[fusion-commits] r2041 - in trunk: layers layers/MapGuide
layers/MapGuide/php widgets
svn_fusion at osgeo.org
Fri Jan 22 12:15:00 EST 2010
Author: chrisclaydon
Date: 2010-01-22 12:14:59 -0500 (Fri, 22 Jan 2010)
New Revision: 2041
trunk/layers/Layers.js
trunk/layers/MapGuide/MapGuide.js
trunk/layers/MapGuide/php/LoadMap.php
trunk/widgets/Legend.js
trunk/widgets/Navigator.js
Fix MG ticket 469 (http://trac.osgeo.org/mapguide/ticket/469) Problems with tiled MG maps
Modified: trunk/layers/Layers.js
--- trunk/layers/Layers.js 2010-01-20 19:13:08 UTC (rev 2040)
+++ trunk/layers/Layers.js 2010-01-22 17:14:59 UTC (rev 2041)
@@ -329,6 +329,7 @@
this.visible = o.visible;
this.initiallyVisible = o.visible;
this.actuallyVisible = o.actuallyVisible;
+ this.isBaseMapGroup = o.isBaseMapGroup;
this.registerEventID(Fusion.Event.GROUP_PROPERTY_CHANGED);
@@ -459,6 +460,7 @@
this.selectable = o.selectable;
+ this.isBaseMapLayer = o.isBaseMapLayer;
//determine the layer type so that the correct icon can be displayed in the legend
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js 2010-01-20 19:13:08 UTC (rev 2040)
+++ trunk/layers/MapGuide/MapGuide.js 2010-01-22 17:14:59 UTC (rev 2041)
@@ -322,15 +322,29 @@
this.oLayerOL.destroy();
- this.oLayerOL = this.createOLLayer(this._sMapname, this.bSingleTile,2);
+ this.oLayerOL = this.createOLLayer(this._sMapname, this.bSingleTile,2,false);
this.oLayerOL.events.register("loadstart", this, this.loadStart);
this.oLayerOL.events.register("loadend", this, this.loadEnd);
this.oLayerOL.events.register("loadcancel", this, this.loadEnd);
+ //remove the dynamic overlay layer if it was already created
+ if (this.oLayerOL2) {
+ this.oLayerOL2.destroy();
//this is to distinguish between a regular map and an overview map
this.bMapLoaded = true;
if (this.bIsMapWidgetLayer) {
- this.mapWidget.addMap(this);
+ this.mapWidget.addMap(this);
+ //if we have a tiled map that also contains dynamic layers, we need to create
+ //an additional overlay layer to render them on top of the tiles
+ if(!this.bSingleTile && o.hasDynamicLayers) {
+ this.oLayerOL2 = this.createOLLayer(this._sMapname + "_DynamicOverlay",true,2,true);
+ this.mapWidget.oMapOL.addLayer(this.oLayerOL2);
+ this.oLayerOL2.setVisibility(true);
this.mapWidget._removeWorker();
@@ -530,7 +544,12 @@
this.aHideGroups = [];
this.aRefreshLayers = [];
- this.oLayerOL.mergeNewParams(params);
+ if(this.oLayerOL2) {
+ this.oLayerOL2.mergeNewParams(params);
+ } else {
+ this.oLayerOL.mergeNewParams(params);
drawSelection: function() {
@@ -546,7 +565,7 @@
* Returns an OpenLayers MapGuide layer object
- createOLLayer: function(layerName, bSingleTile, behavior) {
+ createOLLayer: function(layerName, bSingleTile, behavior, forceAsOverlay) {
/* prevent the useOverlay flag based on MapGuide config element */
this.useAsyncOverlay = Fusion.getConfigurationItem('mapguide', 'useAsyncOverlay');
if (!this.useAsyncOverlay) { //v2.0.1 or earlier
@@ -601,8 +620,12 @@
if (behavior == 5) {
params.selectioncolor = this.selectionColor;
params.format = this.selectionFormat;
- layerOptions.isBaseLayer = false;
+ if(forceAsOverlay)
+ layerOptions.isBaseLayer = false;
} else {
params = { //tiled version
@@ -624,8 +647,8 @@
} else {
url = Fusion.getConfigurationItem('mapguide', 'mapAgentUrl');
- var oLayerOL = new OpenLayers.Layer.MapGuide( layerName, url, params, layerOptions );
- return oLayerOL;
+ var oNewLayerOL = new OpenLayers.Layer.MapGuide( layerName, url, params, layerOptions );
+ return oNewLayerOL;
@@ -910,7 +933,7 @@
if (oNode.hasSelection) {
if (this.selectionAsOverlay) {
if (!this.queryLayer) {
- this.queryLayer = this.createOLLayer("query layer", true, 5);
+ this.queryLayer = this.createOLLayer("query layer", true, 5, true);
this.mapWidget.oMapOL.addLayer(this.queryLayer);
this.mapWidget.registerForEvent(Fusion.Event.MAP_LOADING,
OpenLayers.Function.bind(this.removeQueryLayer, this));
@@ -999,6 +1022,9 @@
this.processGroupEvents(group, true);
if (group.groupName == 'layerRoot') {
this.oLayerOL.setVisibility(true);
+ } else if (group.isBaseMapGroup) {
+ this.oLayerOL.setVisibility(true);
} else {
this.aShowGroups.push(group.uniqueId);
if (!noDraw) {
@@ -1010,6 +1036,9 @@
this.processGroupEvents(group, false);
this.oLayerOL.setVisibility(false);
+ this.oLayerOL2.setVisibility(false);
+ this.oLayerOL.setVisibility(false);
} else {
this.aHideGroups.push(group.uniqueId);
if (!noDraw) {
Modified: trunk/layers/MapGuide/php/LoadMap.php
--- trunk/layers/MapGuide/php/LoadMap.php 2010-01-20 19:13:08 UTC (rev 2040)
+++ trunk/layers/MapGuide/php/LoadMap.php 2010-01-22 17:14:59 UTC (rev 2041)
@@ -148,6 +148,16 @@
$layerObj->actuallyVisible = $layer->isVisible();
$layerObj->editable = IsLayerEditable($resourceService, $layer);
+ $isBaseMapLayer = ($layer->GetLayerType() == MgLayerType::BaseMap);
+ $layerObj->isBaseMapLayer = $isBaseMapLayer;
+ if($isBaseMapLayer)
+ $mapObj->hasBaseMapLayers = true;
+ else
+ $mapObj->hasDynamicLayers = true;
$layerObj->legendLabel = addslashes($layer->GetLegendLabel());
$layerObj->displayInLegend = $layer->GetDisplayInLegend();
@@ -375,6 +385,8 @@
$groupObj->parentUniqueId = $parent != null ? $parent->GetObjectId() : '';
$groupObj->visible = $group->GetVisible();
$groupObj->actuallyVisible = $group->isVisible();
+ $isBaseMapGroup = ($group->GetLayerGroupType() == MgLayerGroupType::BaseMap);
+ $groupObj->isBaseMapGroup = $isBaseMapGroup;
return $groupObj;
Modified: trunk/widgets/Legend.js
--- trunk/widgets/Legend.js 2010-01-20 19:13:08 UTC (rev 2040)
+++ trunk/widgets/Legend.js 2010-01-22 17:14:59 UTC (rev 2041)
@@ -255,7 +255,7 @@
var opt = {
label: OpenLayers.i18n('defaultMapTitle'),
open: true,
- draw: this.renderFolder,
+ draw: this.renderFolderCheckbox,
contextMenu: this.getContextMenu(),
'class':'fusionLegendFolder'
@@ -376,7 +376,7 @@
* @param r Object the reponse xhr object
- /*renderLegend: function(r) {
+ /*renderLegend: function(r) {
this.bIsDrawn = false;
this.clear();
@@ -400,43 +400,43 @@
this.bIsDrawn = true;
this.update();
- renderLegend: function(r) {
- this.bIsDrawn = false;
- this.clear();
- if (this.showRootFolder) {
- this.oRoot.itemLabelobj.innerHTML = this.getMap().getMapTitle();
- if (this.showMapFolder) {
- this.renderGroup(this.layerRoot);
- } else {
- if (this.layerRoot.groups.length > 0) {
- for (var i = 0; i < this.layerRoot.groups.length; i++)
- this.renderGroup(this.layerRoot.groups[i]);
- } else {
- for (var i = 0; i < group.layers.length; i++)
- this.processMapLayer(group.layers[i], this.oRoot);
- this.bIsDrawn = true;
- this.update();
- renderGroup: function(group) {
- if (!group.legend) {
- group.legend = {};
- group.legend.treeItem = this.oRoot;
- for (var i = 0; i < group.groups.length; i++) {
- this.processMapGroup(group.groups[i], this.oRoot);
- for (var i = 0; i < group.layers.length; i++) {
+ renderLegend: function(r) {
+ this.bIsDrawn = false;
+ this.clear();
+ if (this.showRootFolder) {
+ this.oRoot.itemLabelobj.innerHTML = this.getMap().getMapTitle();
+ if (this.showMapFolder) {
+ this.renderGroup(this.layerRoot);
+ } else {
+ if (this.layerRoot.groups.length > 0) {
+ for (var i = 0; i < this.layerRoot.groups.length; i++)
+ this.renderGroup(this.layerRoot.groups[i]);
+ } else {
+ for (var i = 0; i < group.layers.length; i++)
+ this.processMapLayer(group.layers[i], this.oRoot);
+ this.bIsDrawn = true;
+ this.update();
+ renderGroup: function(group) {
+ if (!group.legend) {
+ group.legend = {};
+ group.legend.treeItem = this.oRoot;
+ for (var i = 0; i < group.groups.length; i++) {
+ this.processMapGroup(group.groups[i], this.oRoot);
+ for (var i = 0; i < group.layers.length; i++) {
processMapGroup: function(group, folder) {
if (group.displayInLegend) {
@@ -445,7 +445,7 @@
var opt = {
label: group.legendLabel,
open: group.expandInLegend,
@@ -463,8 +463,11 @@
folder.append(group.legend.treeItem);
- group.legend.treeItem.checkBox.checked = group.visible?true:false;
- OpenLayers.Event.observe(group.legend.treeItem.checkBox, 'click', OpenLayers.Function.bind(this.stateChanged, this, group));
+ if(group.legend.treeItem.checkBox)
+ group.legend.treeItem.checkBox.checked = group.visible?true:false;
+ OpenLayers.Event.observe(group.legend.treeItem.checkBox, 'click', OpenLayers.Function.bind(this.stateChanged, this, group));
var groupInfo = group.oMap.getGroupInfoUrl(group.groupName);
if (groupInfo) {
@@ -500,7 +503,10 @@
layerPropertyChanged: function(eventID, layer) {
- layer.legend.treeItem.checkBox.checked = layer.isVisible();
+ if(layer.legend.treeItem.checkBox)
+ layer.legend.treeItem.checkBox.checked = layer.isVisible();
update: function() {
@@ -557,7 +563,7 @@
updateLayer: function(layer, fScale) {
- var checkbox = layer.oMap.bSingleTile ? this.bIncludeVisToggle : false;
+ var checkbox = layer.isBaseMapLayer ? false : this.bIncludeVisToggle;
if (!layer.displayInLegend || !layer.legend) {
return;
@@ -571,13 +577,19 @@
if (range.styles.length > 1) {
//tree item needs to be a folder
if (!layer.legend.treeItem) {
- layer.legend.treeItem = this.createFolderItem(layer);
- OpenLayers.Event.observe(layer.legend.treeItem.checkBox, 'click', OpenLayers.Function.bind(this.stateChanged, this, layer));
+ layer.legend.treeItem = this.createFolderItem(layer, checkbox);
+ OpenLayers.Event.observe(layer.legend.treeItem.checkBox, 'click', OpenLayers.Function.bind(this.stateChanged, this, layer));
layer.parentGroup.legend.treeItem.append(layer.legend.treeItem);
} else if (layer.legend.treeItem instanceof Jx.TreeItem) {
this.clearTreeItem(layer);
} else {
while(layer.legend.treeItem.nodes.length > 0) {
@@ -612,8 +624,8 @@
} else {
if (range.styles.length > 0) {
- layer.legend.treeItem.domImg.style.backgroundImage = 'url('+layer.oMap.getLegendImageURL(fScale, layer, range.styles[0])+')';
- layer.legend.treeItem.domImg.style.backgroundPosition = '0px 0px';
+ layer.legend.treeItem.domImg.style.backgroundImage = 'url('+layer.oMap.getLegendImageURL(fScale, layer, range.styles[0])+')';
+ layer.legend.treeItem.domImg.style.backgroundPosition = '0px 0px';
$(layer.legend.treeItem.domObj).removeClass('jxDisabled');
} else {
$(layer.legend.treeItem.domObj).addClass('jxDisabled');
@@ -654,11 +666,11 @@
- createFolderItem: function(layer) {
+ createFolderItem: function(layer, hasCheckbox) {
var opt = {
label: layer.legendLabel == '' ? ' ' : layer.legendLabel,
isOpen: layer.expandInLegend,
+ draw: hasCheckbox ? this.renderFolderCheckbox : this.renderFolder,
'class':'fusionLegendItemCheckbox',
// image overrides
@@ -791,8 +803,6 @@
- this.checkBox = document.createElement('input');
- this.checkBox.type = 'checkbox';
this.domImg = document.createElement('img');
this.domImg.className = 'jxTreeIcon ' + (this.options.imageClass ? this.options.imageClass : '');
@@ -807,7 +817,6 @@
html: this.options.label
- domA.appendChild(this.checkBox);
domA.appendChild(this.domImg);
domA.appendChild(domLabel);
@@ -817,6 +826,43 @@
+ renderFolderCheckbox: function() {
+ var domA = new Element('a',{
+ 'class':this.options['class'],
+ href:'javascript:void(0)',
+ events: {
+ click: this.selected.bindWithEvent(this),
+ dblclick: this.selected.bindWithEvent(this),
+ contextmenu: this.options.contextMenu.show.bindWithEvent(this.options.contextMenu)
+ this.checkBox = document.createElement('input');
+ this.checkBox.type = 'checkbox';
+ this.domImg = document.createElement('img');
+ this.domImg.className = 'jxTreeIcon ' + (this.options.imageClass ? this.options.imageClass : '');
+ this.domImg.src = Jx.aPixel.src;
+ if (this.options.image) {
+ this.domImg.style.backgroundImage = 'url('+this.options.image+')';
+ var domLabel = new Element('span',{
+ 'class': 'fusionLegendLabel',
+ html: this.options.label
+ domA.appendChild(this.checkBox);
+ domA.appendChild(this.domImg);
+ domA.appendChild(domLabel);
+ this.itemLabelobj = domA;
+ return domA;
renderItem: function() {
var domA = new Element('a', {
Modified: trunk/widgets/Navigator.js
--- trunk/widgets/Navigator.js 2010-01-20 19:13:08 UTC (rev 2040)
+++ trunk/widgets/Navigator.js 2010-01-22 17:14:59 UTC (rev 2041)
@@ -196,7 +196,7 @@
olMap.zoomTo(olMap.getZoomForResolution(resolution));
this.bInternalChange = false;
} else {
- var zoom = olMap.baseLayer.resolutions.length - value;
+ var zoom = olMap.baseLayer.resolutions.length - value - 1;
this.bInternalChange = true;
olMap.zoomTo(zoom);
@@ -243,8 +243,8 @@
this.slider.set(position);
} else {
- this.slider.steps = map.baseLayer.resolutions.length;
- var position = map.baseLayer.resolutions.length - map.getZoom();
+ this.slider.steps = map.baseLayer.resolutions.length - 1;
+ var position = map.baseLayer.resolutions.length -1 - map.getZoom();
More information about the fusion-commits
