features} feature(s) selected on ${layers} layer(s)',
-'attribute': 'Attribute',
-'value': 'Value',
-'taskHome': 'return to the task pane home',
-'prevTask': 'go to previous task executed',
-'nextTask': 'go to next task executed',
-'taskList': 'Task List',
-'taskPane': 'Task Pane',
-'imperial': 'Imperial',
-'metric': 'Metric',
-'deg': 'Degrees',
-'refresh': 'Refresh',
-'expandAll': 'Expand All',
-'expand': 'Expand',
-'collapseAll': 'Collapse All',
-'collapse': 'Collapse',
-'defaultMapTitle': 'Map',
-'legendTitle': 'Legend',
-'selectionPanelTitle': 'Sélection',
-'ovmapTitle': 'Overview Map',
-'ovmapTitleShort': 'Overview',
-'taskPaneTitle': 'Tasks',
-'segment': 'Segment ${seg}',
-'calculating': 'calculating ...',
-'panWest': 'Ouest',
-'panEast': 'Est',
-'panSouth': 'Sud',
-'panNorth': 'Nord',
-'zoomOut': 'Cliquer pour réduire',
-'zoomIn': 'Cliquer pour agrandir',
-'printCancel': 'Cancel',
-'printGenerate': 'Generate',
-'maptipLinkText': 'Cliquer pour plus d information',
-'end': ''
More information about the fusion-commits mailing list
