[fusion-commits] r2120 - trunk/widgets
svn_fusion at osgeo.org
Fri Mar 26 17:41:25 EDT 2010
Author: chrisclaydon
Date: 2010-03-26 17:41:24 -0400 (Fri, 26 Mar 2010)
New Revision: 2120
trunk/widgets/Measure.js
Fix #377 Reposition dimension markers for Measure widget when map view changes
Modified: trunk/widgets/Measure.js
--- trunk/widgets/Measure.js 2010-03-26 21:39:29 UTC (rev 2119)
+++ trunk/widgets/Measure.js 2010-03-26 21:41:24 UTC (rev 2120)
@@ -26,9 +26,9 @@
* Class: Fusion.Widget.Measure
- * The Measure widget allows the user to measure distances or areas on the map
+ * The Measure widget allows the user to measure distances or areas on the map
* in one or more segments. Area is positive if measured clockwise.
Fusion.Constant.MEASURE_TYPE_DISTANCE = 1;
@@ -41,12 +41,12 @@
Fusion.Widget.Measure = OpenLayers.Class(Fusion.Widget, {
isExclusive: true,
uiClass: Jx.Button,
//distance of each segment
distances: null,
distanceMarkers: null,
areaMarker: null,
/* the units to display distances in */
units: Fusion.UNKNOWN,
@@ -55,17 +55,17 @@
/* Precision of the distance displayed */
distPrecision: 4,
/* Precision of the area displayed */
areaPrecision: 4,
- /* Style for the distance line used for distance draw */
+ /* Style for the distance line used for distance draw */
distanceNormalStyle: null,
- /* Style for the polygon used for area draw */
+ /* Style for the polygon used for area draw */
fillStyle: null,
- /* Style for the polygon line used for area draw */
+ /* Style for the polygon line used for area draw */
areaStyle: null,
segmentLabels: true,
initializeWidget: function(widgetTag) {
@@ -73,13 +73,13 @@
var json = widgetTag.extension;
this.units = (json.Units && (json.Units[0] != '')) ? Fusion.unitFromName(json.Units[0]): this.units;
this.distPrecision = json.DistancePrecision ? parseInt(json.DistancePrecision[0]) : 4;
- this.areaPrecision = json.AreaPrecision ? parseInt(json.AreaPrecision[0]) : 4;
+ this.areaPrecision = json.AreaPrecision ? parseInt(json.AreaPrecision[0]) : 4;
if(json.SegmentLabels){
this.segmentLabels = (json.SegmentLabels[0].toLowerCase == "true" && json.SegmentLabels[0]) ? true : false;
this.sTarget = json.Target ? json.Target[0] : "";
this.sBaseUrl = Fusion.getFusionURL() + 'widgets/Measure/Measure.php';
//init measure type
this.measureType = 0;
if (json.Type) {
@@ -98,25 +98,25 @@
break;
//Here are the canvas style definition
var fillStyle = json.FillStyle ? json.FillStyle[0] : 'rgba(0,0,255, 0.3)';
var lineStyleWidth = json.LineStyleWidth ? json.LineStyleWidth[0] : 2;
- var lineStyleColor = json.LineStyleColor ? json.LineStyleColor[0] : 'rgba(0,0,255,0.3)';
+ var lineStyleColor = json.LineStyleColor ? json.LineStyleColor[0] : 'rgba(0,0,255,0.3)';
this.distanceMarkers = [];
this.distances = [];
this.registerEventID(Fusion.Event.MEASURE_SEGMENT_UPDATE);
this.registerEventID(Fusion.Event.MEASURE_CLEAR);
this.registerEventID(Fusion.Event.MEASURE_COMPLETE);
var mapWidget = this.getMap();
this.keyHandler = OpenLayers.Function.bind(this.onKeyPress, this);
Fusion.addWidgetStyleSheet(widgetTag.location + 'Measure/Measure.css');
mapWidget.registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.setUnits, this, this.units));
this.registerParameter('Units');
// style the sketch fancy
this.sketchSymbolizers = {
"Point": {
@@ -146,10 +146,10 @@
new OpenLayers.Rule({symbolizer: this.sketchSymbolizers})
var styleMap = new OpenLayers.StyleMap({"default": style});
//add in the OL Polygon handler
this.map = mapWidget.oMapOL;
- var handlerOptions = {
+ var handlerOptions = {
style: "default", // this forces default render intent
layerOptions: {styleMap: styleMap}
@@ -157,7 +157,7 @@
if (this.measureType & Fusion.Constant.MEASURE_TYPE_AREA) {
handler = OpenLayers.Handler.Polygon;
var controlOptions = {
persist: true,
handlerOptions: handlerOptions,
@@ -168,19 +168,49 @@
this.control = new OpenLayers.Control.Measure(handler, controlOptions);
this.getMap().oMapOL.addControl(this.control);
this.control.events.on({
measure: this.measure,
scope: this
+ this.getMap().registerForEvent(Fusion.Event.MAP_EXTENTS_CHANGED, OpenLayers.Function.bind(this.extentsChangedCB, this));
+ this.getMap().registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.extentsChangedCB, this));
+ extentsChangedCB : function() {
+ var olControl = this.control;
+ if(olControl && olControl.active)
+ var poly = olControl.handler;
+ var geom = poly.getGeometry();
+ if(geom)
+ this.updateMarkers(geom);
+ updateMarkers : function(geom) {
+ var v = geom.getVertices();
+ for(var i = 0; i < this.distanceMarkers.length; i++)
+ var seg = new OpenLayers.Geometry.LineString();
+ seg.addPoint(v[i].clone());
+ seg.addPoint(v[i+1].clone());
+ this.updateMarker(this.distanceMarkers[i], seg);
+ this.updateDistances(geom);
+ this.updateArea(geom);
shouldActivateWith: function(widget) {
return (widget instanceof Fusion.Widget.Measure &&
widget.measureType == this.measureType);
measure: function(stats) {
this.hasMeasure = true;
/* rebuild distance markers */
@@ -218,7 +248,7 @@
this.triggerEvent(Fusion.Event.MEASURE_COMPLETE);
measurePartial: function(point, sketch) {
if (this.hasMeasure) {
this.resetMeasure();
@@ -227,13 +257,13 @@
var geom = sketch.geometry;
if (this.measureType & Fusion.Constant.MEASURE_TYPE_DISTANCE) {
this.triggerEvent(Fusion.Event.MEASURE_SEGMENT_UPDATE);
updateDistances: function(geom) {
var last = v.length - 1;
@@ -261,19 +291,19 @@
updateArea: function(geom) {
if (!this.areaMarker) {
this.areaMarker = new Fusion.Widget.Measure.Marker(this.units, this.distPrecision, '', true);
this.updateMarker(this.areaMarker, geom);
delayUpdate: function(marker, geom) {
this.delayUpdateTimer = null;
this.updateMarker(marker, geom);
updateMarker: function(marker, geom) {
if (!marker) {
return;
@@ -289,10 +319,10 @@
to = this.getMap().geoToPix(v[1].x,v[1].y);
at = {x: (from.x + to.x) / 2, y: (from.y + to.y) / 2};
quantity = geom.getGeodesicLength(proj);
//calculate the length in pixels
pixQuantity = Math.sqrt((to.x - from.x) * (to.x - from.x) + (to.y - from.y) * (to.y - from.y));
measureUnits = Fusion.METERS;
if (measureUnits != this.units) {
quantity = Fusion.convert(measureUnits, this.units, quantity);
@@ -304,13 +334,13 @@
var cg = geom.getCentroid();
at = this.getMap().geoToPix(cg.x, cg.y);
quantity = geom.getGeodesicArea(proj);
var rate = Fusion.convert(measureUnits, this.units, 1);
quantity = quantity * rate * rate;
//calculate the area in square pixels
var resolution = this.getMap().getResolution();
pixQuantity = quantity / resolution / resolution;
@@ -322,10 +352,10 @@
this.positionMarker(marker, at);
positionMarker: function(marker, at) {
var oDomElem = this.getMap().getDomObj();
- if (!marker.domObj.parentNode ||
+ if (!marker.domObj.parentNode ||
marker.domObj.parentNode != oDomElem) {
oDomElem.appendChild(marker.domObj);
@@ -344,7 +374,7 @@
onKeyPress: function(e) {
var charCode = (e.charCode ) ? e.charCode : ((e.keyCode) ? e.keyCode : e.which);
if (charCode == OpenLayers.Event.KEY_ESC) {
@@ -352,12 +382,12 @@
this.activate();
* (public) initVars()
* reset area and/or distance vars
initVars: function() {
this.cumulativeDistance = 0;
this.lastDistance = 0;
@@ -365,7 +395,7 @@
this.lastArea = 0;
this.aAreaFirstPoint = null;
activate: function() {
this.control.activate();
@@ -373,7 +403,7 @@
this.loadDisplayPanel();
this.getMap().supressContextMenu(true);
loadDisplayPanel: function() {
if (this.sTarget) {
var url = this.sBaseUrl;
@@ -384,7 +414,7 @@
url += '&';
url += queryStr + '&type='+this.measureType;
var taskPaneTarget = Fusion.getWidgetById(this.sTarget);
var outputWin = window;
if ( taskPaneTarget ) {
@@ -393,36 +423,36 @@
} else {
outputWin = window.open(url, this.sTarget, this.sWinFeatures);
- this.registerForEvent(Fusion.Event.MEASURE_CLEAR, OpenLayers.Function.bind(this.clearDisplay, this, outputWin));
+ this.registerForEvent(Fusion.Event.MEASURE_CLEAR, OpenLayers.Function.bind(this.clearDisplay, this, outputWin));
this.registerForEvent(Fusion.Event.MEASURE_SEGMENT_UPDATE, OpenLayers.Function.bind(this.updateDisplay, this, outputWin));
this.registerForEvent(Fusion.Event.MEASURE_COMPLETE, OpenLayers.Function.bind(this.updateDisplay, this, outputWin));
} else {
this.totalDistanceMarker = new Fusion.Widget.Measure.Marker(this.units, this.distPrecision, 'Total:');
- if (!this.totalDistanceMarker.domObj.parentNode ||
+ if (!this.totalDistanceMarker.domObj.parentNode ||
this.totalDistanceMarker.domObj.parentNode != oDomElem) {
oDomElem.appendChild(this.totalDistanceMarker.domObj);
this.totalDistanceMarker.domObj.addClass('divMeasureTotal');
this.totalDistanceMarker.domObj.style.display = 'none';
- this.registerForEvent(Fusion.Event.MEASURE_CLEAR, OpenLayers.Function.bind(this.clearTotalDistance, this));
+ this.registerForEvent(Fusion.Event.MEASURE_CLEAR, OpenLayers.Function.bind(this.clearTotalDistance, this));
this.registerForEvent(Fusion.Event.MEASURE_SEGMENT_UPDATE, OpenLayers.Function.bind(this.updateTotalDistance, this));
this.registerForEvent(Fusion.Event.MEASURE_COMPLETE, OpenLayers.Function.bind(this.updateTotalDistance, this));
* (public) deactivate()
* deactivate the ruler tool
deactivate: function() {
- OpenLayers.Event.stopObserving(document, 'keypress', this.keyHandler);
+ OpenLayers.Event.stopObserving(document, 'keypress', this.keyHandler);
this.control.deactivate();
this.control.cancel();
this.getMap().supressContextMenu(false);
resetMeasure: function() {
this.initVars();
for (var i=0; i<this.distanceMarkers.length; i++) {
@@ -460,7 +490,7 @@
Fusion.ajaxRequest(s, options);
remoteMeasureCompleted: function(from, to, marker, r) {
if (r.status == 200) {
var o;
@@ -474,14 +504,14 @@
if (mapUnits != this.units) {
o.distance = Fusion.convert(mapUnits, this.units, o.distance);
marker.setQuantity(o.distance);
this.positionMarker(marker, from, to);
- this.triggerEvent(Fusion.Event.MEASURE_SEGMENT_UPDATE);
+ this.triggerEvent(Fusion.Event.MEASURE_SEGMENT_UPDATE);
* updates the summary display if it is loaded in a window somewhere
@@ -509,7 +539,7 @@
td.innerHTML = value + ' ' + units;
tr.appendChild(td);
- tbody.appendChild(tr);
+ tbody.appendChild(tr);
var tbody = outputDoc.getElementById('segmentTBody');
@@ -531,7 +561,7 @@
else {
value = totalDistance.toPrecision(this.distPrecision);
- tDist.innerHTML = value + ' ' + units;
+ tDist.innerHTML = value + ' ' + units;
@@ -545,7 +575,7 @@
tArea.innerHTML = value + ' ' + units + '<sup>2</sup>';
@@ -561,7 +591,7 @@
this.totalDistanceMarker.setQuantity(totalDistance);
*clears the summary display if it is loaded in a window somewhere
@@ -581,14 +611,14 @@
clearTotalDistance: function() {
* Callback method for the MAP_LOADED event
* Set the units to whatever is specified in the AppDef, or the mapUnits if not specified
@@ -627,7 +657,7 @@
this.label = label ? label:'';
this.isArea = isArea || false;
this.domObj = new Element('DIV', {});
this.domObj.className = 'divMeasureMarker';
this.calculatingImg = document.createElement('img');
this.calculatingImg.src = Fusion.getFusionURL() + 'widgets/Measure/MeasurePending.gif';
@@ -636,23 +666,23 @@
this.setUnits(units);
this.setCalculating();
destroy: function() {
if (this.domObj.parentNode) {
this.domObj.parentNode.removeChild(this.domObj);
- this.domObj.style.display = 'none'; //Also hide it because Safari leaves the domObj on the page
+ this.domObj.style.display = 'none'; //Also hide it because Safari leaves the domObj on the page
setUnits: function(units) {
this.unit = units;
this.unitAbbr = Fusion.unitAbbr(units);
getQuantity: function() {
return this.quantity;
getQuantityLabel: function() {
var value;
if (this.precision == 0) {
@@ -667,7 +697,7 @@
return this.label + ' ' + value + ' ' + this.unitAbbr + sq;
setQuantity: function(quantity) {
if (this.calculatingImg.parentNode) {
this.calculatingImg.parentNode.removeChild(this.calculatingImg);
@@ -675,14 +705,14 @@
this.quantity = quantity;
this.domObj.innerHTML = this.getQuantityLabel();
setCalculating: function() {
if (!this.calculatingImg.parentNode) {
this.domObj.innerHTML = '';
this.domObj.appendChild(this.calculatingImg);
getSize: function() {
var size = $(this.domObj).getBorderBoxSize();
var imgSize = {width:19, height:4};
More information about the fusion-commits
