[fusion-commits] r2040 - in sandbox/jxlib-3.0: lib widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Wed Jan 20 14:13:08 EST 2010
Author: madair
Date: 2010-01-20 14:13:08 -0500 (Wed, 20 Jan 2010)
New Revision: 2040
   sandbox/jxlib-3.0/lib/Map.js
   sandbox/jxlib-3.0/widgets/LayerManager.js
update of LayerManager, add WMS_LAYER_ADDED event to the MapWidget for the GetFeatureInfo widget to listen to
Modified: sandbox/jxlib-3.0/lib/Map.js
--- sandbox/jxlib-3.0/lib/Map.js	2010-01-15 20:41:28 UTC (rev 2039)
+++ sandbox/jxlib-3.0/lib/Map.js	2010-01-20 19:13:08 UTC (rev 2040)
@@ -41,8 +41,8 @@
 Fusion.Event.MAP_RELOADED = Fusion.Event.lastEventId++;
 Fusion.Event.MAP_SESSION_CREATED = Fusion.Event.lastEventId++;
 Fusion.Event.MAP_MAPTIP_REQ_FINISHED = Fusion.Event.lastEventId++;
+Fusion.Event.WMS_LAYER_ADDED = Fusion.Event.lastEventId++;
 Fusion.Constant.LAYER_POINT_TYPE = 0;
 Fusion.Constant.LAYER_LINE_TYPE = 1;
 Fusion.Constant.LAYER_POLYGON_TYPE = 2;
@@ -168,6 +168,7 @@
         this.registerEventID(Fusion.Event.MAP_SELECTION_ON);
         this.registerEventID(Fusion.Event.MAP_SELECTION_OFF);
         this.registerEventID(Fusion.Event.MAP_MAPTIP_REQ_FINISHED);
+        this.registerEventID(Fusion.Event.WMS_LAYER_ADDED);
         this.registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.mapLoaded,this));
Modified: sandbox/jxlib-3.0/widgets/LayerManager.js
--- sandbox/jxlib-3.0/widgets/LayerManager.js	2010-01-15 20:41:28 UTC (rev 2039)
+++ sandbox/jxlib-3.0/widgets/LayerManager.js	2010-01-20 19:13:08 UTC (rev 2040)
@@ -54,8 +54,8 @@
     currentNode: null,
     bIsDrawn: false,
     map: null,
-    bLayerChanged:false,
     initializeWidget: function(widgetTag) {
+        //console.log("initializeWidget");
         var json = widgetTag.extension;
         this.delIconSrc = json.DeleteIcon ? json.DeleteIcon[0] : 'images/icons/select-delete.png';
@@ -71,22 +71,18 @@
     mapLoaded: function() {
         this.draw();
-        this.bLayerChanged = true;
     layerChanged: function() {
-        this.draw();
         this.updateSessionMapFile();
-   mapReLoaded: function(){
-        this.bLayerChanged = false;
+    mapReLoaded: function(){
         this.draw();
      * remove the dom objects representing the legend layers and groups
     clear: function(node) {
+        //console.log("clear");
         while (node.childNodes.length > 0) {
           this.clear(node.childNodes[0]);
             node.destroy(node.childNodes[0]);
@@ -99,6 +95,7 @@
      * @param r Object the reponse xhr object
     draw: function(r) {
+        //console.log("draw");
       if (this.mapList) {
         this.clear(this.mapList);
         this.mapList.destroy();
@@ -113,7 +110,6 @@
       //this processes the OL layers
       var map = this.getMap();
       for (var i=0; i<map.aMaps.length; ++i) {
         var mapBlock = document.createElement('li');
         mapBlock.className = 'jxLmanMap';
@@ -139,19 +135,15 @@
     processMapBlock: function(blockDom, map) {
+      //console.log("processMapBlock");
       var mapBlockList = document.createElement('ul');
       mapBlockList.className = 'jxLmanSet';
       mapBlockList.id = 'fusionLayerManager_'+map.getMapName();
       blockDom.appendChild(mapBlockList);
       map.layerPrefix = 'layer_';   //TODO make this unique for each block
-      mapBlockList.bLayerChanged = this.bLayerChanged;
       //this process all layers within an OL layer
       var processArray = map.aLayers;
-      if (map.bLayersReversed && this.bLayerChanged === false ) {
-        processArray.reverse();
       for (var i=0; i<processArray.length; ++i) {
         var blockItem = document.createElement('li');
         blockItem.className = 'jxLmanLayer';
@@ -235,6 +227,7 @@
   updateLayer: function(map, ul) {
+   //console.log("updateLayer");
     //reorder the layers in the client as well as the session
     var aLayerIndex = [];
     var aIds = [];
@@ -242,9 +235,6 @@
     for (var i=0; i<nLayers; ++i) {
       aIds[i] = this.childNodes[i].id.split('_');
       var index = parseInt(aIds[i].pop());
-      if (map.bLayersReversed && ul.bLayerChanged === false) {
-        index = nLayers - (index+1);
       aLayerIndex.push(index);
       this.childNodes[i].id = '';
@@ -257,9 +247,6 @@
       node.childNodes[1].checked = node.layer.isVisible()
-      aLayerIndex.reverse();
     map.reorderLayers(aLayerIndex);
@@ -268,6 +255,7 @@
   deleteLayer: function(layer, ev) {
+   // console.log("deleteLayer");
     var targetLI = (new Event(ev)).target.parentNode;
     var ul = targetLI.parentNode;
     $(targetLI).dispose();
@@ -284,6 +272,7 @@
   updateSessionMapFile: function(){
+   // console.log("updateSessionMapFile");
     // get map
     var aMaps = map.getAllMaps();
More information about the fusion-commits mailing list
