[fusion-commits] r2121 - sandbox/adsk/2.2gp/text
svn_fusion at osgeo.org
Tue Mar 30 22:05:02 EDT 2010
Author: liuar
Date: 2010-03-30 22:05:00 -0400 (Tue, 30 Mar 2010)
New Revision: 2121
sandbox/adsk/2.2gp/text/en
sandbox/adsk/2.2gp/text/fr
Fixed ticket #380 Localization: localized text for Theme/Measure/Redline/Query/FeatureInfo doesn't display occasionally in adsk branch
Property changes on: sandbox/adsk/2.2gp/text/en
___________________________________________________________________
Added: svn:eol-style
+ native
Modified: sandbox/adsk/2.2gp/text/fr
--- sandbox/adsk/2.2gp/text/fr 2010-03-26 21:41:24 UTC (rev 2120)
+++ sandbox/adsk/2.2gp/text/fr 2010-03-31 02:05:00 UTC (rev 2121)
@@ -1,335 +1,335 @@
-# Web surround localized strings
-# English language
-# Important: This file must be saved with UTF-8 encoding
-# General
-# Fonts - the 6 following entries are mandatory
- at fontWindows = Arial
- at fontsizeWindows = 8pt
- at fontLinux = Arial
- at fontsizeLinux = 8pt
- at fontMacintosh = Arial
- at fontsizeMacintosh = 8pt
-# Distances
-DISTANCEMILES = Miles
-DISTANCEKILOMETERS = Kilometers
-DISTANCEFEET = Feet
-DISTANCEMETERS = Meters
-# Fill Patterns/Values
-FILLSOLID = Solid
-FILLNET = Net
-FILLLINE = Line
-FILLLINE45 = Line_45
-FILLLINE90 = Line_90
-FILLLINE135 = Line_135
-FILLSQUARE = Square
-FILLBOX = Box
-FILLCROSS = Cross
-FILLDASH = Dash
-FILLDOLMIT = Dolmit
-FILLHEX = Hex
-FILLSACNCR = Sacncr
-FILLSTEEL = Steel
-# Transparency
-TRANSPARENT = transparent
-# Line Styles/Values
-LINESOLID = Solid
-LINEDASH = Dash
-LINEDOT = Dot
-LINEDASHDOT = DashDot
-LINEDASHDOTDOT = DashDotDot
-LINERAIL = Rail
-LINEBORDER = Border
-LINEDIVIDE = Divide
-LINEFENCELINE = FenceLine
-# Buttons
-BUTTONOK = OK
-BUTTONDONE = Done
-BUTTONCANCEL = Cancel
-BUTTONREFRESH = Refresh
-BUTTONCLOSE = Close
-BUTTONCLEAR = Clear
-BUTTONSAVE = Save
-# Colors
-COLORRED = Red
-COLORGREEN = Green
-COLORBLUE = Blue
-# BufferReport
-BUFFERREPORTTITLE = Create Buffer
-BUFFERREPORTCREATED = %s has been created.
-BUFFERREPORTUPDATED = %s has been updated.
-BUFFERREPORTFEATURESSINGULAR = %s buffer feature was created.
-BUFFERREPORTFEATURESPLURAL = %s buffer features were created.
-BUFFERREPORTWARNINGSINGULAR = <b>Warning:</b> %s layer was excluded from buffer computation because its coordinate system is incompatible with the coordinate system of the map, or because it has no coordinate system at all
-BUFFERREPORTWARNINGPLURAL = <b>Warning:</b> %s layers were excluded from buffer computation because their coordinate systems are incompatible with the coordinate system of the map, or because they have no coordinate system at all
-BUFFERREPORTERRORTITLE = Buffer Error
-# Buffer
-BUFFERCLASSDESCR = Feature class for buffer layer
-BUFFERSCHEMADESCR = Temporary buffer schema
-BUFFERDIFFARBXY = Cannot compute a unique buffer around features with different 'Arbitrary X-Y' coordinate systems. Please uncheck the option 'Merge buffer areas' or select only one layer
-# BufferUI
-BUFFERTITLE = Create a Buffer
-BUFFERSUBTITLE = Buffer settings
-BUFFERINFOTEXT = Select features on the image.
-BUFFERDISTANCE = Distance around features:
-BUFFERLAYERS = Layers to include in the buffer:
-BUFFERNOLAYER = <No layer selected>
-BUFFERNAME = Name for the resulting buffer layer:
-BUFFERNAMETEXT = Buffer 1
-BUFFERMERGE = Merge buffer areas
-BUFFERFILLSTYLE = Fill style
-BUFFERFILLPATTERN = Fill pattern:
-BUFFERFOREGROUNDCOLOR = Foreground color:
-BUFFERTRANSPARENCY = Transparency:
-BUFFERBACKGROUNDCOLOR = Background color:
-BUFFERBORDERSTYLE = Border style
-BUFFERBORDERLINEPATTERN = Line pattern:
-BUFFERBORDERLINECOLOR = Line color:
-BUFFERBORDERLINETHICKNESS = Line thickness:
-BUFFERHELP = <li><p align="left">Results of the buffer are put into a new layer above the top feature layer. This buffer layer has the name you enter here.</li><li><p align="left">To create multiple buffer layers, use different buffer names.</li><li><p align="left">To hide buffer layers, turn them off.</li><li><p align="left">Buffer layers are temporary and are removed when you close the viewer.</li>
-BUFFERERRORZERODISTANCE = Please enter a nonzero distance.
-BUFFERERRORNOLAYERNAME = Please enter a layer name.
-BUFFERERRORNEGATIVETHICKNESS = Please enter positive or null thickness.
-BUFFERERRORNOSELECTION = Please select feature(s) to calculate a buffer around.
-# ColorPicker
-COLORPICKERDLGTITLE = Select a color
-COLORPICKERTITLE = Color palette
-COLORPICKERSUBTITLE = Specify a color
-COLORPICKER100TRANSPARENCY = 100%% transparency
-COLORPICKERHEXFORMAT = Hex format
-# MeasureUI
-MEASUREDISTANCETITLE = Measure Distance
-MEASUREAREATITLE = Measure Area
-MEASUREBOTHTITLE = Measure Distance And Area
-MEASUREINFO = Click a start and end point.
-RESUME = Resume
-STOP = Stop
-CLEAR = Clear
-MILES = Miles
-KILOMETERS = Kilometers
-MEASUREHELP = <li>To measure multiple distances, continue clicking new points.</li><li>To finish, click "Stop".</li><li>You can pan or zoom and continue measuring by clicking "Resume".</li><li>To start over, click "Clear".</li>
-SEGMENT = Segment
-TOTAL = Total
-LENGTH = Length
-TOTALLENGTH = Total Length
-TOTALAREA = Total Area
-MEASUREERROR = Measure Error
-# Measure
-MEASUREFEATURECLASS = Feature class for measure layer
-MEASURESCHEMADESCR = Temporary measure schema
-MEASUREPARTIAL = Partial
-MEASURETOTAL = total
-MEASURELAYER = Measure
-# FeatureInfoUI
-FEATUREINFOTITLE = Feature Information
-FEATUREINFOSUBTITLE = Select a Layer
-FEATUREINFOLAYER = Layer:
-FEATUREINFOSELECTFEATURE= Select Features:
-FEATUREINFODIGITIZE = Digitize:
-FEATUREINFOPOINT = Point
-FEATUREINFORECTANGLE = Rectangle
-FEATUREINFOPOLYGON = Polygon
-FEATUREINFOTOTAL = Total:
-FEATUREINFONOSELECTED = no features selected.
-FEATUREINFOERROR = Error
-FEATUREINFOFETCHINFO = fetching feature info ...
-FEATUREINFOFEATURESEL = features selected
-FEATUREINFOAREA = Area:
-FEATUREINFOAREAUNDEFINE = areaIdx undefined
-FEATUREINFONOINFO = no layer info
-FEATUREINFONOFEATUREIN = no features in selected layer.
-# QueryUI
-QUERYTITLE = Query Features
-QUERYSELECTLAYER = Select a Layer
-QUERYLAYER = Layer:
-QUERYPROPERTYFILTER = Property Filter
-QUERYPROPERTY = Property:
-QUERYOPERATOR = Operator:
-QUERYVALUE = Value:
-QUERYSPATIALFILTER = Spatial Filter
-QUERYDIGITIZE = Digitize:
-QUERYRECTANGLE = Rectangle
-QUERYPOLYGON = Polygon
-QUERYCLEAR = Clear
-QUERYOUTPUT = Output
-QUERYOUTPUTPROPERTY = Output property:
-QUERYEXECUTE = Execute
-QUERYMAXRESULT = Max results:
-QUERYRESULTS = Results
-QUERYSCALE = Scale:
-QUERYZOOM = Zoom
-QUERYSELECT = Select
-QUERYERROR = Error
-QUERYEQUALTO = Equal to
-QUERYNOTEQUALTO = Not equal to
-QUERYGREATTHAN = Greater than
-QUERYGREATTHANEQUAL = Greater than or equal to
-QUERYLESSTHAN = Less than
-QUERYLESSTHANEQUAL = Less than or equal to
-QUERYBEGIN = Begins with
-QUERYCONTAINS = Contains
-# Theme UI
-THEMETITLE = Theme Layer
-THEMESELECTLAYER = Select a Layer
-THEMELAYER = Layer:
-THEMENAME = Theme Name:
-THEMECONDITIONS = Define Conditions
-THEMEPROPERTY = Property:
-THEMEMIN = Min:
-THEMEMAX = Max:
-THEMEDISTRIBUTION = Distribution:
-THEMERULE = # of Rules:
-THEMESCALERANGE = Scale Range
-THEMESTYLERAMP = Style Ramp
-THEMEFILLTRANS = Fill Transparency:
-THEMEFILLCOLOR = Fill Color:
-THEMEFROM = From:
-THEMETO = To:
-THEMEBORDERCOLOR = Border Color:
-THEMEAPPLY = Apply
-THEMEERROR = Error
-THEMEINDIVIDUAL = Individual
-THEMEEQUAL = Equal
-THEMESTANDARD = Standard Deviation
-THEMEQUANTILE = Quantile
-THEMEJENKS = Jenks (Natural Breaks)
-# Redline UI
-REDLINEOPTIONS = Digitizing Options
-REDLINESELECTLAYER = Select Layer:
-REDLINENEW = New
-REDLINERENAME = Rename
-REDLINEREMOVE = Remove
-REDLINEDRAW = Draw:
-REDLINEPOINT = Point
-REDLINELINE = Line
-REDLINERECTANGLE = Rectangle
-REDLINEPOLYGON = Polygon
-REDLINESAVE = Save
-REDLINEUPLOAD = Upload
-REDLINEFEATURES = Features
-# HtmlViewerAbout
-HTMLABOUTTITLE = About %s
-HTMLABOUTTITLEBAR = MapGuide Viewer
-HTMLABOUTSERVERTITLE = MapGuide Server
-HTMLABOUTVIEWERTITLE = MapGuide Viewer
-HTMLABOUTSERVERVERSION = %s (Version %s)
-HTMLABOUTVIEWERVERSION = %s (Version %s)
-HTMLABOUTTEXT = <br>This product is made available subject to the terms of GNU Lesser General Public License Version 2.1 ("LGPL"). A copy of the LGPL, as well as additional copyright notices and license terms applicable to portions of this product are set forth in the <a href="../localized/license_en.htm" target="blank">license</a> file.<br><br>All trademarks and registered trademarks mentioned herein are the property of their respective owners.<br><br>Copyright © 2007 Autodesk, Inc.<br><br>
-HTMLABOUTLICENSE = license file
-HTMLABOUTLICENSEFILE = license_en.htm
-# LegendUI
-LEGENDLISTSEPARATOR = ,
-# PrintablePageUi
-PRINTTITLE = Get Printable Page
-PRINTELEMENTS = Select the elements to include in the print layout.
-PRINTPAGETITLE = Page title:
-PRINTLEGEND = Legend
-PRINTNORTHARROW = North arrow
-PRINTCREATEPAGE = Create Page
-# PropertyCtrl
-PROPERTIESNONE = None Selected
-PROPERTIESNAME = Name
-PROPERTIESVALUE = Value
-PROPERTIESITEMSEL = Items selected: {0}
-# Search
-SEARCHDLGTITLE = Search features
-SEARCHTITLE = Search results
-SEARCHERROR = Search error
-SEARCHREPORT = Search report
-SEARCHLAYERNOTFOUND = Layer {0} not found!
-SEARCHNOMULTIPROP = Multi-properties identity not supported yet
-SEARCHTYYPENOTSUP = Identity property type not supported yet ({0})
-SEARCHNOMATCHES = No matches.
-# SearchPrompt
-SEARCHPROMPTFIND = Find
-# SelectWithinUi
-SELECTWITHINTITLE = Select Within
-SELECTWITHINAREAS = Select areas on the image.
-SELECTWITHINRESTRICTION = Restrict results to selected layers:
-SELECTWITHINTEXT = <li>If you continue to select areas on the image, click "Refresh" to update the layer list.</li><li>To finish and select all features within the highlighted areas, click "Done".</li><li>To start over, click "Clear".</li>
-# Error/Report
-REPORTTITLE = Report
-# Legend UI
-REFRESH = Refresh
-EXPANDALL = Expand
-COLLAPSEALL = Collapse All
-DISPLAYALLINGROUP = Display All in Group
-HIDEALLINGROUP = Hide All in Group
-SHOWLONGTHEME = Show Long Theme
-# Task Bar
-TASKS = Tasks
-# Viewer Options
-OPTIONSTITLE = Viewer Options
-OPTIONSINFOTEXT = Select viewing options for status bar and tool tips.
-OPTIONSDISTANCE = Display distances in
-OPTIONSMETRIC = Metric (Kilometers, Meters)
-OPTIONSUSENGLISH = US/English (Miles, Feet)
-OPTIONSPOSITION = Display cursor position in
-OPTIONSLATLON = Latitude, Longitude (Degrees)
-OPTIONSMAPUNITS = Map Coordinate System (X,Y)
-# AJAX Viewer
-VIEWERLAYERS = Layers
-VIEWERPROPS = Properties
-VIEWERPANNORTH = Pan North
-VIEWERPANWEST = Pan West
-VIEWERPANSOUTH = Pan South
-VIEWERPANEAST = Pan East
-VIEWERZOOMIN = Zoom In
-VIEWERZOOMOUT = Zoom Out
-VIEWERMOVESLIDER = Drag to move slider
-VIEWERDRAGZOOM = Drag to zoom
-ENDSEL = CTRL + click to end
-ENDSELSAFARI = SHIFT + click to end
-DECIMALSEPARATOR = .
-THOUSANDSEPARATOR = ,
-# Main Frame
-NEEDLOGIN = You must enter a valid login ID and password to access this site
-ALREADYINMEASURE = Only one measure command is allowed in a web layout
-ACCESSDENIED = Access Denied
-LATLONCURPOS = Lat: {0}, Lon: {1}
-MAPUNITSCURPOS = X: {0}, Y: {1}
-FEATURESSELECTED = {0} features selected
-FEATURESELECTED = {0} feature selected
-MI = mi
-FT = ft
-IN = in
-KM = km
-MT = m
-CM = cm
-DIGALREADYRUNNING = Cannot execute measure: A digitization command is in progress.
-MEASALREADYRUNNING = Cannot execute digitization: A measure is in progress.
-# Localized Icon Files
+# Web surround localized strings
+# English language
+# Important: This file must be saved with UTF-8 encoding
+# General
+# Fonts - the 6 following entries are mandatory
+ at fontWindows = Arial
+ at fontsizeWindows = 8pt
+ at fontLinux = Arial
+ at fontsizeLinux = 8pt
+ at fontMacintosh = Arial
+ at fontsizeMacintosh = 8pt
+# Distances
+DISTANCEMILES = Miles
+DISTANCEKILOMETERS = Kilometers
+DISTANCEFEET = Feet
+DISTANCEMETERS = Meters
+# Fill Patterns/Values
+FILLSOLID = Solid
+FILLNET = Net
+FILLLINE = Line
+FILLLINE45 = Line_45
+FILLLINE90 = Line_90
+FILLLINE135 = Line_135
+FILLSQUARE = Square
+FILLBOX = Box
+FILLCROSS = Cross
+FILLDASH = Dash
+FILLDOLMIT = Dolmit
+FILLHEX = Hex
+FILLSACNCR = Sacncr
+FILLSTEEL = Steel
+# Transparency
+TRANSPARENT = transparent
+# Line Styles/Values
+LINESOLID = Solid
+LINEDASH = Dash
+LINEDOT = Dot
+LINEDASHDOT = DashDot
+LINEDASHDOTDOT = DashDotDot
+LINERAIL = Rail
+LINEBORDER = Border
+LINEDIVIDE = Divide
+LINEFENCELINE = FenceLine
+# Buttons
+BUTTONOK = OK
+BUTTONDONE = Done
+BUTTONCANCEL = Cancel
+BUTTONREFRESH = Refresh
+BUTTONCLOSE = Close
+BUTTONCLEAR = Clear
+BUTTONSAVE = Save
+# Colors
+COLORRED = Red
+COLORGREEN = Green
+COLORBLUE = Blue
+# BufferReport
+BUFFERREPORTTITLE = Create Buffer
+BUFFERREPORTCREATED = %s has been created.
+BUFFERREPORTUPDATED = %s has been updated.
+BUFFERREPORTFEATURESSINGULAR = %s buffer feature was created.
+BUFFERREPORTFEATURESPLURAL = %s buffer features were created.
+BUFFERREPORTWARNINGSINGULAR = <b>Warning:</b> %s layer was excluded from buffer computation because its coordinate system is incompatible with the coordinate system of the map, or because it has no coordinate system at all
+BUFFERREPORTWARNINGPLURAL = <b>Warning:</b> %s layers were excluded from buffer computation because their coordinate systems are incompatible with the coordinate system of the map, or because they have no coordinate system at all
+BUFFERREPORTERRORTITLE = Buffer Error
+# Buffer
+BUFFERCLASSDESCR = Feature class for buffer layer
+BUFFERSCHEMADESCR = Temporary buffer schema
+BUFFERDIFFARBXY = Cannot compute a unique buffer around features with different 'Arbitrary X-Y' coordinate systems. Please uncheck the option 'Merge buffer areas' or select only one layer
+# BufferUI
+BUFFERTITLE = Create a Buffer
+BUFFERSUBTITLE = Buffer settings
+BUFFERINFOTEXT = Select features on the image.
+BUFFERDISTANCE = Distance around features:
+BUFFERLAYERS = Layers to include in the buffer:
+BUFFERNOLAYER = <No layer selected>
+BUFFERNAME = Name for the resulting buffer layer:
+BUFFERNAMETEXT = Buffer 1
+BUFFERMERGE = Merge buffer areas
+BUFFERFILLSTYLE = Fill style
+BUFFERFILLPATTERN = Fill pattern:
+BUFFERFOREGROUNDCOLOR = Foreground color:
+BUFFERTRANSPARENCY = Transparency:
+BUFFERBACKGROUNDCOLOR = Background color:
+BUFFERBORDERSTYLE = Border style
+BUFFERBORDERLINEPATTERN = Line pattern:
+BUFFERBORDERLINECOLOR = Line color:
+BUFFERBORDERLINETHICKNESS = Line thickness:
+BUFFERHELP = <li><p align="left">Results of the buffer are put into a new layer above the top feature layer. This buffer layer has the name you enter here.</li><li><p align="left">To create multiple buffer layers, use different buffer names.</li><li><p align="left">To hide buffer layers, turn them off.</li><li><p align="left">Buffer layers are temporary and are removed when you close the viewer.</li>
+BUFFERERRORZERODISTANCE = Please enter a nonzero distance.
+BUFFERERRORNOLAYERNAME = Please enter a layer name.
+BUFFERERRORNEGATIVETHICKNESS = Please enter positive or null thickness.
+BUFFERERRORNOSELECTION = Please select feature(s) to calculate a buffer around.
+# ColorPicker
+COLORPICKERDLGTITLE = Select a color
+COLORPICKERTITLE = Color palette
+COLORPICKERSUBTITLE = Specify a color
+COLORPICKER100TRANSPARENCY = 100%% transparency
+COLORPICKERHEXFORMAT = Hex format
+# MeasureUI
+MEASUREDISTANCETITLE = Measure Distance
+MEASUREAREATITLE = Measure Area
+MEASUREBOTHTITLE = Measure Distance And Area
+MEASUREINFO = Click a start and end point.
+RESUME = Resume
+STOP = Stop
+CLEAR = Clear
+MILES = Miles
+KILOMETERS = Kilometers
+MEASUREHELP = <li>To measure multiple distances, continue clicking new points.</li><li>To finish, click "Stop".</li><li>You can pan or zoom and continue measuring by clicking "Resume".</li><li>To start over, click "Clear".</li>
+SEGMENT = Segment
+TOTAL = Total
+LENGTH = Length
+TOTALLENGTH = Total Length
+TOTALAREA = Total Area
+MEASUREERROR = Measure Error
+# Measure
+MEASUREFEATURECLASS = Feature class for measure layer
+MEASURESCHEMADESCR = Temporary measure schema
+MEASUREPARTIAL = Partial
+MEASURETOTAL = total
+MEASURELAYER = Measure
+# FeatureInfoUI
+FEATUREINFOTITLE = Feature Information
+FEATUREINFOSUBTITLE = Select a Layer
+FEATUREINFOLAYER = Layer:
+FEATUREINFOSELECTFEATURE= Select Features:
+FEATUREINFODIGITIZE = Digitize:
+FEATUREINFOPOINT = Point
+FEATUREINFORECTANGLE = Rectangle
+FEATUREINFOPOLYGON = Polygon
+FEATUREINFOTOTAL = Total:
+FEATUREINFONOSELECTED = no features selected.
+FEATUREINFOERROR = Error
+FEATUREINFOFETCHINFO = fetching feature info ...
+FEATUREINFOFEATURESEL = features selected
+FEATUREINFOAREA = Area:
+FEATUREINFOAREAUNDEFINE = areaIdx undefined
+FEATUREINFONOINFO = no layer info
+FEATUREINFONOFEATUREIN = no features in selected layer.
+# QueryUI
+QUERYTITLE = Query Features
+QUERYSELECTLAYER = Select a Layer
+QUERYLAYER = Layer:
+QUERYPROPERTYFILTER = Property Filter
+QUERYPROPERTY = Property:
+QUERYOPERATOR = Operator:
+QUERYVALUE = Value:
+QUERYSPATIALFILTER = Spatial Filter
+QUERYDIGITIZE = Digitize:
+QUERYRECTANGLE = Rectangle
+QUERYPOLYGON = Polygon
+QUERYCLEAR = Clear
+QUERYOUTPUT = Output
+QUERYOUTPUTPROPERTY = Output property:
+QUERYEXECUTE = Execute
+QUERYMAXRESULT = Max results:
+QUERYRESULTS = Results
+QUERYSCALE = Scale:
+QUERYZOOM = Zoom
+QUERYSELECT = Select
+QUERYERROR = Error
+QUERYEQUALTO = Equal to
+QUERYNOTEQUALTO = Not equal to
+QUERYGREATTHAN = Greater than
+QUERYGREATTHANEQUAL = Greater than or equal to
+QUERYLESSTHAN = Less than
+QUERYLESSTHANEQUAL = Less than or equal to
+QUERYBEGIN = Begins with
+QUERYCONTAINS = Contains
+# Theme UI
+THEMETITLE = Theme Layer
+THEMESELECTLAYER = Select a Layer
+THEMELAYER = Layer:
+THEMENAME = Theme Name:
+THEMECONDITIONS = Define Conditions
+THEMEPROPERTY = Property:
+THEMEMIN = Min:
+THEMEMAX = Max:
+THEMEDISTRIBUTION = Distribution:
+THEMERULE = # of Rules:
+THEMESCALERANGE = Scale Range
+THEMESTYLERAMP = Style Ramp
+THEMEFILLTRANS = Fill Transparency:
+THEMEFILLCOLOR = Fill Color:
+THEMEFROM = From:
+THEMETO = To:
+THEMEBORDERCOLOR = Border Color:
+THEMEAPPLY = Apply
+THEMEERROR = Error
+THEMEINDIVIDUAL = Individual
+THEMEEQUAL = Equal
+THEMESTANDARD = Standard Deviation
+THEMEQUANTILE = Quantile
+THEMEJENKS = Jenks (Natural Breaks)
+# Redline UI
+REDLINEOPTIONS = Digitizing Options
+REDLINESELECTLAYER = Select Layer:
+REDLINENEW = New
+REDLINERENAME = Rename
+REDLINEREMOVE = Remove
+REDLINEDRAW = Draw:
+REDLINEPOINT = Point
+REDLINELINE = Line
+REDLINERECTANGLE = Rectangle
+REDLINEPOLYGON = Polygon
+REDLINESAVE = Save
+REDLINEUPLOAD = Upload
+REDLINEFEATURES = Features
+# HtmlViewerAbout
+HTMLABOUTTITLE = About %s
+HTMLABOUTTITLEBAR = MapGuide Viewer
+HTMLABOUTSERVERTITLE = MapGuide Server
+HTMLABOUTVIEWERTITLE = MapGuide Viewer
+HTMLABOUTSERVERVERSION = %s (Version %s)
+HTMLABOUTVIEWERVERSION = %s (Version %s)
+HTMLABOUTTEXT = <br>This product is made available subject to the terms of GNU Lesser General Public License Version 2.1 ("LGPL"). A copy of the LGPL, as well as additional copyright notices and license terms applicable to portions of this product are set forth in the <a href="../localized/license_en.htm" target="blank">license</a> file.<br><br>All trademarks and registered trademarks mentioned herein are the property of their respective owners.<br><br>Copyright © 2007 Autodesk, Inc.<br><br>
+HTMLABOUTLICENSE = license file
+HTMLABOUTLICENSEFILE = license_en.htm
+# LegendUI
+LEGENDLISTSEPARATOR = ,
+# PrintablePageUi
+PRINTTITLE = Get Printable Page
+PRINTELEMENTS = Select the elements to include in the print layout.
+PRINTPAGETITLE = Page title:
+PRINTLEGEND = Legend
+PRINTNORTHARROW = North arrow
+PRINTCREATEPAGE = Create Page
+# PropertyCtrl
+PROPERTIESNONE = None Selected
+PROPERTIESNAME = Name
+PROPERTIESVALUE = Value
+PROPERTIESITEMSEL = Items selected: {0}
+# Search
+SEARCHDLGTITLE = Search features
+SEARCHTITLE = Search results
+SEARCHERROR = Search error
+SEARCHREPORT = Search report
+SEARCHLAYERNOTFOUND = Layer {0} not found!
+SEARCHNOMULTIPROP = Multi-properties identity not supported yet
+SEARCHTYYPENOTSUP = Identity property type not supported yet ({0})
+SEARCHNOMATCHES = No matches.
+# SearchPrompt
+SEARCHPROMPTFIND = Find
+# SelectWithinUi
+SELECTWITHINTITLE = Select Within
+SELECTWITHINAREAS = Select areas on the image.
+SELECTWITHINRESTRICTION = Restrict results to selected layers:
+SELECTWITHINTEXT = <li>If you continue to select areas on the image, click "Refresh" to update the layer list.</li><li>To finish and select all features within the highlighted areas, click "Done".</li><li>To start over, click "Clear".</li>
+# Error/Report
+REPORTTITLE = Report
+# Legend UI
+REFRESH = Refresh
+EXPANDALL = Expand
+COLLAPSEALL = Collapse All
+DISPLAYALLINGROUP = Display All in Group
+HIDEALLINGROUP = Hide All in Group
+SHOWLONGTHEME = Show Long Theme
+# Task Bar
+TASKS = Tasks
+# Viewer Options
+OPTIONSTITLE = Viewer Options
+OPTIONSINFOTEXT = Select viewing options for status bar and tool tips.
+OPTIONSDISTANCE = Display distances in
+OPTIONSMETRIC = Metric (Kilometers, Meters)
+OPTIONSUSENGLISH = US/English (Miles, Feet)
+OPTIONSPOSITION = Display cursor position in
+OPTIONSLATLON = Latitude, Longitude (Degrees)
+OPTIONSMAPUNITS = Map Coordinate System (X,Y)
+# AJAX Viewer
+VIEWERLAYERS = Layers
+VIEWERPROPS = Properties
+VIEWERPANNORTH = Pan North
+VIEWERPANWEST = Pan West
+VIEWERPANSOUTH = Pan South
+VIEWERPANEAST = Pan East
+VIEWERZOOMIN = Zoom In
+VIEWERZOOMOUT = Zoom Out
+VIEWERMOVESLIDER = Drag to move slider
+VIEWERDRAGZOOM = Drag to zoom
+ENDSEL = CTRL + click to end
+ENDSELSAFARI = SHIFT + click to end
+DECIMALSEPARATOR = .
+THOUSANDSEPARATOR = ,
+# Main Frame
+NEEDLOGIN = You must enter a valid login ID and password to access this site
+ALREADYINMEASURE = Only one measure command is allowed in a web layout
+ACCESSDENIED = Access Denied
+LATLONCURPOS = Lat: {0}, Lon: {1}
+MAPUNITSCURPOS = X: {0}, Y: {1}
+FEATURESSELECTED = {0} features selected
+FEATURESELECTED = {0} feature selected
+MI = mi
+FT = ft
+IN = in
+KM = km
+MT = m
+CM = cm
+DIGALREADYRUNNING = Cannot execute measure: A digitization command is in progress.
+MEASALREADYRUNNING = Cannot execute digitization: A measure is in progress.
+# Localized Icon Files
Property changes on: sandbox/adsk/2.2gp/text/fr
+ native
More information about the fusion-commits
