[fusion-commits] r2119 - sandbox/adsk/2.2gp/widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Fri Mar 26 17:39:31 EDT 2010
Author: chrisclaydon
Date: 2010-03-26 17:39:29 -0400 (Fri, 26 Mar 2010)
New Revision: 2119
   sandbox/adsk/2.2gp/widgets/Measure.js
Fix #377 Reposition dimension markers for Measure widget when map view changes
Modified: sandbox/adsk/2.2gp/widgets/Measure.js
--- sandbox/adsk/2.2gp/widgets/Measure.js	2010-03-26 21:17:49 UTC (rev 2118)
+++ sandbox/adsk/2.2gp/widgets/Measure.js	2010-03-26 21:39:29 UTC (rev 2119)
@@ -26,9 +26,9 @@
  * Class: Fusion.Widget.Measure
- * The Measure widget allows the user to measure distances or areas on the map
+ * The Measure widget allows the user to measure distances or areas on the map
  * in one or more segments. Area is positive if measured clockwise.
 Fusion.Constant.MEASURE_TYPE_DISTANCE = 1;
@@ -41,12 +41,12 @@
 Fusion.Widget.Measure = OpenLayers.Class(Fusion.Widget, {
     isExclusive: true,
     uiClass: Jx.Button,
     //distance of each segment
     distances: null,
     distanceMarkers: null,
     areaMarker: null,
     /* the units to display distances in */
     units: Fusion.UNKNOWN,
@@ -55,17 +55,17 @@
     /* Precision of the distance displayed */
     distPrecision: 4,
     /* Precision of the area displayed */
     areaPrecision: 4,
-    /* Style for the distance line used for distance draw */
+    /* Style for the distance line used for distance draw */
     distanceNormalStyle: null,
-    /* Style for the polygon used for area draw */
+    /* Style for the polygon used for area draw */
     fillStyle: null,
-    /* Style for the polygon line used for area draw */
+    /* Style for the polygon line used for area draw */
     areaStyle: null,
     segmentLabels: true,
     initializeWidget: function(widgetTag) {
@@ -73,13 +73,13 @@
         var json = widgetTag.extension;
         this.units = (json.Units && (json.Units[0] != '')) ?  Fusion.unitFromName(json.Units[0]): this.units;
         this.distPrecision = json.DistancePrecision ? parseInt(json.DistancePrecision[0]) : 4;
-        this.areaPrecision = json.AreaPrecision ? parseInt(json.AreaPrecision[0]) : 4;
+        this.areaPrecision = json.AreaPrecision ? parseInt(json.AreaPrecision[0]) : 4;
         if(json.SegmentLabels){
             this.segmentLabels = (json.SegmentLabels[0].toLowerCase == "true" && json.SegmentLabels[0]) ? true : false;
         this.sTarget = json.Target ? json.Target[0] : "";
         this.sBaseUrl = Fusion.getFusionURL() + 'widgets/Measure/Measure.php';
         //init measure type
         this.measureType = 0;
         if (json.Type) {
@@ -98,25 +98,25 @@
                     break;
         //Here are the canvas style definition
         var fillStyle = json.FillStyle ? json.FillStyle[0] : 'rgba(0,0,255, 0.3)';
         var lineStyleWidth = json.LineStyleWidth ? json.LineStyleWidth[0] : 2;
-        var lineStyleColor = json.LineStyleColor ? json.LineStyleColor[0] : 'rgba(0,0,255,0.3)';
+        var lineStyleColor = json.LineStyleColor ? json.LineStyleColor[0] : 'rgba(0,0,255,0.3)';
         this.distanceMarkers = [];
         this.distances = [];
         this.registerEventID(Fusion.Event.MEASURE_SEGMENT_UPDATE);
         this.registerEventID(Fusion.Event.MEASURE_CLEAR);
         this.registerEventID(Fusion.Event.MEASURE_COMPLETE);
         var mapWidget = this.getMap();
         this.keyHandler = OpenLayers.Function.bind(this.onKeyPress, this);
         Fusion.addWidgetStyleSheet(widgetTag.location + 'Measure/Measure.css');
         mapWidget.registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.setUnits, this, this.units));
         this.registerParameter('Units');
             // style the sketch fancy
         this.sketchSymbolizers = {
                 "Point": {
@@ -146,10 +146,10 @@
             new OpenLayers.Rule({symbolizer: this.sketchSymbolizers})
         var styleMap = new OpenLayers.StyleMap({"default": style});
         //add in the OL Polygon handler
         this.map = mapWidget.oMapOL;
-        var handlerOptions = {
+        var handlerOptions = {
             style: "default", // this forces default render intent
             layerOptions: {styleMap: styleMap}
@@ -157,7 +157,7 @@
         if (this.measureType & Fusion.Constant.MEASURE_TYPE_AREA) {
             handler = OpenLayers.Handler.Polygon;
         var controlOptions = {
             persist: true,
             handlerOptions: handlerOptions,
@@ -168,19 +168,49 @@
         this.control = new OpenLayers.Control.Measure(handler, controlOptions);
         this.getMap().oMapOL.addControl(this.control);
         this.control.events.on({
             measure: this.measure,
             scope: this
+        this.getMap().registerForEvent(Fusion.Event.MAP_EXTENTS_CHANGED, OpenLayers.Function.bind(this.extentsChangedCB, this));
+        this.getMap().registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.extentsChangedCB, this));
+    extentsChangedCB : function() {
+        var olControl = this.control;
+        if(olControl && olControl.active)
+            var poly = olControl.handler;
+            var geom = poly.getGeometry();
+            if(geom)
+                this.updateMarkers(geom);
+    updateMarkers : function(geom) {
+        var v = geom.getVertices();
+        for(var i = 0; i < this.distanceMarkers.length; i++)
+            var seg =  new OpenLayers.Geometry.LineString();
+            seg.addPoint(v[i].clone());
+            seg.addPoint(v[i+1].clone());
+            this.updateMarker(this.distanceMarkers[i], seg);
+        this.updateDistances(geom);
+        this.updateArea(geom);
     shouldActivateWith: function(widget) {
         return (widget instanceof Fusion.Widget.Measure &&
                 widget.measureType == this.measureType);
     measure: function(stats) {
         this.hasMeasure = true;
         /* rebuild distance markers */
@@ -218,7 +248,7 @@
         this.triggerEvent(Fusion.Event.MEASURE_COMPLETE);
     measurePartial: function(point, sketch) {
         if (this.hasMeasure) {
             this.resetMeasure();
@@ -227,13 +257,13 @@
         var geom = sketch.geometry;
         if (this.measureType & Fusion.Constant.MEASURE_TYPE_DISTANCE) {
         this.triggerEvent(Fusion.Event.MEASURE_SEGMENT_UPDATE);
     updateDistances: function(geom) {
         var last = v.length - 1;
@@ -261,19 +291,19 @@
     updateArea: function(geom) {
         if (!this.areaMarker) {
             this.areaMarker = new Fusion.Widget.Measure.Marker(this.units, this.distPrecision, '', true);
         this.updateMarker(this.areaMarker, geom);
     delayUpdate: function(marker, geom) {
         this.delayUpdateTimer = null;
         this.updateMarker(marker, geom);
     updateMarker: function(marker, geom) {
         if (!marker) {
             return;
@@ -289,10 +319,10 @@
             to = this.getMap().geoToPix(v[1].x,v[1].y);
             at = {x: (from.x + to.x) / 2, y: (from.y + to.y) / 2};
             quantity = geom.getGeodesicLength(proj);
             //calculate the length in pixels
             pixQuantity = Math.sqrt((to.x - from.x) * (to.x - from.x) + (to.y - from.y) * (to.y - from.y));
             measureUnits = Fusion.METERS;
             if (measureUnits != this.units) {
               quantity = Fusion.convert(measureUnits, this.units, quantity);
@@ -304,13 +334,13 @@
             var cg = geom.getCentroid();
             at = this.getMap().geoToPix(cg.x, cg.y);
             quantity = geom.getGeodesicArea(proj);
                 var rate = Fusion.convert(measureUnits, this.units, 1);
                 quantity = quantity * rate * rate;
             //calculate the area in square pixels
             var resolution = this.getMap().getResolution();
             pixQuantity = quantity / resolution / resolution;
@@ -322,10 +352,10 @@
             this.positionMarker(marker, at);
     positionMarker: function(marker, at) {
         var oDomElem =  this.getMap().getDomObj();
-        if (!marker.domObj.parentNode ||
+        if (!marker.domObj.parentNode ||
             marker.domObj.parentNode != oDomElem) {
             oDomElem.appendChild(marker.domObj);
@@ -344,7 +374,7 @@
     onKeyPress: function(e) {
         var charCode = (e.charCode ) ? e.charCode : ((e.keyCode) ? e.keyCode : e.which);
         if (charCode == OpenLayers.Event.KEY_ESC) {
@@ -352,12 +382,12 @@
             this.activate();
      * (public) initVars()
      * reset area and/or distance vars
     initVars: function() {
         this.cumulativeDistance = 0;
         this.lastDistance = 0;
@@ -365,7 +395,7 @@
         this.lastArea = 0;
         this.aAreaFirstPoint = null;
     activate: function() {
         this.control.activate();
@@ -374,7 +404,7 @@
         //roll back this in GrandPrix branch
         //this.getMap().supressContextMenu(true);
     loadDisplayPanel: function() {
         if (this.sTarget) {
             var url = this.sBaseUrl;
@@ -385,7 +415,7 @@
                 url += '&';
             url += queryStr + '&type='+this.measureType;
             var taskPaneTarget = Fusion.getWidgetById(this.sTarget);
             var outputWin = window;
             if ( taskPaneTarget ) {
@@ -394,37 +424,37 @@
             } else {
                 outputWin = window.open(url, this.sTarget, this.sWinFeatures);
-            this.registerForEvent(Fusion.Event.MEASURE_CLEAR, OpenLayers.Function.bind(this.clearDisplay, this, outputWin));
+            this.registerForEvent(Fusion.Event.MEASURE_CLEAR, OpenLayers.Function.bind(this.clearDisplay, this, outputWin));
             this.registerForEvent(Fusion.Event.MEASURE_SEGMENT_UPDATE, OpenLayers.Function.bind(this.updateDisplay, this, outputWin));
             this.registerForEvent(Fusion.Event.MEASURE_COMPLETE, OpenLayers.Function.bind(this.updateDisplay, this, outputWin));
         } else {
             this.totalDistanceMarker = new Fusion.Widget.Measure.Marker(this.units, this.distPrecision, 'Total:');
-            if (!this.totalDistanceMarker.domObj.parentNode ||
+            if (!this.totalDistanceMarker.domObj.parentNode ||
                 this.totalDistanceMarker.domObj.parentNode != oDomElem) {
                 oDomElem.appendChild(this.totalDistanceMarker.domObj);
             this.totalDistanceMarker.domObj.addClass('divMeasureTotal');
             this.totalDistanceMarker.domObj.style.display = 'none';
-            this.registerForEvent(Fusion.Event.MEASURE_CLEAR, OpenLayers.Function.bind(this.clearTotalDistance, this));
+            this.registerForEvent(Fusion.Event.MEASURE_CLEAR, OpenLayers.Function.bind(this.clearTotalDistance, this));
             this.registerForEvent(Fusion.Event.MEASURE_SEGMENT_UPDATE, OpenLayers.Function.bind(this.updateTotalDistance, this));
             this.registerForEvent(Fusion.Event.MEASURE_COMPLETE, OpenLayers.Function.bind(this.updateTotalDistance, this));
      * (public) deactivate()
      * deactivate the ruler tool
     deactivate: function() {
-        OpenLayers.Event.stopObserving(document, 'keypress', this.keyHandler);
+        OpenLayers.Event.stopObserving(document, 'keypress', this.keyHandler);
         this.control.deactivate();
         this.control.cancel();
         //this.getMap().supressContextMenu(false);
     resetMeasure: function() {
         this.initVars();
         for (var i=0; i<this.distanceMarkers.length; i++)  {
@@ -462,7 +492,7 @@
         Fusion.ajaxRequest(s, options);
     remoteMeasureCompleted: function(from, to, marker, r) {
         if (r.status == 200) {
             var o;
@@ -476,14 +506,14 @@
               if (mapUnits != this.units) {
                 o.distance = Fusion.convert(mapUnits, this.units, o.distance);
               marker.setQuantity(o.distance);
               this.positionMarker(marker, from, to);
-              this.triggerEvent(Fusion.Event.MEASURE_SEGMENT_UPDATE);
+              this.triggerEvent(Fusion.Event.MEASURE_SEGMENT_UPDATE);
      * updates the summary display if it is loaded in a window somewhere
@@ -511,7 +541,7 @@
             td.innerHTML = value + ' ' + units;
             tr.appendChild(td);
-            tbody.appendChild(tr);
+            tbody.appendChild(tr);
             var tbody = outputDoc.getElementById('segmentTBody');
@@ -533,7 +563,7 @@
                 else {
                   value = totalDistance.toPrecision(this.distPrecision);
-                tDist.innerHTML = value + ' ' + units;
+                tDist.innerHTML = value + ' ' + units;
@@ -547,7 +577,7 @@
             tArea.innerHTML = value + ' ' + units + '<sup>2</sup>';
@@ -563,7 +593,7 @@
         this.totalDistanceMarker.setQuantity(totalDistance);
       *clears the summary display if it is loaded in a window somewhere
@@ -583,14 +613,14 @@
     clearTotalDistance: function() {
      * Callback method for the MAP_LOADED event
      * Set the units to whatever is specified in the AppDef, or the mapUnits if not specified
@@ -629,7 +659,7 @@
         this.label = label ? label:'';
         this.isArea = isArea || false;
         this.domObj = new Element('DIV', {});
        this.domObj.className = 'divMeasureMarker';
         this.calculatingImg = document.createElement('img');
         this.calculatingImg.src = Fusion.getFusionURL() + 'widgets/Measure/MeasurePending.gif';
@@ -638,23 +668,23 @@
         this.setUnits(units);
         this.setCalculating();
     destroy: function() {
       if (this.domObj.parentNode) {
           this.domObj.parentNode.removeChild(this.domObj);
-          this.domObj.style.display = 'none'; //Also hide it because Safari leaves the domObj on the page
+          this.domObj.style.display = 'none'; //Also hide it because Safari leaves the domObj on the page
     setUnits: function(units) {
         this.unit = units;
         this.unitAbbr = Fusion.unitAbbr(units);
     getQuantity: function() {
         return this.quantity;
     getQuantityLabel: function() {
       var value;
       if (this.precision == 0) {
@@ -669,7 +699,7 @@
       return this.label + ' ' + value + ' ' + this.unitAbbr + sq;
     setQuantity: function(quantity) {
         if (this.calculatingImg.parentNode) {
             this.calculatingImg.parentNode.removeChild(this.calculatingImg);
@@ -677,14 +707,14 @@
         this.quantity = quantity;
         this.domObj.innerHTML = this.getQuantityLabel();
     setCalculating: function() {
         if (!this.calculatingImg.parentNode) {
             this.domObj.innerHTML = '';
             this.domObj.appendChild(this.calculatingImg);
     getSize: function() {
         var size =  $(this.domObj).getBorderBoxSize();
         var imgSize = {width:19, height:4};
More information about the fusion-commits mailing list
