[fusion-commits] r2138 - sandbox/adsk/2.2gp/lib
sandbox/adsk/2.2gp/widgets/BufferPanel
sandbox/adsk/2.2gp/widgets/Search
sandbox/adsk/2.2gp/widgets/Theme trunk/lib
trunk/widgets/BufferPanel trunk/widgets/Search trunk/widgets/Theme
svn_fusion at osgeo.org
Thu Apr 8 14:02:53 EDT 2010
Author: chrisclaydon
Date: 2010-04-08 14:02:52 -0400 (Thu, 08 Apr 2010)
New Revision: 2138
sandbox/adsk/2.2gp/lib/Map.js
sandbox/adsk/2.2gp/widgets/BufferPanel/Buffer.php
sandbox/adsk/2.2gp/widgets/BufferPanel/BufferReport.templ
sandbox/adsk/2.2gp/widgets/BufferPanel/ErrorPage.templ
sandbox/adsk/2.2gp/widgets/Search/ErrorPage.templ
sandbox/adsk/2.2gp/widgets/Search/Search.php
sandbox/adsk/2.2gp/widgets/Theme/thememain.php
trunk/lib/Map.js
trunk/widgets/BufferPanel/Buffer.php
trunk/widgets/BufferPanel/BufferReport.templ
trunk/widgets/BufferPanel/ErrorPage.templ
trunk/widgets/Search/ErrorPage.templ
trunk/widgets/Search/Search.php
trunk/widgets/Theme/thememain.php
Fixes #384 - Buffer / Theme cause the map to zoom to its initial extents when commercial base map layers are present in the map.
Modified: sandbox/adsk/2.2gp/lib/Map.js
--- sandbox/adsk/2.2gp/lib/Map.js 2010-04-07 22:54:19 UTC (rev 2137)
+++ sandbox/adsk/2.2gp/lib/Map.js 2010-04-08 18:02:52 UTC (rev 2138)
@@ -215,7 +215,7 @@
this.aMaps[i].oLayerOL.destroy();
this._fMetersperunit = -1;
this.oMapOL.center = null;
this.maxExtent = new OpenLayers.Bounds();
@@ -281,7 +281,7 @@
this.cumulativeDelta = 0;
this.cumulativeDelta += (deltaZ < 0)?-1:1;
this.wheelTimer = setTimeout(OpenLayers.Function.bind(function(){this.doWheelChange(evt, deltaZ);}, this), 200);
@@ -408,6 +408,18 @@
+ //this method allows a specified map to be reloaded, rather than reloading all of them
+ reloadNamedMap: function(mapName) {
+ if(mapName != null && mapName != "") {
+ for (var i=0; i<this.aMaps.length; ++i) {
+ var map = this.aMaps[i];
+ if(map.getMapName() == mapName) {
+ window.setTimeout(OpenLayers.Function.bind(map.reloadMap, map),1);
loadScaleRanges: function(userFunc) {
@@ -503,8 +515,8 @@
this.oSelection = {};
this.nSelectionMaps = 0;
for (var i=0; i<this.aMaps.length; i++ ) {
- if(this.aMaps[i].layerType == "Google" || this.aMaps[i].layerType == "Yahoo" ||this.aMaps[i].layerType == "VirtualEarth" )
- continue;
+ if(this.aMaps[i].layerType == "Google" || this.aMaps[i].layerType == "Yahoo" ||this.aMaps[i].layerType == "VirtualEarth" )
+ continue;
this.nSelectionMaps++;
this.aMaps[i].getSelection(
OpenLayers.Function.bind(this.accumulateSelection, this, this.aMaps[i]),
@@ -619,11 +631,11 @@
redraw: function() {
- if(this.aMaps[i].oLayerOL.params){
+ if(this.aMaps[i].oLayerOL.params){
this.aMaps[i].oLayerOL.params.ts = (new Date()).getTime();
//mergeNewParams calls redraw on the layer, which will get called below anyway
//this.aMaps[i].oLayerOL.mergeNewParams({ts : (new Date()).getTime()});
this.oMapOL.setCenter(this.oMapOL.getCenter(), this.oMapOL.getZoom(), false, true);
@@ -1066,12 +1078,12 @@
return OpenLayers.Util.getParameterString(queryParams);
getMapTip: function(oMapTips) {
//TODO send this to the correct aMap object
this.aMaps[0].getMapTip(oMapTips);
supressContextMenu: function( bSupress ) {
this.bSupressContextMenu = bSupress;
Modified: sandbox/adsk/2.2gp/widgets/BufferPanel/Buffer.php
--- sandbox/adsk/2.2gp/widgets/BufferPanel/Buffer.php 2010-04-07 22:54:19 UTC (rev 2137)
+++ sandbox/adsk/2.2gp/widgets/BufferPanel/Buffer.php 2010-04-08 18:02:52 UTC (rev 2138)
@@ -361,7 +361,7 @@
function OnError($title, $msg)
- global $target, $popup;
+ global $target, $popup, $mapName;
$templ = Localize(file_get_contents("./ErrorPage.templ"), $locale, GetClientOS());
print sprintf($templ, $popup, $mapName, $title, $msg);
Modified: sandbox/adsk/2.2gp/widgets/BufferPanel/BufferReport.templ
--- sandbox/adsk/2.2gp/widgets/BufferPanel/BufferReport.templ 2010-04-07 22:54:19 UTC (rev 2137)
+++ sandbox/adsk/2.2gp/widgets/BufferPanel/BufferReport.templ 2010-04-08 18:02:52 UTC (rev 2138)
@@ -24,13 +24,13 @@
<script language=javascript>
var popup = %s;
-var errors = false; //this page is only returned for success;
+var errors = false; //this page is only returned for success;
var mapName = '%s';
function InitDocument()
var map = GetParent().Fusion.getMapByName(mapName);
- map.reloadMap();
+ map.reloadNamedMap(mapName);
if (!errors) {
Back();
@@ -42,7 +42,7 @@
history.back();
} else {
var TaskPaneId=this.frameElement.taskPaneId;
- GetParent().Fusion.getWidgetById(TaskPaneId).goHome();
+ GetParent().Fusion.getWidgetById(TaskPaneId).goHome();
Modified: sandbox/adsk/2.2gp/widgets/BufferPanel/ErrorPage.templ
--- sandbox/adsk/2.2gp/widgets/BufferPanel/ErrorPage.templ 2010-04-07 22:54:19 UTC (rev 2137)
+++ sandbox/adsk/2.2gp/widgets/BufferPanel/ErrorPage.templ 2010-04-08 18:02:52 UTC (rev 2138)
@@ -31,8 +31,12 @@
- var map = GetParent().Fusion.getMapByName('%s');
- map.aMaps[0].reloadMap();
+ var mapName = '%s';
+ var map = GetParent().Fusion.getMapByName(mapName);
+ if(map != null)
function Back()
Modified: sandbox/adsk/2.2gp/widgets/Search/ErrorPage.templ
--- sandbox/adsk/2.2gp/widgets/Search/ErrorPage.templ 2010-04-07 22:54:19 UTC (rev 2137)
+++ sandbox/adsk/2.2gp/widgets/Search/ErrorPage.templ 2010-04-08 18:02:52 UTC (rev 2138)
@@ -31,8 +31,12 @@
- map.reloadMap();
+ if(map != null)
function Back()
@@ -41,7 +45,7 @@
history.back();
} else {
Modified: sandbox/adsk/2.2gp/widgets/Search/Search.php
--- sandbox/adsk/2.2gp/widgets/Search/Search.php 2010-04-07 22:54:19 UTC (rev 2137)
+++ sandbox/adsk/2.2gp/widgets/Search/Search.php 2010-04-08 18:02:52 UTC (rev 2138)
@@ -274,9 +274,9 @@
$templ = file_get_contents("./ErrorPage.templ");
- print sprintf($templ, $popup, $title, $msg);
+ print sprintf($templ, $popup, $mapName, $title, $msg);
function GetParameters($params)
Modified: sandbox/adsk/2.2gp/widgets/Theme/thememain.php
--- sandbox/adsk/2.2gp/widgets/Theme/thememain.php 2010-04-07 22:54:19 UTC (rev 2137)
+++ sandbox/adsk/2.2gp/widgets/Theme/thememain.php 2010-04-08 18:02:52 UTC (rev 2138)
@@ -359,7 +359,7 @@
themeReqHandler = null;
var map = parent.Fusion.getMapByName(mapName);
- map.reloadMap();
Modified: trunk/lib/Map.js
--- trunk/lib/Map.js 2010-04-07 22:54:19 UTC (rev 2137)
+++ trunk/lib/Map.js 2010-04-08 18:02:52 UTC (rev 2138)
@@ -53,57 +53,57 @@
Fusion.Constant.LAYER_DWF_TYPE = 5;
Fusion.Widget.Map = OpenLayers.Class(Fusion.Lib.EventMgr, {
/** The DOM object that holds the map */
_oDomObj: null,
/** The id of DOM object */
_sDomObj: '',
/** The internal name used for the map, usually assigned by the server */
_sMapname: '',
/** conversion factor to convert from map units to meters */
_fMetersperunit: -1,
/** scale denominator value */
_fScale: -1,
/** Dots per inch setting for the server */
_nDpi: 96,
/** The current bounds of the map, this is updated on every map draw */
_oCurrentExtents: null,
/** The maximum extent of the map */
maxExtent: new OpenLayers.Bounds(),
/** counter of worker threads for the ActivityIndicator widget */
_nWorkers: 0,
/** The context menu object for right click */
oContextMenu: null,
/** flag to disable the map context menu, set this in the Map extension */
bSupressContextMenu: false,
/** an array to hold all the individual map layer objects */
aMaps: null,
/** flag to indicate if all the map layers are loaded */
mapsLoaded: false,
/** the root of the layer structure for the Legend */
layerRoot: null,
/** flag to indicate if the map is tiled or not, set in the Map extension */
singleTile: true,
/** flag to indicate if fractional zoom is supported, ie. allow any scale
* value rather than a fixed set of scales
fractionalZoom: true,
maxScale: null, //set this to a large number in AppDef to zoom out beyond maxExtent, e.g. 1 billion
@@ -279,7 +279,7 @@
@@ -305,7 +305,7 @@
* Function: layerLoaded
- * Called after each layer is loaded in the OL viewport. Nothing happens
+ * Called after each layer is loaded in the OL viewport. Nothing happens
* here until the last layer is laoded, then it sets the OL baselayer and
* zooms to the initial extent.
@@ -348,7 +348,7 @@
* handles mouse wheel events by accummulating the events and setting a timer
* to do the actual zoom in/out
* Parameters:
* evt - {Event} the mouse wheel event object
* deltaZ - {Integer} the number of ticks wheeled
@@ -360,7 +360,7 @@
@@ -540,7 +540,7 @@
projection: this.projection
map.registerForEvent(Fusion.Event.MAP_SELECTION_OFF,
OpenLayers.Function.bind(this.selectionHandler, this));
map.registerForEvent(Fusion.Event.MAP_SELECTION_ON,
@@ -577,6 +577,18 @@
* Function: loadScaleRanges
@@ -676,8 +688,8 @@
- continue;
+ continue;
@@ -690,8 +702,8 @@
* sets a Selection XML back to the server for each of the maps
- * Parameters:
- * {String} selText - the selection string
+ * Parameters:
+ * {String} selText - the selection string
* {Boolean} zoomTo - if set, will zoom to the selection on completion
setSelection: function(selText, zoomTo) {
@@ -752,7 +764,7 @@
* Function: _addWorker
* indicate that a new asynchronous process has started and make sure the
* visual indicator is visible for the user. This is intended to be used
* internally by gMap but could be used by external tools if appropriate.
@@ -765,7 +777,7 @@
* Function: _removeWorker
* indicate that an asynchronous process has completed and hide the
* visual indicator if no remaining processes are active. This is
* intended to be used internally by gMap but could be used by
@@ -784,7 +796,7 @@
* Function: mapExtentsChanged
* OpenLayers event handler for whenever the map changes either zoom level
- * of the center has changed. This in turn triggers the Fusion event.
+ * of the center has changed. This in turn triggers the Fusion event.
* Parameters: none
@@ -811,7 +823,7 @@
* Function: sizeChanged
- * callback for when the browser window size changes, simply calls resize
+ * callback for when the browser window size changes, simply calls resize
* on the map viewport layout object
* Parameters: none
@@ -884,7 +896,7 @@
* handle selection events from maps and republish for
* widgets as appropriate
- * Parameters: {Object} oExtents - an OpenLayers.Bounds object or an array
+ * Parameters: {Object} oExtents - an OpenLayers.Bounds object or an array
* of 4 values that will be converted to Bounds
* Return: none
@@ -910,7 +922,7 @@
* Function: setInitialExtents
* determine the initialExtents of the map from (in order of precedence):
* 1. a URL query parameter called 'extent'
* 2. an <InitialView> specified in the MapGroup in AppDef
@@ -949,7 +961,7 @@
* gets the intitial extents from all maps with or without including the
* extent of any Generic/commercial layers
* Return: {Object} an OpenLayers.Bounds object which is the initial extent
getMapGroupExtent: function(includeGenericLayers) {
@@ -965,7 +977,7 @@
* Function: fullExtents
* sets the extent of the map to the max as returned by loadMap
fullExtents: function() {
@@ -975,8 +987,8 @@
* Function: isMapLoaded
- * returns if the map has finished loading (based on setting the
+ * returns if the map has finished loading (based on setting the
* _oCurrentExtent value)
* Returns {Boolean} true if the map is loaded and extent has been set
@@ -987,7 +999,7 @@
* Function: zoom
* sets the map zoom and extent.
* Parameters:
@@ -1039,7 +1051,7 @@
* Function: zoom
* Parameters:
@@ -1061,7 +1073,7 @@
* Function: zoom
* Parameters:
@@ -1079,7 +1091,7 @@
* Function: zoom
* Parameters:
@@ -1406,12 +1418,12 @@
Modified: trunk/widgets/BufferPanel/Buffer.php
--- trunk/widgets/BufferPanel/Buffer.php 2010-04-07 22:54:19 UTC (rev 2137)
+++ trunk/widgets/BufferPanel/Buffer.php 2010-04-08 18:02:52 UTC (rev 2138)
@@ -361,7 +361,7 @@
Modified: trunk/widgets/BufferPanel/BufferReport.templ
--- trunk/widgets/BufferPanel/BufferReport.templ 2010-04-07 22:54:19 UTC (rev 2137)
+++ trunk/widgets/BufferPanel/BufferReport.templ 2010-04-08 18:02:52 UTC (rev 2138)
@@ -24,13 +24,13 @@
var popup = %s;
var mapName = '%s';
- map.reloadMap();
if (!errors) {
Back();
@@ -42,7 +42,7 @@
history.back();
} else {
Modified: trunk/widgets/BufferPanel/ErrorPage.templ
--- trunk/widgets/BufferPanel/ErrorPage.templ 2010-04-07 22:54:19 UTC (rev 2137)
+++ trunk/widgets/BufferPanel/ErrorPage.templ 2010-04-08 18:02:52 UTC (rev 2138)
@@ -31,8 +31,12 @@
+ if(map != null)
function Back()
Modified: trunk/widgets/Search/ErrorPage.templ
--- trunk/widgets/Search/ErrorPage.templ 2010-04-07 22:54:19 UTC (rev 2137)
+++ trunk/widgets/Search/ErrorPage.templ 2010-04-08 18:02:52 UTC (rev 2138)
@@ -31,8 +31,12 @@
- map.reloadMap();
+ if(map != null)
function Back()
@@ -41,7 +45,7 @@
history.back();
} else {
Modified: trunk/widgets/Search/Search.php
--- trunk/widgets/Search/Search.php 2010-04-07 22:54:19 UTC (rev 2137)
+++ trunk/widgets/Search/Search.php 2010-04-08 18:02:52 UTC (rev 2138)
@@ -274,9 +274,9 @@
Modified: trunk/widgets/Theme/thememain.php
--- trunk/widgets/Theme/thememain.php 2010-04-07 22:54:19 UTC (rev 2137)
+++ trunk/widgets/Theme/thememain.php 2010-04-08 18:02:52 UTC (rev 2138)
@@ -359,7 +359,7 @@
- map.reloadMap();
More information about the fusion-commits
