[fusion-commits] r2122 - sandbox/adsk/2.2gp/lib/OpenLayers
svn_fusion at osgeo.org
Tue Mar 30 22:31:03 EDT 2010
Author: liuar
Date: 2010-03-30 22:31:02 -0400 (Tue, 30 Mar 2010)
New Revision: 2122
sandbox/adsk/2.2gp/lib/OpenLayers/OpenLayers.js
Integrate the new version of SVG.js in OpenLayers.js which fixed http://trac.openlayers.org/ticket/2402
Modified: sandbox/adsk/2.2gp/lib/OpenLayers/OpenLayers.js
--- sandbox/adsk/2.2gp/lib/OpenLayers/OpenLayers.js 2010-03-31 02:05:00 UTC (rev 2121)
+++ sandbox/adsk/2.2gp/lib/OpenLayers/OpenLayers.js 2010-03-31 02:31:02 UTC (rev 2122)
@@ -11043,6 +11043,14 @@
isGecko: null,
+ * Property: supportUse
+ * {Boolean} true if defs/use is supported - known to not work as expected
+ * at least in some applewebkit/5* builds.
+ * See https://bugs.webkit.org/show_bug.cgi?id=33322
+ supportUse: null,
* Constructor: OpenLayers.Renderer.SVG
* Parameters:
@@ -11055,6 +11063,7 @@
OpenLayers.Renderer.Elements.prototype.initialize.apply(this,
arguments);
this.translationParameters = {x: 0, y: 0};
+ this.supportUse = (navigator.userAgent.toLowerCase().indexOf("applewebkit/5") == -1);
this.isGecko = (navigator.userAgent.toLowerCase().indexOf("gecko/") != -1);
@@ -11198,7 +11207,7 @@
if (style.externalGraphic) {
nodeType = "image";
} else if (this.isComplexSymbol(style.graphicName)) {
- nodeType = "use";
+ nodeType = this.supportUse === false ? "svg" : "use";
} else {
nodeType = "circle";
@@ -11278,7 +11287,6 @@
var offset = style.pointRadius * 3;
var size = offset * 2;
var id = this.importSymbol(style.graphicName);
- var href = "#" + id;
pos = this.getPosition(node);
widthFactor = this.symbolSize[id] / size;
@@ -11290,7 +11298,17 @@
parent.removeChild(node);
- node.setAttributeNS(this.xlinkns, "href", href);
+ if(this.supportUse === false) {
+ // workaround for webkit versions that cannot do defs/use
+ // (see https://bugs.webkit.org/show_bug.cgi?id=33322):
+ // copy the symbol instead of referencing it
+ var src = document.getElementById(id);
+ node.firstChild && node.removeChild(node.firstChild);
+ node.appendChild(src.firstChild.cloneNode(true));
+ node.setAttributeNS(null, "viewBox", src.getAttributeNS(null, "viewBox"));
+ } else {
+ node.setAttributeNS(this.xlinkns, "href", "#" + id);
node.setAttributeNS(null, "width", size);
node.setAttributeNS(null, "height", size);
node.setAttributeNS(null, "x", pos.x - offset);
@@ -11308,9 +11326,16 @@
if (typeof style.rotation != "undefined" && pos) {
- var rotation = OpenLayers.String.format(
- "rotate(${0} ${1} ${2})", [style.rotation, pos.x, pos.y]);
- node.setAttributeNS(null, "transform", rotation);
+ if(node.nodeName !== "svg") {
+ node.setAttributeNS(null, "transform",
+ "rotate(" + style.rotation + " " + pos.x + " " +
+ pos.y + ")");
+ } else {
+ var symbolCenter = 0.5 * this.symbolSize[id] / 3;
+ node.firstChild.setAttributeNS(null, "transform",
+ "rotate(" + style.rotation + " " + symbolCenter +
+ " " + symbolCenter + ")");
@@ -11358,8 +11383,8 @@
dashStyle: function(style, widthFactor) {
var w = style.strokeWidth * widthFactor;
- switch (style.strokeDashstyle) {
+ var str = style.strokeDashstyle;
+ switch (str) {
case 'solid':
return 'none';
case 'dot':
@@ -11373,7 +11398,7 @@
case 'longdashdot':
return [8 * w, 4 * w, 1, 4 * w].join();
default:
- return style.strokeDashstyle.replace(/ /g, ",");
+ return OpenLayers.String.trim(str).replace(/\s+/g, ",");
@@ -11663,7 +11688,6 @@
label.setAttributeNS(null, "x", x);
label.setAttributeNS(null, "y", -y);
- label.setAttributeNS(null, "pointer-events", "none");
if (style.fontColor) {
label.setAttributeNS(null, "fill", style.fontColor);
@@ -11677,6 +11701,15 @@
if (style.fontWeight) {
label.setAttributeNS(null, "font-weight", style.fontWeight);
+ if(style.labelSelect === true) {
+ label.setAttributeNS(null, "pointer-events", "visible");
+ label._featureId = featureId;
+ tspan._featureId = featureId;
+ tspan._geometry = location;
+ tspan._geometryClass = location.CLASS_NAME;
+ } else {
+ label.setAttributeNS(null, "pointer-events", "none");
var align = style.labelAlign || "cm";
label.setAttributeNS(null, "text-anchor",
OpenLayers.Renderer.SVG.LABEL_ALIGN[align[0]] || "middle");
@@ -11888,6 +11921,26 @@
this.defs.appendChild(symbolNode);
return symbolNode.id;
+ * Method: getFeatureIdFromEvent
+ * Parameters:
+ * evt - {Object} An <OpenLayers.Event> object
+ * Returns:
+ * {<OpenLayers.Geometry>} A geometry from an event that
+ * happened on a layer.
+ getFeatureIdFromEvent: function(evt) {
+ var featureId = OpenLayers.Renderer.Elements.prototype.getFeatureIdFromEvent.apply(this, arguments);
+ if(this.supportUse === false && !featureId) {
+ var target = evt.target;
+ featureId = target.parentNode && target != this.rendererRoot &&
+ target.parentNode._featureId;
+ return featureId;
CLASS_NAME: "OpenLayers.Renderer.SVG"
More information about the fusion-commits
